10-WLAN Roaming Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(E1053P01)-5W10110-WLAN Roaming Command Reference
01-WLAN roaming commands
01-WLAN roaming commands 146.52 KB
client cache aging-time
Use client cache aging-time to set the aging time for client roaming entries.
Use undo client cache aging-time to restore the default.
client cache aging-time aging-time
The aging time for client roaming entries is 180 seconds.
Service template view
aging-time: Specifies the aging time in the range of 0 to 86400 seconds.
Setting the roaming entry aging time to 0 allows the system to delete the roaming entry of a client once the client goes offline. Fast roaming cannot be performed.
Make sure the service template is disabled before you executing this command.
The aging time is available only for intra-AC roaming entries, and does not take effect on inter-AC roaming entries.
# Set the aging time for client roaming entries to 180 seconds.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client cache aging-time 100
display wlan mobility roam-track mac-address
Use display wlan mobility roam-track mac-address to display roaming information for a client.
display wlan mobility roam-track mac-address mac-address
mac-address mac-address: Specifies a client by its MAC address, in the form of H-H-H.
Roaming information is displayed in sequence. The most recent roam-track information is displayed the first.
The system can save a maximum of 128 roaming-track entries. To add a new roaming entry when the maximum number is reached, the system deletes the 126th entry and then add a new one.
# Display roaming information for the specified client on the home AC.
<Sysname> display wlan mobility roam-track mac-address 5250-0012-0411
Total entries: 2
BSSID           Created at           Online time       AC IP address  RID  AP name
3ce5-a68d-2280  2016-06-14 11:12:28  00hr 48min 46sec  127.0.0.1      2    ap1
0026-3e08-1150  2016-06-14 11:12:05  00hr 40min 46sec  127.0.0.1      2    ap2
BSSID
BSSID of the AP with which the client is associated.
Created at
Time when a roam-track entry was created for the client.
Online time
Online time of the client.
AC IP address
IP address of the AC with which the client is associated. This field displays 127.0.0.1.
RID
ID of the radio with which the client is associated.
AP name
Name of the AP with which the client is associated.
Enhanced roaming commands
bss transition-management enable
Use bss transition-management enable to enable BTM.
Use undo bss transition-management enable to disable BTM.
BTM is disabled.
With BTM enabled, an AP responds to a BTM query from a client with a BTM request. If client anti-sticky is disabled, the AP sends an unsolicited BTM request to the client when it detects that the RSSI of the client is lower than the specified threshold to trigger BTM. After receiving the BTM request, the client determines whether to roam to another BSS.
Make sure the service template is disabled before you perform this task.
For BTM to take effect on all clients, use the bss transition-management disassociation command to enable BTM disassociation.
# Enable BTM.
[Sysname-wlan-st-service1] bss transition-management enable
sacp anti-sticky
Use bss transition-management disassociation to enable BTM disassociation.
Use undo bss transition-management disassociation to disable BTM disassociation.
bss transition-management disassociation { forced | recommended } [ timer time ]
Recommended BTM disassociation is enabled and the disassociation timeout is 90 seconds.
forced: Enables forced disassociation. An AP forcibly logs off a client if that client has not disassociated with that AP when the disassociation timer expires.
recommended: Enables recommended disassociation. An AP does not forcibly log off a client if that client has not disassociated with that AP when the disassociation timer expires.
timer time: Specifies the disassociation timer in the range of 0 to 180 seconds. By default, the timer is 90 seconds. With this timer set to 0, an AP forcibly logs off a client immediately after sending a BTM request to that client if forced disassociation is enabled. If recommended disassociation is enabled, the AP does not log off a client after sending a BTM request to that client.
With BTM disassociation configured, an AP sends a BTM request to a client upon receiving a BTM query from the client and guides the client for BSS transition. With forced BTM disassociation configured, the AP forcibly logs off the client if the client fails to leave the current BSS before the disassociation timer expires.
Forced BTM disassociation will forcibly log off a client. Use this feature with caution.
For BTM disassociation to take effect, enable BTM first.
# Enable BTM disassociation and set the forced disassociation timer to 60 seconds.
[Sysname-wlan-st-service1] bss transition-management disassociation forced timer 60
display wlan sacp move-history
Use display wlan sacp move-history to display the client roaming history.
display wlan sacp move-history [ mac-address mac-address ]
mac-address mac-address: Specifies the MAC address of a client. If you do not specify this option, the command displays the roaming history of all clients.
This command displays client association and disassociation history during BSS transition.
If you do not specify a client, the command displays information about all clients with the latest information coming first in the output.
This command is available only in AC+fit AP networks.
# Display the roaming history of all clients.
<Sysname> display wlan sacp move-history mac-address 78AC-C0AF-944F
Total entries: 2
Time          MAC address    AP name                          Chl RSSI Result
1/11 15:57:09 78AC-C0AF-944F S:AP2                            6   20
                             T:AP3                            11
1/11 15:57:10                A:AP3                            11  40   BTM-1
1/11 15:56:39 78AC-C0AF-944F S:AP1                            1   19
                             T:AP3                            1
1/11 15:56:45                A:AP2                            1   42   BTM-2
# Display the roaming history of a specific client that does not support BTM.
<Sysname> display wlan sacp move-history mac-address 58AC-C0AF-EEFF
Current entries: 2
1/11 10:51:09 58AC-C0AF-EEFF S:AP2                            6   20
1/11 10:51:16                A:AP3                            11  40   DE-SA
1/11 10:50:44 58AC-C0AF-EEFF S:AP1                            1   19
1/11 10:50:45                A:AP2                            6   42   DE
Total entries
Total number of entries.
Current entries
Number of entries for the specified client.
Time
Time at which the entry was generated.
·     For BTM-capable clients:
¡     For the currently associated AP (named S:ap_name), this field displays the time at which the AP sent the first BTM request to the client.
¡     For the first associated AP (named A:ap_name), this field displays the time at which the client came online.
·     For BTM-incapable clients:
¡     For the currently associated AP (named S:ap_name), this field displays the time at which the AP sent the last Deauth packet to the client.
MAC address
MAC address of the client.
AP name
AP role and AP name.
·     S—Source, the currently associated AP.
·     T—Target.
¡     For a BTM-capable client, T represents that the AP is the first one in the BSS candidate list the last time a BTM request takes effect. If no APs exist in the candidate list, this field displays -.
¡     For a BTM-incapable client, this field displays - because no target AP exists.
·     A—Actual, the AP from which the client came online.
If the name of an AP exceeds 30 characters, the system displays only the last 27 characters with an ellipsis prefixed to the string. For example, if the AP name is cabcxyzxyzxyzabcabcabcxyzabcxyz, the system displays the name as …xyzxyzxyzabcabcabcxyzabcxyz.
Chl
Channel.
·     S—Current working channel.
·     T—Target channel.
¡     For a BTM-capable client, T represents that the channel is the first one in the recommended channel list the last time a BTM request takes effect. If no channels exist in the list, this field displays -.
¡     For a BTM-incapable client, this field displays - because no target channel exists.
·     A—Channel from which the client came online.
RSSI
Client RSSI.
·     S—Client RSSI detected by the associated AP the last time a BTM request or Deauth packet takes effect.
·     A—Client RSSI when the client came online.
This field might display 0 if the collected client RSSI is too low.
Result
Reason why the client changed the associated BSS and the result.
·     For a BTM-capable client, options include:
¡     BTM-n—BTM transition succeeded. n represents that the target AP is the nth in the BSS candidate list. n is in the range of 1 to 5.
¡     BTM-NT—BTM transition succeeded. Not Target (NT) represents that the target is not in the BSS candidate list.
¡     BTM-NU—BTM transition succeeded. NULL (NU) represents that the candidate list is not provided.
¡     BTM-QU—BTM transition succeeded. QU represents that the transition was triggered by a BTM Query sent by the client. If the system has not received the RSSI reported by anti-sticky detection, the RSSI field displays -.
·     For a BTM-incapable client, options include:
¡     DE—DEAUTH transition succeeded. The client came online within 5 seconds after receiving the Deauth packet.
¡     DE-SA—DEAUTH transition succeeded. SlowAccess (SA) represents that it took 5 to 10 seconds for the client to come online again after receiving the Deauth packet.
¡     DE-FO—DEAUTH transition failed. ForcedOffline (FO) represents that the client came online 10 to 30 seconds after being logged off for other reasons.
¡     DE-OB—DEAUTH transition succeeded. OldBSSID (OB) represents that the client came online from the old AP within 5 seconds after receiving the Deauth packet.
¡     DE-NS—DEAUTH transition succeeded. NewSSID (NS) represents that the client came online from a new SSID within 30 seconds after receiving the Deauth packet.
sacp roam-optimize bss-candidate-list enable
display wlan client rm-capabilities
Use display wlan client rm-capabilities to display radio resource measurement capabilities reported by clients.
display wlan client rm-capabilities [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all clients.
# Display radio resource measurement capabilities of the client with a MAC address of a89c-55bc-7819.
<Sysname> display wlan client rm-capabilities mac-address a89c-55bc-7819
Neighbor report capability                                 : Enabled
Beacon passive measurement                                 : Enabled
Beacon active measurement                                  : Enabled
Beacon table measurement                                   : Enabled
Neighbor report capability:
·     Disabled.
·     Enabled.
Beacon passive measurement capability:
·     Disabled.
·     Enabled.
Beacon active measurement capability:
·     Disabled.
·     Enabled.
Beacon table measurement capability:
·     Disabled.
·     Enabled.
ft enable
Use ft enable to enable fast BSS transition (FT).
Use undo ft enable to disable FT.
ft enable
undo ft enable
FT is disabled.
FT minimizes the delay when a client roams from a BSS to another BSS within the same ESS. During 802.11r FT, a client needs to exchange messages with the target AP. FT provides two message exchanging methods.
802.11r takes effect only on clients associated with the AC.
Before executing this command, make sure the service template is disabled.
To use 802.11r, make sure the security IE is RSN, the cipher suite is CCMP, and local authentication is not used.
Do not enable 802.11r FT and set the WPA3 security mode or enable enhanced open system authentication at the same time. If you do so, the service template cannot be enabled. For more information about WPA3 and enhanced open system authentication, see WLAN Security Configuration Guide.
# Enable FT.
[Sysname] wlan service-template st
[Sysname-wlan-st-st] ft enable
security-ie
ft reassociation-timeout
Use ft reassociation-timeout to set the reassociation timeout timer.
Use undo ft reassociation-timeout to restore the default.
ft reassociation-timeout timeout
The reassociation timeout timer is 20 seconds.
timeout: Specifies the reassociation timeout timer in the range of 1 to 100 seconds.
The roaming process is terminated if a client does not send any reassociation requests before the timeout timer expires.
Set the reassociation timeout timer only when the service template is disabled.
This command takes effect only when FT is enabled.
# Set the reassociation timeout timer to 30 seconds.
[Sysname-wlan-st-st] ft reassociation-timeout 30
ft enable
mac-authentication fast-connect enable
Use mac-authentication fast-connect enable to enable fast-connect for MAC authenticated intra-AC roaming clients.
Use undo mac-authentication fast-connect enable to disable fast-connect for MAC authenticated intra-AC roaming clients.
Fast-connect is enabled for MAC authenticated intra-AC roaming clients.
This command allows a MAC authentication roaming client that has been authenticated once on the AC to come online from any APs attached to the AC without re-authentication.
This feature applies only to MAC authentication wireless clients whose authentication location and association location are both on the AC.
This feature affects the displayed roaming state of inter-AC roaming clients that use MAC authentication and requires special configuration for them.
·     If a client has roamed between ACs, its roaming state is N/A in the output from the display wlan client verbose command.
·     If the inter-AC roaming clients belong to different VLANs, you must make sure the upstream ports of all the ACs in the same roaming group permit traffic from these VLANs to pass through.
# Enable fast-connect for MAC authenticated intra-AC roaming clients in service template service1.
[Sysname-wlan-st-service1] mac-authentication fast-connect enable
client-security authentication-mode (User Access and Authentication Command Reference)
sacp anti-sticky
Use sacp anti-sticky enable to enable client anti-sticky.
Use sacp anti-sticky disable to disable client anti-sticky.
Use undo sacp anti-sticky to restore the default.
sacp anti-sticky { disable | enable [ rssi rssi-value ] [ interval interval ] [ forced-logoff ] }
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, client anti-sticky is enabled.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100 dBm. By default, the threshold is 20 dBm.
interval interval: Specifies the detection interval in the range of 1 to 10 seconds. By default, the interval is 3 seconds.
forced-logoff: Logs off non-802.11v clients whose signal strength is lower than the RSSI threshold.
This feature enables APs to examine the signal strength of clients at the specified intervals. For an 802.11v client, its associated AP triggers a BSS transition to guide the client to a better BSS if the signal strength of the client is lower than the threshold. For a non-802.11v client, no action is performed.
# Enable client anti-sticky, set the RSSI threshold to 30, set the detection interval to 5 seconds, and enable forced logoff for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] sacp anti-sticky enable rssi 30 interval 5 forced-logoff
# Enable client anti-sticky, set the RSSI threshold to 30, and set the detection interval to 5 seconds for radio 1 of APs in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] sacp anti-sticky enable rssi 30 interval 5
sacp anti-sticky acl
Use sacp anti-sticky acl to configure ACL-based client anti-sticky.
Use sacp anti-sticky acl remove to remove the ACL-based client anti-sticky configuration.
Use undo sacp anti-sticky acl to restore the default.
In radio view:
sacp anti-sticky acl { acl-number rssi rssi-value | remove }
In an AP group's radio view:
sacp anti-sticky acl acl-number [ rssi rssi-value ]
In radio view, a radio uses the configuration in AP group view.
In an AP group's radio view, ACL-based client anti-sticky is not configured.
Radio view
acl-number: Specifies the number of a Layer 2 ACL, in the range of 4000 to 4999.
With client anti-sticky enabled, the system logs off a client if the signal strength of the client cannot reach the RSSI threshold. This practice might cause frequent BSS transitions and affect user experience.
To solve this issue, configure ACL-based client anti-sticky to set different RSSI thresholds for clients matching different ACL rules.
For clients that do not match any configured ACL rules, the RSSI threshold for client anti-sticky is used.
# Specify ACL 4000 for ACL-based client anti-sticky and set the RSSI threshold to 35 for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] sacp anti-sticky acl 4000 rssi 35
# Specify ACL 4000 for ACL-based client anti-sticky and set the RSSI threshold to 35 for radio 1 of APs in AP group apgroup2.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] sacp anti-sticky acl 4000 rssi 35
sacp anti-sticky
sacp roam-optimize traffic-hold enable advanced
Use sacp roam-optimize traffic-hold enable advanced to enable advanced data transmission holding during roaming.
Use undo sacp roam-optimize traffic-hold enable to disable advanced data transmission holding during roaming.
Advanced data transmission holding during roaming is disabled.
With advanced data transmission holding during roaming enabled, the device caches the data packets and sends the cached packets to the client to reduce the packet loss when the client signal strength is lower than the RSSI threshold specified by client anti-sticky. With advanced data transmission holding during roaming disabled, the device ages out the cached packets after a period of time and will not send the packets to the client. As a best practice, enable advanced data transmission holding during roaming in the BSS roaming scenario enabled with client anti-sticky.
To make this feature take effect, enable client association at the AC and enable the AC to forward client data traffic.
# Enable advanced data transmission holding during roaming.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] sacp roam-optimize traffic-hold enable advanced
Use sacp roam-optimize bss-candidate-list enable to enable an AP to obtain BSS candidate information.
Use sacp roam-optimize bss-candidate-list disable to disable an AP from obtaining BSS candidate information.
Use undo sacp roam-optimize bss-candidate-list to restore the default.
sacp roam-optimize bss-candidate-list { disable | enable [ interval interval ] }
In radio view, an AP uses the configuration in an AP group's radio view.
In an AP group's radio view, the BSS candidate obtaining feature is disabled.
Radio view
interval interval: Specifies the interval for obtaining BSS candidate information in the range of 1 to 500 seconds. By default, the interval is 10 seconds.
This feature takes effect only on clients that come online after the feature is configured.
This feature enables an AP to send Beacon requests at specific intervals to clients that support Beacon measurement and obtain information about BSSs detected by the clients. Upon receiving such a request, a client responds with a Beacon Report frame to report BSS information.
With this feature disabled, the AP stops updating BSS candidate information and deletes all the candidates after the aging time expires.
If both this feature and BSS transition management are enabled, the system can guide clients to roam to better services based on the BSS candidate information.
To examine if a client supports beacon measurement, use the display wlan client rm-capabilities command.
# Enable the BSS candidate obtaining feature for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] sacp roam-optimize bss-candidate-list enable
# Enable the BSS candidate obtaining feature for radio 1 of APs in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] sacp roam-optimize bss-candidate-list enable
Mobility group commands
authentication-mode
Use authentication-mode to set an authentication mode for IADTP control messages.
Use undo authentication-mode to restore the default.
authentication-mode authentication-mode { cipher | simple } string
The device does not verify the integrity of IADTP control messages.
Mobility group view
authentication-mode: Specifies an authentication mode. Only the 128-bit MD5 authentication mode is supported.
simple: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enable the device to verify the integrity of control messages transmitted over IADTP tunnels.
# Set the authentication mode to MD5 and set the plaintext key to 12345.
[Sysname] wlan mobility group aaa
[Sysname-wlan-mg-aaa] authentication-mode md5 simple 12345
data-tunnel disable
Use data-tunnel disable to disable IADTP data tunnels.
Use undo data-tunnel disable to enable IADTP data tunnels.
data-tunnel disable
IADTP data tunnels are enabled.
Mobility group view
CAUTION
CAUTION:
To avoid data loss, do not disable IADTP data tunnels if no service ports are specified on the device for client VLANs.
This feature enables a device to forward client traffic directly out of client VLANs' service ports, instead of through the IADTP data tunnel. This reduces the device's workload caused by processing broadcast packets received from IADTP data tunnels and saves resources used for maintaining the tunnels.
You must enable or disable IADTP tunnels on all devices in a mobility group.
You can configure this feature only when the mobility group is disabled.
# Disable IADTP data tunnels.
[Sysname] wlan mobility group group1
[Sysname-wlan-mg-group1] data-tunnel disable
wlan mobility group
Use display wlan mobility to display information about clients that have roamed to or from the device.
display wlan mobility { roam-in | roam-out } [ member ip ipv4-address ]
roam-in: Specifies clients that have roamed from another device to the current device.
roam-out: Specifies clients that have roamed to another device.
member ip ipv4-address: Specifies the IPv4 address of a member device.
If no member device is specified, this command displays information about all clients that have roamed to and from another device.
# Display information about all clients that have roamed to the device.
<Sysname> display wlan mobility roam-in
Total entries: 1
MAC address     BSSID           VLAN ID  HA IP address
5250-0012-0411  cbab-abab-abab  1        192.168.0.101
# Display information about clients that have roamed to the specified member device.
<Sysname> display wlan mobility roam-in member ip 192.168.0.101
Total entries: 1
# Display information about all clients that have roamed to another device.
<Sysname> display wlan mobility roam-out
Total entries: 1
MAC address     BSSID           VLAN ID  Online time       FA IP address
5250-0012-0411  cbab-abab-abab  1        00hr 01min 39sec  192.168.0.102
# Display information about clients that have roamed from the specified member device to another device.
[Sysname] display wlan mobility roam-out member ip 192.168.0.102
Total entries: 1
5250-0012-0411  cbab-abab-abab  1        00hr 03min 02sec
Total entries
Total number of clients.
MAC address
BSSID
VLAN ID
VLAN ID of the client.
HA IP address
IP address of the HA.
FA IP address
IP address of the FA.
Online time
display wlan mobility group
Use display wlan mobility group to display mobility group information.
# Display mobility group information.
<Sysname> display wlan mobility group
Mobility group name: office
 Tunnel type: IPv4
 Source IPv4: 172.16.220.101
 Source IPv6: Not configured
 Authentication method: Not configured
 Auto discovery: Enabled
 Mobility group status: Enabled
 Member entries: 3
 IP address                              State          Online duration
 172.16.220.102                          DOWN           00hr 00min 00sec
 172.16.220.105                          UP             00hr 36min 27sec
 172.16.220.106                          UP (A)         00h 50min 30sec
Table 5 Command output
Tunnel type
IADTP tunnel type for the mobility group:
·     IPv4.
·     IPv6. This parameter is not supported in the current software version.
Authentication method used for the mobility group.
Auto discovery
Status of automatic group member discovery:
·     Enabled.
·     Disabled.
·     Enabled.
·     Disabled.
Member entries
Number of member devices.
IP address
IP address of the member device.
IADTP tunnel state:
·     UP.
·     DOWN.
The (A) suffix indicates that the device has joined the group through automatic group member discovery.
Online duration
Online duration of the member device.
wlan mobility group
group enable
Use group enable to enable a mobility group.
Use undo group enable to disable a mobility group.
group enable
undo group enable
A mobility group is disabled.
Mobility group view
Before enabling a mobility group, make sure you have completed the following tasks:
·     Configure the source IP address of the same type as the IADTP tunnel address type.
·     Specify member IP addresses of the same type as the IADTP tunnel address type, or enable automatic group member discovery.
This feature enables the device to establish IADTP tunnels and synchronize roaming entries with member devices.
If you disable a mobility group on the device, the device shuts down all IADTP tunnels established with all member devices and deletes the roaming entries.
# Enable mobility group floor1.
[Sysname] wlan mobility group floor1
[Sysname-wlan-mg-floor1] tunnel-type ipv4
[Sysname-wlan-mg-floor1] source ip 192.168.0.1
[Sysname-wlan-mg-floor1] member ip 192.168.0.2
[Sysname-wlan-mg-floor1] group enable
member
source
tunnel-type
wlan mobility group
member
Use member to add a mobility group member.
Use undo member to delete a mobility group member.
member ip ipv4-address [ vlan vlan-id-list ]
undo member [ ip ipv4-address ] [ vlan [ vlan-id-list ] ]
No member devices exist.
Mobility group view
ip ipv4-address: Specifies a device by its IPv4 address.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 2 to 4094. The value for the vlan-id2 argument cannot be lower than the value for the vlan-id1 argument.
Make sure the mobility group is disabled before you use this command.
Members in a mobility group are identified by their IP addresses used to establish IADTP tunnels.
A device can belong to only one mobility group.
You can add a maximum of 31 IPv4 members to a mobility group.
You can specify VLANs for a member device, so that other member devices in the mobility group can directly forward client data of the member device from the specified VLANs. If you do not specify VLANs for the member device, its client data cannot be directly forwarded by another member in the mobility group unless the clients roam to that member.
If a mobility group has multiple devices, make sure no loops exist among IADTP tunnels between members within the mobility group.
The undo form of this command deletes all member devices in a mobility group if you do not specify any parameters.
# Add a mobility group member.
[Sysname] wlan mobility group abc
[Sysname-wlan-mg-abc] member ip 192.168.1.55 vlan 3 10 19 22 to 30
member auto-discovery
Use member auto-discovery to enable automatic group member discovery.
Use undo member auto-discovery to disable automatic group member discovery and delete all automatically discovered member devices.
member auto-discovery [ interval interval ]
Automatic group member discovery is disabled.
Mobility group view
interval: Specifies the interval at which the device broadcasts its source IP address, in the range of 10 to 3600 seconds. The default value is 60.
Before enabling this feature, execute the source command to specify the source IP address used for establishing IADTP tunnels.
This feature enables a device to automatically discover member devices in a mobility group by broadcasting its source IP address in the group. Member devices in the group that receive the IP address automatically establish IADTP tunnels with the device. The device joins the mobility group after it establishes IADTP tunnels with all the other members.
The automatic discovery feature can add only devices in the same subnet as the source IP address.
# Enable automatic group member discovery and set the broadcast interval to 10 seconds.
[Sysname] wlan mobility group 1
[Sysname-wlan-mg-1] member auto-discovery interval 10
member
source
wlan mobility group
role
Use role to specify the role of the device in a mobility group.
Use undo role to restore the default.
role { client | server }
undo role
A member device with a higher IP address acts as the server, and a member device with a lower IP address acts as the client.
Mobility group view
client: Specifies the client role of the device.
server: Specifies the server role of the device.
This feature applies to a scenario where a device establishes an IADTP tunnel with another device in the same mobility group across a NAT device. In this scenario, the device with a lower IP address acts as the client to initiate a connection request to the device with a higher IP address. If the device with a lower IP address resides in the public network, the IADTP tunnel cannot be established. To ensure successful establishment of the IADTP tunnel in this case, specify the device in the private network as the client to initiate the connection request.
# Configure the device to act as a client in mobility group abc.
[Sysname-wlan-mg-abc] role client
snmp-agent trap enable wlan mobility
Use snmp-agent trap enable wlan mobility to enable SNMP notifications for WLAN roaming.
Use undo snmp-agent trap enable wlan mobility to disable SNMP notifications for WLAN roaming.
SNMP notifications are disabled for WLAN roaming.
To report critical WLAN roaming events to an NMS, enable SNMP notifications for WLAN roaming. For WLAN roaming event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN roaming.
[Sysname] snmp-agent trap enable wlan mobility
source
Use source to specify the source IP address for establishing IADTP tunnels.
Use undo source to delete the source IP address for establishing IADTP tunnels.
source ip ipv4-address
undo source [ ip ]
No source IP address is specified for establishing IADTP tunnels.
Mobility group view
ip ipv4-address: Specifies a source IPv4 address.
A device uses its source IP address to establish IADTP tunnels with member devices.
Make sure the mobility group has been disabled.
If you do not specify an IP address when you use the undo command, this command deletes all source IP addresses.
# Specify a source IPv4 address for establishing IADTP tunnels.
[Sysname-wlan-mg-abc] source ip 192.168.1.55
group enable
member
tunnel-dscp
Use tunnel-dscp to set a DSCP value for IADTP keepalive packets.
Use undo tunnel-dscp to restore the default.
tunnel-dscp dscp-value
undo tunnel-dscp
The DSCP value is 0 for IADTP keepalive packets.
Mobility group view
dscp-value: Specifies a DSCP value for IADTP keepalive packets, in the range of 0 to 63. As a best practice, set the DSCP value to 63.
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet. A greater DSCP value means a higher packet priority.
In a scenario where a device establishes IADTP tunnels with other devices across NAT devices, two devices use IPsec for tunnel encryption and establishment. To prevent IADTP tunnel disconnection because the device cannot receive any IADTP keepalive packets from the peer when the IADTP tunnel is busy, set the DSCP value by using this feature.
# Set the DSCP value to 63 for IADTP keepalive packets.
[Sysname-wlan-mg-abc] tunnel-dscp 63
tunnel-type
Use tunnel-type to specify the IP address type for IADTP tunnels.
Use undo tunnel-type to restore the default.
tunnel-type ipv4
undo tunnel-type
The IP address type for IADTP tunnels is IPv4.
Mobility group view
ipv4: Specifies the IPv4 address type.
Make sure the mobility group is disabled before you execute this command.
# Specify the IP address type as IPv4 for IADTP tunnels in mobility group aaa.
[Sysname-wlan-mg-aaa] tunnel-type ipv4
wlan mobility group
Use wlan mobility group to create a mobility group and enter its view, or enter the view of the existing mobility group.
Use undo wlan mobility group to restore the default.
wlan mobility group group-name
undo wlan mobility group group-name
No mobility group exists.
group-name: Specifies a mobility group by its name, a case-insensitive string of 1 to 15 characters that do not contain spaces.
Mobility groups configured on member devices must have the same name.
You can create only one mobility group on a device.
# Create a mobility group named office and enter its view.
[Sysname] wlan mobility group office
[Sysname-wlan-mg-office]
