- 08-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-IP forwarding basics configuration
- 06-Fast forwarding configuration
- 07-Adjacency table configuration
- 08-IRDP configuration
- 09-IP performance optimization configuration
- 10-UDP helper configuration
- 11-IPv6 basics configuration
- 12-IPv6 neighbor discovery configuration
- 13-DHCPv6 configuration
- 14-IPv6 fast forwarding configuration
- 15-IPv6 transition technologies configuration
- 16-WAAS configuration
- 17-HTTP redirect configuration
- 18-Web caching configuration
| 08-IRDP configuration | 85.42 KB |
Restrictions and guidelines: IRDP configuration
Specifying the preference of advertised IP addresses
Setting the lifetime of advertised IP addresses
Setting the advertising intervals
Specifying the multicast address as the destination address for RAs
Configuring IRDP
About IRDP
ICMP Router Discovery Protocol (IRDP), an extension of the ICMP, is independent of any routing protocol. It allows hosts to discover the IP addresses of neighboring routers that can act as default gateways to reach devices on other IP networks.
IRDP enables hosts to track dynamic changes in router availability. It does not require you to configure the default gateways on hosts or configure hosts to listen to routing protocols to obtain IP addresses of routers.
IRDP operation
IRDP uses the following types of ICMP messages:
· Router advertisement (RA)—Sent by a router to advertise IP addresses (including the primary and secondary IP addresses) and preference.
· Router solicitation (RS)—Sent by a host to request the IP addresses of routers on the subnet.
An interface with IRDP enabled periodically broadcasts or multicasts an RA message to advertise its IP addresses and their preferences. A receiving host adds the IP addresses to its routing table, and selects the IP address with the highest preference as the default gateway.
When a host attached to the subnet starts up, the host multicasts an RS message to request immediate advertisements. If the host does not receive any advertisements, it retransmits the RS several times. If the host does not discover the IP addresses of neighboring routers because of network problems, the host can still discover them from periodic RAs.
IRDP allows hosts to discover neighboring routers, but it does not suggest the best route to a destination. If a host sends a packet to a router that is not the best next hop, the host will receive an ICMP redirect message from the router.
Protocols and standards
RFC 1256: ICMP Router Discovery Messages
IRDP tasks at a glance
To configure IRDP, perform the following tasks:
2. (Optional.) Specifying the preference of advertised IP addresses
3. (Optional.) Setting the lifetime of advertised IP addresses
4. (Optional.) Setting the advertising intervals
5. (Optional.) Specifying the multicast address as the destination address for RAs
6. (Optional.) Specifying a proxy-advertised IP address
· IRDP takes effect on any Layer 3 interface (except the loopback interface) if the interface has an IP address.
· After IRDP is enabled on an interface, the IRDP configurations take effect, and the device sends RA messages out of the interface.
Enabling IRDP
1. Enter system view.
2. Enter interface view.
3. Enable IRDP on the interface.
ip irdp
By default, IRDP is disabled on an interface.
Every IP address advertised in RAs has a preference value. A larger preference value represents a higher preference. The IP address with the highest preference is selected as the default gateway address.
You can specify the preference for IP addresses to be advertised on a router interface.
An address with the minimum preference value (-2147483648) will not be used as a default gateway address.
3. Specify the preference of advertised primary and secondary IP addresses on the interface.
ip irdp preference preference-value
The default preference is 0.
The preference applies to all advertised primary and secondary IP addresses on the interface.
An RA contains a lifetime field that specifies the lifetime of advertised IP addresses. If the host does not receive a new RA for an IP address within the address lifetime, the host removes the route entry.
All the IP addresses advertised by an interface, including proxy-advertised IP addresses and the interface IP address, have the same lifetime.
3. Set the lifetime of advertised IP addresses.
ip irdp lifetime lifetime-value
The default lifetime is 1800 seconds.
The lifetime cannot be shorter than the maximum advertising interval.
A router interface with IRDP enabled sends out RAs randomly between the minimum and maximum advertising intervals. This mechanism prevents the local link from being overloaded by a large number of RAs sent simultaneously from routers.
As a best practice, shorten the advertising interval on a link that suffers high packet loss rates.
3. Set the maximum and minimum advertising intervals.
ip irdp interval max-interval [ min-interval ]
By default, the maximum interval is 600 seconds, and the minimum interval is 3/4 of the maximum interval.
An RA uses either of the following destination IP addresses:
· Broadcast address 255.255.255.255.
· Multicast address 224.0.0.1, which identifies all hosts on the local link.
By default, the destination IP address of an RA is the broadcast address. If all listening hosts in a local area network support IP multicast, specify 224.0.0.1 as the destination IP address.
3. Specify the multicast address 224.0.0.1 as the destination IP address of RAs.
ip irdp multicast
By default, RAs use the broadcast address 255.255.255.255 as the destination IP address.
By default, an interface advertises its primary and secondary IP addresses. You can specify IP addresses of other gateways for an interface to proxy-advertise.
3. Specify a proxy-advertised IP address and its preference.
ip irdp address ip-address preference-value
By default, no proxy-advertised IP address is specified.
You can repeat this command to specify a maximum of four proxy-advertised IP addresses on an interface.
IRDP configuration examples
Example: Configuring IRDP
As shown in Figure 1, Host A and Host B that run the Linux support IRDP, and they are in the internal network. Router A and Router B act as the egress routers and connect to external networks 192.168.1.0/24 and 192.168.2.0/24, respectively.
Configure Router A as the default gateway for the hosts. Make sure Router A has routes to reach both External network 1 and External network 2, so that packets to these external networks can be correctly routed.
1. Configure Router A:
# Configure a route for Router A to reach External network 2. (Details not shown.)
# Specify an IP address for Ten-GigabitEthernet 0/0/6.
[RouterA] interface ten-gigabitethernet 0/0/6
[RouterA-Ten-GigabitEthernet0/0/6] ip address 10.154.5.1 24
# Enable IRDP on Ten-GigabitEthernet 0/0/6.
[RouterA-Ten-GigabitEthernet0/0/6] ip irdp
# Specify preference 1000 for advertised IP addresses on Ten-GigabitEthernet 0/0/6.
[RouterA-Ten-GigabitEthernet0/0/6] ip irdp preference 1000
# Specify the multicast address 224.0.0.1 as the destination IP address for RAs sent by Ten-GigabitEthernet 0/0/6.
[RouterA-Ten-GigabitEthernet0/0/6] ip irdp multicast
# Specify the IP address 192.168.1.0 and preference 400 for Ten-GigabitEthernet 0/0/6 to proxy-advertise.
[RouterA-Ten-GigabitEthernet0/0/6] ip irdp address 192.168.1.0 400
2. Configure Router B:
<RouterB> system-view
[RouterB] interface ten-gigabitethernet 0/0/6
[RouterB-Ten-GigabitEthernet0/0/6] ip address 10.154.5.2 24
[RouterB-Ten-GigabitEthernet0/0/6] ip irdp
# Specify preference 500 for advertised IP addresses on Ten-GigabitEthernet 0/0/6.
[RouterB-Ten-GigabitEthernet0/0/6] ip irdp preference 500
[RouterB-Ten-GigabitEthernet0/0/6] ip irdp multicast
# Specify the IP address 192.168.2.0 and preference 400 for Ten-GigabitEthernet 0/0/6 to proxy-advertise.
[RouterB-Ten-GigabitEthernet0/0/6] ip irdp address 192.168.2.0 400
# Display the routing table for Host A.
[HostA@localhost ~]$ netstat -rne
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
10.154.5.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
0.0.0.0 10.154.5.1 0.0.0.0 UG 0 0 0 eth1
The output shows that the default route on Host A points to IP address 10.154.5.1, and Host A has routes to 192.168.1.0/24 and 192.168.2.0/24.
# Display the routing table for Host B.
[HostB@localhost ~]$ netstat -rne
The output shows that the default route on Host B points to IP address 10.154.5.1, and Host B has routes to 192.168.1.0/24 and 192.168.2.0/24.
