- 04-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-Loop detection configuration
- 06-Spanning tree configuration
- 07-LLDP configuration
- 08-PFC configuration
- 09-Service loopback group configuration
00-Preface | 100.00 KB |
Preface
This configuration guide describes the Layer 2—LAN switching configuration procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S6880 and S9820-8M switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
