| 04-URL filtering commands | 175.69 KB |
display url-filter signature library
update schedule (automatic URL signature library update configuration view)
url-filter log except pre-defined
url-filter log except user-defined
url-filter signature auto-update
url-filter signature auto-update-now
add
Use add to add a blacklist or whitelist rule to a URL filtering policy.
Use undo add to delete a blacklist or whitelist rule from a URL filtering policy.
add { blacklist | whitelist } [ id ] host { regex host-regex | text host-name } [ uri { regex uri-regex | text uri-name } ]
undo add { blacklist | whitelist } { id | all }
No blacklist or whitelist rules exist in a URL filtering policy.
URL filtering policy view
blacklist: Specifies the blacklist rule type.
whitelist: Specifies the whitelist rule type.
id: Specifies a rule ID. The value must be an integer in the range of 1 to 65535. The ID of a blacklist or whitelist rule must be unique among all rules of the same type. If you do not specify a rule ID, the system automatically assigns an available ID to the rule according to the largest rule ID N used on the device:
· If N is smaller than 65535, the smallest available ID that is larger than N is used.
· If N equals to 65535, the smallest available ID is used.
host: Matches the host field in the URL.
uri: Matches the URI field in the URL.
regex regex: Specifies a case-sensitive regular expression string pattern. The string can start with only letters, digits, or underscores (_), and it must contain a minimum of three consecutive non-wildcard characters.
· If the host keyword is specified, the string can contain 3 to 224 characters.
· If the uri keyword is specified, the string can contain 3 to 245 characters.
text string: Specifies a case-insensitive text string pattern, which must contain a minimum of three consecutive non-wildcard characters.
· If the host keyword is specified, the string can contain 3 to 224 characters. Valid characters are letters, digits, underscores (_), hyphens (-), colons (:), left square brackets ([), right square brackets (]), dots (.), and asterisk (*).
all: Specifies all rules of the specified type.
The device supports using URL-based whitelist and blacklist rules to filter HTTP packets. If the URL in an HTTP packet matches a blacklist rule, the packet is dropped. If the URL matches a whitelist rule, the packet is permitted to pass through.
Follow these guidelines when you use the asterisk character (*) in the text string pattern for hostname or URI matching:
· For hostname matching, the asterisk (*) can appear only at the beginning or end of the text string pattern as a wildcard character to match zero or more characters.
· For URI matching, the asterisk (*) can appear at the beginning or end of the text string pattern as a wildcard character to match zero or more characters, or appear in the middle as a non-wildcard character.
When you configure a regular expression in a blacklist or whitelist rule, follow these restrictions and guidelines:
· The regular expression pattern can contain a maximum of four branches. For example, 'abc(c|d|e|\x3D)' is valid, and 'abc(c|onreset|onselect|onchange|style\x3D)' is invalid.
· Nested braces are not allowed. For example, 'ab((abcs*?))' is invalid.
· A branch cannot be specified after another branch. For example, 'ab(a|b)(c|d)^\\r\\n]+?' is invalid.
· A minimum of four non-wildcard characters must exist before an asterisk (*) or question mark (?). For example, 'abc*' is invalid and 'abcd*DoS\x2d\d{5}\x20\x2bxi\\r\\nJOIN' is valid.
# In URL filtering policy news, add a blacklist rule to match URLs with the host field starting with games.com.
[Sysname] url-filter policy news
[Sysname-url-filter-policy-news] add blacklist 1 host text games.com*
category action
Use category action to specify actions for a URL category.
Use undo category to remove the action setting from a URL category.
category category-name action { block-source [ parameter-profile parameter-name ] | drop | permit | redirect parameter-profile parameter-name | reset } [ logging [ parameter-profile parameter-name ] ]
undo category category-name
A URL category does not have any action specified.
category-name: Specifies a URL category by its name, a case-insensitive string of 1 to 63 characters. Chinese characters are supported.
action: Specifies the action for the matching packets.
block-source: Drops matching packets and adds the sources of the packets to the IP blacklist. If the IP blacklist feature is enabled, packets from the blacklisted sources will be blocked for a duration set by the block-period command. If the IP blacklist feature is not enabled, packets from the blacklisted sources are not blocked. For more information about the IP blacklist feature, see Security Configuration Guide. For information about configuring the block period, see "DPI engine commands."drop: Drops matching packets.
permit: Permits matching packets to pass.
redirect: Redirects matching packets to a webpage.
reset: Disconnects the TCP connection for matching packets.
logging: Logs matching packets.
parameter-profile parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a profile, or if the specified profile does not exist, the URL filtering action uses the default parameter settings. For information about configuring parameter profiles, see "DPI engine commands."Usage guidelines
If an HTTP packet matches a URL filtering rule in a URL category, the action specified for the category applies to the packet.
If the packet matches none of URL filtering rules in the URL filtering policy, the default action specified for the policy applies to the packet. If the default action is not configured, the device permits the packet to pass.
If you execute this command for a URL category multiple times, the most recent configuration takes effect.
# In the URL filtering policy news, specify the drop action for the URL category sina.
[Sysname-url-filter-policy-news] category sina action drop
inspect block-source parameter-profile
inspect redirect parameter-profile
url-filter category
url-filter policy
default-action
Use default-action to specify the default action for a URL filtering policy.
Use undo default-action to restore the default.
default-action { block-source [ parameter-profile parameter-name ] | drop | permit | redirect parameter-profile parameter-name | reset } [ logging [ parameter-profile parameter-name ] ]
undo default-action
A URL filtering policy does not have any default action.
block-source: Drops matching packets and adds the sources of the packets to the IP blacklist. If the IP blacklist feature is enabled, packets from the blacklisted sources will be blocked for a duration set by the block-period command. For more information about the IP blacklist feature, see Security Configuration Guide. For information about configuring the block period, see "DPI engine commands."
permit: Permits packets to pass.
parameter-profile parameter-name: Specifies a DPI action parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a profile, or if the specified profile does not exist, the DPI action uses the default parameter settings. For information about configuring parameter profiles for DPI actions, see "DPI engine commands."
The default action applies to packets that do not match any URL filtering rules.
# Set the default action to drop for URL filtering policy cmcc.
[Sysname] url-filter policy cmcc
[Sysname-url-filter-policy-cmcc] default-action drop
url-filter policy
description
Use description to configure a description for a URL category.
A user-defined URL category does not have a description.
URL category view
text: Specifies a description, a case-insensitive string of 1 to 255 characters. Spaces are allowed.
Use this command to configure descriptions for URL categories for easy maintenance.
# Configure the description as News information for URL category news.
[Sysname] url-filter category news
[Sysname-url-filter-category-news] description News information
display url-filter category
Use display url-filter category to display URL category information.
display url-filter { category | parent-category } [ verbose ]
category: Specifies child URL categories.
parent-category: Specifies parent URL categories.
verbose: Display detailed URL category information. If you do not specify this keyword, this command displays the summarized URL category information.
The device supports two levels of predefined URL categories: child URL category and parent URL category. A predefined parent URL category contains only predefined child URL categories.
# Display information about child URL categories.
<Sysname> display url-filter category
URL category statistics:
Predefined categories: 53
Predefined rules: 2000
User-defined categories: 5
User-defined rules: 4
URL categories:
# Display detailed information about child URL categories.
<Sysname> display url-filter category verbose
URL category details:
Type: User defined
Severity: 1001
Rules: 1
Description:
Type: User defined
Severity: 1002
Rules: 1
Description:
Type: Predefined
Severity: 300
Rules: 32
Description: Sites that provide advertising graphics or other ad content fi
les such as banners and pop-ups.
Type: Predefined
Severity: 960
Rules: 7
Description: Sites that promote or sell alcohol- or tobacco-related product
s or services.
Predefined categories |
Number of predefined child URL categories. |
Predefined rules |
Number of predefined URL filtering rules. |
User-defined categories |
Number of user-defined child URL categories. |
User-defined rules |
Number of user-defined URL filtering rules. |
URL category details |
Detailed information about the child URL categories. |
Name |
Name of the child URL category. |
Type |
Type of the child URL category, Predefined or User Defined. |
Severity |
Severity level of the child URL category. |
Rules |
Number of rules in the child URL category. |
# Display information about parent URL categories.
<Sysname> display url-filter parent-category
URL parent category statistics:
Predefined parent categories: 40
Included predefined categories: 14
URL parent categories:
Parent category name: SearchEngineAndPortal
Parent category name: P2PAndDownload
Parent category name: OrdinaryDownload
Parent category name: House
Parent category name: EducationAndScientificResearch
Parent category name: Finance
Parent category name: StreamMediaAndVideo
Parent category name: Shopping
Parent category name: TransportationVehicle
Parent category name: Travel
# Display detailed information about parent URL categories.
<Sysname> display url-filter parent-category verbose
Predefined parent categories: 46
Included predefined categories: 139
URL parent category details:
Parent category name: Pre-Adult
Type: Predefined
Description: Adult
Included categories: 7
Pre-Abortion
Pre-AdultSuppliers
Pre-Homosexual
Pre-Nudity
Pre-OtherAdult
Pre-SexualHealth
Pre-Vulgar
Parent category name: Pre-Arts
Type: Predefined
Description: Arts
Included categories: 1
Pre-Arts
Predefined parent categories |
Number of predefined parent URL categories. |
Included predefined categories |
Total number of predefined URL categories included in all parent URL categories. |
URL parent category details |
Detailed information about the parent URL categories. |
Parent category name |
Name of the parent URL category. |
Type |
Type of the parent URL category. The device supports only predefined parent URL categories. |
Description of the parent URL category. |
Included categories |
Number of child URL categories in the parent URL category. |
Use display url-filter signature library to display information about the URL signature library.
# Display information about the URL signature library.
<Sysname> display url-filter signature library
URL filter signature library information:
Type SigVersion ReleaseTime Size
Current 1.0.0 Wed Jan 21 06:43:53 2015 36096
(null) - - -
Factory 1.0.0 Wed Jan 21 06:43:53 2015 36096
Type |
Version of the URL signature library: · Current—Current version. · Last—Previous version. · Factory—Factory default version. |
SigVersion |
Version number. |
ReleaseTime |
Time when the URL signature library was released. |
Size |
Size of the URL signature library, in bytes. |
display url-filter statistics
Use display url-filter statistics to display URL filtering statistics.
# Display URL filtering statistics.
<Sysname> display url-filter statistics
Slot 1 :
Total HTTP requests : 0
Total HTTPS handshakes : 0
Total logged requests : 0
Total logging rate : 0/s
Total permitted requests and handshakes : 0
Total denied requests : 0
Requests that matched the blacklist : 0
Requests that matched the whitelist : 0
Requests that matched the referer-whitelist : 0
Requests that matched a user-defined rule : 0
Requests that matched a predefined rule : 0
Requests that matched a cached rule : 0
Requests that matched the default action : 0
Requests that matched URLs in URL reputation library : 0
Predefined URL filtering rules : 2000
Total HTTP requests |
Total number of HTTP packets. |
Total HTTPS handshakes |
Total number of encrypted traffic hits. |
Total logged requests |
Total number of logged HTTP packets. |
Total HTTP logging rate |
Logging rate for HTTP packets. |
Total permitted HTTP requests |
Total number of permitted HTTP packets. |
Total denied HTTP requests |
Total number of denied HTTP packets. |
Requests that matched the blacklist |
Number of HTTP packets that matched a blacklist rule. |
Requests that matched the whitelist |
Number of HTTP packets that matched a whitelist rule. |
Requests that matched the referer-whitelist |
Number of HTTP packets with a referer header that matched a whitelist rule. |
Requests that matched a user-defined rule |
Number of HTTP packets that matched a user-defined URL filtering rule. |
Requests that matched a predefined rule |
Number of HTTP packets that matched a predefined URL filtering rule. |
Requests that matched a cached rule |
Number of HTTP packets that matched a cached URL filtering rule. |
Requests that matched the default action |
Number of HTTP packets on which the default action is executed. |
Requests that matched URLs in URL reputation library |
This field is not supported in the current software version. Total number of requests that matched URLs in the URL reputation library. |
Predefined URL filtering rules |
Total number of predefined URL filtering rules. |
include pre-defined
Use include pre-defined to add the URL filtering rules of a predefined URL category to a user-defined URL category.
Use undo include pre-defined to restore the default.
include pre-defined category-name
A user-defined URL category does not contain the URL filtering rules of any predefined URL category.
URL category view
category-name: Specifies a predefined URL category by its name, a case-sensitive string of 1 to 63 characters. The specified URL category must exist on the device.
To simplify URL category configuration, you can use this command to add the URL filtering rules of a predefined URL category to a user-defined URL category.
You can add URL filtering rules of only one predefined URL category to a user-defined URL category. If you execute this command for a URL category multiple times, the most recent configuration takes effect.
# Add the URL filtering rules of predefined URL category Pre-Arts to URL category news.
[Sysname-url-filter-category-news] include pre-defined Pre-Arts
referer-whitelist enable
Use referer-whitelist enable to enable referer whitelist.
Use undo referer-white enable to disable referer whitelist.
undo referer-whitelist enable
Referer whitelist is enabled.
The referer whitelist is useful when you want to allow users to access links on the webpages that match the whitelist rules.
If this feature is disabled, the users can visit a webpage when the URL of the webpage matches a whitelist rule, but other links on the accessed webpage are inaccessible. To solve the preceding problem, you can enable this feature. It allows the device to extract the referer header of an HTTP or HTTPS request and compare the referer header with whitelist rules. If a match is found, the device permits the HTTP or HTTPS request to pass through. If no match is found, the device drops the HTTP or HTTPS request.
# Enable referer whitelist in URL filtering policy news.
[Sysname-url-filter-policy-news] referer-whitelist enable
add
rename
Use rename to rename a URL filtering policy.
rename new-name
new-name: Specify a new name for the URL filtering policy, a case-insensitive string of 1 to 31 characters.
If you change the name of a URL filtering policy that has been assigned to a DPI application profile, the policy name in the DPI application profile is also changed.
# Rename URL filtering policy news to hello, and enter the view of URL filtering policy hello.
[Sysname-url-filter-policy-news] rename hello
[Sysname-url-filter-policy-hello]
reset url-filter statistics
Use reset url-filter statistics to clear URL filtering statistics.
# Clear URL filtering statistics.
<Sysname> reset url-filter statistics
rule
Use rule to create a URL filtering rule for a user-defined URL category.
Use undo rule to delete a URL filtering rule from a user-defined URL category.
rule rule-id host { regex regex | text string } [ uri { regex regex | text string } ]
undo rule rule-id
A user-defined URL category does not have any URL filtering rules.
URL category view
rule-id: Assigns an ID to the URL filtering rule, in the range of 1 to 65535.
host: Matches URLs by the hostname field.
uri: Matches URLs by the URI field.
regex regular-expression: Specifies a case-sensitive regular expression string pattern. The string can start with only letters, digits, or underscores (_), and it must contain a minimum of three consecutive non-wildcard characters.
· If the uri keyword is specified, the string can contain 3 to 253 characters.
· If the uri keyword is specified, the string can contain 3 to 255 characters.
A URL filtering rule supports the following URL matching methods:
· Text-based matching—Matches the hostname and URI fields of a URL against text string patterns.
When performing text-based matching for the hostname field of a URL, the device first determines if the text string pattern contains the asterisk (*) wildcard character at the beginning or end.
¡ If the text string pattern does not contain the asterisk (*) wildcard character at the beginning or end, the hostname matching succeeds if the hostname of the URL matches the text string pattern.
¡ If the text string pattern contains the asterisk (*) wildcard character at the beginning, the hostname matching succeeds if the hostname of the URL matches or ends with the text string pattern without the wildcard character.
¡ If the text string pattern contains the asterisk (*) wildcard character at the end, the hostname matching succeeds if the hostname of the URL matches or starts with the text string pattern without the wildcard character.
¡ If the text string pattern contains the asterisk (*) wildcard character at both the beginning and the end, the hostname matching succeeds if the hostname of the URL matches or includes the text string pattern without the wildcard characters.
Text-based matching for the URI field works in the same way that text-based matching for the hostname field works.
· Regular expression-based matching—Matches the hostname and URI fields of a URL against regular expressions. For example, if you set the regular expression for hostname matching to sina.*cn, URLs that carry the news.sina.com.cn hostname will be matched.
Follow these guidelines when you use the asterisk character (*) in the text string for hostname or URI matching:
· For hostname matching, the asterisk (*) can appear only at the beginning or end of the text string as a wildcard character to match zero or more characters.
When you configure a regular expression in a URL filtering rule, follow these restrictions and guidelines:
# In URL category news, create a URL filtering rule to match URLs with the host field starting with sina.com.
[Sysname-url-filter-category-news] rule 10 host text sina.com*
url-filter category
Use update schedule to configure a schedule for automatic URL signature library update.
Use undo update schedule to restore the default.
The following compatibility matrixes show the support of hardware platforms for this command:
Series |
Models |
Product codes |
Command compatibility |
WX2500X series |
WX2560 WX2580X |
EWP-WX2560X EWP-WX2580X |
Yes |
Series |
Models |
Product codes |
WX2800X series |
WX2812X-PWR WX2860X WX2880X |
EWP-WX2812X-PWR EWP-WX2860X EWP-WX2880X |
Yes |
WSG1800X series |
WSG1812X-PWR WSG1840X |
EWP-WSG1812X-PWR EWP-WSG1840X |
No |
The device starts the URL signature library update at a random time between 01:00:00 and 03:00:00 every day.
Automatic URL signature library update configuration view
daily: Updates the URL signature library every day.
weekly: Updates the URL signature library every week.
fri: Updates the URL signature library every Friday.
mon: Updates the URL signature library every Monday.
sat: Updates the URL signature library every Saturday.
sun: Updates the URL signature library every Sunday.
thu: Updates the URL signature library every Thursday.
tue: Updates the URL signature library every Tuesday.
wed: Updates the URL signature library every Wednesday.
start-time time: Specifies the start time in hh:mm:ss format. The value range is 00:00:00 to 23:59:59.
tingle minutes: Specifies the tolerance time in minutes. The value range is 0 to 120. An automatic library update will start at a random time between the following time points:
· Start time minus half the tolerance time.
· Start time plus half the tolerance time.
# Configure the device to automatically start the URL signature library update every Sunday at a random time between 20:25:00 and 20:35:00.
[Sysname] url-filter signature auto-update
[Sysname-url-filter-autoupdate] update schedule weekly sun start-time 20:30:00 tingle 10
url-filter signatures auto-update
url-filter apply policy
Use url-filter apply policy to apply a URL filtering policy to a DPI application profile.
Use undo url-filter apply policy to remove the URL filtering policy from a DPI application profile.
url-filter apply policy policy-name
No URL filtering policy is applied to a DPI application profile.
DPI application profile view
policy-name: Specifies a URL filtering policy by its name, a case-insensitive string of 1 to 31 characters.
A URL filtering policy takes effect only after it is applied to a DPI application profile.
You can apply only one URL filtering policy to a DPI application profile. If you execute this command multiple times, the most recent configuration takes effect.
# Apply URL filtering policy news to DPI application profile abc.
[Sysname] app-profile abc
[Sysname-app-profile-abc] url-filter apply policy news
app-profile
display app-profile
display url-filter policy
url-filter category
Use url-filter category to create a user-defined URL category and enter its view, or enter the view of an existing URL category.
Use undo url-filter category to delete a URL category.
url-filter category category-name [ severity severity-level ]
undo url-filter category category-name
The device has only predefined URL categories with the name prefix Pre-.
category-name: Specify the URL category name, a case-insensitive string of 1 to 63 characters. Valid characters are letters, Chinese characters, digits, underscores (_), hyphens (-), and dots (.). The category name cannot start with Pre- and must be different from the Chinese name of any predefined URL category.
severity severity-value: Specifies a severity level for the URL category. The value range is 1000 to 65535, and the default is 65535. The larger the value, the higher the severity level. The severity level of each user-defined URL category must be unique. This option is required when you create a URL category.
URL filtering provides the URL categorization feature to facilitate filtering rule management.
You can classify multiple URL filtering rules into a URL category and specify an action for the category. If a matching rule is in multiple URL categories, the system takes the action for the category with the highest severity level.
URL filtering supports the following types of URL categories:
· Predefined URL categories.
The predefined URL categories contain the predefined URL filtering rules. Each predefined URL category has a unique severity level in the range of 1 to 999, and a category name that begins with Pre-. Predefined URL categories cannot be modified.
· User-defined URL categories.
You can create user-defined URL categories and configure filtering rules for them. The severity level of a user-defined URL category is in the range of 1000 to 65535. You can edit the filtering rules and change the severity level for a user-defined URL category.
# Create a URL category named news and set its severity level to 2000.
[Sysname] url-filter category news severity 2000
url-filter copy category
Use url-filter copy policy to copy a URL category.
url-filter copy category old-name new-name severity severity-level
old-name: Specifies the name of the URL category to be copied. The specified URL category must already exist.
new-name: Specifies a name for the new URL category. The name is a case-insensitive string of 1 to 63 characters and cannot begin with Pre.
severity severity-level: Assigns a unique severity level to the new URL category. The value range is 1000 to 65535. The larger the value, the higher the severity level.
This command allows you to create a new URL category by copying an existing one.
The device supports copying only user-defined URL categories.
# Create URL category test by copying URL category news.
[Sysname] url-filter copy category news test severity 1001
[Sysname-url-filter-category-test]
url-filter category
Use url-filter copy policy to copy a URL filtering policy.
url-filter copy policy old-name new-name
old-name: Specifies the name of the URL filtering policy to be copied, a case-insensitive string of 1 to 31 characters.
new-name: Specifies a name for the new URL filtering policy, a case-insensitive string of 1 to 31 characters.
This command allows you to create a new URL filtering policy by copying an existing one.
# Create two URL filtering policies by copying URL filtering policy news.
[Sysname] url-filter copy policy news news1
[Sysname-url-filter-policy-news_1] quit
[Sysname] url-filter copy policy news new2
[Sysname-url-filter-policy-news_2] quit
url-filter policy
url-filter log directory root
Use url-filter log directory root to configure URL filtering to log only access to resources in the root directories of websites.
Use undo url-filter log directory root to restore the default.
URL filtering logs access to Web resources in all directories.
After this command is configured, the url-filter log except pre-defined and url-filter log except user-defined commands become invalid.
# Configure URL filtering to log only access to resources in the root directories of websites.
[Sysname] url-filter log directory root
category action logging
default-action logging
url-filter log enable
Use url-filter log enable to enable DPI engine logging.
Use undo url-filter log enable to disable DPI engine logging.
DPI engine logging is disabled.
You can enable DPI engine logging for audit. Log messages generated by DPI engine are output to the device information center. The information center then sends the messages to designated destinations based on log output rules. For more information about the information center, see System Management Configuration Guide.
DPI engine logging is memory intensive. To guarantee system performance, enable DPI engine logging only when necessary.
# Enable DPI engine logging.
[Sysname] url-filter log enable
Use url-filter log except pre-defined to disable URL filtering logging for access to resources of a predefined resource type.
Use undo url-filter log except pre-defined to enable URL filtering logging for access to resources of a predefined resource type.
url-filter log except pre-defined { css | gif | ico | jpg | js | png | swf | xml }
undo url-filter log except pre-defined { css | gif | ico | jpg | js | png | swf | xml }
URL filtering does not log access to resources of the predefined resource types (CSS, GIF, ICO, JPG, JS, PNG, SWF, and XML resources).
css: Specifies the CSS resource type.
gif: Specifies the GIF resource type.
ico: Specifies the ICO resource type.
jpg: Specifies the JPG resource type.
js: Specifies the JS resource type.
png: Specifies the PNG resource type.
swf: Specifies the SWF resource type.
xml: Specifies the XML resource type.
Repeat this command to disable URL filtering logging for access to multiple types of predefined resources.
This command does not take effect if the url-filter log directory root command is configured. To validate this command, you must execute undo url-filter log directory root command.
# Disable URL filtering logging for access to CSS resources.
[Sysname] url-filter log except pre-defined css
Use url-filter log except user-defined to disable URL filtering logging for access to resources of a user-defined resource type.
Use undo url-filter log except user-defined to enable URL filtering logging for access to resources of a user-defined resource type.
url-filter log except user-defined text
undo url-filter log except user-defined [ text ]
URL filtering logs access to all resources except for resources of the predefined types.
text: Specifies a Web resource type. The value is a case-insensitive string of 1 to 63 characters.
Repeat this command to disable URL logging for access to multiple types of user-defined resources.
Executing the undo url-filter log except user-defined command without the text parameter enables URL logging for access to all resources except resources of the predefined resource types.
# Disable URL filtering logging for access to HTML resources.
[Sysname] url-filter log except user-defined html
url-filter policy
Use url-filter policy to create a URL filtering policy and enter its view, or enter the view of an existing URL filtering policy.
Use undo url-filter policy to delete a URL filtering policy.
url-filter policy policy-name
undo url-filter policy policy-name
No URL filtering policies exist.
policy-name: Assigns a name to the URL filtering policy, a case-insensitive string of 1 to 31 characters.
In a URL filtering policy, you can specify an action for each URL category. You can also use the default action command to specify the default action for packets that do not match any URL filtering rules in the policy.
A URL filtering policy takes effect only after it is applied to a DPI application profile. For information about DPI application profiles, see DPI Configuration Guide.
# Create a URL filtering policy named news and enter its view.
Use url-filter signature auto-update to enable automatic URL signature library update and enter automatic URL signature library update configuration view.
Use undo url-filter signature auto-update to disable automatic URL signature library update.
Series |
Models |
Product codes |
WX2500X series |
WX2560 WX2580X |
Yes |
Series |
Models |
Product codes |
WX2800X series |
Yes |
WSG1800X series |
No |
Automatic URL signature library update is disabled.
The automatic update enables the device to periodically access the company's website to download the latest URL filtering signatures and update the local signature library.
You can schedule the time for automatic signature update by using the update schedule command.
# Enable automatic URL signature library update and enter automatic URL signature library update configuration view.
update schedule
Use url-filter signature auto-update-now to trigger an automatic URL signature library update manually.
Series |
Models |
Product codes |
WX2500X series |
WX2560 WX2580X |
Yes |
Series |
Models |
Product codes |
WX2800X series |
Yes |
WSG1800X series |
No |
This command immediately starts the automatic signature library update process. The device accesses the company's website to update the local URL signature library.
You can execute this command anytime you find a new version of signature library on the company's website.
# Trigger an automatic URL signature library update manually.
[Sysname] url-filter signature auto-update-now
url-filter signature rollback
Use url-filter signature rollback to roll back the URL signature library.
url-filter signature rollback { factory | last }
Series |
Models |
Product codes |
WX2500X series |
WX2560 WX2580X |
Yes |
Series |
Models |
Product codes |
WX2800X series |
Yes |
WSG1800X series |
No |
factory: Rolls back the URL signature library to the factory default version.
last: Rolls back the URL signature library to the previous version.
If a URL signature library update causes exceptions or a high false alarm rate, you can roll back the URL signature library.
Before rolling back the URL signature library, the device backs up the current signature library as the "previous version." For example, the previous library version is V1 and the current library version is V2. If you perform a rollback to the previous version, library version V1 becomes the current version and library version V2 becomes the previous version. If you perform a rollback to the previous version again, the library rolls back to library version V2.
# Roll back the URL signature library to the previous version.
[Sysname] url-filter signature rollback last
url-filter signature update
Use url-filter signature update to manually update the URL signature library.
url-filter signature update file-path
Series |
Models |
Product codes |
WX2500X series |
WX2560 WX2580X |
Yes |
Series |
Models |
Product codes |
WX2800X series |
Yes |
WSG1800X series |
No |
file-path: Specifies the URL filtering signature file path, a string of 1 to 255 characters.
CAUTION: Select a signature file according to the memory size and software version of the device. H3C provides signature files separately for high-memory (equal to or higher than 8 GB) and low-memory (lower than 8 GB) devices and for different software versions. If you use a signature file applicable to high-memory devices to update the URL filtering signature library on a low-memory device, exceptions might occur on the low-memory device. As a best practice, use a signature file that is compatible with the software version and memory size of the device to update the URL filtering signature library on the device. |
If the device cannot access the company's website, use one of the following methods to manually update the URL signature library:
· Local update—Updates the URL signature library on the device by using the locally stored update URL filtering signature file.
The following describes the format of the file-path parameter for different update scenarios.
Update scenario |
Format of file-path |
Remarks |
The update file is stored in the current working directory. |
filename |
To display the current working directory, use the pwd command (see file system management in Fundamentals Command Reference). |
The update file is stored in a different directory on the same storage medium. |
filename |
Before updating the signature library, you must first use the cd command to open the directory where the file is stored. For information about the cd command, see file system management in Fundamentals Command Reference. |
The update file is stored on a different storage medium. |
path/filename |
Before updating the signature library, you must first use the cd command to open the root directory of the storage medium where the file is stored. For information about the cd command, see file system management in Fundamentals Command Reference. |
· FTP/TFTP update—Updates the URL signature library on the device by using the file stored on the FTP or TFTP server.
Update scenario |
Remarks |
The update file is stored on an FTP server. |
ftp://username:password@server address/filename |
The username parameter represents the FTP login username. The password parameter represents the FTP login password. The server address parameter represents the IP address or host name of the FTP server. Replace the following special characters in the FTP login username and password with their respective escape characters: · Colon (:)—%3A or %3a. · At sign (@)—%40. · Forward slash (/)—%2F or %2f. |
The update file is stored on a TFTP server. |
tftp://server address/filename |
The server address parameter represents the IP address or host name of the TFTP server. |
NOTE: To update the signature library successfully, make sure the device and the FTP or TFTP server can reach each other. If you specify the FTP or TFTP server by its host name, you must also make sure the device can resolve the host name into an IP address through static or dynamic DNS. For more information about DNS, see Network Connectivity Configuration Guide. |
# Manually update the local URL signature library by using a signature file stored on a TFTP server.
[Sysname] url-filter signature update tftp://192.168.0.10/url-filter-1.0.2-en.dat
# Manually update the local URL signature library by using a signature file stored on an FTP server. The FTP login username and password are user:123 and user@abc/123, respectively.
[Sysname] url-filter signature update ftp://user%3A123:user%40abc%[email protected]/url-filter-1.0.2-en.dat
# Manually update the local URL signature library by using a signature file stored on the device. The file is stored in directory cfa0:/url-filter-1.0.23-en.dat, and the current working directory is cfa0:.
[Sysname] url-filter signature update url-filter-1.0.23-en.dat
# Manually update the local URL signature library by using a signature file stored on the device. The file is stored in directory cfa0:/dpi/url-filter-1.0.23-en.dat, and the current working directory is cfa0:.
<Sysname> cd dpi
# Manually update the local URL signature library by using a signature file stored on the device. The file is stored in directory cfb0:/dpi/url-filter-1.0.23-en.dat, and the current working directory is cfa0:.
<Sysname> cd cfb0:/
[Sysname] url-filter signature update dpi/url-filter-1.0.23-en.dat
warning parameter-profile
Use warning parameter-profile to apply a warning parameter profile to a URL filtering policy, and enable sending the alarm message defined in the profile.
Use undo warning parameter-profile to restore the default.
warning parameter-profile profile-name
No warning parameter profile is applied and the device sends the default alarm message.
profile-name: Specifies a warning parameter profile by its name, a case-insensitive string of 1 to 63 characters. Valid characters are letters, digits, underscores (_).
If an endpoint user visits a website blocked by URL filtering, the device will display an alarm message on the user's browser. The alarm message is stored in the warning parameter profile applied to the URL filtering policy. For more information about configuring a warning parameter profile, see DPI engine configuration in DPI Configuration Guide.
If no warning parameter profile is applied to the URL filtering policy, the device sends the default alarm message to the user. The default alarm message is as follows:
Web Access Blocked
Your access to this website was denied. To access this webpage, contact Technical Support.
· Reason: XXX
· Category: XXX
· URL: XXXX
The device will generate the reason, category, and URL according to the actual condition.
· Reason—Why the URL of the website visited by the user is blocked. The following values are available:
¡ The URL of the website hit the URL blacklist.
¡ The URL of the website hit a user-defined URL category.
¡ The URL of the website hit a predefined URL category.
¡ No matching whitelist entry was found for the website in whitelist mode.
¡ The URL of the website did not match any accessible URL category.
¡ The URL of the website hit the URL reputation signature library.
· Category—Attack category of the hit user-defined URL category, predefined URL category, or URL reputation.
· URL—URL of the website visited by the user.
# Apply warning parameter profile uflt1 to URL filtering policy abc and enable the sending of alarm message defined in the profile.
[Sysname] url-filter policy abc
[Sysname-url-filter-policy-abc] warning parameter-profile uflt1
inspect url-filter warning parameter-profile
whitelist-only enable
Use whitelist-only enable to enable URL whitelist-only filtering.
Use undo whitelist-only enable to disable URL whitelist-only filtering.
URL whitelist-only filtering is disabled.
This feature allows only the HTTP or HTTPS requests that match the whitelist rules to pass through, and the other settings in the URL filtering policy will not take effect.
# Enable URL whitelist-only filtering in URL filtering policy news.
[Sysname-url-filter-policy-news] whitelist-only enable
add
