- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-Emergency shell commands
- 09-Device management commands
- 10-Tcl commands
- 11-Python commands
04-FTP and TFTP commands | 206.24 KB |
FTP commands
FTP is not supported in FIPS mode.
FTP server commands
display ftp-server
Use display ftp-server to display FTP server configuration and status information.
display ftp-server
# Display FTP server configuration and status information.
User count: 1
Idle-timeout timer (in minutes): 30
User count |
Number of the current logged-in users. |
Idle-timeout timer (in minutes) |
If no packet is exchanged between the FTP server and client during this period, the FTP connection is closed. |
ftp server enable
ftp timeout
display ftp-user
Use display ftp-user to display detailed information about online FTP users.
display ftp-user
# Display detailed information about online FTP users.
<Sysname> display ftp-user
UserName HostIP Port HomeDir
root 192.168.20.184 46539 flash:
A field value is wrapped if its length exceeds the limit. The segments are left justified.
The following are the length limits for fields:
· UserName—10 characters.
· HostIP—15 characters.
· HomeDir—37 characters.
user2 2000:2000:2000: 1499 flash:/user2
2000:2000:2000:
2000:2000
administra 100.100.100.100 10001 flash:/123456789/123456789/123456789/
tor 123456789/123456789/123456789/1234567
89/123456789
UserName |
Name of the user. |
HostIP |
IP address of the user. |
Port |
Port number of the user. |
HomeDir |
Authorized directory for the user. |
free ftp user
Use free ftp user to manually release the FTP connections established by using a specific user account.
free ftp user username
username: Specifies a username. To display online FTP users, execute the display ftp-user command.
# Release the FTP connections established by using user account ftpuser.
<Sysname> free ftp user ftpuser
Are you sure to free FTP connection? [Y/N]:y
<Sysname>
free ftp user-ip
Use free ftp user-ip to manually release the FTP connections established from a specific IPv4 address.
free ftp user-ip ip-address [ port port ]
ip-address: Specifies the source IP address of an FTP connection. To view the source IP addresses of FTP connections, execute the display ftp-user command.
port port: Specifies the source port of an FTP connection. To view the source ports of FTP connections, execute the display ftp-user command.
# Release the FTP connections established from the IP address 192.168.20.184.
<Sysname> free ftp user-ip 192.168.20.184
<Sysname>
free ftp user-ip ipv6
Use free ftp user-ip ipv6 to manually release the FTP connections established from a specific IPv6 address.
free ftp user-ip ipv6 ipv6-address [ port port ]
ipv6-address: Specifies the source IPv6 address of an FTP connection. To view the source IPv6 addresses of FTP connections, execute the display ftp-user command.
# Release the FTP connections established from IPv6 address 2000::154.
<Sysname> free ftp user-ip ipv6 2000::154
<Sysname>
ftp server acl
Use ftp server acl to use an ACL to control FTP clients' access to the FTP server.
Use undo ftp server acl to restore the default.
ftp server acl { ipv4-acl-number | ipv6 ipv6-acl-number }
undo ftp server acl [ ipv6 ]
No ACL is used to control FTP clients' access to the FTP server.
ipv4-acl-number: Specifies an IPv4 ACL number in the range of 2000 to 3999.
ipv6 ipv6-acl-number: Specifies an IPv6 ACL number in the range of 2000 to 3999.
You can use this command to permit only FTP requests from specific FTP clients. This configuration takes effect only for FTP connections to be established. It does not impact existing FTP connections.
# Use ACL 2001 to allow only client 1.1.1.1 to access the FTP server.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule 0 permit source 1.1.1.1 0
[Sysname-acl-ipv4-basic-2001] rule 1 deny source any
[Sysname] ftp server acl 2001
ftp server dscp
Use ftp server dscp to set the DSCP value for IPv4 to use for FTP packets sent to an FTP client.
Use undo ftp server dscp to restore the default.
ftp server dscp dscp-value
IPv4 uses the DSCP value 0 for FTP packets sent to an FTP client.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet to indicate the transmission priority of the packet.
# Set the DSCP value for IPv4 to use for outgoing FTP packets to 30 on an FTP server.
[Sysname] ftp server dscp 30
ftp server enable
Use ftp server enable to enable the FTP server.
Use undo ftp server enable to disable the FTP server.
ftp server enable
The FTP server is disabled.
# Enable the FTP server.
[Sysname] ftp server enable
ftp server ipv6 dscp
Use ftp server ipv6 dscp to set the DSCP value for IPv6 to use for FTP packets sent to an FTP client.
Use undo ftp server ipv6 dscp to restore the default.
ftp server ipv6 dscp dscp-value
IPv6 uses the DSCP value 0 for FTP packets sent to an FTP client.
The DSCP value is carried in the Traffic class field of an IPv6 packet to indicate the transmission priority of the packet.
# Set the DSCP value for IPv6 to use for outgoing FTP packets to 30 on an FTP server.
[Sysname] ftp server ipv6 dscp 30
ftp server ssl-server-policy
Use ftp server ssl-server-policy to associate an SSL server policy with the FTP server.
Use undo ftp server ssl-server-policy to restore the default.
ftp server ssl-server-policy policy-name
No SSL server policy is associated with the FTP server.
policy-name: Specifies an SSL server policy by its name, a string of 1 to 31 characters.
After you associate an SSL server policy with the device, a client that supports SFTP will establish a secure connection to the device to ensure data security.
# Associate SSL server policy myssl with the FTP server.
[Sysname] ftp server ssl-server-policy myssl
ftp server enable
ssl server-policy (Security Command Reference)
ftp timeout
Use ftp timeout to set the FTP connection idle-timeout timer.
Use undo ftp timeout to restore the default.
ftp timeout minute
undo ftp timeout
The FTP connection idle-timeout timer is 30 minutes.
Minute: Specifies a time interval in the range of 1 to 35791 minutes.
If no data transfer occurs on an FTP connection within the idle-timeout interval, the FTP server closes the FTP connection to release resources.
# Set the FTP connection idle-timeout timer to 36 minutes.
[Sysname] ftp timeout 36
FTP client commands
For FTP users to execute FTP client configuration commands, you must configure authorization settings for users on the FTP server. Authorized operations include viewing the files in the working directory, reading/downloading/uploading/renaming/removing files, and creating directories.
The FTP client commands in this section are supported by the device, but whether they can be executed successfully depends on the FTP server.
The output in the examples of this section varies by FTP server type.
Use ? to display all commands supported by an FTP client.
Use ? command-name to display the help information for a command.
? [ command-name ]
FTP client view
command-name: Specifies a command supported by the FTP client.
In FTP client view, entering ? is the same as executing the help command.
# Display all commands supported by the FTP client.
ftp> ?
Commands may be abbreviated. Commands are:
append delete ls quit rmdir
ascii debug mkdir reget status
binary dir newer rstatus system
bye disconnect open rhelp user
cd get passive rename verbose
cdup help put reset ?
close lcd pwd restart
# Display the help information for the dir command.
ftp> ? dir
dir list contents of remote directory
help
append
Use append to add the content of a file on the FTP client to a file on the FTP server.
append localfile [ remotefile ]
FTP client view
localfile: Specifies a file on the FTP client.
remotefile: Specifies a file on the FTP server.
You can perform this operation only after you log in to the FTP server.
# Append the content of the local a.txt file to the b.txt file on the FTP server.
ftp> append a.txt b.txt
227 Entering Passive Mode (192,168,1,84,8,145)
150 Accepted data connection
226 File successfully transferred
1657 bytes sent in 0.000736 seconds (2.15 Mbyte/s)
ascii
Use ascii to set the file transfer mode to ASCII.
ascii
The file transfer mode is binary.
FTP client view
FTP transfers files in either of the following modes:
· Binary mode—Transfers non-text files.
· ASCII mode—Transfers text files.
When the device acts as the FTP server, the transfer mode is determined by the FTP client. When the device acts as the FTP client, you can set the transfer mode. The transfer mode is binary by default.
# Set the file transfer mode to ASCII.
ftp> ascii
200 TYPE is now ASCII
binary
binary
Use binary to set the file transfer mode to binary, which is also called the flow mode.
binary
FTP client view
· Binary mode—Transfers program file or pictures.
When the device acts as the FTP server, the transfer mode is determined by the FTP client. When the device acts as the FTP client, you can set the transfer mode. The default transfer mode is binary.
# Set the file transfer mode to binary.
ftp> binary
200 TYPE is now 8-bit binary
ascii
bye
Use bye to terminate the connection to the FTP server and return to user view. If no connection is established between the device and the FTP server, use this command to return to user view.
bye
FTP client view
# Terminate the connection to the FTP server and return to user view.
ftp> bye
221-Goodbye. You uploaded 2 and downloaded 2 kbytes.
221 Logout.
<Sysname>
cd
Use cd to change the current working directory to another directory on the FTP server.
cd { directory | .. | / }
FTP client view
directory: Specifies the target directory. If the target directory does not exist, the cd command does not change the current working directory.
..: Specifies the upper directory. Executing the cd .. command is the same as executing the cdup command. If the current working directory is the FTP root directory, the cd .. command does not change the current working directory.
/: Specifies the FTP root directory.
The directory that can be accessed must be authorized by the FTP server.
# Change the working directory to the logfile subdirectory of the current directory.
ftp> cd logfile
250 OK. Current directory is /logfile
# Change the working directory to the folder subdirectory of the FTP root directory.
ftp> cd /folder
250 OK. Current directory is /folder
# Change the working directory to the upper directory of the current directory.
ftp> cd ..
# Change the working directory to the FTP root directory.
ftp> cd /
cdup
pwd
cdup
Use cdup to enter the upper directory of the FTP server.
cdup
FTP client view
This command does not change the working directory if the current directory is the FTP root directory.
# Change the working directory to the upper directory.
ftp> pwd
257 "/ftp/subdir" is your current location
ftp> cdup
250 OK. Current directory is /ftp
ftp> pwd
257 "/ftp" is your current location
cd
pwd
close
Use close to terminate the connection to the FTP server without exiting FTP client view.
close
FTP client view
# Terminate the connection to the FTP server without exiting the FTP client view.
ftp> close
221-Goodbye. You uploaded 0 and downloaded 0 kbytes.
221 Logout.
ftp>
disconnect
debug
Use debug to enable or disable FTP client debugging.
debug
FTP client debugging is disabled.
FTP client view
When FTP client debugging is enabled, executing this command disables FTP client debugging.
When FTP client debugging is disabled, executing this command enables FTP client debugging.
# Enable and then disable FTP client debugging.
ftp> debug
Debugging on (debug=1).
ftp> debug
Debugging off (debug=0).
delete
Use delete to permanently delete a file from the FTP server.
delete remotefile
FTP client view
To perform this operation, you must have delete permission on the FTP server.
# Delete the b.txt file.
ftp> delete b.txt
250 Deleted b.txt
dir
Use dir to display or save detailed information about files and directories on the FTP server.
dir [ remotefile [ localfile ] ]
FTP client view
remotefile: Specifies a file or directory on the FTP server.
localfile: Specifies the name of the local file used to save the displayed information.
To display detailed information about the files and subdirectories in the working directory on the FTP server, use the dir command.
To display detailed information about a file or directory on the FTP server, use the dir remotefile command.
To save detailed information about a file or directory on the FTP server to a local file, use the dir remotefile localfile command.
In FTP client view, executing the dir command is the same as executing the ls command.
# Display detailed information about the files and subdirectories in the working directory on the FTP server.
ftp> dir
150 Connecting to port 50201
-rwxr-xr-x 1 0 0 1481 Jul 7 15:36 a.txt
-rwxr-xr-x 1 0 0 0 Sep 27 2010 base.bin
drwxr-xr-x 2 0 0 8192 Jul 2 14:33 diagfile
drwxr-xr-x 3 0 0 8192 Jul 7 15:21 ftp
-rwxr-xr-x 1 0 0 0 Sep 27 2010 kernel.bin
drwxr-xr-x 2 0 0 8192 Jul 5 09:15 logfile
drwxr-xr-x 2 0 0 8192 Jul 2 14:33 seclog
-rwxr-xr-x 1 0 0 40808448 Jul 2 14:33 system-a1801.bin
-rwxr-xr-x 1 0 0 3050 Jul 7 12:26 startup.cfg
-rwxr-xr-x 1 0 0 54674 Jul 4 09:24 startup.mdb
-rwxr-xr-x 1 0 0 1481 Jul 7 12:34 x.cfg
226 11 matches total
# Save detailed information about file a.txt to s.txt.
ftp> dir a.txt s.txt
output to local-file: s.txt ? [Y/N]y
150 Connecting to port 50203
226-Glob: a.txt
# Display the content of the file s.txt.
ftp> bye
221-Goodbye. You uploaded 0 and downloaded 2 kbytes.
221 Logout.
<Sysname> more s.txt
-rwxr-xr-x 1 0 0 1481 Jul 7 12:34 a.txt
ls
disconnect
Use disconnect to terminate the connection to the FTP server without exiting FTP client view.
disconnect
FTP client view
ftp> disconnect
221 Logout.
ftp>
close
display ftp client source
Use display ftp client source to display the source address settings on the FTP client.
# Display the source address settings on the FTP client.
<Sysname> display ftp client source
The source IP address of the FTP client is 1.1.1.1.
ftp
Use ftp to log in to an IPv4 FTP server and enter FTP client view.
ftp [ ftp-server [ service-port ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] ] *
ftp-server: Specifies the IPv4 address or host name of an FTP server. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters for a host name include letters, digits, hyphens (-), underscores (_), and dots (.).
service-port: Specifies the TCP port number of the FTP server, in the range of 0 to 65535. The default is 21.
dscp dscp-value: Specifies the DSCP value for IPv4 to use in outgoing FTP packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 0.
source { interface interface-type interface-number | ip source-ip-address }: Specifies the source address used to establish the FTP connection.
· interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's primary IPv4 address as the source address. To establish the FTP connection successfully, make sure the interface is up and has the primary IPv4 address configured.
· ip source-ip-address: Specifies an IPv4 address. To establish the FTP connection successfully, make sure this address is the IPv4 address of an interface in up state on the device.
This command is only applicable to IPv4 networks.
If no parameters are specified, this command enters the FTP client view without logging in to an FTP server.
If the server parameters are specified, you are prompted to enter the username and password for logging in to the FTP server.
# Log in to the FTP server 192.168.0.211. Use the source IPv4 address of 192.168.0.212 for outgoing FTP packets.
<Sysname>ftp 192.168.0.211 source ip 192.168.0.212
Press CTRL+C to abort.
Connected to 192.168.0.211 (192.168.0.211).
User (192.168.0.211:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
ftp client ipv6 source
Use ftp client ipv6 source to specify the source IPv6 address for FTP packets sent to an IPv6 FTP server.
Use undo ftp client ipv6 source to restore the default.
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
No source address is specified for FTP packets sent to an IPv6 FTP server. The device selects a source IPv6 address as defined in RFC 3484.
interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's IPv6 address as the source address. For successful FTP packet transmission, make sure the interface is up and is configured with an IPv6 address.
ipv6 source-ipv6-address: Specifies an IPv6 address. For successful FTP packet transmission, make sure this address is the IPv6 address of an interface in up state on the device.
The source address specified with the ftp ipv6 command takes precedence over the source address specified with the ftp client ipv6 source command.
The source address specified with the ftp client ipv6 source command applies to all FTP connections. The source address specified with the ftp ipv6 command applies only to the FTP connection that is being established.
# Specify the source IPv6 address of 2000::1 for FTP packets sent to an IPv6 FTP server.
<Sysname> system–view
[Sysname] ftp client ipv6 source ipv6 2000::1
ftp ipv6
ftp client source
Use ftp client source to specify the source IPv4 address for FTP packets sent to an IPv4 FTP server.
Use undo ftp client source to restore the default.
No source IPv4 address is specified for FTP packets sent to an IPv4 FTP server. The device uses the primary IPv4 address of the output interface for the route to the server as the source address.
interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's primary IPv4 address as the source address. For successful FTP packet transmission, make sure the interface is up and has the primary IPv4 address configured.
ip source-ip-address: Specifies an IPv4 address. For successful FTP packet transmission, make sure this address is the IPv4 address of an interface in up state on the device.
The source address specified with the ftp command takes precedence over the source address specified with the ftp client source command.
The source address specified with the ftp client source command applies to all FTP connections. The source address specified with the ftp command applies only to the FTP connection that is being established.
# Specify the source IPv4 address of 192.168.20.222 for FTP packets sent to an IPv4 FTP server.
[Sysname] ftp client source ip 192.168.20.222
ftp
ftp ipv6
Use ftp ipv6 to log in to an IPv6 FTP server and enter FTP client view.
ftp ipv6 [ ftp-server [ service-port ] [ dscp dscp-value | source { ipv6 source-ipv6-address | interface interface-type interface-number } ] * [ -i interface-type interface-number ] ]
ftp-server: Specifies the IPv6 address or host name of an FTP server. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters for a host name include letters, digits, hyphens (-), underscores (_), and dots (.).
dscp dscp-value: Specifies the DSCP value for IPv6 to use in outgoing FTP packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 0.
source { ipv6 source-ipv6-address | interface interface-type interface-number }: Specifies the source address used to establish the FTP connection.
· interface interface-type interface-number: Specifies an interface by its type and number. This option can be used only when the FTP server address is a link local address and the specified output interface has a link local address. For information about link local addresses, see Layer 3—IP Services Configuration Guide.
· ipv6 source-ipv6-address: Specifies an IPv6 address. To establish the FTP connection successfully, make sure this address is the IPv6 address of an interface in up state on the device.
-i interface-type interface-number: Specifies an output interface by its type and number. This option can be used only when the FTP server address is a link local address and the specified output interface has a link local address.
This command is only applicable to IPv6 networks.
If no parameters are specified, this command enters the FTP client view.
If the FTP server parameters are specified, you are prompted to enter the username and password for logging in to the FTP server.
# Log in to FTP server 2000::154.
<Sysname>ftp ipv6 2000::154
Connected to 2000::154 (2000::154).
220 FTP service ready.
User (2000::154): root
331 Password required for root.
Password:
230 User logged in
Remote system type is H3C
get
Use get to download a file from the FTP server and save the file.
get remotefile [ localfile ]
FTP client view
remotefile: Specifies the file to be downloaded.
localfile: Specifies a name for the downloaded file. If you do not specify this argument, the system uses the name of the source file.
To save the downloaded file to the working directory accessed by the ftp command, perform one of the following tasks:
· Execute the command without specifying the localfile argument.
· Specify a file name without any path information for the localfile argument, for example, a.cfg.
To save the downloaded file to some other directory, you must specify a fully qualified file name for the localfile argument, for example, flash:/subdirectory/a.cfg.
# Download the a.txt file and save it as b.txt in the working directory accessed by the ftp command.
ftp> get a.txt b.txt
local: b.txt remote: a.txt
150 Connecting to port 47457
1569 bytes received in 0.00527 seconds (290.6 kbyte/s)
# Download the a.txt file to the test directory in the working directory accessed by the ftp command.
ftp> get a.txt flash:/test/b.txt
local: flash:/test/b.txt remote: a.txt
# Download the a.txt file to the root directory of the flash memory on a member device. Save the file as c.txt.
ftp> get a.txt slot1#flash:/c.txt
local: slot1#flash:/c.txt remote: a.txt
150 Connecting to port 47460
1569 bytes received in 0.0564 seconds (27.2 kbyte/s)
put
help
Use help to display all commands supported by the FTP client.
Use help command-name to display the help information for a command.
help [ command-name ]
FTP client view
In FTP client view, executing the help command is the same as entering ?.
ftp> help
ftp> help dir
lcd
Use lcd to display or change the local working directory of the FTP client.
lcd [ directory | / ]
FTP client view
directory: Changes the local working directory of the FTP client to the specified local directory. There must be a slash sign (/) before the name of the storage medium, for example, /flash:/logfile.
/: Changes the local working directory of the FTP client to the local root directory.
To display the local working directory of the FTP client, do not specify the directory or / argument.
# Display the local working directory.
ftp> lcd
Local directory now /flash:
# Change the local working directory to flash:/logfile.
ftp> lcd /flash:/logfile
Local directory now /flash:/logfile
ls
Use ls to display or save detailed information about files and directories on the FTP server.
ls [ remotefile [ localfile ] ]
FTP client view
To display detailed information about the files and subdirectories in the working directory on the FTP server, use the ls command.
To display detailed information about a file or directory on the FTP server, use the ls remotefile command.
To save detailed information about a file or directory on the FTP server to a local file, use the ls remotefile localfile command.
In FTP client view, executing the ls command is the same as executing the dir command.
ftp> ls
# Save detailed information about the file a.txt to s.txt.
ftp> ls a.txt s.txt
226-Glob: s.txt
ftp> bye
221 Logout.
dir
mkdir
Use mkdir to create a subdirectory in the current directory on the FTP server.
mkdir directory
FTP client view
directory: Specifies the name for the directory to be created.
You must have permission to perform this operation on the FTP server.
# Create a subdirectory named newdir in the current directory of the FTP server.
ftp> mkdir newdir
257 "newdir" : The directory was successfully created
newer
Use newer to update a local file by using a file on the FTP server.
newer remotefile [ localfile ]
FTP client view
localfile: Specifies the local file to be updated.
If the local file does not exist, this command downloads the file from the FTP server and saves it locally.
If the file on the FTP server is not newer than the local file, this command does not update the local file.
# Update the local file with the a.txt file on the FTP server.
ftp> newer a.txt
local: a.txt remote: a.txt
150 Connecting to port 63513
1573 bytes received in 0.0293 seconds (52.3 kbyte/s)
open
Use open to log in to an FTP server from FTP client view.
open server-address [ service-port ]
FTP client view
server-address: Specifies the IPv4 address, IPv6 address, or host name of the FTP server.
After you issue this command, the system will prompt you to enter the username and password.
After you log in to one FTP server, you must disconnect from the server before you can use the open command to log in to another server.
# In FTP client view, log in to FTP server 192.168.40.7.
<Sysname>ftp
ftp> open 192.168.40.7
Connected to 192.168.40.7 (192.168.40.7).
User (192.168.40.7:(none)): root
Password:
230 User logged in.
Remote system type is H3C.
ftp>
passive
Use passive to change the FTP operation mode.
passive
The FTP operation mode is passive.
FTP client view
FTP can operate in either of the following modes:
· Active mode—The FTP server initiates the TCP connection.
· Passive mode—The FTP client initiates the TCP connection.
When the FTP operation mode is passive, executing this command changes the mode to active.
When the FTP operation mode is active, executing this command changes the mode to passive.
This command is typically used together with a firewall to control FTP session establishment between private network users and public network users.
# Change the FTP operation mode to passive.
ftp> passive
Passive mode on.
ftp> passive
Passive mode off.
put
Use put to upload a file from the FTP client to the FTP server.
put localfile [ remotefile ]
FTP client view
localfile: Specifies the local file to be uploaded.
remotefile: Specifies the name of the file for saving the uploaded file on the FTP server.
To upload a file in the current working directory, specify a file name without the path for the localfile argument, for example, a.cfg.
To upload a file in some other directory, specify a fully qualified file name for the localfile argument, for example, flash:/subdirectory/a.cfg.
# Upload the a.txt file from the local working directory to the FTP server. Save the file as b.txt.
ftp> put a.txt b.txt
local: a.txt remote: b.txt
150 Connecting to port 47461
1569 bytes sent in 0.000671 seconds (2.23 Mbyte/s)
# Upload the a.txt file from the test directory of the local working directory to the FTP server. Save the file as b.txt.
ftp> put flash:/test/a.txt b.txt
local: flash:/test/a.txt remote: b.txt
# Upload file a.txt from the test directory of the storage medium on a member device. Save the file as b.txt on the FTP server.
ftp> put slot2#flash:/test/a.txt b.txt
local: slot2#flash:/test/a.txt remote: b.txt
get
pwd
Use pwd to display the currently accessed directory on the FTP server.
pwd
FTP client view
# Display the currently accessed directory on the FTP server.
ftp> cd subdir
250 OK. Current directory is /subdir
ftp> pwd
257 "/subdir" is your current location
Use quit to terminate the connection to the FTP server and return to user view.
FTP client view
ftp> quit
221 Logout.
<Sysname>
bye
reget
Use reget to get the missing part of a file from the FTP server.
reget remotefile [ localfile ]
FTP client view
localfile: Specifies a local file.
If a file download is not completed due to network or storage space problems, use this command to get the part that has not been downloaded yet.
# Get the part of the s.bin file that has not been downloaded yet.
ftp> reget s.bin
local: s.bin remote: s.bin
350 Restarting at 1749706
150-Connecting to port 47429
150 38143.3 kbytes to download
39058742 bytes received in 66.2 seconds (576.1 kbyte/s)
rename
Use rename to rename a file.
rename [ oldfilename [ newlfilename ] ]
FTP client view
oldfilename: Specifies the original file name.
newfilename: Specifies the new file name.
# Rename the a.txt file as b.txt.
· Method 1:
ftp> rename
(from-name) a.txt
(to-name) b.txt
350 RNFR accepted - file exists, ready for destination
250 File successfully renamed or moved
· Method 2:
ftp> rename a.txt
(to-name) b.txt
· Method 3:
ftp> rename a.txt b.txt
reset
Use reset to clear the reply information received from the FTP server in the buffer.
reset
FTP client view
# Clear the reply information received from the FTP server.
ftp> reset
restart
Use restart to specify the file retransmission offset.
restart marker
FTP client view
marker: Specifies the retransmission offset, in bytes.
Use this command to continue with a file retransmission. The file retransmission starts from the (offset+1)th byte.
Support for this command depends on the FTP server.
# Set retransmission offset to 2 bytes and retransmit the h.c file. The file has 82 bytes in total.
ftp> restart 2
restarting at 2. execute get, put or append to initiate transfer
ftp> put h.c h.c
local: h.c remote: h.c
350 Restart position accepted (2).
150 Ok to send data.
226 File receive OK.
80 bytes sent in 0.000445 seconds (175.6 kbyte/s)
ftp> dir
150 Here comes the directory listing.
-rw-r--r-- 1 0 0 82 Jul 18 02:58 h.c
rhelp
Use rhelp to display the FTP commands supported by the FTP server.
Use rhelp protocol-command to display the help information for an FTP command supported by the FTP server.
rhelp [ protocol-command ]
FTP client view
protocol-command: Specifies an FTP command.
# Display the FTP-related commands supported by the FTP server.
ftp> rhelp
214-The following FTP commands are recognized
USER PASS NOOP QUIT SYST TYPE
HELP CWD XCWD PWD CDUP XCUP
XPWD LIST NLST MLSD PORT EPRT
PASV EPSV REST RETR STOR APPE
DELE MKD XMKD RMD XRMD ABOR
SIZE RNFR RNTO
214 UNIX Type: L8
USER |
Username. |
PASS |
Password. |
NOOP |
Null operation. |
SYST |
System parameters. |
TYPE |
Request type. |
CWD |
Changes the current working directory. |
XCWD |
Extended command with the meaning of CWD. |
PWD |
Prints the working directory. |
CDUP |
Changes the directory to the upper directory. |
XCUP |
Extended command with the meaning of CDUP. |
XPWD |
Extended command with the meaning of PWD. |
LIST |
Lists files. |
NLST |
Lists brief file description. |
MLSD |
Lists file content. |
PORT |
Active mode (IPv4). |
EPRT |
Active mode (IPv6). |
PASV |
Passive mode (IPv4). |
Passive mode (IPv6). |
REST |
Restarts. |
RETR |
Downloads files. |
STOR |
Uploads files. |
APPE |
Appends uploading. |
DELE |
Deletes files. |
MKD |
Creates folders. |
XMKD |
Extended command with the meaning of MKD. |
RMD |
Deletes folders. |
XRMD |
Extended command with the meaning of RMD. |
ABOR |
Aborts the transmission. |
SIZE |
Size of the transmission file. |
RNFR |
Original name. |
RNTO |
New name. |
rmdir
Use rmdir to permanently delete a directory from the FTP server.
rmdir directory
FTP client view
directory: Specifies a directory on the FTP server.
Delete all files and subdirectories in a directory before you delete the directory. For more information about how to delete files, see the delete command.
The rmdir command does not delete the files of the specified directory from the recycle bin.
# Delete empty directory subdir1.
ftp>rmdir subdir1
250 The directory was successfully removed
delete
rstatus
Use rstatus to display FTP server status information.
Use rstatus remotefile to display detailed information about a directory or file on the FTP server.
rstatus [ remotefile ]
FTP client view
remotefile: Specifies a directory or file on the FTP server.
# Display FTP server status information.
ftp> rstatus
211-FTP server status:
Connected to 192.168.20.177
Logged in as root
TYPE: ASCII
No session bandwidth limit
Session timeout in seconds is 300
Control connection is plain text
Data connections will be plain text
At session startup, client count was 1
vsFTPd 2.0.6 - secure, fast, stable
211 End of status
Filed |
211-FTP server status: |
Beginning of the display of FTP server status, where 211 specifies the FTP command. |
Connected to 192.168.20.177 |
IP address of the FTP client. |
Logged in as root |
Login username root. |
TYPE: ASCII |
File transfer mode ASCII. |
Session timeout in seconds is 300 |
FTP connection idle-timeout interval is 300 seconds. |
Control connection is plain text |
Control connection type is plain text. |
Data connections will be plain text |
Data connection type is plain text. |
At session startup, client count was 1 |
FTP connection number is 1. |
vsFTPd 2.0.6 - secure, fast, stable |
FTP version is 2.0.6. |
211 End of status |
End of the display of FTP server status. |
# Display the file a.txt.
ftp> rstatus a.txt
213-Status follows:
-rw-r--r-- 1 0 0 80 Jul 18 02:58 a.txt
213 End of status
Table 5 Command output
213-Status follows: |
Beginning of the display of the file, where 213 specifies the FTP command. |
-rw-r--r-- |
The first bit specifies the file type. · -—Common. · B—Block. · c—Character. · d—Directory. · l—Symbol connection file. · p—Pipe. · s—socket. The second bit through the tenth bit are divided into three groups. Each group contains three characters, representing the access permission of the owner, group, and other users. · -—No permission. · r—Read permission. · w—Write permission. · x—Execution permission. |
1 |
Number of connections. |
0 |
Name of the file owner. |
0 |
Group number of the file owner. |
80 |
File size, in bytes. |
Jul 18 02:58 |
Date and time when the file was most recently modified. |
a.txt |
File name. |
213 End of status |
End of the display of the file information. |
status
Use status to display FTP status information.
status
FTP client view
# Display FTP status information.
ftp> status
Connected to 192.168.1.56.
No proxy connection.
Not using any security mechanism.
Mode: stream; Type: ascii; Form: non-print; Structure: file
Verbose: on; Bell: off; Prompting: on; Globbing: off
Store unique: off; Receive unique: off
Case: off; CR stripping: on
Ntrans: off
Nmap: off
Hash mark printing: off; Use of PORT cmds: on
Table 6 Command output
Connected to 192.168.1.56. |
IP address of the FTP server that is connected to the FTP client. |
Verbose: on; Bell: off; Prompting: on; Globbing: off |
Displays debugging information. |
Store unique: off; Receive unique: off |
The name of the file on the FTP server is unique and the name of the local file is unique. |
Case: off; CR stripping: on |
Does not support obtaining multiple files once and deletes "\r" when downloading text files. |
Ntrans: off |
Does not use the input-output transmission table. |
Nmap: off |
The file name does not use the input-to-output mapping template. |
Hash mark printing: off; Use of PORT cmds: on |
Does not end with a pound sign (#) and uses "PORT" data transmission. |
system
Use system to display the system information of the FTP server.
system
FTP client view
# Display the system information of the FTP server.
ftp> system
215 UNIX Type: L8
user
Use user to initiate an FTP authentication on the current FTP connection.
user username [ password ]
FTP client view
username: Specifies the username.
password: Specifies the password.
If you tried to access an FTP server but failed to pass the authentication, you can use this command to try again before the connection to the FTP server expires.
After you log in to an FTP server, you can initiate an FTP authentication to change to a new account. By changing to a new account, you can get a different privilege without re-establishing the FTP connection.
Make sure the specified username and password have been configured on the FTP server. If the username or password is not configured, this command fails and the FTP connection is closed.
# After logging in to the FTP server, use username ftp and password 123456 to log in again to the FTP server.
· Method 1:
ftp> user ftp 123456
331 Password required for ftp.
230 User logged in.
· Method 2:
ftp> user ftp
Password:
230 User logged in.
verbose
Use verbose to enable or disable the device to display detailed information about FTP operations.
verbose
The device displays detailed information about FTP operations.
FTP client view
This command affects only the current FTP session.
# Disable the device from displaying detailed information about FTP operations.
ftp> verbose
Verbose mode off.
# Execute the get command.
ftp> get a.cfg 1.cfg
# Enable the device to display detailed information about FTP operations.
ftp> verbose
Verbose mode on.
ftp> get a.cfg 2.cfg
227 Entering Passive Mode (192,168,1,58,68,14)
150-Accepted data connection
150 The computer is your friend. Trust the computer
3796 bytes received in 0.00762 seconds (486.5 kbyte/s)
TFTP commands
TFTP is not supported in FIPS mode.
tftp
Use tftp to download a file from a TFTP server or upload a file to a TFTP server in an IPv4 network.
tftp tftp-server { get | put | sget } source-filename [ destination-filename ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] *
tftp-server: Specifies the IPv4 address or host name of a TFTP server. The host name can be a case-insensitive string of 1 to 253 characters and can contain only letters, digits, hyphens (-), underscores (_), and dots (.).
get: Downloads a file and writes the file directly to the destination folder. If the destination folder already has a file with the same name, the system deletes the existing file before starting the download operation. The existing file is permanently deleted even if the download operation fails.
put: Uploads a file.
sget: Downloads a file and saves the file to memory before writing it to the destination folder. The system starts to write the file to the destination folder only after the file is downloaded and saved to memory successfully. If the destination folder already has a file with the same name, the system overwrites the existing file. If the download or save-to-memory operation fails, the existing file in the destination folder is not overwritten.
source-filename: Specifies the source file name, a case-insensitive string of 1 to 1 to 255 characters.
destination-filename: Specifies the destination file name, a case-insensitive string of 1 to 255 characters. If this argument is not specified, the file uses the source file name.
dscp dscp-value: Specifies the DSCP value for IPv4 to use for outgoing TFTP packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 0.
source { interface interface-type interface-number | ip source-ip-address }: Specifies the source address for outgoing TFTP packets. If you do not specify this option, the device uses the primary IPv4 address of the output interface for the route to the TFTP server as the source address.
· interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's primary IPv4 address as the source IPv4 address. For successful TFTP packet transmission, make sure the interface is up and has the primary IPv4 address configured.
· ip source-ip-address: Specifies an IPv4 address. For successful TFTP packet transmission, make sure this address is the IPv4 address of an interface in up state on the device.
The source address specified with the tftp command takes precedence over the source address specified with the tftp client source command.
The source address specified with the tftp client source command applies to all TFTP connections. The source address specified with the tftp command applies only to the current TFTP connection.
# Download the new.bin file from TFTP server 192.168.1.1 and save the file as new.bin.
<Sysname> tftp 192.168.1.1 get new.bin
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 13.9M 100 13.9M 0 0 1206k 0 0:00:11 0:00:11 --:--:-- 1206k
Writing file...Done.
<System>
Percentage of file transmission progress. |
Total |
Size of files to be transmitted, in bytes. |
Percentage of received file size to total file size. |
Received |
Received file size, in bytes. |
Percentage of sent file size to total file size. |
Xferd |
Sent file size, in bytes. |
Average Dload |
Average download speed, in bps. |
Speed Upload |
Average upload speed, in bps. |
Writing file… |
The system was writing the downloaded file to the storage medium. This field is displayed only when the get or sget keyword is specified. If the operation succeeded, this command displays Done at the end of this field. If the operation failed, this command displays Failed. |
tftp client source
tftp client ipv6 source
Use tftp client ipv6 source to specify the source IPv6 address for TFTP packets sent to an IPv6 TFTP server.
Use undo tftp client ipv6 source to restore the default.
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
No source address is specified for TFTP packets sent to an IPv6 TFTP server. The device selects a source IPv6 address as defined in RFC 3484.
interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's IPv6 address as the source address. For successful TFTP packet transmission, make sure the interface is up and is configured with an IPv6 address.
ipv6 source-ipv6-address: Specifies an IPv6 address . For successful TFTP packet transmission, make sure this address is the IPv6 address of an interface in up state on the device.
The source address specified with the tftp ipv6 command takes precedence over the source address specified with the tftp client ipv6 source command.
The source address specified with the tftp client ipv6 source command applies to all TFTP connections. The source address specified with the tftp ipv6 command applies only to the TFTP connection that is being established.
# Specify the source IPv6 address of 2000::1 for TFTP packets sent to an IPv6 TFTP server.
[Sysname] tftp client ipv6 source ipv6 2000::1
tftp ipv6
tftp client source
Use tftp client source to specify the source IPv4 address for TFTP packets sent to an IPv4 TFTP server.
Use undo tftp client source to restore the default.
No source IPv4 address is specified for TFTP packets sent to an IPv4 TFTP server. The device uses the primary IPv4 address of the output interface for the route to the server as the source address.
interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's primary IPv4 address as the source address. For successful TFTP packet transmission, make sure the interface is up and has the primary IPv4 address configured.
The source address specified with the tftp client source command applies to all TFTP connections. The source address specified with the tftp command applies only to the TFTP connection that is being established.
# Specify the source IP address of 192.168.20.222 for TFTP packets sent to an IPv4 TFTP server.
[Sysname] tftp client source ip 192.168.20.222
tftp
tftp ipv6
Use tftp ipv6 to download a file from a TFTP server or upload a file to a TFTP server in an IPv6 network.
tftp ipv6 tftp-server [ -i interface-type interface-number ] { get | put | sget } source-filename [ destination-filename ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] *
tftp-server: Specifies the IPv6 address or host name of a TFTP server. The host name can be a case-insensitive string of 1 to 253 characters and can contain only letters, digits, hyphens (-), underscores (_), and dots (.).
-i interface-type interface-number: Specifies an output interface by its type and number. This option can be used only when the TFTP server address is a link local address and the specified output interface has a link local address. For information about link local addresses, see Layer 3—IP Services Configuration Guide.
sget: Downloads a file and saves the file to memory before writing it to the destination folder. The system starts to write the file to the destination folder only after the file is downloaded and saved to memory successfully. If the destination folder already has a file using the same name, the system overwrites the existing file. If the download or save-to-memory operation fails, the existing file in the destination folder is not overwritten.
source-filename: Specifies the source file name, a case-insensitive string of 1 to 255 characters.
dscp dscp-value: Specifies the DSCP value for IPv6 to use in outgoing TFTP packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 0.
source { interface interface-type interface-number | ipv6 source-ipv6-address }: Specifies the source address for outgoing TFTP packets. If you do not specify this option, the device selects a source IPv6 address as defined in RFC 3484.
· interface interface-type interface-number: Specifies an interface by its type and number. The device will use the interface's IPv6 address as the source IPv6 address. For successful TFTP packet transmission, make sure the interface is up and is configured with an IPv6 address.
· ipv6 source-ipv6-address: Specifies an IPv6 address. For successful TFTP packet transmission, make sure this address is the IPv6 address of an interface in up state on the device.
The source address specified with the tftp client ipv6 source command applies to all TFTP connections. The source address specified with the tftp ipv6 command applies only to the current TFTP connection.
# Download the new.bin file from TFTP server 2001::1 and save the file as new.bin.
<Sysname> tftp ipv6 2001::1 get new.bin new.bin
For more information about the command output, see Table 7.
tftp-server acl
Use tftp-server acl to use an ACL to control the device's access to TFTP servers in an IPv4 network.
Use undo tftp-server acl to restore the default.
tftp-server acl acl-number
No ACL is used to control the device's access to TFTP servers.
acl-number: Specifies the number of a basic ACL, in the range of 2000 to 2999.
You can use an ACL to deny or permit the device's access to specific TFTP servers.
# Allow the device to access only TFTP server 1.1.1.1.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 1.1.1.1 0
[Sysname] tftp-server acl 2000
tftp-server ipv6 acl
Use tftp-server ipv6 acl to use an ACL to control the device's access to TFTP servers in an IPv6 network.
Use undo tftp-server ipv6 acl to restore the default.
tftp-server ipv6 acl ipv6-acl-number
ipv6-acl-number: Specifies the number of a basic ACL, in the range of 2000 to 2999.
# Allow the device to access only TFTP server 2001::1.
<Sysname> System-view
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source 2001::1/128
[Sysname] tftp-server ipv6 acl 2001
