08-ACL and QoS Command Reference
HomeSupportSwitchesS6890 SeriesReference GuidesCommand ReferencesH3C S6890 Switch Series Command References(R36xx)-6W10108-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 433.52 KB
QoS policy commands· 1
Traffic class commands· 1
description· 1
display traffic classifier 1
if-match· 2
traffic classifier 9
Traffic behavior commands· 10
accounting· 10
car 11
display traffic behavior 12
filter 13
nest top-most 14
packet-rate· 15
redirect 15
remark customer-vlan-id· 16
remark dot1p· 17
remark drop-precedence· 18
remark dscp· 18
remark ip-precedence· 20
remark local-precedence· 20
remark qos-local-id· 21
remark service-class· 22
remark service-vlan-id· 23
traffic behavior 23
QoS policy commands· 24
classifier behavior 24
control-plane· 25
display qos policy· 26
display qos policy control-plane· 27
display qos policy control-plane pre-defined· 29
display qos policy global 30
display qos policy interface· 33
display qos vlan-policy· 36
qos apply policy(interface view, control plane view) 38
qos apply policy global 40
qos policy· 41
qos vlan-policy· 42
reset qos policy control-plane· 43
reset qos policy global 43
reset qos vlan-policy· 44
Priority mapping commands· 45
Priority map commands· 45
display qos map-table· 45
dot1p-trust-tc· 46
import 47
qos map-table· 47
Priority trust mode commands· 48
display qos trust interface· 48
qos trust 49
Port priority commands· 49
qos priority· 49
Traffic policing, GTS, and rate limit commands· 51
Traffic policing commands· 51
display qos car interface· 51
qos car 52
qos car percent 53
GTS commands· 54
display qos gts interface· 54
qos gts· 55
Rate limit commands· 56
display qos lr 56
qos lr 56
Congestion management commands· 58
Common commands· 58
display qos queue interface· 58
SP commands· 59
display qos queue sp interface· 59
qos sp· 59
WRR commands· 60
display qos queue wrr interface· 60
qos wrr 61
qos wrr { byte-count | weight } 62
qos wrr group sp· 63
WFQ commands· 64
display qos queue wfq interface· 64
qos bandwidth queue· 65
qos wfq· 65
qos wfq { byte-count | weight } 66
qos wfq group sp· 67
Queue scheduling profile commands· 68
bandwidth queue· 68
display qos qmprofile configuration· 69
display qos qmprofile interface· 70
qos apply qmprofile· 70
qos qmprofile· 71
queue· 72
Congestion avoidance commands· 74
WRED table commands· 74
display qos wred interface· 74
display qos wred table· 74
qos wred apply· 76
qos wred queue table· 77
queue· 77
queue ecn· 78
queue weighting-constant 79
Aggregate CAR commands· 81
car name· 81
display qos car name· 81
qos car 83
reset qos car name· 84
Queue-based accounting commands· 85
Interface queue-based traffic statistics commands· 85
display qos queue-statistics interface outbound· 85
display statistic mode· 86
reset qos queue-statistics interface outbound· 87
statistic mode queue· 87
QPPB commands· 89
bgp-policy· 89
QoS policy commands
A 100-GE interface before splitting has eight queues numbered 0 through 7. Each breakout interface has two queues and does not support priority mapping, GTS, congestion management, or congestion avoidance. For more information about interface splitting, see Ethernet interface configuration in see Layer 2—LAN Switching Configuration Guide.
description
Use description to configure a description for a traffic class.
Use undo description to delete the description of a traffic class.
No description is configured for a traffic class.
Traffic class view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as classifier for traffic class class1.
[Sysname-classifier-class1] description classifier
Use display traffic classifier to display traffic classes.
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ inner ]
Matches an ACL.
The following are available value ranges for the acl-number argument:
·     2000 to 2999 for basic ACLs.
·     3000 to 3999 for advanced ACLs.
·     4000 to 4999 for Layer 2 ACLs.
·     5000 to 5999 for user-defined ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
If you use the rule [ rule-id ] { deny | permit } command to match packets, the inner keyword matches the inner header information of VXLAN packets. If you do not specify this keyword, the ACL matches the header information of non-encapsulated packets or the outer header information of VXLAN packets.
If you use the rule [ rule-id ] { deny | permit } vxlan command to match inner header information of VXLAN packets, you do not need to specify the inner keyword in the if-match acl command.
To match VXLAN packets, you must execute the if-match vxlan { any | vxlan-id } command in the same traffic class.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
This option matches only protocol packets that use a well-known port number as the destination port number.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
destination-mac mac-address
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
[ ipv6 ] dscp dscp-value&<1-8>
Matches DSCP values.
If you do not specify the ipv6 keyword, this option matches the DSCP value of only IPv4 packets. If you specify the ipv6 keyword, this option matches the DSCP value of only IPv6 packets. The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
The ipv6 keyword is supported only in F3607P02 and later.
forwarding-layer bridge
Matches Layer 2 forwarded packets.
[ ipv6 ] ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
If you do not specify the ipv6 keyword, this option matches the IP precedence value of only IPv4 packets. If you specify the ipv6 keyword, this option matches the IP precedence value of only IPv6 packets. The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
mpls { l2vpn | l3vpn }
Matches the MPLS VPN type:
·     l2vpn—Matches L2VPN packets.
·     l3vpn—Matches L3VPN packets.
Matches a protocol.
The protocol-name argument can be ipv6 or ip.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 4095.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
The dot1p-value&<1-8> argument is a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use this option to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
tunnel-id tunnel-id-value
Matches a VXLAN tunnel ID. The value range for the tunnel ID is 0 to 70000.
This option is supported only in Release 3608 and later.
vlan-tag { double | none | single }
Matches the VLAN tagging mode:
·     double—Matches double-tagged packets.
·     none—Matches packets with no tags.
·     single—Matches single-tagged packets.
Matches a VXLAN ID in the range of 0 to 16777215.
Table 3 Available system-defined control plane protocols
Protocol
default
Protocol packets other than the following packet types
arp
ARP packets
arp-snooping
ARP snooping packets
bfd
BFD packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcpv6
IPv6 DHCP packets
dldp
DLDP packets
dot1x
802.1X packets
drcp
DRCP packets
hoplimit-expires
Hop-limit expire packets
icmp
ICMP packets
icmpv6
ICMPv6 packets
igmp
IGMP packets
ip-option
IPv4 packets with the Options field
ipv6-option
IPv6 packets with the Options field
isis
IS-IS packets
lacp
LACP packets
lldp
LLDP packets
mvrp
MVRP packets (including GVRP packets)
nd
ND packets
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
pim-multicast
PIM multicast packets
pim-unicast
PIM unicast packets
pim6-multicast
IPv6 PIM multicast packets
pim6-unicast
IPv6 PIM unicast packets
radius
RADIUS packets
snmp
SNMP packets
ssh
SSH packets
stp
STP packets
tacacs
TACACS packets
telnet
Telnet packets
ttl-expires
TTL expire packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
In a traffic class with the logical OR operator, you can configure multiple if match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·     You can specify up to eight values for any of the following match criteria in one if-match command:
¡     Control plane protocol.
¡     802.1p priority.
¡     DSCP.
¡     IP precedence.
¡     VLAN ID.
·     If a packet matches one of the specified values, it matches the if-match command.
·     To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
·     The ACL used as a match criterion must already exist.
·     Before defining a criterion to match the inner packet information of VXLAN packets in a traffic class, you must use the if-match vxlan command to define a VXLAN ID match criterion.
·     If a traffic class includes two ACL match criteria that match inner and outer packet information, follow these restrictions:
¡     Each ACL can contain only one rule.
¡     The rule in the ACL for matching the outer packet information can match only source IP addresses.
The ACL is used for classification only and the permit/deny actions in ACL rules are ignored. Actions taken on matching packets are defined in traffic behaviors.
You can use both AND and OR operators to define the match relationships between the criteria for a class. For example, you can define relationships among three match criteria in traffic class classA as follows:
traffic classifier classB operator and
if-match criterion 1
if-match criterion 2
traffic classifier classA operator or
if-match criterion 3
if-match classifier classB
# Define a match criterion for traffic class class1 to match the inner packet information of VXLAN packets.
[Sysname-classifier-class1] if-match vxlan any
[Sysname-classifier-class1] if-match acl 3000 inner
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match the advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match the advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match MPLS L2VPN packets.
[Sysname-classifier-class1] if-match mpls l2vpn
# Define a match criterion for traffic class class1 to match Layer 2 forwarded packets.
[Sysname-classifier-class1] if-match forwarding-layer bridge
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# Define a match criterion for traffic class class1 to match double-tagged packets.
[Sysname-classifier-class1] if-match vlan-tag double
# Define a match criterion for traffic class class1 to match all VXLAN packets matching ACL 3000.
# Define a match criterion for traffic class class1 to match the MPLS packets matching ACL 3000.
[Sysname-classifier-class1] if-match acl 3000 mpls-inner
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting  [ byte | packet ] *
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, traffic is counted in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 8 to 500000000 kbps, in increments of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in the range of 512 to 256000000 bytes, in increments of 512.
ebs excess-burst-size: Specifies the excess burst size (EBS) in the range of 0 to 256000000 bytes, in increments of 512.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 8 to 500000000 kbps, in increments of 8. The PIR must be greater than or equal to the CIR.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·     remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
·     remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
A traffic policing action takes effect only when a QoS policy is applied to the inbound direction of an interface.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
·     Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
·     Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
Use display traffic behavior to display traffic behaviors.
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Accounting enable
Traffic accounting action.
Filter enable
Traffic filtering action.
Redirecting
Information about traffic redirecting.
Mirroring
Information about traffic mirroring.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
A traffic filtering action takes effect only when a QoS policy is applied to an interface or globally.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure an outer VLAN tag adding action in a traffic behavior.
Use undo nest top-most to restore the default.
nest top-most vlan vlan-id
undo nest top-most
No outer VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added in the outer VLAN tag, in the range of 1 to 4094.
An outer VLAN tag adding action takes effect only when a QoS policy is applied to the inbound direction of an interface, VLANs, or globally.
For a QoS policy containing a nesting action to take effect, make sure both the downlink port and uplink port permit the single-tagged packets matching the QoS policy. The double-tagged packets are forwarded in the device based on the inner VLAN tag.
If you execute the nest top-most command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior b1 to add an outer VLAN tag with VLAN ID 123 and 802.1p priority value 3.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123 dot1p 3
packet-rate
Use packet-rate to configure a protocol packet rate limiting action in a traffic behavior.
Use undo packet-rate to restore the default.
packet-rate value
undo packet-rate
No protocol packet rate limiting action is configured.
value: Specifies the protocol packet rate in the range of 1 to 1048575 packets per second (pps).
A protocol packet rate limiting action takes effect only when a QoS policy is applied to the inbound direction of a control plane. You must use one of the following commands to configure match criteria in a traffic class:
·     if-match control-plane protocol
·     if-match control-plane protocol-group
·     if-match acl
This command can flexibly match packets sent to a control plane. You must use an advanced ACL in this command and the ACL must meet the following requirements:
¡     The protocol argument must be TCP or UDP.
¡     A single source or destination port number must be specified by using the eq value of the operator argument.
For example, if the used ACL contains the rule permit tcp source-port eq 80 command, the traffic class matches the TCP packets sent to a control plane.
If you execute this command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior copp to rate limit the protocol packets sent to the CPU to 1600 pps.
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number. To redirect traffic to a tunnel interface, set the interface type to tunnel. To redirect traffic to a Layer 2 aggregate interface, set the interface type to bridge-aggregation. To redirect traffic to a Layer 3 aggregate interface, set the interface type to route-aggregation.
A traffic redirecting action takes effect only when a QoS policy is applied to the inbound direction of an interface, VLANs, or globally.
If you execute the redirect command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure redirecting traffic to Ten-GigabitEthernet 1/0/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
qos policy
traffic behavior
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to restore the default.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
This command is supported only in Release 3608 and later.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior.
The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p dot1p-value command multiple times for the same color, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
A drop priority marking action takes effect only when the QoS policy is applied to the inbound direction.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
If you execute the remark dscp command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to restore the default.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
If you execute the remark ip-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
A local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
By marking the local precedence, you assign matching packets to the queue corresponding to the local precedence value. You can use the display qos queue-statistics interface outbound command to display outgoing traffic statistics collected for interfaces on a per-queue basis. The outgoing traffic statistics are displayed only if you have enabled queue-based traffic accounting in the outbound direction and set the packet counting mode to queue.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
# Configure the action of marking packet with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
Use remark service-class to configure an action of marking the MPLS TE service class in a traffic behavior.
Use undo remark service-class to restore the default.
remark service-class service-class-value
No MPLS TE service class marking action is configured.
service-class-value: Specifies the MPLS TE service class in the range of 0 to 7. The value 0 is not supported in the current software version.
An MPLS TE service class marking action takes effect only when the QoS policy is applied to the inbound direction of an interface.
Only one MPLS TE service class marking action can be configured for packets with the same MPLS EXP value on an interface. To modify the MPLS TE service class to be marked, you must remove the existing service class setting and configure a new service class value.
If you execute the remark service-class command multiple times in the same traffic behavior, the most recent configuration takes effect.
You can use the mpls te service-class command to set the MPLS TE service class. For more information, see MPLS TE commands in MPLS Command Reference.
# Configure an action of marking the MPLS TE service class as 2.
[Sysname-behavior-data] remark service-class 2
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to restore the default.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [  [ mode { dcbx | qppb-manipulation } | insert-before before-classifier-name ] *insert-before before-classifier-name ] *
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode dcbx: Specifies that the class-behavior association applies only to the DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
mode qppb-manipulation: Specifies that the class-behavior association applies only to QPPB. The if-match qos-local-id command in the class sets the same local QoS ID as the apply qos-local-id command in the BGP routing policy. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and specify that the class-behavior association applies only to QPPB.
[Sysname-qospolicy-user1] classifier database behavior test mode qppb-manipulation
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
A QoS policy applied in control plane view takes effect on all packets to the control plane except the packets sent from the management interface.
# Enter the control plane view of slot 1.
[Sysname] control-plane slot 1
[Sysname-cp-slot1]
display qos policy
Use display qos policy to display QoS policies.
display qos policy user-defined [ accounting | remarking ] [ policy-name [ classifier classifier-name ] ] [ slot slot-number ]
user-defined: Specifies user-defined QoS policies.
accounting: Specifies accounting-type QoS policies.
remarking: Specifies marking-type QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
If you do not specify the accounting or remarking keyword, this command displays generic QoS policies.
# Display all user-defined generic QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
     Behavior: 2
      Marking:
        Remark mpls-exp 4
     Behavior: 3
      -none-
# Display user-defined accounting-type QoS policies.
<Sysname> display qos policy user-defined accounting
  Accounting policy: 1 (ID 100)
     Behavior: 1
# Display user-defined marking-type QoS policies.
<Sysname> display qos policy user-defined remarking
  Marking policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
Table 6 Command output
Information about user-defined QoS policies.
Policy
User-defined generic QoS policy name or system-defined QoS policy name.
Accounting policy
User-defined accounting-type QoS policy name.
Mirroring policy
User-defined mirroring-type QoS policy name.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
# Display the QoS policy applied to the control plane of slot 1.
<Sysname> display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
                        0 (pps) 0 (bps)
        Yellow packets: 0 (Packets) 0 (Bytes)
                        0 (pps) 0 (bps)
        Red packets   : 0 (Packets) 0 (Bytes)
                        0 (pps) 0 (bps)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 7 Command output
Direction
Inbound direction on the control plane.
Green packets
Total number of bytes for green packets and average rate of green packets in the most recent statistics collection interval. The interval is set by using the flow-interval command (see Ethernet interface commands in Layer 2—LAN Switching Command Reference).
Yellow packets
Total number of bytes for yellow packets and average rate of yellow packets in the most recent statistics collection interval. The interval is set by using the flow-interval command (see Ethernet interface commands in Layer 2—LAN Switching Command Reference).
Red packets
Total number of bytes for red packets and average rate of red packets in the most recent statistics collection interval. The interval is set by using the flow-interval command (see Ethernet interface commands in Layer 2—LAN Switching Command Reference).
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies of cards.
# Display the predefined control plane QoS policy of slot 3.
<Sysname> display qos policy control-plane pre-defined slot 1
 Pre-defined policy information slot 1
  Protocol          Priority   Bandwidth          Group
  Default           N/A        5000 (pps)         N/A
  IS-IS             5          2048 (pps)         critical
  VRRP              6          512 (pps)          important
  OSPF Multicast    5          4096 (pps)         critical
  OSPF Unicast      5          4096 (pps)         critical
  PIM Multicast     4          512 (pps)          critical
  PIM Unicast       4          512 (pps)          critical
  IGMP              3          512 (pps)          important
  PIMv6 Multicast   4          256 (pps)          critical
  PIMv6 Unicast     4          256 (pps)          critical
  OSPFv3 Unicast    5          2048 (pps)         critical
  OSPFv3 Multicast  5          2048 (pps)         critical
  VRRPv6            6          512 (pps)          important
  ARP               2          2048 (pps)         normal
  DHCP Snooping     3          384 (pps)          redirect
  DHCP              3          384 (pps)          normal
  802.1x            2          512 (pps)          important
  STP               6          384 (pps)          critical
  LACP              6          43 (pps)           critical
  MVRP              3          384 (pps)          critical
  BGP               4          2048 (pps)         critical
  ICMP              1          512 (pps)          monitor
  TTL Expires       3          256 (pps)          important
  IPOPTION          3          256 (pps)          normal
  BGPv6             4          2048 (pps)         critical
  Hop Limit Expires 3          256 (pps)          important
  IPOPTIONv6        3          256 (pps)          normal
  LLDP              4          384 (pps)          important
  DLDP              4          256 (pps)          critical
  TELNET            1          896 (pps)          management
  SSH               1          896 (pps)          management
  TACACS            1          896 (pps)          management
  RADIUS            1          896 (pps)          management
  SNMP              1          896 (pps)          management
  ARP Snooping      3          2048 (pps)         redirect
  ICMPv6            1          2048 (pps)         monitor
  DHCPv6            3          384 (pps)          normal
  BFD               5          6400 (pps)         critical
Table 8 Command output
Pre-defined control plane policy
Contents of the pre-defined control plane QoS policy.
Use display qos policy global to display QoS policies applied globally.
display qos [ accounting | remarking ] policy global [ slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction globally.
outbound: Specifies the QoS policy applied in the outbound direction globally.
If you do not specify the accounting or remarking keyword, this command displays information about generic QoS policies.
If you do not specify a direction, this command displays both QoS policies applied globally.
# Display generic QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Type     : Extension
  Policy: 1, Preorder 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# Display information about marking-type QoS policies applied globally.
<Sysname> display qos remarking policy global
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display information about accounting-type QoS policies applied globally.
<Sysname> display qos accounting policy global
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        0 (Packets)
        0 (pps)
Table 9 Command output
Direction
Direction (inbound or outbound ) in which the QoS policy is applied.
Policy
User-defined generic QoS policy name.
Accounting policy
Mirroring policy
Mode in which the QoS policy is applied globally, which can only be Extension (extended mode).
If you do not specify the mode when applying a QoS policy globally, this field does not appear.
Green packets
Yellow packets
Red packets
Use display qos policy interface to display the QoS policies applied to interfaces or PVCs.
display qos [ accounting | remarking ] policy interface [ interface-type interface-number ] [ slot slot-number | all ] [ inbound | outbound ]
all: Displays information about the specified logical interface. This keyword is supported only if you have specified a logical interface. The command execution results are the same on matter whether you specify this keyword.
inbound: Specifies the QoS policies applied to the inbound direction.
outbound: Specifies the QoS policies applied to the outbound direction.
If you do not specify a direction, this command displays both the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction.
# Display the generic QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
        0 (pps)
      Marking:
        Remark mpls-exp 4
# Display information about the accounting-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos accounting policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Accounting enable:
        0 (Packets)
        0 (pps)
# Display information about the marking-type QoS policy applied to the incoming traffic of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos remarking policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Marking policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
# Display the generic QoS policies applied to all interfaces.
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/2
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
        Green action  : pass
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
Interface: Ten-GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        CIR 200 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 0(Packets)
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
Interface: Ten-GigabitEthernet1/0/4
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/5
        Green action  : pass
                        0 (pps) 0 (bps)
                        0 (pps) 0 (bps)
Table 10 Command output
Direction
Direction in which the QoS policy is applied to the interface.
Policy
Accounting policy
Marking policy
User-defined marking-type QoS policy name.
Mode in which the QoS policy is applied an interface, which can only be Extension (extended mode).
If you do not specify the mode when applying a QoS policy an interface, this field does not appear.
Mode
Sharing mode for QoS and ACL resources.
This field appears only if a QoS policy is applied with the share-mode keyword specified.
Green packets
Yellow packets
Red packets
Use display qos vlan-policy to display QoS policies applied to VLANs.
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
If you do not specify a direction, this command displays the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Outbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Green packets : 0(Packets) 0(Bytes)
                        0 (pps) 0 (bps)
        Yellow packets: 0(Packets) 0(Bytes)
                        0 (pps) 0 (bps)
        Red packets   : 0(Packets) 0(Bytes)
                        0 (pps) 0 (bps)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 11 Command output
Direction
Direction in which the QoS policy is applied for the VLAN.
Mode in which the QoS policy is applied to a VLAN. The value can only be Extension.
If you do not specify the mode when applying a QoS policy to a VLAN, this field does not appear.
Green packets
Yellow packets
Red packets
Use qos apply policy to apply a QoS policy to an interface or control plane.
Use undo qos apply policy to remove an applied QoS policy.
qos apply [ accounting | remarking ] policy policy-name { inbound [ extension ] | outbound } [ share-mode ]
undo qos apply [ accounting | remarking ] policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Interface view
accounting: Specifies an accounting-type QoS policy. This keyword is supported only in interface view.
remarking: Specifies a marking-type QoS policy. This keyword is supported only in interface view.
inbound: Applies the QoS policy to the inbound direction.
outbound: Applies the QoS policy to the outbound direction. This keyword is not supported in control plane view.
extension: Applies the QoS policy in extended mode. A QoS policy applied with the extension keyword uses more hardware resources but supports fewer parameters than that applied without the extension keyword.
share-mode: Applies the QoS policy in sharing mode to a Layer 2 or Layer 3 Ethernet interface. In this mode, all interfaces with the same QoS policy applied in one direction share one QoS and ACL resource.
A maximum of three QoS policies can be applied to one direction of an interface: one accounting-type, one marking-type, and one generic.
You can use the following commands to match protocol packets sent to the CPU for a QoS policy applied to a control plane:
·     if-match acl
When you use the if-match acl command to match protocol packets sent to the CPU, follow these restrictions and guidelines:
¡     The used ACL must be an advanced ACL.
¡     You must specify TCP or UDP for the protocol argument in the rule.
¡     You must specify a source port or destination port by using the eq operator in the rule.
For example, an IPv4 advanced ACL that contains a rule permit tcp source-port eq 80 statement can match TCP packets sent to the CPU.
If you specify the share-mode keyword when applying a QoS policy to an interface, follow these restrictions and guidelines:
·     All interfaces on an interface module with the QoS policy applied in one direction share one QoS and ACL resource.
If the share-mode keyword is not specified, each interface uses one QoS and ACL resource in one direction.
·     All interfaces that share one QoS and ACL resource evenly share the set CIR if a traffic policing action is configured in the QoS policy.
If the share-mode keyword is not specified, the bandwidth of each interface can be limited to the CIR.
·     You cannot specify the share-mode keyword when applying an ACL to the same direction of the interface. For more information about applying an ACL to an interface, see the packet-filter (interface view) command in ACL commands.
The display qos policy interface command output for an interface also contains packet statistics for all interfaces that share the QoS and ACL resource with the interface.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1.     Remove the QoS policy from the interface.
2.     Reapply the QoS policy with or without the share-mode keyword specified.
# Apply generic QoS policy USER1 to the incoming traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy USER1 inbound
# Apply accounting-type QoS policy USER2 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply accounting policy USER2 outbound
# Apply marking-type QoS policy USER3 to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply remarking policy USER3 outbound
# Apply generic QoS policy aaa to the incoming traffic of the control plane of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3] qos apply policy aaa inbound
# Apply generic QoS policy aaa in sharing mode to the outgoing traffic of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1]qos apply policy aaa outbound share-mode
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply [ accounting | remarking ] policy policy-name global { inbound [ extension ] | outbound }
undo qos apply [ accounting | remarking ] policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
A QoS policy applied globally takes effect on traffic of all interfaces.
A maximum of three QoS policies can be applied to one direction globally: one accounting-type, one marking-type, and one generic.
If you do not specify the accounting or remarking keyword, this command applies a generic QoS policy globally.
# Globally apply generic QoS policy user1 to the incoming traffic in extended mode.
[Sysname] qos apply policy user1 global inbound extension
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos [ accounting | remarking ] policy policy-name
undo qos [ accounting | remarking ] policy policy-name
No QoS policies exist.
accounting: Identifies the QoS policy as an accounting-type QoS policy.
remarking: Identifies the QoS policy as a marking-type QoS policy.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
The device supports the following QoS policy types:
·     Accounting—Can contain only class-based accounting actions.
·     Marking—Can contain only marking actions.
·     Generic—Can contain any actions.
If you do not specify the accounting or remarking keyword when creating a QoS policy, a generic QoS policy is created
QoS policies of different types cannot use the same policy name.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a generic QoS policy named user1.
# Create an accounting-type QoS policy named user2.
[Sysname] qos accounting policy user2
[Sysname-qospolicy-user2]
# Create a marking-type QoS policy named user3.
[Sysname] qos remarking policy user3
[Sysname-qospolicy-user3]
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
qos vlan-policy policy-name vlan vlan-id-list { inbound [ extension ] | outbound }
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
You can apply a QoS policy to one direction of an interface in either extended mode or common mode, but not both. A QoS policy applied in extended mode uses more hardware resources but supports limited parameters.
# Apply QoS policy test  in extended mode to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound extension
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
# Clear the statistics of the QoS policy applied to the control plane of slot 1.
<Sysname> reset qos policy control-plane slot 1
Use reset qos policy global to clear the statistics for QoS policies applied globally.
reset qos [ accounting | remarking ] policy global [ inbound | outbound ]
inbound: Specifies the QoS policy applied to the inbound direction globally.
outbound: Specifies the QoS policy applied to the outbound direction globally.
If you do not specify the accounting or remarking keyword, this command clears the statistics for generic QoS policies.
If you do not specify a direction, this command clears the statistics for both QoS policies applied globally.
# Clear the statistics for the generic QoS policy applied to the incoming traffic globally.
<Sysname> reset qos policy global inbound
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics for both the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction .
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
A 100-GE interface before splitting has eight queues numbered 0 through 7. Each breakout interface has two queues and does not support priority mapping. For more information about interface splitting, see Ethernet interface configuration in see Layer 2—LAN Switching Configuration Guide.
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp ]
The device provides the following types of priority map.
Table 12 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-dscp
802.1p-DSCP priority map.
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dp
DSCP-drop priority map.
dscp-dscp
DSCP-DSCP priority map.
dscp-exp
DSCP-EXP priority map.
exp-dot1p
EXP-802.1p priority map.
exp-dscp
EXP-DSCP priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 13 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
dot1p-trust-tc
Use dot1p-trust-tc to modify the 802.1p priority of outgoing packets to the local precedence value.
Use undo dot1p-trust-tc to restore the default.
dot1p-trust-tc slot slot-number
undo dot1p-trust-tc slot slot-number
The 802.1p priority of outgoing packets is not modified.
For the remark dot1p command to take effect, this command must be executed.
After an incoming packet is marked according to the remark dot1p command, it is assigned to a queue according to the default dot1p-lp priority map. The 802.1p priority of the packet is modified as its local precedence value before it is sent out.
If you modify the default dot1p-lp priority map, the outgoing packet is enqueued to a different queue, and its 802.1p priority is modified to a different local precedence value.
# Modify the 802.1p priority of outgoing packets to the local precedence value.
[Sysname] dot1p-trust-tc slot 1
remark dot1p
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-drop priority map to map 802.1p priority values 4 and 5 to drop priority 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-dscp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp }
For the description of the keywords, see Table 12.
# Enter the 802.1p-drop priority map view.
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priorities of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
 Port priority trust information
  Port priority: 0
  Port dscp priority: -
  Port priority trust type: none
Table 14 Command output
Interface type and interface number.
Port dscp priority
DSCP value of the port.
Priority trust mode: dot1p, dscp, or none. If the trust mode is none, the port priority is used for priority mapping.
Override
Indicates whether the priority derived through priority mapping overwrites the priority carried in the packet.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust  { dot1p | dscp }
undo qos trust
An interface does not trust any packet priority.
dot1p: Uses the 802.1p priority in incoming packets for priority mapping. This keyword is supported only on Layer 2 Ethernet interfaces.
dscp: Uses the DSCP value in incoming packets for priority mapping.
# Set the priority trust mode to 802.1p priority on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
The port priority is 0, and the DSCP priority does not have a default value.
priority-value: Specifies the port priority value. If you specify the dscp keyword, the value range is 0 to 63.
# Set the DSCP port priority of Ten-GigabitEthernet 1/0/1 to 20.
[Sysname-Ten-GigabitEthernet1/0/1] qos priority dscp 20
Traffic policing, GTS, and rate limit commands
A 100-GE interface before splitting has eight queues numbered 0 through 7. Each breakout interface has two queues and does not support GTS . For more information about interface splitting, see Ethernet interface configuration in see Layer 2—LAN Switching Configuration Guide.
Traffic policing commands
display qos car interface
Use display qos car interface to display the CAR information for interfaces.
display qos car interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the CAR information for all interfaces.
This command is supported only in F3607P02 and later.
# Display the CAR information for Ten-GigabitEthernet 1/0/1.
<Sysname> display qos car interface ten-gigabitethernet 1/0/1
 Direction: inbound
  Rule: If-match any
   CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
Table 15 Command output
Interface name, including interface type and interface number.
Direction
Direction in which traffic policing is applied.
Rule
Match criteria.
CIR
CIR in kbps (if the CIR is specified in absolute value) or in percentage (if the CIR is specified in percentage).
CBS
CBS in bytes (if the CBS is specified in absolute value) or in ms (if the CBS is specified in milliseconds). When the CBS is specified in milliseconds, the actual CBS value is cbs-time × the actual CIR value.
EBS
EBS in bytes (if the EBS is specified in absolute value) or in ms (if the EBS is specified in milliseconds). When the EBS is specified in milliseconds, the actual EBS value is ebs-time × the actual CIR value.
PIR
PIR in kbps (if the PIR is specified in absolute value) or in percentage (if the PIR is specified in percentage).
qos car
Use qos car to configure a CAR policy on an interface.
Use undo qos car to delete a CAR policy from an interface.
qos car inbound any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car inbound any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car inbound any
No CAR policy is configured.
Interface view
inbound: Performs CAR for incoming packets on the interface.
any: Performs CAR for all IP packets in the specified direction.
cir committed-information-rate: Specifies the CIR in kbps. The value range for the committed-information-rate argument is 8 to 10000000 for 10-GE interfaces and 8 to 100000000 for 100-GE interfaces. The specified value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes, which is the size of bursty traffic when the actual average rate is not greater than the CIR. The value range for committed-burst-size is 512 to 256000000, in increments of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512 that is greater than the product. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 4294967294. The default value for this argument is the product of 62.5 and the PIR. A default value greater than 4294967294 is converted to 4294967294.
pir peak-information-rate: Specifies the PIR in the range of 0 to 4294967294 kbps.
To use two rates for traffic policing, execute the qos car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the qos car command without the pir peak-information-rate option.
If you execute the qos car command multiple times on the same interface, the most recent configuration takes effect.
# Perform CAR for all packets in the inbound direction of Ten-GigabitEthernet 1/0/1. The CAR parameters are as follows:
·     CIR is 200 kbps.
·     CBS is 5120 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos car inbound any cir 200 cbs 5120
qos car percent
Use qos car percent to configure a CAR policy in percentage on an interface.
qos car inbound any percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ]
qos car inbound any percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ]
No CAR policy is configured in percentage.
Interface view
inbound: Performs CAR in the inbound direction.
any: Performs CAR for all IP data packets in the specified direction.
percent cir cir-percent: Specifies the CIR in percentage, in the range of 1 to 100. The actual CIR value is cir-percent × interface bandwidth.
cbs cbs-time: Specifies the CBS in the range of 50 to 2000 milliseconds. The actual CBS value is cbs-time × the actual CIR value.
ebs ebs-time: Specifies the EBS in the range of 0 to 2000 milliseconds. The actual EBS value is ebs-time × the actual CIR value.
pir pir-percent: Specifies the PIR in percentage, in the range of 1 to 100. The value for the pir-percent argument must be greater than or equal to the value for the cir-percent argument.
To use two rates for traffic policing, configure the qos car percent command with the pir pir-percent option. To use one rate for traffic policing, configure the qos car percent command without the pir pir-percent option.
If you execute the qos car percent command multiple times on the same interface, the most recent configuration takes effect.
For this command to take effect on the following interfaces, you must first use the bandwidth command to set the expected bandwidth of the interface:
·     Layer 2 aggregate interface.
·     Layer 3 aggregate interface.
·     Layer 3 aggregate subinterface.
For more information about the bandwidth command, see Ethernet link aggregation commands in Layer 2—LAN Switching Command Reference.
·     CIR is 200 kbps.
[Sysname-Ten-GigabitEthernet1/0/1] qos car inbound any percent cir 50 cbs 1000
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS information for interfaces.
display qos gts interface [ interface-type interface-number [ slot slot-number ] ]
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display the GTS information for all interfaces.
 Rule: If-match queue 0
Table 16 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos gts
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 100000000, in increments of 8.
cbs committed-burst-size: Specifies the CBS in the range of 512 to 16000000 bytes, in increments of 512.
The GTS configuration takes effect only on outgoing traffic.
# Shape the packets in queue 0 on Ten-GigabitEthernet 1/0/1. The GTS parameters are as follows:
·     The CIR is 200 kbps.
·     The CBS is 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos gts queue 0 cir 200 cbs 51200
Rate limit commands
display qos lr
Use display qos lr to display the rate limit information for interfaces.
# Display the rate limit information for all interfaces.
Direction: Outbound
  CIR 1024 (kbps), CBS 51200 (Bytes)
Table 17 Command output
Direction
Direction to which the rate limit configuration is applied: Outbound.
CIR
CIR in kbps.
CBS
CBS in bytes.
qos lr
Use qos lr to configure rate limiting on an interface.
Use undo qos lr to delete the rate limit configuration on an interface.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
No rate limit is configured.
outbound: Limits the rate in the outbound direction.
cir committed-information-rate: Specifies the CIR in the range of 8 to 100000000 kbps, in increments of 8.
cbs committed-burst-size: Specifies the CBS in the range of 512 to 128000000 bytes, in increments of 512.
# Limit the rate of outgoing packets on Ten-GigabitEthernet 1/0/1, with CIR 200 kbps and CBS 51200 bytes.
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 200 cbs 51200
Congestion management commands
A 100-GE interface before splitting has eight queues numbered 0 through 7. Each breakout interface has two queues and does not support congestion management. For more information about interface splitting, see Ethernet interface configuration in see Layer 2—LAN Switching Configuration Guide.
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
 Output queue: Strict Priority queuing
Interface: Ten-GigabitEthernet1/0/2
Table 18 Command output
Output queue
Type of the current output queue.
Group
Number of the group that holds the queue.
Weight
Packet-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
Byte-count
Byte-count scheduling weight of the queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
# Display the SP queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
Table 19 Command output
Output queue
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
# Enable SP queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
WRR commands
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
# Display the WRR queuing configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
Table 20 Command output
Output queue
Group
Number of the group a queue is assigned to.
Weight
Packet-based queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr { byte-count | weight }
undo qos wrr { byte-count | weight }
byte-count: Allocates bandwidth to queues in bytes.
weight: Allocates bandwidth to queues in packets.
You must enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable weight-based WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure the WRR queuing parameters for a queue on an interface.
Use undo qos wrr to restore the default for a queue.
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface belong to WRR group 1, and the scheduling weight of a queue is its queue ID plus 1.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
group 1: Specifies WRR group 1.
schedule-value: Specifies a scheduling weight in the range of 1 to 127.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
The queue-id argument can be either a number or a keyword. Table 21 shows the number-keyword map.
Table 21 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
# Enable byte-count WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0, with the scheduling weight 100, to WRR group 1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 100
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
# Display the WFQ configuration of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos wfq interface ten-gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
Table 22 Command output
Output queue
Group
Byte-count
Min Bandwidth
Minimum guaranteed bandwidth for the queue.
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a WFQ queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth for a WFQ queue is 64 kbps.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in the range of 8 to 100000000 kbps.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable weight-based WFQ on Ten-GigabitEthernet 1/0/1.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to assign a queue to a WFQ group with a certain scheduling weight.
Use undo qos wfq to restore the default for a queue.
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface belong to WFQ group 1 and have a scheduling weight of 1.
group 1: Specifies WFQ group 1.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on Ten-GigabitEthernet 1/0/1, and assign queue 0, with the scheduling weight 100, to WFQ group 1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 100
qos bandwidth queue
qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to remove a queue from the SP group.
qos wfq queue-id group sp
This command is available only on a WFQ-enabled interface. Queues in the SP group are scheduled with SP, instead of WFQ. The SP group has higher scheduling priority than the WFQ groups.
# Enable WFQ on Ten-GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
A queue does not have a minimum guaranteed bandwidth.
Queue scheduling profile view
# Set the minimum guaranteed bandwidth to 128 kbps for queue 1.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] bandwidth queue 1 min 128
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue scheduling profile: myprofile (ID 1)
 Queue ID  Type  Group   Schedule   Schedule  Min         Max
                         unit       value     bandwidth   bandwidth
 be        SP    N/A     N/A        N/A       N/A         N/A
 af1       SP    N/A     N/A        N/A       N/A         N/A
 af2       SP    N/A     N/A        N/A       N/A         N/A
 af3       SP    N/A     N/A        N/A       N/A         N/A
 af4       SP    N/A     N/A        N/A       N/A         N/A
 ef        SP    N/A     N/A        N/A       N/A         N/A
 cs6       SP    N/A     N/A        N/A       N/A         N/A
 cs7       SP    N/A     N/A        N/A       N/A         N/A
Table 23 Command output
Queue management profile
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
·     WFQ.
Group
Priority group to which the queue belongs.
N/A indicates this field is ignored.
Schedule unit
Scheduling unit: weight or byte-count.
N/A indicates that this field is ignored.
Schedule value
This field indicates:
·     Weight value for the weight scheduling unit.
·     Number of bytes for the byte-count scheduling unit.
Min bandwidth
Minimum guaranteed bandwidth.
Max bandwidth
Maximum allowed bandwidth.
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
display qos qmprofile interface [ interface-type interface-number ] [ slot slot-number ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to Ten-GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Direction: Outbound
 Queue management profile: myprofile
Table 24 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
This command applies a queue scheduling profile to the outbound direction of an interface. Only one queue scheduling profile can be applied to an interface.
# Apply queue scheduling profile myprofile to the outbound direction of Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an interface, first remove it from the interface.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a group by its ID, which is fixed at 1.
schedule-value: Specifies the scheduling weight in the range of 1 to 127.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·     The WRR queuing is used.
·     The WRR group is group 1.
·     The scheduling weight is 100.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 100
qos qmprofile
Congestion avoidance commands
A 100-GE interface before splitting has eight queues numbered 0 through 7. Each breakout interface has two queues and does not support congestion avoidance. For more information about interface splitting, see Ethernet interface configuration in see Layer 2—LAN Switching Configuration Guide.
WRED table commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
This command is supported only in Release 3608 and later.
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface ten-gigabitethernet 1/0/1
 Current WRED configuration:
 Applied WRED table name: q1
Table 25 Command output
display qos wred table
Use display qos wred table to display the WRED table configuration.
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID gmin     gmax     gpro ymin     ymax     ypro rmin     rmax     rpro exp ECN
0   250      1000     10   250      1000     10   250      1000     10   9   N
1   250      1000     10   250      1000     10   250      1000     10   9   N
2   250      1000     10   250      1000     10   250      1000     10   9   N
3   250      1000     10   250      1000     10   250      1000     10   9   N
4   250      1000     10   250      1000     10   250      1000     10   9   N
5   250      1000     10   250      1000     10   250      1000     10   9   N
6   250      1000     10   250      1000     10   250      1000     10   9   N
7   250      1000     10   250      1000     10   250      1000     10   9   N
Table 26 Command output
Table name
Name of a WRED table.
Table type
Type of a WRED table.
QID
Queue ID.
gmin
Lower limit for green packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
gmax
Upper limit for green packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
gpro
Drop probability for green packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
ymin
Lower limit for yellow packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
ymax
Upper limit for yellow packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
ypro
Drop probability for yellow packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
rmin
Lower limit for red packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
rmax
Upper limit for red packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
rpro
Drop probability for red packets. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
exp
Exponent for average queue length calculation. A hyphen (-) indicates that this parameter is not configured and the default value of the interface is used when the table is applied to that interface.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
qos wred table
qos wred queue table
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
You can use the display qos wred table command to display the default WRED table, which cannot be modified or deleted.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
The lower limit is 250, the higher limit is 1000, and the drop probability denominator is 10.
WRED table view
all: Specifies all queues.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low-limit low-limit: Specifies the lower limit for the average queue length in the range of 0 to 16383 KB.
high-limit high-limit: Specifies the upper limit for the average queue length in the range of 0 to 16383 KB. The upper limit must be greater than the lower limit.
discard-probability discard-prob: Specifies the drop probability in the range of 0 to 100.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
To use the tail drop mechanism for a queue, set the same value for the lower limit and upper limit and set the drop probability to 100%.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
qos wred table
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is disabled for a queue.
WRED table view
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
qos wred table
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation, in the range of 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
qos wred table
Aggregate CAR commands
car name
Use car name to use an aggregate CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No aggregate CAR action is configured in a traffic behavior.
Traffic behavior view
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
An aggregate CAR action takes effect only when a QoS policy is applied to the inbound direction of an interface, VLANs, or globally.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name, which can be an aggregate CAR action or a hierarchical CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command displays information about all aggregate CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
   Yellow action : pass
   Red action    : discard
  Slot 0:
  Slot 1:
  Slot 2:
   Apply failed
Table 27 Command output
Name
Name of the aggregate CAR action.
Mode
Type of the CAR action, which can only be aggregative.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
Green action
Action to take on green packets:
·     discard—Drops the packets.
·     pass—Permits the packets to pass through.
Yellow action
Action to take on yellow packets:
Red action
Action to take on red packets:
Green packet
Traffic statistics for green packets and average rate of green packets in the most recent five minutes.
Yellow packet
Traffic statistics for yellow packets and average rate of yellow packets in the most recent five minutes.
Red packet
Traffic statistics for red packets and average rate of red packets in the most recent five minutes.
qos car
Use qos car to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action exists.
car-name: Specifies the name of the aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
aggregative: Specifies the aggregate CAR action.
cir committed-information-rate: Specifies the CIR in the range of 8 to 500000000 kbps, in increments of 8.
cbs committed-burst-size: Specifies the CBS in bytes in the range of 512 to 256000000 kbps, in increments of 512.
ebs excess-burst-size: Specifies the EBS in bytes in the range of 0 to 256000000 kbps, in increments of 512.
pir peak-information-rate: Specifies the PIR in the range of 8 to 500000000 kbps, in increments of 8. The PIR must be greater than or equal to the CIR.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
An aggregate CAR action takes effect only after it is used in a QoS policy.
To use two rates for global CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for global CAR, configure the qos car command without the pir peak-information-rate option.
# Configure aggregate CAR action aggcar-1, where CIR is 200, CBS is 2048, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2048 red discard
reset qos car name
Use reset qos car name to clear the statistics about aggregate CAR actions.
car-name: Specifies an aggregate CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify an aggregate CAR action, this command clears statistics for all aggregate CAR actions.
# Clear the statistics about aggregate CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Queue-based accounting commands
Some interfaces on the S6890-54HF switch can be split into four breakout interfaces. An interface before splitting has eight queues numbered 0 through 7. Each breakout interface has two queues numbered 6 and 7. For more information about interface splitting, see Ethernet interface configuration in see Layer 2—LAN Switching Configuration Guide.
Interface queue-based traffic statistics commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
This command displays statistics on only uncast traffic (not broadcast traffic).
# Display queue-based outgoing traffic statistics of Ten-GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
Direction: Outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 0 packets, 0 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Forwarded(peak): 0 pps, 0 bps
  Total queue length: 761856 packets
  Current queue length: 0 packets, 0 bytes, 0% use ratio
  Queue peak size: 0 bytes
 Queue 7
Table 28 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Counts forwarded traffic in packets, bytes, pps, and bps.
Forwarded(peak)
Peak forwarding rate during the time from when the reset qos queue-statistics interface outbound command was last executed to when the display qos queue-statistics interface outbound command was executed.
Dropped
Counts dropped traffic in packets, bytes, pps, and bps.
Total queue length
Total number of packets allowed in the queue.
Current number of packets in the queue.
use ratio
Utilization ratio of the queue.
Queue peak size
Peak queue length of the queue, in bytes.
reset counters interface Layer 2—LAN Switching Command Reference
display statistic mode
Use display statistic mode to display the packet counting mode.
# Display the packet counting mode.
<Sysname> display statistic mode
The packet statistic mode is queue.
statistic mode queue
statistic mode (VXLAN Command Reference)
Use reset qos queue-statistics interface outbound to clear outgoing queue-based traffic statistics for an interface.
reset qos queue-statistics interface [ interface-type interface-number ] outbound
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears the outgoing queue-based traffic statistics for all interfaces.
# Clear the outgoing queue-based traffic statistics for all interfaces.
<Sysname> reset qos queue-statistics interface outbound
# Clear the outgoing queue-based traffic statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> reset qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
Use statistic mode queue to set the packet counting mode to queue.
Use undo statistic mode queue to restore the default.
undo statistic mode
The packet counting mode is vsi.
After you configure this command and the qos queue-statistics command, the device collects statistics on packets of each queue. You can use the display qos queue-statistics interface outbound command to display the statistics.
# Set the packet counting mode to queue.
[Sysname] statistic mode queue
Do you want to change the packet statistic mode? [Y/N]:y
QPPB commands
bgp-policy
Use bgp-policy to enable QPPB, which transmits the apply ip-precedence and apply qos-local-id configuration through BGP routing policies.
Use undo bgp-policy to restore the default.
bgp-policy { destination | source } { ip-prec-map | ip-qos-map } *
undo bgp-policy { destination | source } [ ip-prec-map | ip-qos-map ] *
QPPB is disabled.
Tunnel interface view
destination: Searches the routing table by destination IP address.
source: Searches the routing table by source IP address. If the source keyword is specified, the source IP address is used as the destination address for inverse lookup.
ip-prec-map: Sets an IP precedence value for matching packets.
ip-qos-map: Sets a local QoS ID for matching packets.
The bgp-policy command applies only to the incoming traffic of an interface.
In an MPLS L3VPN, the bgp-policy command is executed after the QoS features are performed in the inbound direction of the PE's public network interface. In any other case, the bgp-policy command is executed before the QoS features.
If you configure either of the following bgp-policy command pairs, both commands in the pair take effect:
·     bgp-policy destination ip-prec-map and bgp-policy source ip-qos-map.
·     bgp-policy source ip-prec-map and bgp-policy destination ip-qos-map.
If you configure either of the following bgp-policy command pairs, the command with the destination keyword in the pair takes effect:
·     bgp-policy destination ip-prec-map and bgp-policy source ip-prec-map.
·     bgp-policy destination ip-qos-map and bgp-policy source ip-qos-map.
# Configure Ten-GigabitEthernet 1/0/1 to get the IP precedence and local QoS ID by looking up routes based on source IP address.
[Sysname-Ten-GigabitEthernet1/0/1] bgp-policy source ip-prec-map ip-qos-map
apply ip-precedence (Layer 3—IP Routing Command Reference)
apply qos-local-id (Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
