10-Network Management and Monitoring Command Reference
HomeSupportSwitchesS5150 SeriesReference GuidesCommand ReferencesH3C S5150-EI Switch Series Command References-Release 510x-6W10210-Network Management and Monitoring Command Reference
07-NETCONF commands
07-NETCONF commands 78.78 KB
NETCONF commands
netconf idle-timeout
Use netconf idle-timeout to set the NETCONF session idle timeout time.
Use undo netconf idle-timeout to restore the default.
netconf { soap | agent } idle-timeout minute
undo netconf { soap | agent } idle-timeout
The NETCONF session idle timeout time is 10 minutes for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
The NETCONF session idle timeout time is 0 minutes for NETCONF over SSH sessions, NETCONF over Telnet sessions, and NETCONF over console sessions. The sessions never time out.
soap: Specifies the NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
agent: Specifies the NETCONF over SSH sessions, NETCONF over Telnet sessions, and NETCONF over console sessions.
minute: Specifies the NETCONF session idle timeout time in minutes. The value range is as follows:
·     1 to 999 for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
·     0 to 999 for NETCONF over SSH sessions, NETCONF over Telnet sessions, and NETCONF over console sessions. The value of 0 indicates that the NETCONF sessions never time out.
If no NETCONF packets are exchanged between the device and a user within the NETCONF session idle timeout time, the device tears down the session.
# Set the NETCONF session idle timeout time to 20 minutes for NETCONF over SOAP over HTTP sessions and NETCONF over SOAP over HTTPS sessions.
[Sysname] netconf soap idle-timeout 20
netconf log
Use netconf log to enable NETCONF logging.
Use undo netconf log to remove the configuration for the specified NETCONF operation sources and NETCONF operations.
netconf log source { all | { agent | soap | web } * } { { protocol-operation { all | { action | config | get | session | set | syntax | others } * } } | verbose }
undo netconf log source { all | { agent | soap | web } * } { { protocol-operation { all | { action | config | get | session | set | syntax | others } * } } | verbose }
NETCONF logging is disabled.
source: Specifies a NETCONF operation source that represents clients that use a protocol.
·     all: Specifies NETCONF clients that use all protocols.
·     agent: Specifies clients that use Telnet, SSH, console, or NETCONF over SSH.
·     soap: Specifies clients that use SOAP over HTTP, or SOAP over HTTPS.
·     web: Specifies clients that use Web.
protocol-operation: Specifies a NETCONF operation type.
·     all: Specifies all NETCONF operations.
·     action: Specifies the action operation.
·     config: Specifies the configuration-related NETCONF operations, including the CLI, save, load, rollback, lock, unlock, and save-point operations.
·     get: Specifies the data retrieval-related NETCONF operations, including the get, get-config, get-bulk, get-bulk-config, and get-sessions operations.
·     session: Specifies session-related NETCONF operations, including the kill-session and close-session operations, and capability exchanges by hello messages.
·     set: Specifies all edit-config operations.
·     syntax: Specifies the requests that include XML and schema errors.
·     others: Specifies NETCONF operations except for those specified by keywords action, config, get, set, session, and syntax.
verbose: Logs detailed NETCONF information. For request operations, this keyword logs the texts of the requests after brief information. For service operations, this keyword takes effect only on edit-config operations. When an edit-config operation error occurs, this keyword logs detailed error information.
For NETCONF to correctly send the generated logs to the information center, you must also configure the information center. For information about information center configuration, see the network management and monitoring configuration guide for the device.
# Configure the device to log NETCONF edit-config information sourced from agent clients.
[Sysname] netconf log source agent protocol-operation set
netconf soap domain
Use netconf soap domain to specify a mandatory authentication domain for NETCONF users.
Use undo netconf soap domain to restore the default.
netconf soap domain domain-name
undo netconf soap domain domain-name
No mandatory authentication domain is specified for NETCONF users.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters. For information about ISP domains, see Security Configuration Guide.
You can use either of the following methods to specify an authentication domain:
·     Execute the netconf soap domain command to specify a mandatory authentication domain. After this command is executed, all NETCONF users are placed in the domain for authentication.
·     Add an authentication domain to the <UserName> parameter of a SOAP request. The authentication domain takes effect only on the current request.
The authentication domain specified by using this command takes precedence over the authentication domain specified by the <UserName> parameter of a SOAP request.
# Specify mandatory authentication domain my-domain for NETCONF users.
[Sysname] netconf soap domain my-domain
netconf soap http acl
Use netconf soap http acl to apply an ACL to control NETCONF over SOAP over HTTP access.
Use undo netconf soap http acl to restore the default.
netconf soap http acl { acl-number | name acl-name }
No ACL is applied to control NETCONF over SOAP over HTTP access.
acl-number: Specifies an ACL by its number in the range of 2000 to 2999.
name acl-name: Specifies an ACL by its name. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter. To avoid confusion, it cannot be all. The specified ACL must be an existing IPv4 basic ACL.
This command is not available in FIPS mode.
Only NETCONF clients permitted by the ACL can establish NETCONF over SOAP over HTTP sessions.
# Use ACL 2001 to allow only NETCONF clients in subnet 10.10.0.0/16 to establish NETCONF over SOAP over HTTP sessions.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] netconf soap http acl 2001
netconf soap http dscp
Use netconf soap http dscp to set the DSCP value for outgoing NETCONF over SOAP over HTTP packets.
Use undo netconf soap http dscp to restore the default.
netconf soap http dscp dscp-value
The DSCP value is 0 for outgoing NETCONF over SOAP over HTTP packets.
dscp-value: Specifies a DSCP value in the range of 0 to 63. A larger DSCP value represents a higher priority.
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet.
# Set the DSCP value to 30 for outgoing NETCONF over SOAP over HTTP packets.
[Sysname] netconf soap http dscp 30
netconf soap http enable
Use netconf soap http enable to enable NETCONF over SOAP over HTTP.
Use undo netconf soap http enable to disable NETCONF over SOAP over HTTP.
NETCONF over SOAP over HTTP is disabled.
This command enables the device to resolve NETCONF messages that are encapsulated with SOAP in HTTP packets.
# Enable NETCONF over SOAP over HTTP.
[Sysname] netconf soap http enable
netconf soap https acl
Use netconf soap https acl to apply an ACL to control NETCONF over SOAP over HTTPS access.
Use undo netconf soap https acl to restore the default.
netconf soap https acl { acl-number | name acl-name }
No ACL is applied to control NETCONF over SOAP over HTTPS access.
Only NETCONF clients permitted by the ACL can establish NETCONF over SOAP over HTTPS sessions.
# Use ACL 2001 to allow only NETCONF clients in subnet 10.10.0.0/16 to establish NETCONF over SOAP over HTTPS sessions.
[Sysname] netconf soap https acl 2001
netconf soap https dscp
Use netconf soap https dscp to set the DSCP value for outgoing NETCONF over SOAP over HTTPS packets.
Use undo netconf soap https dscp to restore the default.
netconf soap https dscp dscp-value
The DSCP value is 0 for outgoing NETCONF over SOAP over HTTPS packets.
# Set the DSCP value to 30 for outgoing NETCONF over SOAP over HTTPS packets.
[Sysname] netconf soap https dscp 30
netconf soap https enable
Use netconf soap https enable to enable NETCONF over SOAP over HTTPS.
Use undo netconf soap https enable to disable NETCONF over SOAP over HTTPS.
NETCONF over SOAP over HTTPS is disabled.
This command enables the device to resolve NETCONF messages that are encapsulated with SOAP in HTTPS packets.
# Enable NETCONF over SOAP over HTTPS.
[Sysname] netconf soap https enable
netconf ssh server enable
Use netconf ssh server enable to enable NETCONF over SSH.
Use undo netconf ssh server enable to disable NETCONF over SSH.
NETCONF over SSH is disabled.
This feature allows you to use an SSH client to invoke NETCONF as an SSH subsystem. Then, you can directly use XML messages to perform NETCONF operations without using the xml command.
Before you execute this command, configure the authentication mode for users as scheme on the device. Then, the NETCONF-over-SSH-enabled user terminals can access the device through NETCONF over SSH.
Only capability set urn:ietf:params:netconf:base:1.0 is available. It is supported by both the device and user terminals.
# Enable NETCONF over SSH.
[Sysname] netconf ssh server enable
netconf ssh server port
Use netconf ssh server port to specify a port to listen for NETCONF over SSH connections.
Use undo netconf ssh server port to restore the default.
netconf ssh server port port-number
Port 830 listens for NETCONF over SSH connections.
port-number: Specifies a port by its number in the range of 1 to 65535.
When assigning a listening port, make sure the specified port is not being used by other services. The SSH service can share the same port with other services, but it might not operate correctly.
# Specify port 800 to listen for NETCONF over SSH connections.
[Sysname] netconf ssh server port 800
xml
Use xml to enter XML view.
xml
In XML view, use NETCONF messages to configure the device or obtain data from the device. The NETCONF operations you can perform depend on the user roles you have, as shown in Table 1.
Table 1 NETCONF operations available for the predefined user roles
User role
NETCONF operations
All NETCONF operations
·     Get
·     Get-bulk
·     Get-bulk-config
·     Get-config
·     Get-sessions
·     Close-session
After you enter XML view, the device automatically advertises its NETCONF capabilities to the client. In response, the client notifies the device of its supported NETCONF capabilities. After the capability exchange, you can use the client to configure the device.
NETCONF messages must comply with the XML format requirements and semantic and syntactic requirements in the NETCONF XML API reference for the device. As a best practice, use third-party software to generate NETCONF messages to ensure successful configuration.
To quit XML view, use a NETCONF message instead of the quit command.
If you have configured a shortcut key (Ctrl + C, by default) by using the escape-key command in user line/user line class view, the NETCONF message should not contain the shortcut key string. If the NETCONF message contains the shortcut key string, relevant configurations in XML view might be affected. For example, in user line view, you configured "a" as the shortcut key by using the escape-key a command. When a NETCONF message includes the character "a," only the contents after the last "a" in the message can be processed.
# Enter XML view.
<Sysname> xml
<?xml version="1.0" encoding="UTF-8"?><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><capabilities><capability>urn:ietf:params:netconf:base:1.1</capability><capability>urn:ietf:params:netconf:writable-running</capability><capability>urn:ietf:params:netconf:capability:notification:1.0</capability><capability>urn:ietf:params:netconf:capability:validate:1.1</capability><capability>urn:ietf:params:netconf:capability:interleave:1.0</capability><capability>urn:h3c:params:netconf:capability:h3c-netconf-ext:1.0</capability></capabilities><session-id>1</session-id></hello>]]>]]>
# Notify the device of the NETCONF capabilities supported on the client.
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>]]>]]>
# Quit XML view.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <close-session>
  </close-session>
</rpc>]]>]]>
<Sysname>
