15-High Availability Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WX2800X&WSG1800X Configuration Guides(E5611)-5W10115-High Availability Configuration Guide
01-WLAN high availability configuration
01-WLAN high availability configuration 158.14 KB
Configuring dual-link backup
About dual-link backup
Dual-link backup enables two ACs to back up each other to reduce risks of service interruption caused by single-AC failures.
With dual-link backup enabled, an AP establishes a master CAPWAP tunnel and a backup CAPWAP tunnel with the master AC and the backup AC, respectively. The master and backup ACs cannot detect each other's link state in real time. When the backup AC takes over traffic forwarding upon a master AC failure, temporary communication interruption occurs. When the failed master AC recovers, the master CAPWAP tunnel preemption feature determines the master CAPWAP tunnel based on the AP connection priority.
Dual-link backup is applicable to networks that are service continuity insensitive.
Figure 1 Network diagram for dual-link backup
Restrictions and guidelines: Dual-link backup configuration
For the dual-link backup feature to function correctly, configure auto AP or manual APs on the two ACs. The manual AP configuration must be identical on both ACs. For more information, see "Managing APs."
You can configure APs by using the following methods:
·     Configure APs one by one in AP view.
·     Assign APs to an AP group and configure the AP group in AP group view.
·     Configure all APs in global configuration view.
For an AP, the settings made in these views for the same parameter take effect in descending order of AP view, AP group view, and global configuration view.
Dual-link backup tasks at a glance
To configure dual-link backup, perform the following tasks:
1.     Setting AP connection priority and specifying a backup AC
2.     (Optional.) Configuring master CAPWAP tunnel preemption
Set a higher AP connection priority for the master AC to ensure that APs can associate with the master AC first.
After an AP establishes a CAPWAP tunnel with the master AC, the AP will establish a backup CAPWAP tunnel with the specified backup AC.
2.     Enter AP view or AP group view.
¡     Enter AP view.
wlan ap ap-name
¡     Enter AP group view.
wlan ap-group group-name
3.     Set the AP connection priority.
priority priority
By default:
¡     In AP view, an AP uses the configuration in AP group view.
¡     In AP group view, the AP connection priority is 4.
4.     Specify a backup AC.
backup-ac { ip ipv4-address | ipv6 ipv6-address }
By default:
¡     In AP group view, no backup AC is specified.
This feature enables a backup CAPWAP tunnel to become a master tunnel after 10 minutes if the backup AC has higher AP connection priority than the master AC.
2.     Enter AP view, AP group view, or global configuration view.
¡     Enter AP view.
wlan ap ap-name
¡     Enter global configuration view.
wlan global-configuration
3.     Configure master CAPWAP tunnel preemption.
wlan tunnel-preempt { disable | enable }
By default:
¡     In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
¡     In AP group view, an AP uses the configuration in global configuration view.
¡     In global configuration view, master CAPWAP tunnel preemption is disabled.
Dual-link backup configuration examples
Example: Configuring dual-link backup
As shown in Figure 2, configure AC 1 to act as the master AC and AC 2 as the backup AC. When AC 1 fails and AC 2 takes over, the AP can communicate through AC 2. Configure the master CAPWAP tunnel preemption feature on the two ACs so that the AP reconnects to AC 1 when AC 1 recovers.
Figure 2 Network diagram
1.     Configure AC 1:
# Create VLAN-interface 1 and assign an IP address to it.
<AC1> system-view
[AC1] interface vlan-interface 1
[AC1-Vlan-interface1] ip address 10.1.1.1 24
[AC1-Vlan-interface1] quit
# Create an AP named ap1, and specify the AP model and serial ID. Set the AP connection priority to 7.
[AC1] wlan ap ap1 model WA6320
[AC1-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC1-wlan-ap-ap1] priority 7
# Specify a backup AC.
[AC1-wlan-ap-ap1] backup-ac ip 11.1.1.1
# Enable master CAPWAP tunnel preemption.
[AC1-wlan-ap-ap1] wlan tunnel-preempt enable
[AC1-wlan-ap-ap1] quit
2.     Configure AC 2:
<AC2> system-view
[AC2] interface Vlan-interface 1
[AC2-Vlan-interface1] ip address 11.1.1.1 24
[AC2-Vlan-interface1] quit
# Create an AP named ap1, and specify the AP model and serial ID. Set the AP connection priority to 5.
[AC2] wlan ap ap1 model WA6320
[AC2-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC2-wlan-ap-ap1] priority 5
[AC2-wlan-ap-ap1] backup-ac ip 10.1.1.1
[AC2-wlan-ap-ap1] wlan tunnel-preempt enable
[AC2-wlan-ap-ap1] quit
# Get the AP online on AC 1. (Details not shown.)
# Shut down VLAN-interface 1 on AC 1 and wait no longer than 3 minutes, during which service interruption occurs. (Details not shown.)
# Verify that the AP comes online on AC 2 and the AP state is R/M on AC 2. (Details not shown.)
# Bring up VLAN-interface 1 on AC 1. (Details not shown.)
# Verify that the AP comes online on AC 1 again and the AP state is R/M on AC 1 and R/B in AC 2. (Details not shown.)
Configuring WLAN uplink detection
About WLAN uplink detection
When the uplink of an AC fails, clients cannot access external networks through the APs that are connected to the AC. WLAN uplink detection associates the uplink state of an AC with the radio state of the connected APs. When the uplink fails, the AC disables the radios of the APs. When the uplink recovers, the AC enables the radios of the APs. The association ensures that clients can associate with APs connected to another AC when the uplink of an AC fails.
This feature collaborates with a detection module and the Track module to function.
·     When the track entry is in Positive state, the AC enables the radios of the connected APs.
·     When the track entry is in Negative state, the AC disables the radios of the connected APs.
·     When the track entry is in Invalid state, the AC does not change the radio state of the connected APs.
For more information about the track module, see High Availability Configuration Guide.
Restrictions and guidelines: WLAN uplink detection
For the WLAN uplink detection feature to function correctly, configure a detection module to detect the uplink state, and associate a track entry with the detection module. For more information, see track configuration in High Availability Configuration Guide.
2.     Associate a track entry with the WLAN uplink detection feature.
wlan uplink track track-entry-number
By default, WLAN uplink detection is not associated with any track entry.
WLAN uplink detection configuration examples
Example: Configuring WLAN uplink detection
As shown in Figure 3, use an NQA operation to test the reachability of each AC's uplink. Configure WLAN uplink detection on each AC so that clients can associate with the AP connected to another AC when the uplink of an AC fails.
Figure 3 Network diagram
1.     Configure AC 1:
# Create an ICMP echo operation.
<AC1> system-view
[AC1] nqa entry admin test
[AC1-nqa-admin-test] type icmp-echo
# Specify 10.1.1.1 as the destination IP address of ICMP echo requests.
[AC1-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
# Create reaction entry 1. If the number of consecutive probe failures reaches 5, collaboration is triggered.
[AC1-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[AC1-nqa-admin-test-icmp-echo] quit
# Start the ICMP echo operation.
[AC1] nqa schedule admin test start-time now lifetime forever
# Configure track entry 1, and associate it with reaction entry 1 of the NQA operation (with administrator admin and operation tag test).
[AC1] track 1 nqa entry admin test reaction 1
# Associate track entry 1 with WLAN uplink detection.
[AC1] wlan uplink track 1
[AC1] quit
2.     Configure AC 2:
<AC2> system-view
[AC2] nqa entry admin test
[AC2-nqa-admin-test] type icmp-echo
# Specify 11.1.1.1 as the destination IP address of ICMP echo requests.
[AC2-nqa-admin-test-icmp-echo] destination ip 11.1.1.1
[AC2-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
[AC2-nqa-admin-test-icmp-echo] quit
[AC2] nqa schedule admin test start-time now lifetime forever
[AC2] track 1 nqa entry admin test reaction 1
[AC2] wlan uplink track 1
[AC2] quit
This example uses AC 1 to verify the configuration.
1.     Verify that the radio state of AP 1 is Up when the state of track entry 1 is Positive:
# Display information about track entry 1.
<AC1> display track 1
Track ID: 1
  State: Positive
  Duration: 0 days 1 hours 5 minutes 48 seconds
  Notification delay: Positive 0, Negative 0 (in seconds)
  Tracked object:
    NQA entry: admin test
    Reaction: 1
# Display detailed information about AP ap1.
<AC1> display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup type                   : Idle
Online time                   : 0 days 3 hours 25 minutes 12 seconds
System up time                : 0 days 2 hours 22 minutes 12 seconds
Model                         : WA6320
Region code                   : CN
Region code lock              : Disabled
Serial ID                     : 219801A28N819CE0002T
MAC address                   : 83D5-AB43-67FF
IP address                    : 1.1.1.2
UDP control port number       : N/A
UDP data port number          : N/A
H/W version                   : Ver.C
S/W version                   : V700R001B62D001
Boot version                  : 1.01
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Description                   : wtp1
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Discovery-response wait-time  : 2 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
CAPWAP data-tunnel status     : Up
Discovery type                : DHCP
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 1
Received control packets      : 1
Echo requests                 : 0
Lost echo responses           : 0
Average echo delay            : 0
Last reboot reason            : N/A
Latest IP address             : N/A
Current AC IP                 : N/A
Tunnel down reason            : N/A
Connection count              : 1
Backup Ipv4                   : Not configured
Backup Ipv6                   : Not configured
Ctrl-tunnel encryption        : Disabled
Ctrl-tunnel encryption state  : Not encrypted
Data-tunnel encryption        : Disabled
Data-tunnel encryption state  : Not encrypted
LED mode                      : Normal
Remote configuration          : Disabled
EnergySaving Level            : 0
Radio 1:
    Basic BSSID               : N/A
    Admin state               : Up
    Radio type                : 802.11ax
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel band-width        : 20/40/80MHz
    Operating bandwidth       : 20/40/80MHz
    Secondary channel offset  : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    mimo                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 52(auto)
    Max power                 : 20 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Supported             : 9, 18, 36, 48, 54 Mbps
        Multicast             : 24 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Maximum rx duration       : 2000 ms
    Noise Floor               : 0 dBm
    Protection mode           : cts-to-self
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    Continuous mode           : N/A
    Client dot11ax-only       : Disabled
    Operational HE-MCS Set:
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9,10,11
                                NSS2 0,1,2,3,4,5,6,7,8,9,10,11
    OFDMA random access RUs   : Not Supported
    Channel Width Set         : 0x02
    DL-OFDMA                  : Enabled
    UL-OFDMA                  : Enabled
    UL-MU-MIMO                : Disabled
    BSS-COLOR                 : Enabled
    TWT negotiation           : Disabled
    HT protection mode        : No protection
Radio 2:
    Basic BSSID               : N/A
    Admin state               : Up
    Radio type                : 802.11gax
    Channel bandwidth         : 20MHz
    Operating bandwidth       : 20MHz
    Secondary channel offset  : SCN
    Short GI for 80MHz        : Not supported
    mimo                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
        Supported             : Not configured
    Channel                   : 11(auto)
    Channel usage(%)          : 0
    Max power                 : 20 dBm
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise floor               : 0 dBm
    SU-TxBF                   : Enabled
    Channel Width Set         : 0x01
    DL-OFDMA                  : Enabled
    UL-OFDMA                  : Enabled
    BSS-COLOR                 : Enabled
2.     Verify that the radio state of AP 1 is Down when the state of track entry 1 is Negative:
Track ID: 1
  State: Negative
  Duration: 0 days 2 hours 5 minutes 48 seconds
  Tracked object:
    Reaction: 1
AP name                       : ap1
AP ID                         : 1
State                         : Run
Backup type                   : Idle
Model                         : WA6320
Region code                   : CN
H/W version                   : Ver.C
Boot version                  : 1.01
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Description                   : wtp1
Priority                      : 4
Echo requests                 : 0
Current AC IP                 : N/A
LED mode                      : Normal
Radio 1:
    Basic BSSID               : N/A
    Admin state               : Down
    mimo                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 52(auto)
    Max power                 : 20 dBm
    Operational rate:
        Multicast             : 24 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 0 dBm
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    DL-OFDMA                  : Enabled
    UL-OFDMA                  : Enabled
    BSS-COLOR                 : Enabled
Radio 2:
    Basic BSSID               : N/A
    Admin state               : Down
    mimo                      : Not Config
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Supported
    STBC                      : Supported
    Channel                   : 11(auto)
    Max power                 : 20 dBm
    Operational rate:
        Multicast             : Auto
    Distance                  : 1 km
    ANI                       : Enabled
    Noise floor               : 0 dBm
    SU-TxBF                   : Enabled
    DL-OFDMA                  : Enabled
    UL-OFDMA                  : Enabled
    BSS-COLOR                 : Enabled
