- 20-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-SNMP configuration
- 04-RMON configuration
- 05-NETCONF configuration
- 06-EAA configuration
- 07-Process monitoring and maintenance configuration
- 08-Flow log configuration
- 09-Packet capture configuration
- 10-Mirroring configuration
- 11-UCC configuration
| 11-UCC configuration | 125.46 KB |
Restrictions and guidelines: UCC configuration
UCC configuration tasks at a glance
Display and maintenance commands for UCC
Example: Configuring SIP-based UCC
Example: Configuring Skype4B-based UCC
Configuring UCC
About UCC
Unified Communication and Collaboration (UCC) can identify packets of specific protocols and increase the priority of the packets accordingly to accelerate packet forwarding and improve user experience.
SIP-based UCC enables the device to identify SIP protocol packets from wireless clients and preferentially forward the audio and video traffic for the wireless clients.
Skype for Business (Skype4B)-based UCC enables the device to analyze Skype4B packets from wireless clients and preferentially forward the audio, video, and application sharing traffic for the wireless clients.
When you bind a UCC profile, follow these restrictions and guidelines:
· If the client traffic forwarder is the AC and clients are in different subnets, bind the UCC profile to both a service template and a Layer 3 interface.
· If the client traffic forwarder is an AP, bind the UCC profile to a service template.
To configure UCC, perform either of the following tasks:
Configure this task if SIP-based third-party audio and video communications system is deployed in your network.
· Configuring Skype4B-based UCC
Configure this task if Skype4B is used for communications in your network to improve audio, video, and application sharing traffic forwarding efficiency.
2. Create a UCC profile and enter its view.
ucc profile profile-name
3. Enable SIP-based UCC.
sip enable
By default, SIP-based UCC is disabled.
4. Return to system view.
5. Enter service template view or Layer 3 interface view.
¡ Enter service template view.
wlan service-template service-template-name
¡ Enter Layer 3 interface view.
6. Bind a UCC profile.
ucc-profile profile-name
By default, no UCC profile is bound.
1. Enter system view.
2. Enable the device to communicate with the Skype4B server and specify the port number.
skype4b listener { http-port http-port-num | https-port https-port-num ssl-policy ssl-policy-name }
Make sure the port numbers are different if you configure both HTTP and HTTPS services.
3. Create a UCC profile and enter its view.
4. Enable Skype4B-based UCC.
skype4b enable
By default, Skype4B-based UCC is disabled.
5. (Optional.) Configure priority marking for Skype4B application sharing packets.
skype4b app-share remark { dscp dscp-value | dot1p dot1p-value }
6. (Optional.) Configure priority marking for Skype4B video packets.
skype4b video remark { dscp dscp-value | dot1p dot1p-value }
By default, the DSCP value is 34 and the 802.1p priority is 4 for Skype4B video packets.
7. (Optional.) Configure priority marking for Skype4B voice packets.
skype4b voice remark { dscp dscp-value | dot1p dot1p-value }
By default, the DSCP value is 46 and the 802.1p priority is 6 for Skype4B voice packets.
Task |
Command |
Display configuration information for UCC profiles. |
display ucc profile [ profile-name ] |
Display UCC entries. |
display ucc table |
Clear UCC entries. |
reset ucc table [ sip | skype4b ] |
UCC configuration examples
As shown in Figure 1, the SIP server installed with third-party VoIP server software acts as both the SIP proxy server and SIP registrar to manage SIP UA registration and SIP calls. The AC is the gateway of Client 1 and Client 2 and is the client traffic forwarder. The clients use third-party client software to place calls to each other.
Configure SIP-based UCC on the AC to optimize multimedia traffic between the clients to provide high-quality multimedia services.
Assign IP addresses to interfaces, and make sure the devices can reach each other.
Make sure the APs can associate with the AC and the clients can obtain an IP address.
1. Configure the SIP server:
Install third-party VoIP server software and specify the usernames (phone numbers) and passwords for the clients. (Details not shown.)
2. Configure Client 1 and Client 2:
Install third-party VoIP client software, specify the IP address of the SIP server, and configure the username (phone number), password, and other parameters on each PC. (Details not shown.)
3. Configure the AC:
# Create UCC profile 1, and enable SIP-based UCC.
[Sysname] ucc profile 1
[Sysname-ucc-profile-1] sip enable
[Sysname-ucc-profile-1] quit
# Bind the UCC profile to service template service1.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] ucc-profile 1
[Sysname-wlan-st-service1] quit
# Bind the UCC profile to service template service2.
[Sysname] wlan service-template service2
[Sysname-wlan-st-service2] ucc-profile 1
[Sysname-wlan-st-service2] quit
# Bind the UCC profile to VLAN-interface 1 (gateway of Client 1).
[Sysname-Vlan-interface1] ucc-profile 1
[Sysname-Vlan-interface1] quit
# Bind the UCC profile to VLAN-interface 2 (gateway of Client 2).
[Sysname-Vlan-interface2] ucc-profile 1
[Sysname-Vlan-interface2] quit
# Place a call from Client 1 to Client 2. (Details not shown.)
# Execute the following command to verify that multimedia traffic has been forwarded from Client 1 to Client 2.
[Sysname] display ucc table
UCC tuple5 entry info:
Source IP/port : 172.16.1.10/11111
Destination IP/port : 172.16.2.10/22222
Transport layer protocol : UDP
Flow type : SIP
Media type : Audio
Lifetime : 280
Total tuple5 entries found : 1
Total tuple3 entries found : 0
Total entries found: 1
As shown in Figure 2, all network users use Skype4B for communication.
The Skype4B server (including front-end and back-end) manage user registration and calls, and the Dialog Listener listens for Skype dialogs on the AC. The two servers are deployed on the same physical server.
The SDN Manager obtains dialog information from the Dialog Listener and establishes an HTTP or HTTPs connection with the AC to issue dialog information.
The AC is the client traffic forwarder, and the switch is the gateway for the clients. The clients use Skype4B client software to place calls to each other.
Configure Skype4B-based UCC on the AC to optimize Skype4B traffic between the clients to provide high-quality Skype4B services.
Deploy the Skype4B server, Skype4B client, SDN Manager, and Dialog Listener.
# Enable the device to communicate with the Skype4B server and specify the port number as 5000. Make sure this port number is the same as the port number configured on the SDN Manager.
[Sysname] skype4b listener http-port 5000
# Create UCC profile 1, and enable Skype4B-based UCC.
[Sysname-ucc-profile-1] skype4b enable
# Mark DSCP priority 50 for Skype4B application sharing packets.
[Sysname-ucc-profile-1] skype4b app-share remark dscp 50
# Mark DSCP priority 50 for Skype4B voice packets.
[Sysname-ucc-profile-1] skype4b voice remark dscp 50
# Mark DSCP priority 50 for Skype4B video packets.
[Sysname-ucc-profile-1] skype4b video remark dscp 50
UCC tuple3 entry info:
Client IP/port : 172.16.1.10/11111
Flow type : SKYPE4B
Media type : Audio
Lifetime : 62
Client IP/port : 172.16.2.10/22222
Flow type : SKYPE4B
Media type : Audio
Lifetime : 76
Total tuple5 entries found : 0
Total tuple3 entries found : 2
Total entries found: 2
