01-Fundamentals Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)-R9119-6W10001-Fundamentals Command Reference
07-Software upgrade commands
07-Software upgrade commands 95.89 KB
As a best practice, store the startup images in a fixed storage medium. If you store the startup images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
boot-loader file
Use boot-loader file to specify startup image files.
boot-loader file boot filename system filename [ feature filename&<1-30> ] { all | slot slot-number } { backup | main }
boot-loader file ipe-filename { all | slot slot-number } { backup | main }
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies a space-separated list of up to 30 feature image files.
filename: Specifies a .bin file in the filesystemname/filename.bin format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see Fundamentals Configuration Guide.
ipe-filename: Specifies an .ipe image package file in the filesystemname/filename.ipe format. The file must be stored in the root directory of a file system on the device. Excluding the file system location section (if any), the value string can have a maximum of 63 characters. For more information about specifying a file, see Fundamentals Configuration Guide.
all: Specifies all hardware components to which the specified images apply.
slot slot-number: Specifies the slot number of an MPU.
backup: Specifies the files as backup startup image files. Backup images are used only when main images are not available.
main: Specifies the files as main startup image files. The device always first attempts to start up with main startup files.
The boot-loader file command overwrites the entire startup image list. To add new startup feature images, specify all feature image files in the old startup image list, including feature image files. The new startup image list will contain only the feature image files that are specified in the command.
To load the specified startup software images, you must reboot the system.
If the upgrade images are not found in the file system on the slot specified to upgrade, the system automatically copies the images to that file system. The destination directory is the root directory of the file system. If the destination root directory already contains a startup image with the same name as an upgrade image, you must choose whether to overwrite the image.
The system will verify the digital signature of the specified images before it updates the startup image list with the specified images. If the digital signature verification fails, the system will not update the startup image list and you will receive a digital signature verification failure message.
# Specify flash:/all.ipe as the main startup image file for slot 1.
<Sysname> boot-loader file flash:/all.ipe slot 1 main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C SR6602 images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:Y
Add images to slot 1.
File flash:/boot.bin already exists on slot 1.
File flash:/system.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:Y
Decompressing file boot.bin to flash:/boot.bin........................Done.
Decompressing file system.bin to flash:/system.bin...............................Done.
Verifying the file flash:/boot.bin on slot 1...Done.
Verifying the file flash:/system.bin on slot 1.............Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
# Specify flash:/all.ipe as the main startup image file.
<Sysname> boot-loader file flash:/all.ipe all main
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
Overwrite the existing files? [Y/N]:y
File flash:/boot.bin already exists on slot 0.
Do you want to overwrite the file?
 Y: Overwrite the file.
 N: Not overwrite the file.
 A: From now on, overwrite or not overwrite without prompt.
Please make a choice. [Y/N/A]:a
What type of overwrite operation do you want to perform?
  Y: Overwrite without prompt.
  N: Not overwrite or display prompt.
  Q: Return to the previous step.
Please make a choice. [Y/N/Q]:y
An existing file will be overwritten without prompt if it has the same name as any upgrade file.
Loading......................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 0.
Decompression completed.
Do you want to delete flash:/all.ipe now? [Y/N]:n
display boot-loader
boot-loader update
Use boot-loader update to synchronize startup images.
boot-loader update { all | slot slot-number }
all: Synchronizes startup images from the active MPU to the standby MPU.
slot slot-number: Specifies the slot number of the standby MPU.
You can use this command to synchronize startup images after adding new MPUs.
The images used for synchronization are in the main or backup startup software images list instead of the current software images list (see the display boot-loader command).
·     The main images list is used if the active MPU started up with the main startup images.
·     The backup image list is used if the active MPU started up with the backup startup images.
The startup images synchronized to a standby MPU are set as main startup images, regardless of whether the source startup images are main or backup.
If a patch installation or ISSU has been performed, use the install commit command to update the main startup images on the active MPU before software synchronization. This command ensures startup image consistency between the active MPU and the standby MPU.
Startup image synchronization fails if any software image being synchronized is not available or is corrupted.
# Synchronize startup images to a slot.
<Sysname> boot-loader update slot 2
This command will update the specified standby MPU. Continue? [Y/N]:y
Updating. Please wait...
Verifying the file flash:/system.bin on slot 1....Done.
Copying main startup software images to slot 2. Please wait...
Done.
Setting copied images as main startup software images for slot 2...
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 2.
Done.
Successfully updated the startup software images of slot 2.
display boot-loader
install commit
display boot-loader
Use display boot-loader to display current software images and startup software images.
display boot-loader [ slot slot-number ]
slot slot-number: Specifies the slot number of an MPU. If you do not specify an MPU, this command displays the software images on each MPU.
# Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
  flash:/boot.bin
  flash:/system.bin
Comware images that have been loaded.
Primary Comware images for the next startup.
Backup Comware images for the next startup.
boot-loader file
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 9.0.001, ESS 9112P05
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.
H3C SR6602 uptime is 0 weeks, 3 days, 4 hours, 2 minutes
Last reboot reason : User reboot
Boot image: sda0:/sr6602i-cmw910-boot-e9112p05.bin
Boot image version: 9.0.001, ESS 9112P05
  Compiled Apr 25 2021 14:00:00
System image: sda0:/sr6602i-cmw910-system-e9112p05.bin
System image version: 9.0.001, ESS 9112P05
Feature image(s) list:
  sda0:/sr6602i-cmw910-devkit-e9112p05.bin, version: 9.0.001
  sda0:/sr6602i-cmw910-virtualization-e9112p05.bin, version: 9.0.001
Slot 0: RT-SR6602-I uptime is 0 week, 0 day, 0 hour, 29 minutes
 CPU ID: 1
 16G bytes DDR4 SDRAM Memory
 32M bytes Flash Memory
 PCB  Version: Ver.A
 FPGA             Version: 2.16
 Basic      CPLD  Version: 1.0
 Extend     CPLD  Version: 1.0
 Basic   BootWare Version: 1.15
 Extend  BootWare Version: 1.15
 [FIXED PORTS] CON              (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
 [FIXED PORTS] MGE              (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
 [FIXED PORTS] 6XGE             (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
 [FIXED PORTS] 14XGSW           (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
 [FIXED PORTS] 12GSW            (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
Slot 1: RT-FIP-30
 PCB              Version: Ver.A
 FPGA             Version: 3.14
 CPLD             Version: 1.0
 [FIXED PORTS] 4XGE             (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
 [FIXED PORTS] 16GE             (Hardware)Ver.A,   (Driver)1.0,   (CPLD)1.0
 [SUBSLOT   1] RT-MIC-X-XP2     (Hardware)Ver.I,   (Driver)1.0,   (CPLD)1.0
 [SUBSLOT   2] The SubCard is not present
Last reboot reason
Reason for the last reboot:
·     User rebootThe reboot was manually initiated from a user interface, such as the CLI or SNMP.
·     Cold rebootThe reboot was caused by a power cycle.
·     Kernel abnormality rebootThe reboot was caused by kernel exceptions.
·     DeadLoop rebootThe reboot was caused by a kernel thread dead loop.
·     DEV HandShake rebootThe reboot was caused by a device management handshake failure.
·     SlaveSwitch rebootThe reboot was caused by a master/subordinate switchover.
·     Auto Update rebootThe reboot was caused by an automatic software upgrade.
·     Memory exhaust rebootThe reboot was caused by a card-memory-exhausted event.
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Jan 18 2020 at 06:23:54):
 *Name        : Comware-cmw710-boot.bin
  Version     : 7.1.070 Test 0001
  Compile time: Jan 25 2020 15:52:43
 *Name        : Comware-cmw710-system.bin
Record n  (updated on Jan 18 2020 at 06:23:54)
Number of the startup software image upgrade record. Record 1 is the most recent record. The time in parentheses is UTC time.
Name
Software image file name.
The software image version changed during the upgrade.
reset version-update-record
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
