08-WLAN Security Command Reference
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesCommand ReferencesH3C WX3800X Series Access Controllers Command References(E1053P01)-5W10108-WLAN Security Command Reference
02-WIPS commands
02-WIPS commands 489.63 KB
WIPS commands· 1
access-scan· 1
ap-channel-change· 1
ap-classification rule· 2
ap-flood· 2
ap-impersonation· 3
apply ap-classification rule· 4
apply classification policy· 4
apply countermeasure policy· 5
apply detect policy· 6
apply signature policy· 6
apply signature rule· 7
ap-rate-limit 7
ap-spoofing· 8
ap-timer 9
association-table-overflow· 9
authentication· 10
block mac-address· 11
classification policy· 11
client-association fast-learn enable· 12
client-online· 13
client-rate-limit 13
client-spoofing· 14
client-timer 15
countermeasure adhoc· 15
countermeasure attack all 16
countermeasure attack deauth-broadcast 16
countermeasure attack disassoc-broadcast 17
countermeasure attack honeypot-ap· 18
countermeasure attack hotspot-attack· 18
countermeasure attack ht-40-mhz-intolerance· 19
countermeasure attack malformed-packet 19
countermeasure attack man-in-the-middle· 20
countermeasure attack omerta· 20
countermeasure attack power-save· 21
countermeasure attack soft-ap· 21
countermeasure attack unencrypted-trust-client 22
countermeasure attack weak-iv· 22
countermeasure attack windows-bridge· 23
countermeasure enhance· 23
countermeasure external-ap· 24
countermeasure mac-address· 24
countermeasure misassociation-client 25
countermeasure misconfigured-ap· 25
countermeasure packet-sending-interval 26
countermeasure policy· 27
countermeasure potential-authorized-ap· 27
countermeasure potential-external-ap· 28
countermeasure potential-rogue-ap· 28
countermeasure rogue-ap· 29
countermeasure unauthorized-client 29
countermeasure uncategorized-ap· 30
countermeasure uncategorized-client 30
deauthentication-broadcast 31
deauth-spoofing· 31
detect dissociate-client enable· 32
detect policy· 32
detect signature· 33
disassociation-broadcast 34
discovered-ap· 35
display wips sensor 35
display wips statistics· 36
display wips virtual-security-domain countermeasure record· 39
display wips virtual-security-domain device· 41
display wlan nat-detect 46
embedded-oui-classify enable· 46
export oui 47
flood association-request 48
flood authentication· 48
flood beacon· 49
flood block-ack· 50
flood cts· 51
flood deauthentication· 51
flood disassociation· 52
flood eap-failure· 53
flood eapol-logoff 54
flood eapol-start 54
flood eap-success· 55
flood null-data· 56
flood probe-request 57
flood reassociation-request 57
flood rts· 58
frame-type· 59
honeypot-ap· 60
hotspot-attack· 61
hotspot ssid· 61
ht-40mhz-intolerance· 62
ht-greenfield· 63
ignorelist 63
import hotspot 64
import oui 65
invalid-oui-classify illegal 65
mac-address· 66
malformed duplicated-ie· 67
malformed fata-jack· 67
malformed illegal-ibss-ess· 68
malformed invalid-address-combination· 69
malformed invalid-assoc-req· 69
malformed invalid-auth· 70
malformed invalid-deauth-code· 71
malformed invalid-disassoc-code· 71
malformed invalid-ht-ie· 72
malformed invalid-ie-length· 73
malformed invalid-pkt-length· 74
malformed large-duration· 74
malformed null-probe-resp· 75
malformed overflow-eapol-key· 76
malformed overflow-ssid· 76
malformed redundant-ie· 77
man-in-the-middle· 78
manual-classify mac-address· 78
match all (AP classification rule view) 79
match all (signature view) 80
omerta· 80
oui 81
pattern· 81
permit-channel 82
power-save· 83
prohibited-channel 84
random-mac-scan· 85
report-interval 85
reset wips embedded-oui 86
reset wips statistics· 86
reset wips virtual-security-domain· 87
reset wips virtual-security-domain countermeasure record· 87
reset wlan nat-detect 88
rssi 88
rssi-change-threshold· 89
rssi-threshold· 89
security· 90
select sensor all 91
seq-number 91
signature policy· 92
signature rule· 92
soft-ap· 93
ssid (AP classification rule view) 93
ssid (signature view) 94
ssid-length· 95
trust mac-address· 96
trust oui 96
trust ssid· 97
unencrypted-authorized-ap· 97
unencrypted-trust-client 98
up-duration· 99
virtual-security-domain· 99
weak-iv· 100
windows-bridge· 100
wips (radio view) 101
wips (system view) 102
wips virtual-security-domain· 102
wireless-bridge· 103
wlan nat-detect 103
wlan nat-detect countermeasure· 104
WIPS commands
access-scan
Use access-scan enable to configure APs to perform WIPS scanning while providing access services.
Use undo access-scan enable to disable APs from performing WIPS scanning while providing access services.
access-scan enable
APs do not perform WIPS scanning while they are providing access services.
WIPS view
This command enhances the WIPS detection and protection capabilities but decreases the access service capability.
# Configure APs to perform WIPS scanning while providing access services.
[Sysname] wips
[Sysname-wips] access-scan enable
ap-channel-change
Use ap-channel-change to configure channel change detection.
Use undo ap-channel-change to disable channel change detection.
ap-channel-change [ quiet quiet-value ]
Channel change detection is disabled.
Attack detection policy view
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a channel change. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a channel change within the quiet time.
# Configure channel change detection.
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] ap-channel-change quiet 5
Use ap-classification rule to create an AP classification rule and enter its view, or enter the view of an existing AP classification rule.
Use undo ap-classification rule to remove an AP classification rule.
ap-classification rule rule-id
undo ap-classification rule rule-id
No AP classification rules exist.
WIPS view
rule-id: Specifies an AP classification rule ID in the range of 1 to 65535.
# Create AP classification rule 1 and enter its view.
[Sysname] wips
[Sysname-wips] ap-classification rule 1
ap-flood
Use ap-flood to configure AP flood attack detection.
Use undo ap-flood to disable AP flood attack detection.
ap-flood [ apnum apnum-value | exceed exceed-value | quiet quiet-value ] *
undo ap-flood
AP flood attack detection is disabled.
apnum apnum-value: Specifies the AP number threshold in the range of 10 to 200. The default AP number threshold is 80.
exceed exceed-value: Specifies the maximum number of excessive APs allowed. The value range for the exceed-value argument is 10 to 200 and the default value is 80. If the number of APs exceeds the sum of the AP number threshold and the maximum number of excessive APs allowed, WIPS triggers an AP flood attack alarm.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an AP flood attack within the quiet time.
# Enable AP flood attack detection, and set the apnum-value, exceed-value, and quiet-value arguments to 50, 50, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] ap-flood apnum 50 exceed 50 quiet 100
ap-impersonation
Use ap-impersonation to configure AP impersonation attack detection.
Use undo ap-impersonation to disable AP impersonation attack detection.
ap-impersonation [ quiet quiet-value ]
AP impersonation attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP impersonation attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an AP impersonation attack within the quiet time.
# Enable AP impersonation attack detection, and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ap-impersonation quiet 360
Use apply ap-classification rule to bind an AP classification rule to a classification policy.
Use undo apply ap-classification rule to cancel the configuration.
apply ap-classification rule rule-id { authorized-ap | { { external-ap | misconfigured-ap | rogue-ap } [ severity-level level ] } }
undo apply ap-classification rule rule-id
No AP classification rule is bound to a classification policy.
Classification policy view
rule-id: Specifies an AP classification rule by its ID in the range of 1 to 65535.
authorized-ap: Specifies APs that match the AP classification rule as authorized APs.
external-ap: Specifies APs that match the AP classification rule as external APs.
misconfigured-ap: Specifies APs that match the AP classification rule as misconfigured APs.
rogue-ap: Specifies APs that match the AP classification rule as rogue APs.
level: Specifies a severity level for the AP that matches the AP classification rule, in the range of 1 to 100. The default severity level is 50.
# Bind AP classification rule 1 to classification policy home, specify APs that match AP classification rule 1 as rogue APs, and set the severity level to 80.
[Sysname] wips
[Sysname-wips] classification policy home
[Sysname-wips-cls-home] apply ap-classification rule 1 rogue-ap severity-level 80
Use apply classification policy to apply a classification policy to a virtual security domain (VSD).
Use undo apply classification policy to remove a classification policy from a VSD.
apply classification policy policy-name
undo apply classification policy policy-name
No classification policy is applied to a VSD.
VSD view
policy-name: Specifies a classification policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply classification policy policy1 to VSD home.
[Sysname] wips
[Sysname-wips] virtual-security-domain home
[Sysname-wips-vsd-home] apply classification policy policy1
Use apply countermeasure policy to apply a countermeasure policy to a VSD.
Use undo apply countermeasure policy to remove a countermeasure policy from a VSD.
apply countermeasure policy policy-name
undo apply countermeasure policy policy-name
No countermeasure policy is applied to a VSD.
VSD view
policy-name: Specifies a countermeasure policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply countermeasure policy policy2 to VSD home.
[Sysname] wips
[Sysname-wips-vsd-home] apply countermeasure policy policy2
apply detect policy
Use apply detect policy to apply an attack detection policy to a VSD.
Use undo apply detect policy to remove an attack detection policy from a VSD.
apply detect policy policy-name
undo apply detect policy policy-name
No attack detection policy is applied to a VSD.
VSD view
policy-name: Specifies an attack detection policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply attack detection policy policy2 to VSD home.
[Sysname] wips
[Sysname-wips-vsd-home] apply detect policy policy2
Use apply signature policy to apply a signature policy to a VSD.
Use undo apply signature policy to remove a signature policy from a VSD.
apply signature policy policy-name
undo apply signature policy policy-name
No signature policy is applied to a VSD.
VSD view
policy-name: Specifies a signature policy by its name, a case-sensitive string of 1 to 63 characters.
# Apply signature policy policy1 to VSD home.
[Sysname] wips
[Sysname-wips-vsd-home] apply signature policy policy1
Use apply signature rule to bind a signature to a signature policy.
Use undo apply signature rule to unbind a signature from a signature policy.
apply signature rule rule-id
undo apply signature rule rule-id
No signature is bound to a signature policy.
Signature policy view
rule-id: Specifies a signature by its ID in the range of 1 to 128.
# Bind signature 1 to signature policy office.
[Sysname] wips
[Sysname-wips] signature policy office
[Sysname-wips-sig-office] apply signature rule 1
ap-rate-limit
Use ap-rate-limit to rate limit AP entry learning.
Use undo ap-rate-limit to restore the default.
ap-rate-limit [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo ap-rate-limit
The statistics collection interval for learned AP entries is 60 seconds, the quiet time is 1200 seconds, and the AP entry threshold is 512.
interval interval-value: Specifies the statistics collection interval for learned AP entries, in the range of 1 to 3600 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP entry attack. The value range for the quiet-value argument is 1200 to 3600 seconds. WIPS stops learning new entries and does not trigger an alarm even if it detects an AP entry attack within the quiet time.
threshold threshold-value: Specifies the number of AP entries that triggers an AP entry attack alarm. The value range for the threshold-value argument is 1 to 4096.
# Rate limit AP entry learning, and set the interval-value, quiet-value, and threshold-value arguments to 60, 1600, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] ap-rate-limit interval 60 quiet 1600 threshold 100
ap-timer
ap-spoofing
Use ap-spoofing to enable AP spoofing attack detection.
Use undo ap-spoofing to disable AP spoofing attack detection.
ap-spoofing [ quiet quiet-value ]
undo ap-spoofing
AP spoofing attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an AP spoofing attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an AP spoofing attack within the quiet time.
# Enable AP spoofing attack detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ap-spoofing quiet 360
ap-timer
Use ap-timer to set an AP entry timer.
Use undo ap-timer to restore the default.
ap-timer inactive inactive-value aging aging-value
undo ap-timer
The inactive time is 300 seconds, and the aging time is 600 seconds.
inactive inactive-value: Specifies the inactive time in the range of 1 to 1200 seconds.
aging aging-value: Specifies the aging time for an AP entry, in the range of 1 to 86400 seconds.
When an AP does not receive or send frames within the specified inactive time, WIPS sets the AP to inactive state. When an AP does not receive or send frames within the specified aging time, WIPS deletes the entry.
The aging time must be equal to or greater than the inactive time. As a best practice, use the default inactive time and aging time.
Errors might exist in the time changes of AP entries, and the error value depends on the interval at which sensors report information about detected devices.
# Set the inactive time to 120 seconds and the aging time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ap-timer inactive 120 aging 360
ap-rate-limit
report-interval
Use association-table-overflow to configure association/reassociation DoS attack detection.
Use undo association-table-overflow to disable association/reassociation DoS attack detection.
association-table-overflow [ quiet quiet-value ]
Association/reassociation DoS attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an association/reassociation DoS attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an association/reassociation DoS attack within the quiet time.
# Enable association/reassociation DoS attack detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] association-table-overflow quiet 100
authentication
Use authentication to configure an AP classification rule to match APs by authentication mode.
Use undo authentication to restore the default.
authentication { equal | include } { 802.1x | none | other | psk }
undo authentication
An AP classification rule does not match APs by authentication mode.
equal: Matches authentication modes equal to the specified authentication mode.
include: Matches authentication modes that include the specified authentication mode.
802.1x: Specifies the 802.1X authentication mode.
none: Specifies no authentication.
other: Specifies an authentication mode other than 802.1X and PSK.
psk: Specifies the PSK authentication mode.
# Configure AP classification rule 1 to match APs that use the PSK authentication mode.
[Sysname] wips
[Sysname-wips-cls-rule-1] authentication equal psk
block mac-address
Use block mac-address to add the MAC address of an AP or client to the static prohibited device list.
Use undo block mac-address to remove one or all MAC addresses from the static prohibited device list.
block mac-address mac-address
undo block mac-address { mac-address | all }
No MAC address is added to the static prohibited device list.
mac-address: Specifies an AP or client by its MAC address, in the H-H-H format.
all: Specifies all MAC addresses.
# Add MAC address 78AC-C0AF-944F to the static prohibited device list.
[Sysname] wips
[Sysname-wips-cls-home] block mac-address 78AC-C0AF-944F
Use classification policy to create a classification policy and enter its view, or enter the view of an existing classification policy.
Use undo classification policy to remove a classification policy.
undo classification policy policy-name
No classification policies exist.
WIPS view
policy-name: Specifies a classification policy name, a case-sensitive string of 1 to 63 characters.
# Create classification policy home and enter its view.
[Sysname] wips
Use client-association fast-learn enable to enable fast learning of client association entries.
Use undo client-association fast-learn enable to disable fast learning of client association entries.
Fast learning of client association entries is disabled.
Client association entries are entries saved on the AC after a client associates with an AP.
If this feature is not enabled, the sensor can learn the client association entries only after a client is associated with an AP successfully. After this feature is enabled, the sensor can learn the client association entries during the association process.
If the sensor learned the client association entries during the association process, the sensor will update the entries every time it detects an association request or response between the AP and the client.
This feature improves the association efficiency but reduces the association accuracy. As a best practice, enable this feature only when fast attack detection and countermeasures are required in the network.
# Enable fast learning of client association entries.
[Sysname] wips
[Sysname-wips] detect policy 1
[Sysname-wips-dtc-1] client-association fast-learn enable
client-online
Use client-online to configure an AP classification rule to match APs by number of associated clients.
Use undo client-online to restore the default.
client-online value1 [ to value2 ]
undo client-online
An AP classification rule does not match APs by number of associated clients.
value1 to value2: Specifies a value range for the number of associated clients for APs. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 128 for both the value1 and value2 arguments, and value2 must be greater than value1.
# Configure AP classification rule 1 to match APs with 20 to 40 associated clients.
[Sysname] wips
[Sysname-wips-cls-rule-1] client-online 20 to 40
client-rate-limit
Use client-rate-limit to rate limit client entry learning.
Use undo client -rate-limit to restore the default.
client-rate-limit [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo client-rate-limit
The statistics collection interval for learned client entries is 60 seconds, the quiet time is 1200 seconds, and the client entry threshold is 1024.
interval interval-value: Specifies the statistics collection interval for learned client entries, in the range of 1 to 3600 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a client entry attack. The value range for the quiet-value argument is 1200 to 3600 seconds. WIPS stops learning new entries and does not trigger an alarm even if it detects a client entry attack within the quiet time.
threshold threshold-value: Specifies the number of client entries that triggers a client entry attack alarm. The value range for the threshold-value argument is 1 to 4096.
# Rate limit client entry learning, and set the interval-value, quiet-value, and threshold-value arguments to 80, 1600, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] client-rate-limit interval 80 threshold 100 quiet 1600
client-timer
client-spoofing
Use client-spoofing to enable client spoofing attack detection.
Use undo client-spoofing to disable client spoofing attack detection.
client-spoofing [ quiet quiet-value ]
Client spoofing attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a client spoofing attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a client spoofing attack within the quiet time.
# Enable client spoofing attack detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] client-spoofing quiet 360
client-timer
Use client-timer to set a client entry timer.
Use undo client-timer to restore the default.
client-timer inactive inactive-value aging aging-value
undo client-timer
inactive inactive-value: Specifies the inactive time in the range of 1 to 1200 seconds. aging aging-value: Specifies the aging time for a client entry, in the range of 1 to 86400 seconds.
When a client does not receive or send frames within the specified inactive time, WIPS sets the client to inactive state. When a client does not receive or send frames within the specified aging time, WIPS deletes the entry.
Errors might exist in the time changes of client entries, and the error value depends on the interval at which sensors report information about detected devices.
# Set the inactive time to 120 seconds, and set the aging time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] client-timer inactive 120 aging 360
client-rate-limit
report-interval
Use countermeasure adhoc to enable WIPS to take countermeasures against Ad hoc devices.
Use undo countermeasure adhoc to restore the default.
WIPS does not take countermeasures against Ad hoc devices.
Countermeasure policy view
# Enable WIPS to take countermeasures against Ad hoc devices.
[Sysname] wips
[Sysname-wips] countermeasure policy home
[Sysname-wips-cms-home] countermeasure adhoc
Use countermeasure attack all to enable WIPS to take countermeasures against all attackers.
Use undo countermeasure attack all to restore the default.
WIPS does not take countermeasures against all attackers.
# Enable WIPS to take countermeasures against all attackers.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack all
Use countermeasure attack deauth-broadcast to enable WIPS to take countermeasures against devices that launch broadcast deauthentication attacks.
Use undo countermeasure deauth-broadcast to restore the default.
undo countermeasure attack deauth-broadcast
WIPS does not take countermeasures against devices that launch broadcast deauthentication attacks.
# Enable WIPS to take countermeasures against devices that launch broadcast deauthentication attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack deauth-broadcast
Use countermeasure attack disassoc-broadcast to enable WIPS to take countermeasures against devices that launch broadcast disassociation attacks.
Use undo countermeasure attack disassoc-broadcast to restore the default.
WIPS does not take countermeasures against devices that launch broadcast disassociation attacks.
# Enable WIPS to take countermeasures against devices that launch broadcast disassociation attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack disassoc-broadcast
Use countermeasure attack honeypot-ap to enable WIPS to take countermeasures against honeypot APs.
Use undo countermeasure attack honeypot-ap to restore the default.
WIPS does not take countermeasures against honeypot APs.
# Enable WIPS to take countermeasures against honeypot APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack honeypot-ap
Use countermeasure attack hotspot-attack to enable WIPS to take countermeasures against devices that launch hotspot attacks.
Use undo countermeasure attack hotspot-attack to restore the default.
WIPS does not take countermeasures against devices that launch hotspot attacks.
# Enable WIPS to take countermeasures against devices that launch hotspot attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack hotspot-attack
Use countermeasure attack ht-40-mhz-intolerance to enable WIPS to take countermeasures against devices with the 40 MHz bandwidth mode disabled.
Use undo countermeasure attack ht-40-mhz-intolerance to restore the default.
WIPS does not take countermeasures against devices with the 40 MHz bandwidth mode disabled.
# Enable WIPS to take countermeasures against devices with the 40 MHz bandwidth mode disabled.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack ht-40-mhz-intolerance
Use countermeasure attack malformed-packet to enable WIPS to take countermeasures against devices that send malformed packets.
Use undo countermeasure attack malformed-packet to restore the default.
WIPS does not take countermeasures against devices that send malformed packets.
# Enable WIPS to take countermeasures against devices that send malformed packets.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack malformed-packet
Use countermeasure attack man-in-the-middle to enable WIPS to take countermeasures against devices that launch MITM attacks.
Use undo countermeasure attack man-in-the-middle to restore the default.
WIPS does not take countermeasures against devices that launch MITM attacks.
# Enable WIPS to take countermeasures against devices that launch MITM attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack man-in-the-middle
Use countermeasure attack omerta to enable WIPS to take countermeasures against devices that launch Omerta attacks.
Use undo countermeasure attack omerta to restore the default.
WIPS does not take countermeasures against devices that launch Omerta attacks.
# Enable WIPS to take countermeasures against devices that launch Omerta attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack omerta
Use countermeasure attack power-save to enable WIPS to take countermeasures against devices that launch power save attacks.
Use undo countermeasure attack power-save to restore the default.
WIPS does not take countermeasures against devices that launch power save attacks.
# Enable WIPS to take countermeasures against devices that launch power save attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack power-save
Use countermeasure attack soft-ap to enable WIPS to take countermeasures against soft APs.
Use undo countermeasure attack soft-ap to restore the default.
WIPS does not take countermeasures against soft APs.
# Enable WIPS to take countermeasures against soft APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack soft-ap
Use countermeasure attack unencrypted-trust-client to enable WIPS to take countermeasures against unencrypted authorized clients.
Use undo countermeasure attack unencrypted-trust-client to restore the default.
WIPS does not take countermeasures against unencrypted authorized clients.
# Enable WIPS to take countermeasures against unencrypted authorized clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack unencrypted-trust-client
Use countermeasure attack weak-iv to enable WIPS to take countermeasures against devices that use weak IVs.
Use undo countermeasure weak-iv to restore the default.
undo countermeasure attack weak-iv
WIPS does not take countermeasures against devices that use weak IVs.
# Enable WIPS to take countermeasures against devices that use weak IVs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack weak-iv
Use countermeasure attack windows-bridge to enable WIPS to take countermeasures against devices that launch Windows bridge attacks.
Use undo countermeasure attack windows-bridge to restore the default.
WIPS does not take countermeasures against devices that launch Windows bridge attacks.
# Enable WIPS to take countermeasures against devices that launch Windows bridge attacks.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure attack windows-bridge
Use countermeasure enhance to enable the enhanced countermeasure mode.
Use undo countermeasure enhance to restore the default.
The enhanced countermeasure mode is not enabled.
Configure this command to prevent dual-band clients from roaming between the two radios sharing the same SSID on a rogue AP.
# Enable the enhanced countermeasure mode.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure enhance
Use countermeasure external-ap to enable WIPS to take countermeasures against external APs.
Use undo countermeasure external-ap to restore the default.
WIPS does not take countermeasures against external APs.
# Enable WIPS to take countermeasures against external APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure external-ap
Use countermeasure mac-address to enable WIPS to take countermeasures against the device with the specified MAC address.
Use undo countermeasure mac-address to remove the configuration.
countermeasure mac-address mac-address [ except-authorized-ap ]
undo countermeasure mac-address { mac-address | all }
WIPS does not take countermeasures against detected devices.
mac-address: Specifies an AP or a client by its MAC address in the H-H-H format.
except-authorized-ap: Configures WIPS to not take countermeasures against wireless clients that have associated with authorized APs.
all: Specifies all APs and clients.
You can configure this command multiple times to enable WIPS to take countermeasures against multiple devices.
# Enable WIPS to take countermeasures against the device with MAC address 2a11-1fa1-141f.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure mac-address 2a11-1fa1-141f
Use countermeasure misassociation-client to enable WIPS to take countermeasures against misassociated clients.
Use undo countermeasure misassociation-client to restore the default.
WIPS does not take countermeasures against misassociated clients.
# Enable WIPS to take countermeasures against misassociated clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure misassociation-client
Use countermeasure misconfigured-ap to enable WIPS to take countermeasures against misconfigured APs.
Use undo countermeasure misconfigured-ap to restore the default.
WIPS does not take countermeasures against misconfigured APs.
# Enable WIPS to take countermeasures against misconfigured APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure misconfigured-ap
Use countermeasure packet-sending-interval to specify the interval at which sensors send countermeasure packets.
Use undo countermeasure packet-sending-interval to restore the default.
countermeasure packet-sending-interval interval
The interval at which sensors send countermeasure packets is 30 milliseconds.
interval: Specifies the interval at which sensors send countermeasure packets. The value range is 1 to 100 milliseconds.
Configure this command to enable a sensor to send countermeasure packets in a channel if it has detected rogue devices in the channel. The sensor sends countermeasure packets in the channel only within scanning periods, and you can specify the interval at which sensors send countermeasure packets. For more information about channel scanning, see channel scanning configuration in Radio Resources Management Configuration Guide.
# Configure sensors to send countermeasure packets every 10 milliseconds.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure packet-sending-interval 10
Use countermeasure policy to create a countermeasure policy and enter its view, or enter the view of an existing countermeasure policy.
Use undo countermeasure policy to remove a countermeasure policy.
undo countermeasure policy policy-name
No countermeasure policies exist.
WIPS view
# Create countermeasure policy home and enter its view.
[Sysname] wips
Use countermeasure potential-authorized-ap to enable WIPS to take countermeasures against potential-authorized APs.
Use undo countermeasure potential-authorized-ap to restore the default.
WIPS does not take countermeasures against potential-authorized APs.
# Enable WIPS to take countermeasures against potential-authorized APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure potential-authorized-ap
Use countermeasure potential-external-ap to enable WIPS to take countermeasures against potential-external APs.
Use undo countermeasure potential-external-ap to restore the default.
WIPS does not take countermeasures against potential-external APs.
# Enable WIPS to take countermeasures against potential-external APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure potential-external-ap
Use countermeasure potential-rogue-ap to enable WIPS to take countermeasures against potential-rogue APs.
Use undo countermeasure potential-rogue-ap to restore the default.
WIPS does not take countermeasures against potential-rogue APs.
# Enable WIPS to take countermeasures against potential-rogue APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure potential-rogue-ap
Use countermeasure rogue-ap to enable WIPS to take countermeasures against rogue APs.
Use undo countermeasure rogue-ap to restore the default.
WIPS does not take countermeasures against rogue APs.
# Enable WIPS to take countermeasures against rogue APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure rogue-ap
Use countermeasure unauthorized-client to enable WIPS to take countermeasures against unauthorized clients.
Use undo countermeasure unauthorized-client to restore the default.
WIPS does not take countermeasures against unauthorized clients.
# Enable WIPS to take countermeasures against unauthorized clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure unauthorized-client
Use countermeasure uncategorized-ap to enable WIPS to take countermeasures against uncategorized APs.
Use undo countermeasure uncategorized-ap to restore the default.
WIPS does not take countermeasures against uncategorized APs.
# Enable WIPS to take countermeasures against uncategorized APs.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure uncategorized-ap
Use countermeasure uncategorized-client to enable WIPS to take countermeasures against uncategorized clients.
Use undo countermeasure uncategorized-client to restore the default.
WIPS does not take countermeasures against uncategorized clients.
# Enable WIPS to take countermeasures against uncategorized clients.
[Sysname] wips
[Sysname-wips-cms-home] countermeasure uncategorized-client
Use deauthentication-broadcast to configure broadcast deauthentication attack detection.
Use undo deauthentication-broadcast to disable broadcast deauthentication attack detection.
deauthentication-broadcast [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Broadcast deauthentication attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for broadcast deauthentication frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a broadcast deauthentication attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a broadcast deauthentication attack within the quiet time.
threshold threshold-value: Specifies the number of broadcast deauthentication frames that triggers a broadcast deauthentication attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable broadcast deauthentication attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] deauthentication-broadcast interval 100 threshold 100 quiet 360
deauth-spoofing
Use deauth-spoofing to configure spoof deauthentication frame detection.
Use undo deauth-spoofing to disable spoof deauthentication frame detection.
deauth-spoofing [ quiet quiet ]
Spoof deauthentication frame detection is disabled.
quiet quiet: Specifies the quiet time after WIPS triggers an alarm upon a spoof deauthentication frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects spoof deauthentication frames within the quiet time.
# Enable spoof deauthentication frame detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] deauth-spoofing quiet 100
Use detect dissociate-client enable to enable WIPS to detect unassociated clients.
Use undo detect dissociate-client enable to disable WIPS from detecting unassociated clients.
WIPS does not detect unassociated clients.
# Enable WIPS to detect unassociated clients.
[Sysname] wips
[Sysname-wips-dtc-home] detect dissociate-client enable
detect policy
Use detect policy to create an attack detection policy and enter its view, or enter the view of an existing attack detection policy.
Use undo detect policy to remove an attack detection policy.
undo detect policy policy-name
No attack detection policies exist.
WIPS view
policy-name: Specifies an attack detection policy name, a case-sensitive string of 1 to 63 characters.
# Create attack detection policy home and enter its view.
[Sysname] wips
detect signature
Use detect signature to enable signature-based attack detection.
Use undo detect signature to disable signature-based attack detection.
detect signature [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo detect
Signature-based attack detection is enabled.
interval interval-value: Specifies the statistics collection interval for packets that match a signature. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an attack within the quiet time.
threshold threshold-value: Specifies the number of packets matching a signature that triggers an user-attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable WIPS to detect packets that match a signature, and set the interval-value, threshold-value, and quiet-value arguments to 60, 100, and 360, respectively.
[Sysname] wips
[Sysname-wips] signature policy home
[Sysname-wips-sig-home] detect signature interval 60 threshold 100 quiet 360
Use disassociation-broadcast to configure broadcast disassociation attack detection.
Use undo disassociation-broadcast to disable broadcast disassociation attack detection.
disassociation-broadcast [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Broadcast disassociation attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for broadcast disassociation frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a broadcast disassociation attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a broadcast disassociation attack within the quiet time.
threshold threshold-value: Specifies the number of broadcast disassociation frames that triggers a broadcast disassociation attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable broadcast disassociation attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] disassociation-broadcast interval 100 threshold 100 quiet 360
discovered-ap
Use discovered-ap to configure an AP classification rule to match APs by number of sensors that detect the APs.
Use undo discovered-ap to restore the default.
discovered-ap value1 [ to value2 ]
undo discovered-ap
An AP classification rule does not match APs by number of sensors that detect the APs.
value1 to value2: Specifies a value range for the number of sensors that detect an AP. The value 1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 1 to 128 for both the value1 and value2 arguments, and value2 must be greater than value1.
# Configure AP classification rule 1 to match APs that are detected by 10 to 128 sensors.
[Sysname] wips
[Sysname-wips-cls-rule-1] discovered-ap 10 to 128
display wips sensor
Use display wips sensor to display information about all sensors.
display wips sensor
# Display information about all sensors.
<Sysname> display wips sensor
Total number of sensors: 1
Sensor ID    Sensor name                VSD name               Radio ID   Status
3            ap1                        aaa                    1          Active
VSD name
Name of the VSD to which the AP belongs.
Radio ID
ID of the radio enabled with WIPS.
Status
Status of the sensor:
·     Active—The sensor is enabled with WIPS.
·     Inactive—The sensor is not enabled with WIPS.
Use display wips statistics to display WLAN attack detection statistics collected from sensors.
display wips statistics [ receive | virtual-security-domain vsd-name ]
receive: Displays attack detection statistics information for all VSDs.
virtual-security-domain vsd-name: Displays attack detection statistics information for the specified VSD.
# Display attack detection statistics information for all VSDs.
<Sysname> display wips statistics receive
Information from sensor 1
 Information about attack statistics:
   Detected association-request flood messages: 0
   Detected authentication flood messages: 0
   Detected beacon flood messages: 0
   Detected block-ack flood messages: 0
   Detected cts flood messages: 0
   Detected deauthentication flood messages: 0
   Detected disassociation flood messages: 0
   Detected eapol-start flood messages: 0
   Detected null-data flood messages: 0
   Detected probe-request flood messages: 0
   Detected reassociation-request flood messages: 0
   Detected rts flood messages: 0
   Detected eapol-logoff flood messages: 0
   Detected eap-failure flood messages: 0
   Detected eap-success flood messages: 0
   Detected duplicated-ie messages: 0
   Detected fata-jack messages: 0
   Detected illegal-ibss-ess messages: 0
   Detected invalid-address-combination messages: 0
   Detected invalid-assoc-req messages: 0
   Detected invalid-auth messages: 0
   Detected invalid-deauth-code messages: 0
   Detected invalid-disassoc-code messages: 0
   Detected invalid-ht-ie messages: 0
   Detected invalid-ie-length messages: 0
   Detected invalid-pkt-length messages: 0
   Detected large-duration messages: 0
   Detected null-probe-resp messages: 0
   Detected overflow-eapol-key messages: 0
   Detected overflow-ssid messages: 0
   Detected redundant-ie messages: 0
   Detected AP spoof AP messages: 0
   Detected AP spoof client messages: 0
   Detected AP spoof ad-hoc messages: 0
   Detected ad-hoc spoof AP messages: 0
   Detected client spoof AP messages: 0
   Detected weak IV messages: 0
   Detected excess AP messages: 0
   Detected excess client messages: 0
   Detected signature rule messages: 0
   Detected 40MHZ messages: 0
   Detected power save messages: 0
   Detected omerta messages: 0
   Detected windows bridge messages: 0
   Detected soft AP messages: 0
   Detected broadcast disassoc messages: 0
   Detected broadcast deauth messages: 0
   Detected AP impersonate messages: 0
   Detected HT greenfield messages: 0
   Detected association table overflow messages: 0
   Detected wireless bridge messages: 0
   Detected AP flood messages: 0
Information from sensor n
Information collected from sensor n, where n represents the ID of the sensor.
Number of detected messages for association request flood attacks.
Number of detected messages for authentication request flood attacks.
Number of detected messages for beacon flood attacks.
Number of detected messages for Block Ack flood attacks.
Number of detected messages for CTS flood attacks.
Number of detected messages for deauthentication flood attacks.
Number of detected messages for disassociation flood attacks.
Number of detected messages for EAPOL-start flood attacks.
Number of detected messages for null data flood attacks.
Number of detected messages for probe request flood attacks.
Number of detected messages for reassociation request flood attacks.
Number of detected messages for RTS flood attacks.
Number of detected messages for EAPOL-logoff flood attacks.
Number of detected messages for EAP-failure flood attacks.
Number of detected messages for EAP-success flood attacks.
Number of detected messages for malformed packets with duplicated IE.
Number of detected messages for FATA-Jack malformed packets.
Number of detected messages for malformed packets with abnormal IBSS and ESS setting.
Number of detected messages for malformed packets with invalid source address.
Number of detected messages for malformed association request frames.
Number of detected messages for malformed authentication request frames.
Number of detected messages for malformed packets with invalid deauthentication code.
Number of detected messages for malformed packets with invalid disassociation code.
Number of detected messages for malformed packets with malformed HT IE.
Number of detected messages for malformed packets with invalid IE length.
Number of detected messages for malformed packets with invalid packet length.
Number of detected messages for malformed packets with oversized duration.
Number of detected messages for malformed probe response frames.
Number of detected messages for malformed packets with oversized EAPOL key.
Number of detected messages for malformed packets with oversized SSID.
Number of detected messages for malformed packets with redundant IE.
Number of detected messages for AP spoofing (AP spoofs AP) attacks.
Number of detected messages for client spoofing (AP spoofs client) attacks.
Number of detected messages for Ad hoc spoofing (AP spoofs Ad hoc) attacks.
Number of detected messages for AP spoofing (Ad hoc spoofs AP) attacks.
Number of detected messages for AP spoofing (client spoofs AP) attacks.
Number of detected messages for weak IVs.
Number of detected messages for AP entry attacks.
Number of detected messages for client entry attacks.
Number of detected messages for clients disabled with the 40 MHz bandwidth mode.
Number of detected messages for power saving attacks.
Number of detected messages for Omerta attacks.
Number of detected messages for Windows bridge.
Number of detected messages for soft APs.
Number of detected messages for broadcast disassociation attacks.
Number of detected messages for broadcast deauthentication attacks.
Number of detected messages for AP impersonation attacks.
Number of detected messages in HT greenfield mode.
Number of detected messages for association and reassociation DoS attacks.
Number of messages detected by wireless bridges.
Number of detected messages for AP flood attacks.
Use display wips virtual-security-domain countermeasure record to display information about countermeasures that WIPS has taken against rogue devices.
display wips virtual-security-domain vsd-name countermeasure record
vsd-name: Specifies a VSD by its name, a case-sensitive string of 1 to 63 characters.
# Display information about countermeasures that WIPS has taken against rogue devices for VSD office.
<Sysname> display wips virtual-security-domain office countermeasure record
Total 3 times countermeasure, current 3 countermeasure record in virtual-security-domain office
Reason: Att - attack; Ass - associated; Black - blacklist;
        Class - classification; Manu - manual;
MAC address    Type   Reason   Countermeasure AP     Radio ID   Time
1000-0000-00e3 AP     Manu     ap1                    1          2016-05-03/09:32:01
1000-0000-00e4 AP     Manu     ap2                    1          2016-05-03/09:32:11
2000-0000-f282 Client Black    ap3                    1          2016-05-03/09:31:56
Total number times countermeasure, current number countermeasure record in virtual-security-domain number
Number of successful countermeasures. This field can display up to 1024 countermeasure records.
MAC Address
MAC address of the wireless device against which WIPS has taken countermeasures.
Type of the wireless device: AP or Client.
Reason
Reason why WIPS takes countermeasures against the wireless device:
·     Att—WIPS takes countermeasures against the device because it is an attacker.
·     Ass—WIPS takes countermeasures against the device because WIPS has taken countermeasures against its associated AP.
·     Black—After WIPS takes countermeasures against the client, the client is added to the blacklist when it associates with an AP.
·     Class—WIPS takes countermeasures against the device based on its device type.
·     Manu—WIPS takes countermeasures against the device based on its MAC address.
Countermeasure AP
Name of the sensor that takes countermeasures against the wireless device.
Radio ID
Radio ID of the sensor that takes countermeasures against the wireless device.
Time
Time when the AC informs the sensor of taking countermeasures against the wireless device.
Use display wips virtual-security-domain device to display information about wireless devices detected in a VSD.
display wips virtual-security-domain vsd-name device [ ap [ ad-hoc | authorized | external | mesh | misconfigured | potential-authorized | potential-external | potential-rogue | rogue | uncategorized ] | client [ [ dissociative-client ] | [ authorized | misassociation | unauthorized | uncategorized ] ] | mac-address mac-address ] [ verbose ]
device: Specifies wireless devices.
ap: Specifies APs.
ad-hoc: Specifies APs operating in Ad hoc mode.
authorized: Specifies authorized APs.
external: Specifies external APs.
mesh: Specifies MPs.
misconfigured: Specifies misconfigured APs.
potential-authorized: Specifies potential-authorized APs.
potential-rogue: Specifies potential-rogue APs.
potential-external: Specifies potential-external APs.
rogue: Specifies rogue APs.
uncategorized: Specifies uncategorized APs.
client: Specifies clients.
dissociative-client: Specifies unassociated clients.
authorized: Specifies authorized clients.
misassociation: Specifies misassociated clients.
unauthorized: Specifies unauthorized clients.
uncategorized: Specifies uncategorized clients.
mac-address mac-address: Specifies a wireless device by its MAC address in the H-H-H format.
verbose: Displays detailed device information.
# Display information about wireless devices detected in VSD office.
<Sysname> display wips virtual-security-domain office device
Total 3 detected devices in virtual-security-domain office
Class: Auth - authorization; Ext - external; Mis - mistake;
       Unauth - unauthorized; Uncate - uncategorized;
       (A) - associate; (C) - config; (P) - potential;
       Ad-hoc; Mesh
MAC address    Type   Class    Duration    Sensors Channel Status
1000-0000-0000 AP     Ext(P)   00h 10m 46s 1       11      Active
1000-0000-0001 AP     Ext(P)   00h 10m 46s 1       6       Active
1000-0000-0002 AP     Ext(P)   00h 10m 46s 1       1       Active
Wireless device type: AP, Client, or Mesh.
Class
Category of the wireless device.
Duration
Duration since the wireless device entered the current state.
Sensors
Number of sensors that have detected the wireless device.
Channel
Channel on which the wireless device was most recently detected.
Status
Status of the AP or client:
·     Active—The AP or client is active.
·     Inactive—The AP or client is inactive.
# Display detailed information about wireless devices detected in VSD a.
<Sysname> display wips virtual-security-domain a device verbose
Total 2 detected devices in virtual-security-domain a
 AP: 1000-0000-0000
   Mesh Neighbor: None
   Classification: Mis(C)
   Severity level: 0
   Classify way: Auto
   Status: Active
   Status duration: 00h 27m 57s
   Vendor: Not found
   SSID: service
   Radio type: 802.11g
   Countermeasuring: No
   Security: None
   Encryption method: None
   Authentication method: None
   Broadcast SSID: Yes
   QoS supported: No
   Ad-hoc: No
   Beacon interval: 100 TU
   Up duration: 00h 27m 57s
Channel band-width supported: 20MHZ
   Hotspot AP: No
   Soft AP: No
   Honeypot AP: No
   Total number of reported sensors: 1
     Sensor 1:
       Sensor ID: 3
       Sensor name: 1
       Radio ID: 1
       RSSI: 15
       Channel: 149
       First reported time: 2014-06-03/09:05:51
       Last reported time: 2014-06-03/09:05:51
   Total number of associated clients: 1
     01: 2000-0000-0000
Client: 2000-0000-0000
  Last reported associated AP: 1000-0000-0000
  Classification: Uncate
  Severity level: 0
  Classify way: Auto
  Dissociative status: No
  Status: Active
  Status duration: 00h 00m 02s
  Vendor: Not found
  Radio type: 802.11a
  40MHz intolerance: No
  Man in the middle: No
     Sensor 1:
       Sensor ID: 2
       Sensor name: 1
       Radio ID: 1
       RSSI: 50
       Channel: 149
       First reported time: 2014-06-03/14:52:56
       Last reported time: 2014-06-03/14:52:56
       Reported associated AP: 1000-0000-0000
Table 5 Command output
AP
MAC address of the AP.
Mesh Neighbor
MAC address of the mesh AP's neighbor.
Client
MAC address of the client.
MAC address of the associated AP that the client most recently reports.
Classification
Category of the AP or client:
·     AP category:
¡     ad_hoc.
¡     authorized.
¡     rogue.
¡     misconfigured.
¡     external.
¡     potential-authorized.
¡     potential-rogue.
¡     potential-external.
¡     uncategorized.
·     Client category:
¡     authorized.
¡     unauthorized.
¡     misassociated.
¡     uncategorized.
Severity level
Severity level of the device.
Classify way
AP or client classification method:
·     Manual—Manual classification.
·     Invalid OUI—Added to the invalid OUI list.
·     Block List—Added to the prohibited device list.
·     Associated—APs that are connected to the AC.
·     Trust List—Added to the permitted device list.
·     User Define—User-defined classification.
·     Auto—Automatic classification.
Dissociative status
Whether the client is an unassociated client.
Status
Status duration
Vendor
OUI of the device. This field displays the device OUI if the OUI matches an imported OUI. This field displays Not found if no OUI is configured for the device or the OUI does not match any imported OUIs.
SSID
SSID of the wireless service provided by the AP.
Radio Type
Radio mode of the wireless device.
40MHz intolerance
Whether the client supports 40 MHz bandwidth mode.
Countermeasuring
Whether WIPS is taking countermeasures against the wireless device:
·     No.
·     Yes.
Man in the middle
Whether an MITM attack is detected.
Security
Security method:
·     None.
·     WEP.
·     WPA.
·     WPA2.
·     WAPI.
Encryption method
Data encryption method:
·     TKIP.
·     CCMP.
·     WEP.
·     WAPI-SMS4.
·     None.
·     None.
·     PSK.
·     802.1X.
·     Others—Authentication methods except for PSK authentication and 802.1X authentication.
Broadcast SSID
Whether the AP broadcasts the SSID. This field displays nothing if the AP does not broadcast the SSID.
QoS supported
Whether the wireless device supports QoS.
Ad-hoc
Whether the wireless device is in Ad hoc mode.
Beacon interval
Beacon interval in TUs. One TU is equal to 1024 microseconds.
Supported channel bandwidth mode:
·     20/40/80MHZ.
·     20/40MHZ.
·     20MHZ.
Hotspot AP
Whether the AP is a hotspot attack AP.
Soft AP
Whether the AP is a soft AP.
Honeypot AP
Whether the AP is a honeypot AP.
Sensor n
Sensor that detected the wireless device. n represents the ID assigned by the system.
Channel
Channel on which the sensor most recently detected the wireless device.
First reported time
Time when the sensor first detected the wireless device.
Last reported time
Time when the sensor most recently detected the wireless device.
n: H-H-H
MAC address of the client associated with the AP. n represents the number assigned by the system.
MAC address of the associated AP that the sensor reports.
reset wips virtual-security-domain device
Use display wlan nat-detect to display information about clients with NAT configured.
display wlan nat-detect [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays information about all detected NAT-configured clients.
# Display information about all detected NAT-configured clients.
<Sysname> display wlan nat-detect
Total 1 detected clients with NAT configured
MAC address    Last report         First report         Duration
0a98-2044-0000 2017-08-24/11:05:23 2017-08-24/10:05:23  01h 15m 00s
Table 6 Command output
Total number detected clients with NAT configured
Number of detected NAT-configured clients.
MAC address
MAC address of the detected client.
Last report
Time when the client was most recently detected.
First report
Time when the client was detected for the first time.
Duration
Duration since the client is configured with NAT.
Use embedded-oui-classify enable to categorize devices based on the built-in OUIs in the WIPS OUI library.
Use undo embedded-oui-classify enable to restore the default.
The built-in OUIs are not used for device categorization.
Device category view
# Enable device categorization based on the built-in OUIs in the WIPS OUI library for device categorization policy home.
[Sysname] wips
[Sysname-wips-cls-home] embedded-oui-classify enable
export oui
Use export oui to export all OUIs in the OUI library to an OUI configuration file.
export oui file-name
WIPS view
file-name: Specifies a configuration file by its name, a case-insensitive string of 1 to 255 characters. It cannot contain back slashes (\), slashes (/), colons (:), asterisks (*), question marks (?), quotation marks ("), left angle brackets (<), right angle brackets (>), or vertical bars (|).
This command exports all OUIs including embedded OUIs and imported OUIs.
The OUIs are exported in the following format:
000FE2     (base 16)        New H3C Technologies Co., Ltd..
# Export all OUIs in the OUI library to configuration file OUIInfo.
[Sysname] wips
[Sysname-wips] export oui OUIInfo
import oui
flood association-request
Use flood association-request to configure association request flood attack detection.
Use undo flood association-request to disable association request flood attack detection.
flood association-request [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Association request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for association request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an association request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an association request flood attack within the quiet time.
threshold threshold-value: Specifies the number of association request frames that triggers an association request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable association request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood association-request interval 100 threshold 100 quiet 360
flood authentication
Use flood authentication to configure authentication request flood attack detection.
Use undo flood authentication to disable authentication request flood attack detection.
flood authentication [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Authentication request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for authentication request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an authentication request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an authentication request flood attack within the quiet time.
threshold threshold-value: Specifies the number of authentication request frames that triggers an authentication request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable authentication request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood authentication interval 100 threshold 100 quiet 360
flood beacon
Use flood beacon to configure beacon flood attack detection.
Use undo flood beacon to disable beacon flood attack detection.
flood beacon [ interval interval-value | quiet quiet-value | threshold threshold-value] *
undo flood beacon
Beacon flood attack detection is disabled.
Attack detection policy view
interval interval-value: Specifies the statistics collection interval for beacon frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a beacon flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a beacon flood attack within the quiet time.
threshold threshold-value: Specifies the number of beacon frames that triggers a beacon flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable beacon flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] flood beacon interval 100 threshold 100 quiet 360
flood block-ack
Use flood block-ack to configure Block Ack flood attack detection.
Use undo flood block-ack to disable Block Ack flood attack detection.
flood block-ack [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Block Ack flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for Block Ack frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a Block Ack flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a Block Ack flood attack within the quiet time.
threshold threshold-value: Specifies the number of Block Ack frames that triggers a Block Ack flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable Block Ack flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood block-ack interval 100 threshold 100 quiet 360
flood cts
Use flood cts to configure CTS flood attack detection.
Use undo flood cts to disable CTS flood attack detection.
flood cts [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo flood cts
CTS flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for CTS frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a CTS flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a CTS flood attack within the quiet time.
threshold threshold-value: Specifies the number of CTS frames that triggers a CTS flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable CTS flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood cts interval 100 threshold 100 quiet 360
flood deauthentication
Use flood deauthentication to configure deauthentication flood attack detection.
Use undo flood deauthentication to disable deauthentication flood attack detection.
flood deauthentication [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Deauthentication flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for deauthentication frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a deauthentication flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a deauthentication flood attack within the quiet time.
threshold threshold-value: Specifies the number of deauthentication frames that triggers a deauthentication flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable deauthentication flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood deauthentication interval 100 threshold 100 quiet 360
flood disassociation
Use flood disassociation to configure disassociation flood attack detection.
Use undo flood disassociation to disable disassociation flood attack detection.
flood disassociation [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Disassociation flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for disassociation frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a disassociation flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a disassociation flood attack within the quiet time.
threshold threshold-value: Specifies the number of disassociation frames that triggers a disassociation flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable disassociation flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood disassociation interval 100 threshold 100 quiet 360
flood eap-failure
Use flood eap-failure to configure EAP-failure flood attack detection.
Use undo flood eap-failure to disable EAP-failure flood attack detection.
flood eap-failure [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAP-failure flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAP-failure frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAP-failure flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAP-failure flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAP-failure frames that triggers an EAP-failure flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAP-failure flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eap-failure interval 100 threshold 100 quiet 360
flood eapol-logoff
Use flood eapol-logoff to configure EAPOL-logoff flood attack detection.
Use undo flood eapol-logoff to disable EAPOL-logoff flood attack detection.
flood eapol-logoff [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAPOL-logoff flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAPOL-logoff frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAPOL-logoff flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAPOL-logoff flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAPOL-logoff frames that triggers an EAPOL-logoff flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAPOL-logoff flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eapol-logoff interval 100 threshold 100 quiet 360
flood eapol-start
Use flood eapol-start to configure EAPOL-start flood attack detection.
Use undo flood eapol-start to disable EAPOL-start flood attack detection.
flood eapol-start [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAPOL-start flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAPOL-start frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAPOL-start flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAPOL-start flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAPOL-start frames that triggers an EAPOL-start flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAPOL-start flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eapol-start interval 100 threshold 100 quiet 360
flood eap-success
Use flood eap-success to configure EAP-success flood attack detection.
Use undo flood eap-success to disable EAP-success flood attack detection.
flood eap-success [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
EAP-success flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for EAP-success frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an EAP-success flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an EAP-success flood attack within the quiet time.
threshold threshold-value: Specifies the number of EAP-success frames that triggers an EAP-success flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable EAP-success flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100, 360, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood eap-success interval 100 threshold 100 quiet 360
flood null-data
Use flood null-data to configure null data flood attack detection.
Use undo flood null-data to disable null data flood attack detection.
flood null-data [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Null data flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for null data frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a null data flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a null data flood attack within the quiet time.
threshold threshold-value: Specifies the number of null data frames that triggers a null data flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable null data flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood null-data interval 100 threshold 100 quiet 360
flood probe-request
Use flood probe-request to configure probe request flood attack detection.
Use undo flood probe-request to disable probe request flood attack detection.
flood probe-request [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Probe request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for probe request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a probe request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a probe request flood attack within the quiet time.
threshold threshold-value: Specifies the number of probe request frames that triggers a probe request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable probe request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood probe-request interval 100 threshold 100 quiet 360
flood reassociation-request
Use flood reassociation-request to configure reassociation request flood attack detection.
Use undo flood reassociation-request to disable reassociation request flood attack detection.
flood reassociation-request [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
Reassociation request flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for reassociation request frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a reassociation request flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a reassociation request flood attack within the quiet time.
threshold threshold-value: Specifies the number of reassociation request frames that triggers a reassociation request flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable reassociation request flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood reassociation-request interval 100 threshold 100 quiet 360
flood rts
Use flood rts to configure RTS flood attack detection.
Use undo flood rts to disable RTS flood attack detection.
flood rts [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo flood rts
RTS flood attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for RTS frames. The value range for the interval-value argument is 1 to 3600 seconds and the default statistics collection interval is 60 seconds.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an RTS flood attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an RTS flood attack within the quiet time.
threshold threshold-value: Specifies the number of RTS frames that triggers an RTS flood attack alarm. The value range for the threshold-value argument is 1 to 100000 and the default value is 50.
# Enable RTS flood attack detection and set the interval-value, quiet-value, and threshold-value arguments to 100 seconds, 360 seconds, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] flood rts interval 100 threshold 100 quiet 360
frame-type
Use frame-type to configure a subsignature to match frame types.
Use undo frame-type to restore the default.
frame-type { control | data | management [ frame-subtype { association-request | association-response | authentication | beacon | deauthentication | disassociation | probe-request } ] }
undo frame-type
No subsignature is configured to match frame types.
Signature view
control: Matches control frames.
data: Matches data frames.
management: Matches management frames.
frame-subtype: Specifies a frame subtype.
association-request: Matches association request frames.
association-response: Matches association response frames.
authentication: Matches authentication frames.
beacon: Matches beacon frames.
deauthentication: Matches deauthentication frames.
disassociation: Matches disassociation frames.
probe-request: Matches probe request frames.
# Configure a subsignature to match data frames for signature 1.
[Sysname] wips
[Sysname-wips] signature rule 1
[wips-sig-rule-1] frame-type data
match all (signature rule view)
mac-address
pattern
seq-number
ssid (signature rule view)
ssid-length
honeypot-ap
Use honeypot-ap to configure honeypot AP detection.
Use undo honeypot-ap to disable honeypot AP detection.
honeypot-ap [ similarity similarity-value | quiet quiet-value ] *
undo honeypot-ap
Honeypot AP detection is disabled.
similarity similarity-value: Specifies the similarity threshold that triggers a honeypot AP alarm, in the range of 70 to 100 in percentage. The default value is 80%. An AP is determined as a honeypot AP if the similarity between the SSID of the AP and the SSID of a legitimate AP reaches the threshold.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a honeypot AP. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a honeypot AP within the quiet time.
# Enable honeypot AP detection, and set the similarity threshold and quiet time to 90% and 10 seconds, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] honeypot-ap similarity 90 quiet 10
hotspot-attack
Use hotspot-attack to configure hotspot attack detection.
Use undo hotspot-attack to disable hotspot attack detection.
hotspot-attack [ quiet quiet-value ]
undo hotspot-attack
Hotspot attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a hotspot attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a hotspot attack within the quiet time.
# Enable hotspot attack detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] hotspot-attack quiet 100
import hotspot
hotspot ssid
Use hotspot ssid to specify an SSID as a hotspot SSID.
Use undo hotspot ssid to remove one or all specified hotspot SSIDs.
hotspot ssid ssid-name
undo hotspot ssid { ssid-name | all }
No SSIDs are specified as hotspot SSIDs, and the device only has built-in hotspot SSIDs.
WIPS view
ssid-name: Specifies an SSID by its name, a case-sensitive string of 1 to 32 characters.
all: Specifies all SSIDs.
By default, the device has built-in hotspot SSIDs. You cannot delete the built-in hotspot SSIDs. To specify an SSID as a hotspot SSID, you can take either of the following actions:
·     Edit the SSID settings in the configuration file and then execute the import hotspot command to import the modified configuration file to the device. You can use this method to specify multiple SSIDs as hotspot SSIDs.
·     Execute the hotspot ssid command to specify an SSID as a hotspot SSID.
With hotspot SSIDs specified and hotspot attack detection enabled, the device can detect all devices broadcasting the hotspot SSIDs in the environment and mark the unlicensed devices as hotspot APs. To ensure the WLAN security, you can take countermeasures against the hotspot APs.
# Specify SSID cmcc as a hotspot SSID.
[Sysname] wips
[Sysname-wips] hotspot ssid cmcc
import hotspot
ht-40mhz-intolerance
Use ht-40mhz-intolerance to configure detection on clients with the 40 MHz bandwidth mode disabled.
Use undo ht-40mhz-intolerance to disable detection on clients with the 40 MHz bandwidth mode disabled.
ht-40mhz-intolerance [ quiet quiet-value ]
Detection on clients with the 40 MHz bandwidth mode disabled is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a client with the 40 MHz bandwidth mode disabled. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a client with the 40 MHz bandwidth mode disabled within the quiet time.
# Enable detection on clients with the 40 MHz bandwidth mode disabled and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ht-40mhz-intolerance quiet 100
ht-greenfield
Use ht-greenfield to configure HT-greenfield AP detection.
Use undo ht-greenfield to disable HT-greenfield AP detection.
ht-greenfield [ quiet quiet-value ]
undo ht-greenfield
HT-greenfield AP detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting an HT-greenfield AP. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an HT-greenfield AP within the quiet time.
# Enable HT-greenfield AP detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] ht-greenfield quiet 100
ignorelist
Use ignorelist to add a MAC address to the alarm-ignored device list.
Use undo ignorelist to remove a specific or all MAC addresses from the alarm-ignored device list.
ignorelist mac-address mac-address
undo ignorelist mac-address { mac-address | all }
No MAC address is added to the alarm-ignored device list.
WIPS view
mac-address: Specifies a MAC address in the H-H-H format.
all: Specifies all MAC addresses in the alarm-ignored device list.
For wireless devices in the alarm-ignored device list, WIPS does not generate any alarms.
# Add MAC address 2a11-1fa1-1311 to the alarm-ignored device list.
[Sysname] wips
[Sysname-wips] ignorelist mac-address 2a11-1fa1-1311
import hotspot
Use import hotspot to import hotspots from a configuration file.
Use undo import hotspot to remove the configuration.
import hotspot file-name
undo import hotspot
No hotspots are imported.
WIPS view
You can import hotspots from only one configuration file.
# Import hotspots from configuration file hotspot_cfg.
[Sysname] wips
[Sysname-wips] import hotspot hotspot_cfg
hotspot-attack
import oui
Use import oui to import OUIs from a configuration file.
Use undo import oui to restore the default.
import oui file-name
undo import oui
No OUIs are imported.
WIPS view
oui: Specifies a configuration file by its name, a case-insensitive string of 1 to 255 characters. It cannot contain back slashes (\), slashes (/), colons (:), asterisks (*), question marks (?), quotation marks ("), left angle brackets (<), right angle brackets (>), or vertical bars (|).
You can download the configuration file from the IEEE website.
You can import OUIs from only one configuration file.
# Import OUIs from configuration file oui_import_cfg.
[Sysname] wips
[Sysname-wips] import oui oui_import_cfg
export oui
reset wips embedded-oui
invalid-oui-classify illegal
Use invalid-oui-classify illegal to configure WIPS to classify devices with invalid OUIs as rogue devices.
Use undo invalid-oui-classify to restore the default.
WIPS does not classify devices with invalid OUIs as rogue devices.
Classification policy view
# Configure WIPS to classify devices with invalid OUIs as rogue devices.
[Sysname] wips
[Sysname-wips] classification policy home
[Sysname-wips-cls-home] invalid-oui-classify illegal
import oui
mac-address
Use mac-address to configure a subsignature to match frames by MAC address.
Use undo mac-address to restore the default.
mac-address { bssid | destination | source } mac-address
undo mac-address
No subsignature is configured to match frames by MAC address.
Signature view
bssid: Matches a BSSID.
destination: Matches a destination MAC address.
source: Matches a source MAC address.
# Configure a subsignature to match frames with source MAC address 000f-e201-0101 for signature 1.
[Sysname] wips
[Sysname-wips-sig-rule-1] mac-address source 000f-e201-0101
frame-type
pattern
seq-number
ssid-length
malformed duplicated-ie
Use malformed duplicated-ie to enable duplicated IE detection.
Use undo malformed duplicated-ie to disable duplicated IE detection.
malformed duplicated-ie [ quiet quiet-value ]
Duplicated IE detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a duplicated IE. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a duplicated IE within the quiet time.
This feature is applicable to all management frames. WIPS determines that a packet is malformed if the packet has an duplicated IE. This feature does not take effect on frames with vendor-defined IEs.
# Enable duplicated IE detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed duplicated-ie quiet 360
malformed fata-jack
Use malformed fata-jack to enable FATA-Jack detection.
Use undo malformed fata-jack to disable FATA-Jack detection.
malformed fata-jack [ quiet quiet-value ]
FATA-Jack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a FATA-Jack malformed packet. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a FATA-Jack malformed packet within the quiet time.
This feature is applicable to authentication frames. WIPS determines that an authentication frame is malformed if the value of the authentication algorithm number is 2.
# Enable FATA-Jack detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed fata-jack quiet 360
malformed illegal-ibss-ess
Use malformed illegal-ibss-ess to enable abnormal IBSS or ESS setting detection.
Use undo malformed illegal-ibss-ess to disable abnormal IBSS or ESS setting detection.
malformed illegal-ibss-ess [ quiet quiet-value ]
Abnormal IBSS or ESS setting detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an abnormal IBSS and ESS setting. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an abnormal IBSS and ESS setting within the quiet time.
This feature is applicable to beacon frames and probe response frames. WIPS determines that a frame is malformed if both the IBSS and ESS are set to 1 in the frame.
# Enable abnormal IBSS or ESS setting detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed illegal-ibss-ess quiet 360
malformed invalid-address-combination
Use malformed invalid-address-combination to enable invalid source address detection.
Use undo malformed invalid-address-combination to disable invalid source address detection.
malformed invalid-address-combination [ quiet quiet-value ]
Invalid source address detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid source address. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid source address within the quiet time.
This feature is applicable to all management frames. WIPS determines that a frame is malformed when the following conditions are met:
·     The TO DS of the frame is 1, indicating that the frame is sent to the AP by a client.
·     The source MAC address of the frame is a multicast or broadcast address.
# Enable invalid source address detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-address-combination quiet 360
malformed invalid-assoc-req
Use malformed invalid-assoc-req to enable malformed association request frame detection.
Use undo malformed invalid-assoc-req to disable malformed association request frame detection.
malformed invalid-assoc-req [ quiet quiet-value ]
Malformed association request frame detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed association request frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed association request frame within the quiet time.
This feature is applicable to association request frames. WIPS determines that a frame is malformed if the SSID length in the frame is 0.
# Enable malformed association request frame detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-assoc-req quiet 360
malformed invalid-auth
Use malformed invalid-auth to enable malformed authentication request frame detection.
Use undo malformed invalid-auth to disable malformed authentication request frame detection.
malformed invalid-auth [ quiet quiet-value ]
Malformed authentication request frame detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed authentication request frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed authentication request frame within the quiet time.
This feature is applicable to authentication request frames. WIPS determines that a frame is malformed when the following conditions are met:
·     The authentication algorithm number does not conform to the 802.11 protocol and is larger than 3.
·     The authentication transaction sequence number, indicating the authentication process between the client and the AP, is 1 and the status code is not 0.
·     The authentication transaction sequence number is larger than 4.
# Enable malformed authentication request frame detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-auth quiet 360
malformed invalid-deauth-code
Use malformed invalid-deauth-code to enable invalid deauthentication code detection.
Use undo malformed invalid-deauth-code to disable invalid deauthentication code detection.
malformed invalid-deauth-code [ quiet quiet-value ]
Invalid deauthentication code detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid deauthentication code. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid deauthentication code within the quiet time.
This feature is applicable to deauthentication frames. WIPS determines that a frame is malformed if the reason code in the frame is 0 or in the range of 67 to 65535.
# Enable invalid deauthentication code detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-deauth-code quiet 360
malformed invalid-disassoc-code
Use malformed invalid-disassoc-code to enable invalid disassociation code detection.
Use undo malformed invalid-disassoc-code to disable invalid disassociation code detection.
malformed invalid-disassoc-code [ quiet quiet-value ]
Invalid disassociation code detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid disassociation code. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid disassociation code within the quiet time.
This feature is applicable to disassociation frames. WIPS determines that a frame is malformed if the reason code in the frame is 0 or in the range of 67 to 65535.
# Enable invalid disassociation code detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-disassoc-code quiet 360
malformed invalid-ht-ie
Use malformed invalid-ht-ie to enable malformed HT IE detection.
Use undo malformed invalid-ht-ie to disable malformed HT IE detection.
malformed invalid-ht-ie [ quiet quiet-value ]
Malformed HT IE detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed HT IE. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed HT IE within the quiet time.
This feature is applicable to beacon, probe response, association response, and reassociation response frames. WIPS determines that a frame is malformed when the following conditions are met:
·     The SM power save value of the HT capabilities IE is 2.
·     The secondary channel offset value of the HT operation IE is 2.
# Enable malformed HT IE detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-ht-ie quiet 360
malformed invalid-ie-length
Use malformed invalid-ie-length to enable invalid IE length detection.
Use undo malformed invalid-ie-length to disable invalid IE length detection.
malformed invalid-ie-length [ quiet quiet-value ]
Invalid IE length detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid IE length. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid IE length within the quiet time.
This feature is applicable to all management frames. WIPS determines that a frame is malformed if the length of an IE in the frame does not conform to the 802.11 protocol.
# Enable invalid IE length detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-ie-length quiet 360
malformed invalid-pkt-length
Use malformed invalid-pkt-length to enable invalid packet length detection.
Use undo malformed invalid-pkt-length to disable invalid packet length detection.
malformed invalid-pkt-length [ quiet quiet-value ]
Invalid packet length detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an invalid packet length. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an invalid packet length within the quiet time.
This feature is applicable to all management frames. WIPS determines that a frame is malformed if the remaining length of the IE is not zero after the packet payload is resolved.
# Enable invalid packet length detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed invalid-pkt-length quiet 360
malformed large-duration
Use malformed large-duration to enable oversized duration detection.
Use undo malformed large-duration to disable oversized duration detection.
malformed large-duration [ quiet quiet-value | threshold value ]
Oversized duration detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an oversized duration. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an oversized duration within the quiet time.
threshold value: Specifies the duration size that triggers WIPS to determine an oversized duration and trigger an alarm. The value range for the value argument is 1 to 32767 and the default value is 5000.
This feature is applicable to unicast management frames, unicast data frames, RTS, CTS, and ACK frames. WIPS determines that a frame is malformed if the duration value in the frame is larger than the specified threshold.
# Enable oversized duration detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed large-duration quiet 360
malformed null-probe-resp
Use malformed null-probe-resp to enable malformed probe response frame detection.
Use undo malformed null-probe-resp to disable malformed probe response frame detection.
malformed null-probe-resp [ quiet quiet-value ]
Malformed probe response frame detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a malformed probe response frame. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a malformed probe response frame within the quiet time.
This feature is applicable to probe response frames. WIPS determines that a frame is malformed if the frame is not a mesh frame and its SSID length is 0.
# Enable malformed probe response frame detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed null-probe-resp quiet 360
malformed overflow-eapol-key
Use malformed overflow-eapol-key to enable oversized EAPOL key detection.
Use undo malformed overflow-eapol-key to disable oversized EAPOL key detection.
malformed overflow-eapol-key [ quiet quiet-value ]
Oversized EAPOL key detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an oversized EAPOL key. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an oversized EAPOL key within the quiet time.
This feature is applicable to EAPOL-Key frames. WIPS determines that a frame is malformed if the TO DS is 1 and the key length is larger than 0 in the frame. A malicious EAPOL-Key frame might result in DOS attacks.
# Enable oversized EAPOL key detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed overflow-eapol-key quiet 360
malformed overflow-ssid
Use malformed overflow-ssid to enable oversized SSID detection.
Use undo malformed overflow-ssid to disable oversized SSID detection.
malformed overflow-ssid [ quiet quiet-value ]
Oversized SSID detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an oversized SSID. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an oversized SSID within the quiet time.
This feature is applicable to beacon, probe request, probe response, and association request frames. WIPS determines that a frame is malformed if the SSID length in the frame is larger than 32, which does not conform to the 802.11 protocol.
# Enable oversized SSID detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed overflow-ssid quiet 360
malformed redundant-ie
Use malformed redundant-ie to enable redundant IE detection.
Use undo malformed redundant-ie to disable redundant IE detection.
malformed redundant-ie [ quiet quiet-value ]
Redundant IE detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a redundant IE. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a redundant IE within the quiet time.
This feature is applicable to all management frames.  WIPS determines that a frame is malformed if an IE in the frame is neither a necessary IE to the frame nor a reserved IE.
# Enable redundant IE detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] malformed redundant-ie quiet 360
man-in-the-middle
Use man-in-the-middle to configure man-in-the-middle (MITM) attack detection.
Use undo man-in-the-middle to disable MITM attack detection.
man-in-the-middle [ quiet quiet-value ]
MITM attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an MITM attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an MITM attack within the quiet time.
WIPS can detect MITM attacks only when you enable both honeypot AP detection and MITM attack detection.
# Enable MITM attack detection.
[Sysname] wips
[Sysname-wips-dtc-home] man-in-the-middle
manual-classify mac-address
Use manual-classify mac-address to classify APs by MAC address.
Use undo manual-classify mac-address to restore the default.
manual-classify mac-address mac-address { authorized-ap | external-ap | misconfigured-ap | rogue-ap }
undo manual-classify mac-address { mac-address | all }
APs are not classified by MAC address.
mac-address: Specifies an AP by its MAC address, in the H-H-H format.
authorized-ap: Specifies the AP as an authorized AP.
external-ap: Specifies the AP as an external AP.
misconfigured-ap: Specifies the AP as a misconfigured AP.
rogue-ap: Specifies the AP as a rogue AP.
all: Specifies all APs.
# Classify the AP whose MAC address is 000f-00e2-0001 as an authorized AP.
[Sysname] wips
[Sysname-wips-cls-home] manual-classify mac-address 000f-00e2-0001 authorized-ap
match all (AP classification rule view)
Use match all to configure the AP classification rule criteria to be in logical AND relationship.
Use undo match all to restore the default.
match all
undo match all
The AP classification rule criteria are in logical OR relationship. An AP matches an AP classification rule if it matches any of the criteria of the AP classification rule.
# Configure the criteria of AP classification rule 1 to be in logical AND relationship.
[Sysname] wips
[Sysname-wips] ap-classification rule 1
[Sysname-wips-cls-rule-1] match all
match all (signature view)
Use match all to configure the subsignatures to be in logical AND relationship.
match all
undo match all
The subsignatures are in logical OR relationship. A packet matches a signature if it matches any of the subsignatures of the signature.
Signature view
# Configure the subsignatures of signature 1 to be in logical AND relationship.
[Sysname] wips
[wips-sig-rule-1] match all
frame-type
mac-address
pattern
seq-number
ssid-length
omerta
Use omerta to configure Omerta attack detection.
Use undo omerta to disable Omerta attack detection.
omerta [ quiet quiet-value ]
undo omerta
Omerta attack detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon an Omerta attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an Omerta attack within the quiet time.
# Enable Omerta attack detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] omerta quiet 100
oui
Use oui to configure an AP classification rule to match APs by OUI information.
Use undo oui to restore the default.
oui oui-info
undo oui
An AP classification rule does not match APs by OUI information.
oui-info: Specifies the OUI information in the XXXXXX format, a case-insensitive hexadecimal string.
# Configure AP classification rule 1 to match APs with OUI 000fe4.
[Sysname] wips
[Sysname-wips-cls-rule-1] oui 000fe4
pattern
Use pattern to configure a subsignature to match frames by specified bits.
Use undo pattern to restore the default.
pattern pattern-number offset offset-value mask mask value1 [ to value2 ] [ from-payload ]
undo pattern { pattern-number | all }
No subsignature is configured to match frames by specified bits.
Signature view
pattern-number: Specifies a number for a subsignature that matches the specified bits of a frame, in the range of 0 to 7.
offset offset-value: Specifies the offset from the specified bit to the reference bit. The value range for the offset-value argument is 0 to 2346 bits. The reference bit can be the first bit of the frame head (default) or the frame payload.
mask mask: Specifies a two-byte mask that is used for the AND operation with the specified bits. The mask is in hexadecimal format and the value range for the mask is 0 to ffff.
value1 [ to value2 ]: Specifies a value range for the specified bits. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 65535 for both the value1 and value2 arguments, and value2 cannot be smaller than value1.
from-payload: Specifies the first bit of the frame payload as the reference bit. If you do not specify this keyword, the first bit of the frame head is the reference bit.
# Configure a subsignature to match the second and third bits from the frame head of a frame. If the values of the second and third bytes of a frame are within the range of 0x0015 to 0x0020, the frame matches the subsignature.
[Sysname] wips
[Sysname-wips-sig-rule-1] pattern 1 offset 8 mask ffff 15 to 20
frame-type
mac-address
seq-number
ssid-length
permit-channel
Use permit-channel to add one or multiple channels to the permitted channel list.
Use undo permit-channel to remove the specified or all channels from the permitted channel list.
permit-channel channel-id-list
undo permit-channel { channel-id-list | all }
No channels are added to the permitted channel list.
channel-id-list: Specifies a space-separated list of up to 10 permitted channel items. Each item specifies a channel number or a range of channel numbers in the form of value1 to value2. The value range for channel numbers is 1 to 224. The value for the value2 argument must be equal to or greater than the value for the value1 argument.
all: Specifies all permitted channels.
To prevent WIPS from taking all channels as prohibited channels, use this command to configure a permitted channel list before you configure prohibited channel detection.
# Add channel 1 to the permitted channel list.
[Sysname] wips
[Sysname-wips-dtc-home] permit-channel 1
prohibited-channel
power-save
Use power-save to configure power saving attack detection.
Use undo power-save to disable power saving attack detection.
power-save [ interval interval-value | minoffpacket packet-value | onoffpercent percent-value | quiet quiet-value ] *
undo power-save
Power saving attack detection is disabled.
interval interval-value: Specifies the statistics collection interval for power save frames. The value range for the interval-value argument is 1 to 3600 seconds, and the default value is 10 seconds.
minoffpacket packet-value: Specifies the threshold for the number of power save off frames that triggers power save attack analysis. If the number of off frames from a client reaches the threshold, WIPS analyzes the power save frames to determine whether a power save attack occurs. The value range for the argument is 10 to 150, and the default is 50.
onoffpercent percent-value: Specifies the threshold for the ratio between the power save on frames and off frames from a client. WIPS triggers an alarm for a power save attack when the threshold is reached. The value range for this argument is 0 to 100, and the default is 80.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a power saving attack. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a power saving attack within the quiet time.
# Enable power saving attack detection, and set the interval-value, packet-value, percent-value, and quiet-value arguments to 20, 20, 90, and 100, respectively.
[Sysname] wips
[Sysname-wips-dtc-home] power-save interval 20 minoffpacket 20 onoffpercent 90 quiet 100
prohibited-channel
Use prohibited-channel to configure prohibited channel detection.
Use undo prohibited-channel to disable prohibited channel detection.
prohibited-channel [ quiet quiet-value ]
Prohibited channel detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a prohibited channel. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a prohibited channel within the quiet time.
To prevent WIPS from taking all channels as prohibited channels, use the permit-channel command to configure a permitted channel list before you configure prohibited channel detection.
# Enable prohibited channel detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] prohibited-channel quiet 100
permit-channel
random-mac-scan
Use random-mac-scan enable to configure WIPS to not trigger alarms for Apple terminals that use a random MAC address.
Use undo random-mac-scan enable to restore the default.
WIPS triggers alarms for Apple terminals that use a random MAC address.
# Configure WIPS to not trigger alarms for Apple terminals that use a random MAC address.
[Sysname] wips
[Sysname-wips-dtc-home] random-mac-scan enable
report-interval
Use report-interval to set the interval at which APs report information about detected devices.
Use undo report-interval to restore the default.
report-interval interval
APs report information about detected devices every 30000 milliseconds.
interval: Specifies the interval at which APs report information about detected devices, in the range of 1000 to 300000 milliseconds.
# Set the interval at which APs report information about detected devices to 10000 milliseconds.
[Sysname] wips
[Sysname-wips-dtc-home] report-interval 10000
Use reset wips embedded-oui to delete all embedded OUIs in the OUI library.
# Delete all embedded OUIs in the OUI library.
<Sysname> reset wips embedded-oui
export oui
import oui
reset wips statistics
Use reset wips statistics to clear WLAN attack detection statistics collected from all sensors.
# Clear information collected by all sensors.
<Sysname> reset wips statistics
display wips statistics receive
reset wips virtual-security-domain
Use reset wips virtual-security-domain to clear AP or client entries in a VSD.
reset wips virtual-security-domain vsd-name device { ap { all | mac-address mac-address } | client { all | mac-address mac-address } | all }
vsd-name: Specifies a VSD by its name, a case-sensitive string of 1 to 63 characters.
device: Specifies device entries.
ap: Specifies AP entries.
all: Specifies all AP entries.
mac-address mac-address: Specifies an AP by its MAC address.
client: Specifies client entries.
all: Specifies all client entries.
mac-address mac-address: Specifies a client by its MAC address.
all: Specifies all APs and client entries.
# Clear all AP and client entries in VSD aaa.
<Sysname> reset wips virtual-security-domain aaa device all
display wips virtual-security-domain device
reset wips virtual-security-domain countermeasure record
Use reset wips virtual-security-domain countermeasure record to clear information about countermeasures that WIPS has taken against rogue devices.
reset wips virtual-security-domain vsd-name countermeasure record
# Clear information about countermeasures that WIPS has taken against rogue devices for VSD aaa.
<Sysname> reset wips virtual-security-domain aaa countermeasure record
display wips virtual-security-domain countermeasure record
reset wlan nat-detect
Use reset wlan nat-detect to clear information about clients with NAT configured.
# Clear information about clients with NAT configured.
<Sysname> reset wlan nat-detect
display wlan nat-detect
rssi
Use rssi to configure an AP classification rule to match APs by RSSI.
Use undo rssi to restore the default.
rssi value1 [ to value2 ]
undo rssi
An AP classification rule does not match APs by RSSI.
value1 [ to value2 ]: Specifies a value range for the RSSI of APs. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 100 for both the value1 and value2 arguments, and value2 cannot be smaller than value1.
# Configure AP classification rule 1 to match APs with an RSSI of 20 to 40.
[Sysname] wips
[Sysname-wips-cls-rule-1] rssi 20 to 40
rssi-change-threshold
Use rssi-change-threshold to set the RSSI difference threshold for wireless device detection.
Use undo rssi-change-threshold to restore the default.
rssi-change-threshold threshold-value
The RSSI difference threshold for wireless device detection is not configured.
threshold-value: Specifies the RSSI difference threshold for wireless device detection, in the range of 1 to 100.
# Set the RSSI difference threshold to 80 for wireless device detection.
[Sysname] wips
[Sysname-wips-dtc-home] rssi-change-threshold 80
rssi-threshold
Use rssi-threshold to set the RSSI threshold for clients or APs.
Use undo rssi-threshold to restore the default.
rssi-threshold { ap ap-rssi-value | client client-rssi-value }
undo rssi-threshold { ap | client }
No RSSI threshold is set for clients or APs.
ap ap-rssi-value: Specifies the RSSI threshold for APs, in the range of 1 to 100.
client client-rssi-value: Specifies the RSSI threshold for clients, in the range of 1 to 100.
# Set the RSSI threshold for APs to 80.
[Sysname] wips
[Sysname-wips-dtc-home] rssi-threshold ap 80
security
Use security to configure an AP classification rule to match APs by security mode.
Use undo security to restore the default.
security { equal | include } { clear | wep | wpa | wpa2 }
undo security
No AP classification rule is configured to match APs by security mode.
equal: Matches security modes equal to the specified security mode.
include: Matches security modes that include the specified security mode.
clear: Specifies the clear security mode.
wep: Specifies the WEP security mode.
wpa: Specifies the WPA security mode.
wpa2: Specifies the WPA2 security mode.
# Configure AP classification rule 1 to match APs that use the WEP security mode.
[Sysname] wips
[Sysname-wips-cls-rule-1] security equal wep
select sensor all
Use select sensor all to enable all sensors that detect an attacker to take countermeasures against the attacker.
Use undo select sensor to remove the configuration.
select sensor all
undo select sensor
Only the sensor that most recently detects an attacker takes countermeasures against the attacker.
Countermeasure policy view
# Enable all sensors that detect an attacker to take countermeasures against the attacker.
[Sysname] wips
[Sysname-wips] countermeasure policy home
[Sysname-wips-ctm-home] select sensor all
seq-number
Use seq-number to configure a subsignature to match frames by sequence number.
Use undo seq-number to restore the default.
seq-number seq-value1 [ to seq-value2 ]
undo seq-number
No subsignature is configured to match frames by sequence number.
Signature view
seq-value1 [ to seq-value2 ]: Specifies a value range for the sequence number of a frame. The seq-value1 and seq-value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 4095 for both the seq-value1 and seq-value2 arguments, and seq-value2 cannot be smaller than seq-value1.
# Configure a subsignature to match frames with the sequence number 100.
[Sysname] wips
[wips-sig-rule-1] seq-number 100
frame-type
mac-address
pattern
ssid-length
signature policy
Use signature policy to create a signature policy and enter its view, or enter the view of an existing signature policy.
Use undo signature policy to remove a signature policy.
signature policy policy-name
undo signature policy policy-name
No signature policies exist.
WIPS view
policy-name: Specifies a signature policy name, a case-sensitive string of 1 to 63 characters.
# Create a signature policy named home and enter its view.
[Sysname] wips
[Sysname-wips] signature policy home
signature rule
Use signature rule to create a signature and enter its view, or enter the view of an existing signature.
Use undo signature rule to remove a signature.
signature rule rule-id
undo signature rule rule-id
No signatures exist.
WIPS view
rule-id: Specifies a signature ID in the range of 1 to 128.
# Create signature 1 and enter its view.
[Sysname] wips
soft-ap
Use soft-ap to configure soft AP detection.
Use undo soft-ap to disable soft AP detection.
soft-ap [ convert-time time-value ]
undo soft-ap
Soft AP detection is disabled.
Attack detection policy view
convert-time time-value: Specifies the interval at which a soft AP switches between its role of client and AP. The value range for the time-value argument is 5 to 600 seconds, and the default is 10 seconds.
# Enable soft AP detection and set the time-value argument to 100 seconds.
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] soft-ap convert-time 100
ssid (AP classification rule view)
Use ssid to configure an AP classification rule to match APs by SSID.
Use undo ssid to restore the default.
ssid [ case-sensitive ] [ not ] { equal | include } ssid-string
undo ssid
An AP classification rule does not match APs by SSID.
case-sensitive: Concerns the case of the SSID.
not: Matches SSIDs that are not equal to or do not include the specified SSID.
equal: Matches SSIDs equal to the specified SSID.
include: Matches SSIDs that include the specified SSID.
ssid-string: Specifies an SSID, a case-sensitive string of 1 to 32 characters.
# Configure AP classification rule 1 to match APs using SSID abc.
[Sysname] wips
[Sysname-wips-cls-rule-1] ssid equal abc
ssid (signature view)
Use ssid to configure a subsignature to match frames by SSID.
ssid [ case-sensitive ] [ not ] { equal | include } string
undo ssid
No subsignature is configured to match frames by SSID.
Signature view
# Configure a subsignature to match frames with SSID office for signature 1.
[Sysname] wips
[Sysname-wips-sig-rule-1] ssid equal office
frame-type
mac-address
pattern
seq-number
ssid-length
ssid-length
Use ssid-length to configure a subsignature to match frames by SSID length.
Use undo ssid-length to restore the default.
ssid-length length-value1 [ to length-value2 ]
undo ssid-length
No subsignature is configured to match frames by SSID length.
Signature rule
length-value1 [ to length-value2 ]: Specifies the value range for the SSID length. The length-value1 and length-value2 arguments specify the start value and end value for the value range, respectively. The value range is 1 to 32 for both the length-value1 and length-value2 arguments, and length-value2 cannot be smaller than length-value1.
# Configure a subsignature to match frames in which the SSID length is 10.
[Sysname] wips
[Sysname-wips-sig-1] ssid-length 10
frame-type
mac-address
pattern
seq-number
trust mac-address
Use trust mac-address to add the MAC address of an AP or client to the permitted device list.
Use undo trust mac-address to remove one or all MAC addresses from the permitted device list.
trust mac-address mac-address
undo trust mac-address { mac-address | all }
No MAC addresses exist in the permitted device list.
mac-address: Specifies a MAC address.
all: Specifies all MAC addresses.
# Add MAC address 78AC-C0AF-944F to the permitted device list.
[Sysname] wips
[Sysname-wips-cls-home] trust mac-address 78AC-C0AF-944F
trust oui
Use trust oui to add an OUI to the trusted OUI list.
Use undo trust oui to remove one or all OUIs from the trusted OUI list.
trust oui oui
undo trust oui { oui | all }
No OUIs exist in the trusted OUI list.
oui: Specifies an OUI by its name, a case-insensitive string of 6 characters.
all: Specifies all OUIs.
# Add OUIs 000fe4 and 000fe5 to the trusted OUI list.
[Sysname] wips
[Sysname-wips-cls-home] trust oui 000fe4
[Sysname-wips-cls-home] trust oui 000fe5
trust ssid
Use trust ssid to add an SSID to the trusted SSID list.
Use undo trust ssid to remove one or all SSIDs from the trusted SSID list.
trust ssid ssid-name
undo trust ssid { ssid-name | all }
No SSIDs exist in the trusted SSID list.
# Add SSID flood1 to the trusted SSID list.
[Sysname] wips
[Sysname-wips-cls-home] trust ssid flood1
unencrypted-authorized-ap
Use unencrypted-authorized-ap to configure unencrypted authorized AP detection.
Use undo unencrypted-authorized-ap to disable unencrypted authorized AP detection.
unencrypted-authorized-ap [ quiet quiet-value ]
Unencrypted authorized AP detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting an unencrypted authorized AP. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an unencrypted authorized AP within the quiet time.
# Enable unencrypted authorized AP detection and set the quiet time to 10 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] unencrypted-authorized-ap quiet 10
unencrypted-trust-client
Use unencrypted-trust-client to configure unencrypted authorized client detection.
Use undo unencrypted-trust-client to disable unencrypted authorized client detection.
unencrypted-trust-client [ quiet quiet-value ]
Unencrypted authorized client detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting an unencrypted authorized client. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects an unencrypted authorized client within the quiet time.
# Enable unencrypted authorized client detection and set the quiet time to 10 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] unencrypted-trust-client quiet 10
up-duration
Use up-duration to configure an AP classification rule to match APs by running time.
Use undo up-duration to restore the default.
up-duration value1 [ to value2 ]
undo up-duration
An AP classification rule does not match APs by running time.
value1 [ to value2 ]: Specifies the value range for the running time of APs. The value1 and value2 arguments specify the start value and end value for the value range, respectively. The value range is 0 to 2592000 seconds for both the value1 and value2 arguments, and value2 must be greater than value1.
# Configure AP classification rule 1 to match APs with a running time of 2000 to 40000 seconds.
[Sysname] wips
[Sysname-wips-cls-rule-1] up-duration 2000 to 40000
Use virtual-security-domain to create a VSD and enter its view, or enter the view of an existing VSD.
Use undo virtual-security-domain to remove a VSD.
undo virtual-security-domain vsd-name
No VSDs exist.
WIPS view
vsd-name: Specifies a VSD name, a case-sensitive string of 1 to 63 characters.
# Create VSD office and enter its view.
[Sysname] wips
[Sysname-wips] virtual-security-domain office
[Sysname-wips-vsd-office]
weak-iv
Use weak-iv to configure weak IV detection.
Use undo weak-iv to disable weak IV detection.
weak-iv [ quiet quiet-value ]
undo weak-iv
Weak IV detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon a weak IV. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a weak IV within the quiet time.
# Enable weak IV detection.
[Sysname] wips
[Sysname-wips-dtc-home] weak-iv
windows-bridge
Use windows-bridge to configure Windows bridge detection.
Use undo windows-bridge to disable Windows bridge detection.
windows-bridge [ quiet quiet-value ]
undo windows-bridge
Windows bridge detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a Windows bridge. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a Windows bridge within the quiet time.
# Enable Windows bridge detection and set the quiet time to 360 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] windows-bridge quiet 360
wips (radio view)
Use wips enable to enable WIPS.
Use wips disable to disable WIPS.
Use undo wips to restore the default.
wips { disable | enable }
undo wips
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, WIPS is disabled.
Radio view
Make sure the number of spatial streams supported by a radio is larger than the number of spatial streams required by the scanned devices. If you enable green energy management, specify a MIMO mode with lower spatial stream handling capacity, or change the default input power level to low, WIPS will be affected.
# Enable WIPS for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] wips enable
# Enable WIPS for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] wips enable
wips (system view)
Use wips to enter WIPS view.
Use undo wips to clear all configurations in WIPS view.
wips
undo wips
No WIPS view is configured.
# Enter WIPS view.
[Sysname] wips
[Sysname-wips]
Use wips virtual-security-domain to add an AP to a VSD.
Use undo wips virtual-security-domain to remove an AP from the VSD.
In AP view, an AP uses the configuration in AP group view.
In AP group view, an AP group is not added to any VSD.
AP view
AP group view
# Add AP ap1 to VSD office.
[Sysname-wlan-ap-ap1] wips virtual-security-domain office
# Add AP group apgroup1 to VSD office.
[Sysname-wlan-ap-group-apgroup1] wips virtual-security-domain office
wireless-bridge
Use wireless-bridge to configure wireless bridge detection.
Use undo wireless-bridge to disable wireless bridge detection.
wireless-bridge [ quiet quiet-value ]
Wireless bridge detection is disabled.
quiet quiet-value: Specifies the quiet time after WIPS triggers an alarm upon detecting a wireless bridge. The value range for the quiet-value argument is 5 to 604800 seconds and the default quiet time is 600 seconds. WIPS does not trigger an alarm even if it detects a wireless bridge within the quiet time.
# Enable wireless bridge detection and set the quiet time to 100 seconds.
[Sysname] wips
[Sysname-wips-dtc-home] wireless-bridge quiet 100
wlan nat-detect
Use wlan nat-detect enable to enable detection on clients with NAT configured.
Use wlan nat-detect disable to disable detection on clients with NAT configured.
Use undo wlan nat-detect to restore the default.
wlan nat-detect { disable | enable }
In AP group view, detection on clients with NAT configured is disabled.
AP view
AP group view
The device generates an alarm when it detects a client configured with NAT. To view information about detected NAT-configured clients, use the display wlan nat-detect command.
# Enable detection on clients with NAT configured for AP ap1.
[Sysname-wlan-ap-ap1] wlan nat-detect enable
# Enable detection on clients with NAT configured for APs in AP group aaa.
[Sysname] wlan ap-group aaa
[Sysname-wlan-ap-group-aaa] wlan nat-detect enable
wlan nat-detect countermeasure
Use wlan nat-detect countermeasure to enable WIPS to take countermeasures against clients with NAT configured.
Use undo wlan nat-detect countermeasure to disable WIPS from taking countermeasures against clients with NAT configured.
In AP group view, WIPS does not take countermeasures against clients with NAT configured.
AP view
AP group view
WIPS generates an alarm when a client with NAT configured is detected. After you configure this command, the AC adds the detected client with NAT configured to the blacklist to prevent the client from accessing the WLAN.
# Enable AP ap1 to take countermeasures against clients with NAT configured.
[Sysname-wlan-ap-ap1] wlan nat-detect countermeasure
# Enable APs in AP group aaa to take countermeasures against clients with NAT configured.
[Sysname-wlan-ap-group-aaa] wlan nat-detect countermeasure
