01-Text | 2.48 MB |
1.1.1 General Operating Safety
1.3.1 Preventing Electrostatic Discharge
1.3.2 Grounding Methods to Prevent Electrostatic Discharge
2 Overview of the BT1004E Ethernet Cascading Module
2.5.1 Connections Between Cascading Modules and Mezz NICs of the Blade Server
2.5.2 Connections Between Cascading Modules and Mezz NIC Ports of the Blade Server
2.5.3 Connections Between Cascading Module Ports and Blade Servers
3.1 Compatibility Between Cascading Modules and Mezz NICs
3.2 Compatibility Between Cascading Modules and Optical Modules
3.3 External Networking Connection
4 Replacing the Cascading Module
5 Powering On and Powering Off
5.1 Powering On the Straight-Through Module
5.2 Powering Off the Straight-Through Module
6 Checking the Cascading Module
6.1 Checking the State of the Cascading Module Port Through OM
6.1.2 Viewing through the OM CLI
7 Configuring the Cascading Module
7.1.1 Changing Through the OM Web UI
7.1.2 Changing Through the OM CLI
1 Safety
1.1 Safety Information
To avoid personal injury or damage to the device, read the following information carefully before you operate the device. Safety precautions in actual operation include but are not limited to safety information mentioned in this document.
· Only H3C authorized or professional engineers are allowed to operate the device.
· Keep the device clean and dust-free. Do not place it in a humid place or allow liquids to enter it.
· Before powering on the device, ensure that the blade enclosure is securely grounded.
· To maintain sufficient heat dissipation, use filler panels on idle slots.
1.1.2 Electrical Safety
· Carefully check any potential hazards in the work area, for example, whether the ground is wet and whether the blade enclosure is grounded or reliably grounded.
· Do not work alone when performing live-line maintenance.
· Do not touch the power supply directly or indirectly through conductive objects to prevent electric shock.
1.2 Safety Precautions
· When maintaining the device, place the device on a clean, stable table or floor.
· To avoid personal injury from hot surfaces or internal components, allow the device and its internal components to cool before touching them.
· When using tools to maintain the device, follow the correct operation methods to avoid damage to the personnel or device.
· When connecting, testing or replacing optical fibers, do not look directly into the optical fiber outlet to prevent the laser beam from hurting your eyes.
· Gently and slowly transport or place the device with force evenly distributed.
1.3 ESD Prevention
Electrostatic charges that build up on people and conductors damage or shorten the lifespan of the main board and electrostatic-sensitive components.
To prevent electrostatic damage, follow these guidelines:
· Transport or store the device in an ESD bag.
· Place the device on a grounded table before taking it out of the ESD bag.
· Avoid touching pins or circuitry of the device without taking any ESD prevention measures.
When removing or installing the device, you can use one or multiple of the following grounding methods to prevent electrostatic discharge:
· Wear an ESD wrist strap and ensure that it is reliably grounded. Ensure that the ESD wrist strap makes good skin contact and can be flexibly stretched out and draw back.
· In the work areas, wear the ESD clothing and shoes.
· Use conductive field service tools.
· Use a portable field service kit with a folding ESD tool mat.
· Hardware images shown in this manual are for illustration purposes only. The actual product may vary.
· The software UI may be updated from time to time. Please refer to the actual product UI.
· ICMs supported by the chassis are classified into switching modules and straight-through modules (also known as cascading modules in some manuals). BT1004E is a type of cascading module. The ICM module, straight-through module, and cascading module mentioned in this document refer to the BT1004E Ethernet cascading module.
Product Overview
H3C UniServer BT1004E is an Ethernet cascading module for the H3C UniServer B16000 blade chassis (4*(4*25 GE)). It provides an external data interface, which enables direct connection of parallel cables to the Ethernet Mezz NIC port of the blade server. BT1004E is applicable to the high-density scale-out networking solution for B16000. By cascading to ToR switches, BT1004E provides unified multi-frame deployment management. For details, see Deployment Guide for the H3C UniServer B16000 High-density Scale-out Networking.
Unlike switching modules, cascading modules only transmit data between blade servers and external networks without the need to process the data.
· The cascading module has four QSFP28 ports, each of which can be split into four logical ports. The port speed is 10 Gb or 25 Gb, which can be switched through the OM management software.
Figure 2-1 shows the appearance of the BT1004E.
Figure 2-1 Appearance of BT716F
2.2 Specifications
Table 2-1 describes the specifications of the cascading module.
Category |
Item |
Physical specifications |
Dimensions |
27 mm x 491.6 mm x 296.5 mm |
Maximum weight |
3.32 kg |
Power consumption |
Maximum power consumption |
25 W |
Environment specifications |
Temperature |
· Operating temperature: 5°C to 45°C · Storage temperature: -40°C to 70°C |
· Operating humidity: 8% to 90% (non-condensing) · Storage humidity: 5% to 95% (non-condensing) |
· Operating altitude: -60 m to +5000 m (The allowed maximum temperature decreases by 0.33 °C as the altitude increases by 100 m from 900 m) · Storage altitude: –60 m to +5000 m |
2.3 Port
This section describes positions, quantity, numbering rules about the ports of the cascading module and the mapping between these ports and slots of blade servers.
2.3.1 Port Description
Figure 2-3 shows the external ports provided by the cascading module. Table 2-2 describes specific functions of the external ports.
Figure 2-2 External ports
(1): AMC serial port |
(2): 4*25 GE optical ports |
Table 2-2 Description of external ports
SN |
Port Name |
Type |
Quantity |
Port No. |
1 |
AMC serial port |
RJ-45 |
1 |
Serial port used to enter the AMC CLI. The baud rate is 115200 bit/s. It is only used by technical support engineers to display the states of the optical ports and to perform subsequent maintenance. |
2 |
QSFP28 |
4 |
Four physical ports ranging from 1 to 4. 16 logical ports ranging from 1 to 16. |
· Each QSFP28 port can be split into four logical ports. Four QSFP28 ports can be split into 16 logical ports ranging from 1 to 16. The port speed is 10 Gb or 25 Gb, which can be switched through the OM management software. · For the mapping between the cascading module ports and the blade servers, see 2.5.3 Connections Between Cascading Module Ports and Blade Servers. · For the optical modules supported by each port, see 3.2 Compatibility Between Cascading Modules and Optical Modules. For the method of changing port rate, see 7.1 Port Rate Switching. |
2.3.2 Port Numbering Rules
As shown in Figure 2-3, the numbering rules for the cascading module ports are defined as "A/B/C" on the OM Web page.
· A: Defaults to 1; cannot be edited.
· B: Indicates an internal or external port. 0 indicates an internal port, and 1 indicates an external port. The cascading module does not have an internal port, so this item number is 1.
· C: Indicates the sequence number of the cascading module ports. Every four ports constitute a group, which corresponds to one external QSFP28 port.
Figure 2-3 Port Numbering Rules
2.4 Indicators
Table 2-3 shows information relating to indicators on the cascading module.
Figure 2-4 Indicators
The 16 logical ports of the cascading module correspond to 16 service port indicators. The service port indicator whose silkscreen is 1 corresponds to Port 1 and the service port indicator whose silkscreen is 2 corresponds to Port 2, and so on. The appearance and meaning of 16 indicators are identical. The figure takes one port indicator for illustration. |
Table 2-3 Description of indicators
SN |
Name |
Color |
Status |
1 |
UID indicator |
Blue |
· Steady on blue: The UID indicator is activated (through the OM module). · Off: The UID indicator is not activated. |
2 |
RUN indicator (RUN) |
Green |
· Steady on green/off: The system is faulty. · Blinking green (at a frequency of 4 Hz): The system is loading data. · Blinking green (at a frequency of 1 Hz): The system is running normally. |
3 |
Red/Green |
· Steady on green: The cascading module is running normally. · Blinking red (1 Hz): The cascading module generates an alarm. · Off: The cascading module is not powered on or in position. |
4 |
Service port 1 indicator |
Yellow/Green |
· Steady on green: The high-speed port link is connected, but no data is received and sent. · Blinking green (1 Hz): The high-speed port link is connected, and data is being received or sent. · Steady on yellow: The low-speed port link is connected, but no data is received and sent. · Blinking yellow (1 Hz): The low-speed port link is connected, and data is being received or sent. · Off: The port link is not connected. |
2.5 Internal Connection
To ensure access to the target blade server through the external ports of the cascading module, the user needs to obtain the following information:
· Slots where the cascading module or Mezz NICs should be placed before installing the cascading module or Mezz NICs of the blade server. For details, see 2.5.1 Connections Between Cascading Modules and Mezz NICs of the Blade Server;
· Mapping between Mezz NIC ports and the cascading module before configuring Mezz NICs of the blade server. For details, see 2.5.2 Connections Between Cascading Modules and Mezz NIC Ports of the Blade Server;
· Connection between the cascading module ports and the target blade server before accessing the blade server through the cascading module. For details, see 2.5.3 Connections Between Cascading Module Ports and Blade Servers.
Table 2-4 describes connections between cascading modules and Mezz NICs, helping you accurately choose slots for installing the cascading modules.
Table 2-4 Connections between cascading modules and Mezz NICs of the blade server
Model of Blade Server |
Maximum Number of Supported Mezz NICs |
Connections between cascading modules and Mezz NICs of the blade server |
H3C UniServer B5700 G5 |
3 |
H3C UniServer B5700 G3 |
3 |
H3C UniServer B7800 G3 |
6 |
H3C UniServer B5800 G3 |
3 |
1. Mode 1
For blade servers that support up to three Mezz NICs, the connections between cascading modules and Mezz NICs of the blade server are shown in Figure 2-5. Where:
· The onboard NIC is connected to the active and standby OM modules.
· Mezz NIC 1 is connected to cascading modules in slot 1 and slot 4.
· Mezz NIC 2 is connected to cascading modules in slot 2 and slot 5.
· Mezz NIC 3 is connected to cascading modules in slot 3 and slot 6.
Figure 2-5 Connections between cascading modules and Mezz NICs of the blade server enclosure (1)
2. Mode 2
For blade servers that support up to six Mezz NICs, the connections between cascading modules and Mezz NICs of the blade server are shown in Figure 2-6. Where:
· Mezz NIC 1 and Mezz NIC 4 are connected to cascading modules in slot 1 and slot 4.
· Mezz NIC 2 and Mezz NIC 5 are connected to cascading modules in slot 2 and slot 5.
· Mezz NIC 3 and Mezz NIC 6 are connected to cascading modules in slot 3 and slot 6.
Figure 2-6 Connections between cascading modules and Mezz NICs of the blade server enclosure (2)
For connections between cascading modules and Mezz NIC ports, check through the Networking query tool.
Table 2-5 shows the connections between external ports of cascading modules and blade servers.
Table 2-5 Connections between external ports of cascading modules and blade servers
Connections between external ports of cascading modules and blade servers |
Half-width single-height blade server |
3 |
See 2.5.3 1. Connections between external ports of cascading modules and half-width single height blade servers. |
Full-width single-height blade server |
6 |
For details, see 2.5.3 2. Connections between external ports of cascading modules and full-width single height blade servers (supporting up to six Mezz NICs). |
3 |
For details, see 2.5.3 3. Connections between external ports of cascading modules and full-width single height blade servers (supporting up to three Mezz NICs). |
When the full-width single height blade server and the half-width single height blade server exist together in the same enclosure, check the external ports of cascading modules according to the type of the blade server configured for each slot. |
Figure 2-3 shows ports on the panel of the cascading module. Four QSFP28 ports can provide 16 ports ranging from 1 to 16. Figure 2-7 shows the 16 slots of the half-width single-height blade server installed in the front slots of the blade server chassis. The slots are numbered 1 to 16.
Figure 2-7 Numbering of slots for the half-width single-height blade server
As shown in Figure 2-8, when the half-width single height blade servers are configured in the front of the enclosure, the external ports of the cascading module correspond to the 16 blade servers respectively. Specifically, Port 1 is connected to the blade server 1, which allows users to access the blade server 1 through Port 1. Port 2 is connected to the blade server 2, which allows users to access the blade server 2 through Port 2, and so on.
· For the connections between cascading modules and Mezz NICs of the blade server, see 2.5.1 Connections Between Cascading Modules and Mezz NICs of the Blade Server.
· For the specific Mezz NIC port on the blade server connected to the cascading module, check through the Networking query tool.
Figure 2-3 shows ports on the panel of the cascading module. Four QSFP28 ports can provide 16 ports ranging from 1 to 16. Figure 2-9 shows the slots for the 8 full-width single-height blade servers installed in the front slots of the blade server chassis. They are numbered 1, 3, 5, 7, 9, 11, 13, and 15.
Figure 2-9 Numbering of slots for the full-width single-height blade server
As shown in Figure 2-10, when the full-width single height blade servers (supporting up to six Mezz NICs) are configured in the front of the enclosure, every two external ports of the cascading module correspond to one full-width single height blade server. Specifically, Port 1 and Port 2 are connected to the blade server 1, which allows users to access the blade server 1 through Port 1 or Port 2. Port 3 and Port 4 are connected to the blade server 3, which allows users to access the blade server 3 through Port 3 or Port 4, and so on.
When the full-width single-height blade server that supports up to 3 Mezz NICs is installed in the front slots of the chassis:
· As shown in Figure 2-11, cascading modules in slots 1, 3, 4, and 6 are connected to blade servers through odd-numbered ports. Specifically, Port 1 is connected to the blade server 1, which allows users to access the blade server 1 through Port 1. Port 3 is connected to the blade server 3, which allows users to access the blade server 3 through Port 3, and so on.
· As shown in Figure 2-12, cascading modules in slots 2 and 5 are connected to blade servers through even-numbered ports. Specifically, Port 2 is connected to the blade server 1, which allows users to access the blade server 1 through Port 2. Port 4 is connected to the blade server 3, which allows users to access the blade server 3 through Port 4, and so on.
Figure 2-11 Logical diagram for connections between external ports of cascading modules in slots 1, 3, 4, and 6 and full-width single height blade servers (supporting up to three Mezz NICs)
2.6 Logical Structure
Figure 2-13 shows two modules in the logical structure of the cascading module.
· AMC unit: As the management unit of the cascading module, the AMC unit is mainly responsible for board data collection and reporting, board power-on/off control, and system monitoring.
· PHY unit: As the data transmission unit of the cascading module, the PHY unit provides a connection channel between the NIC ports of the blade server and the external ports of the cascading module to implement transparent transmission between the NIC ports of the blade server and the external network.
2.7 Installation Guidelines
· As shown in Figure 2-14, up to six cascading modules can be installed in the blade enclosure. The slots to install those modules are ICM1 – ICM6.
· The cascading module supports hot swapping.
· Figure 2-5 and Figure 2-6 describe connections between cascading modules and Mezz NICs, helping you accurately choose slots for installing the cascading modules.
Figure 2-14 Guidelines for installing the cascading module
(1): ICM1 slot |
(2): ICM2 slot |
(3): ICM3 slot |
(4): ICM4 slot |
(5): ICM5 slot |
(6): ICM6 slot |
3 Hardware Compatibility
This section describes the compatibility between cascading modules and Mezz NICs and the compatibility between cascading modules and optical modules.
Table 3-1 describes the compatibility between the cascading module and the Mezz NIC.
Table 3-1 Mezz NIC compatible with BT1004E
Mezz NIC Model |
Port Quantity |
NIC-ETH522i-Mb-2*10G |
2 |
2-Port 10Gb CNA Mezz NIC |
NIC-ETH640i-Mb-2*25G |
2 |
2-Port 25Gb Ethernet Mezz NIC |
NIC-ETH681i-Mb-2*25G |
2 |
NIC-ETH682i-Mb-2*25G |
2 |
2-Port 25Gb CNA Mezz NIC |
Table 3-2 describes the compatibility between the cascading module and the optical module.
Table 3-2 Optical modules/cables compatible with BT1004E
Module/ Cable Type |
Module/Cable Name |
Center Wavelength |
Module Port Connector Type |
Cable Specifications |
Maximum Transmission Distance |
QSFP+ optical module |
QSFP-40G-SR4-MM850-CM |
850 nm |
MPO |
50/125µm multi-mode fiber |
150 m |
QSFP-40G-SR4-MM850 |
150 m |
QSFP-40G-CSR4-MM850-CM |
400 m |
QSFP-40G-CSR4-MM850 |
400 m |
QSFP28 optical module |
QSFP-100G-SR4-MM850-CM |
850 nm |
MPO |
100 m |
QSFP-100G-SR4-MM850 |
100 m |
QSFP+ cable |
QSFP-40G-3M-CM |
QSFP+ cable |
3 m |
QSFP-40G-5M-CM |
5 m |
QSFP+ optical cable |
QSFP-40G-D-AOC-7M-CM |
7 m |
QSFP-40G-D-AOC-7M |
7 m |
QSFP-40G-D-AOC-10M-CM |
10 m |
QSFP-40G-D-AOC-10M |
10 m |
QSFP-40G-D-AOC-20M-CM |
20 m |
QSFP-40G-D-AOC-20M |
20 m |
QSFP28 cable |
QSFP-100G-D-CAB-3M |
QSFP28 cable |
3 m |
QSFP-100G-D-CAB-3M-CM |
3 m |
QSFP28 to 4*SFP28 cable |
QSFP-100G-4SFP-25G-CAB-3M-CM |
3 m |
QSFP-100G-4SFP-25G-CAB-3M |
3 m |
QSFP-100G-4SFP-25G-CAB-5M-CM |
5 m |
QSFP-100G-4SFP-25G-CAB-5M |
5 m |
· QSFP-100G-4SFP-25G-CAB-3M-CM, QSFP-100G-4SFP-25G-CAB-3M, QSFP-100G-4SFP-25G-CAB-5M-CM, and QSFP-100G-4SFP-25G-CAB-5M cables are used to connect one 100G QSFP28 port to four 25G SFP28 ports. The 100 GE port is split into four 25 GE ports for use. QSFP-40G-SR4-MM850-CM, QSFP-40G-SR4-MM850, QSFP-40G-CSR4-MM850-CM, and QSFP-40G-CSR4-MM850 modules allow each port to be split to four. They can be used to connect one 40G QSFP+ port to four 10G SFP+ ports. The 100 GE port is split into four 10 GE ports for use. The connected QSFP+ modules and SFP+ modules must have the same specifications (including center wavelength and optical cable type). |
· H3C SFP/SFP+ modules are recommended as cascading modules.
· The types of H3C SFP/SFP+ modules may change over time. If you need accurate information about module types, consult H3C marketing or technical support personnel.
· For specific specifications of each optical module, see H3C Transceiver Modules User Guide.
· When installing optical modules and cables, wear ESD wrist straps. For installation methods and precautions, see the H3C Optical Module and Cable Installation Guide.
The cascading modules allow transparent transmission of data between blade servers and the external network.
Depending on the types of Mezz NICs configured on the blade server, the blade server can be connected to different external networks through external ports of cascading modules, as shown in Figure 3-1.
Figure 3-1 Connecting a blade server to an external network through cascading modules
BT1004E can be applied to the high-density scale-out networking solution for B16000. For details, see Deployment Guide for the H3C UniServer B16000 High-density Scale-out Networking.
4.1 Scenario
· The cascading module is faulty.
· The straight-through module needs to be replaced by a switching module or straight-through module in another model.
4.2 Installation Tools
The following tools or devices may be required when you install, use, and maintain the equipment.
Image |
Name |
Diagonal pliers |
Used to clip insulating sleeves and binding straps |
Multimeter |
Used to measure resistance and voltage and check the circuitry |
ESD wrist strap |
Used for installing, removing, or maintaining the equipment |
ESD gloves |
ESD clothing |
Ladder |
Used for high-altitude operations |
Port cable (such as an Ethernet cable or optical fiber) |
Used to connect the equipment with the external network |
Login device (such as a PC) |
Used to log in to the equipment |
4.3 Preparations
· Take ESD preventive measures: Wear the ESD clothing. Properly wear and ground the ESD wrist strap. Remove conductive objects (such as jewelry or watch).
· Before replacing a component, check the slots and connectors, and ensure that the pins are not damaged (for example, check whether pins are deformed or whether foreign objects are on the connectors).
· Understand the guidelines for installing the cascading module, as described in 2.7 .
4.4 Replacement Procedure
For specific procedures, see http://www.h3c.com/cn/home/qr/default.htm?id=354.
(1) Remove the cascading module. Press the unlock button on the cascading module to fully open the ejector, and slowly pull the cascading module out of the chassis horizontally.
(2) Put the cascading module into the ESD bag.
(3) Install the cascading module. Take the cascading module out from the ESD bag.
(4) Press the unlock button to automatically open the ejector.
(5) Slowly insert the cascading module into the blade enclosure horizontally with UP facing upwards, and then lock the ejector.
This section describes how to power on/off the cascading module.
The cascading module is energized by the blade enclosure. After the cascading module is successfully powered on, the Health indicator is steady on green. For specific positions of indicators, see 2.4 2.4 Indicators.
· If the cascading module is pre-installed, it is automatically energized when the blade enclosure is powered on by an external power supply. You do not need to perform any operation.
The cascading module is automatically powered off with the blade enclosure without any manual intervention. Upon successful power-off, the Health indicator is off. For specific location of the indicator, see 2.4 2.4 Indicators.
For ease of understanding, the data in this section is only for reference. During operation, the actual data should prevail.
Table 6-1 shows how to check the port connection state of BT1004E through OM.
Table 6-1 Methods for viewing the port status
Port Status |
Method |
Port connection status |
Method 1: Viewing through the OM web UI |
Method 1: Viewing through the OM CLI |
1. Viewing through the OM web UI
2. Prerequisites
Before checking the port connection state of the cascading module through OM Web, ensure that the following work is completed:
· The cascading module has been powered on. For details, see 5.1 5.1 Powering On the Straight-Through Module.
· Log in to the web UI of the OM module. For details, see 7.1.1 Logging into the OM Web.
3. Procedures
(1) Under the Interconnection Module Management tab, select the cascading module to be viewed, and click Port Mapping to enter the page.
(2) Click a port number to view the information about the corresponding port.
· When the port status is "up", the position of the port will be shown in "green" in the Port Mapping area.
· In the "Port Summary" area, you can view all ports that are currently in the "up" status and relevant information about the ports.
1. Prerequisites
Before checking the port connection state of the cascading module through OM CLI, ensure that the following work is completed:
· Log in to the OM CLI: See 7.1.2 Logging In to the CLI of OM Module.
2. Procedures
(1) Run the display io port command to check the state of the cascading module port. This section takes the port of the cascading module in slot 1 for illustration.
<OM>display io port io 1
Internal connectors :
Interface Status Input speed(kbps) Output speed(kbps)
External ports :
WGE1/1/1 Down N/A N/A
WGE1/1/2 Down N/A N/A
WGE1/1/3 Down N/A N/A
WGE1/1/4 Down N/A N/A
WGE1/1/5 Down N/A N/A
WGE1/1/6 Down N/A N/A
WGE1/1/7 Down N/A N/A
WGE1/1/8 Down N/A N/A
WGE1/1/9 Down N/A N/A
WGE1/1/10 Down N/A N/A
WGE1/1/11 Down N/A N/A
WGE1/1/12 Down N/A N/A
WGE1/1/13 Down N/A N/A
WGE1/1/14 Down N/A N/A
WGE1/1/15 Down N/A N/A
WGE1/1/16 Down N/A N/A
<OM>
You can switch the port rate of the cascading module on the OM Web page.
1. Prerequisites
Before switching the port rate of the cascading module on the OM Web page, ensure that the following work is completed:
· Log in to the OM web: See 7.1.1 Logging into the OM Web.
2. Procedures
(1) Click Interconnection Module Management, select the target cascading module, and click Port Mapping > External Port.
(2) In "Port Mapping View", select the external port of which the port rate is to be changed.
(3) In the "Rate Configuration" parameter column, select a required port rate, and click "OK" to complete the rate change.
Notes
· Please set the rate of the matching external port of the cascading module according to the rate of the optical module. Otherwise, the status of the external port of the cascading module cannot be "UP". For example, when an external port is installed with a 10G optical module, the external port rate needs to be set to 10G.
· For BT1004E, if the rate of one port is switched, the OM module will automatically switch the rates of the four ports in the same group.
· When the rate of a port is set to "auto", the port will, based on the optical module it identifies, automatically switch to a port rate that is the same as the optical module.
· By default, the port rate of BT1004E is configured as Auto.
Run the port-speed command to switch the port rate of the cascading module on the OM CLI page.
1. Prerequisites
Before switching the port rate of the cascading module on the OM CLI page, ensure that the following work is completed:
· The cascading module has been powered on. For details, see 5.1 Powering On the Straight-Through Module.
· Log in to the OM CLI: See 7.2.2 Logging In to the CLI of OM Module.
2. Procedures
Run the port-speed command on the OM CLI page and set the port rate of port 3 of the cascading module in slot 1 to 25 Gbps.
<OM>port-speed 25G port-id 3 io 1
Notes
· The port rate of BT1004E can be set to 10 Gbps, 25 Gbps, and Auto.
7.2 Common Operations
7.2.1 Logging into the OM Web
1. Prerequisites
· Power on the chassis.
· Obtain the login data of OM module. The default login data of the OM web is shown in Table 7-1.
Data |
Management IP address of the OM module |
· Management IP address (default): 192.168.100.100 · Subnet mask (default): 255.255.255.0 |
User name and password used to log in to the OM module |
· User name (default): admin · Password (default): Password@_ |
2. Procedures
(1) Ensure that the IP addresses of the PC and OM module are accessible on L3.
Figure 7-1 Logging in to OM Web page (1)
(2) As shown in Figure 7-2 ①, open the browser on PC and enter login IP address of the OM Web page (format: https://OM_ip_address). As shown in ②, enter the admin user name and password. As shown in ③, click Login.
Figure 7-2 Logging in to OM Web page (2)
1. Prerequisites
· Obtain the login data of the OM module. The default login data of the OM CLI is shown in Figure 7-3.
2. Procedures
(1) Connect the Ethernet port of the PC to the "MGMT" port of the primary and backup OM modules via LAN, as shown in Figure 7-3. Ensure that the IP addresses of the PC and OM module are accessible on L3.
Figure 7-3 Setting up the hardware environment
(2) Set the login parameters and log in to the OM CLI using the remote access software. Figure 7-3 lists the login parameters.
Table 7-2 SSH login parameters
Parameter |
Value |
Protocol |
SSH |
Port number |
22 |
· The SSH access mode is enabled for the OM module by default. |
(1) After login, the OM CLI displays the login page, as shown below.
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<OM>
8 Firmware Upgrade
For specific procedures, see the H3C UniServer B16000 Blade Enclosure Upgrade Guide.
