- 03-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-DHCPv6 commands
- 13-IPv6 fast forwarding commands
- 14-Tunneling commands
- 15-GRE commands
| 05-IP forwarding basics commands | 97.31 KB |
forwarding arp-packet destination
forwarding hop-limit-exceeded destination
forwarding nd-packet destination
forwarding ttl-exceeded-packet destination
forwarding tunnel-ttl-unvaried
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Route destination count: 5
Directly-connected host count: 0
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
1.1.1.0/24 192.168.126.1 USGF MGE0/0/0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U MGE0/0/0 Null
20.20.20.0/32 20.20.20.25 UBH MGE0/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H MGE0/0/0 Null
20.20.20.255/32 20.20.20.25 UBH M-GE0/0/0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
FIB entry count: 1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Route destination count |
Number of route destination addresses. |
Directly-connected host count |
Number of directly-connected hosts that are learned through features such as ARP. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
ip forwarding-table save
Use ip forwarding-table save to save the IP forwarding entries to a file.
ip forwarding-table save filename filename
filename filename: Specifies the name of a file, a string of 1 to 255 characters. For information about the filename argument, see Fundamentals Configuration Guide.
The command automatically creates the file if you specify a nonexistent file. If the file already exists, this command overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Save the IP forwarding entries to the fib.txt file.
<Sysname> ip forwarding-table save filename fib.txt
Use forwarding arp-packet destination to enable forwarding ARP packets with a specific destination address to the specified VXLAN tunnel.
Use undo forwarding arp-packet destination to restore the default.
forwarding arp-packet destination [ vpn-instance vpn-instance-name ] ip-address interface tunnel number
undo forwarding arp-packet destination [ vpn-instance vpn-instance-name ] ip-address
The device delivers ARP packets to CPU.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To specify an IP address in the public network, do not specify any VPN instance.
ip-address: Specifies the destination IP address.
interface tunnel number: Specifies the tunnel interface. The number argument represents the interface number. The actual number of tunnel interfaces that can be created depend on the total number of supported interfaces and memory usage.
In ARP flooding suppression, if a device receives an ARP packet that uses the device's MAC as the destination MAC but another device's IP as the destination IP, the device discards the packet. You can perform this task for the device to forward such packets to a specific VXLAN tunnel.
Make sure the specified tunnel interface is a manual created VXLAN over IPv4 tunnel.
# Enable forwarding ARP packet with TTL of 1 to tunnel interface 1 if the packets are destined to IP address 192.168.1.2.
[Sysname] forwarding arp-packet destination vpn-instance vpn1 192.168.1.2 interface tunnel 1
Use forwarding hop-limit-exceeded destination to enable forwarding IPv6 packet with HopLimit of 1 if the packets are destined to the specified IPv6 address. These IPv6 packets are not processed by the CPU.
Use undo forwarding hop-limit-exceeded destination to restore the default.
forwarding hop-limit-exceeded destination [ vpn-instance vpn-instance-name ] ipv6-address
undo forwarding hop-limit-exceeded destination [ vpn-instance vpn-instance-name ] ipv6-address
The device delivers IPv6 packets to CPU.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination IPv6 address belongs to the public network and all VPNs, do not specify this option.
ip-address: Specifies the destination IPv6 address.
This feature is typically configured on a device that acts as the gateway in the following scenario:
· The device directly connects to an interval server.
· The internal devices wishes to receive IPv6 packets destined to a specific IPv6 address, but they do not care about the HopLimit value in the packets.
Upon receiving an IPv6 packet destined to the specified destination IPv6 address, the device forwards the packet with HopLimit of 1 instead of sending it to the CPU.
# Enable forwarding IPv6 packet with HopLimit of 1 if the packets are destined to IPv6 address 1::1.
[Sysname] forwarding hop-limit-exceeded destination 1::1
Use forwarding nd-packet destination to enable forwarding ND packets with a specific destination address to the specified VXLAN tunnel.
Use undo forwarding nd-packet destination to restore the default.
forwarding nd-packet destination [ vpn-instance vpn-instance-name ] ipv6-address interface tunnel number
undo forwarding nd-packet destination [ vpn-instance vpn-instance-name ] ipv6-address
The device delivers ND packets to CPU.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination IPv6 address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. To specify an IP address in the public network, do not specify any VPN instance.
interface tunnel number: Specifies the tunnel interface. The actual number of tunnel interfaces that can be created depend on the total number of supported interfaces and memory usage.
In ND flooding suppression, if a device receives a ND packet that uses the device's MAC as the destination MAC but another device's IP as the destination IP, the device discards the packet. You can perform this task for the device to forward such packets to a specific VXLAN tunnel.
# Enable forwarding ND packet with TTL of 1 to tunnel interface 1 if the packets are destined to IPv6 address 4001::1.
[Sysname] forwarding nd-packet destination vpn-instance vpn1 4001::1 interface tunnel 1
Use forwarding ttl-exceeded-packet destination to enable forwarding IP packet with TTL of 1 if the packets are destined to the specified IP address. These IP packets are not processed by the CPU.
Use undo forwarding ttl-exceeded-packet destination to restore the default.
forwarding ttl-exceeded-packet destination [ vpn-instance vpn-instance-name ] ip-address
undo forwarding ttl-exceeded-packet destination [ vpn-instance vpn-instance-name ] ip-address
The device delivers IP packets to CPU.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the destination IP address belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the destination IP address belongs to the public network and all VPNs, do not specify this option.
· The internal server wishes to receive IP packets destined to a specific IP address, but it does not care about the TTL value in the packets.
Upon receiving an IP packet destined to the specified destination IP address, the device forwards the packet with TTL of 1 instead of sending it to the CPU.
# Enable forwarding IP packet with TTL of 1 if the packets are destined to IP address 10.1.1.2.
[Sysname] forwarding ttl-exceeded-packet destination 10.1.1.2
Use forwarding tunnel-ttl-unvaried to keep the TTL or hop limit unchanged in the packets passing through tunnel interfaces and VSI interfaces.
Use undo forwarding tunnel-ttl-unvaried to restore the default.
The TTL or hop limit is decremented by one when a packet passes through a tunnel interface or VSI interface.
View
On a private network using VXLANs or tunnels, the gateway decrements the value in the TTL or Hop Limit field by 1 in packets passing through VSI interfaces or tunnel interfaces by default. If you do not want the gateway to change the TTL or hop limit in these packets, execute this command on the gateway.
# Configure the device not to decrement the TTL or hop limit in the packets passing through tunnel interfaces and VSI interfaces.
[Sysname] forwarding tunnel-ttl-unvaried
Load sharing commands
bandwidth-based-sharing
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols, such as Locator/ID Separation Protocol (LISP), implement load sharing based on the ratios defined by these protocols.
This feature is mutually exclusive with the enhanced ECMP mode configured by the ecmp mode enhanced command.
After you enable this feature, the expected bandwidth set by using the bandwidth command on an interface cannot exceed the actual physical bandwidth of the interface.
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
display ip load-sharing mode
Use display ip load-sharing mode to display the load sharing mode in use.
display ip load-sharing mode slot slot-number
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the load sharing mode for all cards.
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 1
IP tunnel load-sharing mode: outer
Load-sharing mode |
The load sharing mode in use: per-flow—Per-flow load sharing. |
Load-sharing options |
Options configured for load sharing: · dest-ip—Identifies flows by packet's destination IP address. · src-ip—Identifies flows by packet's source IP address. · ip-pro—Identifies flows by packet's IP protocol. · dest-port—Identifies flows by packet's destination port number. · src-port—Identifies flows by packet's source port number. · ingress-port—Identifies flows by packet's ingress port. |
Load-sharing algorithm |
Algorithm used by load sharing. |
IP tunnel load-sharing mode |
Load sharing for IP tunnel packets: · all—Identifies flows by inner and outer IP header information. · inner—Identifies flows by inner IP header information. · outer—Identifies flows by outer IP header information. |
display ip load-sharing path
Use display ip load-sharing path to display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] *
ingress-port interface-type interface-number: Specifies an ingress port by its type and number.
packet-format: Specifies the packet encapsulation format.
ipv4oe: Specifies the format of IPv4 over Ethernet.
dest-ip ip-address: Specifies the destination IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
src-ip ip-address: Specifies the source IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
ipv6oe: Specifies the format of IPv6 over Ethernet.
dest-ipv6 ipv6-address: Specifies the destination IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
src-ipv6 ipv6-address: Specifies the source IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
dest-port port-id: Specifies a destination port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
ip-pro protocol-id: Specifies an IP protocol by its number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
source-port port-id: Specifies a source port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the path on the public network, do not specify this option.
When you configure this command, make sure the options are the same as those in the ip load-sharing mode command. If the options are not consistent, the path displayed by this command might be different from the real path for load sharing.
# Display the load sharing path selected for the flow with the following attributes: ingress port HundredGigE 1/0/3, destination IP address 10.110.0.2, source IP address 10.100.0.2, IP protocol number 153, destination port number 2000, source port number 2000.
<Sysname> display ip load-sharing path ingress-port hundredgige 1/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing algorithm: 0
Load-sharing options: ingress-port | dest-ip | src-ip | ip-pro | dest-port | src-port
Load-sharing parameters:
Missing configured are set to 0.
ingress-port: HundredGigE1/0/3
packet-format: IPv4oE
dest-ip: 10.110.0.2
src-ip: 10.100.0.2
ip-pro: 153
dest-port: 2000
src-port: 2000
Path selected: 20.0.0.2(interface HundredGigE1/0/3)
Load sharing algorithm ID. |
Load sharing options specified by the ip load-sharing mode command. |
Load-sharing parameters |
Load sharing parameters that you specify for the display ip load-sharing path command. |
Missing configured are set to 0. |
Values of the unconfigured parameters are set to 0. |
ingress-port |
Ingress port of the packet. |
packet-format |
Packet encapsulation format. |
dest-ip |
Destination IP address of the packet. |
src-ip |
Source IP address of the packet. |
ip-pro |
IP protocol number. |
dest-port |
Destination port number. |
src-port: |
Source port number. |
Path selected |
Selected path information, including the IPv4 or IPv6 address of the next hop and the egress port. |
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode per-flow [ algorithm algorithm-number | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] { global | slot slot-number }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { global | slot slot-number }
The device performs per-flow load sharing based on the source IP address, destination IP address, source port, destination port, IP protocol number, and ingress port of the packets.
per-flow: Implements per-flow load sharing. The device performs per-flow load sharing based on the source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port in packets if you specify none of these elements.
algorithm algorithm-number: Specifies an algorithm for per-flow load sharing. The value range for the algorithm-number argument is 0 to 15. Do not use the values 10 to 15 because they are reserved for special test environment. If you do not specify an algorithm, the default algorithm value is 0.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
global: Configures the load sharing mode globally.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
tunnel { all |inner | outer }: Performs load sharing for IP tunnel packets. The all keyword identifies flows by inner and outer IP header information. The inner keyword identifies flows by inner IP header information. The outer keyword identifies flows by outer IP header information. If you do not specify this option, the load sharing for IP tunnel packets is based on outer IP header information.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command configures the load sharing mode for all cards.
If you use the ip load-sharing mode or link-aggregation global load-sharing mode command multiple times, the most recent configuration takes effect.
When you configure the ip load-sharing mode and link-aggregation global load-sharing mode commands together, make sure their load sharing modes are the same as a best practice. After you save the configuration of these commands and reboot the device, only a random one of these commands can take effect. For more information about the link-aggregation global load-sharing mode command, see Ethernet link aggregation commands Layer—2 LAN Switching Command Reference.
# Configure per-packet load sharing on slot 1.
[Sysname] ip load-sharing mode per-packet slot 1
# Configure per-flow load sharing by destination IP address and source IP address on slot 1.
[Sysname] ip load-sharing mode per-flow dest-ip src-ip slot 1
# Configure per-flow load sharing for IP tunnel packets by inner IP header information on slot 1.
[Sysname] ip load-sharing mode per-flow tunnel inner slot 1
# Specify algorithm 1 for per-flow load sharing on slot 1.
[Sysname] ip load-sharing mode per-flow algorithm 1 slot 1
