05-Layer 3—IP Services Command Reference
HomeSupportSwitchesS6550X-HI SeriesReference GuidesCommand ReferencesH3C S6550X-HI Command References-R1116Pxx-6W10005-Layer 3—IP Services Command Reference
02-IP addressing commands
02-IP addressing commands 66.64 KB
display ip interface
Use display ip interface to display IP configuration and statistics for Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ]
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
Use the display ip interface command to display IP configuration and statistics for the specified Layer 3 interface. The statistics include the following information:
·     The number of unicast packets, bytes, and multicast packets the interface has sent and received.
·     The number of TTL-invalid packets and ICMP packets the interface has received.
The packet statistics helps you locate a possible attack on the network.
If you specify only the interface type, this command displays IP configuration and statistics for all interfaces of this interface type. If you do not specify any optional parameters, this command displays IP configuration and statistics for all Layer 3 interfaces.
# Display IP configuration and statistics for VLAN-interface 10.
<Sysname> display ip interface vlan-interface 10
Vlan-interface10 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
current state
Physical link state of the interface:
·     Administrative DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Data link layer state of the interface.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist.
Internet Address
IP address of an interface followed by:
·     Primary—A primary IP address.
·     Sub—A secondary IP address.
·     Unnumbered—An unnumbered IP address.
·     DHCP-Allocated—An IP address obtained through DHCP.
·     BOOTP-Allocated—An IP address obtained through BOOTP.
·     Mad—A MAD IP address.
Broadcast address
Broadcast address of the subnet attached to an interface.
MTU of the interface, in bytes.
input packets, bytes, multicasts
output packets, bytes, multicasts
All received and sent packets, bytes, and multicast packets on an interface (the device starts collecting statistics after it starts up).
Number of TTL-invalid packets received on the interface (statistics start at the device startup).
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total number of ICMP packets received on the interface (statistics start at the device startup):
·     Echo reply packets.
·     Unreachable packets.
·     Source quench packets.
·     Routing redirect packets.
·     Echo request packets.
·     Router advertisement packets.
·     Router solicitation packets.
·     Time exceeded packets.
·     IP header bad packets.
·     Timestamp request packets.
·     Timestamp reply packets.
·     Information request packets.
·     Information reply packets.
·     Netmask request packets.
·     Netmask reply packets.
·     Unknown type packets.
display ip interface brief
ip address
statistics l3-packet enable
Use display ip interface brief to display brief IP configuration for Layer 3 interfaces.
display ip interface [ interface-type [ interface-number ] ] brief [ description ]
interface-type: Specifies an interface type. If you do not specify an interface type, this command displays brief IP configuration for all Layer 3 interfaces except VA interfaces.
interface-number: Specifies an interface number. If you do not specify an interface number, this command displays brief IP configuration for all Layer 3 interfaces of the specified type.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays a maximum of 16 characters for each interface description. If the description is longer than 16 characters, the first 14 characters are displayed, followed by an ellipsis (...).
Information displayed by the command includes the state of the physical and link layer protocols, IP address, and interface descriptions.
# Display brief IP configuration for VLAN interfaces.
<Sysname> display ip interface vlan-interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface                Physical Protocol IP Address      Description
Vlan10                   down     down     6.6.6.1         Link to CoreRo...
Vlan2                    down     down     7.7.7.1         --
<Sysname> display ip interface vlan-interface brief description
Vlan10                   down     down     6.6.6.1         Link to CoreRouter
The interface is administratively shut down by using the shutdown command.
(s) : spoofing
Spoofing attribute of the interface. The link protocol state of the interface is up, but the link is temporarily established on demand or does not exist.
Interface name.
Physical
Physical state of the interface:
·     *down—The interface is administratively shut down by using the shutdown command.
·     down—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the interface:
·     down—The protocol state of the interface is down.
·     down(l)—The protocol state of the interface is down (loopback).
·     up—The protocol state of the interface is up.
·     up(l)—The protocol state of the interface is up (loopback).
·     up(s)—The protocol state of the interface is up (spoofing).
IP Address
IP address of the interface. If no IP address is configured, this field displays hyphens (--).
Description of the interface. If no description is configured, this field displays hyphens (--).
ip address
ip address
Use ip address to assign an IP address to the interface.
Use undo ip address to remove the IP address from the interface.
undo ip address [ ip-address { mask-length | mask } [ sub ] ]
No IP address is assigned to an interface.
Interface view
ip-address: Specifies the IP address of the interface, in dotted decimal notation.
mask-length: Specifies the subnet mask length in the range of 1 to 31. For a loopback interface, the value range is 1 to 32.
mask: Specifies the subnet mask in dotted decimal notation.
sub: Assigns a secondary IP address to the interface.
Use the command to assign a primary or secondary IP address to an interface.
An interface can have only one primary IP address. If you execute this command multiple times to specify different primary IP addresses, the most recent configuration takes effect. If the interface connects to multiple subnets, configure primary and secondary IP addresses on the interface so the subnets can communicate with each other through the interface.
You cannot assign secondary IP addresses to an interface that obtains an IP address through BOOTP, PPP address negotiation, IP unnumbered, or DHCP.
If you do not specify any parameters, the undo ip address command removes all IP addresses from the interface. The undo ip address ip-address { mask | mask-length } command removes the primary IP address. The undo ip address ip-address { mask | mask-length } sub command removes a secondary IP address.
The primary and secondary IP addresses assigned to the interface can be located on the same network segment. Different interfaces on your device must reside on different network segments.
# Assign VLAN-interface 10 a primary IP address 129.12.0.1 and a secondary IP address 202.38.160.1, with subnet masks both 255.255.255.0.
[Sysname-Vlan-interface10] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface10] ip address 202.38.160.1 255.255.255.0 sub
ip address unnumbered
Use ip address unnumbered to configure the current interface as IP unnumbered to borrow an IP address from the specified interface.
Use undo ip address unnumbered to restore the default.
The interface does not borrow IP addresses from other interfaces.
Interface view
interface interface-type interface-number: Specifies an interface from which the current interface can borrow an IP address.
Typically, you assign an IP address to an interface either manually or through DHCP. If the IP addresses are not enough, or the interface is used only occasionally, you can configure an interface to borrow an IP address from other interfaces. This is called IP unnumbered, and the interface borrowing the IP address is called IP unnumbered interface.
Loopback interfaces cannot borrow IP addresses of other interfaces, but other interfaces can borrow IP addresses of loopback interfaces.
Multiple interfaces can use the same unnumbered IP address. If an interface has multiple manually configured IP addresses, only the primary IP address manually configured can be borrowed.
You cannot enable a dynamic routing protocol on the interface that has no IP address configured. To enable the interface to communicate with other devices, you must configure a static route to the peer device on the interface.
# Configure Tunnel 0 to borrow the IP address of VLAN-interface 100.
[Sysname] interface tunnel 0 mode gre
[Sysname-Tunnel0] ip address unnumbered interface vlan-interface 100
