- 07-IP Multicast Configuration Guide
- 01-IGMP configuration
- 02-IGMP snooping configuration
- 03-IPv6 multicast routing and forwarding configuration
- 04-IPv6 multicast VLAN configuration
- 05-IPv6 PIM configuration
- 06-IPv6 PIM snooping configuration
- 07-MLD configuration
- 08-MLD snooping configuration
- 09-Multicast overview
- 10-Multicast routing and forwarding configuration
- 11-Multicast VLAN configuration
- 12-PIM configuration
- 13-PIM snooping configuration
| 02-IGMP snooping configuration | 600.03 KB |
Restrictions and guidelines: IGMP snooping configuration
VLAN-based IGMP snooping tasks at a glance
VSI-based IGMP snooping tasks at a glance
Enabling the IGMP snooping feature
Enabling IGMP snooping globally
Enabling IGMP snooping for VLANs
Enabling IGMP snooping for a VSI
Configuring basic IGMP snooping features
Specifying an IGMP snooping version
Setting the maximum number of IGMP snooping forwarding entries
Configuring static multicast MAC address entries
Configuring static multicast MAC address entries for VXLAN
Setting the IGMP last member query interval
Configuring IGMP snooping port features
Setting aging timers for dynamic ports
Configuring a static member port
Configuring a static router port
Configuring a port as a simulated member host
Enabling fast-leave processing
Disabling a port from becoming a dynamic router port
Preventing the device from forwarding multicast data to router ports in a VLAN
Enabling inner VLAN ID-based forwarding
Specifying the Layer 2 multicast forwarding mode
About Layer 2 multicast forwarding modes
Restrictions and guidelines for specifying the Layer 2 multicast forwarding mode
Specifying the Layer 2 multicast forwarding mode for a VLAN
Specifying the Layer 2 multicast forwarding mode for a VSI
Configuring the IGMP snooping querier
Enabling the IGMP snooping querier
Enabling IGMP snooping querier election
Configuring parameters for IGMP general queries and responses
Enabling the device to send IGMP general queries upon a path change
Enabling the device to send IGMP general queries upon a port state change
Enabling IGMP snooping proxying
About enabling IGMP snooping proxying
Restrictions and guidelines for enabling IGMP snooping proxying
Enabling IGMP snooping proxying for a VLAN
Enabling IGMP snooping proxying for a VSI
Configuring parameters for IGMP messages
Configuring source IP addresses for IGMP messages
Setting the 802.1p priority for IGMP messages
Configuring IGMP snooping policies
Configuring a multicast group policy
Enabling multicast source port filtering
Enabling dropping unknown multicast data
Enabling IGMP report suppression
Setting the maximum number of multicast groups on a port
Enabling multicast group replacement
Configuring an IGMP snooping access control policy
Setting the DSCP value for outgoing IGMP protocol packets
Configuring IGMP snooping to support DRNI
Display and maintenance commands for IGMP snooping
IGMP snooping configuration examples
Example: Configuring VLAN-based IGMP snooping group polices and simulated joining
Example: Configuring VLAN-based IGMP snooping static ports
Example: Configuring the VLAN-based IGMP snooping querier
Example: Configuring VLAN-based IGMP snooping proxying
Example: Configuring IGMP snooping proxy for EVPN multihoming
Example: Configuring a VLAN-based IGMP snooping access policy
Example: Configuring VSI-based IGMP snooping
Example: Configuring VXLAN-based IGMP snooping
Layer 2 multicast forwarding cannot function
Multicast group policy does not work
About IGMP snooping
IGMP snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. It creates Layer 2 multicast forwarding entries from IGMP packets that are exchanged between the hosts and the Layer 3 device.
Fundamentals of IGMP snooping
As shown in Figure 1, when IGMP snooping is not enabled, the Layer 2 switch floods multicast packets to all hosts in a VLAN or VSI. When IGMP snooping is enabled, the Layer 2 switch forwards multicast packets of known multicast groups to only the receivers.
Figure 1 Multicast packet transmission without and with IGMP snooping
IGMP snooping ports
As shown in Figure 2, IGMP snooping runs on Switch A and Switch B, and Host A and Host C are receivers in a multicast group. IGMP snooping ports are divided into member ports and router ports.
Router ports
On an IGMP snooping Layer 2 device, the ports toward Layer 3 multicast devices are called router ports. In Figure 2, Port A1 of Switch A and Port B1 of Switch B are router ports.
Router ports contain the following types:
· Dynamic router port—When a port receives an IGMP general query whose source address is not 0.0.0.0 or receives a PIM hello message, the port is added into the dynamic router port list. At the same time, an aging timer is started for the port. If the port receives either of the messages before the timer expires, the timer is reset. If the port does not receive either of the messages when the timer expires, the port is removed from the dynamic router port list.
· Static router port—When a port is statically configured as a router port, it is added into the static router port list. The static router port does not age out, and it can be deleted only manually.
Do not confuse the "router port" in IGMP snooping with the "routed interface" commonly known as the "Layer 3 interface." The router port in IGMP snooping is a Layer 2 interface.
Member ports
On an IGMP snooping Layer 2 device, the ports toward receiver hosts are called member ports. In Figure 2, Port A2 and Port A3 of Switch A and Port B2 of Switch B are member ports.
Member ports contain the following types:
· Dynamic member port—When a port receives an IGMP report, it is added to the associated dynamic IGMP snooping forwarding entry as an outgoing interface. At the same time, an aging timer is started for the port. If the port receives an IGMP report before the timer expires, the timer is reset. If the port does not receive an IGMP report when the timer expires, the port is removed from the associated dynamic forwarding entry.
· Static member port—When a port is statically configured as a member port, it is added to the associated static IGMP snooping forwarding entry as an outgoing interface. The static member port does not age out, and it can be deleted only manually.
Unless otherwise specified, router ports and member ports in this document include both static and dynamic router ports and member ports.
How IGMP snooping works
The ports in this section are dynamic ports. For information about how to configure and remove static ports, see "Configuring a static member port" and "Configuring a static router port."
IGMP messages types include general query, IGMP report, and leave message. An IGMP snooping-enabled Layer 2 device performs differently depending on the message types.
General query
The IGMP querier periodically sends IGMP general queries to all hosts and devices on the local subnet to check for the existence of multicast group members.
After receiving an IGMP general query, the Layer 2 device forwards the query to all ports in the VLAN or VSI except the receiving port. The Layer 2 device also performs one of the following actions:
· If the receiving port is a dynamic router port in the dynamic router port list, the Layer 2 device restarts the aging timer for the port.
· If the receiving port does not exist in the dynamic router port list, the Layer 2 device adds the port to the dynamic router port list. It also starts an aging timer for the port.
IGMP report
A host sends an IGMP report to the IGMP querier for the following purposes:
· Responds to queries if the host is a multicast group member.
· Applies for a multicast group membership.
After receiving an IGMP report from a host, the Layer 2 device forwards the report through all the router ports in the VLAN or VSI. It also resolves the address of the reported multicast group, and looks up the forwarding table for a matching entry as follows:
· If no match is found, the Layer 2 device creates a forwarding entry with the receiving port as an outgoing interface. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
· If a match is found but the matching forwarding entry does not contain the receiving port, the Layer 2 device adds the receiving port to the outgoing interface list. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
· If a match is found and the matching forwarding entry contains the receiving port, the Layer 2 device restarts the aging timer for the port.
NOTE: A Layer 2 device does not forward an IGMP report through a non-router port because of the host IGMP report suppression mechanism. If a non-router port has member host attached, the member hosts suppress their IGMP reports upon receiving IGMP reports forwarded by the non-router port. The Layer 2 device cannot know the existence of the member hosts attached to the non-router port. For more information about the IGMP report suppression mechanism, see "Configuring IGMP." |
Leave message
An IGMPv1 receiver host does not send any leave messages when it leaves a multicast group. The Layer 2 device cannot immediately update the status of the port that connects to the receiver host. The Layer 2 device does not remove the port from the outgoing interface list in the associated forwarding entry until the aging time for the group expires.
An IGMPv2 or IGMPv3 host sends an IGMP leave message when it leaves a multicast group.
When the Layer 2 device receives an IGMP leave message on a dynamic member port, the Layer 2 device first examines whether a forwarding entry matches the group address in the message.
· If no match is found, the Layer 2 device discards the IGMP leave message.
· If a match is found but the receiving port is not an outgoing interface in the forwarding entry, the Layer 2 device discards the IGMP leave message.
· If a match is found and the receiving port is not the only outgoing interface in the forwarding entry, the Layer 2 device performs the following actions:
¡ Discards the IGMP leave message.
¡ Sends an IGMP group-specific query to identify whether the group has active receivers attached to the receiving port.
¡ Sets the aging timer for the receiving port to twice the IGMP last member query interval.
· If a match is found and the receiving port is the only outgoing interface in the forwarding entry, the Layer 2 device performs the following actions:
¡ Forwards the IGMP leave message to all router ports in the VLAN or VSI.
After receiving the IGMP leave message on a port, the IGMP querier resolves the multicast group address in the message. Then, it sends an IGMP group-specific query to the multicast group through the receiving port.
After receiving the IGMP group-specific query, the Layer 2 device forwards the query through all router ports and member ports of the group in the VLAN or VSI. Then, it waits for the responding IGMP report from the directly connected hosts. For the dynamic member port that received the leave message, the Layer 2 device also performs one of the following actions:
· If the port receives an IGMP report before the aging timer expires, the Layer 2 device resets the aging timer.
· If the port does not receive an IGMP report when the aging timer expires, the Layer 2 device removes the port from the forwarding entry for the multicast group.
As shown in Figure 3, to reduce the number of IGMP report and leave messages received by the upstream device, you can enable IGMP snooping proxying on the edge device. With IGMP snooping proxying enabled, the edge device acts as a host for the upstream IGMP snooping querier to send IGMP report and leave messages to Device A. The host IGMP report suppression mechanism on the edge device does not take effect. For more information about the IGMP report suppression mechanism, see "Configuring IGMP."
Figure 3 IGMP snooping proxying
The IGMP snooping proxy device processes different IGMP messages as follows:
· General query.
After receiving an IGMP general query, the device forwards the query to all ports in the VLAN or VSI except the receiving port. The device also generates an IGMP report based on the local membership information and sends the report to all router ports.
· Group-specific query or group-and-source-specific query.
After receiving an IGMP group-specific query or group-and-source-specific query, the device forwards the query to all ports in the VLAN or VSI except the receiving port. If the forwarding entry has a member port, the device sends a report to all router ports in the VLAN or VSI.
· Report.
After receiving an IGMP report from a host, the device looks up the forwarding table for a matching entry as follows:
¡ If a match is found and the matching forwarding entry contains the receiving port, the device resets the aging timer for the port.
¡ If a match is found but the matching forwarding entry does not contain the receiving port, the device adds the receiving port to the outgoing interface list. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
¡ If no match is found, the device creates a forwarding entry with the receiving port as an outgoing interface. It also marks the receiving port as a dynamic member port and starts an aging timer for the port. Then it sends the report to all router ports.
· Leave message.
After receiving the IGMP leave message on a port, the device sends an IGMP group-specific query through the receiving port. The device sends the IGMP leave message to all router ports only when the last member port is removed from the forwarding entry.
Protocols and standards
RFC 4541, Considerations for Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping Switches
The IGMP snooping configurations made on Layer 2 aggregate interfaces do not interfere with the configurations made on member ports. In addition, the configurations made on Layer 2 aggregate interfaces do not take part in aggregation calculations. The configuration made on a member port of the aggregate group takes effect after the port leaves the aggregate group.
Some features can be configured for a VLAN in VLAN view or for multiple VLANs in IGMP-snooping view. The configuration made in VLAN view and the configuration made in IGMP-snooping view have the same priority, and the most recent configuration takes effect.
Some features can be configured for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. The VLAN-specific configuration takes priority over the global configuration.
Some features can be configured for a VSI in VSI view or globally for all VSIs in IGMP-snooping view. The VSI-specific configuration takes priority over the global configuration.
Some features can be configured for an interface in interface view or for all interfaces of the specified VLANs in IGMP-snooping view. The interface-specific configuration takes priority over the configuration made in IGMP-snooping view.
To configure IGMP snooping for VLANs, perform the following tasks:
1. Enabling the IGMP snooping feature
¡ Enabling IGMP snooping globally
¡ Enabling IGMP snooping for VLANs
3. (Optional.) Configuring basic IGMP snooping features
¡ Specifying an IGMP snooping version
¡ Setting the maximum number of IGMP snooping forwarding entries
¡ Configuring static multicast MAC address entries
¡ Setting the IGMP last member query interval
4. (Optional.) Configuring IGMP snooping port features
¡ Setting aging timers for dynamic ports
¡ Configuring a static member port
¡ Configuring a static router port
¡ Configuring a port as a simulated member host
¡ Enabling fast-leave processing
¡ Disabling a port from becoming a dynamic router port
¡ Preventing the device from forwarding multicast data to router ports in a VLAN
¡ Enabling inner VLAN ID-based forwarding
5. (Optional.) Specifying the Layer 2 multicast forwarding mode
6. (Optional.) Configuring the IGMP snooping querier
¡ Enabling the IGMP snooping querier
¡ Enabling IGMP snooping querier election
¡ Configuring parameters for IGMP general queries and responses
¡ Enabling the device to send IGMP general queries upon a path change
7. (Optional.) Enabling IGMP snooping proxying
8. (Optional.) Configuring parameters for IGMP messages
¡ Configuring source IP addresses for IGMP messages
¡ Setting the 802.1p priority for IGMP messages
9. (Optional.) Configuring IGMP snooping policies
¡ Configuring a multicast group policy
¡ Enabling multicast source port filtering
¡ Enabling dropping unknown multicast data
¡ Enabling IGMP report suppression
¡ Setting the maximum number of multicast groups on a port
¡ Enabling multicast group replacement
¡ Configuring an IGMP snooping access control policy
10. (Optional.) Setting the DSCP value for outgoing IGMP protocol packets
11. (Optional.) Configuring IGMP snooping to support DRNI
To configure IGMP snooping for VSIs, perform the following tasks:
¡ Enabling IGMP snooping for a VSI
¡ Configuring static multicast MAC address entries for VXLAN
4. (Optional.) Setting aging timers for dynamic ports
¡ Enabling the device to send IGMP general queries upon a port state change
You must enable the IGMP snooping feature before you configure other IGMP snooping features.
1. Enter system view.
2. Enable the IGMP snooping feature and enter IGMP-snooping view.
igmp-snooping
By default, the IGMP snooping feature is disabled.
After you enable IGMP snooping globally, IGMP snooping is enabled for all VLANs or VSIs. You can disable IGMP snooping for a VLAN or VSI when IGMP snooping is globally enabled.
To configure other IGMP snooping features for VLANs or VSIs, you must enable IGMP snooping for the specific VLANs or VSIs even though IGMP snooping is enabled globally.
The VLAN-specific or VSI-specific IGMP snooping configuration takes priority over the global IGMP snooping configuration. For example, if you enable IGMP snooping globally and then use the igmp-snooping disable command to disable IGMP snooping for a VLAN, IGMP snooping is disabled in the VLAN.
2. Enter IGMP-snooping view.
igmp-snooping
3. Enable IGMP snooping globally.
global-enable
By default, IGMP snooping is disabled globally.
4. (Optional.) Disable IGMP snooping for a VLAN or VSI.
a. Return to system view.
b. Enter VLAN or VSI view.
vlan vlan-id
vsi vsi-name
c. Disable IGMP snooping for the VLAN or VSI.
By default, the IGMP snooping status in a VLAN or VSI is consistent with the global IGMP snooping status.
You can enable IGMP snooping for multiple VLANs by using the enable vlan command in IGMP-snooping view or for a VLAN by using the igmp-snooping enable command in VLAN view. The configuration in VLAN view has the same priority as the configuration in IGMP-snooping view.
IGMP snooping configuration in a VLAN takes effect only on the member ports in the VLAN.
Enabling IGMP snooping for multiple VLANs
igmp-snooping
3. Enable IGMP snooping for the specified VLANs.
enable vlan vlan-list
By default, the IGMP snooping status in a VLAN is consistent with the global IGMP snooping status.
Enabling IGMP snooping for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Enable IGMP snooping for the VLAN.
For VSIs, you can only enable IGMP snooping for a VSI by using the igmp-snooping enable command in VSI view.
IGMP snooping configuration in a VSI takes effect only on the member ports in the VSI.
On an EVPN distributed relay network, you must enable both IGMP snooping and IGMP snooping proxying for VSIs. For more information about EVPN distributed relay, see EVPN VXLAN configuration in EVPN Configuration Guide.
2. Enter VSI view.
vsi vsi-name
3. Enable IGMP snooping for the VSI.
By default, the IGMP snooping status in a VSI is consistent with the global IGMP snooping status.
Different IGMP snooping versions process different versions of IGMP messages.
· IGMPv2 snooping processes IGMPv1 messages, IGMPv2 messages, and IGMPv3 queries, but it floods IGMPv3 reports in the VLAN or VSI instead of processing them.
· IGMPv3 snooping processes IGMPv1, IGMPv2, and IGMPv3 messages.
If you change the IGMP snooping version from 2 to 3, the device performs the following actions:
· Clears all IGMP snooping forwarding entries that are dynamically created.
· Keeps static IGMPv3 snooping forwarding entries (*, G).
· Clears static IGMPv3 snooping forwarding entries (S, G), which will be restored when the IGMP snooping version is switched back to 3.
For more information about static IGMP snooping forwarding entries, see "Configuring a static member port."
Specifying an IGMP snooping version for multiple VLANs
igmp-snooping
3. Specify an IGMP snooping version for multiple VLANs.
By default, the IGMP snooping version for a VLAN is 2.
Specifying an IGMP snooping version for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Specify an IGMP snooping version for the VLAN.
igmp-snooping version version-number
Specifying an IGMP snooping version for a VSI
2. Enter VSI view.
vsi vsi-name
3. Specify an IGMP snooping version for the VSI.
By default, the IGMP snooping version for a VSI is 2.
You can modify the maximum number of IGMP snooping forwarding entries, including dynamic entries and static entries. When the number of forwarding entries on the device reaches the upper limit, the device does not automatically remove any existing entries. To allow new entries to be created, remove some entries manually.
igmp-snooping
3. Set the maximum number of IGMP snooping forwarding entries.
entry-limit limit
By default, the maximum number of IGMP snooping forwarding entries is 4294967295.
In Layer 2 multicast, multicast MAC address entries can be dynamically created through Layer 2 multicast protocols (such as IGMP snooping). You can also manually configure static multicast MAC address entries by binding multicast MAC addresses and ports to control the destination ports of the multicast data.
You must specify an unused multicast MAC address when configuring a static multicast MAC address entry. A multicast MAC address is the MAC address in which the least significant bit of the most significant octet is 1.
Configuring a static multicast MAC address entry in system view
2. Configure a static multicast MAC address entry.
Configuring a static multicast MAC address entry in interface view
2. Enter Layer 2 interface view.
3. Configure a static multicast MAC address entry.
Use this feature to configure local and remote static multicast MAC address entries for a VXLAN network. For more information about VXLAN, see VXLAN Configuration Guide.
Do not specify the tunnel interfaces automatically created by using ENDP or EVPN as outgoing interfaces for a remote static multicast MAC address entry. If you do so, the numbers of these tunnel interfaces might change during tunnel re-establishment, and the related entries cannot be restored as a result. For more information about ENDP, see VXLAN Configuration Guide. For more information about EVPN, see EVPN Configuration Guide.
In an EVPN network, you cannot configure the same multicast MAC address entry on multiple leaf nodes or VTEPs. When configured with EVPN multihoming or EVPN distributed relay, a VTEP does not support synchronization of multicast MAC address entries.
2. Configure local static multicast MAC address entries.
mac-address multicast mac-address { interface { interface-type interface-number service-instance instance-id }&<1-4> } vsi vsi-name
By default, no local static multicast MAC address entries exist.
For successful configuration, make sure the specified Ethernet service instances have been mapped to the specified VSI.
3. Configure remote static multicast MAC address entries.
mac-address multicast mac-address { interface { tunnel tunnel-number1 [ to tunnel tunnel-number2 ] }&<1-4> } vsi vsi-name
By default, no remote static multicast MAC address entries exist.
For successful configuration, make sure the specified VXLAN tunnel interfaces have been associated with the specified VSI.
A receiver host starts a report delay timer for a multicast group when it receives an IGMP group-specific query for the group. This timer is set to a random value in the range of 0 to the maximum response time advertised in the query. When the timer value decreases to 0, the host sends an IGMP report to the group.
The IGMP last member query interval defines the maximum response time advertised in IGMP group-specific queries. Set an appropriate value for the IGMP last member query interval to speed up hosts' responses to IGMP group-specific queries and avoid IGMP report traffic bursts.
Setting the IGMP last member query interval globally
igmp-snooping
3. Set the IGMP last member query interval globally.
last-member-query-interval interval
By default, the global IGMP last member query interval is 1 second.
Setting the IGMP last member query interval for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Set the IGMP last member query interval for the VLAN.
igmp-snooping last-member-query-interval interval
By default, the IGMP last member query interval is 1 second for a VLAN.
Setting the IGMP last member query interval for a VSI
2. Enter VSI view.
vsi vsi-name
3. Set the IGMP last member query interval for the VSI.
By default, the IGMP last member query interval is 1 second for a VSI.
A dynamic router port is removed from the dynamic router port list if it does not receive an IGMP general query or PIM hello message when its aging timer expires.
A dynamic member port is removed from the dynamic member port if it does not receive an IGMP report when its aging timer expires.
Set an appropriate value for the aging timers of dynamic ports. For example, if the memberships of multicast groups frequently change, set a relatively small value for the aging timer of the dynamic member ports. If the memberships of multicast groups rarely change, set a relatively large value.
If a dynamic router port receives a PIMv2 hello message, the aging timer for the port is specified by the hello message. In this case, the router-aging-time or igmp-snooping router-aging-time command does not take effect on the port.
IGMP group-specific queries originated by the Layer 2 device trigger the adjustment of aging timers for dynamic member ports. If a dynamic member port receives such a query, its aging timer is set to twice the IGMP last member query interval. For more information about setting the IGMP last member query interval on the Layer 2 device, see "Setting the IGMP last member query interval."
Setting the aging timers for dynamic ports globally
igmp-snooping
3. Set the aging timer for dynamic router ports globally.
router-aging-time seconds
By default, the aging timer for dynamic router ports is 260 seconds.
4. Set the global aging timer for dynamic member ports globally.
host-aging-time seconds
By default, the aging timer for dynamic member ports is 260 seconds.
Setting the aging timers for dynamic ports in a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Set the aging timer for dynamic router ports in the VLAN.
igmp-snooping router-aging-time seconds
4. Set the aging timer for dynamic member ports in the VLAN.
igmp-snooping host-aging-time seconds
Setting the aging timers for dynamic ports in a VSI
2. Enter VSI view.
vsi vsi-name
3. Set the aging timer for dynamic router ports in the VSI.
4. Set the aging timer for dynamic member ports in the VSI.
You can configure a port as a static member port for a multicast group so that hosts attached to the port can always receive multicast for the group. The static member port does not respond to IGMP queries. When you complete or cancel this configuration on a port, the port does not send an unsolicited IGMP report or leave message.
On an EVPN distributed relay network, execution of the undo igmp-snooping static-group or reset igmp-snooping group command takes effect only on the local VTEP in the DR system. It does not take effect on the peer VTEP in the DR system.
¡ Enter Layer 2 RPR logical interface view.
interface rpr-bridge interface-number
3. Configure the port as a static member port.
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
By default, a port is not a static member port.
You can configure a port as a static router port for a multicast group so that all multicast data for the group received on the port will be forwarded.
3. Configure the port as a static router port.
igmp-snooping static-router-port vlan vlan-id
By default, a port is not a static router port.
When a port is configured as a simulated member host, it is equivalent to an independent host in the following ways:
· It sends an unsolicited IGMP report when you complete the configuration.
· It responds to IGMP general queries with IGMP reports.
· It sends an IGMP leave message when you cancel the configuration.
The version of IGMP running on the simulated member host is the same as the version of IGMP snooping running on the port. The port ages out in the same way as a dynamic member port.
3. Configure the port as a simulated member host.
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
By default, the port is not a simulated member host.
This feature enables the Layer 2 device to immediately remove a port from the forwarding entry for a multicast group when the port receives a leave massage. The Layer 2 device no longer sends or forwards IGMP group-specific queries for the group to the port.
Do not enable fast-leave processing on a port that has multiple receiver hosts in a VLAN. If you do so, the remaining receivers cannot receive multicast data for a group after a receiver leaves the group.
Enabling fast-leave processing globally
igmp-snooping
3. Enable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
By default, fast-leave processing is disabled globally.
Enabling fast-leave processing on a port
3. Enable fast-leave processing on the port.
igmp-snooping fast-leave [ vlan vlan-list ]
By default, fast-leave processing is disabled on a port.
A receiver host might send IGMP general queries or PIM hello messages for testing purposes. On the Layer 2 device, the port that receives either of the messages becomes a dynamic router port. Before the aging timer for the port expires, the following problems might occur:
· All multicast data for the VLAN to which the port belongs flows to the port. Then, the port forwards the data to attached receiver hosts. The receiver hosts will receive multicast data that it does not want to receive.
· The port forwards the IGMP general queries or PIM hello messages to its upstream Layer 3 devices. These messages might affect the multicast routing protocol state (such as the IGMP querier or DR election) on the Layer 3 devices. This might further cause network interruption.
To solve these problems, you can disable a port from becoming a dynamic router port. This also improves network security and the control over receiver hosts.
This configuration and the static router port configuration do not interfere with each other.
3. Disable the port from becoming a dynamic router port.
igmp-snooping router-port-deny [ vlan vlan-list ]
By default, a port is allowed to become a dynamic router port.
If all ports on an IGMP snooping Layer 2 device are statically configured as router ports, the Layer 2 device will forwards multicast data from Layer 3 multicast devices to all its router ports. This wastes bandwidth resources. Perform this task to not forward multicast data to router ports in a VLAN if they are not interested in receiving the data.
Before performing this task, you must enable IGMP snooping in the VLAN.
2. Enter VLAN view.
vlan vlan-id
3. Prevent the device from forwarding multicast data to static router ports in the VLAN.
igmp-snooping router-port-discard
By default, the device forwards multicast data to static router ports in a VLAN.
Use this feature to enable a port to create and maintain IGMP snooping entries based on the inner VLAN IDs of the received double-tagged IGMP packets.
3. Enable inner VLAN ID-based forwarding.
igmp-snooping cvid-forward
By default, inner VLAN ID-based forwarding is disabled on a port. The port performs outer VLAN ID-based forwarding.
The device supports the following Layer 2 multicast forwarding modes:
· MAC-based mode—The device forwards Layer 2 multicast packets based on the multicast MAC addresses in the packets.
· IP-based mode—The device forwards Layer 2 multicast packets based on the IP addresses (multicast source addresses and multicast group addresses) in the packets.
To display Layer 2 multicast IP forwarding entries, use the display l2-multicast ip forwarding command.
To display Layer 2 multicast MAC forwarding entries, use the display l2-multicast mac forwarding command.
Multiple multicast IP addresses might be mapped to the same multicast MAC address. This causes that non-members of a multicast group receive the multicast data of this group if the device uses the MAC-based forwarding mode. As a best practice, specify the IP-based Layer 2 multicast forwarding mode on Layer 3 multicast devices.
In a TRILL network, specify the MAC-based Layer 2 multicast forwarding mode on devices.
As a best practice, specify the IP-based Layer 2 multicast forwarding mode on the device if a device running IGMPv3 exists in the network.
2. Enter VLAN view.
vlan vlan-id
3. Specify the Layer 2 multicast forwarding mode.
igmp-snooping forwarding-mode { ip | mac }
The default Layer 2 multicast forwarding mode depends on the device model.
2. Enter VSI view.
vsi vsi-name
This feature enables the Layer 2 device to periodically send IGMP general queries to establish and maintain multicast forwarding entries at the data link Layer. You can configure an IGMP snooping querier on a network without Layer 3 multicast devices.
Do not enable the IGMP snooping querier on a multicast network that runs IGMP. An IGMP snooping querier does not take part in IGMP querier elections. However, it might affect IGMP querier elections if it sends IGMP general queries with a low source IP address. For more information about IGMP querier, see "Configuring IGMP."
On a TRILL network, if an RB acts as both the IGMP snooping querier and the AVF of a VLAN, configure the appointed port as a static router port. This configuration ensures that IGMP snooping forwarding entries can be created. For more information about TRILL, RBs, AVFs, and appointed ports, see TRILL Configuration Guide.
On a VXLAN network, the IGMP snooping querier in a VSI does not include VLAN tags in IGMP general queries. As a best practice, do not enable the IGMP snooping querier in a VSI if the VSI uses the Ethernet access mode. For more information about the Ethernet access mode, see VXLAN Configuration Guide.
Enabling the IGMP snooping querier for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Enable the IGMP snooping querier for the VLAN.
igmp-snooping querier
By default, the IGMP snooping querier is disabled for a VLAN.
Enabling the IGMP snooping querier for a VSI
2. Enter VSI view.
vsi vsi-name
3. Enable the IGMP snooping querier for the VSI.
By default, the IGMP snooping querier is disabled for a VSI.
To avoid traffic interruption caused by the failure of a single querier in a VLAN or VSI, configure multiple queriers in the VLAN or VSI and enable querier election. When the elected querier fails, the device starts a new querier election to ensure multicast forwarding. The mechanism for IGMP snooping querier election is the same as that for IGMP querier election. For more information about IGMP querier election, see "Configuring IGMP."
Prerequisites for enabling IGMP snooping querier election
Before you enable IGMP snooping querier election, you must complete the following tasks:
· Enable the IGMP snooping querier for a VLAN or VSI. For more information about enabling the IGMP snooping querier, see "Enabling the IGMP snooping querier."
· Configure the source IP address for IGMP general queries as an IP address different from 0.0.0.0 and the local querier IP address. An IGMP snooping querier performs querier election only if the source IP address of a received IGMP general query is not 0.0.0.0 or its own IP address.
· Make sure the candidate IGMP snooping queriers run the same IGMP snooping version. To specify the IGMP snooping version, use the igmp-snooping version command.
Enabling IGMP snooping querier election for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Enable IGMP snooping querier election for the VLAN.
igmp-snooping querier-election
By default, IGMP snooping querier election is disabled for a VLAN.
Enabling IGMP snooping querier election for a VSI
2. Enter VSI view.
vsi vsi-name
3. Enable IGMP snooping querier election for the VSI.
By default, IGMP snooping querier election is disabled for a VSI.
You can modify the IGMP general query interval based on the actual condition of the network.
A receiver host starts a report delay timer for each multicast group that it has joined when it receives an IGMP general query. This timer is set to a random value in the range of 0 to the maximum response time advertised in the query. When the timer value decreases to 0, the host sends an IGMP report to the corresponding multicast group.
Set an appropriate value for the maximum response time for IGMP general queries to speed up hosts' responses to IGMP general queries and avoid IGMP report traffic bursts.
To avoid mistakenly deleting multicast group members, make sure the IGMP general query interval is greater than the maximum response time for IGMP general queries.
Configuring parameters for IGMP general queries and responses globally
igmp-snooping
3. Set the maximum response time for IGMP general queries.
max-response-time seconds
By default, the maximum response time for IGMP general queries is 10 seconds.
Configuring parameters for IGMP general queries and responses in a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Set the IGMP general query interval in the VLAN.
igmp-snooping query-interval interval
By default, the IGMP general query interval is 125 seconds for a VLAN.
4. Set the maximum response time for IGMP general queries in the VLAN.
igmp-snooping max-response-time seconds
By default, the maximum response time for IGMP general queries is 10 seconds for a VLAN.
Configuring parameters for IGMP general queries and responses in a VSI
2. Enter VSI view.
vsi vsi-name
3. Set the IGMP general query interval in the VSI.
By default, the IGMP general query interval is 125 seconds for a VSI.
4. Set the maximum response time for IGMP general queries in the VSI.
By default, the maximum response time for IGMP general queries is 10 seconds for a VSI.
Perform this task to enable the device to immediately send an IGMP general query to all ports in the affected VLAN or VSI when a path changes. This feature ensures that the device can update the member port information in multicast forwarding entries and switch multicast traffic to the new path promptly.
Perform this task on the IGMP snooping querier in a network of which the topology frequently changes.
igmp-snooping
3. Enable the device to send IGMP general queries upon a path change.
send-query enable
By default, the device does not send IGMP general queries upon a path change.
As shown in Figure 4, the receiver side's devices connect to the Layer 2 multicast device through a Reth interface for high availability. Interface A and interface B are member interfaces of the Reth interface, and interface A is active. Multicast data is sent to the receivers through Device A. When interface A fails, Device C does not send an IGMP general query immediately and cannot update interface B to multicast forwarding entries. For information about Reth interfaces, see High Availability Configuration Guide.
Perform this task to enable the device to immediately send an IGMP general query to all ports in the affected VLAN when the state of a port changes. This feature ensures that the device can update the member port information in multicast forwarding entries and switch multicast traffic to the new link promptly.
2. Enter VLAN view.
vlan vlan-id
3. Enable the device to send IGMP general queries upon a port state change.
igmp-snooping triggered-query enable { port-down | port-up } *
By default, the device does not send IGMP general queries upon a port state change.
The device enabled with IGMP snooping proxying is called an IGMP snooping proxy. The IGMP snooping proxy acts as a host to the upstream device. Enabled with IGMP snooping querier, the IGMP snooping proxy acts as the router to downstream devices and receives report and leave messages on behalf of the upstream device. As a best practice, enable IGMP snooping proxy on the edge device to alleviate the effect caused by excessive packets.
Before you enable IGMP snooping proxying for a VLAN or VSI, you must first enable IGMP snooping globally and enable IGMP snooping for the VLAN or VSI. IGMP snooping proxying does not take effect on sub VLANs of a multicast VLAN.
Use this feature with IGMP snooping querier. For more information about enabling IGMP snooping querier, see "Enabling the IGMP snooping querier."
2. Enter VLAN view.
vlan vlan-id
3. Enable IGMP snooping proxying for the VLAN.
igmp-snooping proxy enable
By default, IGMP snooping proxying is disabled for a VLAN.
2. Enter VSI view.
vsi vsi-name
3. Enable IGMP snooping proxying for the VSI.
By default, IGMP snooping proxying is disabled for a VSI.
The IGMP snooping querier might send IGMP general queries with the source IP address 0.0.0.0. The port that receives such queries will not be maintained as a dynamic router port. This might prevent the associated dynamic IGMP snooping forwarding entry from being correctly created at the data link layer and eventually cause multicast traffic forwarding failures. To avoid this problem, you can configure a non-all-zero IP address as the source IP address of the IGMP queries on the IGMP snooping querier. This configuration might affect the IGMP querier election within the subnet.
You can also change the source IP address of IGMP reports or leave messages sent by a simulated member host or an IGMP snooping proxy.
Configuring the source IP addresses for IGMP messages in a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Configure the source IP address for IGMP general queries.
igmp-snooping general-query source-ip ip-address
By default, the source IP address of IGMP general queries is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
4. Configure the source IP address for IGMP group-specific queries.
igmp-snooping special-query source-ip ip-address
By default, the source IP address of IGMP group-specific queries is one of the following:
¡ The source address of IGMP group-specific queries if the IGMP snooping querier of the VLAN has received IGMP general queries.
¡ The IP address of the current VLAN interface if the IGMP snooping querier does not receive an IGMP general query.
¡ 0.0.0.0 if the IGMP snooping querier does not receive an IGMP general query and the current VLAN interface does not have an IP address.
5. Configure the source IP address for IGMP reports.
igmp-snooping report source-ip ip-address
By default, the source IP address of IGMP reports is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
6. Configure the source IP address for IGMP leave messages.
igmp-snooping leave source-ip ip-address
By default, the source IP address of IGMP leave messages is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
Configuring the source IP addresses for IGMP messages in a VSI
2. Enter VSI view.
vsi vsi-name
By default, the source IP address of IGMP general queries is the IP address of the gateway interface for a VSI. If the gateway interface does not have an IP address, the source IP address is 0.0.0.0.
¡ The source IP address of IGMP general queries if the IGMP snooping querier of a VSI has received IGMP general queries.
¡ The IP address of the gateway interface for the VSI if the IGMP snooping querier does not receive an IGMP general query.
¡ 0.0.0.0 if the gateway interface of the VSI does not have an IP address.
By default, the source IP address of IGMP reports is the IP address of the gateway interface for a VSI. If the gateway interface does not have an IP address, the source IP address is 0.0.0.0.
By default, the source IP address of IGMP leave messages is the IP address of the gateway interface for a VSI. If the gateway interface does not have an IP address, the source IP address is 0.0.0.0.
When congestion occurs on outgoing ports of the Layer 2 device, it forwards IGMP messages in their 802.1p priority order, from highest to lowest. You can assign a higher 802.1p priority to IGMP messages that are created or forwarded by the device.
The configuration in IGMP-snooping view takes effect only for all VLANs. For VSIs, you can set the 802.1p priority for IGMP messages only in VSI view.
Setting the 802.1p priority for IGMP messages globally
igmp-snooping
3. Set the 802.1p priority for IGMP messages.
dot1p-priority priority
By default, the global 802.1p priority is 6 for IGMP messages.
Setting the 802.1p priority for IGMP messages in a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Set the 802.1p priority for IGMP messages in the VLAN.
igmp-snooping dot1p-priority priority
By default, the 802.1p priority is 6 for IGMP messages in a VLAN.
This feature enables the Layer 2 device to filter IGMP reports by using an ACL that specifies the multicast groups and the optional sources. It is used to control the multicast groups that hosts can join. This configuration takes effect only on the multicast groups that ports join dynamically.
In a multicast application, a host sends an unsolicited IGMP report when a user requests a multicast program. The Layer 2 device uses the multicast group policy to filter the IGMP report. The host can join the multicast group only if the IGMP report is permitted by the multicast group policy.
Configuring a multicast group policy globally
igmp-snooping
3. Configure a multicast group policy globally.
group-policy ipv4-acl-number [ vlan vlan-list ]
By default, no multicast group policies are configured, and hosts can join any multicast groups.
Configuring a multicast group policy on a port
3. Configure a multicast group policy on the port.
igmp-snooping group-policy ipv4-acl-number [ vlan vlan-list ]
By default, no multicast group policies are configured on a port, and hosts attached to the port can join any multicast groups.
This feature enables the Layer 2 device to discard all multicast data packets and to accept multicast protocol packets. You can enable this feature on ports that connect only to multicast receivers.
When IPv4 multicast source port filtering is enabled, the system automatically enables IPv6 multicast source port filtering.
The configuration made for multiple interfaces in IGMP-snooping view has the same priority as the interface-specific configuration, and the most recent configuration takes effect.
Enabling multicast source port filtering in IGMP-snooping view
igmp-snooping
3. Enable multicast source port filtering.
By default, multicast source port filtering is disabled.
Enabling multicast source port filtering in interface view
2. Enter Layer 2 Ethernet interface view.
igmp-snooping source-deny
Unknown multicast data refers to multicast data for which no forwarding entries exist in the IGMP snooping forwarding table. This feature enables the device to forward unknown multicast data only to the router port. If the device does not have a router port, unknown multicast data will be dropped.
If you do not enable this feature, the unknown multicast data is flooded in the VLAN or VSI to which the data belongs.
The drop-unknown command in IGMP-snooping view and the igmp-snooping drop-unknown command in VLAN view or VSI view are mutually exclusive. You cannot configure them on the same device.
When dropping unknown IPv4 multicast data is enabled, the device also drops unknown IPv6 multicast data.
When this feature is enabled for a VLAN or VSI, the device still forwards unknown multicast data out of router ports except the receiving router port in this VLAN or VSI.
Enabling dropping unknown multicast data globally
igmp-snooping
3. Enable dropping unknown multicast data globally.
drop-unknown
By default, dropping unknown multicast data is disabled globally. Unknown multicast data is flooded.
Enabling dropping unknown multicast data for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Enable dropping unknown multicast data for the VLAN.
By default, dropping unknown multicast data is disabled for a VLAN. Unknown multicast data is flooded in the VLAN.
Enabling dropping unknown multicast data for a VSI
2. Enter VSI view.
vsi vsi-name
3. Enable dropping unknown multicast data for the VSI.
By default, dropping unknown multicast data is disabled for a VSI. Unknown multicast data is flooded in the VSI.
This feature enables the Layer 2 device to forward only the first IGMP report for a multicast group to its directly connected Layer 3 device. Other reports for the same group in the same query interval are discarded. Use this feature to reduce multicast traffic.
igmp-snooping
3. Enable IGMP report suppression.
report-aggregation
By default, IGMP report suppression is enabled.
You can set the maximum number of multicast groups on a port to regulate the port traffic. This feature takes effect only on the multicast groups that a port joins dynamically.
If the number of multicast groups on a port exceeds the limit, the system removes all the forwarding entries associated with the port. The receiver hosts attached to that port can join multicast groups again before the number of multicast groups on the port reaches the limit. When the number of multicast groups on the port reaches the limit, the port automatically drops IGMP reports for new groups.
3. Set the maximum number of multicast groups on the port.
igmp-snooping group-limit limit [ vlan vlan-list ]
By default, no limit is placed on the maximum number of multicast groups on a port.
When multicast group replacement is enabled, the port does not drop IGMP reports for new groups if the number of multicast groups on the port reaches the upper limit. Instead, the port leaves the multicast group that has the lowest IP address and joins the new group contained in the IGMP report. The multicast group replacement feature is typically used in the channel switching application.
This feature does not take effect if the following conditions exist:
· The number of the IGMP snooping forwarding entries on the device reaches the upper limit.
· The multicast group that the port newly joins is not included in the multicast group list maintained by the device.
Enabling multicast group replacement globally
igmp-snooping
3. Enable multicast group replacement globally.
By default, multicast group replacement is disabled globally.
Enabling multicast group replacement on a port
3. Enable multicast group replacement on the port.
igmp-snooping overflow-replace [ vlan vlan-list ]
By default, multicast group replacement is disabled on a port.
Enabling host tracking
This feature enables the Layer 2 device to record information about member hosts that are receiving multicast data. The information includes IP addresses of the hosts, length of time elapsed since the hosts joined multicast groups, and remaining timeout time for the hosts. This feature facilitates monitoring and managing member hosts.
The global configuration does not take effect on VSIs.
Enabling host tracking globally
igmp-snooping
3. Enable host tracking globally.
host-tracking
By default, host tracking is disabled globally.
Enabling host tracking for a VLAN
2. Enter VLAN view.
vlan vlan-id
3. Enable host tracking for the VLAN.
igmp-snooping host-tracking
By default, host tracking is disabled for a VLAN.
This feature enables the device to use ACLs to filter IGMP reports and leave messages from multicast users. Multicast users can join or leave only multicast groups permitted by the IGMP snooping access control policies.
2. Enter user profile view.
user-profile profile-name
For more information about this command, see user profile commands in Security Command Reference.
3. Configure an IGMP snooping access control policy.
igmp-snooping access-policy ipv4-acl-number
By default, no IGMP snooping access control policies are configured. Multicast users can join or leave any multicast groups.
The DSCP value determines the packet transmission priority. A greater DSCP value represents a higher priority.
2. Enter IGMP snooping view.
igmp-snooping
3. Set the DSCP value for outgoing IGMP protocol packets.
dscp dscp-value
By default, the DSCP value is 48 for outgoing IGMP protocol packets.
VSI-based IGMP snooping supports DRNI only on an EVPN VXLAN network. You must enable IGMP snooping proxying at the same time.
PIM snooping does not support DRNI. For information about PIM snooping, see "Configuring PIM snooping."
1. Configure DRNI.
For more information, see DRNI configuration in Layer 2—LAN Switching Configuration Guide.
2. Configure IGMP snooping.
Command |
Display IGMP snooping status. |
display igmp-snooping [ global | vlan vlan-id | vsi vsi-name ] |
Display dynamic IGMP snooping group entries. |
Centralized devices: display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | verbose ] Distributed devices in standalone mode:Centralized IRF devices: display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ slot slot-number [ cpu cpu-number ] ] ] Distributed devices in IRF mode: display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id | vsi vsi-name ] [ interface interface-type interface-number | [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] ] |
Display host tracking information. |
Centralized devices: display igmp-snooping host-tracking vlan vlan-id group group-address [ source source-address ] Distributed devices in standalone mode:Centralized IRF devices: display igmp-snooping host-tracking vlan vlan-id group group-address [ source source-address ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display igmp-snooping host-tracking vlan vlan-id group group-address [ source source-address ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display dynamic router port information. |
Centralized devices: display igmp-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] Distributed devices in standalone mode:Centralized IRF devices: display igmp-snooping router-port [ vlan vlan-id | vsi vsi-name ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display igmp-snooping router-port [ vlan vlan-id | vsi vsi-name] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display static IGMP snooping group entries. |
Centralized devices: display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] Distributed devices in standalone mode:Centralized IRF devices: display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display static router port information. |
Centralized devices: display igmp-snooping static-router-port [ vlan vlan-id ] Distributed devices in standalone mode:Centralized IRF devices: display igmp-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display igmp-snooping static-router-port [ vlan vlan-id ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display statistics for the IGMP messages and PIMv2 hello messages learned by IGMP snooping. |
display igmp-snooping statistics |
Display Layer 2 multicast fast forwarding entries. |
Centralized devices: display l2-multicast fast-forwarding cache [ vlan vlan-id ] [ source-address | group-address ] * Distributed devices in standalone mode:Centralized IRF devices: display l2-multicast fast-forwarding cache [ vlan vlan-id ] [ source-address | group-address ] * [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display l2-multicast fast-forwarding cache [ vlan vlan-id ] [ source-address | group-address ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display information about Layer 2 IP multicast groups. |
Centralized devices: display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] Distributed devices in standalone mode:Centralized IRF devices: display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display Layer 2 IP multicast group entries. |
Centralized devices: display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] Distributed devices in standalone mode:Centralized IRF devices: display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display information about Layer 2 MAC multicast groups. |
Centralized devices: display l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] Distributed devices in standalone mode:Centralized IRF devices: display l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display l2-multicast mac [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display Layer 2 MAC multicast group entries. |
Centralized devices: display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] Distributed devices in standalone mode:Centralized IRF devices: display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id | vsi vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Display static multicast MAC address entries. |
display mac-address [ mac-address [ vlan vlan-id ] | [ multicast ] [ vlan vlan-id ] [ count ] ] |
Display multicast group information that IGMP snooping learns from EVPN. |
Centralized devices: display igmp-snooping evpn-group [ group-address | source-address ] * [vsi vsi-name ] Distributed devices in standalone mode:Centralized IRF devices: display igmp-snooping evpn-group [ group-address | source-address ] * [vsi vsi-name ] [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: display igmp-snooping evpn-group [ group-address | source-address ] * [vsi vsi-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Clear dynamic IGMP snooping group entries. |
reset igmp-snooping group { group-address [ source-address ] | all } [ vlan vlan-id | vsi vsi-name ] |
Clear dynamic router port information. |
reset igmp-snooping router-port { all | vlan vlan-id | vsi vsi-name } |
Clear statistics for IGMP messages and PIMv2 hello messages learned through IGMP snooping. |
reset igmp-snooping statistics |
Clear Layer 2 multicast fast forwarding entries. |
Centralized devices: reset l2-multicast fast-forwarding cache [ vlan vlan-id ] { { source-address | group-address } * | all } Distributed devices in standalone mode:Centralized IRF devices: reset l2-multicast fast-forwarding cache [ vlan vlan-id ] { { source-address | group-address } * | all } [ slot slot-number [ cpu cpu-number ] ] Distributed devices in IRF mode: reset l2-multicast fast-forwarding cache [ vlan vlan-id ] { { source-address | group-address } * | all } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
As shown in Figure 5, Router A runs IGMPv2 and acts as the IGMP querier. Switch A runs IGMPv2 snooping.
Configure a multicast group policy and simulated joining to meet the following requirements:
· Host A and Host B receive only the multicast data addressed to multicast group 224.1.1.1. Multicast data can be forwarded through GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 of Switch A uninterruptedly, even though Host A and Host B fail to receive the multicast data.
· Switch A will drop unknown multicast data instead of flooding it in VLAN 100.
Assign an IP address and subnet mask to each interface, as shown in Figure 5.
1. Configure Router A:
# Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable IGMP on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] igmp enable
# Enable PIM-DM on GigabitEthernet 1/0/2.
[RouterA-GigabitEthernet1/0/2] pim dm
2. Configure Switch A:
# Enable the IGMP snooping feature.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/4
# Enable IGMP snooping, and enable dropping unknown multicast data for VLAN 100.
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] igmp-snooping drop-unknown
[SwitchA-vlan100] quit
# Configure a multicast group policy so that hosts in VLAN 100 can join only multicast group 224.1.1.1.
[SwitchA] acl basic 2001
[SwitchA-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[SwitchA-acl-ipv4-basic-2001] quit
[SwitchA-igmp-snooping] group-policy 2001 vlan 100
# Configure GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 as simulated member hosts of multicast group 224.1.1.1.
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] igmp-snooping host-join 224.1.1.1 vlan 100
[SwitchA-GigabitEthernet1/0/3] quit
[SwitchA] interface gigabitethernet 1/0/4
[SwitchA-GigabitEthernet1/0/4] igmp-snooping host-join 224.1.1.1 vlan 100
[SwitchA-GigabitEthernet1/0/4] quit
# Send IGMP reports from Host A and Host B to join multicast groups 224.1.1.1 and 224.2.2.2. (Details not shown.)
# Display dynamic IGMP snooping group entries for VLAN 100 on Switch A.
[SwitchA] display igmp-snooping group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
(0.0.0.0, 224.1.1.1)
Host ports (2 in total):
GE1/0/3 (00:03:23)
GE1/0/4 (00:04:10)
· Host A and Host B have joined multicast group 224.1.1.1 through the member ports GigabitEthernet 1/0/4 and GigabitEthernet 1/0/3 on Switch A, respectively.
· Host A and Host B have failed to join multicast group 224.2.2.2.
Example: Configuring VLAN-based IGMP snooping static ports
As shown in Figure 6:
· Router A runs IGMPv2 and acts as the IGMP querier. Switch A, Switch B, and Switch C run IGMPv2 snooping.
· Host A and host C are permanent receivers of multicast group 224.1.1.1.
Configure static ports to meet the following requirements:
· To enhance the reliability of multicast traffic transmission, configure GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 on Switch C as static member ports for multicast group 224.1.1.1.
· Suppose the STP runs on the network. To avoid data loops, the forwarding path from Switch A to Switch C is blocked. Multicast data flows to the receivers attached to Switch C only along the path of Switch A—Switch B—Switch C. When this path is blocked, a minimum of one IGMP query-response cycle must be completed before multicast data flows to the receivers along the path of Switch A—Switch C. In this case, the multicast delivery is interrupted during the process. For more information about the STP, see Layer 2—LAN Switching Configuration Guide.
Configure GigabitEthernet 1/0/3 on Switch A as a static router port. Then, multicast data can flow to the receivers nearly uninterruptedly along the path of Switch A—Switch C when the path of Switch A—Switch B—Switch C is blocked.
Assign an IP address and subnet mask to each interface, as shown in Figure 6.
[RouterA-mrib] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
# Enable IGMP snooping for VLAN 100.
# Configure GigabitEthernet 1/0/3 as a static router port.
[SwitchA-GigabitEthernet1/0/3] igmp-snooping static-router-port vlan 100
3. Configure Switch B:
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port gigabitethernet 1/0/1 gigabitethernet 1/0/2
[SwitchB-vlan100] igmp-snooping enable
[SwitchB-vlan100] quit
4. Configure Switch C:
[SwitchC] igmp-snooping
[SwitchC-igmp-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/5 to the VLAN.
[SwitchC] vlan 100
[SwitchC-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/5
[SwitchC-vlan100] igmp-snooping enable
[SwitchC-vlan100] quit
# Configure GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 as static member ports for multicast group 224.1.1.1.
[SwitchC] interface gigabitethernet 1/0/3
[SwitchC-GigabitEthernet1/0/3] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchC-GigabitEthernet1/0/3] quit
[SwitchC] interface gigabitethernet 1/0/5
[SwitchC-GigabitEthernet1/0/5] igmp-snooping static-group 224.1.1.1 vlan 100
[SwitchC-GigabitEthernet1/0/5] quit
# Display static router port information for VLAN 100 on Switch A.
[SwitchA] display igmp-snooping static-router-port vlan 100
VLAN 100:
Router ports (1 in total):
GE1/0/3
The output shows that GigabitEthernet 1/0/3 on Switch A has become a static router port.
# Display static IGMP snooping group entries for VLAN 100 on Switch C.
[SwitchC] display igmp-snooping static-group vlan 100
Total 1 entries.
GE1/0/3
GE1/0/5
The output shows that GigabitEthernet 1/0/3 and GigabitEthernet 1/0/5 on Switch C have become static member ports of multicast group 224.1.1.1.
Example: Configuring the VLAN-based IGMP snooping querier
As shown in Figure 7:
· The network is a Layer 2-only network.
· Source 1 and Source 2 send multicast data to multicast groups 224.1.1.1 and 225.1.1.1, respectively.
· Host A and Host C are receivers of multicast group 224.1.1.1, and Host B and Host D are receivers of multicast group 225.1.1.1.
· All host receivers run IGMPv2, and all switches run IGMPv2 snooping. Switch A (which is close to the multicast sources) acts as the IGMP snooping querier.
Configure the switches to meet the following requirements:
· To prevent the switches from flooding unknown data in the VLAN, enable all the switches to drop unknown multicast data.
· A switch does not mark a port that receives an IGMP query with source IP address 0.0.0.0 as a dynamic router port. This adversely affects the establishment of Layer 2 forwarding entries and multicast traffic forwarding. To avoid this, configure the source IP address of IGMP queries as a non-zero IP address.
1. Configure Switch A:
[SwitchA] vlan 100
# Configure Switch A as the IGMP snooping querier.
[SwitchA-vlan100] igmp-snooping querier
# In VLAN 100, specify 192.168.1.1 as the source IP address of IGMP general queries.
[SwitchA-vlan100] igmp-snooping general-query source-ip 192.168.1.1
# In VLAN 100, specify 192.168.1.1 as the source IP address of IGMP group-specific queries.
[SwitchA-vlan100] igmp-snooping special-query source-ip 192.168.1.1
2. Configure Switch B:
[SwitchB] vlan 100
[SwitchB-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[SwitchB-vlan100] igmp-snooping drop-unknown
3. Configure Switch C:
[SwitchC] vlan 100
[SwitchC-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[SwitchC-vlan100] igmp-snooping drop-unknown
4. Configure Switch D:
<SwitchD> system-view
[SwitchD] igmp-snooping
[SwitchD-igmp-snooping] quit
[SwitchD] vlan 100
[SwitchD-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[SwitchD-vlan100] igmp-snooping enable
[SwitchD-vlan100] igmp-snooping drop-unknown
[SwitchD-vlan100] quit
# Display statistics for IGMP messages and PIMv2 hello messages learned through IGMP snooping on Switch B.
[SwitchB] display igmp-snooping statistics
Received IGMP messages:
IGMP general queries: 19
DRNI: 19
IGMPv2 specific queries: 10
DRNI: 0
IGMPv3 specific queries: 0
DRNI: 0
IGMPv3 specific sg queries: 0
DRNI: 0
IGMPv1 reports: 0
DRNI: 0
IGMPv2 reports: 19
DRNI: 19
IGMPv3 reports: 0
DRNI: 0
IGMPv3 reports with right and wrong records: 0
DRNI: 0
IGMP leaves: 5
DRNI: 5
Error IGMP messages: 1
DRNI: 1
Sent IGMP messages:
IGMPv2 specific queries: 0
Received PIMv2 hello : 0
The output shows that all switches except Switch A can receive the IGMP general queries after Switch A acts as the IGMP snooping querier.
Example: Configuring VLAN-based IGMP snooping proxying
As shown in Figure 8, Router A runs IGMPv2 and acts as the IGMP querier. Switch A runs IGMPv2 snooping. Configure IGMP snooping proxying so that Switch A can perform the following actions:
· Forward IGMP report and leave messages to Router A.
· Respond to IGMP queries sent by Router A and forward the queries to downstream hosts.
Assign an IP address and subnet mask to each interface, as shown in Figure 8.
[RouterA-mrib] quit
# Enable IGMP and PIM-DM on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] pim dm
[SwitchA] vlan 100
# Enable IGMP snooping and IGMP snooping proxying for the VLAN.
[SwitchA-vlan100] igmp-snooping proxy enable
# Send IGMP reports from Host A and Host B to join multicast groups 224.1.1.1 and 224.1.1.1. (Details not shown.)
# Display brief information about IGMP snooping group entries on Switch A.
Total 1 entries.
GE1/0/3 (00:04:00)
GE1/0/4 (00:04:04)
The output shows that GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 are member ports of multicast group 224.1.1.1. Host A and Host B become receivers of the group.
# Display IGMP group membership information on Router A.
[RouterA] display igmp group
IGMP groups in total: 1
GigabitEthernet1/0/1(10.1.1.1):
IGMP groups reported in total: 1
Group address Last reporter Uptime Expires
224.1.1.1 0.0.0.0 00:00:31 00:02:03
# Send an IGMP leave message from Host A to leave multicast group 224.1.1.1. (Details not shown.)
Total 1 entries.
Host ports (1 in total):
GE1/0/3 ( 00:01:23 )
The output shows that GigabitEthernet 1/0/3 is the only member port of multicast group 224.1.1.1. Only Host B remains as the receiver of the group.
Example: Configuring IGMP snooping proxy for EVPN multihoming
As shown in Figure 9:
· Configure VXLAN 10 on Switch A, Switch B, and Switch C. Configure Switch A and Switch B as redundant VTEPs for Server 2, and configure Switch B and Switch C as redundant VTEPs for Server 3.
· Configure Switch A, Switch B, and Switch C as distributed EVPN gateways.
· Configure Switch D as an RR to reflect BGP EVPN routes between Switch A, Switch B, and Switch C.
· Enable multicast and IGMP snooping proxying on Switch A, Switch B, and Switch C.
1. On VM 1, VM 2, and VM 3, specify 10.1.1.1 as the gateway address. (Details not shown.)
2. Configure IP addresses and unicast routing settings:
# Assign an IP address and subnet mask to each interface. (Details not shown.)
# Configure OSPF on all transport network switches (Switches A through D) for them to reach one another. (Details not shown.)
3. Configure Switch A:
# Enable L2VPN.
[SwitchA ] l2vpn enable
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Create an EVPN instance on VSI vpna, and configure the switch to automatically generate an RD and a route target for the EVPN instance.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] evpn encapsulation vxlan
[SwitchA-vsi-vpna-evpn-vxlan] route-distinguisher auto router-id
[SwitchA-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchA-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchA-vsi-vpna] vxlan 10
[SwitchA-vsi-vpna] quit
# Configure BGP to advertise BGP EVPN routes.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 4.4.4.4 as-number 200
[SwitchA-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# On GigabitEthernet 1/0/1, create Ethernet service instance 1000 to match VLAN 2.
[SwitchA-GigabitEthernet1/0/1] service-instance 1000
[SwitchA-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
# Map Ethernet service instance 1000 to VSI vpna.
[SwitchA-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchA-GigabitEthernet1/0/1-srv1000] quit
# Assign an ESI to GigabitEthernet 1/0/2.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] esi 0.0.0.0.1
# On GigabitEthernet 1/0/2, create Ethernet service instance 2000 to match VLAN 2.
[SwitchA-GigabitEthernet1/0/2] service-instance 2000
[SwitchA-GigabitEthernet1/0/2-srv2000] encapsulation s-vid 2
# Map Ethernet service instance 2000 to VSI vpna.
[SwitchA-GigabitEthernet1/0/2-srv2000] xconnect vsi vpna
[SwitchA-GigabitEthernet1/0/2-srv2000] quit
# Configure RD and route target settings for VPN instance l3vpna.
[SwitchA] ip vpn-instance l3vpna
[SwitchA-vpn-instance-l3vpna] route-distinguisher 1:1
[SwitchA-vpn-instance-l3vpna] address-family ipv4
[SwitchA-vpn-ipv4-l3vpna] vpn-target 2:2
[SwitchA-vpn-ipv4-l3vpna] quit
[SwitchA-vpn-instance-l3vpna] address-family evpn
[SwitchA-vpn-evpn-l3vpna] vpn-target 1:1
[SwitchA-vpn-evpn-l3vpna] quit
[SwitchA-vpn-instance-l3vpna] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance l3vpna
[SwitchA-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 1-1-1
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] local-proxy-arp enable
[SwitchA-Vsi-interface1] quit
# Associate VSI-interface 3 with VPN instance l3vpna, and configure the L3 VXLAN ID as 1000 for the VPN instance.
[SwitchA] interface vsi-interface 3
[SwitchA-Vsi-interface3] ip binding vpn-instance l3vpna
[SwitchA-Vsi-interface3] l3-vni 1000
[SwitchA-Vsi-interface3] quit
# Specify VSI-interface 1 as the gateway interface for VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] gateway vsi-interface 1
# Enable IGMP snooping globally.
# Enable IGMP snooping, IGMP snooping proxying, and dropping unknown multicast data on VSI vpna.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna] igmp-snooping enable
[SwitchA-vsi-vpna] igmp-snooping proxy enable
[SwitchA-vsi-vpna] igmp-snooping drop-unknown
# Specify IP-based Layer 2 multicast forwarding mode, set the IGMP snooping version, and enable the IGMP snooping querier on VSI vpna.
[SwitchA-vsi-vpna] igmp-snooping forwarding-mode ip
[SwitchA-vsi-vpna] igmp-snooping version 3
[SwitchA-vsi-vpna] igmp-snooping querier
4. Configure Switch B:
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] evpn encapsulation vxlan
[SwitchB-vsi-vpna-evpn-vxlan] route-distinguisher auto router-id
[SwitchB-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchB-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchB-vsi-vpna] vxlan 10
[SwitchB-vsi-vpna] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 4.4.4.4 as-number 200
[SwitchB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
# Assign an ESI to GigabitEthernet 1/0/1.
[SwitchB-GigabitEthernet1/0/1] esi 0.0.0.0.1
# On GigabitEthernet 1/0/1, create Ethernet service instance 2000 to match VLAN 2.
[SwitchB-GigabitEthernet1/0/1] service-instance 2000
[SwitchB-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 2
[SwitchB-GigabitEthernet1/0/1-srv2000] xconnect vsi vpna
[SwitchB-GigabitEthernet1/0/1-srv2000] quit
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] esi 0.0.0.0.2
# On GigabitEthernet 1/0/2, create Ethernet service instance 3000 to match VLAN 2.
[SwitchB-GigabitEthernet1/0/2] service-instance 3000
[SwitchB-GigabitEthernet1/0/2-srv3000] encapsulation s-vid 2
# Map Ethernet service instance 3000 to VSI vpna.
[SwitchB-GigabitEthernet1/0/2-srv3000] xconnect vsi vpna
[SwitchB-GigabitEthernet1/0/2-srv3000] quit
[SwitchB] ip vpn-instance l3vpna
[SwitchB-vpn-instance-l3vpna] route-distinguisher 2:2
[SwitchB-vpn-instance-l3vpna] address-family ipv4
[SwitchB-vpn-ipv4-l3vpna] vpn-target 2:2
[SwitchB-vpn-ipv4-l3vpna] quit
[SwitchB-vpn-instance-l3vpna] address-family evpn
[SwitchB-vpn-evpn-l3vpna] vpn-target 1:1
[SwitchB-vpn-evpn-l3vpna] quit
[SwitchB-vpn-instance-l3vpna] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance l3vpna
[SwitchB-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 1-1-1
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] local-proxy-arp enable
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 3
[SwitchB-Vsi-interface3] ip binding vpn-instance l3vpna
[SwitchB-Vsi-interface3] l3-vni 1000
[SwitchB-Vsi-interface3] quit
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] gateway vsi-interface 1
[SwitchB] vsi vpna
[SwitchB-vsi-vpna] igmp-snooping enable
[SwitchB-vsi-vpna] igmp-snooping proxy enable
[SwitchB-vsi-vpna] igmp-snooping drop-unknown
[SwitchB-vsi-vpna] igmp-snooping forwarding-mode ip
[SwitchB-vsi-vpna] igmp-snooping version 3
[SwitchB-vsi-vpna] igmp-snooping querier
5. Configure Switch C:
# Enable L2VPN.
[SwitchC] l2vpn enable
[SwitchC] vxlan tunnel mac-learning disable
[SwitchC] vxlan tunnel arp-learning disable
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] evpn encapsulation vxlan
[SwitchC-vsi-vpna-evpn-vxlan] route-distinguisher auto router-id
[SwitchC-vsi-vpna-evpn-vxlan] vpn-target auto
[SwitchC-vsi-vpna-evpn-vxlan] quit
# Create VXLAN 10.
[SwitchC-vsi-vpna] vxlan 10
[SwitchC-vsi-vpna] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default] address-family l2vpn evpn
[SwitchC-bgp-default-evpn] peer 4.4.4.4 enable
[SwitchC-bgp-default-evpn] quit
[SwitchC-bgp-default] quit
[SwitchC] interface gigabitethernet 1/0/1
[SwitchC-GigabitEthernet1/0/1] esi 0.0.0.0.2
# On GigabitEthernet 1/0/1, create Ethernet service instance 3000 to match VLAN 2.
[SwitchC-GigabitEthernet1/0/1] service-instance 3000
[SwitchC-GigabitEthernet1/0/1-srv3000] encapsulation s-vid 2
[SwitchC-GigabitEthernet1/0/1-srv3000] xconnect vsi vpna
[SwitchC-GigabitEthernet1/0/1-srv3000] quit
[SwitchC] ip vpn-instance l3vpna
[SwitchC-vpn-instance-l3vpna] route-distinguisher 3:3
[SwitchC-vpn-instance-l3vpna] address-family ipv4
[SwitchC-vpn-ipv4-l3vpna] vpn-target 2:2
[SwitchC-vpn-ipv4-l3vpna] quit
[SwitchC-vpn-instance-l3vpna] address-family evpn
[SwitchC-vpn-evpn-l3vpna] vpn-target 1:1
[SwitchC-vpn-evpn-l3vpna] quit
[SwitchC-vpn-instance-l3vpna] quit
[SwitchC] interface vsi-interface 1
[SwitchC-Vsi-interface1] ip binding vpn-instance l3vpna
[SwitchC-Vsi-interface1] ip address 10.1.1.1 255.255.255.0
[SwitchC-Vsi-interface1] mac-address 1-1-1
[SwitchC-Vsi-interface1] distributed-gateway local
[SwitchC-Vsi-interface1] local-proxy-arp enable
[SwitchC-Vsi-interface1] quit
[SwitchC] interface vsi-interface 3
[SwitchC-Vsi-interface3] ip binding vpn-instance l3vpna
[SwitchC-Vsi-interface3] l3-vni 1000
[SwitchC-Vsi-interface3] quit
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] gateway vsi-interface 1
[SwitchC -igmp-snooping] quit
[SwitchC] vsi vpna
[SwitchC -vsi-vpna] igmp-snooping enable
[SwitchC -vsi-vpna] igmp-snooping proxy enable
[SwitchC -vsi-vpna] igmp-snooping drop-unknown
[SwitchC -vsi-vpna] igmp-snooping forwarding-mode ip
[SwitchC -vsi-vpna] igmp-snooping version 3
[SwitchC -vsi-vpna] igmp-snooping querier
[SwitchC -vsi-vpna] quit
6. Configure Switch D:
# Establish BGP connections with other transport network switches.
[SwitchD] bgp 200
[SwitchD-bgp-default] group evpn
[SwitchD-bgp-default] peer 1.1.1.1 group evpn
[SwitchD-bgp-default] peer 2.2.2.2 group evpn
[SwitchD-bgp-default] peer 3.3.3.3 group evpn
[SwitchD-bgp-default] peer evpn as-number 200
[SwitchD-bgp-default] peer evpn connect-interface loopback 0
# Configure BGP to advertise BGP EVPN routes, and disable route target filtering for BGP EVPN routes.
[SwitchD-bgp-default] address-family l2vpn evpn
[SwitchD-bgp-default-evpn] peer evpn enable
[SwitchD-bgp-default-evpn] undo policy vpn-target
# Configure Switch D as an RR.
[SwitchD-bgp-default-evpn] peer evpn reflect-client
[SwitchD-bgp-default-evpn] quit
[SwitchD-bgp-default] quit
1. On Server 1, send an IGMP membership report to multicast group address 225.0.0.1.
2. Verify that Switch B has received the SMET route advertised by Switch A and created a multicast forwarding entry.
# Display SMET routes on Switch B.
<SwitchB> display evpn route smet
VSI name: vpna
Source address : 0.0.0.0
Group address : 225.0.0.1
Local version : -
Peers :
Nexthop Tunnel name Link ID Remote version
1.1.1.1 Tunnel0 0x5000000 v3(E)
# # Display EVPN routes on Switch B.
<SwitchB> display igmp-snooping evpn-group
Total 1 entries.
VSI vpna: Total 1 entries.
(0.0.0.0, 225.0.0.1)
Tun1 (VXLAN ID 10)
3. Verify that Switch B has received the IGMP join synch route advertised by Switch A.
<SwitchB> dis evpn route igmp-js
VSI name: vpna
Local version : -
Remote version : v3(E)
ESI : 0000.0000.0000.0000.0001
Ethernet tag ID : 2
AC :
Peers : 2.2.2.2
Example: Configuring a VLAN-based IGMP snooping access policy
As shown in Figure 10:
· The switch runs IGMPv2 snooping.
· The switch performs 802.1X authentication for Host A and Host B.
Configure an IGMP snooping access group policy on the switch so that Host A can join or leave only multicast group 224.1.1.1.
Configuring the switch
1. Configure IGMP snooping.
<Switch> system-view
[Switch] igmp-snooping
[Switch-igmp-snooping] quit
# Create VLAN 100 and assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to the VLAN.
[Switch] vlan 100
[Switch-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Switch-vlan100] igmp-snooping enable
[Switch-vlan100] quit
# Configure an IGMP snooping access policy.
[Switch] acl basic 2001
[Switch-acl-ipv4-basic-2001] rule permit source 224.1.1.1 0
[Switch-acl-ipv4-basic-2001] quit
[Switch] user-profile profile2
[Switch-user-profile-profile2] igmp-snooping access-policy 2001
[Switch-user-profile-profile2] quit
2. Configure a RADIUS scheme.
# Create a RADIUS scheme named scheme2.
[Switch] radius scheme scheme2
# Specify the primary authentication server and primary accounting server, and configure the keys for communication with the servers.
[Switch-radius-scheme2] primary authentication 3.1.1.1
[Switch-radius-scheme2] key authentication simple 321123
[Switch-radius-scheme2] primary accounting 3.1.1.1
[Switch-radius-scheme2] key accounting simple 321123
# Exclude the ISP domain name from the username sent to the RADIUS server.
[Switch-radius-scheme2] user-name-format without-domain
[Switch-radius-scheme2] quit
3. Configure an ISP domain.
# Create an ISP domain named domain2.
[Switch] domain domain2
# Configure AAA methods for the ISP domain.
[Switch-isp-domain2] authorization-attribute user-profile profile2
[Switch-isp-domain2] authentication lan-access radius-scheme scheme2
[Switch-isp-domain2] authorization lan-access radius-scheme scheme2
[Switch-isp-domain2] accounting lan-access radius-scheme scheme2
[Switch-isp-domain2] quit
# Configure domain domain2 as the default ISP domain.
[Switch] domain default enable domain2
4. Configure 802.1X authentication.
# Enable 802.1X authentication on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x
# Enable 802.1X authentication on GigabitEthernet 1/0/3.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] dot1x
[Switch-GigabitEthernet1/0/3] quit
# Enable 802.1X authentication globally.
[Switch] dot1x
Configuring the RADIUS server
# Configure the RADIUS server properly to provide authentication and accounting functions. (Details not shown.)
# Display dynamic IGMP snooping group entries for VLAN 100.
[Switch] display igmp-snooping group vlan 100
Total 1 entries.
GE1/0/3 (00:03:05)
Example: Configuring VSI-based IGMP snooping
As shown in Figure 11:
· There are three sites in VPN a. They are connected through the VPLS network.
· In VLAN 100, Source in Site 1, Host A in Site 2, and Host B in Site 3 communicate with CE 1, CE 2, and CE 3, respectively.
Configure the devices so that Host A and Host B can receive multicast data from Source.
Device |
IP address |
Device |
IP address |
PE 1 |
Vlan-int101 |
10.110.1.1/24 |
PE 2 |
Loop0 |
2.2.2.2/32 |
PE 1 |
Vlan-int102 |
10.110.2.1/24 |
PE 3 |
Loop0 |
10.110.2.2/24 |
PE 1 |
Loop0 |
1.1.1.1/32 |
PE 3 |
Loop0 |
10.110.3.2/24 |
PE 2 |
Vlan-int101 |
10.110.1.2/24 |
PE 3 |
Loop0 |
3.3.3.3/32 |
PE 2 |
Vlan-int103 |
10.110.3.1/24 |
On the VPLS network, assign an IP address and subnet mask to each interface as shown in Table 1, and configure OSPF on the switches.
1. Configure CE 1:
<CE1> system-view
[CE1] igmp-snooping
[CE1-igmp-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/2 to VLAN 100.
[CE1] vlan 100
[CE1-vlan100] port gigabitethernet 1/0/2
# In VLAN 100, enable IGMP snooping, and enable dropping unknown multicast data.
[CE1-vlan100] igmp-snooping enable
[CE1-vlan100] igmp-snooping drop-unknown
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign it to VLAN 100.
[CE1] interface gigabitethernet 1/0/1
[CE1-GigabitEthernet1/0/1] port link-type trunk
[CE1-GigabitEthernet1/0/1] port trunk permit vlan 100
[CE1-GigabitEthernet1/0/1] quit
# In VLAN 100, enable the IGMP snooping querier.
[CE1-vlan100] igmp-snooping querier
# In VLAN 100, specify 192.168.1.100 as the source IP address of IGMP general queries and IGMP group-specific queries.
[CE1-vlan100] igmp-snooping general-query source-ip 192.168.1.100
[CE1-vlan100] igmp-snooping special-query source-ip 192.168.1.100
2. Configure CE 2:
<CE2> system-view
[CE2] igmp-snooping
[CE2-igmp-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 1/0/2 to VLAN100.
[CE2] vlan 100
[CE2-vlan100] port gigabitethernet 1/0/2
[CE2-vlan100] igmp-snooping enable
[CE2-vlan100] igmp-snooping drop-unknown
[CE2] interface gigabitethernet 1/0/1
[CE2-GigabitEthernet1/0/1] port link-type trunk
[CE2-GigabitEthernet1/0/1] port trunk permit vlan 100
[CE2-GigabitEthernet1/0/1] quit
3. Configure CE 3:
<CE3> system-view
[CE3] igmp-snooping
[CE3-igmp-snooping] quit
[CE3] vlan 100
[CE3-vlan100] port gigabitethernet 1/0/2
# In VLAN 100, enable IGMP snooping, and dropping unknown multicast data.
[CE3-vlan100] igmp-snooping enable
[CE3-vlan100] igmp-snooping drop-unknown
[CE3] interface gigabitethernet 1/0/1
[CE3-GigabitEthernet1/0/1] port link-type trunk
[CE3-GigabitEthernet1/0/1] port trunk permit vlan 100
[CE3-GigabitEthernet1/0/1] quit
4. Configure PE 1:
# Configure the LSR ID as 1.1.1.1 for the local node, and enable L2VPN and LDP.
<PE1> system-view
[PE1] mpls lsr-id 1.1.1.1
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
# Enable MPLS and LDP on VLAN-interface 101.
[PE1] interface vlan-interface 101
[PE1-Vlan-interface101] mpls enable
[PE1-Vlan-interface101] mpls ldp enable
[PE1-Vlan-interface101] quit
# Enable MPLS and LDP on VLAN-interface 102.
[PE1] interface vlan-interface 102
[PE1-Vlan-interface102] mpls enable
[PE1-Vlan-interface102] mpls ldp enable
[PE1-Vlan-interface102] quit
# Create a VSI named aaa, and specify the VSI to establish PWs statically.
[PE1] vsi aaa
[PE1-vsi-aaa] pwsignaling static
# Configure PWs for VSI aaa.
[PE1-vsi-aaa-static] peer 2.2.2.2 pw-id 3 in-label 100 out-label 100
[PE1-vsi-aaa-static-2.2.2.2-3] quit
[PE1-vsi-aaa-static] peer 3.3.3.3 pw-id 3 in-label 200 out-label 200
[PE1-vsi-aaa-static-3.3.3.3-3] quit
[PE1-vsi-aaa-static] quit
[PE1-vsi-aaa] quit
# Bind GigabitEthernet 1/0/1 to VSI aaa.
[PE1-GigabitEthernet1/0/1] service-instance 1
[PE1-GigabitEthernet1/0/1-srv1] encapsulation s-vid 5
[PE1-GigabitEthernet1/0/1-srv1] xconnect vsi aaa
[PE1-GigabitEthernet1/0/1-srv1] quit
[PE1] igmp-snooping
[PE1-igmp-snooping] quit
# Enable IGMP snooping, and enable dropping unknown multicast data for VSI aaa.
[PE1] vsi aaa
[PE1-vsi-aaa] igmp-snooping enable
[PE1-vsi-aaa] igmp-snooping drop-unknown
[PE1-vsi-aaa] quit
5. Configure PE 2:
# Configure the LSR ID as 2.2.2.2 for the local node, and enable L2VPN and LDP.
<PE2> system-view
[PE2] mpls lsr-id 2.2.2.2
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface vlan-interface 101
[PE2-Vlan-interface101] mpls enable
[PE2-Vlan-interface101] mpls ldp enable
[PE2-Vlan-interface101] quit
# Enable MPLS and LDP on VLAN-interface 103.
[PE2] interface vlan-interface 103
[PE2-Vlan-interface103] mpls enable
[PE2-Vlan-interface103] mpls ldp enable
[PE2-Vlan-interface103] quit
[PE2] vsi aaa
[PE2-vsi-aaa] pwsignaling static
[PE2-vsi-aaa-static] peer 1.1.1.1 pw-id 3 in-label 100 out-label 100
[PE2-vsi-aaa-static-1.1.1.1-3] quit
[PE2-vsi-aaa-static] peer 3.3.3.3 pw-id 3 in-label 300 out-label 300
[PE2-vsi-aaa-static-3.3.3.3-3] quit
[PE2-vsi-aaa-static] quit
[PE2-vsi-aaa] quit
[PE2] interface gigabitethernet 1/0/1
[PE2-GigabitEthernet1/0/1] service-instance 1
[PE2-GigabitEthernet1/0/1-srv1] encapsulation s-vid 5
[PE2-GigabitEthernet1/0/1-srv1] xconnect vsi aaa
[PE2-GigabitEthernet1/0/1-srv1] quit
[PE2-GigabitEthernet1/0/1] quit
[PE2] igmp-snooping
[PE2-igmp-snooping] quit
# In VSI aaa, enable IGMP snooping, and enable dropping unknown multicast data.
[PE2] vsi aaa
[PE2-vsi-aaa] igmp-snooping enable
[PE2-vsi-aaa] igmp-snooping drop-unknown
[PE2-vsi-aaa] quit
6. Configure PE 3:
# Configure the LSR ID as 3.3.3.3 for the local node, and enable L2VPN and LDP.
<PE3> system-view
[PE3] mpls lsr-id 3.3.3.3
[PE3] l2vpn enable
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] interface vlan-interface 102
[PE3-Vlan-interface102] mpls enable
[PE3-Vlan-interface102] mpls ldp enable
[PE3-Vlan-interface102] quit
[PE3] interface vlan-interface 103
[PE3-Vlan-interface103] mpls enable
[PE3-Vlan-interface103] mpls ldp enable
[PE3-Vlan-interface103] quit
[PE3] vsi aaa
[PE3-vsi-aaa] pwsignaling static
[PE3-vsi-aaa-static] peer 1.1.1.1 pw-id 3 in-label 200 out-label 200
[PE3-vsi-aaa-static-1.1.1.1-3] quit
[PE3-vsi-aaa-static] peer 2.2.2.2 pw-id 3 in-label 300 out-label 300
[PE3-vsi-aaa-static-2.2.2.2-3] quit
[PE3-vsi-aaa-static] quit
[PE3-vsi-aaa] quit
[PE3] interface gigabitethernet 1/0/1
[PE3-GigabitEthernet1/0/1] service-instance 1
[PE3-GigabitEthernet1/0/1-srv1] encapsulation s-vid 5
[PE3-GigabitEthernet1/0/1-srv1] xconnect vsi aaa
[PE3-GigabitEthernet1/0/1-srv1] quit
[PE3-GigabitEthernet1/0/1] quit
[PE3] igmp-snooping
[PE3-igmp-snooping] quit
[PE3] vsi aaa
[PE3-vsi-aaa] igmp-snooping enable
[PE3-vsi-aaa] igmp-snooping drop-unknown
[PE3-vsi-aaa] quit
# Display detailed information about dynamic IGMP snooping group entries for VSI aaa on PE 1.
[PE1] display igmp-snooping group vsi aaa verbose
Total 1 entries.
VSI aaa: Total 1 entries.
Attribute: global port
FSM information: dummy
Host slots (0 in total):
NPW (Link ID 9) (00:02:24)
VLAN pairs (1 in total):
Outer VLAN 100 Inner VLAN 0 (00:02:24)
# Display detailed information about dynamic router ports for VSI aaa on PE 1.
[PE1] display igmp-snooping router-port vsi aaa verbose
VSI aaa:
Router slots (0 in total):
GE1/0/1 (Link ID 0) (00:01:46)
Outer VLAN 100 Inner VLAN 0 (00:01:46)
# Display detailed information about dynamic IGMP snooping group entries for VSI aaa on PE 2.
[PE2] display igmp-snooping group vsi aaa verbose
Total 1 entries.
NPW (Link ID 8) (00:02:07)
Outer VLAN 100 Inner VLAN 0 (00:02:07)
# Display detailed information about dynamic router ports for VSI aaa on PE 2.
[PE2] display igmp-snooping router-port vsi aaa verbose
VSI aaa:
NPW (Link ID 9) (00:01:26)
Outer VLAN 100 Inner VLAN 0 (00:01:26)
# Display detailed information about dynamic IGMP snooping group entries for VSI aaa on PE 3.
[PE3] display igmp-snooping group vsi aaa verbose
Total 1 entries.
GE1/0/1 (Link ID 0) (00:02:04)
Outer VLAN 100 Inner VLAN 0 (00:02:04)
# Display detailed information about dynamic router ports for VSI aaa on PE 3.
[PE3] display igmp-snooping router-port vsi aaa verbose
VSI aaa:
NPW (Link ID 9) (00:01:24)
Outer VLAN 100 Inner VLAN 0 (00:01:24)
Example: Configuring VXLAN-based IGMP snooping
As shown in Figure 12:
· VXLAN 10 provides Layer 2 connectivity for VM 1, VM 2, and VM 3 across the network sites.
· VXLAN 10 uses the unicast mode for flood traffic.
Configure IGMP snooping on the switches to implement Layer 2 multicast forwarding and reduce the burden of replicating known multicast traffic for VTEPs in VXLAN 10.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int11 |
11.1.1.1/24 |
Switch C |
Vlan-int13 |
13.1.1.3/24 |
Switch A |
Loop0 |
1.1.1.1/32 |
Switch C |
Loop0 |
3.3.3.3/32 |
Switch B |
Vlan-int12 |
12.1.1.2/24 |
Switch D |
Vlan-int11 |
11.1.1.4/24 |
Switch B |
Loop0 |
2.2.2.2/32 |
Switch D |
Vlan-int12 |
12.1.1.4/24 |
Switch D |
Vlan-int13 |
13.1.1.4/24 |
On the transport network, assign an IP address and subnet mask to each interface as shown in Table 2, and configure OSPF on all the switches.
# Enable L2VPN.
[SwitchA] l2vpn enable
# Enable Layer 2 forwarding for VXLANs.
[SwitchA] undo vxlan ip-forwarding
# Create a VSI named vpna, and create VXLAN 10.
[SwitchA] vsi vpna
[SwitchA -igmp-snooping] quit
# Enable IGMP snooping and dropping unknown multicast data packets for VSI vpna.
[SwitchA] vsi vpna
# Assign an IP address to Loopback 0. This IP address will be used as the source address of the VXLAN tunnels to Switch B and Switch C.
[SwitchA-Loopback0] ip address 1.1.1.1 255.255.255.255
[SwitchA-Loopback0] quit
# Create a VXLAN tunnel to Switch B.
¡ The tunnel interface name is Tunnel 1.
¡ The source address and destination address of the tunnel interface are 1.1.1.1 and 2.2.2.2, respectively.
[SwitchA-Tunnel1] quit
# Create a VXLAN tunnel to Switch C.
¡ The tunnel interface name is Tunnel 2.
¡ The source address and destination address of the tunnel interface are 1.1.1.1 and 3.3.3.3, respectively.
[SwitchA] interface tunnel 2 mode vxlan
[SwitchA-Tunnel2] source 1.1.1.1
[SwitchA-Tunnel2] destination 3.3.3.3
[SwitchA-Tunnel2] quit
# Assign Tunnel 1 and Tunnel 2 to VXLAN 10.
[SwitchA] vsi vpna
[SwitchA-vsi-vpna-vxlan-10] tunnel 1
[SwitchA-vsi-vpna-vxlan-10] tunnel 2
[SwitchA-GigabitEthernet1/0/1] quit
# Enable L2VPN.
[SwitchB] undo vxlan ip-forwarding
[SwitchB] vsi vpna
[SwitchB -igmp-snooping] quit
[SwitchB] vsi vpna
# Assign an IP address to Loopback 0. This IP address will be used as the source address of the VXLAN tunnels to Switch A and Switch C.
[SwitchB-Loopback0] ip address 2.2.2.2 255.255.255.255
[SwitchB-Loopback0] quit
# Create a VXLAN tunnel to Switch A.
¡ The source address and destination address of the tunnel interface are 2.2.2.2 and 1.1.1.1, respectively.
[SwitchB] interface tunnel 2 mode vxlan
[SwitchB-Tunnel2] source 2.2.2.2
[SwitchB-Tunnel2] destination 1.1.1.1
[SwitchB-Tunnel2] quit
¡ The tunnel interface name is Tunnel 3.
¡ The source address and destination address of the tunnel interface are 2.2.2.2 and 3.3.3.3, respectively.
[SwitchB] interface tunnel 3 mode vxlan
[SwitchB-Tunnel3] source 2.2.2.2
[SwitchB-Tunnel3] destination 3.3.3.3
[SwitchB-Tunnel3] quit
# Assign Tunnel 2 and Tunnel 3 to VXLAN 10.
[SwitchB] vsi vpna
[SwitchB-vsi-vpna-vxlan-10] tunnel 2
[SwitchB-vsi-vpna-vxlan-10] tunnel 3
[SwitchB-GigabitEthernet1/0/1] service-instance 1000
[SwitchB-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchB-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchB-GigabitEthernet1/0/1-srv1000] quit
# Enable L2VPN.
[SwitchC] undo vxlan ip-forwarding
[SwitchC] vsi vpna
# Enable IGMP snooping for VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna] igmp-snooping enable
# Enable dropping unknown multicast data packets for VSI vpna.
[SwitchC-vsi-vpna] igmp-snooping drop-unknown
# Specify 3.3.3.3 as the source IP address of IGMP general queries in VSI vpna.
[SwitchC-vsi-vpna] igmp-snooping general-query source-ip 3.3.3.3
# Enable the IGMP snooping querier.
[SwitchC-vsi-vpna] igmp-snooping querier
# Assign an IP address to Loopback 0. This address will be used as the source address of the VXLAN tunnels to Switch A and Switch B.
[SwitchC-Loopback0] ip address 3.3.3.3 255.255.255.255
[SwitchC-Loopback0] quit
¡ The source address and destination address of the tunnel interface are 3.3.3.3 and 1.1.1.1, respectively.
[SwitchC] interface tunnel 1 mode vxlan
[SwitchC-Tunnel1] source 3.3.3.3
[SwitchC-Tunnel1] destination 1.1.1.1
[SwitchC-Tunnel1] quit
¡ The source address and destination address of the tunnel interface are 3.3.3.3 and 2.2.2.2, respectively.
[SwitchC] interface tunnel 3 mode vxlan
[SwitchC-Tunnel3] source 3.3.3.3
[SwitchC-Tunnel3] destination 2.2.2.2
[SwitchC-Tunnel3] quit
# Assign Tunnel 1 and Tunnel 3 to VSI vpna.
[SwitchC] vsi vpna
[SwitchC-vsi-vpna-vxlan-10] tunnel 1
[SwitchC-vsi-vpna-vxlan-10] tunnel 3
[SwitchC-GigabitEthernet1/0/1] service-instance 1000
[SwitchC-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 2
[SwitchC-GigabitEthernet1/0/1-srv1000] xconnect vsi vpna
[SwitchC-GigabitEthernet1/0/1-srv1000] quit
[SwitchC-GigabitEthernet1/0/1] quit
# Display brief information about dynamic router ports for VSI vpna on Switch A.
[SwitchA] display igmp-snooping router-port vsi vpna
VSI vpna:
Tun2 (VXLAN ID 10) (00:04:17)
# Display brief information about dynamic router ports for VSI vpna on Switch B.
[SwitchB] display igmp-snooping router-port vsi vpna
VSI vpna:
Tun3 (VXLAN ID 10) (00:04:07)
Troubleshooting IGMP snooping
Layer 2 multicast forwarding cannot function
Symptom
Layer 2 multicast forwarding cannot function on the Layer 2 device.
Solution
To resolve the problem:
1. Use the display igmp-snooping command to display IGMP snooping status.
2. If IGMP snooping is not enabled, use the igmp-snooping command in system view to enable the IGMP snooping feature. Then, use the igmp-snooping enable command in VLAN view or VSI view to enable IGMP snooping for the VLAN or VSI.
3. If IGMP snooping is enabled globally but not enabled for the VLAN or VSI, use the igmp-snooping enable command in VLAN view or VSI view to enable IGMP snooping for the VLAN or VSI.
4. If the problem persists, contact H3C Support.
Multicast group policy does not work
Symptom
Hosts can receive multicast data for multicast groups that are not permitted by the multicast group policy.
Solution
1. Use the display acl command to verify that the configured ACL meets the multicast group policy requirements.
2. Use the display this command in IGMP-snooping view or in a corresponding interface view to verify that the correct multicast group policy has been applied. If the applied policy is not correct, use the group-policy or igmp-snooping group-policy command to apply the correct multicast group policy.
3. Use the display igmp-snooping command to verify that dropping unknown multicast data is enabled. If it is not, use the drop-unknown or igmp-snooping drop-unknown command to enable dropping unknown multicast data.
