HomeSupportConfigure & DeployConfiguration GuidesH3C S6800 & S6860 Switch Series Configuration Guides-Release 671x-6W10009-Security Configuration Guide
15-Object group configuration
15-Object group configuration 55.19 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL or object group to identify packets. Object groups are divided into the following types:
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet.
·     Port object group—A group of port objects used to match the protocol port number in a packet.
Configuring an IPv4 address object group
When you use the group-object object-group-name option, follow these guidelines:
·     The object group to be used must be an IPv4 address object group.
·     Two object groups cannot use each other at the same time.
·     The system supports a maximum of two object group hierarchy layers and contents of used groups cannot be the same. For example, if object group ipgroup contains subnet 10.1.1.0 255.255.255.0 and group object ipgroup1, and object group ipgroup1 also contains 10.1.1.0 255.255.255.0, the packet filter that uses object group ipgroup will fail to be deployed.
2.     Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask }| group-object object-group-name }
Configuring an IPv6 address object group
·     The object group to be used must be an IPv6 address object group.
·     The system supports a maximum of two object group hierarchy layers and contents of used groups cannot be the same. For example, if object group ipv6group contains subnet 1:1:1::1 24 and group object ipv6group1, and object group ipv6group1 also contains 1:1:1::1 24, the packet filter that uses object group ipv6group will fail to be deployed.
2.     Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length | group-object object-group-name}
Configuring a port object group
·     The system supports a maximum of two object group hierarchy layers and contents of used object groups cannot be the same. For example, if object group portgroup contains port eq 100 and object group portgroup1, and object group portgroup1 also contains port eq 100, the packet filter that uses object group portgroup will fail to be deployed.
Precedure
2.     Configure a port object group and enter its view.
object-group port object-group-name
The system has one default port object group named any.
3.     (Optional.) Configure a description for the port object group.
4.     Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | port }[ default ] [ name object-group-name ] | name object-group-name ]
