08-ACL and QoS Command Reference
HomeSupportSwitchesS5590-EI SeriesReference GuidesCommand ReferencesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Command References-R6010Pxx-6W10008-ACL and QoS Command Reference
03-Data buffer commands
03-Data buffer commands 68.50 KB
buffer packet-drop alarm enable
Use buffer packet-drop alarm enable to enable packet-drop alarms.
Use undo buffer packet-drop alarm enable to disable packet-drop alarms.
Packet-drop alarms are disabled.
The device generates and reports packet-drop alarms to a network management system (such as IMC) for displaying the data buffer usage.
This command does not take effect only on the Headroom buffer.
# Enable packet-drop alarms.
[Sysname] buffer packet-drop alarm enable
buffer usage threshold queue (interface view)
buffer packet-drop alarm interval
Use buffer packet-drop alarm interval to set the interval for sending packet-drop alarms.
Use undo buffer packet-drop alarm interval to restore the default.
buffer packet-drop alarm interval interval
The interval for sending packet-drop alarms is 5 seconds.
interval: Specifies the interval for sending packet-drop alarms, in the range of 0 to 60 seconds. The value of 0 indicates that packet-drop alarms are sent immediately after they are generated.
This command takes effect only when packet-drop alarms are enabled.
# Set the interval for sending packet-drop alarms to 20 seconds.
[Sysname] buffer packet-drop alarm interval 20
buffer threshold alarm enable
Use buffer threshold alarm enable to enable threshold-crossing alarms.
Use undo buffer threshold alarm enable to disable threshold-crossing alarms.
buffer threshold alarm { egress | headroom | ingress } enable
undo buffer threshold alarm { egress | headroom | ingress } enable
Threshold-crossing alarms are disabled.
ingress: Specifies the ingress buffer.
headroom: Specifies the Headroom buffer.
egress: Specifies the egress buffer.
The device generates and reports threshold-crossing alarms to a network management system (such as IMC) for displaying the data buffer usage.
# Enable threshold-crossing alarms.
[Sysname] buffer threshold alarm ingress enable
buffer usage threshold headroom
buffer threshold alarm interval
Use buffer threshold alarm interval to set the interval for sending threshold-crossing alarms.
Use undo buffer threshold alarm interval to restore the default.
buffer threshold alarm { egress | headroom | ingress } interval interval
undo buffer threshold alarm { egress | headroom | ingress } interval
The interval for sending threshold-crossing alarms is 5 seconds.
interval: Specifies the interval for sending threshold-crossing alarms, in the range of 0 to 60 seconds. 0 indicates that threshold-crossing alarms are sent immediately after they are generated.
This command takes effect only when threshold-crossing alarms are enabled.
# Set the interval for sending threshold-crossing alarms to 20 seconds.
[Sysname] buffer threshold alarm ingress interval 20
Use buffer usage threshold headroom to set the global per-queue alarm threshold for the Headroom buffer.
Use undo buffer usage threshold headroom to restore the default.
buffer usage threshold headroom slot slot-number ratio ratio
undo buffer usage threshold headroom slot slot-number ratio
The global per-queue alarm threshold for the Headroom buffer is 100%.
slot slot-number: Specifies an IRF member device by its member ID (slot number).
ratio ratio: Specifies the alarm threshold in percentage, in the range of 1 to 100.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global alarm threshold for the Headroom buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
#  Set the global per-queue alarm threshold to 50% for slot 1.
[Sysname] buffer usage threshold headroom slot 1 ratio 50
buffer usage threshold null-queue
Use buffer usage threshold null-queue to set the global per-interface alarm threshold for the ingress or egress buffer.
Use undo buffer usage threshold null-queue to restore the default.
buffer { egress | ingress } usage threshold slot slot-number null-queue ratio ratio
undo buffer { egress | ingress } usage threshold slot slot-number null-queue ratio
The global per-queue alarm threshold for the ingress or egress buffer is 100%.
When the alarm threshold is exceeded, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
If you configure both the global alarm threshold and the alarm threshold on an interface, the latter takes effect.
If you configure this command multiple times, the most recent configuration takes effect.
# Set the global per-interface alarm threshold to 50% in slot 1.
[Sysname] buffer ingress usage threshold slot 1 interface ratio 50
port buffer usage threshold null-queue
Use buffer usage threshold queue to set the ingress or egress buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold queue to restore the default.
buffer egress usage threshold queue queue-id ratio ratio
undo buffer egress usage threshold queue queue-id ratio
The egress buffer alarm threshold for a queue on an interface is 100%.
Interface view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold for the egress buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the egress buffer alarm threshold to 50% for queue 1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] buffer egress usage threshold queue 1 ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·     Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
port buffer usage threshold headroom null-queue
Use port buffer usage threshold headroom null-queue to set the per-interface alarm threshold for the Headroom buffer.
Use undo port buffer usage threshold headroom null-queue to restore the default.
port buffer usage threshold headroom null-queue ratio ratio
undo port buffer usage threshold headroom null-queue ratio
The global alarm threshold for the Headroom buffer is used.
This command takes effect only when threshold-crossing alarms are enabled. When the global alarm threshold for the Headroom buffer is exceeded, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the alarm threshold to 50% on GigabitEthernet1/0/1.
[Sysname–GigabitEthernet1/0/1] port buffer usage threshold headroom null-queue ratio 50
Use port buffer usage threshold null-queue to set the per-interface alarm threshold for the ingress or egress buffer.
Use undo port buffer usage threshold null-queue to restore the default.
port buffer { egress | ingress } usage threshold null-queue ratio ratio
undo port buffer { egress | ingress } usage threshold null-queue ratio
The global alarm threshold for the ingress or egress buffer is used.
[Sysname-GigabitEthernet1/0/1] port buffer ingress usage threshold null-queue ratio 50
