- 05-Layer 3-IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-DCN commands
07-Policy-based routing commands | 115.71 KB |
apply fail-action-drop next-hop
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
reset ip policy-based-route statistics
apply access-vpn vpn-instance
Use apply access-vpn vpn-instance to set VPN instances.
Use undo apply access-vpn vpn-instance to remove VPN instances.
apply access-vpn vpn-instance vpn-instance-name
undo apply access-vpn vpn-instance [ vpn-instance-name ]
No VPN instances are specified for a node.
Policy node view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist.
You can specify a maximum of six VPN instances for a node. The matching packets are forwarded according to the forwarding table of the first available VPN instance.
With a VPN instance specified, the undo apply access-vpn vpn-instance command removes the VPN instance.
Without any VPN instance specified, the undo apply access-vpn vpn-instance command removes all VPN instances.
# Set VPN 1 for node 10. (VPN 1 already exists.)
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10] apply access-vpn vpn-instance vpn1
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No default next hops are set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ip-address: Specifies the IP address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered up to two times.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply loadshare
Use apply fail-action-drop next-hop to set the action that drops matching packets when all next hops on a policy node are invalid.
Use undo apply fail-action-drop next-hop to restore the default.
The drop action is not configured. The matching packets are forwarded based on the typical packet forwarding process if all next hops on the policy node are invalid.
Policy node view
By default, the device uses the typical packet forwarding process to route matching packets when all next hops on the policy node are unavailable. To drop all matching packets when all next hops on the policy node are unavailable, use this command. This command is typically used in scenarios that require strict routing paths.
If no next hops are specified on the policy node, this command drops all packets that match the node.
This command does not apply to software-forwarded packets.
# Set next hop 1.1.1.1 on policy node 10 and configure the policy node to drop matching packets when the next hop is invalid.
[Sysname-pbr-policy1-10] apply next-hop 1.1.1.1
[Sysname-pbr-policy1-10] apply fail-action-drop next-hop
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops and default next hops.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | next-hop }
undo apply loadshare { default-next-hop | next-hop }
Multiple next hops and default next hops operate in primary/backup mode.
Policy node view
default-next-hop: Enables load sharing among multiple default next hops.
next-hop: Enables load sharing among multiple next hops.
Multiple next hop or default next hop options operate in either primary/backup or load sharing mode.
· Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple output interfaces are configured, the first configured output interface is selected. When the selected output interface fails, the next available output interface takes over.
· Load sharing mode—Matching traffic is distributed across the available options. They load share traffic in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
Multiple default next hops implement load sharing in the same way as multiple next hops.
# Enable load sharing among multiple next hops.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
# Enable load sharing among multiple default next hops.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare default-next-hop
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-16>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-16> ]
No next hops are set.
Policy node view
ip-address: Specifies the IP address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
&<1-16>: Indicates that the argument before it can be entered up to 16 times.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }
undo apply output-interface [ { interface-type interface-number } ]
No output interfaces are set.
Policy node view
You can specify multiple output interfaces for backup by executing this command multiple times.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
To specify a tunnel interface as the output interface, you can specify only an IPv6 tunnel interface.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify VLAN-interface 2 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface vlan-interface 2
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
apply service-chain
Use apply service-chain to set service chain information.
Use undo apply service-chain to restore the default.
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
Policy node view
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 16777215. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
# Set service chain path ID 1 and node index 10.
[Sysname] policy-based-route aa permit node 5
[Sysname-pbr-aa-5] apply service-chain path-id 1 path-index 10
description
Use description to configure a description for a policy node.
No description is configured for a policy node.
Policy node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] policy-based-route 1 permit node 1
[Sysname-pbr-1-1] description Officeuse
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
policy-based-route
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on the master device.
# Display PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ip policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
node 0 deny:
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 2.2.2.2
node 5 permit:
if-match acl 3101
Total matches: 0, total bytes: 0
Policy based routing information for interface XXXX |
PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
node 0 deny node 2 permit |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
apply next-hop |
Matches |
This field is not supported in the current software version. Number of successful matches on the node. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
bytes |
This field is not supported in the current software version. Number of matching bytes on the node. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on the node. |
Total matches |
This field is not supported in the current software version. Total number of successful matches on all nodes. This field displays N/A if the device does not support counting successful matches on a node. This field is not displayed if match counting is disabled on all nodes. |
total bytes |
This field is not supported in the current software version. Total number of matching bytes on all nodes. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on all nodes. |
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays local PBR configuration and statistics for the master device.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
node 5 permit:
if-match acl 3101
Policy based routing information for local |
Local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node: permit or deny. |
if-match acl |
apply next-hop |
Matches |
This field is not supported in the current software version. Number of successful matches on the node. This field displays N/A if the device does not support counting successful matches on a node. This field is not displayed if match counting is disabled on the node. |
bytes |
Total matches |
total bytes |
ip local policy-based-route
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy name Type Interface
pr01 Forward Vlan-interface2
aaa Local N/A
Table 5 Command output
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. |
Interface where the policy is applied. This field displays N/A for local PBR. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
If the vpn-instance keyword is specified for an ACL rule, the ACL does not take effect. If the vpn-instance keyword is not specified, the rule applies to both public and private network packets.
If you specify a local QoS ID for an ACL rule in the if-match acl command, you cannot configure the if-match qos-local-id command on the same policy node.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
Use if-match qos-local-id to set a local QoS ID match criterion.
Use undo if-match qos-local-id to restore the default.
if-match qos-local-id local-id-value
No local QoS ID match criterion is set.
Policy node view
local-id-value: Specifies a local QoS ID in the range of 1 to 4095.
If the device is configured with MAC authentication, make sure the local QoS ID specified for this command is smaller than 3000. For more information about MAC authentication, see Security Configuration Guide.
# Match packets with local QoS ID 200.
[Sysname-pbr-aa-11] if-match qos-local-id 200
if-match service-chain
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain { path-id service-path-id [ path-index service-path-index ] }
undo if-match service-chain [ [ path-id service-path-id ] ]
No service chain match criteria are set.
Policy node view
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr-aa-5] if-match service-chain path-id 1 path-index 10
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is specified for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
Before you apply a new policy, you must first remove the current policy.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ip policy-based-route aaa
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
· If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
· If a match mode is specified, the command deletes all nodes configured with the match mode.
· If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
