05-Network Connectivity Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C WX2800X&WSG1800X Configuration Guides(E5611)-5W10105-Network Connectivity Configuration Guide
07-Layer 2 forwarding configuration
07-Layer 2 forwarding configuration 47.59 KB
Configuring normal Layer 2 forwarding
About normal Layer 2 forwarding
When an incoming frame's destination MAC address does not match any Layer 3 interface's MAC address, normal Layer 2 forwarding forwards the frame through a Layer 2 interface.
The device uses the destination MAC address of the frame to look for a match in the MAC address table.
·     The device forwards the frame out of the outgoing interface in the matching entry if a match is found.
·     The device floods the frame to all interfaces in the VLAN of the frame if no match is found.
Normal Layer 2 forwarding is enabled by default.
Display and maintenance commands for Layer 2 forwarding
Display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ]
Clear Layer 2 forwarding statistics.
reset mac-forwarding statistics
Configuring fast Layer 2 forwarding
About fast Layer 2 forwarding
Fast Layer 2 forwarding improves packet forwarding efficiency by using a high-speed cache and flow-based technology. It identifies a flow by using the following items:
·     Source IP address.
·     Source port number.
·     Destination IP address.
·     Destination port number.
·     Protocol number.
·     Input interface.
·     Output interface.
·     VLAN ID.
Fast Layer 2 forwarding creates an entry in a high-speed cache by obtaining the forwarding information of a flow's first packet. Subsequent packets of the flow are forwarded based on the entry.
Fast Layer 2 forwarding is enabled by default.
Display and maintenance commands for fast Layer 2 forwarding
Display IPv4 fast forwarding entries.
display mac-forwarding cache ip [ ip-address ]
Display IPv4 fast forwarding entries for fragments.
display mac-forwarding cache ip fragment [ ip-address ]
Display IPv6 fast forwarding entries.
display mac-forwarding cache ipv6 [ ipv6-address ]
