07-AP and WT Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WX2800X&WSG1800X Command References(E5611)-5W10107-AP and WT Management Command Reference
02-WT commands
02-WT commands 54.49 KB
WT commands
The following compatibility matrixes show the support of hardware platforms for WT:
Hardware series
Model
Product code
WT compatibility
WX2500X series
WX2560X
WX2580X
EWP-WX2560X
EWP-WX2580X
Yes
Hardware series
Model
Product code
WT compatibility
WX2800X series
WX2812X-PWR
WX2860X
WX2880X
EWP-WX2812X-PWR
EWP-WX2860X
EWP-WX2880X
No
WSG1800X series
WSG1812X-PWR
WSG1840X
EWP-WSG1812X-PWR
EWP-WSG1840X
No
display wlan wt
Use display wlan wt to display wireless terminator (WT) information and information about the wireless terminator units (WTUs) connected to it.
display wlan wt { all | name wt-name }
all: Specifies all WTs.
name wt-name: Specifies a WT by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display information about all WTs.
<Sysname> display wlan wt all
WT name          : wt1
Model            : WT1024-X-Q
Serial ID        : 219801A0SS9156G00072
MAC address      : 0000-f3ea-0a3e
WTU number       : 2
  Wireless Terminator Unit:
  WTU name      Port         Model      Serial ID
  wtu1          1            WTU430     219801A0SS9156G00185
  wtu2          2            WTU430     219801A0SS9156G00133
WT name          : wt2
Model            : WT1024-X-Q
Serial ID        : 219801A0SS9156G00068
MAC address      : 0000-f3ea-0a3a
WTU number       : 2
  wtu3          3            WTU430     219801A0SS9156G00054
  Wtu4          4            WTU430     219801A0SS9156G00167
Fields
WTU number
Number of WTUs that are connected to the WT.
WTU information.
Port
Port that connects the WT to a WTU.
poe wtu-port
Use poe wtu-port enable to enable PoE for a WTU port.
Use poe wtu-port disable to disable PoE for a WTU port.
Use undo poe wtu-port to restore the default.
poe wtu-port port-number1 [ to port-number2 ] { disable | enable }
undo poe wtu-port port-number1 [ to port-number2 ]
In AP view, an AP uses the configuration in an AP group's AP model view.
In an AP group's AP model view, PoE is enabled for WTU ports.
AP view
port-number1: Specifies the WTU port number. The value range varies by AP model.
port-number1 to port-number2: Specifies a WTU port range. The port-number1 argument represents the start port number, and the port-number2 argument represents the end port number. The end port number cannot be smaller than the start port number. Value range for a port number varies by AP model.
A WT stops power supply to the connected WTU through PoE after you disable PoE for a WTU port of the WT.
This command is configurable only when the AP is a WT.
# Disable PoE for WTU port 1 in AP view.
[Sysname] wlan ap ap1 model WT1024-X-Q
[Sysname-wlan-ap-ap1] poe wtu-port 1 disable
# Disable PoE for WTU port 1 in AP model view of AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WT1024-X-Q
[Sysname-wlan-ap-group-1-ap-model-WT1024-X-Q] poe wtu-port 1 disable
port-type switch
Support for this command depends on the WT model.
Use port-type switch to enable switching between an Ethernet port and a WTU port on a WT.
Use undo port-type switch to restore the default.
port-type switch number port-number-list { gigabitethernet | wtu }
undo port-type switch number port-number-list
In an AP group's AP model view, the default setting varies by AP model.
AP view
gigabitethernet: Switches a WTU port to an Ethernet port.
wtu: Switches an Ethernet port to a WTU port.
port-number-list: Specifies a space-separated list of Ethernet or WTU port items. Each item specifies an Ethernet/WTU port or a range of Ethernet/WTU ports in the form of port-number1 to port-number2. The value for the port-number2 argument must be equal to or greater than the value for the port-number1 argument. &<1-n> Indicates that you can specify up to n port numbers. The value for n varies by WT model.
CAUTION
CAUTION:
To prevent the chips on the connected from being damaged because of PoE power supply capacity change, make sure the port to switch is not connected to any other device.
You can execute this command to increase the number of WTU ports on a WT.
This command will reboot the WT and the new port will use its default settings.
If a port has a mark of two different port names separated by a slash (/), G3/WTU26 for example, the port supports port type switching.
The configuration in AP view takes precedence over the configuration in an AP group's AP model view.
# Switch Ethernet port 2 to a WTU port in AP view.
[Sysname-wlan-ap-ap1] port-type switch number 2 wtu
# Switch Ethernet port 2 to a WTU port in AP model view of AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WT1024-X-Q] port-type switch number 2 wtu
wt version
Use wt version to specify the WT version.
Use undo wt version to restore the default.
wt version { 1 | 2 | 3 }
undo wt version
AP view
1: Specifies version 1.0.
2: Specifies version 2.0.
3: Specifies version 3.0.
If the specified WT version is different from the WT version in use, the WT will restart automatically. Then, it will switch to the specified WT version and restore the factory settings.
Support for WT versions varies by AP model.
This command does not take effect on WTs that support different types of WTUs.
# Specify version 2.0 as the WT version in AP view.
[Sysname] wlan ap ap1 mode WT1010-QU
[Sysname-wlan-ap-ap1] wt version 2
# Specify version 2.0 as the WT version in AP model view of AP group 1.
[Sysname-wlan-ap-group-1] ap-model WT1010-QU
[Sysname-wlan-ap-group-1-ap-model-WT1010-QU] wt version 2
