04-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-8M[S6880] Command References-R1116Pxx-6W10004-Layer 2—LAN Switching Command Reference
06-Loop detection commands
06-Loop detection commands 66.58 KB
display loopback-detection
Use display loopback-detection to display the loop detection configuration and status.
Example
# Display the loop detection configuration and status.
<Sysname> display loopback-detection
Loop detection is enabled.
Loop detection interval is 30 second(s).
Loop is detected on following interfaces:
 Interface                      Action mode     VLANs
 Twenty-FiveGigE1/0/3           None            10
Action mode
Loop protection action:
·     Block—When a loop is detected on a port, the device performs the following operations:
¡     Generates a log.
¡     Disables the port from learning MAC addresses.
¡     Blocks the port.
·     None—When a loop is detected on a port, the device generates a log but performs no action on the port.
·     No-learning—When a loop is detected on a port, the device generates a log and disables the port from learning MAC addresses.
·     Shutdown—When a loop is detected on a port, the device performs the following operations:
¡     Generates a log.
¡     Shuts down the port to disable the port from receiving or sending frames. The device automatically sets the port to the forwarding state after a time interval. Set the time interval by using the shutdown-interval command (see System Management Command Reference).
VLANs
VLANs to which the interface belongs and where loops are detected.
loopback-detection action
Use loopback-detection action to set the loop protection action on a per-port basis.
Use undo loopback-detection action to restore the default.
In Layer 2 Ethernet interface view:
loopback-detection action { block | no-learning | shutdown }
In Layer 2 aggregate interface view:
loopback-detection action shutdown
When the device detects a loop on a port, it generates a log but performs no action on the port.
block: Enables the block mode. If a loop is detected, the device performs the following operations:
·     Generates a log.
·     Disables MAC address learning.
·     Blocks the port.
Layer 2 aggregate interfaces do not support this keyword.
no-learning: Enables the no-learning mode. If a loop is detected, the device generates a log and disables MAC address learning on the port. Layer 2 aggregate interfaces do not support this keyword.
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the port. The device automatically sets the port to the forwarding state after the time interval set by using the shutdown-interval command (see System Management Command Reference).
To set the loop protection action globally, use the loopback-detection global action command.
The global action applies to all ports. The per-port action applies to the individual ports. The per-port action takes precedence over the global action.
Example
# Set the loop protection action to shutdown on Twenty-FiveGigE 1/0/1.
[Sysname] interface twenty-fivegige 1/0/1
[System-Twenty-FiveGigE1/0/1] loopback-detection action shutdown
loopback-detection enable
Use loopback-detection enable to enable loop detection on a per-port basis.
Use undo loopback-detection enable to disable loop detection on a port.
loopback-detection enable vlan { vlan-id-list | all }
undo loopback-detection enable vlan { vlan-id-list | all }
Loop detection is disabled on ports.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be no less than the ID for vlan-id1.
all: Specifies all existing VLANs.
You can enable loop detection globally or on a per-port basis. When a port receives a detection frame in any VLAN, the loop protection action is triggered on that port, regardless of whether loop detection is enabled on it.
Example
# Enable loop detection on Twenty-FiveGigE 1/0/1 for VLAN 10 through VLAN 20.
[System-Twenty-FiveGigE1/0/1] loopback-detection enable vlan 10 to 20
loopback-detection global enable
Use loopback-detection global action to set the global loop protection action.
Use undo loopback-detection global action to restore the default.
loopback-detection global action shutdown
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the port. The device automatically sets the port to the forwarding state after you set the time interval by using the shutdown-interval command (see System Management Command Reference).
To set the loop protection action on a per-port basis, use the loopback-detection action command in interface view.
Example
# Set the global loop protection action to shutdown.
[System] loopback-detection global action shutdown
Use loopback-detection global enable to enable loop detection globally.
Use undo loopback-detection global enable to disable loop detection globally.
loopback-detection global enable vlan { vlan-id-list | all }
undo loopback-detection global enable vlan { vlan-id-list | all }
Loop detection is globally disabled.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
Example
# Globally enable loop detection for VLAN 10 through VLAN 20.
[System] loopback-detection global enable vlan 10 to 20
loopback-detection interval-time
Use loopback-detection interval-time to set the loop detection interval.
Use undo loopback-detection interval-time to restore the default.
loopback-detection interval-time interval
The loop detection interval is 30 seconds.
interval: Sets the loop detection interval in the range of 1 to 300 seconds.
With loop detection enabled, the device sends loop detection frames at the specified interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
Example
# Set the loop detection interval to 10 seconds.
[Sysname] loopback-detection interval-time 10
