- 04-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 policy-based routing configuration
- 12-Routing policy configuration
- 13-DCN configuration
| 07-Policy-based routing configuration | 147.21 KB |
Restrictions and guidelines: PBR configuration
Setting match criteria for a node
Configuring actions for a node
Specifying a policy for local PBR
Specifying a policy for interface PBR
Enabling the PBR logging feature
Display and maintenance commands for PBR
Configuring PBR
About PBR
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify parameters for packets that match specific criteria such as ACLs. The parameters include the next hop, output interface, default next hop, and default output interface.
Packet forwarding process
The device forwards received packets using the following process:
1. The device uses PBR to forward matching packets.
2. If one of the following events occurs, the device searches for a route (except the default route) in the routing table to forward packets:
¡ The packets do not match the PBR policy.
¡ The PBR-based forwarding fails.
3. If the routing table-based forwarding fails, the device uses the default next hop or default output interface defined in PBR to forward packets.
4. If the default next hop or default output interface-based forwarding fails, the device uses the default route to forward packets.
PBR types
PBR includes the following types:
· Local PBR—Guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
· Interface PBR—Guides the forwarding of packets received on an interface.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
· Each node is identified by a node number. A smaller node number has a higher priority.
· A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
· A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses but only one if-match clause for each type.
To match a node, a packet must match all types of the if-match clauses for the node but only one if-match clause for each type.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node? |
Match mode |
Permit |
Deny |
Yes. |
· If the node contains apply clauses, PBR executes the apply clauses on the node. ¡ If PBR-based forwarding succeeds, PBR does not compare the packet with the next node. ¡ If PBR-based forwarding fails, PBR does not compare the packet with the next node. · If the node does not contain apply clauses, the device performs a routing table lookup for the packet. |
The device performs a routing table lookup for the packet. |
No. |
PBR compares the packet with the next node. |
NOTE: A node that has no if-match clauses matches any packet. |
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop, output interface, default next hop, or default output interface.
· When the track entry associated with an object changes to Negative, the apply clause is invalid.
· When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see High Availability Configuration Guide.
If a packet destined for the local device matches a PBR policy, PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a PBR policy, be careful to avoid this situation.
PBR tasks at a glance
To configure PBR, perform the following tasks:
Enable VXLAN mode for PBR on VTEPs to direct packets to VXLAN tunnels.
b. Setting match criteria for a node
c. Configuring actions for a node
3. Specifying a policy for PBR
¡ Specifying a policy for local PBR
¡ Specifying a policy for interface PBR
4. (Optional.) Enabling the PBR logging feature
Enabling VXLAN-mode PBR
VXLAN-mode PBR enables you to guide packets from a site-facing interface on a VXLAN VTEP to a VXLAN tunnel by using a PBR policy. If VXLAN-mode PBR is not enabled, the PBR policy on a site-facing interface cannot guide packets to a VXLAN tunnel.
Enable VXLAN-mode PBR before you apply a PBR policy to a site-facing interface. This task requires PBR to update forwarding entries, which is time-consuming and might cause inadequate table entry resources.
1. Enter system view.
2. Enable VXLAN-mode PBR.
ip policy-based-route vxlan-mode enable
By default, VXLAN-mode PBR is disabled.
Configuring a policy
Creating a node
2. Create a node for a policy, and enter its view.
On a transport network device, you can configure PBR on the Layer 3 interface to guide the forwarding of packets based on VXLAN IDs. On a VXLAN IP gateway, you can configure PBR on the tunnel interface to guide the forwarding of packets based on VXLAN IDs.
2. Enter policy node view.
3. Set match criteria.
¡ Set an ACL match criterion.
By default, no ACL match criterion is set.
The ACL match criterion cannot match Layer 2 information.
When using the ACL to match packets, PBR ignores the action (permit or deny) and time range settings in the ACL.
¡ Set a local QoS ID match criterion.
if-match qos-local-id local-id-value qppb-manipulation
By default, no local QoS ID match criterion is set.
This command takes effect only on HFR cards and only when the TCAM operating mode of the device is routing or mix. For more information about TCAM operating modes, see device management in Fundamentals Configuration Guide.
If you specify the qppb-manipulation keyword, the command applies only to QPPB in which the device acts as a BGP receiver. The device determines that a received packet matches the policy node if the local QoS ID obtained from its matching route entry is identical to the specified local QoS ID criterion. For more information about QPPB, see ACL and QoS Configuration Guide.
¡ Set a VXLAN match criterion.
if-match vxlan-id vxlan-id
By default, no VXLAN match criterion is set.
About apply clauses
The apply clauses allow you to specify the actions to be taken on matching packets on a node.
The following apply clauses determine the packet forwarding paths in a descending order:
· apply access-vpn vpn-instance
· apply next-hop
· apply output-interface
· apply default-next-hop
· apply default-output-interface
PBR supports the types of apply clauses shown in Table 1.
Table 1 Priorities and meanings of apply clauses
Clause |
Meaning |
Priority |
apply precedence |
Sets an IP precedence. |
This clause is always executed. |
apply access-vpn vpn-instance |
Sets VPN instances. |
If a packet matches a forwarding entry of a specified VPN instance, it is forwarded in the VPN instance. |
apply next-hop and apply output-interface |
Sets next hops and output interfaces. |
Only the apply next-hop clause is executed when both are configured. |
apply default-next-hop and apply default-output-interface |
Sets default next hops and default output interfaces. |
Only the apply default-next-hop clause is executed when both are configured. The clauses take effect only in the following cases: · No next hops or output interfaces are set or the next hops and output interfaces are invalid. · The packet does not match any route in the routing table. |
apply statistics |
Counts successful matches and matching bytes on the policy node. |
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command. This clause is always executed for matching packets. |
For outbound PBR, you can specify only one next hop and the next hop must be directly connected.
If you specify a next hop or default next hop, PBR periodically performs a lookup in the FIB table to determine its availability. Temporary service interruption might occur if PBR does not update the route immediately after its availability status changes.
Configuring actions to modify packet fields
3. Configure actions.
¡ Set an IP precedence.
By default, no IP precedence is specified.
Configuring actions to direct packet forwarding
¡ Set VPN instances.
apply access-vpn vpn-instance vpn-instance-name
By default, no VPN instance is specified.
¡ Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no next hops are specified.
You can specify a maximum of two next hops for backup in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡ Set output interfaces.
apply output-interface interface-type interface-number [ track track-entry-number ]
By default, no output interfaces are specified.
¡ Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no default next hops are specified.
You can specify a maximum of two default next hops for backup in one command line or by executing this command multiple times.
¡ Set default output interfaces.
apply default-output-interface interface-type interface-number [ track track-entry-number ]
By default, no default output interfaces are specified.
Collecting policy node statistics
3. Count successful matches and matching bytes on the policy node.
apply statistics
By default, match counting is disabled on a policy node.
Perform this task to specify a policy for local PBR to guide the forwarding of locally generated packets.
You can specify only one policy for local PBR and must make sure the specified policy already exists. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
2. Specify a policy for local PBR.
ip local policy-based-route policy-name
By default, local PBR is not enabled.
Perform this task to apply a policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one policy to an interface and must make sure the specified policy already exists. Before you can apply a new interface PBR policy to an interface, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
When you use interface PBR in conjunction with VXLAN-mode PBR to guide packets on a site-facing interface to a VXLAN tunnel, enable VXLAN-mode PBR before you apply the PBR policy. For more information about VXLAN-mode PBR, see "Enabling VXLAN-mode PBR."
2. Enter interface view.
3. Specify a policy for interface PBR.
ip policy-based-route policy-name [ share-mode ]
By default, no interface policy is applied to an interface.
The share-mode keyword is supported only in R3608 and later.
The PBR logging feature helps the administrator locate and fix faults. The feature logs PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
2. Enable the PBR logging feature.
ip policy-based-route-log enable
By default, the PBR logging feature is disabled.
Task |
Command |
Display PBR policy information. |
display ip policy-based-route [ policy policy-name ] |
Display PBR configuration. |
display ip policy-based-route setup |
Display local PBR configuration and statistics. |
display ip policy-based-route local [ slot slot-number ] |
Display interface PBR configuration and statistics. |
display ip policy-based-route interface interface-type interface-number [ slot slot-number ] |
Clear PBR statistics. |
reset ip policy-based-route statistics [ policy policy-name ] |
PBR configuration examples
Example: Configuring packet type-based local PBR
As shown in Figure 1, Router B and Router C do not have a route to reach each other.
Configure PBR on Router A to forward all TCP packets to the next hop 1.1.2.2 (Router B).
IMPORTANT: By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface. |
1. Configure Router A:
# Configure the IP addresses of HundredGigE 1/0/1 and HundredGigE 1/0/2.
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] ip address 1.1.2.1 24
[RouterA-HundredGigE1/0/1] quit
[RouterA] interface hundredgige 1/0/2
[RouterA-HundredGigE1/0/2] ip address 1.1.3.1 24
[RouterA-HundredGigE1/0/2] quit
# Configure ACL 3101 to match TCP packets.
[RouterA] acl advanced 3101
[RouterA-acl-ipv4-adv-3101] rule permit tcp
[RouterA-acl-ipv4-adv-3101] quit
# Configure Node 5 for the policy aaa to forward TCP packets to next hop 1.1.2.2.
[RouterA] policy-based-route aaa permit node 5
[RouterA-pbr-aaa-5] if-match acl 3101
[RouterA-pbr-aaa-5] apply next-hop 1.1.2.2
[RouterA-pbr-aaa-5] quit
# Configure local PBR by applying the policy aaa to Router A.
[RouterA] ip local policy-based-route aaa
2. On Router B, configure the IP address of HundredGigE 1/0/1.
<RouterB> system-view
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] ip address 1.1.2.2 24
3. On Router C, configure the IP address of HundredGigE 1/0/2.
<RouterC> system-view
[RouterC] interface hundredgige 1/0/2
[RouterC-HundredGigE1/0/2] ip address 1.1.3.2 24
1. Perform telnet operations to verify that local PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Router B), as follows:
# Verify that you can telnet to Router B from Router A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Router A. (Details not shown.)
2. Verify that Router A forwards packets other than TCP packets through HundredGigE 1/0/2. For example, verify that you can ping Router C from Router A. (Details not shown.)
Example: Configuring packet type-based interface PBR
As shown in Figure 2, Router B and Router C do not have a route to reach each other.
Configure PBR on Router A to forward all TCP packets received on HundredGigE 1/0/1 to the next hop 1.1.2.2 (Router B).
1. Make sure Router B and Router C can reach Host A. (Details not shown.)
2. Configure Router A:
# Configure the IP addresses of HundredGigE 1/0/2 and HundredGigE 1/0/3.
[RouterA-HundredGigE1/0/2] ip address 1.1.2.1 24
[RouterA] interface hundredgige 1/0/3
[RouterA-HundredGigE1/0/3] ip address 1.1.3.1 24
[RouterA-HundredGigE1/0/3] quit
# Configure interface PBR by applying the policy aaa to HundredGigE 1/0/1.
[RouterA-HundredGigE1/0/1] ip address 10.110.0.10 24
[RouterA-HundredGigE1/0/1] ip policy-based-route aaa
1. Perform telnet operations to verify that interface PBR on Router A operates as configured to forward the matching TCP packets to the next hop 1.1.2.2 (Router B), as follows:
# Verify that you can telnet to Router B from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Router C from Host A. (Details not shown.)
2. Verify that Router A forwards packets other than TCP packets through HundredGigE 1/0/3. For example, verify that you can ping Router C from Host A. (Details not shown.)
