03-System Management Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)-R9119-6W10003-System Management Command Reference
07-Flow log commands
07-Flow log commands 67.06 KB
Flow log commands
display userlog export
Use display userlog export to display flow log configuration and statistics.
# Display flow log configuration and statistics.
<Sysname> display userlog export
Flow:
  Export flow log as UDP Packet.
  Version: 3.0
  Source ipv4 address: 2.2.2.2
  Source ipv6 address:
  Log load balance function: Disabled
  Local time stamp: Disabled
  Number of log hosts: 2
  Log host 1:
    Host/Port: 1.2.3.6/2000
    Total logs/UDP packets exported: 112/87
  Log host 2:
    VPN instance:abc
    Host/Port:1.1.1.1/2000
    Total logs/UDP packets exported: 6553665536/409597846
Flow
Flow log configuration and statistics.
Flow log entries were sent to log hosts in UDP.
Version
Flow log feature version.
Source ipv4/ipv6 address
Source IP address of the flow log packets.
Load balancing status for flow log packets:
·     Enabled—Flow log packets are distributed among available log hosts.
·     Disabled—Every flow log packet is copied and sent to all available log hosts.
Local time stamp
Whether the use of the local time in the flow log timestamp is enabled or disabled.
Number of log hosts
Total number of log hosts.
Log host
Information about the log host.
VPN instance
VPN instance to which the log host belongs.
Host/port
IP address and port number of the log host.
Total logs
Total number of flow log entries successfully exported and those failed to be exported to the log hosts.
Total number of UDP packets successfully sent and those failed to be sent to the log hosts.
The UDP packets are used to export flow log entries. A UDP packet can contain multiple flow log entries.
userlog flow export
reset userlog flow export
Use reset userlog flow export to clear flow log statistics.
# Clear flow log statistics.
<Sysname> reset userlog flow export
userlog flow export
userlog flow export host
Use userlog flow export host to specify a log host to receive flow log entries.
Use undo userlog flow export host to remove a log host.
userlog flow export [ vpn-instance vpn-instance-name ] host { hostname | ipv4-address | ipv6 ipv6-address } port udp-port
undo userlog flow export [ vpn-instance vpn-instance-name ] host { hostname | ipv4-address | ipv6 ipv6-address }
No log hosts are specified.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
hostname: Specifies a log host by its name, a case-insensitive string of 1 to 253 characters. The host name can contain letters, digits, and special characters including hyphen (-), underscore (_), and dot (.).
ipv4-address: Specifies a log host by its IPv4 address. The address must be a valid unicast address and cannot be a loopback address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address.
port udp-port: Specifies the UDP port number of the log host, in the range of 1 to 65535. As a best practice, use UDP port numbers in the range 1025 to 65535 to avoid collision with well-known UDP port numbers.
# Export flow log entries to UDP port 2000 on the log host at 1.2.3.6.
[Sysname] userlog flow export host 1.2.3.6 port 2000
userlog flow export load-balancing
Use userlog flow export load-balancing to enable load balancing for flow log entries.
Use undo userlog flow export load-balancing to restore the default.
Load balancing is disabled. The device sends a copy of each flow log entry to all available log hosts.
In load balancing mode, flow log entries are distributed among log hosts based on the source IP addresses (before NAT) that are recorded in the entries. The flow log entries generated for the same source IP address are sent to the same log host. If a log host goes down, the flow logs sent to it will be lost.
# Enable load balancing for flow logging.
[Sysname] userlog flow export load-balancing
userlog flow export source-ip
Use userlog flow export source-ip to specify a source IP address for flow log packets.
Use undo userlog flow export source-ip to restore the default.
userlog flow export source-ip { ipv4-address | ipv6 ipv6-address }
undo userlog flow export source-ip [ ipv6 ]
The source IP address of flow log packets is the IP address of their outgoing interface.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address.
# Specify 1.2.1.2 as the source IP address for flow log packets.
[Sysname] userlog flow export source-ip 1.2.1.2
userlog flow export timestamp localtime
Use userlog flow export timestamp localtime to configure the device to use the local time in the timestamp of flow logs.
Use undo userlog flow export timestamp localtime to restore the default.
The device uses the UTC time in the timestamp of flow logs.
The device uses either the local time or the UTC time in the timestamp of flow logs.
·     UTC time—Standard Greenwich Mean Time (GMT).
·     Local time—Standard GMT plus or minus the time zone offset.
The time zone offset can be configured by using the clock timezone command. For more information, see basic device management commands in System Management Command Reference.
# Configure the device to use the local time in the timestamp of flow logs.
[Sysname] userlog flow export timestamp localtime
userlog flow export version
Use userlog flow export version to set the flow log version.
Use undo userlog flow export version to restore the default.
userlog flow export version version-number
The flow log version is 1.0.
version-number: Specifies a flow log version. Available options are 1 and 3, which represent version 1.0 and version 3.0.
# Set the flow log version to 3.0.
[Sysname] userlog flow export version 3
userlog flow syslog
Use userlog flow syslog to specify the information center as the destination for flow log export.
Use undo userlog flow syslog to restore the default.
userlog flow syslog
Flow log entries are not exported.
You can export flow log entries to log hosts or the information center, but not both. If both methods are configured, the system exports flow log entries to the information center.
Flow log entries are converted to the syslog format when they are exported to the information center. Their severity level is informational. With the information center, you can specify multiple log output destinations, including the console, log host, and log file.
Log entries in ASCII format are human readable. However, the log data volume is higher in ASCII format than in binary format.
# Specify the information center as the destination for flow log export.
[Sysname] userlog flow syslog
