05-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-8M[S6880] Command References-R1116Pxx-6W10005-Layer 3—IP Services Command Reference
13-IPv6 fast forwarding commands
13-IPv6 fast forwarding commands 49.17 KB
display ipv6 fast-forwarding aging-time
Use display ipv6 fast-forwarding aging-time to display the aging time of IPv6 fast forwarding entries.
# Display the aging time of IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding aging-time
Aging time: 30s
Aging time
Aging time of IPv6 fast forwarding entries, in seconds.
display ipv6 fast-forwarding cache
Use display ipv6 fast-forwarding cache to display IPv6 fast forwarding entries.
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
# Display all IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding cache
Total number of IPv6 fast-forwarding items: 2
Src IP: 123::2                                         Src Port: 1036
Dst IP: 123::1                                         Dst Port: 32768
Protocol: 58
VPN instance: N/A
Input interface: Vlan2
Output interface: InLoop0
Src IP: 123::1                                         Src Port: 1036
Dst IP: 123::2                                         Dst Port: 33024
Protocol: 58
VPN instance: N/A
Input interface: InLoop0
Output interface: Vlan2
Number of IPv6 fast forwarding entries.
Src IP
Source IPv6 address.
Src port
Source port number.
Dst IP
Destination IPv6 address.
Dst Port
Destination port number.
Protocol
Protocol number.
VPN instance
VPN instance. If the entry does not belong to any VPN instance, this field displays N/A.
Input interface
Input interface type and number.
If no interface is involved in fast forwarding, this field displays N/A.
If the input interface does not exist, this field displays a hyphen (-).
Output interface
Output interface type and number.
If the output interface does not exist, this field displays a hyphen (-).
reset ipv6 fast-forwarding cache
Use ipv6 fast-forwarding aging-time to set the aging time for IPv6 fast forwarding entries.
Use undo ipv6 fast-forwarding aging-time to restore the default.
ipv6 fast-forwarding aging-time aging-time
The aging time is 30 seconds.
aging-time: Sets the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for IPv6 fast forwarding entries.
[Sysname] ipv6 fast-forwarding aging-time 20
ipv6 fast-forwarding load-sharing
Use ipv6 fast-forwarding load-sharing to enable IPv6 fast forwarding load sharing.
Use undo ipv6 fast-forwarding load-sharing to disable IPv6 fast forwarding load sharing.
IPv6 fast forwarding load sharing is enabled.
IPv6 fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If IPv6 fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable IPv6 fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ipv6 fast-forwarding load-sharing
Use reset ipv6 fast-forwarding cache to clear IPv6 fast forwarding entries.
reset ipv6 fast-forwarding cache [ slot slot-number ]
# Clear IPv6 fast forwarding entries.
<Sysname> reset ipv6 fast-forwarding cache
