H3C S9820-64H Switch Installation Guide-6W104
HomeSupportSwitchesS9820 SeriesInstall & UpgradeInstallation GuidesH3C S9820-64H Switch Installation Guide-6W104
01-Installation Guide
01-Installation Guide 6.20 MB
1 Preparing for installation· 1-1
Safety recommendations· 1-1
Examining the installation site· 1-1
Temperature/humidity· 1-2
Cleanliness· 1-2
Corrosive gas limit 1-2
EMI 1-3
Laser safety· 1-4
Installation tools· 1-4
Installation accessories· 1-4
2 Installing the switch· 2-6
Installing the switch in a 19-inch rack· 2-6
Installation accessories· 2-6
Mounting bracket installation positions and switch dimensions· 2-7
Rack requirements· 2-8
Rack-mounting procedure at a glance· 2-9
Attaching the mounting brackets, chassis rails, and grounding cable to the chassis· 2-10
Attaching cage nuts and slide rails to the rack· 2-12
Mounting the switch in the rack· 2-13
Grounding the switch· 2-15
Installing/removing fan trays· 2-16
Installing a fan tray· 2-17
Removing a fan tray· 2-17
Installing/removing power supplies· 2-18
Installing a power supply· 2-19
Removing a power supply· 2-20
Connecting power cords· 2-21
Connecting an AC power cord· 2-22
Connecting a DC power cord· 2-22
Verifying the installation· 2-23
3 Accessing the switch for the first time· 3-24
Connecting the switch to a configuration terminal 3-24
Connecting the console cable· 3-25
Connecting a DB9-to-RJ45 console cable· 3-25
Connecting a USB-to-RJ45 console cable· 3-26
Connecting a mini USB console cable· 3-28
Setting terminal parameters· 3-28
Powering on the switch· 3-28
4 Setting up an IRF fabric· 4-29
IRF fabric setup flowchart 4-29
Planning IRF fabric setup· 4-30
Planning IRF fabric size and the installation site· 4-30
Identifying the master switch and planning IRF member IDs· 4-30
Planning IRF topology and connections· 4-31
Identifying physical IRF ports on the member switches· 4-32
Planning the cabling scheme· 4-32
Configuring basic IRF settings· 4-34
Connecting the physical IRF ports· 4-34
Accessing the IRF fabric to verify the configuration· 4-34
5 Maintenance and troubleshooting· 5-36
Power supply failure· 5-36
Symptom·· 5-36
Solution· 5-36
Fan tray failure· 5-36
Symptom·· 5-36
Solution· 5-36
Configuration terminal display issues· 5-36
No output 5-36
Garbled output 5-37
The H3C S9820-64H switch is a high-density intelligent 100G switch developed for data center and high-end campus networks, providing powerful hardware forwarding capacity and abundant data center features.
The switch provides the following ports and FRUs:
·     100G QSFP28 ports.
·     Two 1G management Ethernet ports (one fiber port and one copper port).
·     Removable fan trays in redundancy mode and flexible airflows. By using different fan trays, you can change the airflow direction of the chassis to adapt to ventilation needs.
·     Removable power supplies in redundancy mode.
To avoid any equipment damage or bodily injury caused by incorrect use, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
·     Before cleaning the switch, remove all power cords from the switch. Do not clean the switch with wet cloth or liquid.
·     Do not place the switch near water or in a damp environment. Prevent water or moisture from entering the switch chassis.
·     Do not place the switch on an unstable case or desk. The switch might be severely damaged in case of a fall.
·     Ensure good ventilation of the equipment room and keep the air inlet and outlet vents of the switch free of obstruction.
·     Make sure the operating voltage is in the required range.
·     To avoid electrical shocks, do not open the chassis while the switch is operating or when the switch is just powered off.
·     To avoid ESD damage, always wear an ESD wrist strap when replacing power supplies and fan trays.
The switch must be used indoors. Make sure the installation site meets the following requirements:
·     Adequate clearance is reserved at the air inlet and outlet vents for ventilation.
·     The rack has a good ventilation system.
·     Identify the hot aisle and cold aisle at the installation site, and make sure ambient air flows into the switch from the cold aisle and exhausts to the hot aisle.
·     Identify the airflow designs of neighboring devices, and prevent hot air flowing out of the neighboring devices from entering the top device.
·     The rack is sturdy enough to support the switch and its accessories.
·     The rack is reliably grounded.
To ensure correct operation and long service life of your switch, install it in an environment that meets the requirements described in the following subsections.
Maintain appropriate temperature and humidity in the equipment room in the acceptable range. For more information, see H3C S9820-64H Switch Hardware Information and Specifications.
·     Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
·     Lasting low relative humidity can cause washer contraction and ESD and cause problems including loose mounting screws and circuit failure.
·     High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the switch.
Cleanliness
Dust buildup on the chassis might cause electrostatic adsorption and dust corrosion, resulting in poor contact of metal connectors and contact points. This might shorten the device's lifetime and even cause device failure in the worst case. Table1-1 describes the switch requirement for cleanliness.
Table1-1 Switch requirement for cleanliness
Substance
Particle diameter
Concentration limit
Dust particles
≥ 0.5 µm
≤ 1.8 × 107 particles/m3
To maintain cleanliness in the equipment room, follow these guidelines:
·     Keep the equipment room away from pollution sources. Do not smoke, eat, or drink in the equipment room.
·     Use double-layer glass in windows and seal doors and windows with dust-proof rubber strips. Use screen doors and window screens for doors and windows open to the outside and make sure the external windows are air tight.
·     Use dustproof materials for floors, walls, and ceilings and use wallpaper or matt paint that does not produce powders.
·     Clean the equipment room regularly and clean the air filters of the rack each month.
·     Wear ESD clothing and shoe covers before entering the equipment room, keep the ESD clothing and shoe covers clean, and change them frequently.
Corrosive gas limit
Corrosive gases can accelerate corrosion and aging of metal components, and even cause device failure in the worst case. Make sure the corrosive gases do not exceed the concentration limits as shown in Table1-2.
Table1-2 Corrosive gas concentration limits
Gas
Average concentration (mg/m3)
Maximum concentration (mg/m3)
SO2
0.3
1.0
H2S
0.1
0.5
Cl2
0.1
0.3
HCI
0.1
0.5
HF
0.01
0.03
NH3
1.0
3.0
O3
0.05
0.1
NOX
0.5
1.0
CAUTION
CAUTION:
As a best practice, control the corrosive gas concentrations in the equipment room at their average values. Make sure the corrosive gas concentrations do not exceed 30 minutes per day at their maximum values.
To control corrosive gases, use the following guidelines:
·     As a best practice, do not build the equipment room in a place with a high concentration of corrosive gases.
·     Make sure the equipment room is not connected to sewer, vertical shaft, or septic tank pipelines and keep it far away from these pipelines. The air inlet of the equipment room must be away from such pollution sources.
·     Use environmentally friendly materials to decorate the equipment room. Avoid using organic materials that contains harmful gases, such as sulfur or chlorine-containing insulation cottons, rubber mats, sound-proof cottons, and avoid using plasterboards with high sulfur concentration.
·     Place fuel (diesel or gasoline) engines separately. Do not place them in the same equipment room with the device. Make sure the exhausted air of the engines will not flow into the equipment room or towards the air inlet of the air conditioners.
·     Place batteries separately. Do not place them in the same room with the device.
·     Employ a professional company to monitor and control corrosive gases in the equipment room regularly.
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the switch and application system, adversely affect the switch in the following ways:
·     A conduction pattern of capacitance coupling.
·     Inductance coupling.
·     Electromagnetic wave radiation.
·     Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
·     If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid.
·     Keep the switch far away from radio transmitting stations, radar stations, and high-frequency devices.
·     Use electromagnetic shielding, for example, shielded interface cables, when necessary.
·     To prevent signal ports from getting damaged by overvoltage or overcurrent caused by lightning strikes, route interface cables only indoors.
Laser safety
WARNING
WARNING!
Do not stare into any open apertures of operating transceiver modules or optical fiber connectors. The laser light emitted from these apertures might hurt your eyes.
The switch is a Class 1M laser device.
Installation tools
No installation tools are provided with the switch. Prepare the following tools yourself:
·     Phillips screwdriver.
·     ESD wrist strap.
·     Marker.
Before installation, make sure you have all the required installation accessories. If any accessory is damaged or missing, use the part number provided in this table to purchase a new one.
Table1-3 Installation accessories
Part number in BOM
Quantity
0223A0NB
Mounting brackets
1 kit (provided)
2150A05N
2U rack mounting rail kit (short slide rails)
1 kit (provided)
N/A
M6 screw and cage nut
User supplied
0404A1RA (single-hole grounding lug) or 0404A0KM (two-hole grounding lug)
Grounding cable
1 (provided)
26010553
Grounding screw
2 (provided)
2114A09C
Power supply filler panel
2 (provided)
N/A
Releasable cable tie
User supplied
04042967
Serial console cable
Optional
0404A1EE
Optional
N/A
Mini USB console cable
User supplied
14990101
SFP port dust plug
1 (provided)
1499A01G
QSFP port dust plug
Same number as the QSFP28 ports
CAUTION
CAUTION:
Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact H3C for permission. Otherwise, H3C shall not be liable for any consequence caused thereby.
CAUTION
CAUTION:
When installing the switch, always wear an ESD wrist strap and make sure the wrist strap makes good skin contact and is reliably grounded.
Figure2-1 Installation flow
The switch is provided with the following installation accessories:
·     A pair of mounting brackets (2150A0EH), as shown in Figure2-2.
·     A pair of cable management brackets (each attached to a mounting bracket), as shown in Figure2-2.
·     A rack-mount rail kit, including a pair of slide rails (2150A05N) and a pair of chassis rails, as shown in Figure2-3.
Figure2-2 Mounting brackets and cable management brackets
(1) Cable management bracket
(2) Left mounting bracket (with an L mark)
(3) Right mounting bracket (with an R mark)
Figure2-3 Chassis rail and slide rail
(1) Chassis rail
(2) Slide rail
The switch supports both the port-side and power supply-side installation positions for mounting brackets, as shown in Figure2-4 and Figure2-5.
Figure2-4 Installing the mounting brackets at the port side
(1) Power supply handle
(2) Mounting bracket
(3) Cable management bracket
Figure2-5 Installing the mounting brackets at the power supply side
Rack requirements
To mount the switch in a 19-inch rack, the rack must meet the requirements in Table2-1.
Table2-2 Rack requirements
Chassis dimensions
Distance between the front and rear rack posts
Rack requirements
Mounting brackets installed near the port side
·     Width—440 mm (17.32 in)
·     Height—88.1 mm (3.47 in)/2 RU
·     Depth—643 mm (25.31 in)
¡     540 mm (21.26 in) for the chassis
¡     92 mm (3.62 in) for the mounting brackets
¡     26 mm (1.02 in) for the power supply/fan tray handles
501 to 778 mm (19.72 to 30.63 in)
·     A minimum of 800 mm (31.50 in) in depth (recommended)
·     A minimum of 130 mm (5.12 in) between the front rack posts and the front door
·     A minimum of 630 mm (24.80 in) between the front rack post and the rear door.
Mounting brackets installed near the power supply side
·     Depth—630 mm (24.80 in)
506 to 778 mm (19.92 to 30.63 in)
IMPORTANT
IMPORTANT:
To reserve enough cabling space and close the rack door easily, make sure the rack meets the depth requirements.
Figure2-6 Rack-mounting procedure
If a rack shelf is available, you can put the switch on the rack shelf, slide the switch to an appropriate location, and attach the switch to the rack using the mounting brackets.
As shown in Figure2-7, the switch provides two installation positions on the two sides for mounting brackets: one near the power supply side and one near the port side. A primary grounding point (with a grounding sign) and an auxiliary grounding point are available on the switch.
Figure2-7 Mounting brackets and grounding cable installation positions
(1) Mounting bracket installation position near the power supply side
(2) Primary grounding point
(3) Auxiliary grounding point
(4) Mounting bracket installation position near the port side
Attaching the mounting brackets and chassis rails to the chassis
1.     Attach the mounting brackets to the chassis.
a.     Identity the left and right mounting brackets.
The left mounting bracket has an L mark. The right mounting bracket has an R mark.
b.     Place the long side of a mounting bracket against its installation position on the chassis. Align the mounting holes in the mounting bracket with the screw holes in the chassis. Use the provided M4 screws to attach the mounting bracket to the chassis. As a best practice, use a torque of 12 kgf-cm (1.18 Nm) to fasten the M4 screws.
-     To install a mounting bracket near the port side, see Figure2-8.
-     To install a mounting bracket near the power supply side, see Figure2-9.
2.     Attach the chassis rails to the chassis.
a.     Determine the chassis rail installation position based on the mounting bracket installation positon and the distance between the front and rear rack posts, as shown in Table2-2.
Table2-3 Chassis rail installation positions
Port-side position
Position a
531 to 778 mm (20.91 to 30.63 in)
Position b
501 to 713 mm (19.72 to 28.07 in)
Power supply-side position
Position c
506 to 648 mm (19.92 to 25.51 in)
Position d
506 to 713 mm (19.92 to 28.07 in)
Position e
b.     Use the provided M4 screws to attach the chassis rails to the chassis.
Figure2-8 Attaching a mounting bracket and chassis rail to the switch (port-side mounting position for the mounting brackets)
Figure2-9 Attaching a mounting bracket and chassis rail to the switch (power supply-side mounting position for the mounting brackets)
Connecting the grounding cable to the chassis
CAUTION
CAUTION:
The primary grounding point and auxiliary grounding point are located on the left panel of the chassis. Use one of the grounding points as required. Connect the grounding cable to a grounding point before you mount the switch in the rack.
Use M5 grounding screws to attach a grounding cable that has a single-hole grounding lug or two-hole grounding lug to the grounding point on the switch. If the grounding cable length or grounding lug type cannot meet your requirement, make an applicable grounding cable or contact H3C Support.
The grounding screws provided with the switch are applicable to both the primary and auxiliary grounding points. This procedure uses the primary grounding point as an example.
To connect the grounding cable:
1.     Unpack the grounding cable and grounding screws.
2.     Use the grounding screws to attach the single-hole grounding lug or two-hole grounding lug of the grounding cable to the grounding point and then fasten the screws, as shown in Figure2-10 and Figure2-11.
As a best practice, use a torque of 30 kgf-cm (2.94 Nm) to fasten the grounding screws.
Figure2-10 Attaching a grounding cable that has a single-hole grounding lug to the grounding point
Figure2-11 Attaching a grounding cable that has a two-hole grounding lug to the grounding point
1.     Identify and mark the cage nut installation holes on the rack for securing mounting brackets and slide rails.
The mounting brackets for the switch are 2 RU high. For the left mounting bracket, install cage nuts in the upper and lower installation holes of each RU. For the right mounting bracket, install cage nuts in the uppermost and lowermost installation holes.
Figure2-12 Marking cage nut installation holes for attaching mounting brackets
2.     Install cage nuts (user-supplied) in the marked mounting holes in the rack posts.
3.     Align the screw holes in one slide rail with the cage nuts in a rear rack post. Use the user-supplied M6 screws to attach the slide rail to the post, as shown in Figure2-13.
As a best practice, use a torque of 30 kgf-cm (2.94 Nm) to fasten the M6 screws.
4.     Perform the same procedure to attach the other slide rail to the other rear rack post.
Make sure the two slide rails at the same height so the slide rails can slide into the chassis rails.
Figure2-13 Installing slide rails
This task requires two people.
To mount the switch in the rack:
1.     Verify that the mounting brackets and chassis rails have been securely attached to the switch chassis.
2.     Verify that the slide rails have been correctly attached to the rear rack posts.
3.     Attach cage nuts (user-supplied) to the front rack posts and make sure they are at the same level as the slide rails.
4.     One person performs the following operations:
a.     Supporting the bottom of the switch, aligns the chassis rails with the slide rails on the rack posts.
b.     Pushes the switch slowly into the rack so that the slide rails slide into and reach out the chassis rails and the mounting brackets are flush against the rack posts.
5.     Another person uses screws (user-supplied) to attach the mounting brackets to the rack.
Figure2-14 Mounting the switch in the rack (port-side mounting position for the mounting brackets)
Figure2-15 Mounting the switch in the rack (power supply-side mounting position for the mounting brackets)
CAUTION
CAUTION:
·     Correctly connecting the grounding cable is crucial to lightning protection and EMI protection.
·     To guarantee the grounding effect, connect the switch to a grounding strip in the equipment room by using the grounding cable provided with the switch.
The power input end of the switch has a noise filter, whose central ground is directly connected to the chassis to form the chassis ground (commonly known as PGND). You must securely connect this chassis ground to the earth to minimize the potential for system damage, maximize the safety at the site, and minimize EMI susceptibility of the system.
You can ground a switch by using a grounding strip at the installation site.
The grounding terminals in this section are for illustration only.
WARNING
WARNING!
Connect the grounding cable to the grounding system in the equipment room. Do not connect it to a fire main or lightning rod.
To ground the switch by using a grounding strip:
1.     Attach the single-hole grounding lug or two-hole grounding lug of the grounding cable to a grounding point on the chassis. For more information, see "Connecting the grounding cable to the chassis."
2.     Remove the hex nut of a grounding post on the grounding strip.
3.     Attach the ring terminal at the other end of the grounding cable to the grounding post on the grounding strip, and secure the ring terminal to the grounding post with the hex nut.
Figure2-16 Connecting the grounding cable to a grounding strip
(1) Hex nut
(2) Ring terminal
(3) Grounding post
(4) Grounding strip
CAUTION
CAUTION:
The switch has three fan tray slots. For adequate heat dissipation, follow these guidelines:
·     The switch is provided with the fan tray slots empty. Before powering on the switch, make sure all fan tray slots have fan trays installed and the fan trays are the same model.
·     Make sure each slot has a module or filler panel installed when the switch is operating.
·     If one fan tray fails when the switch is operating, replace the fan tray immediately and keep the failed fan tray in position before the replacement. If two fan trays fail, finish replacing at least one fan tray within 1 minute. Replace the fan trays one after another. Do not remove them simultaneously.
The switch uses a front-rear air aisle. It can provide airflow from the power supply side to the port side or from the port side to the power supply side by using different fan trays.
The LSWM1BFANSC, LSWM1BFANSC-SN, LSWM1BFANSCB, and LSWM1BFANSCB-SN fan trays are available for the switch. The LSWM1BFANSC or LSWM1BFANSC-SN fan tray intakes air from the fan tray panel. The fan tray handles are blue. The LSWM1BFANSCB or LSWM1BFANSCB-SN fan tray exhausts air from the fan tray panel. The fan tray handles are red. Select fan trays for the switch based on the airflow requirements. For the fan tray specifications, see H3C S9820-64H Switch Hardware Information and Specifications.
The installation and removal procedures are the same for the fan trays. The following installation and removal procedures use the LSWM1BFANSC fan tray as an example.
CAUTION
CAUTION:
To prevent damage to the fan tray or the connectors on the backplane, insert the fan tray gently. If you encounter a hard resistance while inserting the fan tray, pull out the fan tray and insert it again.
CAUTION
CAUTION:
Before powering on the switch, make sure the fan tray airflow direction and the preferred airflow direction of the switch are the same. If they are not the same, the system generates traps and logs. You can use the fan prefer-direction command to configure the preferred airflow direction for the switch. By default, the preferred airflow direction of the switch is from the port side to the power supply side.
For more information about the fan prefer-direction command, see device management in H3C S9820-64H Switch Fundamentals Command Reference.
The switch supports shipping with fan trays and power supplies installed. If your switch came with fan trays preinstalled, skip this section.
To install a fan tray:
1.     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2.     Unpack the fan tray and verify that the fan tray model is correct.
3.     Orient the fan tray with the "TOP" mark on top. Grasp the handle of the fan tray with one hand and support the fan tray bottom with the other, and slide the fan tray along the guide rails into the slot until the fan tray is fully seated in the slot and has a firm contact with the backplane. See Figure2-17.
Figure2-17 Installing an LSWM1BFANSC fan tray
Removing a fan tray
WARNING
WARNING!
·     Ensure electricity safety and never touch the rotating fans when you hot-swap a fan tray.
·     To prevent a fan from causing loud noise, do not touch the fan blades and rotation axis, even if the fan is not rotating.
To remove a fan tray:
2.     Grasp the handle of the fan tray with one hand and pull the fan tray part way out of the slot. Support the fan tray bottom with the other and pull the fan tray completely out of the slot.
3.     Put the removed fan tray in an antistatic bag.
Figure2-18 Removing an LSWM1BFANSC fan tray
WARNING
WARNING!
·     To avoid bodily injury and device damage, strictly follow the procedures in Figure2-19 and Figure2-20 to install and remove a power supply.
·     Provide a separate circuit breaker for each power supply.
CAUTION
CAUTION:
Make sure each slot has a filler panel or module installed when the switch is operating.
The switch has four power supply slots. It is shipped with power supply slots PWR2 and PWR4 empty and power supplies slots PWR1 and PWR3 installed with filler panels.
The switch supports 2+1 and 2+2 power supply redundancy. You can install two to four power supplies for the switch. For information about the power supplies available for the switch, see H3C S9820-64H Switch Hardware Information and Specifications.
Figure2-19 Installation procedure
Figure2-20 Removal procedure
CAUTION
CAUTION:
·     Follow the forward inertia of the power supply when inserting it into the chassis, and make sure the power supply has firm contact with the connectors on the backplane.
·     To prevent damage to the connectors inside the switch chassis, insert the power supply gently. If you encounter a hard resistance while inserting the power supply, pull out the power supply and insert it again.
The switch supports shipping with fan trays and power supplies installed. If your switch came with power supplies preinstalled, skip this section.
The installation procedure is the same for the LSVM1AC650 and LSVM1DC650 power supplies. The following procedure uses the LSVM1AC650 power supply as an example.
To install a power supply:
2.     Remove the filler panel, if any, from the target power supply slot, as shown in Figure2-21.
Figure2-21 Removing a filler panel
3.     Unpack the power supply and verify that the power supply model is correct.
4.     Correctly orient the power supply with the lettering on it upward. Grasping the power supply handle with one hand and supporting the module bottom with the other, slide the power supply slowly into the slot along the guide rails.
The power supply slot has a disorientation rejection structure. If you cannot insert the power supply into the slot, re-orient the power supply rather than use excessive force to push it in.
Figure2-22 Installing a power supply (LSVM1AC650)
CAUTION
CAUTION:
The switch supports 2+1 or 2+2 power supply redundancy. When the switch is configured with four power supplies, removing one or two power supplies does not affect the operation of the switch. When the switch has only two power supplies installed, removing power supplies powers off the switch or causes power insufficiency.
The removal procedure is the same for the LSVM1AC650 and LSVM1DC650 power supplies.
To remove a power supply:
2.     Remove the power cord connector from the power supply.
A DC power cord connector has locking tabs. Squeeze the tabs on the power cord connector with your thumb and forefinger, and pull the connector out, as shown in Figure2-23.
3.     Hold the handle on the power supply with one hand, pivot the latch on the power supply to the right with your thumb, and pull the power supply part way out of the slot, as shown in Figure2-24.
4.     Supporting the power supply bottom with one hand, slowly pull the power supply out with the other hand.
5.     Put the removed power supply in an antistatic bag for future use.
6.     If you are not to install a new power supply, install a filler panel in the slot to ensure good ventilation in the switch.
Figure2-23 Removing a DC power cord
(1) Press the tabs on the power cord connector with your thumb and forefinger
(2) Pull the power cord connector out
Figure2-24 Removing the power supply
(1) Pivot the latch to the right with your thumb
(2) Pull the power supply out
WARNING
WARNING!
·     Provide a circuit breaker for each power input.
·     Before you connect a power cord, make sure the circuit breaker for the power cord is switched off.
1.     Insert the female connector of the AC power cord supplied with the power supply into the power receptacle on the power supply.
2.     Use a cable tie to secure the power cord to the handle of the power supply, as shown in Figure2-25.
3.     Connect the other end of the power cord to an AC power source.
Figure2-25 Connecting the AC power cord for an LSVM1AC650 power supply
(1) Cable tie
(2) Fasten the cable tie to secure the power cord to the handle of the power supply
1.     Correctly orient the DC power cord connector and insert it into the DC-input receptacle on the power supply, as shown in Figure2-26.
The DC power cord connector and the receptacle form a disorientation rejection structure. If you cannot insert the connector into the receptacle, the orientation might be wrong. Re-orient the connector rather than use excessive force to push it in.
3.     Connect the other end of the power cord to a DC power source.
Figure2-26 Connecting the DC power cord for an LSVM1DC650 power supply
If the provided DC power cord cannot meet your connection requirements, use the following table to prepare a suitable copper cable as the DC power cord.
Table2-4 Requirements for a suitable DC power cord
Power supply model
Power cord connector
Minimum cross sectional area of the conductor
Cross sectional area of the provided power cord
Maximum cross sectional area of the conductor
LSVM1DC650
Use the connector of the provided power cord
3.3 mm2 or 12 AWG
3.3 mm2 or 12 AWG
5.3 mm2 or 10 AWG
After you complete the installation, verify the following items:
·     There is enough space for heat dissipation around the switch, and the rack is stable.
·     The grounding cable is securely connected.
·     The correct power source is used.
·     The power cords are correctly connected.
·     All the interface cables are cabled indoors. The switch does not support outdoor cable routing.
The following options are available for connecting the switch to a configuration terminal:
·     Use a serial console cable to connect the serial console port on the switch to a configuration terminal.
·     Use a mini USB console cable to connect the mini USB console port on the switch to a configuration terminal.
Only the mini USB console port is active if you connect both the serial console port and mini USB console port.
The example uses a serial console cable to connect a console terminal (PC) to the serial console port on the switch.
Figure3-1 Connecting the serial console port to a terminal
As shown in Table3-1, three types of console cables can be used for connecting the switch to a configuration terminal. The switch is not provided with a serial console cable or a mini USB console cable.
Table3-1 Connection methods and console cables
Connection method
Console cable type
Configuration terminal-side connector
Switch-side connector
Using the serial console port for connection
DB-9 female connector
RJ-45 connector
USB connector
RJ-45 connector
Using the mini USB console port for connection
USB connector
USB mini-Type B connector
The signal pinout for the RJ-45 connector of a serial console cable varies by vendor. To avoid abnormal configuration terminal display, use a serial console cable provided by H3C. For more information, see Table3-2. To prepare a serial console cable yourself, make sure the signal pinout for the RJ-45 connector is the same as that shown in Table3-3.
Table3-2 Console cable views
Console cable type
Console cable view
Product code for the recommended H3C console cable
04042967
0404A1EE
User supplied,
CAUTION
CAUTION:
·     Identify the mark on the serial console port and make sure you are connecting to the correct port.
·     The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating switch, first disconnect the switch end.
A serial console cable is an 8-core cable, with a crimped RJ-45 connector at one end for connecting to the serial console port of the switch, and a DB-9 female connector at the other end for connecting to the serial port on the console terminal.
Figure3-2 Serial console cable
Table3-3 Console port signaling and pinout
RJ-45
Signal
DB-9
Signal
1
RTS
8
CTS
2
DTR
6
DSR
3
TXD
2
RXD
4
SG
5
SG
5
SG
5
SG
6
RXD
3
TXD
7
DSR
4
DTR
8
CTS
7
RTS
To connect a configuration terminal (for example, a PC) to the switch through a DB9-to-RJ45 console cable:
1.     Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port on the PC.
2.     Connect the RJ-45 connector to the serial console port on the switch.
IMPORTANT
IMPORTANT:
·     To use a USB-to-RJ45 console cable to connect the switch to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal and then connect the USB-to-RJ45 console cable to the configuration terminal.
·     If you have connected a USB-to-RJ45 console cable to the configuration terminal before driver installation, you must remove and reconnect the USB-to-RJ45 console cable to the configuration terminal.
For information about the signal pinout for the RJ-45 connector of a USB-to-RJ45 console cable, see Table3-3.
The following procedure describes how to install the driver on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by the corresponding operating system.
To connect the switch to the configuration terminal through a USB-to-RJ45 console cable:
1.     Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2.     View the TXT file Read me in the Windows folder to check whether the Windows system of the configuration terminal supports the driver.
3.     If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4.     Click Next on the welcome page of the driver installation wizard.
Figure3-3 Driver installation wizard
5.     Click Finish after the drive installation is completed.
Figure3-4 Finishing the driver installation
6.     Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7.     Connect the RJ-45 connector of the cable to the console port of the switch.
A mini USB console cable has a USB mini-Type B connector at one end to connect to the mini USB console port of the switch, and a standard USB Type A connector at the other end to connect to the USB port on the configuration terminal.
To connect to the mini USB console port on the switch to a configuration terminal:
1.     Connect the standard USB Type A connector to the USB port of the configuration terminal.
2.     Click the following link, or copy it to the address bar on the browser to log in to download page of the USB console driver, and download the driver.
http://www.h3c.com/en/home/USB_Console/
3.     Run Installer to preinstall the driver. After the preinstallation finishes, the system pops up a dialog box to indicate a successful preinstallation.
4.     Connect the USB mini-Type B connector to the Mini USB console port on the switch. The system installs the driver automatically.
To configure and manage the switch through the console port, you must run a terminal emulator program, TeraTermPro or PuTTY, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs
The following are the required terminal settings:
·     Bits per second—9600.
·     Data bits—8.
·     Stop bits—1.
·     Parity—None.
·     Flow control—None.
1.     Before powering on the switch, verify that the following conditions are met:
¡     All the fan tray slots have a fan tray installed.
¡     The power cords are connected correctly.
¡     The input power voltage is as required by the switch.
¡     The console cable is connected correctly.
¡     The configuration terminal (a PC, for example) has started, and its serial port settings are consistent with the console port settings on the switch.
2.     Power on the switch.
During the startup process, you can access BootWare menus to perform tasks such as software upgrade and file management. The BootWare interface and menu options vary by software version. For more information about BootWare menu options, see the software-matching release notes for the device.
3.     After the startup completes, you can access the CLI to configure the switch.
For more information about the configuration commands and CLI, see H3C S9820-64H Switch Configuration Guides and H3C S9820-64H Switch Command References.
You can use H3C IRF technology to connect and virtualize multiple S9820-64H switches into a large virtual switch called an "IRF fabric" for flattened network topology, and high availability, scalability, and manageability.
Figure4-1 IRF fabric setup flowchart
To set up an IRF fabric:
Step
1.     Plan IRF fabric setup.
Plan the installation site and IRF fabric setup parameters:
·     Planning IRF fabric size and the installation site
·     Identifying the master switch and planning IRF member IDs
·     Planning IRF topology and connections
·     Identifying physical IRF ports on the member switches
·     Planning the cabling scheme
2.     Install IRF member switches.
See "Installing the switch in a 19-inch rack."
3.     Connect ground wires and power cords.
See "Grounding the switch" and "Connecting power cords."
4.     Power on the switches.
N/A
5.     Configure basic IRF settings.
See H3C S9820-64H Switch Virtual Technologies Configuration Guide.
6.     Connect the physical IRF ports.
Connect the physical IRF ports on switches. Use QSFP28 transceiver modules and fibers for connections over long distances. Use QSFP28 cables for connections over short distances.
All switches except the master switch automatically reboot, and the IRF fabric is established.
This section describes issues that an IRF fabric setup plan must cover.
Determine the number of required IRF member switches, depending on the user density and upstream bandwidth requirements. The switching capacity of an IRF fabric equals the total switching capacities of all member switches.
Plan the installation site depending on your network solution as follows:
·     Place all IRF member switches in one rack for centralized high-density access.
·     Distribute the IRF member switches in different racks to implement the top-of-rack (ToR) access solution for a data center.
As your business grows, you can add member switches into the IRF fabric to increase the switching capacity without any topology change or replacement.
Determine which switch you want to use as the master for managing all member switches in the IRF fabric. An IRF fabric has only one master switch. You configure and manage all member switches in the IRF fabric at the command line interface of the master switch.
IRF member switches will automatically elect a master. You can affect the election result by assigning a high member priority to the intended master switch. For more information about master election, see H3C S9820-64H Switch Virtual Technologies Configuration Guide.
Prepare an IRF member ID assignment scheme. An IRF fabric uses member IDs to uniquely identify and manage its members, and you must assign each IRF member switch a unique member ID.
You can create an IRF fabric in daisy chain topology, or more reliably, ring topology. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy chain topology. Rather, the IRF fabric changes to a daisy chain topology without interrupting network services.
You connect the IRF member switches through IRF ports, the logical interfaces for the connections between IRF member switches. Each IRF member switch has two IRF ports: IRF-port 1 and IRF-port 2. To use an IRF port, you must bind a minimum of one physical port to it.
When connecting two neighboring IRF member switches, you must connect the physical ports of IRF-port 1 on one switch to the physical ports of IRF-port 2 on the other switch.
The IRF port connections in the two figures are for illustration only, and more connection methods are available.
Figure4-2 IRF fabric in daisy chain topology
Figure4-3 IRF fabric in ring topology
You can use a QSFP28 transceiver module and fiber or a QSFP28 cable to connect QSFP28 ports on the S9820-64H switches to set up a 100-GE IRF physical connection.
You can bind several ports to an IRF port for increased bandwidth and availability.
Identify the QSFP28 ports for IRF connections on the member switches according to your topology and connection scheme.
All the QSFP28 ports on the switch can be used for IRF connections. However, the 25G ports and 10G ports split from a QSFP28 port do not support IRF connections. The QSFP28 ports connected by a QSFP+ transceiver module and fiber or a QSFP+ cable do not support IRF connections.
You can use QSFP28 cables or QSFP28 transceiver modules and fibers to connect the S9820-64H switches for IRF connections.
If the switches are all in one equipment room, choose QSFP28 cables for IRF connections. If the switches are far away from one another, choose QSFP28 transceiver modules and fibers for IRF connections.
For more information about available cables, see H3C S9820-64H Switch Hardware Information and Specifications.
The following subsections describe several IRF connection schemes by using the QSFP28 cables and QSFP28 transceiver modules and fibers. As a best practice, use the ring topology for IRF connections.
Connecting the IRF member switches in one rack
Figure4-4 shows an example for connecting four IRF member switches in a rack. The switches in the ring topology (see Figure4-5) are in the same order as connected in the rack.
Figure4-4 Connecting the switches in one rack
Figure4-5 IRF fabric topology
Connecting the IRF member switches in a ToR solution
You can install IRF member switches in different racks side by side to deploy a top of rack (ToR) solution.
Figure4-6 shows an example for connecting four top of rack IRF member switches. The topology is the same as Figure4-5.
Figure4-6 ToR cabling
After you install the IRF member switches, power on the switches, and log in to each IRF member switch (see H3C S9820-64H Switch Fundamentals Configuration Guide) to configure their member IDs, member priorities, and IRF port bindings.
Follow these guidelines when you configure the switches:
·     Assign the master switch higher member priority than any other switch.
·     Bind physical ports to IRF port 1 on one switch and to IRF port 2 on the other switch.
·     Execute the display irf configuration command to verify the basic IRF settings.
For more information about configuring basic IRF settings, see H3C S9820-64H Switch Virtual Technologies Configuration Guide.
CAUTION
CAUTION:
Wear an ESD wrist strap when you install cables and transceiver modules and fibers. For more information, see the installation guide for the transceiver modules and cables.
Use transceiver modules and fibers or cables to connect the IRF member switches as planned.
To verify the basic functionality of the IRF fabric after you finish configuring basic IRF settings and connecting IRF ports:
1.     Log in to the IRF fabric through the console port of any member switch.
2.     Create a Layer 3 interface, assign it an IP address, and make sure the IRF fabric and the remote network management station can reach each other.
3.     Use Telnet or SNMP to access the IRF fabric from the network management station. (See H3C S9820-64H Switch Fundamentals Configuration Guide.)
4.     Verify that you can manage all member switches as if they were one node.
5.     Display the running status of the IRF fabric by using the commands in Table4-1.
Table4-1 Displaying and maintaining IRF configuration and running status
Display information about the IRF fabric.
display irf
Display all members' IRF configurations.
Display IRF fabric topology information.
display irf topology
To avoid IP address collision and network problems, configure at least one multi-active detection (MAD) mechanism to detect the presence of multiple identical IRF fabrics and handle collisions. For more information about MAD detection, see H3C S9820-64H Switch Virtual Technologies Configuration Guide.
Symptom
The status LED on a power supply is not steady green (active state) or flashing green (standby state)
For more information about the power supply LED, see H3C LSVM1AC650 & LSVM1DC650 Power Modules User Manual.
Solution
To resolve the issue:
1.     Verify that the power cord is connected correctly.
2.     Verify that the power source is as required by the switch.
3.     Verify that the operating temperature of the switch is in the acceptable range and adequate ventilation is available for the power supply.
4.     If the issue persists, contact H3C Support.
To replace a power supply, see "Installing/removing power supplies."
Fan tray failure
CAUTION
CAUTION:
The switch has three fan tray slots. If one fan tray fails when the switch is operating, replace the fan tray immediately and keep the failed fan tray in position before replacement. If two fan trays fail, finish replacing at least one fan tray within 1 minute. Replace the fan trays one after another. Do not remove them simultaneously.
Symptom
The alarm LED on a fan tray is steady yellow and the system outputs alarm messages.
Solution
See "Installing/removing fan trays" to replace the fan tray. If the issue persists, contact H3C Support.
No output
Symptom
The configuration terminal does not have any output when the switch is powered on.
Solution
1.     Verify that the power system is operating correctly.
2.     Verify that the console cable is connected correctly.
3.     Verify that the console cable does not have any problems and the terminal settings are correct.
Garbled output
Symptom
The output of the configuration terminal is garbled.
Solution
1.     Verify that the following settings are configured for the terminal:
¡     Baud rate—9600.
¡     Data bits—8.
¡     ParityNone.
¡     Stop bits—1.
¡     Flow controlNone.
2.     If the issue persists, contact H3C Support.
