| 04-Flow group commands | 73.92 KB |
display telemetry flow-group flow-table
telemetry flow-group aging-time
telemetry flow-group max-entry
telemetry flow-group rate-limit
Flow group commands
Use display telemetry flow-group to display the configuration and application status of flow groups.
display telemetry flow-group [ group-id | name group-name ] [ slot slot-number ]
group-id: Specifies a flow group by its ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group by its name, a case-sensitive string of 1 to 63 characters.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
If you do not specify the group-id or name group-name option, this command displays the configuration and application status of all flow groups.
# Display the configuration of flow group 1 and its application status in slot 3.
<Sysname> display telemetry flow-group 1 slot 3
Flow group 1 (Failed)
ACL : 2001
Template :
destination-ip
destination-port
source-ip
source-port
Mode : MOD
Aging time: 100 minutes
Rate limit: 100 pps
Max entry : 200
Flow group 2 named aaa (Successful) |
ID, name, and application status of the flow group. Values for the application status include: · Successful—The flow group is applied successfully. · Failed—The flow group fails to be applied for some reasons other than incomplete flow group configuration. · Inactive—The flow group has not been administratively applied. · Incomplete—The flow group fails to be applied because its configuration is incomplete. |
Rate limit |
Maximum rate of packets to the CPU in pps. A hyphen (-) indicates that no rate limit is configured. |
Max entry |
Maximum number of flow entries generated. A hyphen (-) indicates that no entry limit is configured. |
Use display telemetry flow-group flow-table to display the flow entries generated by flow groups.
display telemetry flow-group flow-table [ [ group-id | name group-name ] | mod ] [ destination-ip { dst-ipv4 | dst-ipv6 } | destination-port dst-port | protocol protocol | source-ip { src-ipv4 | src-ipv6 } | source-port src-port ] * { slot slot-number }
mod: Specifies flow groups in MOD mode and flow groups in simple MOD mode.
destination-ip { dst-ipv4 | dst-ipv6 }: Specifies the destination IPv4 or IPv6 address.
destination-port dst-port: Specifies the destination port number.
protocol protocol: Specifies the network layer protocol.
source-ip { src-ipv4 | src-ipv6 }: Specifies the source IPv4 or IPv6 address.
source-port src-port: Specifies the source port number.
If you do not specify flow groups, this command displays the flow entries generated by each flow group.
# Display the flow entries generated by flow group 1 for slot 3.
<Sysname> display telemetry flow-group flow-table 1 slot 3
Slot: 3
Flow group 1 (name: abc)
Mode: MOD
Src IP Dst IP Pro SPort DPort Aging Packets
In Src IP In Dst IP InP InSP InDP VXLAN ID Bytes
Drop Reason
192.168.1.86 192.168.10.2 6 20 30 12m10s 10
- - - - - - 12400
unknown-vlan
Mode |
Flow group mode: MOD—Simple MOD mode. |
In Src IP |
This field is not supported in the current software version. Inner source IP address of VXLAN packets. |
In Dst IP |
This field is not supported in the current software version. Inner destination IP address of VXLAN packets. |
InP |
This field is not supported in the current software version. Inner network layer protocol. |
InSP |
This field is not supported in the current software version. Inner source port number. |
InDP |
This field is not supported in the current software version. Inner destination port number. |
VXLAN ID |
This field is not supported in the current software version. VXLAN ID. |
Drop Reason |
Packet drop reason: · ip-multicast-error—IP multicast packet error. · ipv4-dip-miss—The destination IPv4 address of a packet does not match a route or matches the default route. · parity-error—Parity error. · tunnel-header-error—Tunnel packet header error. · unknown-vlan—Unknown VLAN. |
if-match acl
Use if-match acl to specify an ACL for a flow group.
Use undo if-match acl to remove an ACL from a flow group.
undo if-match acl
No ACL is specified for a flow group.
Flow group view
acl-number: Specifies the ACL number. The following are available value ranges:
· 2000 to 2999 for basic ACLs.
· 3000 to 3999 for advanced ACLs.
name acl-name: Specifies the ACL name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter.
When specifying an ACL, follow these restrictions and guidelines:
· If the specified ACL does not exist or does not have any rules, no traffic will match the ACL.
· An ACL rule can be configured only with a 5-tuple (source IP address, destination IP address, source port number, destination port number, and protocol type) and DSCP priority.
A flow group takes effect only on the traffic that matches the specified ACL.
Only one ACL can be specified for a flow group.
# Specify ACL 3000 in flow group 1.
[Sysname] telemetry flow-group 1
[Sysname-telemetry-flow-group-1] if-match acl 3000
acl (ACL and QoS Command Reference)
telemetry apply flow-group
Use telemetry apply flow-group to apply a flow group.
Use undo telemetry apply flow-group to remove the application of a flow group.
telemetry apply flow-group { group-id | name group-name }
undo telemetry apply flow-group { group-id | name group-name }
No flow group is applied.
# Apply flow group 1.
[Sysname] telemetry apply flow-group 1
Use telemetry flow-group to create a flow group and enter its view, or enter the view of an existing flow group.
Use undo telemetry flow-group to delete a flow group.
telemetry flow-group group-id [ name group-name ] mode simple-mod
undo telemetry flow-group { group-id | name group-name }
No flow groups exist.
group-id: Specifies a flow group ID. The value range for this argument is 1 to 7.
name group-name: Specifies a flow group name, a case-sensitive string of 1 to 63 characters. The name must be globally unique and cannot start with system-defined-.
mode: Specifies a flow group mode. Only simple MOD mode is supported.
· simple-mod: Specifies the simple MOD mode.
The flow entries generated by a flow group can be used by other features. A flow group can only be in simple MOD mode, which is used by MOD. This mode has a higher burden on the CPU but saves hardware resources.
You cannot name or rename an existing flow group and cannot modify the mode of an existing flow group.
To delete an applied flow group, first remove the application and then delete the flow group.
# Create flow group 3 in simple MOD mode and enter its view.
[Sysname] telemetry flow-group 3 mode simple-mod
[Sysname-telemetry-flow-group-3]
Use telemetry flow-group aging-time to set the aging time for flow entries.
Use undo telemetry flow-group aging-time to restore the default.
telemetry flow-group aging-time aging-time
The aging time for flow entries is 15 minutes.
aging-time: Specifies the aging time for flow entries in minutes. The value range for this argument is 1 to 16.
# Set the aging time for flow entries to 20 minutes.
[Sysname] telemetry flow-group aging-time 20
Use telemetry flow-group max-entry to set the maximum number of flow entries generated.
Use undo telemetry flow-group max-entry to restore the default.
telemetry flow-group max-entry max-entries
By default, the number of flow entries is not limited.
max-entries: Specifies the maximum number of flow entries generated. The value range for this argument is 1 to 8192.
When the maximum number of flow entries is reached, the device does not generate new flow entries until old flow entries are aged out.
# Set the maximum number of flow entries generated to 100.
[Sysname] telemetry flow-group max-entry 100
Use telemetry flow-group rate-limit to set the maximum rate of packets sent to the CPU to limit the flow entry generation rate.
Use undo telemetry flow-group rate-limit to restore the default.
telemetry flow-group rate-limit pps
By default, the rate of packets sent to the CPU is not limited.
pps: Specifies the maximum rate of packets sent to the CPU to limit the flow entry generation rate. The value range for this argument is 1 to 1024.
# Set the maximum rate of packets sent to the CPU to 100 pps.
[Sysname] telemetry flow-group rate-limit 100
template
Use template to configure a flow entry generation rule.
Use undo template to delete a flow entry generation rule.
template { destination-ip | destination-port | protocol | source-ip | source-port } *
undo template
No flow entry generation rule is configured.
destination-ip: Generates flow entries based on the destination IP address.
destination-port: Generates flow entries based on the destination port number.
protocol: Generates flow entries based on the Layer 3 protocol type.
source-ip: Generates flow entries based on the source IP address.
source-port: Generates flow entries based on the source port number.
This command enables the device to identify traffic and generate flow entries based on the specified header fields.
# Configure flow group 1 to generated flow entries based on the source IP address, destination IP address, source port number, and destination port number.
[Sysname-telemetry-flow-group-1] template destination-ip destination-port source-ip source-port
