- H3C UniServer B16000 Blade Server Chassis Hardware Options Installation and Replacement Videos-6W100
- 01-Install slide rails
- 02-Rack-mount the enclosure by using adjustable slide rails
- 03-Install the cable management bracket
- 04-Ground the server chassis
- 05-Cascade enclosures
- 06-Replace a blade server
- 07-Replace an OM module
- 08-Replace an interconnect module
- 09-Replace a power supply module
- 10-Replace a fan module
- 11-Install or remove blanks
