- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-GIR commands
- 10-Preprovisioning commands
- 11-Device management commands
- 12-Tcl commands
- 13-Python commands
- 14-License management commands
| 10-Preprovisioning commands | 47.74 KB |
display provision failed-config
Use display provision failed-config to display preprovisioned-commands application failure records.
A preprovisioned command cannot be applied if it conflicts with the running configuration.
Use this command to verify the application result of preprovisioned commands except for the following commands:
· duplex
· speed
· sflow
To verify the application result of the listed commands, use the display current-configuration command. The display provision failed-config command might display incorrect application results for the listed commands.
# Display preprovisioned-commands application failure records.
<Sysname> display provision failed-config
Configuration applied at: Sat Jun 14 06:06:00 2014
Slot information: slot 1
Commands that failed to be applied:
interface HundredGigE 1/0/1
speed 100000
provision
reset provision failed-config
provision
Use provision to enable preprovisioning.
Use undo provision to disable preprovisioning.
provision model model
undo provision model
Preprovisioning is disabled.
Slot view
model model: Specifies the IRF member device model to be preprovisioned. To obtain available models, enter a question mark (?) for the model argument.
This command allows you to enable preprovisioning on devices that will join the IRF fabric.
When you disable preprovisioning on a slot, the device removes all preconfigured settings for the slot.
# Enable preprovisioning for the S9820-64H device on a slot.
[Sysname] slot 2
[Sysname-slot-2] provision model S9820-64H
slot
Use reset provision failed-config to clear preprovisioned-commands application failure records.
Preprovisioned member devices that repeatedly join and leave the IRF fabric might leave in memory a large number of commands that were not applied. To release the occupied memory space, execute the reset provision failed-config command.
# Clear preprovisioned-commands application failure records.
<Sysname> reset provision failed-config
provision
slot
Use slot to select a slot to provision and enter slot view.
slot slot-number
slot-number: Specifies an IRF member device by its member ID.
# Enter the view of a slot.
[Sysname] slot 2
[Sysname-slot-2]
provision
