18-Internet Access Behavior Management Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WX2800X&WSG1800X Configuration Guides(E5611)-5W10118-Internet Access Behavior Management Configuration Guide
02-Application audit and management configuration
Configuring application audit and management
About application audit and management
Application audit and management audits and records Internet access behaviors of users by identifying behaviors (for example, login and message sending in IM applications) and behavior objects (for example, account information for IM login).
This feature parses personal information from user packets and must be used for legitimate purposes.
Application audit and management policy
You can configure match criteria, audit rules, and actions in an application audit and management policy to audit matching packets.
Policy types
Application audit and management policies have the following types:
·     Audit policy—Audits packets that meet match criteria in the policy.
·     Audit-free policy—Does not audit packets that meet match criteria in the policy.
·     Deny policy—Drops packets that meet match criteria in the policy.
Match criteria
Multiple match criteria can be configured in an application audit and management policy.
The following match criteria are available:
·     Source and destination IP addresses.
·     Services.
·     Users/user groups.
·     Applications.
One match criterion can contain multiple match values.
Audit rule
Audit rules can be configured for an audit policy to perform more granular control on user behaviors and to generate audit logs.
The following rule match modes are available:
·     in-order—The device compares packets with audit rules in ascending order of rule ID. When a packet matches a rule, the device stops the match process and performs the action defined in the rule.
·     all—The device compares packets with audit rules in ascending order of rule ID.
¡     If a packet matches a rule with the permit action, all subsequent rules continue to be matched.
The device takes the action with higher priority on matching packets. The deny action has higher priority than the permit action.
¡     If a packet matches a rule with the deny action, the device stops the match process and performs the deny action.
Audit log
The device can generate and output audit logs for packets that match an audit rule. The audit logs can be output as common logs or output by using the fast log output feature.
Application audit and management workflow
Figure 1 shows the application audit and management workflow.
Figure 1 Application audit and management workflow
The application audit and management workflow is as follows:
1.     The device matches the packet against the match criteria in an application audit and management policy.
The packet meets a match criterion if it matches any of its match values. A packet does not match a match criterion if it matches none of its match values.
2.     If the packet meets all match criteria in the policy (for the user and user group criteria, only one criterion needs to be matched), the packet matches the policy. Otherwise, the packet does not match the policy and continues to be matched by the next policy. If the packet does not match any policy, the device takes the policy's default action on the packet.
3.     If the packet matches a policy, it is processed according to the policy type.
¡     If the policy is an audit-free policy, the packet is allowed to pass.
¡     If the policy is a deny policy, the packet is denied.
¡     If the policy is an audit policy, the packet is matched against the audit rules in the policy.
4.     The device processes the packet as follows:
¡     If a packet matches all items in an audit rule, the action in the audit rule is taken on the packet.
¡     If a packet matches only the specified application or application category in an audit rule, the packet is allowed to pass through.
¡     If a packet does not match the specified application or application category in an audit rule, the default action for audit rules is taken on the packet.
Restrictions: Hardware compatibility with application audit and management
Series
Models
Product codes
Application audit and management compatibility
WX2500X series
WX2560
WX2580X
EWP-WX2560X
EWP-WX2580X
Yes
Series
Models
Product codes
WX2800X series
WX2812X-PWR
WX2860X
WX2880X
EWP-WX2812X-PWR
EWP-WX2860X
EWP-WX2880X
Yes
WSG1800X series
WSG1812X-PWR
WSG1840X
EWP-WSG1812X-PWR
EWP-WSG1840X
No
Restrictions and guidelines: Application audit and management configuration
As a best practice to audit packets more accurately, observe the depth-first principle when creating policies. Always create a policy with a smaller audit scope before a policy with a larger audit scope.
Prerequisites for application audit and management
Before configuring application audit and management, complete the following tasks:
·     Update the APR signature library to the latest version (see APR configuration in DPI Configuration Guide).
·     Configure time ranges (see time range configuration in Security Configuration Guide).
·     Configure IP address object groups and service object groups (see object group configuration in Security Configuration Guide).
·     Configure applications (see APR configuration in DPI Configuration Guide).
·     Configure users and user groups (see user identification configuration in User Access and Authentication Configuration Guide).
Application audit and management tasks at a glance
To configure application audit and management, perform the following tasks:
1.     Creating an application audit and management policy
2.     Configuring match criteria for the policy
3.     (Optional.) Specifying a time range for the policy
4.     Configuring an audit rule for the policy
5.     Configuring a keyword group
6.     (Optional.) Managing and maintaining an application audit and management policy
7.     Activating policy and rule settings of all DPI service modules
2.     Enter application audit and management view.
uapp-control
3.     Create an application audit and management policy and enter its view.
policy name policy-name { audit | deny | noaudit }
4.     Configure the default action for the policy.
policy default-action { deny | permit }
By default, the default action for a policy is permit.
uapp-control
3.     Enter application audit and management policy view.
policy name policy-name [ audit | deny | noaudit ]
4.     Configure an IP address object group as a match criterion.
¡     Configure a source IP address object group as a match criterion.
source-address { ipv4 | ipv6 } object-group-name
¡     Configure a destination IP address object group as a match criterion.
destination-address { ipv4 | ipv6 } object-group-name
By default, no IP address object group is used as a match criterion.
5.     Configure a service object group as a match criterion.
service service-name
By default, no service object group is used as a match criterion.
6.     Configure a user or user group as a match criterion.
¡     Configure a user as a match criterion.
user user-name [ domain domain-name ]
¡     Configure a user group as a match criterion.
user-group user-group-name [ domain domain-name ]
By default, no user or user group is used as a match criterion.
7.     Configure an application or application group as a match criterion.
application { app application-name | app-group application-group-name }
By default, no application or application group is used as a match criterion.
The application and application group match criteria can be configured only in audit-free policies and deny policies.
uapp-control
4.     Specify a time range during which the policy is in effect.
time-range time-range-name
By default, an application audit and management policy is in effect at any time.
An audit rule provices the following functions:
·     General auditing—Performs granular control on user behaviors.
·     Email protection—Detects incoming emails, counts emails based on recipients, and protects recipients from attacks. Specifically, you can configure the following functions:
¡     Limit email sending—Prevents users from sending emails to users of a different domain. For example, the user at [email protected] cannot receive emails from the user at [email protected].
¡     Prevent email bombing—Protects recipients from being overwhelmed by large numbers of emails from the same sender during a short period of time.
You can configure audit rules only for an audit policy.
If you specify the audit-logging keyword for an audit rule, the device supports the following methods to send log messages:
·     Fast log output—You must specify a log host to receive the log messages. Log messages are sent to the specified log host.
·     Syslog output—Log messages are sent to the information center. With the information center, you can set log message filtering and output rules, including output destinations. The information center can output audit syslogs to any destinations except the console and the monitor terminal. If you configure the console or monitor terminal as an output destination, the output destination setting will not take effect. To view audit syslogs stored on the device, use the display logbuffer command. Make sure you do not disable log output to the log buffer, which is enabled by default.
Syslog output might affect device performance. As a best practice, use fast log output.
For more information about configuring the information center, see System Management Configuration Guide. For more information about fast log output, see fast log output configuration in Network Management and Monitoring Configuration Guide.
For WeChat and QQ, specific messages cannot be audited..
uapp-control
3.     Enter application audit and management policy view of the audit type.
policy name policy-name [ audit ]
4.     Configure an audit rule for the policy.
rule rule-id { app app-name | app-category app-category-name | any } behavior { behavior-name | any } bhcontent { bhcontent-name | any } { keyword { equal | exclude | include | unequal } { keyword-group-name | any } | integer { equal | greater | greater-equal | less | less-equal | unequal } { number } } action { deny | permit } [ audit-logging ]
rule rule-id { email-bomb-defense [ interval interval max-number email-number ] | email-send-restriction } * action { deny | permit } [ audit-logging ]
By default, a policy does not have audit rules.
5.     Configure the match mode for audit rules in the policy.
rule match-method { all | in-order }
By default, the match mode for audit rules is in-order.
6.     Configure the default action for audit rules in the policy.
rule default-action { deny | permit }
By default, the default action for audit rules is permit.
A keyword group can be used by an audit rule to match more specific information.
uapp-control
3.     Create a keyword group and enter its view.
keyword-group name keyword-group-name
4.     (Optional.) Configure a description for the keyword group.
By default, a keyword group does not have a description.
5.     Add a keyword to the keyword group.
keyword keyword-value
By default, a keyword group does not contain keywords.
Copying an application audit and management policy
uapp-control
3.     Copy an application audit and management policy.
policy copy policy-name new-policy-name
Renaming an application audit and management policy
uapp-control
3.     Rename an application audit and management policy.
policy rename old-policy-name new-policy-name
Moving an application audit and management policy
uapp-control
3.     Move an application audit and management policy.
policy move policy-name1 { after | before } policy-name2
Disabling an application audit and management policy
uapp-control
4.     Disable the application audit and management policy.
disable
By default, an application audit and management policy is enabled.
After detecting application audit and management policy changes, the system starts a timer to check for new changes 20 seconds later.
·     If no further changes are detected when the timer expires, the system determines that the changes are final and activate the changes at the expiration of the next check interval (after 40 seconds).
·     If new changes are detected, the system resets the check interval timer and continues the periodic check until it determines that the changes are final and activates the changes.
You can also perform this task to manually activate policy changes immediately.
For more information about this task, see DPI engine configuration in DPI Configuration Guide.
This task will interrupt DPI service processing. To reduce the impact on DPI services, perform this task after you complete policy and rule settings of all DPI service modules.
2.     Activate policy and rule settings of all DPI service modules.
inspect activate
By default, policy and rule settings of all DPI service modules are deactivated.
CAUTION
CAUTION:
This command causes transient DPI service interruption. DPI-based services might also be interrupted. For example, security policies cannot control access to applications, or server load balancing services cannot load share traffic based on applications.
Application audit and management configuration examples
Example: Configuring account login audit
As shown in Figure 2, the switch assigns IP addresses to the AP and the client. The AP and the AC establish a CAPWAP tunnel through VLAN 100, and the client accesses the wireless network through VLAN 200. The working hours of the company are 8:00:00 through 18:00:00 from Monday to Friday.
Configure an application audit and management policy on the device to meet the following requirements:
·     Permit login from all QQ accounts during working hours.
·     Generate audit logs.
Figure 2 Network diagram
1.     Configure the AC:
# Create VLAN 100, and assign an IP address to VLAN-interface 100.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 192.1.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200, and assign an IP address to VLAN-interface 200.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 192.2.1.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, remove it from VLAN 1, assign it to VLAN 100 and VLAN 200, and set its PVID to VLAN 100.
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2.     Configure wireless services:
# Create service template 1 and enter service template view.
[AC] wlan service-template 1
# Set the SSID to service.
[AC-wlan-st-1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-1] vlan 200
# Enable the service template..
[AC-wlan-st-1] quit
3.     Configure the AP:
# Create an AP named ap1, with model WA6320.
[AC] wlan ap ap1 model WA6320
# Set the serial ID to 219801A28N819CE0002T.
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Enter radio view of radio 1, and  bind service template 1 to the radio.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] service-template 1
# Enable radio 1.
[AC-wlan-ap-ap1-radio-1] quit
# Enter radio view of radio 2, and  bind service template 1 to the radio.
[AC-wlan-ap-ap1] radio 2
[AC-wlan-ap-ap1-radio-2] service-template 1
# Enable radio 2.
[AC-wlan-ap-ap1-radio-2] radio enable
[AC-wlan-ap-ap1-radio-2] quit
[AC-wlan-ap-ap1] quit
4.     Configure a time range named work to cover 8:00:00 through 18:00:00 from Monday to Friday.
[Device] time-range work 08:00 to 18:00 working-day
5.     Create an IPv4 address object group named audit, and configure an IPv4 address object with the IPv4 address of 192.2.1.0 and mask length of 24..
[AC] object-group ip address audit
[AC-obj-grp-ip-audit] network subnet 192.2.1.0 24
[AC-obj-grp-ip-audit] quit
6.     Configure an application audit and management policy:
# Enter application audit and management view.
[AC] uapp-control
# Create an audit policy named audit-qq and enter its view.
[AC-uapp-control] policy name audit-qq audit
# Configure IPv4 address object group audit as a match criterion for audit policy audit-qq.
[AC-uapp-control-policy-audit-qq] source-address ipv4 audit
# Specify time range work for audit policy audit-qq.
[Device-uapp-control-policy-audit-qq] time-range work
# Configure an audit rule to permit login from all QQ accounts and generate audit logs.
[AC-uapp-control-policy-audit-qq] rule 1 app QQ behavior Login bhcontent any keyword equal any action permit audit-logging
[AC-uapp-control-policy-audit-qq] quit
[AC-uapp-control] quit
# Activate the configuration.
[AC] inspect activate
When QQ accounts attempt to access the Internet, the device permits the login requests and generates audit log messages.
