- 10-High availability
- 01-Dual-Link Backup Configuration Examples
- 02-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples
- 03-Dual-Link Backup OAuth-Based Portal Authentication in Local Forwarding Configuration Examples
- 04-Dual-Link Backup Remote Portal MAC-Trigger Authentication in Local Forwarding Configuration Examples
- 05-Dual-Link Backup Remote Portal and Transparent MAC Auth in Local Forwarding Configuration Examples
- 06-Dual-Link Backup Remote Portal Authentication in Local Forwarding Configuration Examples
- 07-Dual-Link Backup Remote Portal and Transparent MAC Auth in Centralized Forwarding Configuration Examples
- 08-Dual-Link Backup Remote Portal Authentication in Centralized Forwarding Configuration Examples
- 09-Dual-Link Backup Lightweight Portal Authentication in Centralized Forwarding Configuration Examples
- 10-Dual-Link Backup OAuth-Based Portal Authentication in Centralized Forwarding Configuration Examples
- 11-Dual-Link Backup Remote Portal MAC-Trigger Auth in Centralized Forwarding Configuration Examples
- 12-Remote 802.1X Authentication on a Dual-Link AC Backup Network Configuration Examples
- 13-Remote MAC Authentication on a Dual-Link AC Backup Network Configuration Examples
| 02-OAuth-Based Portal MAC-Trigger Auth on a Local-Forwarding Dual-Link Backup Configuration Examples | 376.49 KB |
H3C Access Controllers |
OAuth-Based Portal MAC-trigger Authentication on a Local-Forwarding Dual-Link Backup Network |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example of configuring OAuth-based portal MAC-trigger authentication on a local-forwarding dual-link backup network.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN high availability, AAA, portal MAC-trigger authentication, and WLAN access.
Example: Configuring OAuth-based portal MAC-trigger authentication on a local-forwarding dual-link backup network
As shown in Figure 1:
· The AP and the client obtain IP addresses from the DHCP server.
· The network deploys an IMC server as the portal authentication server, portal Web server, MAC binding server, and RADIUS server.
Configure the devices to meet the following requirements:
· The ACs operate in active/standby mode. When AC 1 (the master AC) fails, the AP associates with AC 2 (the backup AC). When AC 1 recovers, the AP re-associates with AC 1.
· The ACs use a service template to provide OAuth-based portal MAC-trigger authentication for the client. Before passing the authentication, the client can access only the portal Web server. After passing the authentication, the client can access other network resources. If the client goes offline and then attempts to come online again, the client does not need to enter the username and password.
· The AP forwards the client traffic locally.
· The client can access network resources through any Layer 2 ports in its access VLAN without re-authentication.
· The RADIUS server can dynamically change user authorization information or forcibly disconnect users.
Analysis
To allow a client to access network resources through any Layer 2 ports in its access VLAN without re-authentication, enable portal roaming.
In local forwarding mode, to ensure that valid clients can perform portal authentication, enable validity check on wireless clients.
To avoid portal authentication failure caused by frequent logins and logouts in a short time, disable the Rule ARP entry feature.
For the RADIUS server to dynamically change user authorization information or forcibly disconnect users, enable the RADIUS session-control feature.
To use GigabitEthernet 1/0/1 on the AP to forward client traffic, edit a .txt configuration file and upload the file to the ACs.
For dual-link backup to operate correctly, configure a manual AP or auto AP on the ACs. Make sure that the AP can establish CAPWAP tunnels with each of the ACs.
To implement MAC-trigger authentication by using the OAuth protocol, enable cloud MAC-trigger authentication by using the cloud-binding enable command.
Make sure the master and backup ACs have the same portal authentication configuration. The following items in the portal authentication can be different on the master and backup ACs:
· The portal Web server configuration.
· The BAS-IP attribute for portal packets sent to the portal authentication server.
· The specified interface of the AC for portal client access during portal authentication.
If you configure a manual AP on the ACs, make sure the AP name, serial ID, and MAC address of the manual AP are the same on the ACs.
Use the actual serial ID of an AP to uniquely identify that AP.
Some endpoints by default use random MAC addresses. For transparent MAC authentication to take effect on such an endpoint, disable the endpoint from using a random MAC address.
You must upload the configuration file of the AP to both the master and backup ACs.
Procedures
Editing the AP configuration file
# Use a text editor to edit the AP's configuration file. Name the configuration file map.txt, and then upload the file to the storage medium of the ACs.
The content of the configuration file is as follows:
vlan 200
interface gigabitethernet1/0/1
port link-type trunk
port trunk permit vlan 200
Configuring AC 1
1. Configure interfaces:
# Create VLAN 100, create VLAN-interface 100, and then assign the VLAN interface an IP address. The AC will use this IP address to establish CAPWAP control and data tunnels with the AP.
<AC1> system-view
[AC1] vlan 100
[AC1-vlan100] quit
[AC1] interface vlan-interface 100
[AC1-Vlan-interface100] ip address 2.2.1.1 24
[AC1-Vlan-interface100] quit
# Create VLAN 200, create VLAN-interface 200, and then assign the VLAN interface an IP address. This VLAN will be used for wireless client access.
[AC1] vlan 200
[AC1-vlan200] quit
[AC1] interface vlan-interface 200
[AC1-Vlan-interface200] ip address 2.2.2.1 24
[AC1-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects AC 1 to the switch as a trunk port, and assign the port to VLANs 100 and 200.
[AC1] interface gigabitethernet 1/0/1
[AC1-GigabitEthernet1/0/1] port link-type trunk
[AC1-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC1-GigabitEthernet1/0/1] quit
2. Configure a static route:
# Configure a static route to the IMC server.
[AC1] ip route-static 192.168.0.0 255.255.0.0 2.2.2.100
3. Configure the DNS server. (Details not shown.)
4. Configure the wireless service:
# Create a service template named st1.
[AC1] wlan service-template st1
# Set the SSID of the service template.
[AC1-wlan-st-st1] ssid service
# Specify VLAN 200 for the service template.
[AC1-wlan-st-st1] vlan 200
# Specify the AKM mode as PSK, and configure the preshared key as 12345678 in plain text.
[AC1-wlan-st-st1] akm mode psk
[AC1-wlan-st-st1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC1-wlan-st-st1] cipher-suite ccmp
[AC1-wlan-st-st1] security-ie rsn
# Configure the AP to forward client traffic. (Skip this step if the client data traffic forwarder is the AP by default.)
[AC1–wlan-st-st1] client forwarding-location ap
[AC1-wlan-st-st1] quit
5. Configure the AP:
NOTE: In large-scale networks, configure AP groups instead of single APs as a best practice. |
# Create an AP named office with model WA6320, and then specify the serial ID of the AP.
[AC1] wlan ap office model WA6320
[AC1-wlan-ap-office] serial-id 219801A28N819CE0002T
[AC1-wlan-ap-office] quit
# Create AP group group1 and add AP office to AP group group1.
[AC1] wlan ap-group group1
[AC1-wlan-ap-group-group1] ap office
# Set the AP connection priority to 7.
[AC1-wlan-ap-group-group1] priority 7
# Specify AC 2 as the backup AC for AC 1. Set the backup AC address as the IP address of VLAN-interface 100 on AC 2.
[AC1-wlan-ap-group-group1] backup-ac ip 2.2.1.2
# Enable master CAPWAP tunnel preemption.
[AC1-wlan-ap-group-group1] wlan tunnel-preempt enable
# Deploy configuration file map.txt to the AP.
[AC1-wlan-ap-group-group1] ap-model WA6320
[AC1-wlan-ap-group-group1-ap-model-WA6320] map-configuration map.txt
# Bind service template st1 to radio 2 in AP group group1.
[AC1-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st1
# Enable radio 2.
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC1-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC1-wlan-ap-group-group1-ap-model-WA6320] quit
[AC1-wlan-ap-group-group1] quit
6. Configure portal authentication:
# Create an ISP domain named dm1.
[AC1] domain dm1
# Configure the AC not to perform AAA on portal users.
[AC1-isp-dm1] authentication portal none
[AC1-isp-dm1] authorization portal none
[AC1-isp-dm1] accounting portal none
[AC1-isp-dm1] quit
# Create a portal Web server named newpt, specify http://192.168.0.111:8080/wsmAuth/protocol as the server's URL, and then configure the server type as OAuth. (Make sure the server' URL is the same as the URL of the actual portal Web server.)
[AC1] portal web-server newpt
[AC1-portal-websvr-newpt] url http://192.168.0.111:8080/wsmAuth/protocol
[AC1-portal-websvr-newpt] server-type oauth
# Enable the optimized captive-bypass feature for iOS users.
[AC1-portal-websvr-newpt] captive-bypass ios optimize enable
[AC1-portal-websvr-newpt] quit
# Create an HTTP-based local portal Web service.
[AC1] portal local-web-server http
[AC1-portal-local-websvr-http] quit
# Configure destination-based portal-free rules 2 and 3 to allow portal users to access the DNS server without authentication.
[AC1] portal free-rule 2 destination ip any udp 53
[AC1] portal free-rule 3 destination ip any tcp 53
# Configure the safe-redirect feature to reduce the redirect workload on the portal server.
[AC1] portal safe-redirect enable
[AC1] portal safe-redirect method get post
[AC1] portal safe-redirect user-agent CaptiveNetworkSupport
[AC1] portal safe-redirect user-agent MicroMessenger
[AC1] portal safe-redirect user-agent Mozilla
[AC1] portal safe-redirect user-agent WeChat
[AC1] portal safe-redirect user-agent iPhone
[AC1] portal safe-redirect user-agent micromessenger
# Specify VLAN-interface 200 as the interface for portal clients to access the AC during portal authentication.
[AC1] portal client-gateway interface vlan-interface 200
# Set the NAS ID. (Make sure the NAS ID is the same as that in the configuration file iMC\client\conf\wiportal\conf.properties.)
[AC1] wlan global-configuration
[AC1-wlan-global-configuration] nas-id wiportal
[AC1-wlan-global-configuration] quit
# Set the user synchronization interval to 60 seconds for portal authentication using OAuth.
[AC1] portal oauth user-sync interval 60
# Configure destination-based portal-free rules to allow users to access the portal Web server, AC 1, and AC 2 without authentication.
[AC1] portal free-rule 0 destination ip 192.168.0.111 32
[AC1] portal free-rule 1 destination ip 2.2.2.1 32
[AC1] portal free-rule 4 destination ip 2.2.2.2 32
# Enable roaming for portal users.
[AC1] portal roaming enable
# Disable the Rule ARP entry feature.
[AC1] undo portal refresh arp enable
# Enable the RADIUS session-control feature.
[AC1] radius session-control enable
# Enable validity check on wireless portal clients.
[AC1] portal host-check enable
# Enable direct portal authentication on service template st1.
[AC1-wlan-st-st1] portal enable method direct
# Specify ISP domain dm1 as the portal authentication domain.
[AC1-wlan-st-st1] portal domain dm1
# Specify portal Web server newpt on service template st1.
[AC1-wlan-st-st1] portal apply web-server newpt
# Enable portal temporary pass and set the temporary pass period to 300 seconds on service template st1.
[AC1-wlan-st-st1] portal temp-pass period 300 enable
# Configure the BAS-IP as 2.2.2.1 for portal packets sent from service template st1 to the portal authentication server.
[AC1-wlan-st-st1] portal bas-ip 2.2.2.1
7. Configure MAC-trigger authentication:
# Create a MAC binding server named mts.
[AC1] portal mac-trigger-server mts
# Specify 192.168.0.111 as the IP address of the MAC binding server.
[AC1-portal-mac-trigger-server-mts] ip 192.168.0.111
# Enable cloud MAC-trigger authentication (using Oauth for authentication).
[AC1-portal-mac-trigger-server-mts] cloud-binding enable
[AC1-portal-mac-trigger-server-mts] quit
# Specify MAC binding server mts on service template st1.
[AC1-wlan-st-st1] portal apply mac-trigger-server mts
# Enable service template st1.
[AC1-wlan-st-st1] service-template enable
Configuring AC 2
<AC2> system-view
[AC2] vlan 100
[AC2-vlan100] quit
[AC2] interface vlan-interface 100
[AC2-Vlan-interface100] ip address 2.2.1.2 24
[AC2-Vlan-interface100] quit
[AC2] vlan 200
[AC2-vlan200] quit
[AC2] interface vlan-interface 200
[AC2-Vlan-interface200] ip address 2.2.2.2 24
[AC2-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 that connects AC 2 to the switch as a trunk port, and assign the port to VLANs 100 and 200.
[AC2] interface gigabitethernet 1/0/1
[AC2-GigabitEthernet1/0/1] port link-type trunk
[AC2-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC2-GigabitEthernet1/0/1] quit
[AC2] ip route-static 192.168.0.0 255.255.0.0 2.2.2.100
[AC2] wlan service-template st1
[AC2-wlan-st-st1] ssid service
[AC2-wlan-st-st1] vlan 200
[AC2-wlan-st-st1] akm mode psk
[AC2-wlan-st-st1] preshared-key pass-phrase simple 12345678
[AC2-wlan-st-st1] cipher-suite ccmp
[AC2-wlan-st-st1] security-ie rsn
[AC2–wlan-st-st1] client forwarding-location ap
[AC2-wlan-st-st1] quit
[AC2] wlan ap office model WA6320
[AC2-wlan-ap-office] serial-id 219801A28N819CE0002T
[AC2-wlan-ap-office] quit
[AC2] wlan ap-group group1
[AC2-wlan-ap-group-group1] ap office
# Set the AP connection priority to 6.
[AC2-wlan-ap-group-group1] priority 6
# Specify AC 1 as the backup AC for AC 2. Set the backup AC address as the IP address of VLAN-interface 100 on AC 1.
[AC2-wlan-ap-group-group1] backup-ac ip 2.2.1.1
[AC2-wlan-ap-group-group1] wlan tunnel-preempt enable
[AC2-wlan-ap-group-group1] ap-model WA6320
[AC2-wlan-ap-group-group1-ap-model-WA6320] map-configuration map.txt
[AC2-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC2-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st1
# Enable radio 2.
[AC2-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC2-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
[AC2-wlan-ap-group-group1-ap-model-WA6320] quit
[AC2-wlan-ap-group-group1] quit
[AC2] domain dm1
[AC2-isp-dm1] authentication portal none
[AC2-isp-dm1] authorization portal none
[AC2-isp-dm1] accounting portal none
[AC2-isp-dm1] quit
# Create a portal Web server named newpt, specify http://192.168.0.111:8080/wsmAuth/protocol as the server's URL, and configure the server type as OAuth. (Make sure the server' URL is the same as the URL of the actual portal Web server.)
[AC2] portal web-server newpt
[AC2-portal-websvr-newpt] url http://192.168.0.111:8080/wsmAuth/protocol
[AC2-portal-websvr-newpt] server-type oauth
[AC2-portal-websvr-newpt] captive-bypass ios optimize enable
[AC2-portal-websvr-newpt] quit
# Create an HTTP-based local portal Web service and enter its view.
[AC2] portal local-web-server http
[AC2-portal-local-websvr-http] quit
[AC2] portal free-rule 2 destination ip any udp 53
[AC2] portal free-rule 3 destination ip any tcp 53
[AC2] portal safe-redirect enable
[AC2] portal safe-redirect method get post
[AC2] portal safe-redirect user-agent CaptiveNetworkSupport
[AC2] portal safe-redirect user-agent MicroMessenger
[AC2] portal safe-redirect user-agent Mozilla
[AC2] portal safe-redirect user-agent WeChat
[AC2] portal safe-redirect user-agent iPhone
[AC2] portal safe-redirect user-agent micromessenger
[AC2] portal client-gateway interface vlan-interface 200
[AC2] wlan global-configuration
[AC2-wlan-global-configuration] nas-id wiportal
[AC2-wlan-global-configuration] quit
[AC2] portal oauth user-sync interval 60
[AC2] portal free-rule 0 destination ip 192.168.0.111 32
[AC2] portal free-rule 1 destination ip 2.2.2.1 32
[AC2] portal free-rule 4 destination ip 2.2.2.2 32
[AC2] portal roaming enable
[AC2] undo portal refresh arp enable
[AC2] portal host-check enable
[AC2] radius session-control enable
[AC2-wlan-st-st1] portal enable method direct
[AC2-wlan-st-st1] portal domain dm1
[AC2-wlan-st-st1] portal apply web-server newpt
[AC2-wlan-st-st1] portal temp-pass period 300 enable
# Configure the BAS-IP as 2.2.2.2 for portal packets sent from service template st1 to the portal authentication server.
[AC2-wlan-st-st1] portal bas-ip 2.2.2.2
[AC2] portal mac-trigger-server mts
[AC2-portal-mac-trigger-server-mts] ip 192.168.0.111
# Enable cloud MAC-trigger authentication.
[AC2-portal-mac-trigger-server-mts] cloud-binding enable
[AC2-portal-mac-trigger-server-mts] quit
[AC2-wlan-st-st1] portal apply mac-trigger-server mts
[AC2-wlan-st-st1] service-template enable
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward traffic on CAPWAP tunnels between the ACs and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward packets for wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 2. The switch will use this VLAN to communicate with the IMC server.
[Switch] vlan 2
[Switch-vlan2] quit
# Assign the port that connects the switch to the IMC server to VLAN 2. (Details not shown.)
# Configure GigabitEthernet 1/0/1 (the port connected to AC 1) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/4 (the port connected to AC 2) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[Switch] interface gigabitethernet 1/0/4
[Switch-GigabitEthernet1/0/4] port link-type trunk
[Switch-GigabitEthernet1/0/4] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/4] quit
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as a trunk port, set the PVID to 100, and assign the port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk pvid vlan 100
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 100 200
# Enable PoE on GigabitEthernet 1/0/2.
# Configure GigabitEthernet 1/0/3 (the port connected to the DHCP server) as a trunk port, set the PVID to 100, and assign the port to VLAN 100 and VLAN 200.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type trunk
[Switch-GigabitEthernet1/0/3] port trunk permit vlan 100 200
# Assign an IP address to VLAN-interface 200.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 2.2.2.100 255.255.255.0
[Switch-Vlan-interface200] quit
# Assign an IP address to the VLAN-interface 2.
[Switch-Vlan-interface2] ip address 192.168.0.100 255.255.255.0
[Switch-Vlan-interface2] quit
Configuring the DHCP server
# Configure GigabitEthernet 1/0/1 (the port connected to the switch) as a trunk port, and assign the port to VLAN 100 and VLAN 200.
[DHCP] interface gigabitethernet 1/0/1
[DHCP-GigabitEthernet1/0/1] port link-type trunk
[DHCP-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[DHCP-GigabitEthernet1/0/1] quit
# Assign an IP address to VLAN-interface 100.
[DHCP] interface vlan-interface 100
[DHCP-Vlan-interface100] ip address 2.2.1.200 255.255.255.0
[DHCP-Vlan-interface100] quit
[DHCP] interface vlan-interface 200
[DHCP-Vlan-interface200] ip address 2.2.2.200 255.255.255.0
[DHCP-Vlan-interface200] quit
# Enable the DHCP service.
[DHCP] dhcp enable
# Configure DHCP address pool VLAN100. In the address pool, specify 2.2.1.200 as the gateway IP address and 2.2.1.0/24 as the subnet for dynamic allocation, and then exclude IP addresses 2.2.1.1 and 2.2.1.2 from dynamic allocation.
[DHCP] dhcp server ip-pool VLAN100
[DHCP-dhcp-pool-vlan100] gateway-list 2.2.1.200
[DHCP-dhcp-pool-vlan100] network 2.2.1.0 mask 255.255.255.0
[DHCP-dhcp-pool-vlan100] forbidden-ip 2.2.1.1 2.2.1.2
[DHCP-dhcp-pool-vlan100] quit
# Configure DHCP address pool VLAN200. In the address pool, specify 2.2.2.100 as the gateway IP address and 2.2.2.0/24 as the subnet for dynamic allocation, and 8.8.8.8 as the DNS server address, and then exclude IP addresses 2.2.2.100, 2.2.2.1, and 2.2.2.2 from dynamic allocation.
[DHCP] dhcp server ip-pool VLAN200
[DHCP-dhcp-pool-vlan200] gateway-list 2.2.2.100
[DHCP-dhcp-pool-vlan200] network 2.2.2.0 mask 255.255.255.0
[DHCP-dhcp-pool-vlan200] dns-list 8.8.8.8
[DHCP-dhcp-pool-vlan200] forbidden-ip 2.2.2.100 2.2.2.1 2.2.2.2
[DHCP-dhcp-pool-vlan200] quit
Configuring the IMC server
In this example, the IMC server runs IMC PLAT 7.3 (E0605) and IMC IPM 7.3 (E0516).
The IMC server configuration is the same for AC 1 and AC 2, except for the AC IP address. This section configures AC 1 as an example. Refer to AC 1 configuration when you configure AC 2 and remember to change the IP address setting for AC 2.
1. Add an access user:
a. Log in to IMC and click the Service tab.
b. From the navigation tree, select Intelligent Portal Management > User Management > Users.
c. Click Add to open the Add User page.
d. Enter username client and password admin@123.
e. Use the default settings for other parameters.
f. Click OK.
Figure 2 Adding an access user
2. Add an authentication page template:
a. From the navigation tree, select Intelligent Portal Management > Page Template List.
b. Click Add to open the Add Theme page.
c. Enter template name theme in the Theme Name field.
d. Use the default settings for other parameters.
e. Click OK to open the page for editing the template.
Figure 3 Adding an authentication page template
f. On the theme page, click
the Authentication icon
in
the Basic Controls area.
g. Click Edit in authentication edit area, select Other and Account in the Authentication Method area, click OK, and then click Save Page.
h. Use the default settings for other configuration.
i. Click Confirm Release.
3. Add an authentication policy:
a. From the navigation tree, select Intelligent Portal Management > Authentication Policies.
b. Click Add to open the Add Authentication Policy page.
c. Enter authentication policy name policy1, and select theme from the Page Template list.
d. Select a transparent authentication period to enable portal transparent authentication (MAC-trigger authentication).
f. Click OK.
Figure 5 Adding an authentication policy
4. Add a site:
a. From the navigation tree, select Intelligent Portal Management > Site Management.
b. Click Add to open the Add Site page.
c. Enter the site name, the site address, the expected number of clients to be supported, and the telephone number.
d. Click OK.
Figure 6 Adding a site
e. In the Associated APs area, click Add to associate an AP.
f. Enter the serial number and MAC address of the AP.
g. Click OK.
Figure 7 Adding an AP
i. In the Bind Authentication Policy area, click Add to bind the AP to an authentication policy.
j. Select authentication policy policy1.
k. Use the default settings for other parameters.
l. Click OK.
Figure 8 Binding the AP to an authentication policy
1. Verify that the AP can come online from AC 1 and AC 2.
# Display AP information on AC 1.
<AC1> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 6144
Remaining APs: 6143
Total AP licenses: 2048
Local AP licenses: 2048
Server AP licenses: 0
Remaining Local AP licenses: 2047
Sync AP licenses: 0
AP information
State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad
C = Config, DC = DataCheck, R = Run, M = Master, B = Backup
AP name APID State Model Serial ID
office 1 R/M WA6320 219801A28N819CE0002T
The output shows that the AP has come online from AC 1 and the AP is in the R/M state.
# Display AP information on AC 2.
<AC2> display wlan ap all
Remaining APs: 6143
Remaining Local AP licenses: 2048
Sync AP licenses: 0
AP information
office 1 R/B WA6320 219801A28N819CE0002T
The output shows that the AP has come online from AC 2 and the AP is in R/B state.
2. Verify that user Client can perform portal authentication through a Web browser on the wireless client. Before passing authentication, all Web accesses are redirected to the portal authentication page (http://192.168.0.111:8080/portal). After passing authentication, the user can access other network resources.
# Display online portal user information on the ACs. This example uses AC 1.
[AC1] display portal user all
Total portal users: 1
Username: client
AP name: office
Radio ID: 2
SSID: service
Portal server: newpt
State: Online
VPN instance: N/A
MAC IP VLAN Interface
0021-6330-0933 2.2.2.3 200 WLAN-BSS1/0/16
Authorization information:
DHCP IP pool: N/A
User profile: N/A
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
The output shows that the user has come online.
# Verify that the user can come online without entering the username and password when attempting to come online again. (Details not shown.)
3. Verify that the local forwarding mode can take effect.
# Display portal filtering rules on the ACs. This example uses AC 1.
[AC1] display portal rule all ap office
Slot 1:
The output shows that AC 1 does not have portal filtering rules, indicating that AC 1 does not forward client data traffic.
# Display portal filtering rules on the AP.
[AP] display portal rule all
IPv4 portal rules on WLAN-BSS1/0/16:
Rule 1:
Type : Static
Action : Permit
Protocol : Any
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : Any
MAC : 0000-0000-0000
Interface : WLAN-BSS1/0/16
VLAN : Any
Destination:
IP : 192.168.0.111
Mask : 255.255.255.255
Port : Any
Rule 2:
Type : Dynamic
Action : Permit
Status : Active
Source:
IP : 2.2.2.3
MAC : 0021-6330-0933
VLAN : Any
Rule 3:
Type : Static
Action : Redirect
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : Any
Protocol : TCP
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : 443
Rule 4:
Type : Static
Action : Redirect
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : Any
Protocol : TCP
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
Port : 80
Rule 5:
Type : Static
Action : Deny
Status : Active
Source:
IP : 0.0.0.0
Mask : 0.0.0.0
VLAN : Any
Destination:
IP : 0.0.0.0
Mask : 0.0.0.0
The output shows that the AP has portal filtering rules, indicating that the AP forwards client data traffic.
Configuration files
· AC 1:
nas-id wiportal
vlan 100
vlan 200
ssid service
vlan 200
akm mode psk
preshared-key pass-phrase cipher $c$3$oLf6pOZ6bxrf25nodjOJKYEfnZ6g6ErccHyQ
cipher-suite ccmp
security-ie rsn
portal domain dm1
interface Vlan-interface100
ip address 2.2.1.1 255.255.255.0
interface Vlan-interface200
ip address 2.2.2.1 255.255.255.0
port trunk permit vlan 1 100 200
ip route-static 192.168.0.0 16 2.2.2.100
domain dm1
portal client-gateway interface Vlan-interface200
portal free-rule 0 destination ip 192.168.0.111 255.255.255.255
portal free-rule 1 destination ip 2.2.2.1 255.255.255.255
portal free-rule 4 destination ip 2.2.2.2 255.255.255.255
server-type oauth
ip 192.168.0.111
priority 7
ap office
ap-model WA6320
map-configuration flash:/map.txt
radio 1
radio 2
radio enable
· AC 2:
nas-id wiportal
vlan 100
vlan 200
ssid service
vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
portal domain dm1
ip address 2.2.1.2 255.255.255.0
ip address 2.2.2.2 255.255.255.0
domain dm1
server-type oauth
ip 192.168.0.111
priority 6
ap office
ap-model WA6320
radio 1
radio 2
radio enable
· Switch:
vlan 2
vlan 100
vlan 200
poe enable
interface GigabitEthernet1/0/4
· DHCP server:
dhcp enable
dhcp server ip-pool vlan100
forbidden-ip 2.2.1.2
dhcp server ip-pool vlan200
dns-list 8.8.8.8
forbidden-ip 2.2.2.2
Related documentation
· High Availability Configuration Guide in H3C Access Controllers Configuration Guides
· High Availability Command Reference in H3C Access Controllers Command References
· User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
· User Access and Authentication Command Reference in H3C Access Controllers Command References
· WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
· WLAN Access Command Reference in H3C Access Controllers Command References
