| 02-RBAC commands | 175.80 KB |
RBAC commands
description
Use description to configure a description for a user role for easy identification.
A user role does not have a description.
User role view
text: Specifies a description, a case-sensitive string of 1 to 128 characters.
# Configure the description as labVIP for user role role1.
[Sysname] role name role1
[Sysname-role-role1] description labVIP
display role
role
display role
Use display role to display user role information.
display role [ name role-name ]
name role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. If you do not specify a user role name, the command displays information about all user roles, including the predefined user roles.
# Display information about user role 123.
<Sysname> display role name 123
Role: 123
Description: new role
VLAN policy: Permit (default)
Interface policy: Permit (default)
VPN instance policy: Permit (default)
Location policy: Permit (default)
# Display information about all user roles.
Role: network-admin
Description: Predefined network admin role has access to all commands on the device
Rule Perm Type Scope Entity
sys-1 permit command *
sys-2 permit RWX web-menu -
sys-3 permit RWX xml-element -
sys-4 deny command display security-logfile summary
sys-5 deny command system-view ; info-center securi
ty-logfile directory *
sys-6 deny command security-logfile save
sys-7 permit RW- oid 1
R:Read W:Write X:Execute
Role: network-operator
Description: Predefined network operator role has access to all read commands
on the device
sys-1 permit command display *
sys-2 permit command xml
sys-3 deny command display history-command all
sys-4 deny command display exception *
sys-5 deny command display cpu-usage configuration
sys-6 deny command display kernel exception *
sys-7 deny command display kernel deadloop *
sys-8 deny command display kernel starvation *
sys-9 deny command display kernel reboot *
sys-12 permit command system-view ; local-user *
sys-14 permit R-- web-menu -
sys-15 permit RW- web-menu m_device/m_maintenance/m_changep
assword
sys-16 permit RWX web-menu m_device/m_changevsys
sys-17 permit R-- xml-element -
sys-18 permit --X xml-element useraccounts/changemypassword
sys-19 permit --X xml-element rpc
sys-20 deny command display security-logfile summary
sys-21 deny command system-view ; info-center securi
sys-22 deny command security-logfile save
sys-23 deny command system-view ; local-user-import
sys-24 deny command system-view ; local-user-export
sys-25 permit R-- oid 1
sys-26 deny command system-view ; probe ; display sy
stem internal dbm *
sys-27 deny command system-view ; probe ; monitor sy
stem internal dbm name *
sys-28 deny command system-view ; probe ; undo monit
or system internal dbm name *
Role: level-0
Description: Predefined level-0 role
sys-1 permit command tracert *
sys-2 permit command telnet *
sys-3 permit command ping *
sys-4 permit command ssh2 *
sys-5 permit command super *
Role: level-1
Description: Predefined level-1 role
sys-5 permit command display *
sys-6 permit command super *
sys-7 deny command display history-command all
sys-8 deny command system-view ; probe ; display sy
stem internal dbm *
sys-9 deny command system-view ; probe ; monitor sy
sys-10 deny command system-view ; probe ; undo monit
Role: level-2
Description: Predefined level-2 role
Role: level-3
Description: Predefined level-3 role
Role: level-4
Description: Predefined level-4 role
Role: level-5
Description: Predefined level-5 role
Role: level-6
Description: Predefined level-6 role
Role: level-7
Description: Predefined level-7 role
Role: level-8
Description: Predefined level-8 role
Role: level-9
Description: Predefined level-9 role
sys-1 permit RWX feature -
sys-2 deny RWX feature device
sys-3 deny RWX feature filesystem
sys-4 permit command display *
sys-5 deny command display history-command all
sys-6 deny command system-view ; probe ; display sy
stem internal dbm *
sys-7 deny command system-view ; probe ; monitor sy
sys-8 deny command system-view ; probe ; undo monit
Role: level-10
Description: Predefined level-10 role
Role: level-11
Description: Predefined level-11 role
Role: level-12
Description: Predefined level-12 role
Role: level-13
Description: Predefined level-13 role
Role: level-14
Description: Predefined level-14 role
Role: level-15
Description: Predefined level-15 role
sys-3 deny RWX web-menu m_device/m_changevsys
sys-4 permit RWX xml-element -
sys-5 deny RWX xml-element fundamentals/switchvsys/vsysinde
x
sys-6 deny command display security-logfile summary
sys-7 deny command system-view ; info-center securi
sys-8 deny command security-logfile save
sys-9 permit RW- oid 1
Role: security-audit
Description: Predefined security audit role only has access to commands for the security log administrator
sys-1 deny command *
sys-2 permit command display security-logfile summary
sys-3 permit command system-view ; info-center securi
sys-4 permit command security-logfile save
sys-5 permit command cd *
sys-6 permit command copy *
sys-7 permit command delete *
sys-8 permit command dir *
sys-9 permit command mkdir *
sys-10 permit command more *
sys-11 permit command move *
sys-12 permit command rmdir *
sys-13 permit command pwd
sys-14 permit command rename *
sys-15 permit command undelete *
sys-16 permit command ftp *
sys-17 permit command sftp *
Role: guest-manager
Description: Predefined guest manager role can't access to commands
sys-1 permit RWX xml-element useraccounts/approveguest/
sys-2 permit RWX xml-element useraccounts/exportguestaccount/
sys-3 permit RWX xml-element useraccounts/generateguestaccoun
t/
sys-4 permit RWX xml-element useraccounts/guest/
sys-5 permit RWX xml-element useraccounts/guestconfigure/
sys-6 permit RWX xml-element useraccounts/importguestaccount/
sys-7 permit RWX xml-element useraccounts/exportguesttemplet/
sys-8 permit --X xml-element useraccounts/changemypassword
sys-9 permit RWX xml-element rpc/
sys-10 permit RWX web-menu m_global/m_networksecurity/m_gue
stmanage/
sys-11 permit RWX web-menu m_global/m_networksecurity/m_gue
stmanage/m_guestlist/
sys-12 permit RWX web-menu m_global/m_networksecurity/m_gue
stmanage/m_importguest/
sys-13 permit RWX web-menu m_global/m_networksecurity/m_gue
stmanage/m_generateguest/
sys-14 permit RWX web-menu m_global/m_networksecurity/m_gue
stmanage/m_approveguest/
sys-15 deny command *
Role: role1
Description:
Role |
User role name. Predefined user role names: · network-admin. · network-operator. · level-n (where n represents an integer in the range of 0 to 15). · security-audit. · guest-manager. |
User role description. |
VLAN policy |
VLAN policy of the user role: · Deny—Denies access to any VLANs except for permitted VLANs. · Permit (default)—Default VLAN policy, which enables the user role to access all VLANs. |
Permitted VLANs |
VLANs accessible to the user role. |
Interface policy |
Interface policy of the user role: · Deny—Denies access to any interfaces except for permitted interfaces. · Permit (default)—Default interface policy, which enables the user role to access all interfaces. |
Permitted interfaces |
Interfaces accessible to the user role. |
VPN instance policy |
This field is not supported in the current software version. VPN instance policy of the user role: · Deny—Denies access to any VPN instances except for permitted VPN instances. · Permit (default)—Default VPN instance policy, which enables the user role to access all VPN instances. |
Permitted VPN instances |
This field is not supported in the current software version. VPN instances accessible to the user role. |
Location policy |
Location identifier policy of the user role: · Deny—Denies access to any location identifiers except for permitted location identifiers. · Permit (default)—Default location identifier policy, which enables the user role to access all location identifiers. |
Permitted locations |
Location identifiers accessible to the user role. |
Rule |
User role rule number. Predefined user role rules are identified by sys-n, where n represents an integer. |
Perm |
Access control type: · Permit—User role has access to the items in the Entity field. · Deny—User role does not have access to the items in the Entity field. |
Type |
Controlled type: · R—Read-only. · W—Write. · X—Execute. |
Scope |
Rule control scope: · command—Controls access to the command or commands, as specified in the Entity field. · feature—Controls access to the commands of the feature, as specified in the Entity field. · feature-group—Controls access to the commands of the features in the feature group, as specified in the Entity field. · web-menu—Controls access to Web menus. · xml-element—Controls access to XML elements. · oid—Controls access to MIB nodes. |
Entity |
Command string, feature name, feature group, Web menu, XML element, or OID specified in the user role rule: · An en dash (–) represents any feature. · An asterisk (*) represents zero or more characters. |
role
display role feature
Use display role feature to display features available in the system.
display role feature [ name feature-name | verbose ]
name feature-name: Specifies a feature by feature name. The feature-name argument represents the feature name, and all letters must be in lower case.
verbose: Displays the commands of each feature.
If you do not specify any parameters, the command displays only the list of features available in the system.
# Display the list of feature names.
<Sysname> display role feature
Feature: stress (Stress related commands)
Feature: device (Device configuration related commands)
Feature: interface (Interface related commands)
Feature: syslog (Syslog related commands)
# Display the commands of each feature.
<Sysname> display role feature verbose
display clock (R)
debugging dev (W)
display debugging dev (R)
display device * (R)
display diagnostic-information * (R)
display environment * (R)
display fan * (R)
display power * (R)
display current-configuration * (R)
display saved-configuration * (R)
display default-configuration * (R)
display startup (R)
display this * (R)
display archive configuration (R)
display configuration replace server (R)
display system stable state * (R)
clock datetime * (W)
reboot * (W)
save * (W)
repeat * (W)
archive configuration (W)
backup startup-configuration to * (W)
# Display the commands of feature aaa.
<Sysname> display role feature name aaa
Feature: aaa (AAA related commands)
system-view ; domain-delimiter * (W)
system-view ; domain * (W)
system-view ; header * (W)
system-view ; aaa * (W)
system-view ; ita * (W)
display domain * (R)
system-view ; user-group * (W)
system-view ; local-user * (W)
system-view ; local-server * (W)
display local-user * (R)
display user-group * (R)
display debugging local-server (R)
debugging local-server * (W)
super * (X)
display password-control * (R)
reset password-control * (W)
system-view ; password-control * (W)
system-view ; local-user-import * (W)
system-view ; local-user-export * (W)
system-view ; probe ; display system internal local-user * (R)
system-view ; probe ; reset system internal local-user * (W)
system-view ; probe ; debugging system internal local-user * (W)
Table 2 Command output (display role feature name aaa)
Feature |
Displays the name and brief function description of the feature. |
system-view ; domain * |
All commands that start with the domain keyword in system view, and all commands in ISP domain view. |
system-view ; header * |
All commands that start with the header keyword in system view. |
system-view ; aaa * |
All commands that start with the aaa keyword in system view. |
system-view ; ita * |
All commands that start with the ita keyword in system view. |
display domain * |
All commands that start with the display domain keywords in user view. |
system-view ; user-group * |
All commands that start with the user-group keyword in system view, and all commands in user group view. |
system-view ; local-user * |
All commands that start with the local-user keyword in system view, and all commands in local user view. |
display local-user * |
All commands that start with the display local-user keywords in user view. |
display user-group * |
All commands that start with the display user-group keywords in user view. |
display debugging local-server |
All commands that start with the display debugging local-server keywords in user view. |
debugging local-server * |
All commands that start with the debugging local-server keywords in user view. |
super * |
All commands that start with the super keyword in user view. |
display password-control * |
All commands that start with the display password-control keywords in user view. |
reset password-control * |
All commands that start with the reset password-control keywords in user view. |
system-view ; password-control * |
All commands that start with the password-control keyword in system view. |
(W) |
Command type is Write. A write command configures the system. |
(R) |
Command type is Read. A read command displays configuration or maintenance information. |
(X) |
Command type is Execute. An execute command executes a specific function. |
feature
display role feature-group
Use display role feature-group to display feature group information.
display role feature-group [ name feature-group-name ] [ verbose ]
name feature-group-name: Specifies a feature group. The feature-group-name argument represents the feature group name, a case-sensitive string of 1 to 31 characters. If you do not specify a feature group, the command displays information about all feature groups.
verbose: Displays the commands of each feature in feature groups. If you do not specify this keyword, the command displays only the feature lists of feature groups.
Feature groups L2 and L3 are predefined feature groups.
# Display the feature lists of feature groups.
<Sysname> display role feature-group
Feature group: L2
Feature: igmp-snooping (IGMP-Snooping related commands)
Feature: mld-snooping (MLD-Snooping related commands)
Feature: lacp (LACP related commands)
Feature: stp (STP related commands)
Feature: lldp (LLDP related commands)
Feature: loopbk-detect (Loopback-detection related commands)
Feature: vlan (Virtual LAN related commands)
Feature: ofp (OFP related commands)
Feature: port-security (Port-security related commands)
Feature group: L3
Feature: route (Route management related commands)
Feature: usr (Unicast static route related commands)
Feature: rip (Routing Information Protocol related commands)
Feature: l3vpn (Layer 3 Virtual Private Network related commands)
Feature: multicast (Multicast related commands)
# Display the commands in each feature group. For more information about the wildcards and marks used in the command list, see Table 2.
<Sysname> display role feature-group verbose
Feature group: L2
system-view ; igmp-snooping * (W)
system-view ; vlan * ; igmp-snooping * (W)
system-view ; vlan * ; pim-snooping * (W)
system-view ; interface * ; igmp-snooping * (W)
display igmp-snooping * (R)
display pim-snooping * (R)
display l2-multicast * (R)
system-view ; probe ; display system internal l2-multicast * (R)
reset igmp-snooping * (W)
reset pim-snooping * (W)
reset l2-multicast * (W)
debugging igmp-snooping * (W)
display debugging igmp-snooping * (R)
system-view ; probe ; debugging system internal igmp-snooping * (W)
system-view ; mld-snooping * (W)
system-view ; vlan * ; mld-snooping * (W)
system-view ; vlan * ; ipv6 pim-snooping * (W)
system-view ; interface * ; mld-snooping * (W)
display mld-snooping * (R)
display ipv6 pim-snooping * (R)
# Display the feature list of the L3 feature group.
<Sysname> display role feature-group name L3
Feature group: L3
feature
role feature-group
feature
Use feature to add a feature to a feature group.
Use undo feature to remove a feature from a feature group.
feature feature-name
undo feature feature-name
A user-defined feature group does not have any features.
Feature group view
feature-name: Specifies a feature name. You must enter the feature name in lower case.
Repeat the feature command to add multiple features to a feature group.
# Add the AAA and ACL features to feature group security-features.
[Sysname] role feature-group name security-features
[Sysname-featuregrp-security-features] feature aaa
[Sysname-featuregrp-security-features] feature acl
role feature-group
interface policy deny
Use interface policy deny to enter user role interface policy view.
Use undo interface policy deny to restore the default.
A user role has access to all interfaces.
User role view
CAUTION: This command denies a user role access to any interfaces if you do not specify accessible interfaces by using the permit interface command. To configure an interface, make sure the interface is permitted by the user role interface policy in use. |
To limit the scope of interfaces accessible to a user role, perform the following tasks:
1. Use interface policy deny to enter user role interface policy view and deny the user role access to any interfaces.
2. Use permit interface to specify accessible interfaces.
You can perform the following tasks on an accessible interface:
· Create, remove, or configure the interface.
· Enter interface view.
· Specify the interface in feature commands.
The create and remove operations are available only for logical interfaces.
Any change to a user role interface policy takes effect only on users who log in with the user role after the change.
# Enter user role interface policy view of role1, and deny role1 to access any interfaces.
[Sysname-role-role1] interface policy deny
[Sysname-role-role1-ifpolicy] quit
# Enter user role interface policy view of role1, and deny role1 to access any interfaces except for GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4.
[Sysname-role-role1-ifpolicy] permit interface gigabitethernet 1/0/1 to gigabitethernet 1/0/4
display role
permit interface
role
location policy deny
Use location policy deny to enter user role location identifier policy view.
Use undo location policy deny to restore the default.
A user role has access to all location identifiers.
User role view
CAUTION: This command denies a user role access to any location identifiers if you do not specify accessible location identifiers by using the permit location command. To configure a location identifier, make sure the location identifier is permitted by the user role location identifier policy in use. |
To limit the scope of location identifiers accessible to a user role, perform the following tasks:
1. Use location policy deny to enter user role location identifier policy view and deny the user role access to any location identifiers.
2. Use permit location to specify accessible location identifiers.
You can perform the following tasks on an accessible location identifier:
· Create, remove, or configure the location identifier.
· Enter the location identifier view.
· Specify the location identifier in feature commands.
Any change to a user role location identifier policy takes effect only on users who log in with the user role after the change.
# Enter user role location identifier policy view of role1, and deny role1 to access all location identifiers.
[Sysname-role-role1] location policy deny
[Sysname-role-role1-locationpolicy] quit
# Enter user role location identifier policy view of role1, and deny role1 to access all location identifiers except for abc and 123.
[Sysname-role-role1-locationpolicy] permit location abc 123
display role
permit location
role
permit interface
Use permit interface to configure a list of interfaces accessible to a user role.
Use undo permit interface to disable the access of a user role to specific interfaces.
permit interface interface-list
undo permit interface [ interface-list ]
No permitted interfaces are configured in user role interface policy view.
User role interface policy view
interface-list: Specifies a space-separated list of up to 10 interface items. Each interface item specifies one interface in the interface-type interface-number form or a range of interfaces in the interface-type interface-number to interface-type interface-number form. If you specify an interface range, the end interface must meet the following requirements:
· Be the same type as the start interface.
· Have a higher interface number than the start interface.
To permit a user role to access an interface after you use the interface policy deny command, you must add the interface to the permitted interface list of the policy. With the user role, you can perform the following tasks to the interfaces in the permitted interface list:
· Create, remove, or configure the interfaces.
· Enter the interface views.
· Specify the interfaces in feature commands.
You can repeat the permit interface command to add multiple permitted interfaces to a user role interface policy.
The undo permit interface command removes the entire list of permitted interfaces if you do not specify an interface.
1. Configure user role role1:
# Permit user role role1 to execute all commands available in interface view.
[Sysname-role-role1] rule 1 permit command system-view ; interface *
# Permit user role role1 to execute all commands available in VLAN view.
[Sysname-role-role1] rule 2 permit command system-view ; vlan *
# Permit the user role to access only GigabitEthernet 1/0/1.
[Sysname-role-role1] quit
2. Verify that you cannot use user role role1 to work on any interfaces except for GigabitEthernet 1/0/1:
# Verify that you can enter GigabitEthernet 1/0/1 interface view.
# Verify that you can assign GigabitEthernet 1/0/1 to VLAN 10. In this example, the user role can access all VLANs because the default VLAN policy of the user role is used.
[Sysname] vlan 10
[Sysname-vlan10] port gigabitethernet 1/0/1
[Sysname-vlan10] quit
# Verify that you cannot enter interface view of GigabitEthernet 1/0/2.
Permission denied.
display role
role
permit location
Use permit location to configure a list of location identifiers accessible to a user role.
Use undo permit location to disable the access of a user role to specific location identifiers.
permit location location-name&<1-10>
undo permit location [ location-name&<1-10> ]
No permitted location identifiers are configured in user role location identifier policy view.
User role location identifier policy view
location-name&<1-10>: Specifies a space-separated list of up to 10 location identifier names. Each name is a case-sensitive string of 1 to 31 characters.
To permit a user role to access a location identifier after you use the location policy deny command, you must add the location identifier to the permitted location identifier list of the policy. With the user role, you can perform the following tasks to the location identifiers in the permitted location identifier list:
· Create, remove, or configure the location identifiers.
· Enter the location identifier views.
· Specify the location identifiers in feature commands.
You can repeat the permit location command to add multiple permitted location identifiers to a user role location identifier policy.
The undo permit location command removes the entire list of permitted location identifiers if you do not specify a location identifier.
# Permit user role role1 to execute all commands available in system view and in the child views of system view.
[Sysname-role-role1] rule 1 permit command system-view ; *
# Permit the user role to access location identifiers abc and 123.
2. Verify that you cannot use the user role to work on any location identifiers except for location identifiers abc and 123:
# Verify that you can create location identifier abc and specify the location identifier for AP group ap-group1.
[Sysname] wlan location abc
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] location abc
[Sysname-wlan-ap-group-1] quit
# Verify that you cannot create location identifier local or specify the location identifier for AP group ap-group1.
[Sysname] wlan location local
Permission denied.
[Sysname-wlan-ap-group-1] location local
Permission denied.
display role
role
permit vlan
Use permit vlan to configure a list of VLANs accessible to a user role.
Use undo permit vlan to remove the permission for a user role to access specific VLANs.
permit vlan vlan-id-list
undo permit vlan [ vlan-id-list ]
No permitted VLANs are configured in user role VLAN policy view.
User role VLAN policy view
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument.
To permit a user role to access a VLAN after you use the vlan policy deny command, you must add the VLAN to the permitted VLAN list of the policy. With the user role, you can perform the following tasks on the VLANs in the permitted VLAN list:
· Create, remove, or configure the VLANs.
· Enter the VLAN views.
· Specify the VLANs in feature commands.
You can repeat the permit vlan command to add multiple permitted VLANs to a user role VLAN policy.
The undo permit vlan command removes the entire list of permitted VLANs if you do not specify a VLAN.
Any change to a user role VLAN policy takes effect only on users who log in with the user role after the change.
By default, all access ports belong to VLAN 1. To assign an access port to any other VLAN by using the port access vlan command, make sure you have a user role that can access both VLAN 1 and the new VLAN.
# Permit user role role1 to execute all commands available in interface view and VLAN view.
# Permit user role role1 to access VLANs 1, 2, 4, and 50 to 100.
[Sysname-role-role1] vlan policy deny
[Sysname-role-role1-vlanpolicy] permit vlan 1 2 4 50 to 100
[Sysname-role-role1-vlanpolicy] quit
2. Verify that you cannot use user role role1 to work on any VLANs except for VLANs 1, 2, 4, and 50 to 100:
# Verify that you can create VLAN 100 and enter VLAN view.
[Sysname] vlan 100
[Sysname-vlan100] quit
# Verify that you can add GigabitEthernet 1/0/1 to VLAN 100 as an access port.
[Sysname-GigabitEthernet1/0/1] port access vlan 100
# Verify that you cannot create VLAN 101 or enter VLAN view.
[Sysname] vlan 101
Permission denied.
display role
role
vlan policy deny
role
Use role to create a user role and enter its view, or enter the view of an existing user role.
Use undo role to delete a user role.
role name role-name
undo role name role-name
The system has the following predefined user roles: network-admin, network-operator, level-n (where n represents an integer in the range of 0 to 15), guest-manager, and security-audit.
name role-name: Specifies a username. The role-name argument is a case-sensitive string of 1 to 63 characters.
You can create a maximum of 64 user roles in addition to the predefined user roles.
You cannot delete the predefined user roles or change the permissions assigned to network-admin, network-operator, level-15, guest-manager, or security-audit.
The access permissions of the level-0 to level-14 user roles can be modified through user role rules and resource access policies. However, you cannot make changes on the predefined access permissions of these user roles. For example, you cannot change the access permission of these user roles to the display history-command all command.
# Create user role role1 and enter its view.
display role
rule
vlan policy deny
role default-role enable
Use role default-role enable to enable the default user role feature for remote AAA users.
Use undo role default-role enable to restore the default.
role default-role enable [ role-name ]
The default user role feature is disabled. AAA users who do not have a user role cannot log in to the device.
role-name: Specifies a user role by its name for the default user role. The user role must already exist. The argument is a case-sensitive string of 1 to 63 characters.
The default user role feature assigns the default user role to AAA-authenticated users if the authentication server (local or remote) does not assign any user roles to the users. These users are allowed to access the system with the default user role.
For local authorization, this command is required if you do not use the authorization-attribute user role command to assign user roles to local users.
If AAA users have been assigned user roles, they log in with the user roles.
If you do not specify the role-name argument, the default user role is network-operator.
# Enable the default user role feature.
[Sysname] role default-role enable
role
role feature-group
Use role feature-group to create a user role feature group and enter its view, or enter the view of an existing user role feature group.
Use undo role feature-group to delete a user role feature group.
role feature-group name feature-group-name
undo role feature-group name feature-group-name
Two user role feature groups L2 and L3 exist.
name feature-group-name: Specifies a feature group name. The feature-group-name argument is a case-sensitive string of 1 to 31 characters.
The L2 feature group includes all Layer 2 feature commands, and the L3 feature group includes all Layer 3 feature commands. These predefined feature groups are not user configurable.
In addition to the predefined feature groups L2 and L3, you can create a maximum of 64 user role feature groups.
# Create feature group security-features and enter its view.
feature
rule
Use rule to create or change a user role rule.
Use undo rule to delete user role rules.
rule number { deny | permit } { command command-string | { execute | read | write } * { feature [ feature-name ] | feature-group feature-group-name | oid oid-string | web-menu [ web-string ] | xml-element [ xml-string ] } }
undo rule { number | all }
A user-defined user role does not have any rules and cannot access any resources.
User role view
number: Specifies a rule number in the range of 1 to 256.
deny: Denies access to the specified commands, Web menus, XML elements, or MIB nodes.
permit: Permits access to the specified commands, Web menus, XML elements, or MIB nodes.
command command-string: Specifies a command string. The command string can represent a command or a group of commands. The command-string argument is a case-sensitive string of 1 to 128 characters, including the wildcard asterisk (*), the delimiters space and tab, and all printable characters. If the command string includes a left bracket ([) or right bracket (]), you must add a back slash (\) as the escape character before the left or right bracket. For example, to specify the statistics[ifindex="*"] command, you must enter statistics\[ifindex="*"\] for the command-string argument.
execute: Specifies the execute commands, Web menus, XML elements, or MIB nodes to execute a specific function or program. The ping command is an example of execute commands.
read: Specifies the read commands, Web menus, XML elements, or MIB nodes to display configuration or maintenance information. The display, dir, more, and pwd commands are examples of read commands.
write: Specifies the write commands, Web menus, XML elements, or MIB nodes to configure the system. The ssh server enable command is an example of write commands.
feature [ feature-name ]: Specifies one or all features. The feature-name argument is a case-sensitive character string. If you do not specify a feature name, you specify all the features in the system.
feature-group feature-group-name: Specifies a user-defined or predefined feature group. The feature-group-name argument represents the feature group name, a case-sensitive string of 1 to 31 characters. If the feature group has not been created, the rule takes effect after the group is created. To display the feature groups that have been created, use the display role feature-group command.
oid oid-string: Specifies an OID of a MIB node. The oid-string argument represents the OID, a case-insensitive string of 1 to 255 characters. The OID is a dotted numeric string that uniquely identifies the path from the root node to this node. For example, 1.3.6.1.4.1.25506.8.35.14.19.1.1.
web-menu [ web-string ]: Specifies a Web menu. The web-string argument represents the ID path of the Web menu, a case-insensitive string of 1 to 255 characters. Use the forward slash (/) to separate ID items, for example, M_DEVICE/I_BASIC_INFO/I_reboot. If you do not specify a Web menu, the rule applies to all Web items. To verify the ID path of a Web menu, use the display web menu command.
xml-element [ xml-string ]: Specifies an XML element. The xml-string argument represents the XPath of the XML element, a case-insensitive string of 1 to 255 characters. Use the forward slash (/) to separate Xpath items, for example, Interfaces/Index/Name. If you do not specify an XML element, the rule applies to all XML elements.
all: Specifies all the user role rules.
You can define the following types of rules for different access control granularities:
· Command rule—Controls access to a command or a set of commands that match a regular expression.
· Feature rule—Controls access to the commands of a feature by command type.
· Feature group rule—Controls access to the commands of a group of features by command type.
· Web menu rule—Controls access to Web menus by menu type.
· XML element rule—Controls access to XML elements by element type.
· OID rule—Controls access to the specified MIB node and its child nodes by node type.
A user role can access the set of permitted resources specified in the user role rules. User role rules include predefined (identified by sys-n) and user-defined user role rules.
You can configure a maximum of 256 user-defined rules for a user role. The total number of user-defined user role rules cannot exceed 1024.
Any rule modification, addition, or removal for a user role takes effect only on the users who log in with the user role after the change.
Access to the file system commands is controlled by both the file system command rules and the file system feature rule.
A command with output redirection to the file system is permitted only when the command type write is assigned to the file system feature.
The following guidelines apply to non-OID rules:
· If two user-defined rules of the same type conflict, the rule with the higher ID takes effect. For example, a user role can use the tracert command but not the ping command if the user role contains rules configured by using the following commands:
¡ rule 1 permit command ping
¡ rule 2 permit command tracert
¡ rule 3 deny command ping
· If a predefined user role rule and a user-defined user role rule conflict, the user-defined user role rule takes effect.
The following guidelines apply to OID rules:
· The system compares an OID with the OIDs specified in rules, and it uses the longest match principle to select a rule for the OID. For example, a user role cannot access the MIB node with OID 1.3.6.1.4.1.25506.141.3.0.1 if the user role contains rules configured by using the following commands:
¡ rule 1 permit read write oid 1.3.6
¡ rule 2 deny read write oid 1.3.6.1.4.1
¡ rule 3 permit read write oid 1.3.6.1.4
· If the same OID is specified in multiple rules, the rule with the higher ID takes effect. For example, a user role can access the MIB node with OID 1.3.6.1.4.1.25506.141.3.0.1 if the user role contains rules configured by using the following commands:
¡ rule 3 permit read write oid 1.3.6.1.4.1
When you specify a command string, follow the guidelines in Table 3.
Table 3 Command string configuration rules
Rule |
Guidelines |
Semicolon (;) is the delimiter. |
Use a semicolon to separate the command of each view that you must enter before you access a command or a set of commands. However, do not use a semicolon to separate commands available in user view or any view, for example, display and dir. Each semicolon-separated segment must have a minimum of one printable character. To specify the commands in a view but not the commands in the view's subviews, use a semicolon as the last printable character in the last segment. To specify the commands in a view and the view's subviews, the last printable character in the last segment must not be a semicolon. For example, you must enter system view before you enter interface view. To specify all commands starting with the ip keyword in any interface view, you must use the "system ; interface * ; ip * ;" command string. For another example, the "system ; radius scheme * ;" command string represents all commands that start with the radius scheme keywords in system view. The "system ; radius scheme *" command string represents all commands that start with the radius scheme keywords in system view and all commands in RADIUS scheme view. |
Asterisk (*) is the wildcard. |
An asterisk represents zero or multiple characters. In a non-last segment, you can use an asterisk only at the end of the segment. In the last segment, you can use an asterisk in any position of the segment. If the asterisk appears at the beginning, you cannot specify a printable character behind the asterisk. For example, the "system ; *" command string represents all commands available in system view and all subviews of the system view. The "debugging * event" command string represents all event debugging commands available in user view. |
Keyword abbreviation is allowed. |
You can specify a keyword by entering the first few characters of the keyword. Any command that starts with this character string matches the rule. For example, "rule 1 deny command display arp source *" denies access to the display arp source-mac interface and display arp source-suppression commands. |
To control the access to a command, you must specify the command immediately after the view that has the command. |
To control access to a command, you must specify the command immediately behind the view to which the command is assigned. The rules that control command access for any subview do not apply to the command. For example, the "rule 1 deny command system ; interface * ; *" command string disables access to any command that is assigned to interface view. However, you can still execute the acl advanced command in interface view, because this command is assigned to system view rather than interface view. To disable access to this command, use "rule 1 deny command system ; acl *;". |
Do not include the vertical bar (|), greater-than sign (>), or double greater-than sign (>>) when you specify display commands in a user role command rule. |
The system does not treat the redirect signs and the parameters that follow the signs as part of command lines. However, in user role command rules, these redirect signs and parameters are handled as part of command lines. As a result, no rule that includes any of these signs can find a match. For example, "rule 1 permit command display debugging > log" can never find a match. This is because the system has a display debugging command but not a display debugging > log command. |
# Permit user role role1 to execute the display acl command.
[Sysname-role-role1] rule 1 permit command display acl
# Permit user role role1 to execute all commands that start with the display keyword.
[Sysname-role-role1] rule 2 permit command display *
# Permit user role role1 to execute the radius scheme aaa command in system view and use all commands assigned to RADIUS scheme view.
[Sysname-role-role1] rule 3 permit command system ; radius scheme aaa
# Deny the access of role1 to the read or write commands of any features.
[Sysname-role-role1] rule 4 deny read write feature
# Deny the access of role1 to the read commands of the aaa feature.
[Sysname-role-role1] rule 5 deny read feature aaa
# Permit role1 to access all read, write, and execute commands of feature group security-features.
[Sysname-role-role1] rule 6 permit read write execute feature-group security-features
# Permit role1 to access all read and write MIB nodes starting from the node with OID 1.1.2.
[Sysname-role-role1] rule 7 permit read write oid 1.1.2
display role
display web menu
role
super
Use super to obtain another user role without reconnecting to the device.
super [ role-name ]
role-name: Specifies a user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system and cannot be security-audit or guest-manager. If you do not specify a user role, you obtain the default target user role which is set by using the super default role command.
The obtained user role is a temporary user role, because this command is effective only on the current login. The next time you are logged in with the user account, the original user role settings take effect.
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication.
Enter the username (if any) and password within 60 seconds after you enter the super command. If you fail to do so, the command will time out. To obtain the role, you will need to re-execute the command.
· If no local password is configured in the local password authentication (local), a console user can obtain the user role by either entering a string or not entering anything.
· If no local password is configured in the local-then-remote authentication (local scheme), a console or VTY user performs remote authentication.
# Obtain the user role network-operator.
<Sysname> super network-operator
Password:
User privilege role is network-operator, and only those commands that authorized to the role can be used.
authentication super (User Access and Authentication Command Reference)
super authentication-mode
super password
Use super authentication-mode to set an authentication mode for temporary user role authorization.
Use undo super authentication-mode to restore the default.
super authentication-mode { local | scheme } *
Local password authentication applies.
local: Enables local password authentication.
scheme: Enables remote AAA authentication.
For local password authentication, use the super password command to set a password.
For remote AAA authentication, set the username and password on the RADIUS or HWTACACS server.
If you specify both local and scheme keywords, the keyword first entered in the command takes precedence.
· scheme local—Enables remote-then-local authentication mode. The device first performs AAA authentication to obtain a temporary user role. Local password authentication is performed if the remote HWTACACS or RADIUS server does not respond, or if the AAA configuration on the device is invalid.
· local scheme—Enables local-then-remote authentication mode. The device first performs local password authentication. If no password is configured for the user role, the device performs remote authentication for VTY users.A console user can obtain another user role by either entering a string or not entering anything.
For more information about AAA, see User Access and Authentication Configuration Guide.
# Enable local-only authentication for temporary user role authorization.
[Sysname] super authentication-mode local
# Enable remote-then-local authentication for temporary user role authorization.
[Sysname] super authentication-mode scheme local
super password
super default role
Use super default role to specify the default target user role for temporary user role authorization.
Use undo super default role to restore the default.
super default role role-name
The default target user role is network-admin.
role-name: Specifies the name of the default target user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system and cannot be security-audit or guest-manager.
The default target user role is applied to the super or super password command when you do not specify a user role for the command.
# Specify network-operator as the default target user role for temporary user role authorization.
[Sysname] super default role network-operator
super
super password
super password
Use super password to set a password for a user role.
Use undo super password to delete the password for a user role.
super password [ role role-name ] [ { hash | simple } string ]
undo super password [ role role-name ]
No password is set for a user role.
role role-name: Specifies a user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system and cannot be security-audit or guest-manager. If you do not specify a user role, the command sets a password for the default target user role which is set by using the super default role command.
hash: Specifies a password in hashed form.
simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password. The plaintext form of the password is a case-sensitive string of 1 to 63 characters. The hashed form of the password is a case-sensitive string of 1 to 110 characters.
If you do not specify any parameters, you specify a plaintext password in the interactive mode.
Set a password if you configure local password authentication for temporary user role authorization.
It is a good practice to specify different passwords for different user roles.
When the global password control feature is enabled, the device maintains a history of super passwords, which are stored in hashed form.
Use the following guidelines when you change the authentication password for a user role when the global password control feature is enabled:
· If you set the new password in plaintext form, you must make sure the password is different from the current one and those stored in the history super password records.
· If you set the new password in hashed form, the system does not compare the new super password with the current one or the history super password records. The password can be the same as the current one or a history password retained by the device.
# Set the password to 123456TESTplat&! in plaintext form for user role network-operator.
[Sysname] super password role network-operator simple 123456TESTplat&!
# Set the password to 123456TESTplat&! in the interactive mode for user role network-operator.
Password:
Confirm :
Updating user information. Please wait......
super default role
super use-login-username
Use super use-login-username to enable the device to automatically obtain the login username when a login user requests temporary user role authorization from a remote authentication server.
Use undo super use-login-username to restore the default.
The device prompts for a username when a login user requests temporary user role authorization from a remote authentication server.
This command is applicable only to the login from a user line that uses scheme authentication, which requires a username for login.
If the user was logged in from a user line that uses password authentication or no authentication, the device cannot obtain the login username. The request for temporary user role authorization from a remote authentication server will fail.
This command does not take effect on local password authentication for temporary user role authorization.
# Enable the device to automatically obtain the login username when a login user requests temporary user role authorization from a remote authentication server.
[Sysname] super use-login-username
super password
vlan policy deny
Use vlan policy deny to enter user role VLAN policy view.
Use undo vlan policy deny to restore the default.
vlan policy deny
A user role has access to all VLANs.
User role view
CAUTION: The vlan policy deny command denies a user role access to any VLANs if you do not specify accessible VLANs by using the permit vlan command. To configure a VLAN, make sure the VLAN is permitted by the user role VLAN policy in use. |
To limit the scope of VLANs accessible to a user role, perform the following tasks:
1. Use vlan policy deny to enter user role VLAN policy view and deny the user role access to any VLANs.
2. Use permit vlan to specify accessible VLANs.
You can perform the following tasks on an accessible VLAN:
· Create, remove, or configure the VLAN.
· Enter VLAN view.
· Specify the VLAN in feature commands.
# Enter user role VLAN policy view of role1, and deny the access of role1 to any VLANs.
# Enter user role VLAN policy view of role1, and deny the access of role1 to any VLANs except for VLANs 50 to 100.
[Sysname-role-role1-vlanpolicy] permit vlan 50 to 100
display role
permit vlan
role
