10-Network Management and Monitoring Command Reference
HomeSupportSwitchesS9820 SeriesReference GuidesCommand ReferencesH3C S9820-8C Switch Command References-Release 671x-6W10010-Network Management and Monitoring Command Reference
15-Mirroring commands
15-Mirroring commands 126.08 KB
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 4.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
remote-destination: Specifies remote destination groups.
remote-source: Specifies remote source groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        HundredGigE1/1/1  Inbound
    Monitor port: HundredGigE1/1/2
Mirroring group 2:
    Type: Local
    Status: Active
    Mirroring port:
        HundredGigE1/1/5  Inbound
    Monitor port: HundredGigE1/1/6
                  Encapsulation: Destination IP address 1.1.1.1
                                 Source IP address 2.2.2.2
                                 DSCP 1
                                 VLAN 2
                                 VRF Instance 3
                                 Destination MAC address 0011-0200-0211
Mirroring group
Number of the mirroring group.
Type of the mirroring group:
·     Local.
·     Remote source.
·     Remote destination.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Mirroring port
Source port.
Encapsulation
Encapsulation parameters of the mirrored packets.
Mirroring CPU
Source CPU.
Monitor port
Destination port.
Destination IP address in the outer header of the GRE-encapsulated mirrored packets.
Source IP address
Source IP address in the outer header of the GRE-encapsulated mirrored packets.
DSCP
DSCP value in the outer header of the GRE-encapsulated mirrored packets.
VLAN
VLAN in the outer header of the GRE-encapsulated mirrored packets.
VRF Instance
VPN instance whose routing table is used to direct forwarding of the mirrored packets.
Destination MAC address in the outer header of the GRE-encapsulated mirrored packets.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is 1 to 4.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu
Use mirroring-group mirroring-cpu to configure source CPUs for a mirroring group.
Use undo mirroring-group mirroring-cpu to remove source CPUs from a mirroring group.
mirroring-group group-id mirroring-cpu slot slot-number-list inbound
undo mirroring-group group-id mirroring-cpu slot slot-number-list
No source CPU is configured for a mirroring group.
group-id: Specifies a mirroring group by its number. The specified mirroring group must already exist. The value range for this argument is 1 to 4.
slot slot-number-list: Specifies an IRF member device by its member ID. The slot-number argument is fixed at 1.
inbound: Mirrors only received packets.
You can configure source CPUs only for local mirroring groups and remote source groups.
# Create local mirroring group 1 to monitor the inbound traffic of the CPU on the specified slot.
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
mirroring-group
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
both: Mirrors both received and sent packets.
outbound: Mirrors only sent packets.
You can configure source ports only for local mirroring groups and remote source groups.
Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
A source port cannot be used as a reflector port, monitor port, or egress port.
A Layer 2 or Layer 3 aggregate interface can be configured as a source port of a local or a remote source group. However, the mirrored traffic direction of an aggregate interface cannot be the same as the mirrored traffic direction of its member ports in the same mirroring group. If the mirrored traffic direction of an aggregate interface is the same as the mirrored traffic direction of an interface in the same group, do not assign the interface to the aggregate interface. Otherwise, the mirroring source configuration does not take effect for the interface and the aggregate interface in the specified direction.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port HundredGigE 1/1/1.
[Sysname] interface hundredgige 1/1/1
[Sysname-HundredGigE1/1/1] mirroring-group 1 mirroring-port both
# Create remote source group 2 to monitor the bidirectional traffic of the port HundredGigE 1/1/2.
[Sysname] mirroring-group 2 remote-source
[Sysname] interface hundredgige 1/1/2
[Sysname-HundredGigE1/1/2] mirroring-group 2 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of HundredGigE 1/1/1.
[Sysname] mirroring-group 1 mirroring-port hundredgige 1/1/1 both
# Create remote source group 2 to monitor the bidirectional traffic of HundredGigE 1/1/2.
[Sysname] mirroring-group 2 mirroring-port hundredgige 1/1/2 both
mirroring-group
mirroring-group monitor-egress
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
·     Spanning tree.
·     IGMP snooping.
·     Static ARP.
·     MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
# Create remote source group 1. Configure HundredGigE 1/1/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress hundredgige 1/1/1
# Create remote source group 2. Configure HundredGigE 1/1/2 as its egress port in interface view.
[Sysname-HundredGigE1/1/2] mirroring-group 2 monitor-egress
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * ]
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 2. The default DSCP value is 0.
Table 2 DSCP keywords and values
Keyword
DSCP value in binary
DSCP value in decimal
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094 for the mirrored packets.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
You can configure monitor ports only for local mirroring groups and remote destination groups.
Only when you configure Layer 3 remote port mirroring through encapsulation parameters, you can configure the following encapsulation parameters for mirrored packets sent to the monitor port:
·     Destination IP address, which is the IP address of the remote data monitoring device.
·     Source IP address.
·     Optional encapsulation parameters, including the DSCP value, VLAN, VPN instance, and destination MAC address.
The mirrored packet is first encapsulated in a GRE packet with a protocol number of 0x88BE. The GRE packet is then encapsulated in a delivery protocol by using the configured encapsulation parameters and routed to the final destination.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
A Layer 2 or Layer 3 aggregate interface cannot be configured as the monitor port for a mirroring group.
An aggregation member port cannot be configured as the monitor port.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
# Create local mirroring group 1 and configure HundredGigE 1/1/1 as its monitor port.
[Sysname-HundredGigE1/1/1] mirroring-group 1 monitor-port
# Create remote destination group 2 and configure HundredGigE 1/1/2 as its monitor port.
[Sysname] mirroring-group 2 remote-destination
[Sysname-HundredGigE1/1/2] mirroring-group 2 monitor-port
# Create local mirroring group 3. Specify HundredGigE 1/1/1 as its monitor port and configure the encapsulation parameters including the source and destination IP addresses, DSCP value, VLAN, and VPN instance for the mirrored packets.
[Sysname] mirroring-group 3 local
[Sysname-HundredGigE1/1/1] mirroring-group 3 monitor-port destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * ]
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port hundredgige 1/1/1
[Sysname] mirroring-group 2 monitor-port hundredgige 1/1/2
# Create local mirroring group 4. Specify HundredGigE 1/1/1 as its monitor port and configure the encapsulation parameters including the source and destination IP addresses, DSCP value, VLAN, and VPN instance for the mirrored packets.
[Sysname] mirroring-group 4 local
[Sysname] mirroring-group 4 monitor-port hundredgige 1/1/1 destination-ip 1.1.1.1 source-ip 3.3.3.3 dscp 1 vlan 1 vrf-instance 122
mirroring-group
mirroring-group reflector-port
Use mirroring-group reflector-port to configure the reflector port for a remote source group.
Use undo mirroring-group reflector-port to restore the default.
In system view:
mirroring-group group-id reflector-port interface-type interface-number
undo mirroring-group group-id reflector-port interface-type interface-number
In interface view:
No reflector port is configured for a mirroring group.
Interface view
WARNING
WARNING!
·     The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
·     When a port is configured as a reflector port, the port restores to the factory default settings. You cannot configure other features on a reflector port.
You can configure reflector ports only for remote source groups.
You cannot change the duplex mode or speed for a reflector port.
The member port of an aggregate interface cannot be configured as a reflector port.
# Create remote source group 1. Configure HundredGigE 1/1/1 as its reflector port in system view.
[Sysname] mirroring-group 1 reflector-port hundredgige 1/1/1
# Create remote source group 2. Configure HundredGigE 1/1/2 as its reflector port in interface view.
[Sysname-HundredGigE1/1/2] mirroring-group 2 reflector-port
mirroring-group
mirroring-group remote-probe vlan
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to grpc
Use mirror-to grpc to configure a mirroring action that mirrors traffic to gRPC.
Use undo mirror-to grpc to delete the mirroring action that mirrors traffic to gRPC.
mirror-to grpc
undo mirror-to grpc
No mirroring action exists to mirror traffic to gRPC.
Google Remote Procedure Call (gRPC) is a Google developed framework for remote procedure calls. gRPC provides a programmable method for monitoring and managing network devices.
This command enables the device to mirror traffic matching the traffic class in the QoS policy to the directly-connected gRPC network management server for traffic analysis.
For more information about gRPC, visit website www.grpc.io. For information about how to configure the gRPC network management server, see the network management server configuration guide.
# Create traffic behavior 1 and configure a mirroring action that mirrors traffic to gRPC.
[Sysname-behavior-1] mirror-to grpc
mirror-to ifa-processor
Use mirror-to ifa-processor to configure a mirroring action that mirrors traffic to the in-band network telemetry (INT) processor.
Use undo mirror-to ifa-processor to delete the mirroring action that mirrors traffic to the INT processor.
mirror-to ifa-processor [ sampler sampler-name ]
No mirroring action exists to mirror traffic to the INT processor.
sampler sampler-name: Specifies a sampler by its name. The sampler-name argument is a case-insensitive string of 1 to 31 characters. If you do not specify this option, packets are not sampled, and all matching packets are mirrored.
A sampler selects a packet from sequential packets. Flow mirroring uses the sampler to limit the volume of traffic to be mirrored. Flow mirroring supports using a sampler that has not been created. If you configure multiple samplers for a mirroring action, the most recent configuration takes effect. For more information about samplers, see Network Management and Monitoring Configuration Guide.
Flow mirroring is mutually exclusive with NetStream, IPv6 NetStream, NetAnalysis, sFlow, INT, Telemetry Stream, and MOD. For more information about NetStream, IPv6 NetStream, NetAnalysis, and sFlow, see Network Management and Monitoring Configuration Guide. For more information about INT, Telemetry Stream, and MOD, see Telemetry Configuration Guide.
Example
# Create traffic behavior 1 and configure the action of mirroring traffic to the INT processor. Specify sampler samp for the mirroring action.
[Sysname-behavior-1] mirror-to ifa-processor sampler samp
sampler
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
Syntax 1:
mirror-to interface interface-type interface-number [ sampler sampler-name ] [ loopback | [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * ]
undo mirror-to interface interface-type interface-number
Syntax 2:
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ sampler sampler-name ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] *
undo mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
Syntax 3:
mirror-to interface interface-type interface-number reflector-port interface-type interface-number strip-vlan vlan-id
No mirroring actions exist to mirror traffic to interfaces.
loopback: Uses the GRE encapsulation format for mirrored packets. Upon arriving at the specified interface, the mirrored packets are forwarded to the destination device through the GRE tunnel. The destination device decapsulates the packets and forwards them to the data monitoring device.
destination-ipv6 destination-ipv6-address: Specifies the destination IPv6 address for the mirrored packets.
source-ipv6 source-ipv6-address: Specifies the source IPv6 address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 3.
Table 3 DSCP keywords and values
Keyword
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
reflector-port interface-type interface-number: Specifies a reflector port by its type and number.
strip-vlan vlan-id: Specifies a VLAN where mirrored packets are broadcast by its ID in the range of 1 to 4094.
You can execute the mirror-to interface interface-type interface-number command multiple times for a traffic behavior to mirror traffic to different interfaces.
By using the mirror-to interface interface-type interface-number command, you can mirror traffic to a maximum of four Ethernet interfaces or Layer 2 aggregate interfaces. If more than four interfaces are configured, all the interfaces configured by using the command do not take effect.
To mirror traffic to the specified interface, use the mirror-to interface interface-type interface-number command.
To mirror traffic to interfaces based on routes matching the specified destination IP address, use the mirror-to interface destination-ip destination-ip-address source-ip source-ip-address command. When receiving packets that meet the flow mirroring criteria, the device performs the following tasks:
1.     Encapsulates the packets based on the configured encapsulation parameters, including the source and destination IP addresses.
2.     Searches the routing table for routes matching the configured destination IP address.
If ECMP load-balancing is configured, multiple matching ECMP routes might be found for the specified destination IP address.
3.     Sends the mirrored packets out of the output interfaces in the matching routes to the final destination.
If a selected output interface goes down, the device will send the mirrored packets out of another interface based on the routing metric recalculations.
If you do not specify a VLAN for the mirrored packets destined to a VLAN interface, the device encapsulates the packets as follows:
¡     The device determines whether to encapsulate a VLAN ID for the packets based on the VLAN settings for the Layer 2 Ethernet interface associated with the VLAN interface.
¡     To encapsulate a VLAN ID, the device uses the VLAN ID of the VLAN interface to encapsulate the packets.
When you use syntax 3 to mirror traffic to an interface, the device copies packets received on the mirroring sources to the destination interface. Then, the destination interface sends the mirrored packets to the specified reflector port, and the reflector port broadcasts the mirrored packets within the specified VLAN. This syntax is applicable only when the mirrored packets are VLAN-tagged and these packets must be sent out of the device untagged.
When you use syntax 3, the specified mirroring destination interface and reflector port must be assigned to a mirroring-type service loopback group. For more information about service loopback groups, see service loopback group configuration in Layer 2—LAN Switching Configuration Guide.
Flow-mirroring traffic to aggregate interfaces is not supported in the current software version.
# Create traffic behavior 1 and configure the action of mirroring traffic to HundredGigE 1/1/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface hundredgige 1/1/1
# Create traffic behavior 1, and configure the action of mirroring traffic to HundredGigE 1/1/1 for the traffic behavior. Specify the following parameters for the mirrored packets sent to HundredGigE 1/1/1:
·     Specify 1.1.1.1 and 2.2.2.2 as the destination address and source address, respectively.
·     Specify 20, 100, and vrf1 as the DSCP value, VLAN, and the VPN instance name, respectively.
[Sysname-behavior-1] mirror-to interface hundredgige 1/1/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
# Configure traffic behavior 1 to encapsulate mirrored packets with source address 2.2.2.2 and destination address 1.1.1.1 and send out the packets.
[Sysname-behavior-1] mirror-to interface destination-ip 1.1.1.1 source-ip 2.2.2
# Configure traffic behavior 1 to mirror packets to HundredGigE 1/1/1 with the reflector port as HundredGigE 1/1/2 and broadcast the mirrored packets with VLAN 100.
[Sysname-behavior-1] mirror-to interface hundredgige 1/1/1 reflector-port hundredgige 1/1/2 strip-vlan 100
