- 05-Layer 3-IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-RIPng commands
- 10-OSPFv3 commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-DCN commands
| 09-RIPng commands | 158.33 KB |
RIPng commands
checkzero
Use checkzero to enable zero field check on RIPng packets.
Use undo checkzero to disable zero field check.
checkzero
undo checkzero
Zero field check is enabled.
RIPng view
Some fields in RIPng packet headers must be zero. These fields are called zero fields. You can enable zero field check on incoming RIPng packets. If a zero field of a packet contains a non-zero value, RIPng discards the packet.
# Disable zero field check on RIPng packets for RIPng 100.
[Sysname] ripng 100
[Sysname-ripng-100] undo checkzero
default cost
Use default cost to configure a default metric for redistributed routes.
Use undo default cost to restore the default.
default cost cost-value
undo default cost
The default metric of redistributed routes is 0.
RIPng view
cost-value: Specifies a default metric for redistributed routes, in the range of 0 to 16.
When you use the import-route command to redistribute routes from another routing protocol without specifying a metric, the metric specified by the default cost command applies.
# Configure a default metric of 2 for redistributed routes.
[Sysname] ripng 100
[Sysname-ripng-100] default cost 2
import-route
display ripng
Use display ripng to display state and configuration information for a RIPng process.
display ripng [ process-id ]
process-id: Specifies a RIPng process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all RIPng processes.
# Display state and configuration information for all configured RIPng processes.
<Sysname> display ripng
Public VPN-instance name:
RIPng process: 1
Preference: 100
Routing policy: abc
Fast-reroute:
Routing policy: abc
Checkzero: Enabled
Default cost: 0
Maximum number of load balanced routes: 6
Update time : 30 secs Timeout time : 180 secs
Suppress time : 120 secs Garbage-collect time : 120 secs
Update output delay: 20(ms) Output count: 3
Graceful-restart interval: 60 secs
Triggered Interval : 5 50 200
Number of periodic updates sent: 256
Number of triggered updates sent: 0
Public VPN-instance name |
Public network where the RIPng process runs. |
Private VPN-instance name |
VPN where the RIPng process runs. |
RIPng process |
RIPng process ID. |
Preference |
RIPng preference. |
Checkzero |
Indicates whether zero field check for RIPng packet headers is enabled: Enabled or Disabled. |
Default cost |
Default metric of redistributed routes. |
Fast-reroute |
RIPng FRR. |
Maximum number of balanced routes |
Maximum number of load-balanced routes. |
Update time |
RIPng update interval, in seconds. |
Timeout time |
RIPng timeout interval, in seconds. |
Suppress time |
RIPng suppress interval, in seconds. |
Garbage-collect time |
RIPng garbage collection interval, in seconds. |
Update output delay |
RIPng packet sending interval, in milliseconds. |
Output count |
Maximum number of RIPng packets that can be sent at each interval. |
Graceful-restart interval |
GR interval in seconds. |
Triggered Interval |
Triggered update sending interval. |
display ripng database
Use display ripng database to display all active routes in the advertising database for a RIPng process.
display ripng process-id database [ ipv6-address prefix-length ]
ipv6-address prefix-length: Specifies an IPv6 address. The ipv6-address argument specifies an IPv6 address. The prefix-length argument specifies a prefix length in the range of 0 to 128.
# Display active routes for RIPng process 1.
<Sysname> display ripng 1 database
1::/64,
cost 0, RIPng-interface
10::/32,
cost 0, imported
2::2/128,
via FE80::20C:29FF:FE7A:E3E4, cost 1
cost |
Route metric value. |
imported |
Indicates the route is redistributed from another routing protocol. |
RIPng-interface |
Route learned from the interface. |
via |
Next hop IPv6 address. |
display ripng graceful-restart
Use display ripng graceful-restart to display GR information.
display ripng [ process-id ] graceful-restart
# Display GR information for RIPng process 1.
<Sysname> display ripng 1 graceful-restart
RIPng process: 1
Graceful Restart capability : Enabled
Current GR state : Normal
Graceful Restart period : 60 seconds
Graceful Restart remaining time: 0 seconds
Graceful Restart capability |
Indicates whether GR is enabled: Enabled or Disabled. |
Current GR state |
GR state: · Under GR—GR is in process. · Normal—GR is not in progress or has completed. |
display ripng interface
Use display ripng interface to display interface information for a RIPng process.
display ripng process-id interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays information about all interfaces for the RIPng process.
# Display interface information for RIPng process 1.
<Sysname> display ripng 1 interface
Total: 1
Interface: Vlan-interface100
Link-local address: FE80::20C:29FF:FEC8:B4DD
Split-horizon: On Poison-reverse: Off
MetricIn: 0 MetricOut: 1
Default route: Off
Update output delay: 20 (ms) Output count: 3
Primary path detection mode: BFD echo
Summary address:
1::/16
Total |
Number of interfaces running RIPng. |
Name of an interface running RIPng. |
Link Local Address |
Link-local address of an interface running RIPng. |
Split-horizon |
Indicates whether split horizon is enabled: · On—Enabled. · Off—Disabled. |
Poison-reverse |
Indicates whether poison reverse is enabled: · On—Enabled. · Off—Disabled. |
MetricIn/MetricOut |
Additional metric to incoming and outgoing routes. |
Default route |
· Only—The interface advertises only a default route. · Originate—The interface advertises a default route and other RIPng routes. · Off—In this state, the interface does not advertise a default route. · In garbage-collection status—In this state, the interface advertises a default route with a metric of 16. |
Output count |
Maximum number of RIPng packets that an interface can send at each interval. |
Default route cost |
Cost of the default route. |
Primary path detection mode |
BFD echo indicates that BFD single-hop echo detection is used to detect primary link failures. |
display ripng neighbor
Use display ripng neighbor to display neighbor information for a RIPng process.
display ripng process-id neighbor [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this argument, the command displays information about all neighbors for the RIPng process.
# Display neighbor information for RIPng process 1.
<Sysname> display ripng 1 neighbor
Neighbor Address: FE80::230:FF:FE00:0
Interface : Vlan-interface1
Version : RIPng version 1 Last update: 00h00m27s
Bad packets: 0 Bad routes : 0
Table 5 Command output
Neighbor Address |
Link-local address of a neighbor interface. |
Name of a neighbor interface. |
Version |
Version of RIPng that a neighbor runs. |
Last update |
Time elapsed since the most recent update. |
display ripng non-stop-routing
Use display ripng non-stop-routing to display RIPng NSR information.
display ripng [ process-id ] non-stop-routing
# Display NSR information for RIPng process 1.
<Sysname> display ripng 1 non-stop-routing
RIPng process: 1
Nonstop Routing capability: Enabled
Current NSR state : Finish
Table 6 Command output
Nonstop Routing capability |
Indicates whether NSR is enabled: Enabled or Disabled. |
Current NSR state |
NSR state: · Initialization—Initialization state. · Smooth—Upgrading data. · Advertising—Advertising routes. · Redistribution—Redistributing routes. · Finish—Finished. |
display ripng route
Use display ripng route to display all RIPng routes for a RIPng process.
display ripng process-id route [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ]
verbose: Displays all routing information for the specified destination IPv6 address. If you do not specify this keyword, the command displays only optimal RIPng routes with the specified destination IPv6 address.
peer ipv6-address: Specifies a neighbor by its IPv6 address.
statistics: Displays routing information statistics, including total number of routes and the number of routes learned from each neighbor.
# Display routing information for RIPng process 1.
<Sysname> display ripng 1 route
Route Flags: A - Aging, S - Suppressed, G - Garbage-collect, D – Direct
O - Optimal, F - Flush to RIB
Peer FE80::20C:29FF:FED4:7171 on Vlan-interface100
Destination 4::4/128,
via FE80::20C:29FF:FED4:7171, cost 1, tag 0, AOF, 5 secs
Local route
Destination 3::3/128,
via ::, cost 0, tag 0, DOF
Destination 6::/64,
# Display information about routes with the specified prefix for RIPng process 1.
<Sysname> display ripng 1 route 3::3 128 verbose
Peer FE80::4283:59FF:FE97:205 on Vlan-interface100
via FE80::4283:59FF:FE97:205, cost 1, tag 0, AOF, 28 secs
Table 7 Command output
A–Aging |
The route is in aging state. |
S–Suppressed |
The route is in suppressed state. |
G–Garbage-collect |
The route is in Garbage-collect state. |
D–Direct |
The route is a direct route. |
Local route |
The route is a locally generated direct route. |
O - Optimal |
The route is an optimal route. |
F - Flush to RIB |
The route has been flushed to the RIB. |
Peer |
Neighbor connected to the interface. |
Destination |
IPv6 destination address. |
via |
cost |
Routing metric value. |
tag |
Route tag. |
secs |
Time a route entry has stayed in the current state. |
# Display routing information statistics for RIPng process 1.
<Sysname> display ripng 1 route statistics
Peer Optimal/Aging Garbage
FE80::20C:29FF:FED4:7171 1/2 0
Local 2/0 0
total 3/2 0
Table 8 Command output
Peer |
IPv6 address of the neighbor. |
Optimal |
Number of optimal routes. |
Aging |
Number of routes in aging state. |
Garbage |
Number of routes in Garbage-collection state. |
Local |
Total number of locally generated direct route. |
total |
Total number of routes learned from RIPng neighbors. |
fast-reroute
Use fast-reroute to configure RIPng FRR.
Use undo fast-reroute to disable RIPng FRR.
undo fast-reroute
RIPng FRR is disabled.
RIPng view
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
RIPng FRR is available only when the state of primary link (with Layer 3 interfaces in up state) changes from bidirectional to unidirectional or down.
RIPng FRR is effective only for RIPng routes that are learned from directly connected neighbors.
Equal-cost routes do not support RIPng FRR.
# Enable RIPng FRR and use routing policy frr to specify a backup next hop.
[Sysname] ipv6 prefix-list abc index 10 permit 100:: 64
[Sysname] route-policy frr permit node 10
[Sysname-route-policy-frr-10] if-match ipv6 address prefix-list abc
[Sysname-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 1 backup-nexthop FE80::8
[Sysname-route-policy-frr-10] quit
[Sysname] ripng 100
[Sysname-ripng-100] fast-reroute route-policy frr
filter-policy export
Use filter-policy export to configure RIPng to filter redistributed routes.
Use undo filter-policy export to remove the filtering.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
RIPng does not filter redistributed routes.
RIPng view
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a string of 1 to 63 characters, to filter redistributed routes.
protocol: Filters routes redistributed from a routing protocol.
process-id: Specifies the process ID of the specified routing protocol, in the range of 1 to 65535. This argument is available only when the routing protocol is ripng, ospfv3, or isisv6. The default is 1.
If the protocol argument is specified, RIPng filters only routes redistributed from the specified routing protocol. Otherwise, RIPng filters all redistributed routes.
To specify an ACL in the command, follow these restrictions and guidelines:
· If the ACL does not exist or has no rules configured, all routes redistributed by RIPng will match the ACL.
· If a rule in the ACL has the vpn-instance keyword configured, the rule applies to only the RIPng routes in the specified VPN instance. If the rule does not have the vpn-instance keyword configured, the rule applies to only the RIPng routes on the public network.
To specify an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL in one of the following ways:
· To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix command.
· To deny/permit a route with the specified destination and prefix, use the rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix destination dest dest-prefix command.
The source keyword specifies the destination address of a route and the destination keyword specifies the prefix of the route. For the prefix configuration to take effect, specify a contiguous prefix.
# Use IPv6 prefix list to filter redistributed RIPng updates.
[Sysname] ipv6 prefix-list abc index 10 permit 100:1:: 32
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy prefix-list abc export
# Configure advanced IPv6 ACL 3000 to permit only route 2001::1/128 to pass. Use advanced IPv6 ACL 3000 to filter redistributed routes.
[Sysname-acl-ipv6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl-ipv6-adv-3000] rule 100 deny ipv6
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy 3000 export
filter-policy import
Use filter-policy import to configure RIPng to filter received routes.
Use undo filter-policy import to restore the default.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name } import
RIPng does not filter received routes.
RIPng view
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter received routes.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a string of 1 to 63 characters, to filter received routes.
· If the ACL does not exist or has no rules configured, all routes received by RIPng will match the ACL.
The source keyword specifies the destination address of a route and the destination keyword specifies the prefix of the route. For the configuration to take effect, specify a contiguous prefix.
# Use the IPv6 prefix list abc to filter received RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy prefix-list abc import
# Configure advanced IPv6 ACL 3000 to permit only route 2001::1/128 to pass. Use advanced IPv6 ACL 3000 to filter received routes.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy 3000 import
graceful-restart
Use graceful-restart to enable Graceful Restart (GR) for RIPng.
Use undo graceful-restart to disable RIPng GR.
graceful-restart
RIPng GR is disabled.
RIPng view
RIPng GR and RIPng NSR are mutually exclusive. Do not configure the graceful-restart command and the non-stop-routing command at the same time.
# Enable GR for RIPng process 1.
[Sysname] ripng 1
[Sysname-ripng-1] graceful-restart
graceful-restart interval
Use graceful-restart interval to set the GR interval.
Use undo graceful-restart interval to restore the default.
The GR interval is 60 seconds.
RIPng view
interval: Specifies the GR interval in the range of 5 to 360 seconds.
# Set the GR interval to 200 seconds for RIPng process 1.
[Sysname] ripng 1
[Sysname-ripng-1] graceful-restart interval 200
import-route
Use import-route to enable route redistribution.
Use undo import-route to disable route redistribution.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name ] *
undo import-route bgp4+
import-route { direct | static } [ cost cost-value | route-policy route-policy-name ] *
undo import-route { direct | static }
import-route { isisv6 | ospfv3 | ripng } [ process-id ] [ allow-direct | cost cost-value | route-policy route-policy-name ] *
undo import-route { isisv6 | ospfv3 | ripng } [ process-id ]
RIPng does not redistribute routes.
RIPng view
bgp4+: Redistributes BGP4+ routes.
direct: Redistributes direct routes.
isisv6: Redistributes IPv6 IS-IS routes.
ospfv3: Redistributes OSPFv3 routes.
ripng: Redistributes RIPng routes.
static: Redistributes static routes.
as-number: Specifies an AS by its number in the range of 1 to 4294967295. If you do not specify the as-number argument, this command redistributes all IPv6 EBGP routes. As a best practice, specify the AS number to avoid redistributing excessive IPv6 EBGP routes.
process-id: Specifies an OSPFv3, IPv6 IS-IS, or RIPng process by its ID in the range of 1 to 65535. The default is 1.
allow-ibgp: Allows redistribution of IBGP routes. The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command additionally redistributes IBGP routes and might cause routing loops. Therefore, use it with caution.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. If you do not specify this keyword, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a metric for redistributed routes, in the range of 0 to 16. The default metric is 0.
This command redistributes only active routes. To view route state information, use the display ipv6 routing-table protocol command.
# Redistribute routes from IPv6 IS-IS process 7 into RIPng and set the metric for redistributed routes to 7.
[Sysname] ripng 100
[Sysname-ripng-100] import-route isisv6 7 cost 7
maximum load-balancing
Use maximum load-balancing to set the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of RIPng ECMP routes equals the maximum number of ECMP routes, which is configurable by using the max-ecmp-num command.
RIPng view
number: Specifies the maximum number of ECMP routes. When this argument takes a value of 1, RIPng does not perform load balancing.
The value range for the number argument varies by ECMP mode. To configure the ECMP mode, use the ecmp mode command. Table 9 shows the value ranges for the number argument in various ECMP modes.
Table 9 Value ranges for the maximum number of RIPng ECMP routes in various ECMP modes
ECMP mode |
Value range |
Normal/Enhanced ECMP mode |
1 to 128 |
Compressed ECMP mode |
1 to 32 |
Other ECMP modes |
1 to 64 |
# Set the maximum number of ECMP routes to 2.
[Sysname] ripng 100
[Sysname-ripng-100] maximum load-balancing 2
non-stop-routing
Use non-stop-routing to enable RIPng NSR.
Use undo non-stop-routing to disable RIPng NSR.
non-stop-routing
RIPng NSR is disabled.
RIPng view
RIPng NSR enabled for a RIPng process takes effect only on that process. If multiple RIPng processes exist, enable RIPng NSR for each process as a best practice.
RIPng NSR and RIPng GR are mutually exclusive. Do not configure the non-stop-routing command and the graceful-restart command at the same time.
# Enable NSR for RIPng process 1.
[Sysname] ripng 1
[Sysname-ripng-1] non-stop-routing
output-delay
Use output-delay to set the RIPng packet sending interval and the maximum number of RIPng packets that can be sent at each interval.
Use undo output-delay to restore the default.
output-delay time count count
undo output-delay
A RIPng process sends a maximum of three RIPng packets every 20 milliseconds.
RIPng view
time: Specifies the RIPng packet sending interval in the range of 10 to 100 milliseconds.
count: Specifies the maximum number of RIPng packets sent by a RIPng process at each interval, in the range of 1 to 30.
If you configure the RIPng packet sending rate for both a RIPng process and an interface running the RIPng process, the configuration on the interface takes effect.
# Configure RIPng process 1 to send a maximum of 10 RIPng packets every 60 milliseconds.
[Sysname] ripng 1
[Sysname-ripng-1] output-delay 60 count 10
ripng output-delay
preference
Use preference to set the preference for RIPng routes.
Use undo preference to restore the default.
undo preference
The preference of RIPng routes is 100.
RIPng view
preference: Specifies the preference for RIPng routes, in the range of 1 to 255. The smaller the value, the higher the preference.
You can specify a routing policy to set a preference for the matching RIPng routes.
· The preference set by the routing policy applies to all matching RIPng routes. The preference of other routes is set by the preference command.
· If no preference is set by the routing policy, the preference of all RIPng routes is set by the preference command.
# Set the preference for RIPng routes to 120.
[Sysname] ripng 100
[Sysname-ripng-100] preference 120
reset ripng process
Use reset ripng process to restart a RIPng process.
reset ripng process-id process
After executing the command, you are prompted to confirm the operation.
# Restart RIPng process 100.
<Sysname> reset ripng 100 process
Reset RIPng process? [Y/N]:y
reset ripng statistics
Use reset ripng statistics to clear statistics for a RIPng process.
reset ripng process-id statistics
# Clear statistics for RIPng process 100.
<Sysname> reset ripng 100 statistics
ripng
Use ripng to enable RIPng and enter RIPng view.
Use undo ripng to disable RIPng.
ripng [ process-id ] [ vpn-instance vpn-instance-name ]
undo ripng [ process-id ]
RIPng is disabled.
process-id: Specifies a RIPng process by its ID in the range of 1 to 65535. The default value is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the RIPng process runs on the public network.
Before you configure global RIPng parameters, you must create a RIPng process. This restriction does not apply to configuring interface RIPng parameters.
If you disable a RIPng process, the configured RIPng parameters become invalid.
# Create RIPng process 100 and enter its view.
[Sysname] ripng 100
[Sysname-ripng-100]
ripng default-route
Use ripng default-route to configure a RIPng interface to advertise a default route with a specified metric.
Use undo ripng default-route to disable a RIPng interface from sending a default route.
ripng default-route { only | originate } [ cost cost-value | route-policy route-policy-name ] *
A RIPng process does not advertise a default route.
Interface view
only: Advertises only an IPv6 default route (::/0).
originate: Advertises an IPv6 default route (::/0) and other routes.
cost-value: Specifies a cost for the default route, in the range of 1 to 15. The default is 1.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The command advertises a default route only when a route in the routing table matches the routing policy.
This command enables the interface to advertise a RIPng default route in a route update regardless of whether the default route exists in the local IPv6 routing table.
A RIPng interface configured to advertise a default route does not receive any default routes from its neighbors.
# Configure RIPng on VLAN-interface 100 to advertise only a default route.
[Sysname-Vlan-interface100] ripng default-route only
# Configure RIPng on VLAN-interface 101 to advertise a default route and other routes.
[Sysname] interface vlan-interface 101
[Sysname-Vlan-interface101] ripng default-route originate
ripng enable
Use ripng enable to enable RIPng on an interface.
Use undo ripng enable to disable RIPng on an interface.
ripng process-id enable
undo ripng enable
RIPng is disabled on an interface.
Interface view
# Enable RIPng 100 on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng 100 enable
ripng metricin
Use ripng metricin to configure an interface to add a metric to inbound RIPng routes.
Use undo ripng metricin to restore the default.
ripng metricin value
undo ripng metricin
The additional metric of an inbound route is 0.
Interface view
value: Adds an additional metric to inbound routes, in the range of 0 to 16.
# Configure VLAN-interface 100 to add a metric of 12 to inbound RIPng routes.
[Sysname-Vlan-interface100] ripng metricin 12
ripng metricout
Use ripng metricout to configure an interface to add a metric to outbound RIPng routes.
Use undo ripng metricout to restore the default.
ripng metricout value
The additional metric of outbound routes is 1.
Interface view
value: Adds an additional metric to outbound routes, in the range of 1 to 16.
# Configure RIPng on VLAN-interface 100 to add a metric of 12 to outbound routes.
[Sysname-Vlan-interface100] ripng metricout 12
ripng output-delay
Use ripng output-delay to set the RIPng packet sending interval and the maximum number of RIPng packets that can be sent by an interface at each interval.
Use undo ripng output-delay to restore the default.
ripng output-delay time count count
An interface uses the RIPng packet sending rate set for the RIPng process that the interface runs.
Interface view
count: Specifies the maximum number of RIPng packets sent at each interval, in the range of 1 to 30.
If you set the RIPng packet sending rate for both a RIPng process and an interface running the RIPng process, the configuration on the interface takes effect.
# Configure VLAN-interface 100 to send a maximum of six RIPng packets every 30 milliseconds.
[Sysname-Vlan-interface100] ripng output-delay 30 count 6
output-delay
ripng poison-reverse
Use ripng poison-reverse to enable poison reverse.
Use undo ripng poison-reverse to disable poison reverse.
Poison reverse is disabled.
Interface view
# Enable poison reverse for RIPng update messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng poison-reverse
ripng primary-path-detect bfd echo
Use ripng primary-path-detect bfd echo to enable BFD single-hop echo detection for RIPng FRR.
Use undo ripng primary-path-detect bfd to disable BFD single-hop echo detection for RIPng FRR.
BFD single-hop echo detection is disabled for RIPng FRR.
Interface view
For quicker RIPng FRR, use BFD single-hop echo detection on the primary link of redundant links to detect link failure.
For correct operation of BFD, make sure the interface is configured with an IPv6 global unicast address before you exeucte this command. For more information about IPv6 global unicast addresses, see Layer 3—IP Services Configuration Guide.
# Enable BFD single-hop echo detection for RIPng FRR on VLAN-interface 10.
[Sysname] ripng 1
[Sysname-ripng-1] fast-reroute route-policy frr
[Sysname-ripng-1] quit
[Sysname] bfd echo-source-ipv6 1::1
[Sysname-Vlan-interface10] ripng primary-path-detect bfd echo
ripng split-horizon
Use ripng split-horizon to enable split horizon.
Use undo ripng split-horizon to disable split horizon.
ripng split-horizon
Split horizon is enabled.
Interface view
Split horizon prevents routing loops. If you want to disable this feature, make sure the operation is indispensable.
If both poison reverse and split horizon are enabled, only poison reverse takes effect.
# Enable split horizon on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng split-horizon
ripng summary-address
Use ripng summary-address to configure a summary network to be advertised through an interface.
Use undo ripng summary-address to remove a summary network.
ripng summary-address ipv6-address prefix-length
undo ripng summary-address ipv6-address prefix-length
No summary network is configured to be advertised through an interface.
Interface view
ipv6-address: Specifies the destination IPv6 address of the summary route.
prefix-length: Specifies the prefix length of the destination IPv6 address of the summary route, in the range of 0 to 128. It indicates the number of consecutive 1s of the prefix, which defines the network ID.
Networks on the summary network will not be advertised. The cost of the summary route is the lowest cost among summarized routes.
# Assign an IPv6 address with the 64-bit prefix to VLAN-interface 100 and configure a summary with the 35-bit prefix.
[Sysname-Vlan-interface100] ipv6 address 2001:200::3EFF:FE11:6770/64
[Sysname-Vlan-interface100] ripng summary-address 2001:200:: 35
timer triggered
Use timer triggered to set the interval for sending triggered updates.
Use undo timer triggered to restore the default.
The maximum, minimum, and incremental intervals for sending triggered updates are 5 seconds, 50 milliseconds, and 200 milliseconds, respectively.
RIPng view
Predefines user roles
maximum-interval: Specifies the maximum interval for sending triggered updates, in the range of 1 to 5 seconds.
minimum-interval: Specifies the minimum interval for sending triggered updates, in the range of 10 to 5000 milliseconds.
incremental-interval: Specifies the incremental interval for sending triggered updates, in the range of 100 to 1000 milliseconds.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
For a stable network, the minimum interval is used. If network changes become frequent, the incremental interval incremental-interval is used to increase the triggered update sending interval until the maximum-interval is reached.
# Set the maximum, minimum, and incremental intervals for sending triggered updates to 2 seconds, 100 milliseconds, and 100 milliseconds, respectively.
[Sysname] ripng 100
[Sysname-ripng-100] timer triggered 2 100 100
timers
Use timers to set RIPng timers.
Use undo timers to restore the default.
undo timers { garbage-collect | suppress | timeout | update } *
The garbage-collect timer is 120 seconds, the suppress timer is 120 seconds, the timeout timer is 180 seconds, and the update timer is 30 seconds.
RIPng view
garbage-collect-value: Sets the garbage-collect timer in the range of 1 to 86400 seconds.
suppress-value: Sets the suppress timer in the range of 0 to 86400 seconds.
timeout-value: Sets the timeout timer in the range of 1 to 86400 seconds.
update-value: Sets the update timer in the range of 1 to 86400 seconds.
RIPng has the following timers:
· Update timer—Interval between update messages.
· Timeout timer—Route aging time. If no update for a route is received before the timer expires, RIPng sets the metric of the route to 16.
· Suppress timer—How long a RIPng route stays in suppressed state. When the metric of a route becomes 16, the route enters the suppressed state. If RIPng receives an update for the route from the same neighbor and the route in the update has a metric less than 16, RIPng uses the route to replace the suppressed route.
· Garbage-collect timer—Interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIPng advertises the route with a metric of 16. If no update is announced for that route before the garbage-collect timer expires, RIPng deletes the route from the routing table.
As a best practice, do not change the default values of these timers.
The timer lengths must be kept consistent on all routers in the network.
# Set the update, timeout, suppress, and garbage-collect timers to 5 seconds, 15 seconds, 15 seconds, and 30 seconds.
[Sysname] ripng 1
[Sysname-ripng-1] timers update 5 timeout 15 suppress 15 garbage-collect 30
