| 11-TCP-MIB | 87.32 KB |
TCP-MIB
About this MIB
This MIB is defined by RFC 4022. Use this MIB to obtain the TCP protocol parameters, TCP connection information, and TCP packet statistics.
MIB file name
rfc4022-tcp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).tcp(6)
Scalar objects
tcpRtoAlgorithm
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpRtoAlgorithm (1.3.6.1.2.1.6.1) |
read-only |
INTEGER |
other(1), constant(2), rsre(3), vanj(4), rfc2988(5) |
Algorithm used to determine the timeout value for retransmitting unacknowledged octets. |
As per the MIB. |
tcpRtoMin
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpRtoMin (1.3.6.1.2.1.6.2) |
read-only |
Integer32 |
Integer32 (0..2147483647) |
Minimum value, in milliseconds, for the TCP retransmission timeout. |
As per the MIB. |
tcpRtoMax
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpRtoMax (1.3.6.1.2.1.6.3) |
read-only |
Integer32 |
Maximum value, in milliseconds, for the TCP retransmission timeout. |
As per the MIB. |
tcpMaxConn
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpMaxConn (1.3.6.1.2.1.6.4) |
read-only |
Integer32 |
Integer32 (-1 | 0..2147483647) |
Maximum number of TCP connections that are supported. In the maximum number is a dynamic value, this object take the "value–1". |
As per the MIB. |
tcpActiveOpens
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpActiveOpens (1.3.6.1.2.1.6.5) |
read-only |
Counter32 |
Standard MIB values. |
Number of times that TCP connections have made a direct transition to the SYN-SENT state from the CLOSED state. |
As per the MIB. |
tcpPassiveOpens
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpPassiveOpens (1.3.6.1.2.1.6.6) |
read-only |
Counter32 |
Number of times that TCP connections have made a direct transition to the SYN-RCVD state from the LISTEN state. |
As per the MIB. |
tcpAttemptFails
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpAttemptFails (1.3.6.1.2.1.6.7) |
read-only |
Counter32 |
Sum of the following number of times that TCP connections have made a direct transition: · Number of transitions to the CLOSED state from either the SYN-SENT state or the SYN-RCVD state. · Number of transitions to the LISTEN state from the SYN-RCVD state. |
As per the MIB. |
tcpEstabResets
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpEstabResets (1.3.6.1.2.1.6.8) |
read-only |
Counter32 |
Number of times that TCP connections have made a direct transition to the CLOSED state from either the ESTABLISHED state or the CLOSE-WAIT state. |
As per the MIB. |
tcpCurrEstab
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpCurrEstab (1.3.6.1.2.1.6.9) |
read-only |
Gauge32 |
Number of TCP connections for which the current state is either ESTABLISHED or CLOSE-WAIT. |
As per the MIB. |
tcpInSegs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpInSegs (1.3.6.1.2.1.6.10) |
read-only |
Counter32 |
Total number of segments received, including those received in error, and the segments received on established connections. |
As per the MIB. |
tcpOutSegs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpOutSegs (1.3.6.1.2.1.6.11) |
read-only |
Counter32 |
Total number of sent segments, including those on current connections. The segments containing only retransmitted octets are not included. |
As per the MIB. |
tcpRetransSegs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpRetransSegs (1.3.6.1.2.1.6.12) |
read-only |
Counter32 |
Total number of segments retransmitted, that is, the number of transmitted TCP segments containing one or more previously transmitted octets. |
As per the MIB. |
tcpInErrs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpInErrs (1.3.6.1.2.1.6.14) |
read-only |
Counter32 |
Total number of segments received in error (for example, bad TCP checksums). |
As per the MIB. |
tcpOutRsts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpOutRsts (1.3.6.1.2.1.6.15) |
read-only |
Counter32 |
Number of sent TCP segments containing the RST flag. |
As per the MIB. |
tcpHCInSegs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpHCInSegs (1.3.6.1.2.1.6.17) |
read-only |
Counter64 |
64-bit equivalent of tcpInSegs. |
Not supported |
tcpHCOutSegs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpHCOutSegs (1.3.6.1.2.1.6.18) |
read-only |
Counter64 |
64-bit equivalent of tcpOutSegs. |
Not supported |
Tabular objects
tcpConnTable
About this table
Use this table to obtain detailed IPv4 TCP connection information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are tcpConnLocalAddress, tcpConnLocalPort, tcpConnRemAddress, and tcpConnRemPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpConnState (1.3.6.1.2.1.6.13.1.1) |
read-write |
INTEGER |
closed(1), listen(2), synSent(3), synReceived(4), established(5), finWait1(6), finWait2(7), closeWait(8), lastAck(9), closing(10), timeWait(11), deleteTCB(12) |
TCP connection state. The only value that a management station can set is deleteTCB(12). If a management station tries to set the object to a value other than deleteTCB(12), the agent will return an error response. If the object value is set to deleteTCB(12), TCB will deleted and the corresponding TCP connection will be terminated. |
Read only. |
tcpConnLocalAddress (1.3.6.1.2.1.6.13.1.2) |
read-only |
IpAddress |
Local IP address for the TCP connection. The value 0.0.0.0 indicates that the connection in the listen state can accept connections for any interface. |
As per the MIB. |
tcpConnLocalPort (1.3.6.1.2.1.6.13.1.3) |
read-only |
Integer32 |
Integer32 (0..65535) |
Local port number of the TCP connection. |
As per the MIB. |
tcpConnRemAddress (1.3.6.1.2.1.6.13.1.4) |
read-only |
IpAddress |
Remote IP address of the TCP connection. |
As per the MIB. |
tcpConnRemPort (1.3.6.1.2.1.6.13.1.5) |
read-only |
Integer32 |
Remote port number of the TCP connection. |
As per the MIB. |
tcpConnectionTable
About this table
Use this table to obtain TCP connection information. Different from tcpConnTable, information about the connections in the LISTEN state is stored in tcpListenTable.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are tcpConnectionLocalAddressType, tcpConnectionLocalAddress, tcpConnectionLocalPort, tcpConnectionRemAddressType, tcpConnectionRemAddress, and tcpConnectionRemPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpConnectionLocalAddressType (1.3.6.1.2.1.6.19.1.1) |
not-accessible |
InetAddressType |
Address type of tcpConnectionLocalAddress. |
Only supports ipv4(1) and ipv6 (2). |
tcpConnectionLocalAddress (1.3.6.1.2.1.6.19.1.2) |
not-accessible |
InetAddress |
Local IP address of the TCP connection. |
As per the MIB. |
tcpConnectionLocalPort (1.3.6.1.2.1.6.19.1.3) |
not-accessible |
InetPortNumber |
As per the MIB. |
tcpConnectionRemAddressType (1.3.6.1.2.1.6.19.1.4) |
not-accessible |
InetAddressType |
Address type of tcpConnectionRemAddress. |
Supports only ipv4(1) and ipv6 (2). |
tcpConnectionRemAddress (1.3.6.1.2.1.6.19.1.5) |
not-accessible |
InetAddress |
As per the MIB. |
tcpConnectionRemPort (1.3.6.1.2.1.6.19.1.6) |
not-accessible |
InetPortNumber |
As per the MIB. |
tcpConnectionState (1.3.6.1.2.1.6.19.1.7) |
read-write |
INTEGER |
Read only. |
tcpConnectionProcess (1.3.6.1.2.1.6.19.1.8) |
read-only |
Unsigned32 |
System's process ID for the process associated with this connection. The value is 0 if no such process exists. |
As per the MIB. |
tcpListenerTable
About this table
Use this table to obtain the TCP listener information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are tcpListenerLocalAddressType, tcpListenerLocalAddress, and tcpListenerLocalPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
tcpListenerLocalAddressType (1.3.6.1.2.1.6.20.1.1) |
not-accessible |
InetAddressType |
Address type of tcpListenerLocalAddress. The value unknown(0) indicates that the listener accepts connection initiations to all local IP addresses. |
tcpListenerLocalAddress (1.3.6.1.2.1.6.20.1.2) |
not-accessible |
InetAddress |
As per the MIB. |
tcpListenerLocalPort (1.3.6.1.2.1.6.20.1.3) |
not-accessible |
InetPortNumber |
As per the MIB. |
tcpListenerProcess (1.3.6.1.2.1.6.20.1.4) |
read-only |
Unsigned32 |
As per the MIB. |
