02-System Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-8M[S6880] Command References-R1116Pxx-6W10002-System Management Command Reference
03-Hardware resource management commands
03-Hardware resource management commands 230.82 KB
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
display cpu-usage [ control-plane ] [ summary ]
control-plane: Displays CPU usage statistics for the control plane.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Unit CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the current CPU usage statistics in table form.
CPU        Last 5 sec        Last 1 min        Last 5 min
0          2%                2%                10%
x% in last 5 seconds
Last 5 sec
Average CPU usage during the most recent 5-second interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
y% in last 1 minute
Last 1 min
Average CPU usage during the most recent 1-minute interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
z% in last 5 minutes
Last 5 min
Average CPU usage during the most recent 5-minute interval. If this statistics collection feature is not supported, two hyphens (--) are displayed.
display cpu-usage configuration
Use display cpu-usage configuration to display CPU usage monitoring settings.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
CPU usage tracking is enabled.
Sampling interval for CPU usage tracking is 60 seconds.
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
display cpu-usage history
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
display cpu-usage history [ job job-id ]
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Command Reference.
After CPU usage tracking is enabled, the system regularly samples CPU usage and saves the samples to a buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device hardware information.
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Displays flash memory information.
usb: Displays USB interface information.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify a subcard, this command does not display information about any subcards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information, and does not display firewall card information.
If you do not specify the flash or usb keyword, this command displays hardware information about the device.
# Display device hardware information.
<Sysname> display device
Slot Type                State    Subslot  Soft Ver             Patch Ver
1    S6880               Master   0        S6880-6103           None
Device type.
Device role. The value is Master.
Soft Ver
Software version of the device.
Patch Ver
Most recently released patch image version that is running on the device. If no patch image is installed, this field displays None.
If both incremental and non-incremental patch images are running on the device, this field displays the most recently released incremental patch image version. For more information about patch image types, see software upgrade configuration in Fundamentals Configuration Guide.
display device manuinfo
Use display device manuinfo to display hardware electronic label information for the device.
display device manuinfo [ slot slot-number ] [ subslot subslot-number ] ]
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display hardware electronic label information for the device.
<Sysname> display device manuinfo
display device manuinfo fan
Use display device manuinfo fan to display electronic label information for a fan tray.
display device manuinfo slot slot-number fan fan-id
fan-id: Specifies a fan tray by its ID.
# Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
display device manuinfo power
Use display device manuinfo power to display electronic label information for a power module.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power module by its ID.
# Display electronic label information for a power module.
<Sysname> display device manuinfo slot 1 power 1
display environment
Use display environment to display temperature information.
# Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 30           0      65       70     NA
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
hotspot—Hotspot sensor.
Slot
Sensor position.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically. If the device does not support this field, this field displays NA.
display fan
Use display fan to display fan tray operating status information.
display fan [ slot slot-number [ fan-id ] ]
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan 1:
 State    : Normal
 Airflow Direction: Fan-Panel-Exhaust
 Fan 2:
 State    : Normal
 Fan 3:
 State    : Normal
 Fan 4:
 State    : Normal
Table 5 Command output
Fan 1
Fan tray number.
Fan tray status:
·     Absent—The slot is not installed with a fan tray.
·     Fault—The fan tray is faulty.
·     Normal—The fan tray is operating correctly.
Airflow Direction
Actual airflow direction:
·     Port-to-power—From the port side to the power supply side.
·     Power-to-port—From the power supply side to the port side.
·     Fan-Panel-Exhaust—Fan panel side exhaust airflow.
·     Fan-Panel-Intake—Fan panel side intake airflow.
display hardware-mode status
Use display hardware-mode status to display the hardware resource mode for MAC address entries, ARP/ND entries, and routing entries.
# Specify the hardware resource mode for MAC address entries, ARP/ND entries, and routing entries.
<H3C> display hardware-mode status
                         mode   | Route-v4 | Route-v6 | MAC  | ARP | ND
         mode in use: 0  NORMAL   216K       108K       128K   88K   66K
mode for next reboot: 1  ROUTE    504K       252K       32K    40K   34K
Table 6 Command output
mode in use
Current hardware resource mode for MAC address entries, ARP/ND entries, and routing entries.
Hardware resource mode for MAC address entries, ARP/ND entries, and routing entries after the device reboots.
mode
Route-v4
Number of IPv4 routing entries
Route-v6
Number of IPv6 routing entries
MAC
Number of MAC address entries
ARP
Number of ARP entries
ND
Number of ND entries
hardware-mode
display memory
Use display memory to display memory usage information.
display memory [ summary ]
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       8081628   3222792   4858836         0      5360   2002404       60.4%
-/+ Buffers/Cache:   1215028   6866600
Swap:            0         0         0
Container memory statistics are measured in KB:
Slot 1:
             Total      Used      Free  UsageRatio
Mem:       8081628   1173472   4858836       14.5%
# Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   0   0     16335164   4144720  12190444     8596   2472508     77.5%
Slot CPU        Total      Used      Free  UsageRatio
   0   0     16335164   2358048  12190444       14.4%
Table 7 Command output
Memory usage information on the physical device, in KB.
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code and kernel management functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
display memory-threshold
Use display memory-threshold to display memory alarm thresholds and statistics.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 256M
    Severe: 192M
    Critical: 128M
    Normal: 320M
    Early-warning: 0M
    Secure: 0M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
display power
Use display power to display power module information.
display power [ slot slot-number [ power-id ] ]
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
# Display brief power supply information.
<Sysname> display power
PowerID State    Mode   Current(A)  Voltage(V)  Power(W)
 1       Normal   AC        --          --          --
 2       Absent   --        --          --          --
Table 8 Command output
PowerID
Power supply ID.
Power supply status.
·     Absent—The slot is not installed with a power supply.
·     Fault—The power supply is faulty.
·     Normal—The power supply is operating correctly.
Mode
Mode of the power supply:
·     AC—AC power supply.
·     DC—DC power supply.
Current(A)
Output current of the power supply, in amperes.
Voltage(V)
Output voltage of the power supply, in volts.
Power(W)
Output power of the power supply, in watts.
display resource-monitor
Use display resource-monitor to display resource monitoring information.
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name. For the resource types, seeTable 19.
cpu cpu-number: Specifies a CPU by its number.
# Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
Table 9 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(absolute)
Numbers of available resources and total resources, in absolute values.
resource-monitor minor resend enable
display transceiver active-control
Use display transceiver active-control to display the active control information of 400-GE transceiver modules.
This command is supported only on the S9820-8M switch.
display transceiver active-control interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command applies to all interfaces.
# Display the active control information of the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
<Sysname> display transceiver active-control interface fourhundredgigE 1/1/1
|FourHundredGigE 1/1/1 transceiver active-control setting information:
Current working mode     :400G-SR8
  Lane    LowestHostLane   RxPre-Cursor     RxPost-Cursor    RxAmplitude
  Lane1   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane2   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane3   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane4   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane5   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane6   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane7   Lane1            1.5 dB           1 dB             600-1200 mV
  Lane8   Lane1            1.5 dB           1 dB             600-1200 mV
Table 10 Command output
Current operating mode of the transceiver module.
Lane
Current lane.
LowestHostLane
Host lane with the smallest number in the lane group currently used by the transceiver module.
RxPre-Cursor
Pre-cursor when the transceiver module acts as the receiver.
RxPost-Cursor
Post-cursor when the transceiver module acts as the receiver.
RxAmplitude
Amplitude when the transceiver module acts as the receiver.
display transceiver advertising
Use display transceiver advertising to display the advertising information of 400-GE transceiver modules.
display transceiver advertising interface [ interface-type interface-number ]
# Display the advertising information of the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
<Sysname> display transceiver advertising interface fourhundredgigE 1/1/1
|FourHundredGigE 1/1/1 transceiver advertising information:
  CMIS Revision                      : 4.1
  Versatile Diagnostic Monitoring    : YES
  Tx clock recovery capabilities     : module requires all Tx input lanes to be
in a single Tx synchronous group
  Max Tx Input Eq(dB)                : No Equalization
  Max Rx Output Eq Pre-cursor(dB)    : Custom
  Max Rx Output Eq Post-cursor(dB)   : Custom
  Tx disable implemented             : YES
  Tx Force Squelch implemented       : YES
  Tx Squelch implemented             : Pave
  Tunable transmitter                : YES
  Tx bypass CDR implemented          : NO
  Rx bypass CDR implemented          : NO
  Tx Input Eq Adaptive               : YES
  CDB implemented                    : One instance of CDB implemented
Table 11 Command output
CMIS revision
QSFP-DD CMIS version. The value is 3.0 or 4.0.
Versatile diagnostic monitoring
Support for versatile diagnostic monitoring:
·     YES.
·     NO.
Clock recovery capabilities when the transceiver module acts as the transmitter:
·     All Tx input lanes to be in a single Tx synchronous group.
·     Tx input lanes 1-4 and 5-8 to be in separate Tx synchronous groups.
·     Tx input lanes 1-2, 3-4, 5-6, 7-8 to be in separate Tx synchronous groups.
·     Each Tx input lane to be in a separate Tx synchronous group.
Max Tx input Eq (dB)
Maximum Tx Input Equalization control value.
Max Rx output Eq pre-cursor (dB)
Maximum Rx Output Eq Pre-cursor control value.
Max Rx output Eq post-cursor (dB)
Maximum Rx Output Eq Post-cursor control value.
Support for Tx disable:
·     YES.
·     NO.
Support for Tx Force Squelch:
·     YES.
·     NO.
Support for Tx Squelch:
·     NO.
·     OMA—Implements Tx Squelch based on OMA.
·     Pave—Implements Tx Squelch based on Pave.
·     Both—Implements Tx Squelch based on OMA or Pave as needed.
Tunable transmitter
Indicates whether the transmitter is tunable:
·     YES.
·     NO.
Support for bypass CDR when the transceiver module acts as the transmitter:
·     YES.
·     NO.
Support for bypass CDR when the transceiver module acts as the receiver:
·     YES.
·     NO.
Tx input Eq adaptive
Support for the input equalization adaptive control when the transceiver module acts as the transmitter:
·     YES.
·     NO.
CDB implemented
Support for CDB:
·     NO.
·     One instance of CDB—Supports one CDB instance.
·     Two instances of CDB—Supports two CDB instances.
·     Unknown.
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 12 shows the common transceiver alarm components. If no error occurs, "None" is displayed.
Table 12 Common transceiver alarm components
APD
Avalanche photo diode
PCS
Physical coding sublayer
PHY XS
PHY extended sublayer
PMA/PMD
Physical medium attachment/physical medium dependent
power
Optical power
REFCLK
Reference clock
RX
Receive
TEC
Thermoelectric cooler
Temp
Temperature
TX
Transmit
WIS
WAN interface sublayer
# Display the alarms present on the transceiver module in interface Twenty-FiveGigE 1/0/1.
<Sysname> display transceiver alarm interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
Table 13 Command output
Alarms present on the transceiver module.
RX loss of signal
Received signals are lost.
RX power low
Received power is low.
display transceiver application
Use display transceiver application to display application related information for 400-GE transceiver modules.
display transceiver application interface [ interface-type interface-number ]
# Display application related information for the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
<Sysname> display transceiver application interface fourhundredgigE 1/1/1
|FourHundredGigE 1/1/1 transceiver application information:
ApSel code: 0001b
     Host Electrical Interface code     Module Media Interface Code
     400GAUI-8 C2M                      400G-SR8
     Host Lane Count                    Media Lane Count
     8                                  8
     The Lowest host Lane               The Lowest media lane
     1                                  1
ApSel Code: 0010b
     IB EDR                             Undefined
     8                                  8
     1                                  1
Table 14 Command output
ApSel Code
Current application of the transceiver module represented by the
ApSel code.
Host lane with the smallest number for the application in each lane group. The supported number of lanes varies by application of the transceiver module. These lanes are divides into groups.
Media lane with the smallest number for the application.
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Twenty-FiveGigE 1/0/1.
<Sysname> display transceiver diagnosis interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1 transceiver diagnostic information:
[module]  Temp.(C)   Voltage(V)   Total RX power(dBm)   Total TX power(dBm)
          43         3.30         4.60                  6.12
[channel] Bias(mA)  RX power(dBm)  TX power(dBm)
    1     7.39      -36.96         1.13
    2     7.39      -36.96         0.99
    3     7.39      -36.96         1.08
    4     7.39      -36.96         1.11
  Alarm thresholds:
          Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    High  85         3.64        15.00     3.40           5.40
    Low   -15        2.97        3.00      -14.00         -12.10
Table 15 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
TEC Curr (%)
TEC current in percentage, accurate to 0.01%.
Laser Temp(C)
Laser temperature in °C, accurate to 0.01°C.
Total RX power(dBm)
Total receive power of all channels in dBm, accurate to 0.01 dBm.
Total TX power(dBm)
Total transmit power of all channels in dBm, accurate to 0.01 dBm.
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Twenty-FiveGigE 1/0/1.
<Sysname> display transceiver interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1 transceiver information:
  Transceiver type                 : 100G_BASE_SR4_QSFP28
  Connector type                   : MPO
  Wavelength (nm)                  : 850
  Transfer distance (m)            : 70(OM3),100(OM4)
  Digital diagnostic monitoring    : Yes
  Vendor name                      : H3C
  Ordering Name                    : QSFP-100G-SR4-MM850
  Part Number                      : AFBR-89CDDZ-H3C
  Serial Number                    : AF1709GH03A
Table 16 Command output
Transceiver Type
Model of the transceiver module.
Connector Type
Connector type of the transceiver module:
·     Optical connectors, including SC connector developed by NTT, and 1.25mm/RJ45 LC connector developed by Lucent.
·     Other connectors, including RJ-45 and CX4.
Wavelength(nm)
For the transceiver module, this field displays central wavelength of the laser sent, in nm. If the transceiver module such as 10GBASE-LX4, supports multiple wavelengths, each wavelength value is separated by a comma.
For the electrical transceiver, this field displays N/A.
Transfer Distance(xx)
Transfer distance. For a single-mode transceiver module, the distance is measured in km. For other transceiver modules, the distance is measured in m. If the transceiver module supports multiple transfer media, the transfer distances are separated by commas. The corresponding transfer medium is enclosed in the brackets following the transfer distance value. The following are the transfer media:
·     9um—9/125 um single-mode optical fiber.
·     50um—50/125 um multi-mode optical fiber.
·     62.5um—62.5/125 um multi-mode optical fiber.
·     TP—Twisted pair.
·     CX4—CX4 cable.
Digital Diagnostic Monitoring
Support for digital diagnostic monitoring:
·     Yes.
·     No.
Ordering Name
Ordering name of the transceiver module.
Part Number
Serial Number
Serial number of the transceiver module.
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
# Display electronic label information for the transceiver module in interface Twenty-FiveGigE 1/0/1.
<Sysname> display transceiver manuinfo interface twenty-fivegige 1/0/1
Twenty-FiveGigE1/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2019-09-01
  Vendor Name          : H3C
Table 17 Command output
Manu. Serial Number
Serial number generated during debugging and testing.
Manufacturing Date
Debugging and testing date. The date takes the value of the system clock of the computer when debugging and testing is performed.
display transceiver status
Use display transceiver status to display 400-GE transceiver module status information.
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
# Display status information for the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
<Sysname> display transceiver status interface fourhundredgigE 1/1/1
|FourHundredGigE 1/1/1 transceiver status information:
  Module state        : ModuleReady
  Interrupt           : YES
  Lane      Data Path State     Media Lane State
  Lane1     Activated           Enable
  Lane2     Activated           Enable
  Lane3     Activated           Enable
  Lane4     Activated           Enable
  Lane5     Activated           Enable
  Lane6     Activated           Enable
  Lane7     Activated           Enable
  Lane8     Activated           Enable
  Loopback Mode       :
  Lane      Media Output   Media Input    Host Output    Host Input
  Lane1     Disable        Disable        Disable        Disable
  Lane2     Disable        Disable        Disable        Disable
  Lane3     Disable        Disable        Disable        Disable
  Lane4     Disable        Disable        Disable        Disable
  Lane5     Disable        Disable        Disable        Disable
  Lane6     Disable        Disable        Disable        Disable
  Lane7     Disable        Disable        Disable        Disable
  Lane8     Disable        Disable        Disable        Disable
Table 18 Command output
Module status
Transceiver module status:
·     ModuleLowPwr—The transceiver module operates in low power.
·     ModulePwrUp—The transceiver module is powered on.
·     ModuleReady—The transceiver module is ready.
·     ModulePwrDn—The transceiver module is powered off.
·     Fault state—The transceiver module is faulty.
·     Unknown.
Interrupt alarm
Indicates whether the transceiver module is in interrupt alarm status:
·     Yes.
·     No.
Data path state
Data path status:
·     Unknown.
·     Deactivated.
·     Initial—The transceiver module is performing initialization tasks on the data path.
·     Deinit—The data path is deinitialized.
·     Activated.
·     TxTurnOn—Tx output is enabled.
·     TxTurnOff—Tx output is disabled.
·     Initialized—The data path is fully initialized.
Media Lane State
Media lane status:
·     Enabled.
·     Disabled.
Host-fault-detect
Fault detection status on the transceiver host side:
·     Enabled.
·     Disabled.
Media-fault-detect
Fault detection status on the transceiver media side:
·     Enabled.
·     Disabled.
display transceiver vdm
Use display transceiver vdm to display the versatile diagnostics monitoring (VDM) information of a transceiver module.
display transceiver vdm interface interface-type interface-number vdm-id vdm-id
vdm-id vdm-id: Specifies a VDM by its ID. The value range varies by transceiver module model.
This command is available only for 400G transceiver modules that support CMIS 4.0.
# Display the VDM 1 information of the transceiver module in FourHundredGigE 1/1/1.
<Sysname> display transceiver vdm interface fourhundredgige 1/1/1 vdm-id 1
VDM Description: Laser Temperature
Module/lane         VDM value(C)
Lane1               58.0
Alarm/Warning thresholds:
          Warning(C)     Alarm(C)
  High    80.0           85.0
  Low     0.0            251.0
# Display the VDM 2 information of the transceiver module in FourHundredGigE 1/1/1.
<Sysname> display transceiver vdm interface fourhundredgige 1/1/1 vdm-id 2
VDM Description: eSNR Host Input
Module/lane         VDM value(dB)
Lane1               0.0
          Warning(dB)    Alarm(dB)
  High    99.0           99.0
  Low     226.0          216.0
hardware-mode
Use hardware-mode to specify the hardware resource mode for MAC address entries, APR/ND entries, and routing entries.
hardware-mode { 0 | 1 | 2 }
The normal hardware resource mode applies.
0: Specifies the normal hardware resource mode for MAC address entries, APR/ND entries, and routing entries.
1: Specifies the routing hardware resource mode for MAC address entries, APR/ND entries, and routing entries.
2: Specifies the MAC hardware resource mode for MAC address entries, APR/ND entries, and routing entries.
The quantities of MAC address entries, APR/ND entries, and routing entries supported by the device vary by hardware resource mode. For more information, see the device management configuration in Fundamentals Configuration Guide.
For the command to take effect, you must save the configuration and reboot the device. Before rebooting the device, evaluate the impact on the network and make preparations.
# Specify the routing hardware resource mode for MAC address entries, APR/ND entries, and routing entries.
[Sysname] hardware-mode 1
Reboot device to make the configuration take effect.
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the default.
memory-threshold [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value
Minor alarm threshold: 256 MB.
Severe alarm threshold: 192 MB.
Critical alarm threshold: 128 MB.
Normal state threshold: 320 MB.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
You can use the display memory command to display memory usage information.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
memory-threshold usage memory-threshold
The memory usage threshold is 100%.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
Use monitor cpu-usage enable to enable CPU usage tracking.
Use undo monitor cpu-usage enable to disable CPU usage tracking.
After you enable CPU usage tracking, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage tracking.
[Sysname] monitor cpu-usage enable
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
monitor cpu-usage interval interval
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
monitor cpu-usage threshold severe-threshold [ minor-threshold minor-threshold]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ]
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 80%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1. If you do not specify this option, the minor CPU usage alarm threshold is 80 percent of the severe CPU usage alarm threshold.
The device samples CPU usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage alarm threshold to 90%.
[Sysname] monitor cpu-usage threshold 90
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } *
undo monitor resend cpu-usage [ minor-interval | severe-interval ]
The minor CPU usage alarm resending interval is 300 seconds. The severe CPU usage alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe CPU usage alarm resending interval in seconds, a multiple of 5 in the range of 10 to 3600.
The device samples CPU usage at intervals, and compares the samples with CPU usage thresholds to identify the CPU usage status and send alarms or notifications accordingly.
In minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed. In severe alarm state, the device sends severe alarms periodically until the severe alarm is removed. This command sets the alarm resending intervals.
If you do not specify a keyword for the undo monitor resend cpu-usage command, the command restores the default minor and severe CPU usage alarm resending intervals.
# Set the minor CPU usage alarm resending interval to 60 seconds.
[Sysname] monitor resend cpu-usage minor-interval 60
reset transceiver interface
Use reset transceiver interface to reset 400-GE transceiver modules.
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command applies to all interfaces.
This command is disruptive. Use this command only when you cannot troubleshoot transceiver modules by using other methods.
This command will restart transceiver modules.
# Reset the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
<Sysname> reset transceiver interface fourhundredgige 1/1/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending period is fixed at 24 hours for a severe alarm and is fixed at 7 * 24 hours for a minor alarm.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
resource-monitor output
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in System Management Configuration Guide.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
resource-monitor resource resource-name cpu cpu-number by-percent minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name cpu cpu-number
The default varies by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. Table 19 shows the resource types that can be monitored.
Table 19 Resource types that can be monitored
Resource type
arp
ARP hardware resources.
ecmpgroup
ECMP group hardware resources.
ipv4host
IPv4 host route resources.
ipv4route
IPv4 route entry resources.
ipv6host
IPv6 host route resources.
ipv6route
IPv6 route entry resources.
nd
ND hardware resources.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The vlaue of 0 inidcates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number  hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
transceiver diagnostic selector
Use transceiver diagnostic selector to specify a diagnostic selector for a transceiver module and display specified diagnostic information.
transceiver diagnostic selector selector-id
No diagnostic selector is specified for a transceiver module.
400GE interface view
selector-id: Specifies a diagnostic selector. The value range varies by transceiver module model.
The command settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the command settings will be cleared. You must re-execute the command after a power recovery.
# Specify diagnostic selector 1 for the transceiver module in FourHundredGigE1/1/1 and display  specified diagnostic information.
[Sysname] interface fourhundredgige 1/1/1
[Sysname-FourHundredGigE1/1/1] transceiver diagnostic selector 1
Lane     Host side BER     Media side BER
1        1.00E-7           1.00E-7
2        1.00E-7           1.00E-7
3        1.00E-7           1.00E-7
4        1.00E-7           1.00E-7
5        1.00E-7           1.00E-7
6        1.00E-7           1.00E-7
7        1.00E-7           1.00E-7
8        1.00E-7           1.00E-7
# Specify diagnostic selector 2 for the transceiver module in FourHundredGigE 1/1/1 and display specified diagnostic information.
[Sysname-FourHundredGigE1/1/1] transceiver diagnostic selector 2
Lane     Host error count     Host total bits
1        1234567890           1234567890123456789
2        1234567890           1234567890123456789
3        1234567890           1234567890123456789
4        1234567890           1234567890123456789
# Specify diagnostic selector 6 for the transceiver module in FourHundredGigE 1/1/1 and display specified diagnostic information.
[Sysname-FourHundredGigE1/1/1] transceiver diagnostic selector 6
Lane     Host peak detect        Host SNR        Media peak detect        Media SNR
1        12345                   18.00dB         12345                    18.00dB
2        12345                   18.00dB         12345                    18.00dB
3        12345                   18.00dB         12345                    18.00dB
4        12345                   18.00dB         12345                    18.00dB
5        12345                   18.00dB         12345                    18.00dB
6        12345                   18.00dB         12345                    18.00dB
7        12345                   18.00dB         12345                    18.00dB
8        12345                   18.00dB         12345                    18.00dB
 transceiver lane enable
Use transceiver lane enable to enable lanes on a 400-GE transceiver module.
Use undo transceiver lane to disable lanes on a 400-GE transceiver module.
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
All lanes on a transceiver module are enabled.
400-GE Ethernet interface view and its breakout interface view
lane-number: Specifies a lane by its number in the range of 1 to 8. If you do not specify a lane, this command enables all lanes on the transceiver module.
Execute this command only for transceiver module debugging or testing.
Disabling a lane will stop signal transmission on the lane.
Disabling a lane will stop signal transmission on the fiber port where the lane is located.
The lane enablement setting is saved in a register on the transceiver module. It is not saved to the configuration file.
# Enable lane 1 on the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
[Sysname-FourHundredGigE1/1/1] transceiver lane 1 enable
 transceiver lane equalization
Use transceiver lane equalization to configure the pre-cursor and post-cursor equalizers, and amplitude for a 400-GE transceiver module.
Use undo transceiver lane equalization to restore the default.
transceiver lane [ lane-number ] equalization { precursor precursor-value | postcursor postcursor-value | amplitude amplitude-value }
undo transceiver lane [ lane-number ] equalization { precursor | postcursor | amplitude }
The default varies by transceiver module model.
lane-number: Specifies a lane by its number in the range of 1 to 8. If you do not specify a lane, this command configures the settings for all lanes on the transceiver module.
precursor precursor-value: Specifies the code value of the pre-cursor. The following shows all code values:
·     level0—No equalization.
·     level1—0.5 dB.
·     level2—1 dB.
·     level3—1.5 dB.
·     level4—2 dB.
·     level5—2.5 dB.
·     level6—3 dB.
·     level7—3.5 dB.
postcursor postcursor-value: Specifies the code value of the post-cursor. The following shows all code values:
·     level1—1 dB.
·     level2—2 dB.
·     level3—3 dB.
·     level4—4 dB.
·     level5—5 dB.
·     level6—6 dB.
·     level7—7 dB.
amplitude amplitude-value: Specifies the code value of the amplitude. The following shows all code values:
·     range0—100 to 400 mV.
·     range1—300 to 600 mV.
·     range2—400 to 800 mV.
·     Range3—600 to 1200 mV.
Execute this command for debugging and testing on high speed signals to achieve optimal link status. The default settings are generally applied. To change the default settings, contact professional engineers to avoid transceiver module exceptions.
As a best practice, do not execute this command when the interface is transmitting traffic. This command enables the device to automatically disable and then enable the transceiver module, which affects traffic transmission.
The configuration by this command is saved in a register on the transceiver module. It is not saved to the configuration file.
# Configure the pre-cursor and post-cursor equalizers, and amplitude for the 400-GE transceiver module in interface FourHundredGigE 1/1/1.
[Sysname-FourHundredGigE1/1/1] transceiver lane 1 equalization pre-cursor 1 post-cursor 8 amplitude 3
This operation will shut down and then bring up the transceiver module, affecting data transmission. Continue? [Y/N]:Y
 transceiver lane pattern
Use transceiver lane pattern to configure the signal mode and signal transmission Pseudo Random Binary Sequence (PRBS) pattern for a transceiver module lane.
Use undo transceiver lane pattern to restore the default.
transceiver lane [ lane-number ] pattern [ host-checker | host-generator media-checker | media-generator ] prbs-pattern
undo transceiver lane [ lane-number ] pattern
lane-number: Specifies a lane by its number. The value is in the range of 1 to 4 for a 200G transceiver module and in the range of 1 to 8 for a 400G transceiver module. If you do not specify a lane, this command applies to all lanes of the transceiver module.
host-checker: Specifies the host-side signal check mode.
host-generator: Specifies the host-side signal generation mode.
media-checker: Specifies the media-side signal check mode.
media-generator: Specifies the medial-side signal generation mode.
prbs-pattern: Specifies a signal transmission PRBS pattern. The value range varies by transceiver module model.
This command is available only for 200G and 400G transceiver modules that support CMIS 4.0.
This command settings will be saved in a register of the transceiver module. If the transceiver module has a power loss, the command settings will be cleared. You must re-execute the command after a power recovery.
# Specify the host-side signal generation mode and signal transmission pattern of PRBS-31Q for all lanes of the transceiver module in FourHundredGigE1/1/1.
[Sysname-FourHundredGigE1/1/1] transceiver lane pattern host-generator PRBS-31Q
This operation causes the service to be down for a while. Continue? [Y/N]:Y
 transceiver power-mode
Use transceiver power-mode to set a power mode for a 400-GE transceiver module.
Use undo transceiver power-mode to restore the default.
transceiver power-mode { high | low }
A transceiver module generally operates in high power mode. If the transceiver module does not work for a long time, you can switch the transceiver module to low power mode to reduce power consumption. In low power mode, the transceiver module does not transmit signals.
The power mode setting is saved in a register on the transceiver module. It is not saved to the configuration file.
# Set the 400-GE transceiver module in interface FourHundredGigE 1/1/1 to high power mode.
[Sysname-FourHundredGigE1/1/1] transceiver power-mode high
# Set the 400-GE transceiver module in interface FourHundredGigE 1/1/1 to low power mode.
[Sysname-FourHundredGigE1/1/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
