H3C SeerEngine-DC Controller Ansible Plug-In Installation Guide-E63xx-5W300
HomeSupportAD-NET(SDN)H3C SeerEngine-DCConfigure & DeployInteroperability GuidesH3C SeerEngine-DC Controller Ansible Plug-In Installation Guide-E63xx-5W300
01-Text
01-Text 153.13 KB
Overview
Ansible, an automated operations and maintenance tool programmed in Python, allows for bulk system configuration, program deployment, and command execution. The SeerEngine-DC Ansible plug-in provides customized modules that can synchronize the plays in Ansible playbooks to the SeerEngine-DC controller through the RESTful API.
The SeerEngine-DC Ansible plug-in provides the following customized modules:
·     NetworkCreates or deletes vNetworks.
·     PortCreates or deletes vPorts.
·     QoSCreates or deletes network policies.
·     RouterCreates or deletes vRouters.
·     Security groupCreates or deletes security groups.
·     SubnetCreates or deletes vSubnets.
·     TenantCreates or deletes tenants.
·     DeviceCreates or deletes devices.
·     InterfaceManages device interface status.
Preparing for installation
Hardware requirements
Table 1 shows the minimum hardware requirements for installing the SeerEngine-DC Ansible plug-in on a physical server or virtual machine.
Table 1 Minimum hardware requirements
CPU
Memory size
Drive size
One core
2 GB
5 GB
Software requirements
The SeerEngine-DC Ansible plug-in can operate only on the CentOS 7 series and CentOS 8 series operating systems.
Installing the SeerEngine-DC Ansible plug-in
The SeerEngine-DC Ansible plug-in operates based on Python3. Make sure the operating system is installed with Python3.6 or its later versions.
Setting up the basic environment
Before installing the plug-in, set up the basic environment first.
To set up the basic environment:
1.     Download and install the Ansible installation package online.
[root@localhost ~]# pip3 install ansible
CAUTION
CAUTION:
Make sure the Ansible installation package is in version 2.10.0 or later.
2.     Install the requests package.
[root@localhost ~]# pip3 install requests
Installing the plug-in
Obtaining the plug-in installation package
Obtain the SeerEngine-DC Ansible package of the required version and then save the package to the target installation directory on the target server or virtual machine.
Alternatively, transfer the installation package to the target installation directory through a file transfer protocol such as FTP, TFTP, or SCP. Use the binary transfer mode to prevent the software package from being corrupted during transit.
Access the directory where the SeerEngine-DC Ansible package (a .tar.gz file) is saved, and install the package. In the following example, the SeerEngine-DC Ansible package is saved to the /root directory. The name of the package is SeerEngine_DC-ANSIBLE_PLUGIN-version1.tar.gz. version1 represents the version of the package.
[root@localhost ~]# ansible-galaxy collection install SeerEngine_DC-ANSIBLE_PLUGIN-E6203.tar.gz
Verifying the installation
Verify that the SeerEngine-DC Ansible package is correctly installed. If the correct software version is displayed, the package is installed successfully.
[root@localhost ~]# ansible-galaxy collection list | grep h3c
h3c.sdn    2.0.0
Removing the plug-in
1.     Identify the path where the plug-in is saved.
[root@localhost ~]# find / -name h3c
/root/.ansible/collections/ansible_collections/h3c
2.     Remove the code block from the path.
[root@localhost ~]  rm  -rf  /root/.ansible/collections/ansible_collections/h3c
3.     Verify that the plug-in is removed successfully. If no result is displayed, the plug-in is removed successfully.
Upgrading the plug-in
To upgrade the SeerEngine-DC Ansible plug-in, you must remove the current version first, and install the new version. For information about installing the SeerEngine-DC Ansible plug-in, see "Installing the plug-in." For information about removing the SeerEngine-DC Ansible plug-in, see "Removing the plug-in."
Creating playbooks
CAUTION
CAUTION:
SeerEngine-DC performs a fuzzy match when it searches for resources through the RESTful API. For example, if you use an Ansible playbook to delete a vNetwork resource named net1, all vNetworks whose name contains "net1", for example, net12 and net123 are matched and will also be deleted. To avoid such issues, you must make sure the names of the resources are not inclusive of each other when you create resources on the controller.
Create a playbook in the format of xxx.yaml. When you run a playbook, the system calls a specific custom module defined in that playbook.
For a required parameter, you must enter the parameter and its value in the playbook. For an optional parameter, if you do not specify a value for it, the system uses the default value, if any. Other parameters are common parameters defined by Ansible. You specify the parameters by following the examples.
Creating a network playbook
- name: network
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
- h3c.sdn.network:
     auth:
       url: http://192.168.12.100:30000
       username: admin
       password: Pwd@12345
     tenant_name: “ansible”
     shared: false
     admin_state_up: true
     external: false
     provider_physical_network: “phy1”
     provider_network_type: vxlan
     provider_segmentation_id: 222
     mtu: 1450
     state: present
Table 2 Parameter description
Parameter
Example
name
Name of the playbook.
network
hosts
Host on which the playbook runs.
localhost
gather_facts
Whether to collect information about the host:
·     true.
·     false.
false
become
Whether to escalate privilege:
·     true.
·     false.
false
tasks
Tasks in the playbook.
N/A
h3c.sdn.network
Network module that the task calls.
N/A
auth
Peer controller authentication parameters.
N/A
url
API of the controller, required.
username
Username of the controller, required.
admin
password
Password of the controller, required.
Pwd@12345
name
Name of the vNetwork, required.
net1
tenant_name
Name of the tenant to which the network belongs. For an internal network, this parameter is required. For an external network, this parameter is optional.
ansible
shared
Whether to share the network, optional:
·     true.
·     false.
The default value is false.
false
admin_state_up
Management state, optional:
·     true.
·     false.
The default value is true.
true
external
Whether the network is an external network, optional:
·     true.
·     false.
false
Name of the physical interface, optional.
phy1
Type of the network, optional:
·     vlan.
·     vxlan.
vxlan
ID of the network segment, optional. The value is an integer in the range of 1 to 16777215.
222
mtu
Value of the network MTU, optional. The value is an integer in the range of 68 to 65535.
1450
state
Execution state, optional:
·     absent—Delete.
·     present—Create.
The default value is present.
present
Creating a port playbook
- name: port
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.port:
      auth:
        username: admin
        password: Pwd@12345
network_name: “network1”
mac_address“00:50:56:bd:2c:b6”
fixed_ips:[{“subnet_name”:”sub1”, ”ip_address”:”99.0.92.8”}]
binding_profile:{"enable_snat": true, "fw_enabled": “true”}
port_security_enabled: true
port_securities_name:[“sq1”, ”sg2”]
qos_name: “qos1”
state:present
Table 3 Parameter description
Parameter
Example
name
port
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn.port
Port module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of the virtual port, required.
port1
network_name
Name of the network in which the port resides, required.
network1
mac_address
MAC address of the port, optional.
00:50:56:bd:2c:b6
fixed_ips
IP address of the port, required. This parameter is list type.
binding_profile
Customized data, optional. This parameter is dictionary type.
Port security, optional:
·     true.
·     false.
true
Name of the security group to which the port is bound, optional. This parameter is list type.
[“sq1”, ”sg2”]
qos_name
Name of QoS policy to which the port is bound, optional.
qos1
state
·     absent—Delete.
·     present—Create.
present
Creating a QoS playbook
- name: qos
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.qos:
      auth:
        username: admin
        password: Pwd@12345
      policies: {"dscp": "3", "rateUnit": "Kbps", "rx_averateLimit": "22", "rx_brustsize": "33","tx_averateLimit": "33","tx_brustsize": "22"}
      state: present
Table 4 Parameter description
Parameter
Example
name
qos
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn.qos
QoS module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of QoS policy, required.
qos1
policies
QoS policy, optional. This parameter is dictionary type.
{"dscp": "3", "rateUnit": "Kbps", "rx_averateLimit": "22", "rx_brustsize": "33", "tx_averateLimit": "33", "tx_brustsize": "22"}
state
·     absent—Delete.
·     present—Create.
present
Creating a router playbook
- name: router
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.router:
      auth:
        username: admin
        password: Pwd@12345
      provider_segmentation_id: 123
      router_internal_subnet_interface_name: [“sub1”, ”sub2”]
      external_gateway: “external_network”
      state: present
Table 5 Parameter description
Parameter
Example
name
router
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn.router
Router module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of the vRouter, required.
router1
tenant_name
Name of the tenant to which the router belongs, required.
ansible
admin_state_up
·     true.
·     false.
true
L3VNI, an integer in the range of 1 to 16777215.
123
Name of the internal subnet to which the router is bound, optional. This parameter is list type.
[“sub1”, ”sub2”]
external_gateway
Network name of the gateway, optional.
external_network
state
·     absent—Delete.
·     present—Create.
present
Creating a security group playbook
- name: security_group
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.security_group:
      auth:
        username: admin
        password: Pwd@12345
      ip_mac_binding: true
      empty_rule_action: deny
      securityrules: [{"direction": "ingress","ipprefix": "66.0.3.0/24","protocol": "TCP","ip_version": "4","portrange_max": "49","portrange_min": "3"}]
      state: present
Table 6 Parameter description
Parameter
Example
name
security_group
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn. security_group
Security group module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of the security group, required.
sg1
tenant_name
Name of the tenant to which the security group belongs, required.
ansible
ip_mac_binding
IP-MAC spoofing prevention, required.
·     true.
·     false.
true
empty_rule_action
Action to be taken if no rule is specified, optional:
·     permit.
·     deny.
The default value is permit.
deny
securityrules
Rule of the security group, optional. This parameter is list type.
state
·     absent—Delete.
·     present—Create.
present
Creating a subnet playbook
- name: subnet
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.subnet:
      auth:
        username: admin
        password: Pwd@12345
      cidr: “99.0.98.0/24”
      ip_version: “4”
      gateway_ip: “99.0.98.1”
      enable_dhcp: true
      allocation_pools: [{"start": "99.0.98.1","end":"99.0.98.25"}]
      dns_nameservers[“99.0.9.9”]
      leaseTime: 365
      dhcp_options: {"server_identifier":"99.0.98.2","domain_name":"dhcp_domain"}
      ipv6_address_mode: dhcpv6-stateless
      ipv6_ra_mode: dhcpv6-stateless
      state: present
Table 7 Parameter description
Parameter
Example
name
subnet
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn. subnet
Subnet module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of the vSubnet, required.
subnet1
network_name
Name of the network to which the vSubnet belongs, required.
network1
cidr
Network address, required.
99.0.98.0/24
ip_version
Version of the IP address, required:
·     4
·     6
4
gateway_ip
IP address of the gateway, optional.
99.0.98.1
enable_dhcp
Whether to enable DHCP for the subnet, optional:
·     true.
·     false.
true
allocation_pools
Subnet address pool, optional. This parameter is list type.
dns_nameservers
DNS server list, optional. This parameter is list type.
[“99.0.9.9”]
leaseTime
Lease time of the DHCP client address, optional. This parameter is supported by only IPv4. The default value is 365.
365
dhcp_options
DHCP options, optional. This parameter is dictionary type.
ipv6_address_mode
IPv6 address mode, optional:
·     None.
·     slaac.
·     dhcpv6-stateful.
·     dhcpv6-stateless.
dhcpv6-stateless
ipv6_ra_mode
IPv6 RA mode, optional:
·     None.
·     slaac.
·     dhcpv6-stateful.
·     dhcpv6-stateless.
dhcpv6-stateless
state
·     absent—Delete.
·     present—Create.
present
Creating a tenant playbook
- name: tenant
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.tenant:
      auth:
        username: admin
        password: Pwd@12345
      type: local-create
      vds_list: “VDS1”
      state: present
Table 8 Parameter description
Parameter
Example
name
tenant
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn.tenant
Tenant module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of the tenant, required.
ansible
type
Source of the tenant, required:
·     default.
·     local-create.
·     import.
·     iam.
local-create
vds_list
VDS of the tenant, required.
VDS1
state
·     absent—Delete.
·     present—Create.
present
Creating a device playbook
- name: device
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.device:
      auth:
        username: admin
        password: Pwd@12345
description: “my_device”
type: EDGW
management_ip: “99.0.50.159”
management_ip6: “64::64”
vtep_ip: “159.159.159.159”
vtep_ip6: “77::77”
dci_vtep_ip: “180.180.180.180”
dci_vtep_ip6: “88::88”
fabric_name: “fabric1”
prior_region_name: “region1”
label: “biaoqian”
smooth_flag: “ON”
snmp_parameter_version: SNMP_V2
snmp_parameter_community_write: “write”
snmp_parameter_community_read: “read”
snmp_parameter_user_name: “sdn”
snmp_parameter_authentication_protocol: MD5
snmp_parameter_authentication_password: “1qaz2wsx3ed”
snmp_parameter_privacy_protocol: DES
snmp_parameter_privacy_password: “2wsx3edc1qaz”
netconf_name: “root”
netconf_password: “123456”
openflow_connection_vrf: “vrf1”
openflow_inband_management_vlan: “200”
openflow_ssl_policy_name: “ssl1”
openflow_ssl_access_control_policy_name: “ssl2”
openflow_controller_port: 6633
openflow_forbidden_port: 0
reserve_tunnel_id: 256
role_name: leaf
state: present
Table 9 Parameter description
Parameter
Example
name
device
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn.device
Device module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
name
Name of the device, required.
device1
description
Description for the device, optional
my_device
type
Type of the device, required:
·     UNDERLAY_DEVICE.
·     EDGW.
·     EDGW_BORDER.
·     TRADITIONAL_DEVICE.
EDGW
management_ip
IPv4 address for device management. You must specify an IPv4 or IPv6 address for device management.
This parameter is mutually exclusive with the management_ip6 parameter.
99.0.50.159
management_ip6
IPv6 address for device management. You must specify an IPv4 or IPv6 address for device management.
This parameter is mutually exclusive with the management_ip parameter.
64::64
vtep_ip
VXLAN tunnel endpoint (VTEP) IPv4 address. This parameter is required when the value of the type parameter is UNDERLAY_DEVICE, EDGW, or EDGW_BORDER and not required when the value of the type parameter is TRADITIONAL_DEVICE.
159.159.159.159
vtep_ip6
VXLAN tunnel endpoint (VTEP) IPv6 address. This parameter is required when the value of the type parameter is UNDERLAY_DEVICE, EDGW, or EDGW_BORDER and not required when the value of the type parameter is TRADITIONAL_DEVICE.
77::77
dci_vtep_ip
VTEP IPv4 address for DC interconnection, optional.
180.180.180.180
dci_vtep_ip6
VTEP IPv6 address for DC interconnection, optional.
88::88
fabric_name
Name of the fabric to which the device belongs.
If you do not configure this parameter, the default fabric on the controller is used. If the controller does not have a default fabric, you must configure this parameter.
fabric1
prior_region_name
Name of the preferential region, optional.
region1
label
Label, optional.
biaoqian
smooth_flag
How data is synchronized between the controller and device when the device is activated, optional:
·     DEFAULT.
·     ON.
·     OFF.
The default value is DEFAULT. If you select ON or OFF, add double quotation marks for it.
"ON"
SNMP version, optional:
·     SNMP_V2.
·     SNMP_V3.
SNMP_V2
SNMP read-write community string, optional. This parameter takes effect only when the value of the snmp_parameter_version parameter is SNMP_V2.
write
SNMP read-only community string, optional. This parameter takes effect only when the value of the snmp_parameter_version parameter is SNMP_V2.
read
SNMPv3 username, a case-sensitive string of 1 to 32 characters. Chinese characters are not supported.
This parameter is required and takes effect only when the value of the snmp_parameter_version parameter is SNMP_V3.
sdn
SNMPv3 authentication algorithm, optional:
·     MD5.
·     SHA.
This parameter takes effect only when the value of the snmp_parameter_version parameter is SNMP_V3.
MD5
SNMPv3 authentication password, a string of 10 to 64 characters that must contain a minimum of two of the four character types: digits, uppercase letters, lowercase letters, and special characters. Chinese characters, quotation marks (?), spaces, username, and username spelled backward are not supported.
This parameter is required and takes effect only when the snmp_parameter_authentication_protocol parameter is configured.
1qaz2wsx3ed
SNMPv3 encryption algorithm, optional:
·     DES.
·     AES128.
·     AES192.
·     AES256.
·     3DES.
This parameter takes effect only when the snmp_parameter_authentication_protocol parameter is configured.
DES
SNMPv3 encryption password, a string of 10 to 64 characters that must contain a minimum of two of the four character types: digits, uppercase letters, lowercase letters, and special characters. Chinese characters, quotation marks (?), spaces, username, and username spelled backward are not supported.
This parameter is required and takes effect only when the snmp_parameter_privacy_protocol parameter is configured.
2wsx3edc1qaz
netconf_name
NETCONF username. You can leave this parameter unconfigured if the NETCONF username of the device is consistent with the default NETCONF username configured for devices on the controller. If not consistent, you must configure this parameter.
root
netconf_password
NETCONF password. You can leave this parameter unconfigured if the NETCONF password of the device is consistent with the default NETCONF password configured for devices on the controller. If not consistent, you must configure this parameter.
123456
VRF to which the controller belongs specified for the device to establish OpenFlow connection with the controller.
vrf1
In-band management VLAN ID or range in the range of 1 to 4094, optional.
200
SSL client policy name, optional.
ssl1
Certificate access control policy name, optional.
ssl2
Port number used by the controller for establishing OpenFlow connection with the device, optional. The value is an integer in the range of 1 to 65535.
6633
Forbidden port number in the OpenFlow instance, option. The value is an integer in the range of 0 to 7.
0
reserve_tunnel_id
Number of tunnels reserved for other services. The value is an integer in the range of 0 to 64000. The default value is 256.
256
role_name
Role of the device, optional:
·     spine.
·     aggr.
·     leaf.
·     access.
leaf
state
·     absent—Delete.
·     present—Create.
present
Creating an interface playbook
- name: interface
  hosts: localhost
  gather_facts: false
  become: false
  tasks:
  - h3c.sdn.interface:
      auth:
        username: admin
        password: Pwd@12345
      device_name: “device1”
      if_index: “XGE2/1/1”
      state: present
Table 10 Parameter description
Parameter
Example
name
interface
hosts
localhost
gather_facts
·     true.
·     false.
false
become
·     true.
·     false.
false
tasks
N/A
h3c.sdn.interface
Interface module that the task calls.
N/A
auth
N/A
url
username
admin
password
Pwd@12345
device_name
Device name, required.
device1
if_index
Device interface name.
XGE2/1/1
state
·     absent—Delete.
·     present—Create.
present
Running playbooks
To run a playbook, execute the ansible-playbook xxx.yaml command. The following example runs the network playbook.
[root@localhost ~]# ansible-playbook h3c_network.yaml
