05-Layer 3—IP Routing Command Reference
HomeSupportSwitchesS5590-EI SeriesReference GuidesCommand ReferencesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Command References-R6010Pxx-6W10005-Layer 3—IP Routing Command Reference
02-Static routing commands
02-Static routing commands 127.57 KB
delete static-routes all
Use delete static-routes all to delete all static routes.
delete [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all static routes for the public network.
CAUTION
CAUTION:
Deleting all static routes with caution. This operation might cause network connectivity failure and packet forwarding failure.
When you use this command, the system will prompt you to confirm the operation before deleting all the static routes.
To delete one static route, use the undo ip route-static command. To delete all static routes, including the default route, use the delete static-routes all command.
# Delete all static routes.
[Sysname] delete static-routes all
This will erase all IPv4 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip route-static
display route-static nib
Use display route-static nib to display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string of 1 to ffffffff. If you do not specify this argument, the command displays all static route next hop information.
verbose: Displays detailed static route next hop information. If you do not specify this keyword, the command displays brief static route next hop information.
# Displays brief static route next hop information.
<Sysname> display route-static nib
Total number of nexthop(s): 44
      NibID: 0x11000000        Sequence: 0
       Type: 0x21               Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x111              VrfNthp: 0
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
     NewUK0: 0x0                 NewUK1: 0x0
     NewUK2: 0x0                 NewUK3: 0x0
     NewUK4: 0x0                 NewUK5: 0x0
     NewUK6: 0x0                 NewUK7: 0x0
   TopoNthp: 0                  ExtType: 0x0
    FIRType: Normal           Threshold: 0
      NibID: 0x11000001        Sequence: 1
       Type: 0x41               Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                VrfNthp: 5
   UserKey1: 0x0                Nexthop: 2.2.2.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
Age
Elapsed time since the next hop information was last updated.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
Local interface address.
NewUK0
New reserved data 1.
NewUK1
New reserved data 2.
NewUK2
New reserved data 3.
NewUK3
New reserved data 4.
NewUK4
New reserved data 5.
NewUK5
New reserved data 6.
NewUK6
New reserved data 7.
NewUK7
New reserved data 8.
TopoNthp
Index of the topology that contains the next hop. This field displays 0 if the next hop is on the public network.
ExtType
NIB extension type.
FIRType
Type of the link for the next hop in FIR ECMP mode:
·     Normal.
·     Primary.
·     Secondary.
Threshold
Upper threshold (in percentage) for the bandwidth usage of primary links in FIR ECMP mode.
# Displays detailed static route next hop information.
<Sysname> display route-static nib verbose
        Age: 00h01m50s
     RefCnt: 2              FlushRefCnt: 0
       Flag: 0x2                Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology: base
     Weight: 1000000              Flags: 0x0
RealFIRType: Normal           RealThres: 0
        Age: 00h01m50s
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x12               Version: 1
    ExtFlag: 0x0
 2 nexthop(s):
PrefixIndex: 0              OrigNexthop: 2.2.2.2
  RelyDepth: 7              RealNexthop: 8.8.8.8
  Interface: Vlan11           LocalAddr: 12.12.12.12
  RelyDepth: 9              RealNexthop: 0.0.0.0
NibID
ID of the NIB.
Sequence
Type of the NIB.
Flushed
Age
UserKey0
Reserved data 1.
VrfNthp
UserKey1
Reserved data 2.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
TopoNthp
ExtType
NIB extension type.
FIRType
·     Normal.
·     Primary.
·     Secondary.
Threshold
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
ExtFlag
Extended flag of the next hop.
x nexthop(s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
localAddr
TunnelCnt
Number of tunnels after route recursion.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. The topology name for the public network is base.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
Flags
Flags of the next hop.
RealFIRType
Type of the link for the real next hop in FIR ECMP mode:
·     Normal.
·     Primary.
·     Secondary.
The real next hop is the direct next hop found after route recursion.
RealThres
Upper threshold (in percentage) for the bandwidth usage of the primary link to which the real next hop is attached in FIR ECMP mode.
display route-static routing-table
Use display route-static routing-table to display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays static routing table information for the public network.
ip-address: Specifies the destination IP address in dotted decimal notation. If you do not specify this argument, the command displays all static routing table information.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
# Display static routing table information.
<Sysname> display route-static routing-table
Total number of routes: 24
Status: * - valid
*Destination: 0.0.0.0/0
       NibID: 0x1100000a        NextHop: 2.2.2.10
   MainNibID: N/A             BkNextHop: N/A
     BkNibID: N/A             Interface: Vlan-interface11
     TableID: 0x2           BkInterface: Vlan-interface12
        Flag: 0x82d01          BfdSrcIp: N/A
     DbIndex: 0xd            BfdIfIndex: 0x0
        Type: Normal        BfdVrfIndex: 0
  TrackIndex: 0xffffffff          Label: NULL
  Preference: 60            vrfIndexDst: 0
     BfdMode: N/A            vrfIndexNH: 0
   Permanent: 0                     Tag: 0
  MicroSegID: 0          RecurseMaskLen: N/A
       NibID: 0x1100000b        NextHop: 2.2.2.11
     BkNibID: N/A             Interface: Vlan-interface13
     TableID: 0x2           BkInterface: Vlan-interface14
   Permanent: 0                     Tag: 0
destination
Destination address/prefix.
NibID
ID of the NIB.
MainNibID
ID of the primary next hop for static route FRR.
BkNibID
ID of the backup next hop for static route FRR.
NextHop
Next hop address.
BkNextHop
Backup next hop address.
Output interface of the route.
BkInterface
Backup output interface.
TableID
ID of the table to which the route belongs.
Flag
Flag of the route.
DbIndex
Index of the database to which the route belongs.
Route type:
·     Normal.
·     DHCP.
·     IPsec.
·     IPSGT.
BfdSrcIp
Source IP address of the indirect BFD session.
BfdIfIndex
Index of the interface where BFD is enabled.
BfdVrfIndex
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network.
BfdMode
BFD session mode:
·     N/A—No BFD session is configured.
·     Ctrl—Control packet mode
TrackIndex
NQA Track index.
vrfIndexDst
Index of VPN instance that the destination belongs to. For the public network, this field displays 0.
vrfIndexNH
Index of the VPN instance that the next hop belongs to. For the public network, this field displays 0.
Permanent
Permanent static route flag. 1 indicates a permanent static route.
FIRType
·     Normal.
·     Primary.
·     Secondary.
Threshold
MicroSegID
Microsegment ID in the route.
RecurseMaskLen
Exact mask length for route recursion. If the device uses the longest match principle for route recursion, this field displays N/A.
ip route-static
Use ip route-static to configure a static route.
Use undo ip route-static to delete a static route.
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ nexthop-index index-string ] ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd control-packet | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd control-packet | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static  group group-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static group group-name vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ip route-static { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
No static route is configured.
dest-address: Specifies the destination IP address of the static route, in dotted decimal notation.
group group-name: Specifies a static route group by its name, a case-sensitive string of 1 to 31 characters.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you specify this option, the device searches for the output interface in the specified destination VPN instance based on the specified next hop address for packets matching the static route.
interface-type interface-number: Specifies an output interface by its type and number. For more information, see Layer 3—IP Routing Configuration Guide.
next-hop-address: Specifies the IP address of the next hop, in dotted decimal notation. For more information, see Layer 3—IP Routing Configuration Guide.
nexthop-index index-string: Specifies the index of the next hop. The index-string argument represents the index, which is a case-insensitive string of 1 to 93 characters. If you do not specify an index for the next hop, the static route uses the output interface and the IP address of the next hop as the next hop index. Do not specify the same next hop index for routes to the same destination.
recursive-lookup host-route: Specifies only host routes for static route recursion.
backup-interface interface-type interface-number: Specifies a backup output interface by its type and number. If the backup output interface is an NBMA interface or broadcast interface and not a P2P interface, you must specify the backup next hop address.
backup-nexthop backup-nexthop-address: Specifies a backup next hop address.
bfd: Enables BFD to detect reachability of the static route's next hop. When the next hop is unreachable, the system immediately switches to the backup route.
control-packet: Specifies the BFD control packet mode.
bfd-source ip-address: Specifies the source IP address of BFD packets. As a best practice, specify the loopback interface address.
permanent: Specifies the route as a permanent static route. If the output interface is down, the permanent static route is still active.
track track-entry-number: Associates the static route with a track entry specified by its number in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
preference preference: Specifies a preference for the static route, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag value for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
recursive-lookup: Enables support for next hop recursion loops for the IPv4 static route. If you do not specify this keyword, the device does not support next hop recursion loops for the IPv4 static route.
description text: Configures a description of 1 to 60 characters for the static route. The description can include special characters, such as the space, except the question mark (?).
If the destination IP address and the mask are both 0.0.0.0 (or 0), the configured route is a default route. The default route is used for forwarding a packet matching no entry in the routing table.
Implement different routing policies to configure different route preferences. For example, to enable load sharing for multiple routes to the same destination, assign the same preference to the routes. To enable the routes to back up one another, assign different preferences to them.
Follow these guidelines when you specify the output interface or the next hop address of the static route:
·     If the output interface is a Null 0 interface, no next hop address is required.
·     If the output interface is a point-to-point interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
·     NBMA or P2MP interfaces need IP address-to-link layer address mappings for successful packet delivery. As a best practice, specify the next hop address for the route at the same time if the output interface is an NBMA or P2MP interface.
·     If the output interface is a broadcast interface, the device uses the next hop IP address to obtain the MAC address of the next hop. Therefore, you must specify both the output interface and next hop IP address, except for certain cases.
Follow these guidelines when you configure a static route:
·     Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see High Availability Configuration Guide.
·     For static routing-Track-NQA collaboration, you must configure the same VPN instance ID for the next hop to be detected and the NQA operation.
·     If a static route needs route recursion, the associated track entry must monitor the next hop of the related route instead of that of the recursive static route. Otherwise, a valid route might be mistakenly considered invalid.
·     Do not specify the permanent keyword together with the bfd or track keyword.
To specify the recursive-lookup host-route keyword, you must enable ARP direct route advertisement to advertise 32-bit host routes on the output interface corresponding to the next hop. To enable ARP direct route advertisement, use the arp route-direct advertise command.
If you specify a static route group, all prefixes in the static route group will be assigned the next hop and output interface specified by using this command.
A recursion loop occurs when an IPv4 static route recurses to a related route whose destination address contains the destination address of the IPv4 static route. For example, a recursion loop occurs when the IPv4 static route destined for 10.1.0.0/24 recurses to a related route whose destination address is 10.1.0.0/16.
·     If the recursive-lookup keyword is not specified, the recursion loop results in route recursion failure. The device further looks up for a related route.
·     If the recursive-lookup keyword is specified, the device determines that the recursion succeeds if the output interface of the related route is an interface directly connected to the device.
If the output interface of an IPv4 static route is found through recursion loops, routing protocols on the device cannot advertise the IPv4 static route to other devices.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive. You cannot specify both of the keywords.
# Configure a static route, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2, tag value is 45, and description information is for internet.
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet
display ip routing-table protocol
ip route-static-group
prefix
ip route-static arp-request
Use ip route-static arp-request to enable periodic sending of ARP requests to the next hops of static routes.
Use undo ip route-static arp-request to disable periodic sending of ARP requests to the next hops of static routes.
ip route-static arp-request [ interval interval ]
Periodic sending of ARP requests to the next hops of static routes is disabled.
interval: Specifies an ARP request sending interval in the range of 1 to 300 seconds. The default value is 5.
When the following conditions exist, a recursive static route becomes inactive:
·     The static route uses a host route to reach its direct next hop.
·     The host route is obtained by specifying the recursive-lookup host-route keyword in the ip route-static command or by routing policy-based recursive lookup.
·     The host route is unavailable because the direct next hop cannot send gratuitous ARP messages and consequently no ARP entry exists for that host route on the device.
To resolve this issue, you can use this command to enable the device to periodically send ARP requests to the direct next hop. When the device receives an ARP response from the direct next hop, it stops sending ARP requests and activates the recursive static route.
This command applies only to a recursive static route that meets the following requirements:
·     The static route has no output interface specified.
·     The static route fails the next-hop recursion.
# Enable sending of ARP requests to the next hops of static routes and set the sending interval to 10 seconds.
[Sysname] ip route-static arp-request interval 10
ip route-static
protocol nexthop recursive-lookup
ip route-static default-preference
Use ip route-static default-preference to configure a default preference for static routes.
Use undo ip route-static default-preference to restore the default.
ip route-static default-preference default-preference
The default preference of static routes is 60.
default-preference: Specifies a default preference for static routes, in the range of 1 to 255.
If no preference is specified for a static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added static routes.
# Set a default preference of 120 for static routes.
[Sysname] ip route-static default-preference 120
ip route-static fast-reroute auto
Use ip route-static fast-reroute auto to configure static route FRR to automatically select a backup next hop.
Use undo ip route-static fast-reroute auto to disable static route FRR from automatically selecting a backup next hop.
Static route FRR is disabled from automatically selecting a backup next hop.
# Configure static route FRR to automatically select a backup next hop.
[Sysname] ip route-static fast-reroute auto
ip route-static vpn-instance
Use ip route-static vpn-instance to configure a static route in a VPN instance.
Use undo ip route-static vpn-instance to delete a static route from a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ nexthop-index index-string ] ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd control-packet | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } next-hop-address [ nexthop-index index-string ] [ recursive-lookup host-route ] [ public ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number [ next-hop-address ] [ bfd control-packet | backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name next-hop-address [ recursive-lookup host-route ] [ public ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup host-route ] [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
undo ip route-static vpn-instance s-vpn-instance-name { dest-address { mask-length | mask } | group group-name } [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
No static route is configured in a VPN instance.
s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN instance has its own routing table, and the configured static route is installed in the routing tables of the specified VPN instances.
public: Specifies the public network. If you specify this keyword following the next-hop-address argument, the next hop is on the public network. The device searches for the output interface in the public network based on the next hop address for packets matching the static route. If you specify the next-hop-address argument without specifying the public keyword, the device searches for the output interface in the source VPN instance based on the next hop address for packets matching the static route.
·     If the output interface is a broadcast interface (for example, an Ethernet interface or VLAN interface), the device uses the next hop IP address to obtain the MAC address of the next hop. Therefore, you must specify both the output interface and next hop IP address.
# Configure a static route in VPN instance vpn1, whose destination address is 1.1.1.1/24, next hop address is 2.2.2.2 in VPN instance vpn2, tag value is 45, and description information is for internet.
[Sysname] ip route-static vpn-instance vpn1 1.1.1.1 24 vpn-instance vpn2 2.2.2.2 tag 45 description for internet
prefix
Use ip route-static-group to create a static route group and enter its view, or enter the view of an existing static route group.
Use undo ip route-static-group to delete a static route group.
ip route-static-group group-name
undo ip route-static-group group-name
No static route groups exist.
group-name: Specifies the static route group name, a case-sensitive string of 1 to 31 characters.
# Create static route group test and enter its view.
[Sysname] ip route-static-group test
[Sysname-route-static-group-test]
ip route-static
prefix
prefix
Use prefix to add a static route prefix to a static route group.
Use undo prefix to delete a static route prefix from a static route group.
prefix dest-address { mask-length | mask }
undo prefix dest-address { mask-length | mask }
No static route prefix is added to a static route group.
Static route group view
Execute this command repeatedly to add multiple static route prefixes to a static route group.
After you add static route prefixes to a static route group, you can specify that group in the ip route-static group command to configure static routes with the prefixes. To configure more static routes, you only need to add new static route prefixes to the group.
# Add static route prefix 1.1.1.1/32 to static route group test.
[Sysname-route-static-group-test] prefix 1.1.1.1 32
ip route-static
