04-Layer 2 - LAN Switching Configuration Guide
HomeSupportServersBlade ServerH3C UniServer B16000BX608FEConfigure & DeployConfiguration GuidesH3C UniServer BX608FE Switch Module Configuration Guide-1.03.XX-6W10004-Layer 2 - LAN Switching Configuration Guide
01-MAC address table configuration
01-MAC address table configuration 44.42 KB
Configuring the MAC address table
About the MAC address table
An Ethernet device uses a MAC address table to forward frames. A MAC address entry includes a destination MAC address, an outgoing interface, and a VLAN ID. When the device receives a frame, it uses the destination MAC address of the frame to look for a match in the MAC address table.
·     The device forwards the frame out of the outgoing interface in the matching entry if a match is found.
·     The device floods the frame in the VLAN of the frame if no match is found.
Display and maintenance commands for MAC address table
Display MAC address table information.
display mac-address [ mac-address [ vlan vlan-id ] | [ [ dynamic | static ] [ interface interface-type interface-number ] | blackhole | multiport ] [ vlan vlan-id ] [ count ]]
Display the aging timer for dynamic MAC address entries.
display mac-address aging-time
Display the system or interface MAC address learning state.
Display the MAC address move records.
display mac-address mac-move [ slot slot-number ]
Display MAC address statistics.
display mac-address statistics
