- 02-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Bulk interface commands
- 03-Ethernet interface commands
- 04-Ethernet link aggregation commands
- 05-Port isolation commands
- 06-VLAN commands
- 07-Loopback, null, and inloopback interface commands
- 08-VLAN mapping commands
- 09-VLAN termination commands
- 10-Loop detection commands
- 11-LLDP commands
- 12-L2PT commands
- 13-Service loopback group commands
- 14-Spanning tree commands
- 15-Cut-through Layer 2 forwarding commands
| 00-Preface | 100.67 KB |
Preface
This command reference describes Layer 2-LAN switching configuration commands, including:
· Flow control and load sharing.
· Isolating users in the same VLAN and configuring VLANs.
· Eliminating Layer 2 loops.
· Transmitting packets of the customer network over the service provider network.
· Modifying VLAN tags of packets.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500R Switch Router Series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
