- 09-Security Command Reference
- 01-AAA commands
- 02-Password control commands
- 03-Keychain commands
- 04-Public key management commands
- 05-PKI commands
- 06-IPsec commands
- 07-SSH commands
- 08-SSL commands
- 09-Attack detection and prevention commands
- 10-IP source guard commands
- 11-ARP attack protection commands
- 12-ND attack defense commands
- 13-uRPF commands
- 14-Crypto engine commands
| 11-ARP attack protection commands | 165.36 KB |
Unresolvable IP attack protection commands
arp resolving-route probe-count
arp resolving-route probe-interval
display arp source-suppression
ARP packet rate limit commands
Source MAC-based ARP attack detection commands
display arp source-mac configuration
display arp source-mac statistics
reset arp source-mac statistics
ARP packet source MAC consistency check commands
display arp valid-check statistics
reset arp valid-check statistics
ARP active acknowledgement commands
display arp detection statistics
reset arp detection statistics
ARP scanning and fixed ARP commands
ARP gateway protection commands
ARP sender IP address checking commands
arp resolving-route enable
Use arp resolving-route enable to enable ARP blackhole routing.
Use undo arp resolving-route enable to disable ARP blackhole routing.
ARP blackhole routing is enabled.
Configure this command on the gateways.
# Enable ARP blackhole routing.
[Sysname] arp resolving-route enable
Use arp resolving-route probe-count to set the number of ARP blackhole route probes for each unresolved IP address.
Use undo arp resolving-route probe-count to restore the default.
arp resolving-route probe-count count
The device performs three ARP blackhole route probes for each unresolved IP address.
count: Sets the number of probes, in the range of 1 to 25.
# Configure the device to perform five ARP blackhole route probes for each unresolved IP address.
[Sysname] arp resolving-route probe-count 5
Use arp resolving-route probe-interval to set the interval at which the device probes ARP blackhole routes.
Use undo arp resolving-route probe-interval to restore the default.
arp resolving-route probe-interval interval
The device probes ARP blackhole routes every 1 second.
interval: Specifies the probe interval in the range of 1 to 5 seconds.
# Configure the device to probe ARP blackhole routes every 3 seconds.
[Sysname] arp resolving-route probe-interval 3
arp source-suppression enable
Use arp source-suppression enable to enable the ARP source suppression feature.
Use undo arp source-suppression enable to disable the ARP source suppression feature.
The ARP source suppression feature is disabled.
Configure this feature on the gateways.
# Enable the ARP source suppression feature.
[Sysname] arp source-suppression enable
arp source-suppression limit
Use arp source-suppression limit to set the maximum number of unresolvable packets that can be processed per source IP address within 5 seconds.
Use undo arp source-suppression limit to restore the default.
The device can process a maximum of 10 unresolvable packets per source IP address within 5 seconds.
limit-value: Specifies the limit in the range of 2 to 1024.
If unresolvable packets received from an IP address within 5 seconds exceed the limit, the device stops processing the packets from that IP address until the 5 seconds elapse.
# Configure the device to process a maximum of 100 unresolvable packets per source IP address within 5 seconds.
[Sysname] arp source-suppression limit 100
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
ARP source suppression is enabled
Current suppression limit: 100
Current suppression limit |
Maximum number of unresolvable packets that can be processed per source IP address within 5 seconds. |
arp rate-limit
Use arp rate-limit to enable the ARP packet rate limit feature on an interface.
Use undo arp rate-limit to disable the ARP packet rate limit feature on an interface.
arp rate-limit [ pps ]
undo arp rate-limit
The ARP packet rate limit feature is enabled on an interface.
pps: Specifies the upper limit for ARP packet rate in pps. The value range for this argument is 5 to 2000.
If you do not specify a value for the pps argument in the arp rate-limit command, the default rate limit value applies. Packets that exceed the rate limit are discarded.
# Enable the ARP packet rate limit feature on Layer 2 Ethernet interface HundredGigE 1/0/1, and set the maximum ARP packet rate to 50 pps.
[Sysname-HundredGigE1/0/1] arp rate-limit 50
arp rate-limit log enable
Use arp rate-limit log enable to enable logging for ARP packet rate limit.
Use undo arp rate-limit log enable to disable logging for ARP packet rate limit.
Logging for ARP packet rate limit is disabled.
When logging for ARP packet rate limit is enabled, the device sends the highest threshold-crossed ARP packet rate within the sending interval in a log message to the information center. You can configure the information center module to set the log output rules. For more information about information center, see Network Management and Monitoring Configuration Guide.
# Enable logging for ARP packet rate limit.
[Sysname] arp rate-limit log enable
arp rate-limit log interval
Use arp rate-limit log interval to set the notification and log message sending interval for ARP packet rate limit.
Use undo arp rate-limit log interval to restore the default.
arp rate-limit log interval interval
The device sends notifications or log messages every 60 seconds when the rate of ARP packets received on an interface exceeds the limit.
interval: Specifies an interval in the range of 1 to 86400 seconds.
To change the default interval and activate it, you must enable ARP packet rate limit and enable sending notifications or log messages for ARP packet rate limit.
# Set the device to send notifications and log messages every 120 seconds when the rate of ARP packets received on an interface exceeds the limit.
[Sysname] arp rate-limit log interval 120
arp rate-limit
snmp-agent trap enable arp
Use snmp-agent trap enable arp to enable SNMP notifications for ARP.
Use undo snmp-agent trap enable arp to disable SNMP notifications for ARP.
snmp-agent trap enable arp [ rate-limit ]
undo snmp-agent trap enable arp [ rate-limit ]
SNMP notifications for ARP are disabled.
rate-limit: Specifies the ARP packet rate limit feature.
After you enable SNMP notifications for ARP, the device generates a notification that includes the highest threshold-crossed ARP packet rate within the sending interval.
For ARP event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for ARP packet rate limit.
[Sysname] snmp-agent trap enable arp rate-limit
arp source-mac
Use arp source-mac to enable the source MAC-based ARP attack detection feature and specify a handling method.
Use undo arp source-mac to disable the source MAC-based ARP attack detection feature.
arp source-mac { filter | monitor }
undo arp source-mac [ filter | monitor ]
The source MAC-based ARP attack detection feature is disabled.
filter: Specifies the filter handling method.
monitor: Specifies the monitor handling method.
This feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within the check interval exceeds a threshold, the device generates an ARP attack entry for the MAC address. Before the entry ages out, the device handles the attack by using either of the following methods:
· Monitor—Only generates log messages.
· Filter—Generates log messages and filters out subsequent ARP packets from the MAC address.
Make sure you have enabled the ARP logging feature before enabling the source MAC-based ARP attack detection feature. For information about the ARP logging feature, see Layer 3—IP Services Configuration Guide.
If you do not specify any handling method in the undo arp source-mac command, the command disables this feature.
# Enable the source MAC-based ARP attack detection feature and specify the filter handling method.
[Sysname] arp source-mac filter
arp source-mac aging-time
Use arp source-mac aging-time to set the aging time for ARP attack entries.
Use undo arp source-mac aging-time to restore the default.
arp source-mac aging-time time
The aging time for ARP attack entries is 300 seconds.
time: Sets the aging time for ARP attack entries, in the range of 60 to 6000 seconds.
# Set the aging time for ARP attack entries to 60 seconds.
[Sysname] arp source-mac aging-time 60
arp source-mac check-interval
Use arp source-mac check-interval to set the check interval for source MAC-based ARP attack detection.
Use undo arp source-mac check-interval to restore the default.
arp source-mac check-interval interval
The check interval for source MAC-based ARP attack detection is 5 seconds.
interval: Specifies the check interval in seconds. The value range is 5 to 60.
The source MAC-based ARP attack detection feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within the check interval exceeds the threshold, the device generates an ARP attack entry for the MAC address.
If attacks occur frequently in your network, set a short check interval so that source MAC-based ARP attacks can be detected in a timely manner. If attacks seldom occur, you can set a long check interval.
# Set the check interval for source MAC-based ARP attack detection to 30 seconds.
[Sysname] arp source-mac check-interval 30
arp source-mac
arp source-mac exclude-mac
Use arp source-mac exclude-mac to exclude specific MAC addresses from source MAC-based ARP attack detection.
Use undo arp source-mac exclude-mac to remove the excluded MAC addresses from source MAC-based ARP attack detection.
arp source-mac exclude-mac mac-address&<1-10>
undo arp source-mac exclude-mac [ mac-address&<1-10> ]
No MAC addresses are excluded from source MAC-based ARP attack detection.
mac-address&<1-10>: Specifies a MAC address list. The mac-address argument indicates an excluded MAC address in the format of H-H-H. &<1-10> indicates the number of excluded MAC addresses that you can configure.
If you do not specify a MAC address, the undo arp source-mac exclude-mac command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC-based ARP attack detection.
[Sysname] arp source-mac exclude-mac 001e-1200-0213
arp source-mac threshold
Use arp source-mac threshold to set the threshold for source MAC-based ARP attack detection. If the number of ARP packets sent from a MAC address within the check interval exceeds this threshold, the device recognizes this as an attack.
Use undo arp source-mac threshold to restore the default.
arp source-mac threshold threshold-value
The threshold is 30 for source MAC-based ARP attack detection.
threshold-value: Specifies the threshold for source MAC-based ARP attack detection. The value range is 1 to 5000.
# Set the threshold for source MAC-based ARP attack detection to 30.
[Sysname] arp source-mac threshold 30
Use display arp source-mac to display ARP attack entries detected by source MAC-based ARP attack detection.
display arp source-mac interface interface-type interface-number [ slot slot-number ] [ verbose ]
display arp source-mac { mac mac-address | vlan vlan-id } slot slot-number [ verbose ]
display arp source-mac slot slot-number [ count | verbose ]
interface interface-type interface-number: Specifies an interface by its type and number. If you specify a virtual interface, you can also specify a location on the device to display entries for the member physical interfaces that the virtual interface has at that location.
mac mac-address: Specifies a MAC address, in the format of H-H-H.
vlan vlan-id: Specifies a VLAN by its VLAN ID, in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number.
verbose: Displays the detailed information about source MAC-based ARP attack entries. If you do not specify this keyword, this command displays the brief information about the source MAC-based ARP attack entries.
count: Displays the number of ARP attack entries detected by source MAC-based ARP attack detection. If you do not specify this keyword, the command displays ARP attack entries detected by source MAC-based ARP attack detection.
The slot slot-number option is supported only when the interface interface-type interface-number option specifies a virtual interface.
Virtual interfaces can be Layer 2 aggregate interfaces, Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, VXLAN VSI interface, EVB VSI interfaces, and EVB VSI aggregate interfaces.
If you do not specify any parameters, the command displays all ARP attack entries.
# Display the ARP attack entries detected by source MAC-based ARP attack detection on HundredGigE 1/0/1.
<Sysname> display arp source-mac interface hundredgige 1/0/1
Source MAC VLAN ID Interface Aging time (sec) Packets dropped
23f3-1122-3344 4094 HGE1/0/1 10 18446744073709551615
# Display the number of source MAC-based ARP attack entries.
<Sysname> display arp source-mac count
Total source MAC-based ARP attack detection entries: 1
# Display the detailed information about ARP attack entries detected by source MAC-based ARP attack detection on HundredGigE 1/0/1.
<Sysname> display arp source-mac interface hundredgige 1/0/1 verbose
Source MAC: 0001-0001-0001
VLAN ID: 4094
Hardware status: Succeeded
Aging time: 10 seconds
Interface: HundredGigE1/0/1
Attack time: 2018/06/04 15:53:34
Packets dropped: 18446744073709551615
Source MAC |
Source MA address in the source MAC-based ARP attack entry. |
VLAN ID |
ID of the VLAN where the source MAC-based ARP attack is detected. |
Interface where the source MAC-based ARP attack is detected. |
Aging time |
Remaining lifetime of the source MAC-based ARP attack entry, in seconds. |
Packets dropped |
Total number of packets dropped by source MAC-based ARP attack detection. If the packets dropped by source MAC-based ARP attack occurs on a Layer 2 Ethernet interface, packet drop statistics is not calculated and this field displays 1. |
Total source MAC-based ARP attack detection entries |
Total number of source MAC-based ARP attack entries. |
Hardware status |
Status of the source MAC-based ARP attack entry setting to hardware: · Succeeded · Failed · Not supported · Not enough resources |
Attack time |
Time when the source MAC-based ARP attack is detected. The formation of the time is YYYY/MM/DD HH:MM:SS. |
Use display arp source-mac configuration to display the configuration of source MAC-based ARP attack detection.
# Display the configuration of source MAC-based ARP attack detection.
<Sysname> display arp source-mac configuration
ARP source-mac is enabled.
Mode: Filter Check interval: 5 seconds
Threshold: 20 Aging time: 300 seconds
ARP source-mac is disabled.
ARP source-mac is enabled. |
The source MAC-based ARP attack detection is enabled. |
ARP source-mac is disabled. |
The source MAC-based ARP attack detection is disabled. |
Mode |
Source MAC-based ARP attack detection mode: · Filter. · Monitor. |
Check interval |
Check interval of the source MAC-based ARP attack detection, in seconds. |
Threshold |
Threshold for source MAC-based ARP attack detection. |
Aging time |
Aging time of the source MAC-based ARP attack entry, in seconds. |
arp source-mac
Use display arp source-mac statistics to display statistics for packets dropped by source MAC-based ARP attack detection.
display arp source-mac statistics slot slot-number
# Display statistics for packets dropped by source MAC-based ARP attack detection.
<Sysname> display arp source-mac statistics
Dropped ARP packets:123321
Dropped ARP packets |
Number of packets dropped by source MAC-based ARP attack detection. |
arp source-mac
Use reset arp source-mac to delete source MAC-based ARP attack entries.
reset arp source-mac [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ slot slot-number ]
mac mac-address: Specify a MAC address, in the format of H-H-H.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command deletes the source MAC-based ARP attack entries on the active MPU.
If you do not specify any parameter, the command deletes all source MAC-based ARP attack entries on the device.
# Delete all source MAC-based ARP attack entries on the device.
<Sysname> reset arp source-mac
Use reset arp source-mac statistics to clear statistics of packets dropped by source MAC-based ARP attack detection.
reset arp source-mac statistics [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ slot slot-number ]
If you do not specify any parameter, the command clears all statistics of packets dropped by source MAC-based ARP attack detection.
# Clear all statistics of packets dropped by source MAC-based ARP attack detection.
<Sysname> reset arp source-mac statistics
arp valid-check enable
Use arp valid-check enable to enable ARP packet source MAC address consistency check.
Use undo arp valid-check enable to disable ARP packet source MAC address consistency check.
ARP packet source MAC address consistency check is disabled.
Configure this feature on gateways. The gateways can filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp valid-check enable
Use display arp valid-check statistics to display statistics for packets dropped by ARP packet source MAC address consistency check.
display arp valid-check statistics slot slot-number
# Display statistics for packets dropped by ARP packet source MAC address consistency check.
<Sysname> display arp valid-check statistics
Table 5 Command output
Number of packets dropped by ARP packet source MAC address consistency check. |
Use reset arp valid-check statistics to clear statistics for packets dropped by ARP packet source MAC address consistency check.
reset arp valid-check statistics { all | slot slot-number }
all: Specifies all statistics for packets dropped by ARP packet source MAC address consistency check.
# Clear statistics for packets dropped by ARP packet source MAC address consistency check.
<Sysname> reset arp valid-check statistics
arp active-ack enable
Use arp active-ack enable to enable ARP active acknowledgement.
Use undo arp active-ack enable to disable ARP active acknowledgement.
arp active-ack [ strict ] enable
undo arp active-ack [ strict ] enable
The ARP active acknowledgement feature is disabled.
strict: Enables strict mode for ARP active acknowledgement.
Configure this feature on gateways to prevent user spoofing.
# Enable ARP active acknowledgement.
[Sysname] arp active-ack enable
Authorized ARP commands
arp authorized enable
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to disable authorized ARP on an interface.
Authorized ARP is disabled on the interface.
Layer 3 RPR logical interface view
VSI interface view
Reth interface/subinterface view
VLAN interface view
# Enable authorized ARP on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] arp authorized enable
arp detection enable
Use arp detection enable to enable ARP attack detection.
Use undo arp detection enable to disable ARP attack detection.
VLAN view
# Enable ARP attack detection for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp detection enable
arp detection port-match-ignore
arp detection rule
arp detection log enable
Use arp detection log enable to enable ARP attack detection logging.
Use undo arp detection log enable to disable ARP attack detection logging.
ARP attack detection logging is disabled.
# Enable ARP attack detection logging.
[Sysname] arp detection log enable
arp detection rule
Use arp detection rule to configure a user validity check rule.
Use undo arp detection rule to delete a user validity check rule.
arp detection rule rule-id { deny | permit } ip { ip-address [ mask ] | any } mac { mac-address [ mask ] | any } [ vlan vlan-id ]
undo arp detection rule [ rule-id ]
No user validity check rule is configured.
rule-id: Assigns an ID to the user validity check rule. The ID value range is 0 to 511. A smaller value represents a higher priority.
deny: Denies matching ARP packets.
permit: Permits matching ARP packets.
ip { ip-address [ mask ] | any }: Specifies the sender IP address as the match criterion.
· ip-address: Specifies an IP address in dotted decimal notation.
· mask: Specifies the address mask in dotted decimal notation. If you do not specify the mask, the ip-address argument specifies a host IP address.
· any: Matches any IP address.
mac { mac-address [ mask ] | any }: Specifies the sender MAC address as the match criterion.
· mac-address: Specifies a MAC address in the H-H-H format.
· mask: Specifies the MAC address mask in the H-H-H format. If you do not specify the mask, the argument specifies the host MAC address.
· any: Matches any MAC address.
vlan vlan-id: Specifies the ID of a VLAN to which the specified rule applies. The value range for the vlan-id argument is 1 to 4094. If you do not specify a VLAN, the rule applies to all VLANs.
A user validity check rule takes effect only when ARP attack detection is enabled.
If you do not specify a rule ID, the undo arp detection rule command deletes all user validity check rules.
# Configure a user validity check rule and enable ARP detection for VLAN 2.
[Sysname] arp detection rule 0 permit ip 10.1.1.1 255.255.0.0 mac 0001-0203-0405 ffff-ffff-0000
[Sysname] vlan 2
arp detection trust
Use arp detection trust to configure an interface as an ARP trusted interface.
Use undo arp detection trust to restore the default.
arp detection trust
An interface is an ARP untrusted interface.
# Configure HundredGigE 1/0/1 as an ARP trusted interface.
[Sysname-HundredGigE1/0/1] arp detection trust
arp detection validate
Use arp detection validate to enable ARP packet validity check.
Use undo arp detection validate to disable ARP packet validity check.
undo arp detection validate [ dst-mac | ip | src-mac ] *
ARP packet validity check is disabled.
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-one or multicast IP addresses are considered invalid and the corresponding packets are discarded.
src-mac: Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
You can specify more than one object to be checked in one command line.
If no keyword is specified, the undo arp detection validate command disables ARP packet validity check for all objects.
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac ip src-mac
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
ARP restricted forwarding is disabled.
VLAN view
# Enable ARP restricted forwarding in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] arp restricted-forwarding enable
Use display arp detection to display the VLANs enabled with ARP attack detection.
# Display the VLANs enabled with ARP attack detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1-2, 4-5
Use display arp detection statistics to display ARP attack detection statistics.
display arp detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the ARP attack detection statistics for all interfaces.
This command displays numbers of packets discarded by user validity check and ARP packet validity check.
# Display the ARP attack detection statistics for all interfaces.
<Sysname> display arp detection statistics
State: U-Untrusted T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State) IP Src-MAC Dst-MAC Inspect
HGE1/0/1(U) 40 0 0 78
HGE1/0/2(U) 0 0 0 0
HGE1/0/3(T) 0 0 0 0
HGE1/0/4(U) 0 0 30 0
Table 6 Command output
State |
State of an interface: · U—ARP untrusted interface. · T—ARP trusted interface. |
Interface(State) |
Inbound interface of ARP packets. State specifies the port state, trusted or untrusted. |
IP |
Number of ARP packets discarded due to invalid sender and target IP addresses. |
Src-MAC |
Number of ARP packets discarded due to invalid source MAC address. |
Dst-MAC |
Number of ARP packets discarded due to invalid destination MAC address. |
Inspect |
Number of ARP packets that failed to pass user validity check. |
Use reset arp detection statistics to clear ARP attack detection statistics.
reset arp detection statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears the ARP attack detection statistics of all interfaces.
# Clear the ARP attack detection statistics of all interfaces.
<Sysname> reset arp detection statistics
arp fixup
Use arp fixup to convert existing dynamic ARP entries to static ARP entries.
Use undo arp fixup to convert valid static ARP entries to dynamic ARP entries and delete invalid static ARP entries.
arp fixup
undo arp fixup
The ARP conversion is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
The static ARP entries converted from dynamic ARP entries have the same attributes as the manually configured static ARP entries. Due to the device's limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
The static ARP entries after conversion can include the following entries:
· Existing dynamic and static ARP entries before conversion.
· New dynamic ARP entries learned during the conversion.
Dynamic ARP entries that are aged out during the conversion are not converted to static ARP entries.
To delete a static ARP entry changed from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. To delete all such static ARP entries, use the reset arp all or reset arp static command.
# Convert existing dynamic ARP entries to static ARP entries.
[Sysname] arp fixup
arp scan
Use arp scan to trigger an ARP scanning in an address range.
arp scan [ start-ip-address to end-ip-address ]
VSI interface view
VLAN interface view
start-ip-address: Specifies the start IP address of the scanning range.
end-ip-address: Specifies the end IP address of the scanning range. The end IP address must be higher than or equal to the start IP address.
ARP scanning automatically creates ARP entries for devices in the specified address range. IP addresses already in existing ARP entries are not scanned.
If the interface's primary and secondary IP addresses are in the address range, the sender IP address in the ARP request is the address on the smallest network segment.
If no address range is specified, the device learns ARP entries for devices on the subnet where the primary IP address of the interface resides. The sender IP address in the ARP requests is the primary IP address of the interface.
The start and end IP addresses must be on the same subnet as the primary IP address or secondary IP addresses of the interface.
ARP scanning will take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
# Configure the device to scan neighbors on the network where the primary IP address of HundredGigE 1/0/1 resides.
[Sysname-HundredGigE1/0/1] arp scan
# Configure the device to scan neighbors in an address range.
[Sysname-HundredGigE1/0/1] arp scan 1.1.1.1 to 1.1.1.20
arp filter source
Use arp filter source to enable ARP gateway protection for a gateway.
Use undo arp filter source to disable ARP gateway protection for a gateway.
arp filter source ip-address
undo arp filter source ip-address
ARP gateway protection is disabled.
ip-address: Specifies the IP address of a protected gateway.
You can enable ARP gateway protection for a maximum of eight gateways on an interface.
You cannot configure both the arp filter source and arp filter binding commands on the same interface.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1.
[Sysname-HundredGigE1/0/1] arp filter source 1.1.1.1
ARP filtering commands
arp filter binding
Use arp filter binding to enable ARP filtering and configure an ARP permitted entry.
Use undo arp filter binding to remove an ARP permitted entry.
undo arp filter binding ip-address
ARP filtering is disabled.
ip-address: Specifies a permitted sender IP address.
mac-address: Specifies a permitted sender MAC address.
If the sender IP and MAC addresses of an ARP packet match an ARP permitted entry, the ARP packet is permitted. If the sender IP and MAC addresses of an ARP packet do not match an ARP permitted entry, the ARP packet is discarded.
You can configure a maximum of eight ARP permitted entries on an interface.
# Enable ARP filtering and configure an ARP permitted entry.
[Sysname-HundredGigE1/0/1] arp filter binding 1.1.1.1 0e10-0213-1023
arp sender-ip-range
Use arp sender-ip-range to enable the ARP sender IP address checking feature and specify the IP address range.
Use undo arp sender-ip-range to disable the ARP sender IP address checking feature.
arp sender-ip-range start-ip-address end-ip-address
The ARP sender IP address checking feature is disabled.
VLAN view
start-ip-address: Specifies the start IP address.
end-ip-address: Specifies the end IP address. The end IP address must be higher than or equal to the start IP address.
This feature enables a device to discard an ARP packet if its sender IP address is not within the specified IP address range.
# Enable the ARP sender IP address checking feature in VLAN 2 and specify the IP address range 1.1.1.1 to 1.1.1.20.
[Sysname] vlan 2
[Sysname–vlan2] arp sender-ip-range 1.1.1.1 1.1.1.20
