03-Layer 2-LAN Switching Configuration Guide
HomeSupportSwitchesS9820 SeriesConfigure & DeployConfiguration GuidesH3C S9820-64H Switch Configuration Guides-Release 671x-6W10003-Layer 2-LAN Switching Configuration Guide
03-Ethernet interface configuration
03-Ethernet interface configuration 243.19 KB
Configuring Ethernet interfaces· 1
About Ethernet interface· 1
Configuring a management Ethernet interface· 1
Ethernet interface naming conventions· 2
Restrictions and guidelines: Ethernet interface configuration· 2
Restrictions and guidelines for 25-GE interfaces· 2
Restrictions on use with the data buffer feature· 4
Configuring common Ethernet interface settings· 4
Splitting a 100-GE interface and combining 10-GE breakout interfaces· 4
Splitting a 100-GE interface and combining 25-GE breakout interfaces· 5
Configuring basic settings of an Ethernet interface· 6
Configuring basic settings of an Ethernet subinterface· 7
Configuring the link mode of an Ethernet interface· 8
Configuring jumbo frame support 8
Configuring physical state change suppression on an Ethernet interface· 9
Configuring dampening on an Ethernet interface· 9
Enabling link flapping protection on an interface· 11
Configuring FEC· 12
Enabling FEC bypass· 12
Configuring link compensation· 13
Configuring storm suppression· 13
Configuring generic flow control on an Ethernet interface· 14
Setting the statistics polling interval 15
Enabling loopback testing on an Ethernet interface· 15
Forcibly bringing up a fiber port 16
Configuring interface alarm functions· 17
Shutting down all physical interfaces· 20
Restoring the default settings for an interface· 21
Configuring a Layer 2 Ethernet interface· 21
Configuring storm control on an Ethernet interface· 21
Enabling bridging on an Ethernet interface· 22
Configuring a Layer 3 Ethernet interface or subinterface· 23
Setting the MTU for an Ethernet interface or subinterface· 23
Setting the MAC address of an Ethernet interface or subinterface· 24
Display and maintenance commands for Ethernet interfaces· 24
The Switch Series supports Ethernet interfaces, management Ethernet interfaces, Console interfaces, and USB interfaces. For the interface types and the number of interfaces supported by a switch model, see the hardware manuals.
This chapter describes how to configure management Ethernet interfaces and Ethernet interfaces.
You can connect a management Ethernet interface to a PC for software loading and system debugging, or connect it to a remote NMS for remote system management.
Each member device in an IRF system has a management Ethernet interface. For management link backup, perform the following tasks:
1.     Connect your PC to the management Ethernet interface on the master device.
2.     Connect the PC to a management Ethernet interface with the same interface number on a subordinate device.
The two management Ethernet interfaces operate as follows:
·     When the IRF system has multiple management Ethernet interfaces, only the management Ethernet interface on the master device processes management traffic.
·     When the management Ethernet interface on the master device fails, the management Ethernet interface on the subordinate device takes over to process management traffic.
·     When the management Ethernet interface on the master device recovers, it takes over to process management traffic again.
2.     Enter management Ethernet interface view.
interface M-GigabitEthernet interface-number
3.     (Optional.) Set the interface description.
The default setting is M-GigabitEthernet0/0/0 Interface.
4.     (Optional.) Set the duplex mode for the management Ethernet interface.
duplex { auto | full | half }
By default, the duplex mode is auto for a management Ethernet interface.
5.     (Optional.)_Set the speed for the management Ethernet interface.
speed { 10 | 100 | 1000 | auto }
By default, the speed is auto for a management Ethernet interface.
6.     (Optional.) Shut down the interface.
shutdown
By default, the management Ethernet interface is up.
CAUTION
CAUTION:
Executing the shutdown command on an interface will disconnect the link of the interface and interrupt communication. Use this command with caution.
The Ethernet interfaces are named in the format of interface type A/B/C. The letters that follow the interface type represent the following elements:
·     A—IRF member ID. If the switch is not in an IRF fabric, A is 1 by default.
·     B—Card slot number. 0 indicates the interface is a fixed interface of the switch.
·     C—Port index.
A 10-GE or 25-GE breakout interface split from a 100-GE interface is named in the format of interface type A/B/C:D. A/B/C is the interface number of the 100-GE interface. D is the number of the 10-GE or 25-GE interface, which is in the range of 1 to 4. For information about splitting a 100-GE interface into 10-GE breakout interfaces, see "Splitting a 100-GE interface and combining 10-GE breakout interfaces." For information about splitting a 100-GE interface into 25-GE breakout interfaces, see "Splitting a 100-GE interface and combining 25-GE breakout interfaces."
When a local 25-GE interface on an S9820-64H switch is connected to a peer 25-GE interface on a different device, the interface configuration requirements are as shown in Table 1 and Table 2. For interfaces to operate properly, you must enable link compensation (also known as training or CL72) on both ends when the interfaces are connected by using a copper cable. This requirement is not otherwise described in Table 1 and Table 2.
In Table 1 and Table 2, the 25-GE interfaces (including 25-GE breakout interfaces split from a 100-GE interface) are supposed to be connected when they use the default settings.
Table 1 States of a local 25-GE interface split from an interface numbered 1 through 32 on an S9820-64H switch
Peer device
Local interface state and operations for bringing the interface up
S6820 switch series
By default, the local interface is down.
·     When the local interface is connected to the peer by using a cable, perform the following operations:
¡     Configure the local interface to operate in the same speed and duplex mode as the peer interface. Do not configure autonegotiation settings.
¡     Set the FEC mode to BASE-R FEC for the local interface.
¡     Execute the port media-type copper command on the peer interface if the peer interface is one of Twenty-FiveGigE1/0/1 through Twenty-FiveGigE1/0/8 and Twenty-FiveGigE1/0/49 through Twenty-FiveGigE1/0/56 on an S6820-56HF switch or an SFP28 interface on an LSWM124TG2H interface module.
·     When the local interface is connected to the peer by using a transceiver module, set the FEC mode to BASE-R FEC for the local interface.
25-GE breakout interfaces split from interfaces 1 through 32 on an S9820-64H switch
Up by default.
25-GE breakout interfaces split from interfaces 33 through 64 on an S9820-64H switch
·     By default, the local interface is down when connected to the peer by using a cable. To bring up the local interface, perform the following operations:
¡     Set the FEC mode to RS-FEC for the local interface.
·     The local interface is up by default when connected to the peer by using a transceiver module.
S9850-4C, S6850-2C
¡     Execute the port media-type copper command on the peer interface if the peer interface is an SFP28 interface on an LSWM124TG2H interface module.
S6850-56HF, S9850-32H
Up by default.
Table 2 States of a local 25-GE interface split from an interface numbered 33 through 64 on an S9820-64H switch
Peer device
S6820 switch series
¡     Configure the peer interface to operate in the same speed and duplex mode as the local interface. Do not configure autonegotiation settings.
¡     Set the FEC mode to RS-FEC for the peer interface.
Up by default.
S9850-4C, S6850-2C
·     When the local interface is connected to the peer by using a cable, execute the port media-type copper command on the peer interface if the peer interface is an SFP28 interface on an LSWM124TG2H interface module.
·     When the local interface is connected to the peer by using a transceiver module, the local interface is up by default.
Changing the link type of an Ethernet interface, splitting an interface, or combining breakout interfaces can cause temporary packet loss on the device if the following data buffer configuration exists on the device.
·     buffer egress cell queue shared (setting the maximum size of the shared area that the queue can use)
·     buffer service-pool shared (setting the size of the shared area that the service pool can use)
For more information about data buffer configuration, see ACL and QoS Configuration Guide.
This section describes the settings common to Layer 2 Ethernet interfaces, Layer 3 Ethernet interfaces, and Layer 3 Ethernet subinterfaces. For more information about the settings specific to Layer 2 Ethernet interfaces, see "Configuring a Layer 2 Ethernet interface." For more information about the settings specific to Layer 3 Ethernet interfaces or subinterfaces, see "Configuring a Layer 3 Ethernet interface or subinterface."
You can use a 100-GE interface as a single interface. To improve port density, reduce costs, and improve network flexibility, you can split a 100-GE interface with a split-capable transceiver module installed into four 10-GE breakout interfaces. The 10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered differently. For example, you can split 100-GE interface HundredGigE 1/0/1 into four 10-GE breakout interfaces Ten-GigabitEthernet1/0/1:1 through Ten-GigabitEthernet1/0/1:4.
If you need higher bandwidth on a single interface, you can combine the multiple 10-GE breakout interfaces into a 100-GE interface.
Restrictions and guidelines for 100-GE interface splitting and 10-GE breakout interface combining
·     A 100-GE interface split into multiple 10-GE breakout interfaces must use a dedicated cable. After you combine the multiple 10-GE breakout interfaces, replace the dedicated cable with a dedicated 1-to-1 cable or a 100-GE transceiver module. For more information about the cable or transceiver module, see the installation guides.
After configuring this feature, you do not need to reboot the device. To view information about the breakout interfaces, execute the display interface brief command. Only odd-numbered interfaces on the switch can be split. When an odd-numbered interface is split, the interface numbered the odd number + 1 is deleted.
An interface with any of the following configurations cannot be split:
·     IRF physical interface.
·     Service loopback group member.
·     Reflector port for mirroring.
·     Forcibly bringing up a fiber port.
Splitting a 100-GE interface into multiple 10-GE breakout interfaces
2.     Enter 100-GE interface view.
interface hundredgige interface-number
3.     Split the 100-GE interface into multiple 10-GE breakout interfaces.
using tengige
By default, a 100-GE interface is not split and operates as a single interface.
Combining multiple 10-GE breakout interfaces into a 100-GE interface
2.     Enter the view of any 10-GE breakout interface.
interface ten-gigabitethernet interface-number
3.     Combine the multiple 10-GE breakout interfaces into a 100-GE interface.
using hundredgige
By default, a 10-GE breakout interface operates as a single interface.
You can use a 100-GE interface as a single interface. To improve port density, reduce costs, and improve network flexibility, you can also split a 100-GE interface into four 25-GE breakout interfaces. The 25-GE breakout interfaces support the same configuration and attributes as common 25-GE interfaces, except that they are numbered differently.
For example, you can split 100-GE interface HundredGigE 1/0/1 into four 25-GE breakout interfaces Twenty-FiveGigE 1/0/1:1 through Twenty-FiveGigE 1/0/1:4.
If you need higher bandwidth on a single interface, you can combine the four 25-GE breakout interfaces into a 100-GE interface.
Restrictions and guidelines for 100-GE interface splitting and 25-GE breakout interface combining
·     A 100-GE interface split into four 25-GE breakout interfaces must use a dedicated 1-to-4 cable. After you combine the four 25-GE breakout interfaces, replace the dedicated 1-to-4 cable with a dedicated 1-to-1 cable or a 100-GE transceiver module. For more information about the cable or transceiver module, see the installation guides.
Splitting a 100-GE interface into four 25-GE breakout interfaces
3.     Split the 100-GE interface into four 25-GE breakout interfaces.
using twenty-fivegige
Combining four 25-GE breakout interfaces into a 100-GE interface
2.     Enter the view of any 25-GE breakout interface.
interface twenty-fivegige interface-number
3.     Combine the four 25-GE breakout interfaces into a 100-GE interface.
using hundredgige
By default, a 25-GE breakout interface operates as a single interface.
You can configure an Ethernet interface to operate in one of the following duplex modes:
·     Full-duplex mode—The interface can send and receive packets simultaneously.
·     Autonegotiation mode—The interface negotiates a duplex mode with its peer.
You can set the speed of an Ethernet interface or enable it to automatically negotiate a speed with its peer.
The shutdown and port up-mode commands are mutually exclusive.
The shutdown command cannot be configured on an Ethernet interface in a loopback test.
2.     Enter Ethernet interface view.
3.     Set the description for the Ethernet interface.
The default setting is interface-name Interface. For example, HundredGigE1/0/1 Interface.
4.     Set the duplex mode for the Ethernet interface.
duplex { auto | full }
By default, the duplex mode is auto for Ethernet interfaces.
5.     Set the speed for the Ethernet interface.
speed { 10 | 100 | 1000 | 10000 | 25000 | 40000 | 100000 | auto }
By default, an Ethernet interface negotiates a speed with its peer.
6.     Set the expected bandwidth for the Ethernet interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
7.     Bring up the Ethernet interface.
By default, Ethernet interfaces are in up state.
By default, a Layer 3 Ethernet subinterface processes packets for only the VLAN whose ID is the same as the subinterface number.
Restrictions and guidelines for Ethernet subinterface basic settings
·     The shutdown command cannot be configured on an Ethernet interface in a loopback test.
2.     Create an Ethernet subinterface.
interface interface-type interface-number.subnumber
3.     Set the description for the Ethernet subinterface.
The default setting is interface-name Interface. For example, HundredGigE1/0/1.1 Interface.
4.     Set the expected bandwidth for the Ethernet subinterface.
5.     Bring up the Ethernet subinterface.
By default, Ethernet subinterfaces are in up state.
Interfaces on the device can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can use commands to set the link mode to bridge or route.
3.     Configure the link mode of the Ethernet interface.
By default, all Ethernet interfaces on the device operate in bridge mode.
CAUTION
CAUTION:
After you change the link mode of an Ethernet interface, all commands (except the description, duplex, jumboframe enable, speed, shutdown commands) on the Ethernet interface are restored to their defaults in the new link mode.
Jumbo frames are frames larger than 1536 bytes and are typically received by an Ethernet interface during high-throughput data exchanges, such as file transfers.
The Ethernet interface processes jumbo frames in the following ways:
·     When the Ethernet interface is configured to deny jumbo frames (by using the undo jumboframe enable command), the Ethernet interface discards jumbo frames.
·     When the Ethernet interface is configured with jumbo frame support, the Ethernet interface performs the following operations:
¡     Processes jumbo frames within the specified length.
¡     Discards jumbo frames that exceed the specified length.
3.     Configure jumbo frame support.
jumboframe enable [ size ]
By default, the device allows jumbo frames within 9416 bytes to pass through.
If you set the size argument multiple times, the most recent configuration takes effect.
The physical link state of an Ethernet interface is either up or down. Each time the physical link of an interface comes up or goes down, the interface immediately reports the change to the CPU. The CPU then performs the following operations:
·     Notifies the upper-layer protocol modules (such as routing and forwarding modules) of the change for guiding packet forwarding.
·     Automatically generates traps and logs to inform users to take the correct actions.
To prevent frequent physical link flapping from affecting system performance, configure physical state change suppression. You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event to the CPU.
Do not enable this feature on an interface that has RRPP, spanning tree protocols, or Smart Link enabled.
You can configure different suppression intervals for link-up and link-down events.
If you execute the link-delay command multiple times on an interface, the following rules apply:
·     You can configure the suppression intervals for link-up and link-down events separately.
·     If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
The link-delay, dampening, and port link-flap protect enable commands are mutually exclusive on an Ethernet interface.
3.     Configure physical state change suppression.
By default, each time the physical link of an interface goes up or comes down, the interface immediately reports the change to the CPU.
The interface dampening feature uses an exponential decay mechanism to prevent excessive interface flapping events from adversely affecting routing protocols and routing tables in the network. Suppressing interface state change events protects the system resources.
If an interface is not dampened, its state changes are reported. For each state change, the system also generates an SNMP trap and log message.
After a flapping interface is dampened, it does not report its state changes to the CPU. For state change events, the interface only generates SNMP trap and log messages.
·     Penalty—The interface has an initial penalty of 0. When the interface flaps, the penalty increases by 1000 for each down event until the ceiling is reached. It does not increase for up events. When the interface stops flapping, the penalty decreases by half each time the half-life timer expires until the penalty drops to the reuse threshold.
·     Ceiling—The penalty stops increasing when it reaches the ceiling.
·     Suppress-limit—The accumulated penalty that triggers the device to dampen the interface. In dampened state, the interface does not report its state changes to the CPU. For state change events, the interface only generates SNMP traps and log messages.
·     Reuse-limit—When the accumulated penalty decreases to this reuse threshold, the interface is not dampened. Interface state changes are reported to the upper layers. For each state change, the system also generates an SNMP trap and log message.
·     Decay—The amount of time (in seconds) after which a penalty is decreased.
·     Max-suppress-time—The maximum amount of time the interface can be dampened. If the penalty is still higher than the reuse threshold when this timer expires, the penalty stops increasing for down events. The penalty starts to decrease until it drops below the reuse threshold.
When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2(Max-suppress-time/Decay)  × reuse-limit. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
Figure 1 shows the change rule of the penalty value. The lines t0 and t2 indicate the start time and end time of the suppression, respectively. The period from t0 to t2 indicates the suppression period, t0 to t1 indicates the max-suppress-time, and t1 to t2 indicates the complete decay period.
Figure 1 Change rule of the penalty value
·     The dampening, link-delay, and port link-flap protect enable commands are mutually exclusive on an interface.
·     The dampening command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the upper-layer protocols.
·     Do not enable the dampening feature on an interface with RRPP, MSTP, or Smart Link enabled.
3.     Enable dampening on the interface.
By default, interface dampening is disabled on Ethernet interfaces.
Link flapping on an interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, configure this feature on the interface.
With this feature enabled on an interface, when the interface goes down, the system enables link flapping detection. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
This feature takes effect only if it is configured in both the system view and interface view.
When you configure this feature on an interface, how link flapping protection is triggered depends on the parameters specified:
·     If you specify level-1 link flapping protection parameters but do not specify level-2 parameters, link flapping protection will be triggered and the interface will be shut down when the level-1 link flapping protection conditions are met.
·     If you specify both level-1 and level-2 link flapping protection parameters, link flapping protection will be triggered and the interface will be shut down when either of level-1 and level-2 link flapping protection conditions are met.
IRF system stability might be affected by IRF physical link flapping. For IRF system stability, this feature is enabled by default on IRF physical interfaces and the enabling status of this feature is not affected by the status of global link flapping protection. When the number of flaps detected on an IRF physical interface exceeds the threshold within the detection interval, the device outputs a log rather than shuts down the IRF physical interface.
The dampening, link-delay, and port link-flap protect enable commands are mutually exclusive on an Ethernet interface.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
In the display interface command output, the Link-Flap DOWN value of the Current state field indicates that the interface has been shut down by link flapping protection.
2.     Enable link flapping protection globally.
By default, link flapping protection is disabled globally.
3.     Enter Ethernet interface view.
4.     Enable link flapping protection on the Ethernet interface.
port link-flap protect enable [ interval interval | threshold threshold ] * [ second-interval second-interval second-threshold second-threshold ]
By default, link flapping protection is disabled on an Ethernet interface.
Configuring FEC
The forward error correction (FEC) feature corrects packet errors to improve transmission quality. It attaches correction information to a packet at the sending end, and corrects error codes generated during transmission at the receiving end based on the correction information. You can set the FEC mode as needed.
This feature is supported only on 100-GE interfaces.
Make sure you set the same FEC mode for both interfaces of a link.
3.     Set the FEC mode of the Ethernet interface.
port fec mode { auto | none | rs-fec }
By default, the FEC mode of an Ethernet interface is autonegotiation.
Enabling FEC bypass
By default, when an interface continuously receives three or more packets that it cannot process, the device will shut down and then bring up the interface to fix the interface. However, there are many possible packet error reasons. If you are sure that the interface is not faulty, you do not need to fix the interface. To avoid service interruption in this case, you can enable this feature on the interface to prevent the device from shutting down and bringing up the interface.
This feature is supported only on 25-GE, 40-GE, and 100-GE interfaces.
3.     Enable FEC bypass.
port fec bypass enable
By default, FEC is disabled.
As the signal transmission rate or frequency increases, high frequency components in signals attenuate more severely. For signal transmission performance, common signal compensation technologies such as pre-emphasis and equalization are introduced. Pre-emphasis amplifies high frequency components but increases the probability of crosstalk. Equalization is introduced to filter out high frequency crosstalk on the receiving end.
Link compensation enables the sending and receiving ends to exchange pre-emphasis and equalization parameters through frames. This feature improves the performance of pre-emphasis and equalization.
Only 25-GE Ethernet interfaces connected through copper cables support this command. For 25-GE interfaces connected through copper cables to operate properly, you must enable link compensation.
You must enable or disable link compensation on both interfaces of a link.
Typically, the link compensation status is controlled by the software, and do not adjust the link compensation status as a best practice. Use this command to adjust the link compensation status only when the interface cannot come up.
3.     Configure link compensation on the interface.
port training { disable | enable }
By default, link compensation is disabled on an interface.
The storm suppression feature ensures that the size of a particular type of traffic (broadcast, multicast, or unknown unicast traffic) does not exceed the threshold on an interface. When the broadcast, multicast, or unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the traffic drops below this threshold.
Both storm suppression and storm control can suppress storms on an interface. Storm suppression uses the chip to suppress traffic. Storm suppression has less impact on the device performance than storm control, which uses software to suppress traffic.
·     For the traffic suppression result to be determined, do not configure storm control together with storm suppression for the same type of traffic. For more information about storm control, see "Configuring storm control on an Ethernet interface."
·     When you configure the suppression threshold in kbps, the actual suppression threshold might be different from the configured one as follows:
¡     If the configured value is smaller than 64, the value of 64 takes effect.
¡     If the configured value is greater than 64 but not an integer multiple of 64, the integer multiple of 64 that is greater than and closest to the configured value takes effect.
For the suppression threshold that takes effect, see the prompt on the device.
·     Set the same type of thresholds for each interface, that is, set the ratio argument, pps max-pps option, or kbps max-kbps option for the interface.
3.     Enable broadcast suppression and set the broadcast suppression threshold.
By default, broadcast suppression is disabled.
4.     Enable multicast suppression and set the multicast suppression threshold.
multicast-suppression { ratio | pps max-pps | kbps max-kbps } [ unknown ]
By default, multicast suppression is disabled.
5.     Enable unknown unicast suppression and set the unknown unicast suppression threshold.
By default, unknown unicast suppression is disabled.
To avoid dropping packets on a link, you can enable generic flow control at both ends of the link. When traffic congestion occurs at the receiving end, the receiving end sends a flow control (Pause) frame to ask the sending end to suspend sending packets. Generic flow control includes the following types:
·     TxRx-mode generic flow control—Enabled by using the flow-control command. With TxRx-mode generic flow control enabled, an interface can both send and receive flow control frames:
¡     When congestion occurs, the interface sends a flow control frame to its peer.
¡     When the interface receives a flow control frame from its peer, it suspends sending packets to its peer.
·     Rx-mode generic flow control—Enabled by using the flow-control receive enable command. With Rx-mode generic flow control enabled, an interface can receive flow control frames, but it cannot send flow control frames:
¡     When congestion occurs, the interface cannot send flow control frames to its peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end and the flow-control command at the other end. To enable both ends of a link to handle traffic congestion, configure the flow-control command at both ends.
To implement flow control, configure flow control on each interface that the traffic passes through.
3.     Enable generic flow control.
¡     Enable TxRx-mode generic flow control.
flow-control
¡     Enable Rx-mode generic flow control.
By default, generic flow control is disabled on an Ethernet interface.
By setting the statistics polling interval, you can collect statistics of packets and analyze packets at the specified interval. Based on the interface traffic statistics, you can take traffic control measures promptly to avoid network congestion and service interruption.
·     When network congestion is detected, you can set the statistics polling interval to be smaller than 300 seconds (30 seconds when congestion deteriorates). Then, check traffic distribution on interfaces within a short period of time. For data packets that cause congestion, take traffic control measures.
·     When the network bandwidth is sufficient and services are operating normally, you can set the statistics polling interval to be greater than 300 seconds. Once traffic parameter anomalies occur, modify the statistics polling interval promptly so that you can observe the traffic parameter trend in real time.
To display the interface statistics collected in the last statistics polling interval, use the display interface command. To clear the interface statistics, use the reset counters interface command.
Setting the statistics polling interval in Ethernet interface view
3.     Set the statistics polling interval for the Ethernet interface.
flow-interval interval
By default, the statistics polling interval is 300 seconds.
Perform this task to determine whether an Ethernet link works correctly.
Loopback testing includes the following types:
·     Internal loopback testing—Tests the device where the Ethernet interface resides. The Ethernet interface sends outgoing packets back to the local device. If the device fails to receive the packets, the device fails.
·     External loopback testing—Tests the hardware function of the Ethernet interface. The Ethernet interface sends outgoing packets to the local device through a self-loop plug. If the device fails to receive the packets, the hardware function of the Ethernet interface fails.
·     After you enable this feature on an Ethernet interface, the interface does not forward data traffic.
·     You cannot perform a loopback test on the following Ethernet interfaces:
¡     Ethernet interfaces manually brought down (displayed as in ADM or Administratively DOWN state).
¡     Ethernet interfaces with the port up-mode command executed.
·     The speed, duplex, and shutdown commands cannot be executed on an Ethernet interface in a loopback test.
·     After you enable this feature on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable this feature, the Ethernet interface restores to its duplex setting.
3.     Configure loopback testing on the Ethernet interface.
¡     Enable loopback testing on the Ethernet interface.
loopback{ external | internal }
By default, loopback testing is disabled on an Ethernet interface.
As shown in Figure 2, a fiber port uses separate fibers for transmitting and receiving packets. The physical state of the fiber port is up only when both transmit and receive fibers are physically connected. If one of the fibers is disconnected, the fiber port does not work.
To enable a fiber port to forward traffic over a single link, you can use the port up-mode command. This command forcibly brings up a fiber port, even when no fiber links or transceiver modules are present for the fiber port. When one fiber link is present and up, the fiber port can forward packets over the link unidirectionally.
Figure 2 Forcibly bring up a fiber port
·     The port up-mode and shutdown commands are mutually exclusive.
·     A fiber port does not support this feature if the port is shut down by a protocol or by using the shutdown command.
·     A fiber port forcibly brought up stays physically up whether or not a transceiver module or a fiber link is present for the port.
3.     Forcibly bring up the fiber port.
port up-mode
By default, a fiber port is not forcibly brought up, and the physical state of a fiber port depends on the physical state of the fibers.
With the interface alarm functions enabled, when the number of error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the interface alarm parameters in system view and interface view.
·     The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface.
·     For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
An interface that is shut down because of error packet alarms cannot automatically recover. To bring up the interface, execute the undo shutdown command on the interface.
Enabling interface alarm functions
2.     Enable alarm functions for the interface monitoring module.
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | tx-pause ] *
By default, all alarm functions are enabled for interfaces.
Configuring CRC error packet parameters
2.     Configure global CRC error packet alarm parameters.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packets.
4.     Configure CRC error packet alarm parameters for the interface.
By default, an interface uses the global CRC error packet alarm parameters.
Configuring input error packet alarm parameters
2.     Configure global input error packet alarm parameters.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packets.
4.     Configure input error packet alarm parameters for the interface.
By default, an interface uses the global input error packet alarm parameters.
Configuring output error packet alarm parameters
2.     Configure global output error packet alarm parameters.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packets.
4.     Configure output error packet alarm parameters.
By default, an interface uses the global output error packet alarm parameters.
Configuring input bandwidth usage alarm parameters
2.     Configure global input bandwidth usage alarm parameters.
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
By default, the upper threshold is 90 and the lower threshold is 80 for input bandwidth usage alarms.
4.     Configure input bandwidth usage alarm parameters.
By default, an interface uses the global input bandwidth usage alarm parameters.
Configuring output bandwidth usage alarm parameters
2.     Configure global output bandwidth usage alarm parameters.
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
By default, the upper threshold is 90 and the lower threshold is 80 for output bandwidth usage alarms.
4.     Configure output bandwidth usage alarm parameters.
By default, an interface uses the global output bandwidth usage alarm parameters.
Configuring received pause frame alarm parameters
2.     Configure global received pause frame alarm parameters.
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
By default, the upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for received pause frames.
4.     Configure received pause frame alarm parameters.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
By default, an interface uses the global received pause frame alarm parameters.
Configuring sent pause frame alarm parameters
2.     Configure global sent pause frame alarm parameters.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for sent pause frames.
4.     Configure sent pause frame alarm parameters.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, an interface uses the global sent pause frame alarm parameters.
This feature shuts down all physical interfaces except the management Ethernet interfaces on the device. Physical interfaces shut down by using this command are in ADM state.
To shut down all physical interfaces or the specified interface, execute the shutdown all-physical-interfaces command in system view or execute the shutdown command in interface view.
To bring up interfaces shut down by using the shutdown all-physical-interfaces command, execute its undo form in system view. To bring up an interface shut down by using the shutdown command, execute its undo form in interface view.
If you execute the shutdown all-physical-interfaces command with the include irf-physical-interface keyword multiple times, this command shuts down all physical interfaces except the management Ethernet interfaces on the device.
2.     Shut down all physical interfaces except management Ethernet interfaces.
shutdown all-physical-interfaces [ include irf-physical-interface ]
By default, physical interfaces are up.
CAUTION
CAUTION:
This feature might interrupt ongoing network services. Make sure you are fully aware of the impacts of this feature when you use it in a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
2.     Enter Ethernet interface view or Ethernet subinterface view.
3.     Restore the default settings for the interface.
default
Storm control compares broadcast, multicast and unknown unicast traffic regularly with their respective traffic thresholds on an Ethernet interface. For each type of traffic, storm control provides a lower threshold and an upper threshold.
Depending on your configuration, when a particular type of traffic exceeds its upper threshold, the interface performs either of the following operations:
·     Blocks this type of traffic and forwards other types of traffic—Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the interface begins to forward the traffic.
·     Goes down automatically—The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not automatically come up. To bring up the interface, use the undo shutdown command or disable the storm control feature.
You can configure an Ethernet interface to output threshold event traps and log messages when monitored traffic meets one of the following conditions:
·     Exceeds the upper threshold.
·     Drops below the lower threshold.
Both storm suppression and storm control can suppress storms on an interface. Storm suppression uses the chip to suppress traffic. Storm suppression has less impact on the device performance than storm control, which uses software to suppress traffic. For more information about storm suppression, see "Configuring storm suppression."
Storm control uses a complete polling cycle to collect traffic data, and analyzes the data in the next cycle. An interface takes one to two polling intervals to take a storm control action.
2.     (Optional.) Set the statistics polling interval of the storm control module.
storm-constrain interval interval
The default setting is 10 seconds.
For network stability, use the default or set a longer statistics polling interval.
4.     Enable storm control, and set the lower and upper thresholds for broadcast, multicast, or unknown unicast traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
By default, storm control is disabled.
5.     Set the control action to take when monitored traffic exceeds the upper threshold.
6.     Enable the Ethernet interface to output log messages when it detects storm control threshold events.
storm-constrain enable log
By default, the Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
7.     Enable the Ethernet interface to send storm control threshold event traps.
storm-constrain enable trap
By default, the Ethernet interface sends traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from the upper threshold from a value above the upper threshold.
By default, the device drops packets whose outgoing interface and incoming interface are the same.
To enable the device to forward such packets rather than drop them, enable the bridging feature in Ethernet interface view.
3.     Enable bridging on the Ethernet interface.
port bridge enable
By default, bridging is disabled on an Ethernet interface.
The maximum transmission unit (MTU) determines the maximum number of bytes in a single IP packet that can be sent. The length of an IP packet refers to the number of bytes starting from the IP header to the payload.
When the IP layer receives an IP data packet to be sent, the IP layer determines the local destination interface of the packet and obtains the MTU of the interface. The IP layer compares the MTU with the length of the data packet to be sent. If the length is greater than the MTU, the IP layer fragments the packet. The length of a fragment can be smaller than or equal to the MTU to ensure that big packets are not lost on the network.
As a best practice, use the default MTU. When the packet length or the packet receiver changes, you can adjust the MTU as needed. When configuring the MTU, follow these restrictions and guidelines:
·     If the configured MTU is small but the packet length is large, the following events might occur:
¡     Packets will be dropped when they are forwarded by hardware.
¡     Packets will be fragmented into too many fragments when packets are forwarded through the CPUs, which affects normal data transmission.
·     If the configured MTU is too large, the MTU will exceed the receiving capabilities of the receiver or a device along the transmission path. As a result, packets will be fragmented or even dropped, which increases the network transmission load and affects data transmission.
The MTU of an Ethernet interface affects the fragmentation and reassembly of IP packets on the interface. Typically, you do not need to modify the MTU of an interface.
2.     Enter interface view.
3.     Set the MTU for the interface.
mtu size
The default setting is 1500 bytes.
In a network, when the Layer 3 Ethernet interfaces or subinterfaces of different devices have the same MAC address, the devices might fail to communicate correctly. To eliminate the MAC address conflicts, use the mac-address command to modify the MAC addresses of Layer 3 Ethernet interfaces or subinterfaces.
3.     Set the interface MAC address.
mac-address mac-address
By default, no MAC address is set for an Ethernet interface.
As a best practice, do not set a MAC address in the VRRP-reserved MAC address range for a Layer 3 Ethernet subinterface.
For more information about the display diagnostic-information command, see device management in Fundamentals Command Reference.
Display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
Display traffic rate statistics of interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number ] ]
Display the operating information for the IFMGR module.
display diagnostic-information ifmgr [ key-info ] [ filename ]
Display the Ethernet module statistics.
display ethernet statistics slot slot-number
Display the operational and status information of the specified interfaces.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
Display the status and packet statistics of interfaces.
display interface link-info [ main ]
Display the operational and status information of interfaces except subinterfaces.
display interface [ interface-type ] [ brief [ description | down ] ] main
Display information about link flapping protection on interfaces.
display link-flap protection [ interface interface-type [ interface-number ] ]
Display the physical link state change statistics of interfaces.
display link-state-change statistics interface [ interface-type [ interface-number ] ]
Display information about dropped packets on the specified interfaces.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
Display information about storm control on the specified interfaces.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
Clear interface statistics.
reset counters interface [ interface-type [ interface-number ] ]
Clear the Ethernet module statistics.
reset ethernet statistics [ slot slot-number ]
Clear the physical link state change statistics of interfaces.
reset link-state-change statistics interface [ interface-type [ interface-number ] ]
Clear the statistics of dropped packets on the specified interfaces.
reset packet-drop interface [ interface-type [ interface-number ] ]
