- 09-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-Basic BGP commands
- 07-Advanced BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-RIR commands
| 01-Basic IP routing commands | 335.86 KB |
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
ipv6 route fast-switchover enable
reset ip routing-table statistics protocol
reset ipv6 routing-table statistics protocol
address-family ipv4
Use address-family ipv4 to create the RIB IPv4 address family and enter its view, or enter the view of the existing RIB IPv4 address family.
Use undo address-family ipv4 to delete the RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family exists.
RIB view
# Create the RIB IPv4 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create the RIB IPv6 address family and enter its view, or enter the view of the existing RIB IPv6 address family.
Use undo address-family ipv6 to delete the RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family exists.
RIB view
# Create the RIB IPv6 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
Use display ip routing-table to display routing table information.
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table [ all-routes ]
all-vpn-instance: Specifies all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing table information for the public network.
all-routes: Displays routing table information for the public network and all VPN instances.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Destinations : 10 Routes : 10
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.0/24 Static 60 0 192.168.47.4 XGE0/0/6
Static 60 0 192.168.47.4 XGE0/0/7
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.40/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Display brief information about active routes in the routing table for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes
VPN instance: public instance
VPN instance: vpn1
1.1.2.0/24 Static 60 0 2.2.1.1 XGE0/0/6
3.3.1.0/24 BGP 255 0 55.1.1.2 XGE0/0/7
# Display information about IPv4 routes for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Destinations : 9 Routes : 9
1.1.3.0/24 Static 60 0 3.3.1.1 XGE0/0/6
Destinations |
Number of destination addresses. |
Routes |
Number of routes. |
Destination/Mask |
Destination address/mask length. |
Proto |
Route type or protocol that installed the route: · Direct—Direct route. · Static—Static route. · RIP—RIP route. · OSPF—OSPF route. · ISIS—IS-IS route. · EIGRP—EIGRP route. · BGP—BGP route. · OpenR—Open Routing (OpenR) route. · LDP—LDP route. · SLSP—Static LSP. · PIM—PIM route. · MSTATIC—Multicast static route. · O_INTRA—OSPF intra-area route. · O_INTER—OSPF inter-area route. · O_ASE1—OSPF Type-1 external route. · O_ASE2—OSPF Type-2 external route. · O_SUM—OSPF summary route. · IS_L1—IS-IS Level-1 route. · IS_L2—IS-IS Level-2 route. · IS_SUM—IS-IS summary route. |
Pre |
Preference of the route. |
Cost |
Cost of the route. |
NextHop |
Next hop address of the route. |
Output interface for packets to be forwarded along the route. |
Summary count |
Number of routes. |
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destinations : 13 Routes : 13
Destination: 0.0.0.0/32
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h34m37s
Cost: 0 Preference: 0
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active NoAdv
TableID: 0x2 OrigAs: 0
NibID: 0x10000000 LastAs: 0
AttrID: 0xffffffff Neighbor: 0.0.0.0
Flags: 0x1000c OrigNextHop: 127.0.0.1
Label: NULL RealNextHop: 127.0.0.1
BkLabel: NULL BkNextHop: N/A
SRLabel: NULL Interface: InLoopBack0
BkSRLabel: NULL BkInterface: N/A
Tunnel ID: Invalid IPInterface: InLoopBack0
BkTunnel ID: Invalid BKIPInterface: N/A
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BKColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: N/A
TrafficIndex: N/A BKTunnelInterface: N/A
Connector: N/A PathID: 0x0
SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: Invalid BkNID: Invalid
BkFlushNID: Invalid StatFlags: 0x0
Exp: N/A
VpnPeerId: N/A Dscp: N/A
SID: N/A OrigLinkID: 0x0
BkSID: N/A RealLinkID: 0x0
CommBlockLen: 0
Destination: 1.1.1.0/24
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 04h20m37s
Cost: 0 Preference: 60
Tag: 0 State: Active Adv
NibID: 0x10000003 LastAs: 0
Flags: 0x1008c OrigNextHop: 192.168.47.4
Label: NULL RealNextHop: 192.168.47.4
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/6
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet0/0/6
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 1.2.3.4/32
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x1 Age: 02h38m34s
Cost: 0 Preference: 255
TableID: 0x2 OrigAs: 200
NibID: 0x16000000 LastAs: 200
AttrID: 0x2 Neighbor: 2.2.3.4
Flags: 0x10060 OrigNextHop: 2.2.3.4
Label: NULL RealNextHop: 2.2.3.4
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/8
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet0/0/8
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
# Display detailed information about all routes in the routing table for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1 Routes : 1
Protocol: Direct
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
VPN instance: vpn2
Protocol: Static
Process ID: 0
OrigTblID: 0x0 OrigVrf: vpn2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destinations |
Routes |
Number of routes. |
Destination |
Protocol |
SubProtID |
ID of the subprotocol for routing. |
Age |
Time for which the route has been in the routing table. |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Local QoS ID. N/A represents an invalid value. |
Tag |
Route tag. |
State |
Route status: · Active—Active unicast route. · Adv—Route that can be advertised. · Inactive—Inactive route. · NoAdv—Route that the router must not advertise. · Vrrp—Routes generated by VRRP. · Nat—Routes generated by NAT. · TunE—Tunnel. · Derived—Derived route. If a route recurses to multiple related routes, all related routes except the first one are derived routes. The number of derived routes is not included in the total number of routes. |
OrigTblID |
Original routing table ID. |
OrigVrf |
Original VPN instance to which the route belongs. This field displays default-vrf if the route is on the public network. |
TableID |
ID of the routing table. |
OrigAs |
Original AS number. |
NibID |
ID of the next hop. |
LastAs |
Last AS number. |
AttrID |
Attribute ID. |
Neighbor |
Address of the neighbor determined by the routing protocol. |
Flags |
Flags of the route. |
OrigNextHop |
Label |
Label. |
RealNextHop |
Real next hop of the route. |
BkLabel |
Backup label. |
BkNexthop |
Backup next hop. |
SRLabel |
Segment routing (SR) label. |
BkSRLabel |
Backup SR label. |
SIDIndex |
SID index value. |
InLabel |
Incoming label of the route. |
Tunnel ID |
Tunnel ID. |
BkTunnel ID |
Backup tunnel ID. If multiple backup tunnels are available, an ellipsis (...) exists in this field. Only the first backup tunnel can take effect. |
BkInterface |
Backup output interface. If multiple backup output interfaces are available, an ellipsis (...) exists in this field. Only the first backup output interface can take effect. |
IPInterface |
IP output interface. |
BkIPInterface |
Backup IP output interface. |
ColorInterface |
This field is not supported in the current software version. Color output interface obtained through SR-MPLS TE policy-based recursion or SRv6 TE policy-based recursion. |
BkColorInterface |
Backup color output interface. |
FtnIndex |
Index of the FTN entry. |
TunnelInterface |
Tunnel output interface. |
TrafficIndex |
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid. |
BkTunnelInterface |
Backup tunnel output interface. |
Connector |
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if the BGP connector attribute is not supported. |
Summary count |
Number of routes. |
PathID |
Path ID. |
SRTunnelID |
SR tunnel ID. |
SID Type |
SID type. If the route does not have an SID, this field displays N/A. |
NID |
Index of the Next Hop Label Forwarding Entry (NHLFE) issued by the routing protocol. |
FlushNID |
Actual NHLFE index issued to the FIB. |
BkNID |
Backup NHLFE index issued by the routing protocol. |
BkFlushNID |
Actual backup NHLFE index issued to the FIB. |
VpnPeerId |
ID of the VPN peer to which the route belongs, in the range of 1 to 134217727. This field displays N/A when the value is invalid. |
Dscp |
DSCP value of the route, in the range of 0 to 63. This field displays N/A when the value is invalid. |
Exp |
MPLS EXP value of the route, which is supported only by BGP. This field displays N/A when the value is invalid. |
SID |
Primary SID. N/A indicates that the attribute is not available. |
BkSID |
Backup SID. N/A indicates that the attribute is not available. |
CommBlockLen |
Common prefix length in the locator. |
OrigLinkID |
Original link ID of the SDWAN TTE connection. |
RealLinkID |
Real link ID of the SDWAN TTE connection. |
display ip routing-table acl
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing information for the public network.
ipv4-acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
When you specify an ACL, follow these restrictions and guidelines:
· If the specified ACL does not exist or does not have any rules, the command displays information about all routes.
· If you specify the vpn-instance keyword for an ACL rule, the ACL rule will not take effect.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24 Direct 0 0 192.168.1.111 XGE0/0/6
192.168.1.0/32 Direct 0 0 192.168.1.111 XGE0/0/6
192.168.1.111/32 Direct 0 0 127.0.0.1 InLoop0
192.168.1.255/32 Direct 0 0 192.168.1.111 XGE0/0/6
For command output, see Table 1.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
Protocol: Direct
Process ID: 0
SubProtID: 0x1 Age: 04h20m37s
Flags: 0x10080 OrigNextHop: 192.168.1.111
Label: NULL RealNextHop: 192.168.1.111
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.111/32
Protocol: Direct
Process ID: 0
Flags: 0x10004 OrigNextHop: 127.0.0.1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.255/32
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 192.168.1.111
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
For command output, see Table 2.
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the IP address mask in dotted decimal notation.
longer-match: Displays the route entries that meet the matching rules as described in the usage guidelines.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
· display ip routing-table ip-address
¡ The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡ The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
· display ip routing-table ip-address mask
¡ The system ANDs the entered destination IP address with the entered subnet mask.
¡ The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
· display ip routing-table ip-address longer-match
¡ The system ANDs the entered destination IP address with the subnet mask in the following way:
- If the entered IP address belongs to class A, B, or C, the system ANDs it with the default subnet mask of the corresponding class.
- If the entered IP address is 0.0.0.0, the system ANDs it with the subnet mask 0.0.0.0.
- Except the previous cases, for example, if the entered IP address is a multicast address or loopback address, the system ANDs it with the subnet mask 255.255.255.255.
¡ The system ANDs the destination IP address in each active route entry with the subnet mask of the entered IP address.
If the two operations yield the same result for multiple entries, all the entries are displayed.
· display ip routing-table ip-address mask longer-match
· display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8 Static 60 0 0.0.0.0 NULL0
11.0.0.0/16 Static 60 0 0.0.0.0 NULL0
11.0.0.0/24 Static 60 0 0.0.0.0 NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 with mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the routes to the destination IP address 11.0.0.1 with the default mask length for class A networks.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
3.3.3.0/24 Direct 0 0 3.3.3.1 XGE0/0/7
3.3.3.1/32 Direct 0 0 127.0.0.1 InLoop0
4.4.4.0/24 Direct 0 0 4.4.4.1 XGE0/0/6
4.4.4.1/32 Direct 0 0 127.0.0.1 InLoop0
# Display detailed information about the routes to the destination IP address 1.2.3.4.
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Protocol: Static
Process ID: 0
SubProtID: 0x1 Age: 00h00m37s
NibID: 0x15000000 LastAs: 0
AttrID: 0x0 Neighbor: 0.0.0.0
Flags: 0x10060 OrigNextHop: 192.168.47.2
Label: NULL RealNextHop: 192.168.47.2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24 Direct 0 0 1.1.1.2 XGE0/0/7
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
Flags: 0x1008c OrigNextHop: 1.1.1.2
Label: NULL RealNextHop: 1.1.1.2
SRLabel: NULL Interface: Ten-GigabitEthernet0/0/7
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet0/0/7
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol: Specifies a routing protocol.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24 Direct 0 0 192.168.80.10 XGE0/0/6
192.168.80.0/32 Direct 0 0 192.168.80.10 XGE0/0/6
192.168.80.10/32 Direct 0 0 127.0.0.1 InLoop0
192.168.80.255/32 Direct 0 0 192.168.80.10 XGE0/0/6
Direct Routing table status : <Inactive>
Summary count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8 Static 60 0 2.2.2.2 XGE0/0/6
# Display brief information about OpenR routes.
<Sysname> display ip routing-table protocol openr
Summary count : 1
OpenR Routing table status : <Active>
Summary count : 1
192.11.3.0/24 OpenR 30 0 12.13.3.12 XGE0/0/6
Summary count : 0
# Display detailed information about BGP routes.
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
Destination: 1.1.1.2/32
Process ID: 0
SubProtID: 0x6 Age: 00h03m54s
AttrID: 0x0 Neighbor: 192.168.47.2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
# Display detailed information about OpenR routes.
<Sysname> display ip routing-table protocol openr verbose
Summary count : 1
Destination: 192.11.3.0/24
Protocol: OpenR
Process ID: 0
SubProtID: 0xfe Age: 01h13m48s
Cost: 0 Preference: 30
NibID: 0x19000000 LastAs: 0
Flags: 0x10040 OrigNextHop: 12.13.3.12
Label: NULL RealNextHop: 12.13.3.12
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ip routing-table statistics to display IPv4 route or route prefix statistics.
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes: Specifies the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv4 route statistics for the public network.
prefix: Displays statistics about IPv4 route prefixes. If you do not specify this keyword, the command displays statistics about IPv4 routes.
If you do not specify any parameters, this command displays statistics about IPv4 routes in the public network.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15 Active prefixes: 15
Proto Routes Active Added Deleted
DIRECT 12 12 30 18
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 15 15 35 20
# Display IPv4 route statistics for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11 Active prefixes: 11
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 11 11 13 2
# Display IPv4 route statistics for VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 11 11 13 2
# Display IPv4 route statistics for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIP 0 0 0 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 11 11 13 2
# Display IPv4 route prefix statistics for the public network.
<Sysname> display ip routing-table prefix statistics
Proto Prefixes Active Added Deleted
DIRECT 7 7 7 0
STATIC 0 0 0 0
UNR 0 0 0 0
RIP 1 0 1 0
OSPF 0 0 0 0
IS-IS 0 0 0 0
LISP 0 0 0 0
EIGRP 0 0 0 0
BGP 0 0 0 0
OpenR 0 0 0 0
Total 8 7 8 0
Proto |
Protocol that installed the route. |
Routes |
Number of routes installed by the protocol. |
Prefixes |
Number of IPv4 route prefixes. |
Active |
Number of active routes. |
Added |
Number of routes added to the routing table after the router started up or the routing table was cleared most recently. |
Deleted |
Number of routes marked as deleted, which will be cleared after a period. |
Total |
Total number of routes. |
Use display ip routing-table summary to display brief routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ip routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief routing table information for the public network.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# Display brief routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
Max ECMP |
Maximum number of ECMP routes supported by the system. |
Max Active Route |
Maximum number of supported routes. |
Remain Active Route |
Number of the remaining inactive routes. |
Threshold value xxx |
Alarm threshold of active routes specified by using the routing-table limit command in a VPN instance: · Threshold value of active routes alert—This field is displayed when the alarm threshold is specified by using the routing-table limit number simply-alert command. When the number of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. · Threshold value percentage of max active routes—This field is displayed when the routing-table limit number simply-alert command is not configured or when the alarm threshold is specified by using the routing-table limit number warn-threshold command. The value range for the alarm threshold is 1 to 100 in percentage. When the percentage of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. If the number of active routes reaches the maximum number, no more routes can be added. The percentage of active routes equals the number of active routes divided by the maximum number of active routes supported in a VPN instance, and multiplied by 100. |
display ipv6 rib attribute
Use display ipv6 rib attribute to display route attribute information in the IPv6 RIB.
attribute-id: Specifies a route attribute by its ID, a hexadecimal string in the range of 0 to ffffffff.
# Display route attribute information in the IPv6 RIB.
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
Flag: 0x0
Protocol: BGP4+ instance default
Address family: IPv6
Reference count: 0
Local preference: 0
Ext-communities number: 0
Ext-communities value: N/A
Communities number: 0
Communities value: N/A
AS-path number: 0
AS-path value: N/A
For command output, see Table 8.
Use display ipv6 rib graceful-restart to display IPv6 RIB GR state information.
# Display IPv6 RIB GR state information.
<Sysname> display ipv6 rib graceful-restart
RIB GR state : Phase2-calculation end
RCOM GR state : Flush end
Protocol GR state:
No. Protocol Lifetime FD State Start/End
1 DIRECT6 480 29 End No/No
2 STATIC6 480 32 End No/No
3 ISISV6 480 30 End No/No
4 BGP4+ instance default
480 31 End No/No
5 BGP4+ instance ebcdefg
480 32 End No/No
6 OpenR6 480 83 End No/No
For command output, see Table 9.
display ipv6 rib nib
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
sub-nib nib-id: Specifies a sub-NIB by its ID to display information about its parent NIB.
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
NibID: 0x20000000 Sequence: 0
Type: 0x1 Flushed: Yes
UserKey0: 0x0 VrfNthp: 0
UserKey1: 0x0 Nexthop: ::
UserKey2: 0x0 IFIndex: 0x111
UserKey3: 0x0 LocalAddr: ::
TopoNthp: Invalid
Color: 0 COFlag: 0x0
LinkID: 0x0
SIDIndex: 0x0 SRPName:
OriNexthop: ::
NibID: 0x20000001 Sequence: 1
UserKey1: 0x0 Nexthop: ::1
UserKey2: 0x0 IFIndex: 0x112
UserKey3: 0x0 LocalAddr: ::1
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
RefCnt: 4 FlushRefCnt: 1
Flag: 0x84 Version: 1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::
RelyDepth: 0 RealNexthop: ::
Interface: NULL0 LocalAddr: ::
TunnelCnt: 0 Vrf: default-vrf
TunnelID: N/A Topology:
Weight: 0 Flags: 0x0
SRPolicyNID: 4294967295 SRInterface:
ColorWeight: 0 Locator: N/A
OrigLinkID: 0x0 RealLinkID: 0x0
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: ::1
RelyDepth: 0 RealNexthop: ::1
Interface: InLoop0 LocalAddr: ::1
NibID: 0x26000002 Sequence: 1
UserKey1: 0x0 Nexthop: 122::2
UserKey3: 0x0 LocalAddr: 122::2
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
Instance: abc
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 122::2
RelyDepth: 0 RealNexthop: 122::2
For command output, see Table 10 and Table 11.
display ipv6 route-direct nib
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
RefCnt: 1 FlushRefCnt: 0
Flag: 0x2 Version: 1
1 nexthop(s):
TopoNthp: Invalid
LinkID: 0x0
OriNexthop: ::
1 nexthop(s):
For command output, see Table 12 and Table 13.
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ]
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 6::/64 Protocol : Static
NextHop : 5::2 Preference: 60
Interface : XGE0/0/6 Cost : 0
Interface : XGE0/0/7 Cost : 0
Destination: FE80::/10 Protocol : Direct
NextHop : :: Preference: 0
Destination: FF00::/8 Protocol : Direct
Interface : NULL0 Cost : 0
Destinations |
Routes |
Number of routes. |
Destination |
IPv6 address and prefix of the destination network or host. |
NextHop |
Preference |
Output interface for packets to be forwarded along the route. (If the protocol is SRv6 and the forwarding tunnel is SRv6 TE policy, this field displays the policy name.) |
Protocol |
Route type or protocol that installed the route: · Direct—Direct route. · Static—Static route. · RIPng—RIPng route. · OSPFv3—OSPFv3 route. · ISISv6—IPv6 IS-IS route. · EIGRPv6—IPv6 EIGRP route. · BGP4+—IPv6 BGP route. · OpenR6—IPv6 Open Routing (IPv6 OpenR) route. · LDP—LDP route. · SLSP—Static LSP. · PIM—PIM route. · MSTATIC—Multicast static route. · O_INTRA—OSPF intra-area route. · O_INTER—OSPF inter-area route. · O_ASE1—OSPF Type-1 external route. · O_ASE2—OSPF Type-2 external route. · O_SUM—OSPF summary route. · IS_L1—IS-IS Level-1 route. · IS_L2—IS-IS Level-2 route. · IS_SUM—IS-IS summary route. · SRv6—SRv6 route. |
Cost |
Summary count |
Number of routes. |
<Sysname> display ipv6 routing-table verbose
Destinations : 6 Routes : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h23m02s
TableID: 0xa OrigAs: 0
NibID: 0x20000000 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10004 OrigNextHop: ::1
Label: NULL RealNextHop: ::1
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 6::/64
Protocol: Static
Process ID: 0
SubProtID: 0x0 Age: 00h01m47s
NibID: 0x21000000 LastAs: 0
Flags: 0x10080 OrigNextHop: 5::2
Label: NULL RealNextHop: 3::3
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 12::/96
Protocol: Direct
Process ID: 0
NibID: 0x20000003 LastAs: 0
Flags: 0x10080 OrigNextHop: ::
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: 12::1/128
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h01m45s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination: FF::11/128
Process ID: 0
SubProtID: 0x6 Age: 00h00m33s
TableID: 0xa OrigAs: 200
NibID: 0x26000000 LastAs: 200
AttrID: 0x1 Neighbor: 12::2
Flags: 0x10060 OrigNextHop: 12::2
Label: NULL RealNextHop: 12::2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Destination |
Protocol |
SubProtID |
Age |
Cost |
Preference |
IpPre |
IP precedence. |
QosLocalID |
Tag |
Tag of the route. |
State |
OrigTblID |
OrigVrf |
TableID |
OrigAs |
NibID |
LastAs |
Last AS number. |
AttrID |
Attribute ID. |
Neighbor |
Flags |
OrigNextHop |
Label |
Label. |
RealNextHop |
BkLabel |
Backup label. |
BkNexthop |
Backup next hop. |
SRLabel |
BkSRLabel |
Backup SR label. |
SIDIndex |
SID index value. |
InLabel |
Tunnel ID |
Tunnel ID. |
BkTunnel ID |
BkInterface |
Backup output interface. (If the protocol is SRv6 and the forwarding tunnel is SRv6 TE policy, this field displays the policy name.) If multiple backup output interfaces are available, an ellipsis (...) exists in this field. Only the first backup output interface can take effect. |
IPInterface |
BkIPInterface |
ColorInterface |
BkColorInterface |
TunnelInterface |
BkTunnelInterface |
FtnIndex |
TrafficIndex |
Connector |
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported. |
PathID |
Path ID. |
SRTunnelID |
SR tunnel ID. |
SID Type |
NID |
FlushNID |
BkNID |
BkFlushNID |
VpnPeerId |
Dscp |
Exp |
SID |
BkSID |
CommBlockLen |
OrigLinkID |
RealLinkID |
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
When you specify an IPv6 ACL, follow these restrictions and guidelines:
· If the specified IPv6 ACL does not exist or does not have any rules, the command displays information about all IPv6 routes.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128 Protocol : Direct
Destination: 12::/96 Protocol : Direct
Destination: 12::1/128 Protocol : Direct
Destination: FF::11/128 Protocol : BGP4+
NextHop : 12::2 Preference: 255
For command output, see Table 5.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 19h29m12s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 00h07m57s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
For command output, see Table 6.
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
· display ipv6 routing-table ipv6-address
¡ The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡ The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
· display ipv6 routing-table ipv6-address prefix-length
¡ The system ANDs the entered destination IPv6 address with the entered prefix length.
¡ The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
· display ipv6 routing-table ipv6-address longer-match
If you do not specify the prefix-length argument, the command yields the same result as the display ipv6 routing-table command.
· display ipv6 routing-table ipv6-address prefix-length longer-match
· display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64 Protocol : Static
NextHop : :: Preference: 60
Destination: 10::/68 Protocol : Static
Destination: 10::/120 Protocol : Static
# Display brief information about the routes to the destination IPv6 address 10::1 with prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64 Protocol : Static
Destination: 200::/64 Protocol : Static
Destination: 300::/64 Protocol : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
Protocol: BGP4+ instance abc
Process ID: 0
SubProtID: 0x1 Age: 00h01m14s
TableID: 0x1 OrigAs: 200
AttrID: 0x0 Neighbor: 2:2::3:4
Flags: 0x10060 OrigNextHop: 2:2::3:4
Label: NULL RealNextHop: 2:2::3:4
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
Protocol: Direct
Process ID: 0
SubProtID: 0x0 Age: 08h57m19s
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
# Display brief information about IPv6 direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# Display brief information about IPv6 static routes.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128 Protocol : Static
NextHop : fe80::2 Preference: 60
NextHop : fe80::3 Preference: 60
Destination: 3::3/128 Protocol : Static
NextHop : 2::2 Preference: 60
Summary count : 0
# Display brief information about IPv6 OpenR routes.
<Sysname> display ipv6 routing-table protocol openr
Summary count : 1
OpenR6 Routing table status : <Active>
Summary count : 1
Destination: 2::2/128 Protocol : OpenR6
NextHop : fe80::2 Preference: 30
OpenR6 Routing table status : <Inactive>
Summary count : 0
# Display detailed information about IPv6 BGP routes.
<Sysname> display ipv6 routing-table protocol bgp4+ verbose
Summary count : 1
Destination: 22::22/128
Process ID: 0
SubProtID: 0x6 Age: 00h04m15s
NibID: 0x25000001 LastAs: 200
AttrID: 0x3 Neighbor: 121::2
Flags: 0x10060 OrigNextHop: 121::2
Label: NULL RealNextHop: 121::2
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
# Display detailed information about IPv6 OpenR routes.
<Sysname> display ipv6 routing-table protocol openr verbose
Summary count : 1
Protocol: OpenR6
Process ID: 0
SubProtID: 0x1 Age: 01h28m12s
Flags: 0x10060 OrigNextHop: 200::6
SRTunnelID: Invalid
Exp: N/A
CommBlockLen: 0
Use display ipv6 routing-table statistics to display IPv6 route and route prefix statistics.
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays route statistics for the public network.
prefix: Displays statistics about IPv6 route prefixes. If you do not specify this keyword, the command displays statistics about IPv6 routes.
If you do not specify any parameters, this command displays statistics about IPv6 routes in the public network.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8 Active prefixes: 8
DIRECT 5 5 5 0
STATIC 3 3 3 0
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 8 8 8 0
# Display IPv6 route statistics for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6 Active prefixes: 6
DIRECT 3 3 3 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 6 6 8 2
# Display IPv6 route statistics for VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 11 11 13 2
# Display IPv6 route statistics for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT 8 8 8 0
STATIC 3 3 5 2
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 11 11 13 2
# Display IPv6 route prefix statistics for the public network.
<Sysname> display ipv6 routing-table prefix statistics
DIRECT 5 5 5 0
STATIC 1 1 1 0
UNR 0 0 0 0
RIPng 0 0 0 0
OSPFv3 0 0 0 0
IS-ISv6 0 0 0 0
LISP 0 0 0 0
SRv6 0 0 0 0
BGP4+ 0 0 0 0
OpenR6 0 0 0 0
Total 6 6 6 0
Table 7 Command output
Proto |
Routes |
Prefixes |
Number of IPv6 route prefixes. |
Active |
Added |
Deleted |
Total |
Use display ipv6 routing-table summary to display brief IPv6 routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief IPv6 routing table information for the public network.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
# Display brief IPv6 routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
For command output, see Table 4.
display rib attribute
Use display rib attribute to display route attribute information in the RIB.
# Display route attribute information in the RIB.
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
Flag: 0x0
Address family: IPv4
Reference count: 0
Act-RT reference count: 0
Flush flag: 0
Local preference: 0
Ext-communities number: 26
Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
> <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
: 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
<RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
AS-path number: 0
AS-path value: N/A
SFlow AS-path length: 0
SFlow AS-path value: N/A
Detailed information of attribute 0x1:
Flag: 0x0
Protocol: BGP
Reference count: 0
Flush flag: 0
Local preference: 0
Ext-communities number: 1
Ext-communities value: <RT: 1:2>
AS-path number: 0
AS-path value: N/A
Protocol |
Protocol that generates the attribute. |
Act-RT reference count |
Reference count of active routes. |
Flush flag |
Flag of flushing route attribute information to the FIB: · 0—The route attribute information is not flushed to the FIB. · 1—The route attribute information is flushed to the FIB. |
Ext-communities number |
Number of the extended community attribute values. |
Ext-communities value |
Values of the extended community attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values. |
Communities number |
Number of the COMMUNITY attribute values. |
Communities value |
Values of the COMMUNITY attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values. |
AS-path number |
Number of ASs in the AS_PATH attribute. |
AS-path value |
Values of the AS_PATH attribute, including AS_SET, AS_SEQUENCE, confederation AS_SET, and confederation AS_SEQUENCE. This field displays N/A when no values exist, and it can display a maximum of 20 values. |
SFlow AS-path length |
Length of the sFlow AS-path attribute. |
SFlow AS-path value |
Value of the sFlow AS-path attribute. This field displays N/A if the length of the sFlow AS-path attribute is 0. This field can display a maximum of 80 characters. |
display rib graceful-restart
Use display rib graceful-restart to display RIB GR state information.
# Display RIB GR state information.
<Sysname> display rib graceful-restart
Protocol GR state:
1 DIRECT 100 30 End No/No
2 STATIC 480 34 End No/No
3 OSPF 480 36 End No/No
4 ISIS 480 32 End No/No
5 BGP instance abc
480 22 End No/No
6 BGP instance default
480 25 End No/No
7 LDP 480 35 End No/No
8 SLSP 480 29 End No/No
9 OpenR 480 85 End No/No
RIB GR state |
RIB GR status: · Start—GR starts. · IGP end—All IGP protocols complete GR. · VPN-triggering end—Optimal route selection triggered by VPN routes completes. · VPN-calculation end—Optimal VPN route selection completes. · Routing protocol end—All routing protocols complete GR. · NSR-calculation unfinished—NSR has not finished optimal route selection. · Triggering start—All triggered optimal route selection starts. · Triggering end—All triggered optimal route selection completes. · Phase1-calculation end—Optimal route selection phase 1 completes. · All end—All protocols complete GR. · Phase2-calculation end—Optimal route selection phase 2 completes. |
RCOM GR state |
RCOM GR status: · Start—GR starts. · VPN-calculation end—Optimal VPN route selection completes. · VPN-notification end—VPN routes have been delivered to the route management module. · Routing protocol end—All routing protocols complete GR. · NSR-calculation unfinished—NSR has not finished optimal route selection. · Phase1-calculation end—Optimal route selection phase 1 completes. · Notification end—All routes have been delivered to the route management module. · Phase2-calculation end—Optimal route selection phase 2 completes. · Flush start—Starts to flush routes to the FIB. · Flush end—Completes flushing routes to the FIB. |
No. |
Protocol number. |
Lifetime |
Lifetime (in seconds) of routes/labels in the RIB during GR. |
FD |
Handle between the protocol and the RIB. |
State |
Protocol GR state: · Init—Initialization state. · Listen—Listening state. · Idle. · Active. · Start—GR starts. · End—GR completes. |
Start/End |
Message sending state: · No—The message has not been sent. · Yes—The message has been sent. |
display rib nib
Use display rib nib to display next hop information in the RIB.
display rib nib [ sub-nib nib-id ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
NibID: 0x10000000 Sequence: 0
UserKey1: 0x0 Nexthop: 0.0.0.0
UserKey3: 0x0 LocalAddr: 0.0.0.0
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID: 0x10000001 Sequence: 1
UserKey1: 0x0 Nexthop: 127.0.0.1
UserKey3: 0x0 LocalAddr: 127.0.0.1
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID: 0x10000002 Sequence: 2
Type: 0x5 Flushed: Yes
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID: 0x16000000 Sequence: 3
Type: 0x21 Flushed: No
UserKey1: 0x0 Nexthop: 12.1.1.2
UserKey2: 0x0 IFIndex: 0x0
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
Instance: abc
NibID |
Sequence |
Sequence number of the next hop. |
Type |
Type of the next hop. |
Flushed |
Indicates whether the route with the next hop has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
UserKey2 |
Reserved data 3. |
UserKey3 |
Reserved data 4. |
VrfNthp |
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network. |
Nexthop |
Next hop address. |
IFIndex |
Interface index. |
LocalAddr |
Local interface address. |
TopoNthp |
Non-base topologies are not supported in the current software version. Index of the topology that contains the next hop. This field displays 0 if the next hop is on the IPv4 public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies. |
Color |
Color extended community attribute. |
COFlag |
Flag of the color extended community attribute. |
LinkID |
Link ID of the SDWAN TTE connection. |
SIDIndex |
SID index value. |
Instance |
BGP instance name. |
SubNibID |
ID of the sub-next hop. |
SubSeq |
Sequence number of the sub-next hop. |
NthpCnt |
Number of sub-next hops. |
Samed |
Number of the same sub-next hops. |
NthpType |
Type of the sub-next hop: · IP—IP forwarding. · MPLS—MPLS forwarding. |
SRPName |
This field is not supported in the current software version. SR-MPLS TE policy name. |
OriNexthop |
Original next hop of the route. If the route is obtained from a BGP update message, this field displays the next hop IP address in the received message. |
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
UserKey2: 0x0 IFIndex: 0x10002
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 6 FlushRefCnt: 2
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 0.0.0.0
RelyDepth: 0 RealNexthop: 0.0.0.0
Interface: NULL0 LocalAddr: 0.0.0.0
TunnelID: N/A Topology: base
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 13 FlushRefCnt: 5
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 127.0.0.1
RelyDepth: 0 RealNexthop: 127.0.0.1
Interface: InLoop0 LocalAddr: 127.0.0.1
NibID: 0x15000003 Sequence: 3
Type: 0x43 Flushed: Yes
UserKey0: 0x100010000 VrfNthp: 0
UserKey1: 0x0 Nexthop: 22.22.22.22
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
Instance: default
RefCnt: 9 FlushRefCnt: 3
Policy: tnl-policy1
1 nexthop(s):
PrefixIndex: 0 OrigNexthop: 22.22.22.22
RelyDepth: 1 RealNexthop: 13.1.1.2
Interface: GE0/1/3 LocalAddr: 13.1.1.1
TunnelCnt: 1 Vrf: default-vrf
TunnelID: 1025 Topology: base
Policy |
Tunnel policy name. |
x nexthop (s) |
Number of next hops. |
PrefixIndex |
Prefix index of the next hop for an ECMP route. |
Vrf |
VPN instance name. For the public network, this field displays default-vrf. |
OrigNexthop |
Original next hop. |
RealNexthop |
Real next hop. |
Output interface. |
LocalAddr |
IFIndex |
Interface index. |
TopoNthp |
Color |
COFlag |
LinkID |
SIDIndex |
SID index value. |
SRPName |
OriNexthop |
RelyDepth |
Recursion depth. |
TunnelCnt |
Number of tunnels after route recursion. |
TunnelID |
ID of the tunnel after route recursion. |
Topology |
Non-base topologies are not supported in the current software version. Topology name. The topology name for the IPv4 public network is base. This field is blank for IPv6, because IPv6 does not support non-base topologies. |
Weight |
ECMP route weight. This field displays 0 for non-ECMP routes. |
Instance |
RefCnt |
Reference count of the next hop. |
FlushRefCnt |
Reference count of the next hop that is flushed to the FIB. |
Flag |
Flag of the next hop. |
Version |
Version of the next hop. |
Flags |
Flags of the detailed next hop. |
SRPolicyNID |
This field is not supported in the current software version. NIB ID of the route obtained from an SR-MPLS TE policy through route recursion. |
SRInterface |
This field is not supported in the current software version. Output interface of the route obtained from the SR-MPLS TE policy through route recursion. |
ColorWeight |
This field is not supported in the current software version. Weight value of the color attribute in the SR-MPLS TE policy. |
Locator |
IPv6 prefix of the locator to which the SID belongs. N/A indicates that the attribute is not available. |
OrigLinkID |
RealLinkID |
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
NibID |
ID of the NIB. |
Sequence |
Sequence number of the NIB. |
Type |
Type of the NIB. |
Flushed |
Indicates whether the route with the NIB has been flushed to the FIB. |
UserKey0 |
Reserved data 1. |
UserKey1 |
Reserved data 2. |
UserKey2 |
Reserved data 3. |
UserKey3 |
Reserved data 4. |
Color |
COFlag |
LinkID |
SIDIndex |
SID index value. |
VrfNthp |
Nexthop |
Next hop address. |
IFIndex |
Interface index. |
LocalAddr |
Local interface IP address. |
TopoNthp |
SRPName |
OriNexthop |
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 2 FlushRefCnt: 0
1 nexthop(s):
TopoNthp: 0
LinkID: 0x0
OriNexthop: 0.0.0.0
RefCnt: 5 FlushRefCnt: 0
1 nexthop(s):
x nexthop(s) |
PrefixIndex |
Vrf |
OrigNexthop |
RealNexthop |
Real next hop. |
Output interface. |
localAddr |
RelyDepth |
Recursion depth. |
TunnelCnt |
TunnelID |
Topology |
Weight |
RefCnt |
FlushRefCnt |
Flag |
Version |
IFIndex |
Interface index. |
TopoNthp |
Color |
COFlag |
Flag of the extended community attribute. |
LinkID |
SIDIndex |
SID index value. |
SRPName |
OriNexthop |
Flags |
SRPolicyNID |
SRInterface |
ColorWeight |
Locator |
OrigLinkID |
RealLinkID |
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view
RIB IPv6 address family view
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs and GR or NSR is not configured, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
inter-protocol fast-reroute
Use inter-protocol fast-reroute to enable IPv4 or IPv6 RIB inter-protocol FRR.
Use undo inter-protocol fast-reroute to disable IPv4 or IPv6 RIB inter-protocol FRR.
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
Inter-protocol FRR is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables inter-protocol FRR for the public network.
This command allows a device to perform fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
This command uses the next hop of a route from a different protocol as the backup next hop for the faulty route, which might cause loops.
Inter-protocol FRR cannot select a backup next hop from routes in the RIB that have the same next hop, output interface, and destination as those of the faulty route.
# Enable IPv4 RIB inter-protocol FRR for the public network.
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ipv6 route fast-switchover enable
Use ipv6 route fast-switchover enable to enable IPv6 route fast switchover.
Use undo ipv6 route fast-switchover enable to disable IPv6 route fast switchover.
IPv6 route fast switchover is disabled.
Use this command if a physical interface is the output interface for a large number of routes, including ECMP routes and primary/secondary routes. When a link failure occurs on an interface, the device typically performs the following operations before switching the traffic to a valid route:
1. Deletes all ND entries for the link.
2. Instructs the FIB to delete the associated FIB entries.
This process is time-consuming and interruptive if a large number of routes traverse the interface. Route fast switchover minimizes traffic interruption by instructing the FIB to delete the affected FIB entries immediately without having to wait for the ND entries to be deleted.
# Enable IPv6 route fast switchover.
[Sysname] ipv6 route fast-switchover enable
non-stop-routing
Use non-stop-routing to enable RIB NSR.
Use undo non-stop-routing to disable RIB NSR.
non-stop-routing
RIB NSR is disabled.
# Enable NSR for the RIB IPv4 address family.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4] non-stop-routing
primary-path-detect bfd
Use primary-path-detect bfd to enable BFD for primary link availability detection.
Use undo primary-path-detect bfd to disable BFD for primary link availability detection.
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
BFD is disabled for primary link availability detection.
ctrl: Specifies the BFD control packet mode.
echo: Specifies the BFD echo packet mode.
inter-protocol-frr: Enables primary link availability detection for inter-protocol FRR.
protocol-ecmp protocol: Enables primary link availability detection for ECMP routes of a routing protocol.
· In RIB IPv4 address family view, the value for the protocol argument can be bgp, isis, ospf, or static.
· In RIB IPv6 address family view, the value for the protocol argument depends on the BFD mode.
¡ In BFD control packet mode, the value can be bgp4+, isisv6, ospfv3, or static.
¡ In BFD echo packet mode, the value can be bgp4+ or static.
This command enables the device to use a BFD session to detect the next hop availability of the primary link.
· For inter-protocol FRR, the primary link is the route with the highest preference among the routes to the same destination.
· For ECMP routes of a routing protocol, the primary link is each ECMP route. If you specify the ecmp-shared keyword when configuring FFR for a routing protocol, the device will use the LFA algorithm to calculate backup next hops for each ECMP route. The routes destined for the backup next hops are also added to the routing table as ECMP routes and the state of these routes is backup. BFD does not detect these backup ECMP routes.
You can execute this command multiple times to change the BFD mode (echo packet mode or control packet mode).
If you do not specify the inter-protocol-frr or protocol-ecmp keyword, the command applies to both inter-protocol FRR and ECMP routes. The command without the inter-protocol-frr and protocol-ecmp keywords takes precedence over that with the inter-protocol-frr or protocol-ecmp keyword. For example, if you have used the primary-path-detect bfd ctrl command, you can use only the following commands to modify or cancel the command configuration:
· primary-path-detect bfd echo.
· undo primary-path-detect bfd.
# Enable control-mode BFD for primary link availability detection of IS-IS ECMP routes.
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
fast-reroute
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
undo protocol protocol [ instance instance-name ] lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 480 seconds.
seconds: Specifies the maximum lifetime for routes and labels in the RIB, in the range of 1 to 6000 seconds.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. This argument applies only to the BGP protocol. If you do not specify a BGP instance, this command sets the maximum lifetime for all BGP routes and labels in the RIB.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for static routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol static lifetime 60
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears IPv4 route statistics for the public network.
all-routes: Clears route statistics for the public network and all VPN instances.
all-vpn-instance: Clears route statistics for all VPN instances.
protocol: Clears route statistics for a routing protocol.
all: Clears route statistics for all IPv4 routing protocols.
This command clears IPv4 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears the IPv6 route statistics for the public network.
protocol: Clears route statistics for an IPv6 routing protocol.
all: Clears route statistics for all IPv6 routing protocols.
This command clears IPv6 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
