H3C Magic BS200 Series GE Switch Installation Guide-5W100
HomeSupportInstall & UpgradeInstallation GuidesH3C Magic BS200 Series GE Switch Installation Guide-5W100
01-Hardware Information and Specifications
01-Hardware Information and Specifications 692.21 KB
1 Introduction
Overview
H3C Magic BS200 Switch Series (hereinafter referred to as BS200) are a portfolio of GE cloud-managed network switches.
The switch, adopting a brand new software and hardware platform, supports one-key switching among four operating modes (standard switch, port isolation, uplink aggregation, and network clone), providing an effective response to a variety of complex network environments. The switch, featuring easy installation and abundant service features, also can be managed and maintained in a unified manner through a cloud network (cloud + gateway), making it applicable to small and micro enterprises, commercial chains, hotels, and campuses.
Product models
Table1-1 describes the models of the BS200 Ethernet switch series.
Table1-1 Switch models
Series
Model
Short name
Magic BS200 series
Non-PoE switch models
H3C Magic BS216
BS216
H3C Magic BS224
BS224
PoE switch models
H3C Magic BS218F-HP
BS218F-HP
Technical specifications
Table1-2 Technical specifications for non-PoE switch models of Magic BS200 Ethernet Switch Series
Item
BS216
BS224
Dimensions (H × W × D)
294 × 179 × 43.6 mm (11.57 × 7.05 × 1.72 in)
Weight
≤ 1.3 kg (2.87 lb)
10/100/1000BASE-T autosensing Ethernet port
16 (including 2 Uplink ports)
24 (including 2 Uplink ports)
Input voltage
100 V to 240 V AC, 50 or 60 Hz
Minimum power consumption
7.8 W
Maximum power consumption
≤ 11 W
≤ 16.5 W
Working mode
Supporting 4 operating models, including standard, isolation, aggregation, and clone
Cooling system
Natural cooling
Chassis leakage current compliance
EN/IEC 62368-1
Operating temperature
0°C to 40°C (32°F to 104°F)
Operating humidity
5% to 95%, noncondensing
Fire resistance compliance
EN/IEC 62368-1
Table1-3 Technical specifications for PoE switch models of Magic BS200 Ethernet Switch Series
Item
BS218F-HP
440 × 210 × 43.6 mm (17.32 × 8.27 × 1.72 in)
Weight
≤ 2.4 kg (5.29 lb)
1000Base-X SFP port
2 (Uplink ports)
Input voltage
Maximum PoE power per port
30 W
Total PoE power
225 W
20 W
Maximum power consumption (including PoE power consumption)
≤ 255 W (including 225 W total PoE power)
Working mode
Cooling system
Cooling with fan
EN/IEC 62368-1
Operating humidity
EN/IEC 62368-1
2 Chassis view
BS216 switch
Figure2-1 BS216 front panel
(1): Ethernet port LED
(2): 10/100/1000Base-T Ethernet port
(3): 10/100/1000Base-T Ethernet port (Uplink port)
(4): Function key
(5): Mode LED
(6): Power status LED (Power)
Figure2-2 BS216 rear panel
(1): AC-input power receptacle
(2): Grounding screw
BS218F-HP switch
Figure2-3 BS218F-HP front panel
(2): PoE status LED
(4): 10/100/1000Base-T Ethernet port (Uplink port)
(5): 1000Base-X SFP optical port (Uplink port)
(6): Function key
(7): Mode LED
(8): PoE MAX status LED
(9): Power status LED (Power)
(10): Optical port status LED
Figure2-4 BS218F-HP rear panel
BS224 switch
Figure2-5 BS224 front panel
(4): Function key
(5): Mode LED
Figure2-6 BS224 rear panel
3 Ports and LEDs
Ports
Function key
The switch series provide a function key for selecting one operating mode among the 4 operating modes. The default operating mode is "standard switch".
Operation instructions
The function key employs an anti-miscontact design. Table3-1 describes the instructions for using the function key.
Table3-1 Operation instructions
Operation
Unlock button
Press and hold the function key for 3 seconds to unlock the function key. Then, the mode LED flashes.
Mode switch/taking effect
After the function key is unlocked, press it once to switch to another operating mode. After the function key is pressed, a corresponding mode LED is on.
The mode is selected when 5 seconds elapse after the function key is pressed. In this case, the mode LED becomes steady, the mode takes effect, and the function key becomes locked again.
Factory reset
Press and hold the function key for more than 10 seconds until the 4 mode LEDs are on. In this case, the device will restore its factory setting and automatically reboot.
Mode description
Table3-2 describes the 4 operating modes.
Table3-2 Mode description
Working mode
Application
Standard switch
Enable traffic control and port negotiation.
Serve as one standard full GE switch.
Port isolation
Enable layer-2 isolation between downlink ports so that each port can communicate only with its Uplink ports.
Apply to scenarios with high privacy requirements for downlink network, reduce broadcasting storms, and isolate DHCP broadcasting. For example, isolate hosts in an Internet cafe.
Uplink aggregation
Enable traffic control and port negotiation, and provide port trunking for 2 Uplink optical ports or 2 Uplink electrical ports (source MAC + target MAC, static trunking).
WARNING!
In this case, the peer device port of the Uplink port also requires static trunking. Otherwise, a loop may occur.
Apply to the requirements for expanding bandwidth when the network bandwidth is inadequate, without replacing a device.
Network clone
Disable traffic control, but enable port negotiation.
Apply to the "network clone" application scenario mode.
·     Traffic control: When a local port receives a packet that is faster than a line speed from a remote end, the local port will automatically send flow control frames to the remote port to request the remote port to reduce the transmitting speed, thus ensuring proper communication.
·     Port negotiation: Negotiate on the transmitting speed before communication, to keep the speed consistent between the two ports. The port speed of the local device can be reduced by enabling port negotiation when it is higher than that of the remote port, to ensure proper communication.
·     Port trunking: Static trunking is applied for the two Uplink ports to form a trunking group, in which each port undertake loads based on source MAC + target MAC of received data.
10/100/1000BASE-T Ethernet port
The Ethernet switch series provide 10/100/1000BASE-T autosensing Ethernet ports. Each device provides two 10/100/1000Base-T Ethernet ports (Uplink ports) as its uplink interfaces.
Table3-3 describes the specifications of the 10/100/1000BASE-T Ethernet port.
Table3-3 Specifications of the 10/100/1000BASE-T Ethernet port
Item
Connector type
RJ-45
Specification
·     10 Mbit/s, half/full duplex
·     100 Mbit/s, half/full duplex
·     1,000 Mbit/s, full duplex
·     MDI/MDI-X autosensing
Maximum transmission distance
100 m
Transmission medium
Category-5 (or above) twisted pair cable
Compatible standards
IEEE 802.3i, 802.3u, 802.3ab
SFP optical port
Some models of the switch series provide SFP ports which support GE SFP transceiver modules or GE SFP cables listed in Table3-4.
Table3-4 GE SFP transceiver modules and cables
Transceiver module
Module name
Center wavelength
Connector
Cable specifications
Maximum Transmission Distance
1000BASE-SX-SFP
850nm
LC
50/125µm multi-mode fiber
550 m
62.5/125µm multi-mode fiber
275 m
1000BASE-LX-SFP
1310 nm
LC
9/125µm single-mode fiber
10 km
1000BASE-LH-SFP
40 km
1000BASE-ZX-LR-SFP
1550nm
LC
40 km
1000BASE-ZX-VR-SFP
70 km
·     H3C SFP transceiver modules and cables are recommended.
·     The H3C SFP transceiver modules and cables available for the SFP ports are subject to change over time. For the most up-to-date list of H3C SFP transceiver modules and cables available for the SFP ports, contact your H3C sales representative or technical support engineer.
LEDs
Power status LED
The power status LED shows the operating status of the switch. See Table3-5 for more information.
Table3-5 Power status LED description
LED mark
Status
Power
Steady green
The switch has been powered on, and the power module operates properly.
Flashing green
The switch is powering on and self-checking.
Off
The switch is powered off or the power module has failed.
Mode LED
The 4 mode LEDs show the current operating mode of the device. See Table3-6 for more information.
Table3-6 Description for the mode LED
LED mark
Status
Standard
Isolation
Aggregation
Clone
Steady green
The mode has taken effect.
Flashing green
The operating mode is being selected.
Off
The mode hasn't taken effect.
10/100/1000BASE-T Ethernet port LED
Each Ethernet port of one switch has an LED, the Link/Act LED. Table3-7 describes the Link/Act LED.
Table3-7 10/100/1000BASE-T Ethernet port LED
LED mark
Status
Link/Act
Steady green
The port is operating at 1,000 Mbps.
The port is properly connected to a remote device.
Flashing green
The port, operating at 1,000 Mbps, is receiving/sending data.
Steady yellow
The port, operating at 10/100 Mbps, is properly connected to a remote device.
Flashing yellow
The port, operating at 10/100Mbps, is receiving/sending data.
Off
The port is not connected to a remote device or the port connection has failed.
SFP optical port status LED
Some models of the switch series provide SFP optical ports. Table3-8 describes the SFP optical port status LEDs.
Table3-8 SFP optical interface status LED
Switch model
Status
BS218F-HP
Steady green
The port, operating at 1,000 Mbps, is properly connected to a remote device.
Flashing green
Off
PoE status LED
Some PoE models of the switch series provide PoE status LEDs. Table3-9 describes the PoE status LEDs.
Table3-9 PoE status LED
Switch model
LED mark
Status
BS218F-HP
PoE status
Steady yellow
Power supply to a remote device is proper.
Flashing yellow
Power supply to a remote device is improper.
Off
No power supply to a remote device.
PoE MAX status LED
Some PoE models of the switch series provide PoE MAX LEDs. Table3-10 describes the PoE MAX LED.
Table3-10 PoE MAX status LED
Switch model
LED mark
Status
BS218F-HP
PoE-MAX
Steady yellow
The power is within its protection power range:
·     The BS218F-HP protection power ranges from 205 W to 225 W.
Off
The power does not reach the lower limit of the protection power range.
4 Cooling system
With an efficient cooling system, the switch ensures that the heat generated can be discharged in time to improve its stability. Install the switch by considering the ventilation conditions of the environment.
Some models of the switch series are provided with fixed fans:
·     BS218F-HP: Cooling air flows in from the right side of the chassis and the port and flows out from the left side of the chassis (views of the user facing the side panel of the device port).
Figure4-1 Cooling air flow (BS218F-HP)
