01-gRPC commands | 144.02 KB |
destination-group (subscription view)
destination-group (telemetry view)
sensor-group (subscription view)
gRPC commands
Generic gRPC commands
display grpc
Use display grpc to display gRPC information.
display grpc [ verbose ]
verbose: Display detailed gPRC information. If you do not specify this keyword, the command displays brief gPRC information.
# Display brief gRPC information.
<Sysname> display grpc
gRPC status : Enabled
PKI domain : grpc
Current-time: 2020-05-20T04:12:48.119
------------Dial-in mode information------------
gRPC server port: 50052
Session idle-timeout: 10 minutes
Session count: 1
ID IP Address:Port UserName
1 192.1.11.254:53030 test
------------Dial-out mode information-----------
Sensor group count: 10
Sensor path count: 70
Destination group count: 5
Destination count: 4
Subscription count: 1
Connection ID: 1
IP address:Port: 192.1.1.254:11111
Encoding: JSON
Status: Connected
gRPC status |
Status of the gRPC service: · Enabled—The gRPC service is enabled. · Disabled—The gRPC service is disabled. |
PKI domain |
PKI domain for secure gRPC connections to collectors. This field is not displayed if no PKI domain has been specified by using the grpc pki domain command. |
Current-time |
Current system time. |
Dial-in mode information |
Information about gRPC in dail-in mode. |
gRPC server port |
Port number for the gRPC service. |
Session idle-timeout |
gRPC session idle timeout timer, in minutes. |
Session count |
Number of gRPC sessions. |
ID |
ID of a gRPC session. |
IP Address:Port |
IP address and port number of the gRPC client. |
UserName |
Username of the gRPC user. |
Dial-out mode information |
Information about gRPC in dial-out mode. |
Sensor group count |
Number of sensor groups. |
Sensor path count |
Number of sensor paths. |
Destination group count |
Number of destination groups. |
Destination count |
Number of collectors. |
Subscription count |
Number of subscriptions. |
Connection ID |
ID of the connection between the device and a collector. |
IP address:Port |
IP address and port number of the collector. |
Encoding |
Encoding format for data packets sent to the controller. In the current software version, only JSON is supported. |
Status |
Status of the channel between the device and the collector: · Init—The channel is being initialized. · Idle—The channel is idle. · Connecting—The channel is being established. · Connected—The channel has been established. · Transient failure—The channel has failed transiently and is attempting to recover. · Shut down—The channel has been closed because of an issue. |
# Display detailed gRPC information.
<Sysname> display grpc verbose
PKI domain : grpc
Current-time: 2020-05-20T04:12:44.346
Session count: 1
Session ID: 1
User name: test
Login time:2020-05-19 16:40:16 Idle time : 3 mins 41 s
Client IP address : 192.1.11.254:53030
Received RPCs : 39 Received erroneous RPCs : 6
Received subscription: 0 Sent notifications: 0
Subscription s
Subscription mode: non-gNMI
DSCP value: 0
Source-address or interface: not-config
Telemetry data model: 2-layer
Encoding: JSON
Protocol: UDP
Sensor group: s
Sampling interval: N/A
Sampling type Effective sampling interval Sensor path
destination-group: wyq
Start-time: 2020-05-20T03:38:05.833
IP:Port: 1.1.1.1:50051
VPN: N/A
Periodic sampling statistics:
Effective count: 272
Sent successfully: 0 Failed: 68
Event-triggered statistics:
Effective count: 0
Sent successfully: 0 Failed: 0
Queued packets/Queue size: 204/1000
Dropped: 0
Last error: Channel(Connecting)
gRPC status |
PKI domain |
PKI domain for securing gRPC connections to collectors. This field is not displayed if no PKI domain has been specified by using the grpc pki domain command. |
Current-time |
Information about gRPC in dial-in mode. |
gRPC server port |
Session count |
Session ID |
User name |
Login time |
Time when the gRPC user logged in to the device. |
Idle time |
Amount of time in which the session idle timeout timer will expire. If the value in this field is 0, gRPC sessions will never time out. |
Client IP address |
Received RPCs |
Number of received gRPC requests. |
Received erroneous RPCs |
Number of received erroneous gRPC requests. |
Received subscription |
Number of received gRPC subscription requests. |
Sent notifications |
Number of gRPC notifications reported to the collector. |
Sensor path count |
Destination count |
Subscription |
Name of the subscription. |
Subscription mode |
Supported subscription modes: · gNMI. · non-gNMI. |
Push mode |
Data push mode for the subscription: · Condition-triggered—The device periodically checks each sensor path in a sensor group and pushes the data from the sensor path to collectors if certain conditions are met. · Periodic and Event-triggered—The device pushes data both periodically and when triggering events occur. |
DSCP value |
DSCP value of packets sent to the collector. |
Source-address or interface |
Source IP address or source interface for packets sent to the collector. This field displays not-config if no source IP address or source interface has been specified. |
Telemetry data model |
Telemetry data model architecture for gRPC. Options: · 2-layer—Two-layer telemetry data model architecture. · 3-layer—Three-layer telemetry data model architecture. |
Encoding |
Encoding format for packets sent to the controller. The current software version supports only JSON for encoding. |
Protocol |
Transport protocol: · GRPC. · UDP. |
Sensor-group |
Name of the sensor group. |
Sampling interval |
Data sampling interval, in seconds. This field displays 0 for event-triggered sampling. |
Sampling type |
Data sampling type: · Event-triggered—Event-triggered sampling. · Periodic—Periodical sampling. |
Sensor-path |
Sensor path. |
Destination-group |
Name of the destination group. |
Start-time |
Time when the gRPC connection established. |
IP address:Port |
IP address and port number of the collector (gRPC server). |
VPN |
VPN instance to which the collector belongs. This field displays N/A if the collector belongs to the public network. |
Periodic sampling statistics |
Statistics for periodic sampling. |
Event-triggered statistics |
Statistics for event-triggered sampling. |
Effective count |
Number of effective samplings. This counter does not count a sampling if it does not collect any data. |
Sent successfully |
Number of sent data packets. |
Failed |
Number of data packets failed to be sent. |
Queued packets/Queue size |
Number of data packets in queue and the size of the queue. |
Dropped |
Number of data packets dropped because the queue is full. |
Last error |
Most recent error: · VPN doesn’t exist—The VPN instance does not exist. · PKI failed—An error exists in the PKI domain. For example, the certificate became invalid. · Channel (reason)—An error occurred on the gRPC channel. Possible reasons: ¡ Init—The channel is being initialized. ¡ Idle—The channel is idle, ¡ Connecting—The channel is being established. ¡ Transient failure—The channel has transiently failed and is attempting to recover. ¡ Shutdown—The channel has been closed because of an issue. This field displays two hyphens (--) if no errors exist. |
grpc data-model
Use grpc data-model to specify the architecture of telemetry data models.
Use undo grpc data-model to restore the default.
grpc data-model { 2-layer | 3-layer }
The device uses the two-layer telemetry data model architecture to push data.
2-layer: Specifies the two-layer telemetry data model architecture.
3-layer: Specifies the three-layer telemetry data model architecture.
This command is available only in gRPC dial-out mode.
If you specify the two-layer telemetry data model, the encoding format for pushed data can only be JSON.
For more information about telemetry data model architectures, see gRPC configuration in Telemetry Configuration Guide.
# Configure the device to use three-layer telemetry data models to push data.
[Sysname] grpc data-model 3-layer
encoding
grpc enable
Use grpc enable to enable the gRPC service.
Use undo grpc enable to disable the gRPC service.
grpc enable
undo grpc enable
You must enable the gRPC service before you can configure the gRPC service.
Disabling the gRPC service deletes all gRPC settings.
# Enable the gRPC service.
<Sysname> system
[Sysname] grpc enable
grpc pki domain
Use grpc pki domain to specify the PKI domain for secure gRPC connections to collectors.
Use undo grpc pki domain to restore the default.
grpc pki domain domain-name
No PKI domain is specified for secure gRPC connections to collectors.
domain-name: Specifies a PKI domain by its name, a case-sensitive string of 1 to 31 characters.
By default, the gRPC connection between the device and a collector does not provide data encryption service or require authentication. After you specify a PKI domain, the device and the collector will use TLS for data encryption and bidirectional certificate-based authentication to improve communication security.
For the device to establish gRPC connections to collectors successfully, make sure the PKI domain already exists and has correct certificate and key settings. For more information about PKI configuration, see Security Configuration Guide.
Executing this command reboots the gRPC service and closes all gRPC connections to collectors. In dial-in mode, the collectors must re-initiate the connections. In dial-out mode, the device will automatically re-initiate the connections.
# Specify the PKI domain for secure gRPC connections to collectors.
[Sysname] grpc pki domain grpc_test
gRPC dial-in mode commands
grpc idle-timeout
Use grpc idle-timeout to set the gRPC session idle timeout timer.
Use undo grpc idle-timeout to restore the default.
grpc idle-timeout minutes
The gRPC session idle timeout timer is 5 minutes.
minutes: Specifies the gRPC session idle timeout timer in minutes, in the range of 0 to 30. To disable gRPC sessions from being timed out, set it to 0.
If no gRPC packet exchanges occur on the session between a gRPC and the server before the idle timeout timer expires, the device closes the session.
# Set the gRPC session idle timeout timer to 6 minutes.
<Sysname> system
[Sysname] grpc idle-timeout 6
grpc log dial-in gnmi
Use grpc log dial-in gnmi to enable gRPC logging for gNMI operations in dial-in mode.
Use undo grpc log dial-in gnmi to disable gRPC logging for gNMI operations in dial-in mode.
grpc log dial-in gnmi { all | { capabilities | get | set | subscribe }* }
undo grpc log dial-in gnmi { all | { capabilities | get | set | subscribe }* }
In dial-in mode, gRPC logging is enabled for gNMI Set operations and disabled for other gNMI operations.
all: Specifies all gNMI operations.
capabilities: Specifies the gNMI Capabilities operations.
get: Specifies the gNMI Get operations.
set: Specifies the gNMI Set operations.
subscribe: Specifies the gNMI Subscribe operations.
To identify gRPC issues, enable gNMI operations logging in dial-in mode.
This command generates gNMI operation logs in dial-in mode and sends them to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable gRPC logging for gNMI Get operations in dial-in mode.
<Sysname> system
[Sysname] grpc log dial-in gnmi get
grpc log dial-in rpc
Use grpc log dial-in rpc to enable gRPC logging for RPC operations in dial-in mode.
Use undo grpc log dial-in rpc to disable gRPC logging for RPC operations in dial-in mode.
grpc log dial-in rpc { all | { cli | get }* }
undo grpc log dial-in rpc { all | { cli | get }* }
In dial-in mode, gRPC logging is disabled for RPC operations.
all: Specifies both RPC CLI and Get operations.
cli: Specifies the RPC CLI operations.
get: Specifies the RPC Get operations.
To identify gRPC issues, enable RPC operations logging in dial-in mode.
This command generates RPC operation logs in dial-in mode and sends them to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Enable gRPC logging for RPC Get operations in dial-in mode.
<Sysname> system
grpc port
Use grpc port to specify the gRPC service port number.
Use undo grpc port to restore the default.
grpc port port-number
undo grpc port
The gRPC service port number is 50051.
port-number: Specifies the gRPC service port number, in the range of 1 to 65535.
Changing the gRPC service port number reboots the gRPC service and terminates all gRPC sessions to the gRPC server. If the new port is not available, the system reboots the gRPC service again to use the old port.
# Set the gRPC service port number to 50052.
<Sysname> system
[Sysname] grpc port 50052
grpc enable
gRPC dial-out mode commands
Use destination-group to specify a destination group for a subscription.
Use undo destination-group to remove a destination group from a subscription.
destination-group group-name
undo destination-group group-name
A subscription does not have a destination group.
Subscription view
group-name: Specifies a destination group by its name, a case-sensitive string of 1 to 31 characters.
A subscription binds sensor groups to destination groups. Then, the device pushes data from the specified sensors to the collectors.
The specified destination group must have been created by using the destination-group command in telemetry view.
You cannot use a destination group in both a gRPC subscription and a gNMI subscription.
A subscription can have a maximum of five destination groups.
# Specify destination group collector1 for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscription A
[Sysname-telemetry-subscription-A] destination-group collector1
Use destination-group to create a destination group and enter its view, or enter the view of an existing destination group.
Use undo destination-group to delete a destination group.
No destination groups exist.
Telemetry view
group-name: Specifies the destination group name, a case-sensitive string of 1 to 31 characters.
As a best practice, configure a maximum of five destination groups. If you configure too many destination groups, system performance might degrade.
To delete a destination group that is already used by a subscription, you must remove the destination group from the subscription first.
# Create a destination group named collector1.
[Sysname] telemetry
[Sysname-telemetry] destination-group collector1
[Sysname-telemetry-destination-group-collector1]
subscription
dscp
Use dscp to set the DSCP value of packets sent to collectors.
Use undo dscp to restore the default.
dscp dscp-value
undo dscp
The DSCP value of packets sent to collectors is 0.
Subscription view
dscp-value: Specifies the DSCP value of packets sent to collectors, in the range of 0 to 63.
A greater DSCP value represents a higher priority.
If you execute this command multiple times in the same view, the most recent configuration takes effect.
# Set the DSCP value of packets sent to collectors to 12 for subscription A.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] dscp 12
encoding
Use encoding to specify the encoding format for pushed data.
Use undo encoding to restore the default.
encoding { gpb | json }
undo encoding
The encoding format for pushed data is JSON.
Subscription view
gpb: Specifies the GPB encoding format. This keyword is available only when the device uses the three-layer telemetry data model architecture to push data.
json: Specifies the JSON encoding format.
This command is not available for gNMI subscriptions.
The device supports JSON encoding for all data available for subscription. However, it does not support GPB encoding for all data. With GPB encoding, the device will not push data that cannot be GPB encoded. When you choose GPB encoding for a subscription, make sure all data in the subscription can be encoded in GPB.
# Specify the three-layer architecture for telemetry data models and use GPB to encode data for subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscrption A
[Sysname-telemetry-subscription-A] encoding gpb
grpc data-model
grpc log dial-out
Use grpc log dial-out to enable gRPC logging in dial-out mode.
Use undo grpc log dial-out to disable gRPC logging in dial-out mode.
grpc log dial-out { all | { event | sample }* }
undo grpc log dial-out { all | { event | sample }* }
In dial-out mode, gRPC logging is disabled.
all: Specifies all data collection types.
event: Specifies event-triggered data collection.
sample: Specifies periodical data collection.
To identify gRPC issues, enable gRPC data collection logging in dial-out mode.
This command generates gRPC data collection logs in dial-out mode and sends them to the information center. With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
gRPC logging in dial-out mode is unavailable for gNMI subscriptions.
# Enable gRPC logging for periodical data collection in dial-out mode.
<Sysname> system
ipv4-address
Use ipv4-address to add an IPv4 collector to a destination group.
Use undo ipv4-address to remove an IPv4 collector from a destination group.
ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv4-address ipv4-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv4 collectors.
Destination group view
ipv4-address: Specifies the IPv4 address of the collector.
port port-number: Specifies the listening port of the collector, in the range of 1 to 65535. The default is 50051.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the collector belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the collector belongs to the public network, do not specify this option.
To add multiple collectors to a destination group, execute this command multiple times.
One collector must have a different address, port, or VPN instance than the other collectors.
The device supports a maximum of five collectors.
To modify the collector configuration for a destination group that is already used by a subscription, you must remove the destination group from the subscription first.
# Add a collector that uses IPv4 address 192.168.21.21 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv4-address 192.168.21.21
subscription
ipv6-address
Use ipv6-address to add an IPv6 collector to a destination group.
Use undo ipv6-address to remove an IPv6 collector from a destination group.
ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ipv6-address ipv6-address [ port port-number ] [ vpn-instance vpn-instance-name ]
A destination group does not have IPv6 collectors.
ipv6-address: Specifies the IPv6 address of the collector. It cannot be an IPv6 link-local address. For more information about IPv6 link-local addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
# Add a collector that uses IPv6 address 1::1 and the default port number to destination group collector1.
[Sysname] telemetry
[Sysname-telemetry-destination-group-collector1] ipv6-address 1::1
subscription
protocol
Use protocol to specify a transport protocol for the device to send packets to collectors.
Use undo protocol to restore the default.
protocol { grpc | udp }
undo protocol
The device uses gRPC as the transport protocol to send packets to collectors.
Subscription view
grpc: Specifies gRPC as the transport protocol. gRPC uses TCP at the transport layer
udp: Specifies UDP as the transport protocol.
For a subscription that has sensor group and destination group bindings, you must first remove all the sensor groups and destination groups from it before you execute this command.
# Specify UDP as the transport protocol for subscription A.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] protocol udp
push-mode
Use push-mode to set the data push mode for a subscription.
Use undo push-mode to restore the default.
push-mode condition-triggered
undo push-mode
The data push mode for a sensor path in a subscription is periodic or event-triggered.
Subscription view
condition-triggered: Specifies the condition-triggered data push mode. In this mode, the device periodically checks each sensor path in a sensor group and pushes the data from the sensor path to collectors if certain conditions are met.
This command is available only for gNMI subscriptions.
As a best practice, use condition-triggered data push mode only if a sensor group has condition-triggered sensor groups.
For information about condition-triggered sensor paths, the sensor path check interval, and data push conditions, contact H3C Support.
Example
# Set the data push mode to condition-triggered for gNMI subscription A.
[Sysname] telemetry
[Sysname-telemetry] subscription A gnmi
[Sysname-telemetry-subscription-A] push-mode condition-triggered
subscription
sensor path
Use sensor path to configure a sensor path.
Use undo sensor path to delete a sensor path.
For gNMI subscriptions:
sensor path path
undo sensor path path
For non-gNMI subscriptions:
sensor path path [ selection-nodes node-list | depth depth ]
sensor path path
No sensor paths exist.
Sensor group view
path: Specifies a data path. For information about the available paths, enter a question mark (?) in the position of this argument.
selection-nodes: Pushes data from nodes in the specified data path. If you do not specify this keyword, the device pushes data from all nodes in the specified data path.
node-list: Specifies a space-separated list of up to 24 nodes by their names. To view available nodes in the sensor path, enter a question mark (?) in the position of this argument. For more information about path nodes, see the Columns sections in the NETCONF XML API references of the related module.
depth depth: Specifies the retrieval level for the sensor path. This option takes effect if the sensor path is a periodic path. The value range for the depth is 1 to 3. The default depth is 1.
· If the depth is set to 1, the device collects data from all columns under the specified path.
· If the depth is set to 2, the device collects data from all columns and subtables under the specified path.
· If the depth is set to 3, the device collects data from all columns, subtables, and subtables under the subtables, under the specified path.
Follow these restrictions and guidelines when you configure a sensor path in a gNMI subscription:
· To push only a subset of data from a sensor path, add filters in [column="value"] format in that sensor path. The column argument represents a column in a multi-instance table, which is case insensitive. The value argument represents the column value, which is case sensitive.
For more information about multi-instance tables, see NETCONF XML API references of related modules.
· If you specify two sensor path nodes that have the same sensor path but different filtering conditions, both of the sensor path nodes take effect.
In a non-gNMI subscription, you can include filters in sensor path ifmgr/statistics to match data you need to push to collectors. The device pushes data from the sensor path to collectors as long as one of the filters has matching data.
· Do not specify both data paths and filters for this sensor path.
· Use the [ifindex="index"] format to specify a filter. The index is a case-insensitive string that represents the type and number or index of an interface.
· The last character for index can be wildcard character (*), for example, you can specify sensor path ifmgr/statistics[ifindex="GigabitEthernet1/0/*"].
· You can specify a maximum of 64 filters in a sensor path.
To configure multiple sensor paths, repeat this command. If you execute this command with the same sensor path specified, the most recent configuration takes effect.
The device supports a maximum of 128 sensor paths.
To modify the sensor path configuration for a sensor group that is already used by a subscription, you must remove the sensor group from the subscription first.
# Configure sensor path ifmgr/devicecapabilities/ for non-gNMI sensor group test.
[Sysname] telemetry
[Sysname-telemetry] sensor-group test
[Sysname-telemetry-sensor-group-test] sensor path ifmgr/devicecapabilities/
subscription
Use sensor-group to specify a sensor group for a subscription.
Use undo sensor-group to remove a sensor group from a subscription.
sensor-group group-name [ sample-interval [ msec ] interval | suppress-time suppress-time ]
undo sensor-group group-name
A subscription does not have a sensor group.
Subscription view
group-name: Specifies a sensor group by its name, a case-sensitive string of 1 to 31 characters.
sample-interval: Specifies that the sensor group collects and pushes data at intervals. If you do not specify this keyword, the sensor group collects and pushes data only when triggered by events.
msec: Specifies the data push interval in milliseconds. To set the data push interval in seconds, do not specify this keyword. This keyword is available only for non-gNMI subscription.
interval: Specifies the data push interval. The value range for this argument differs depending on the unit of interval measurement.
· If you do not specify the msec keyword, the value range is 1 to 86400.
· If you specify the msec keyword, the data push interval must be a multiple of 100 in the range of 100 to 900.
suppress-time suppress-time: Specifies the data push suppression interval in seconds. During the data push suppression interval, the device does not push the data from a sensor path even though conditions are met. The value range for the argument is 1 to 300, and the default is 60.
For the device to correctly push data from sensor paths in a sensor group, make sure the subscription settings for the sensor paths are compliant with Table 3.
Table 3 Compatibility of sensor path types and subscription settings
Sensor path type |
Push mode |
Data push interval |
Data push suppression interval |
Periodical |
Default |
Configured |
Not configured |
Event-triggered |
Default |
Not configured |
Not configured |
Condition-triggered |
Not configured |
Configured |
The specified sensor group must have been created by using the sensor-group command in telemetry view.
For a gNMI subscription, you must specify gNMI sensor groups. For a non-gNMI subscription, you must specify non-gNMI sensor groups.
To change the data collection interval for a subscription for which you have specified a sensor group, you must first remove the sensor group in subscription view.
# Specify sensor group test for subscription A. Set the data collection interval to 10 seconds.
[Sysname] telemetry
[Device-telemetry] subscription A
[Device-telemetry-subscription-A] sensor-group test sample-interval 10
push-mode
sensor path
sensor-group (telemetry view)
Use sensor-group to create a sensor group and enter its view, or enter the view of an existing sensor group.
Use undo sensor-group to delete a sensor group.
sensor-group group-name [ gnmi ]
No sensor groups exist.
Telemetry view
group-name: Specifies the sensor group name, a case-sensitive string of 1 to 31 characters.
gnmi: Specifies a gNMI sensor group. If you do not specify this keyword, this command creates a non-gNMI sensor group.
When you enter the view of an existing gNMI sensor group, you do not need to specify the gnmi keyword.
The device supports a maximum of 32 sensor groups.
To delete a sensor group that is already used by a subscription, you must remove the sensor group from the subscription first.
# Create a non-gNMI sensor group named test.
[Sysname] telemetry
subscription
source-address
Use source-address to specify the source IP address for packets sent to collectors.
Use undo source-address to restore the default.
source-address { ipv4-address | interface interface-type interface-number | ipv6 ipv6-address } [ port port-number ]
undo source-address
The device uses the primary IP address of the output interface for the route to the collectors as the source address.
Subscription view
ipv4-address: Specifies an IPv4 address.
interface interface-type interface-number: Specifies an interface by its type and number. In the current software version, you must specify a loopback interface. The device will use the interface's primary IPv4 address as the source address. If the interface does not have a primary IPv4 address, the device uses the primary IP address of the output interface for the route to the collectors.
ipv6 ipv6-address: Specifies an IPv6 address.
port port-number: Specifies a source port number for subscription packets sent by the device, in the range of 1 to 65535. If you do not specify a source port number, the device uses a port number automatically assigned by the system as the source port number.
Changing the source address causes the device to reconnect to the gRPC server.
# Specify the source IPv4 address of 169.254.1.1 for packets sent to collectors.
[Sysname] telemetry
[Sysname-telemetry-subscription-A] source-address 169.254.1.1
subscription
Use subscription to create a subscription and enter its view, or enter the view of an existing subscription.
Use undo sensor-group to delete a subscription.
subscription subscription-name [ gnmi ]
undo subscription subscription-name
No subscription exists.
Telemetry view
subscription-name: Specifies the subscription name, a case-sensitive string of 1 to 31 characters.
gnmi: Specifies a gNMI subscription. If you do not specify this keyword, this command creates a non-gNMI subscription.
When you enter the view for an existing gNMI subscription, you do not need to specify the gnmi keyword.
The device supports a maximum of 10 subscriptions.
# Configure a non-gNMI subscription named A.
[Sysname] telemetry
telemetry
Use telemetry to enter telemetry view.
telemetry
In telemetry view, you can configure telemetry parameters.
# Enter telemetry view.
[Sysname] telemetry
[Sysname-telemetry]
