05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10005-Layer 2 - LAN Switching
19-LLDP-EXT-DOT1-V2-MIB
19-LLDP-EXT-DOT1-V2-MIB 281.76 KB
LLDP-EXT-DOT1-V2-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Tabular objects· 1
lldpV2Xdot1ConfigPortVlanTable· 1
lldpV2Xdot1ConfigVlanNameTable· 2
lldpV2Xdot1ConfigProtoVlanTable· 3
lldpV2Xdot1ConfigProtocolTable· 3
lldpV2Xdot1ConfigVidUsageDigestTable· 4
lldpV2Xdot1ConfigManVidTable· 4
lldpV2Xdot1LocTable· 5
lldpV2Xdot1LocProtoVlanTable· 5
lldpV2Xdot1LocVlanNameTable· 6
lldpV2Xdot1LocProtocolTable· 7
lldpV2Xdot1LocManVidTable· 7
lldpV2Xdot1LocLinkAggTable· 8
lldpV2Xdot1RemTable· 8
lldpV2Xdot1RemProtoVlanTable· 9
lldpV2Xdot1RemVlanNameTable· 10
lldpV2Xdot1RemProtocolTable· 10
lldpV2Xdot1RemVidUsageDigestTable· 11
lldpV2Xdot1RemManVidTable· 11
lldpV2Xdot1RemLinkAggTable· 12
lldpXdot1dcbxConfigETSConfigurationTable· 13
lldpXdot1dcbxConfigETSRecommendationTable· 13
lldpXdot1dcbxConfigPFCTable· 14
lldpXdot1dcbxConfigApplicationPriorityTable· 15
lldpXdot1dcbxLocETSBasicConfigurationTable· 15
lldpXdot1dcbxLocETSConPriorityAssignmentTable· 16
lldpXdot1dcbxLocETSConTrafficClassBandwidthTable· 17
lldpXdot1dcbxLocETSConTrafficSelectionAlgorithmTable· 18
lldpXdot1dcbxLocETSRecoTrafficClassBandwidthTable· 18
lldpXdot1dcbxLocETSRecoTrafficSelectionAlgorithmTable· 19
lldpXdot1dcbxLocPFCBasicTable· 20
lldpXdot1dcbxLocPFCEnableTable· 20
lldpXdot1dcbxLocApplicationPriorityAppTable· 21
lldpXdot1dcbxRemETSBasicConfigurationTable· 22
lldpXdot1dcbxRemETSConPriorityAssignmentTable· 23
lldpXdot1dcbxRemETSConTrafficClassBandwidthTable· 23
lldpXdot1dcbxRemETSConTrafficSelectionAlgorithmTable· 24
lldpXdot1dcbxRemETSRecoTrafficClassBandwidthTable· 25
lldpXdot1dcbxRemETSRecoTrafficSelectionAlgorithmTable· 25
lldpXdot1dcbxRemPFCBasicTable· 26
lldpXdot1dcbxRemPFCEnableTable· 27
lldpXdot1dcbxRemApplicationPriorityAppTable· 27
lldpXdot1dcbxAdminETSBasicConfigurationTable· 28
lldpXdot1dcbxAdminETSConPriorityAssignmentTable· 29
lldpXdot1dcbxAdminETSConTrafficClassBandwidthTable· 30
lldpXdot1dcbxAdminETSConTrafficSelectionAlgorithmTable· 30
lldpXdot1dcbxAdminETSRecoTrafficClassBandwidthTable· 31
lldpXdot1dcbxAdminETSRecoTrafficSelectionAlgorithmTable· 32
lldpXdot1dcbxAdminPFCBasicTable· 32
lldpXdot1dcbxAdminPFCEnableTable· 33
lldpXdot1dcbxAdminApplicationPriorityAppTable· 34
About this MIB
LLDP facilitates network management to discover and use network physical topology in a standard way, and enables network management to discover configuration inconsistencies or errors that affect the upper-layer applications. Although H3C products already support the LLDP 2009 version, they still use the MIBs of the LLDP 2005 version.
The MIB of the LLDP 2009 version is also referred to as LLDP-V2-MIB. This MIB is a standard public MIB, which contains LLDP configuration, LLDP statistics, local LLDP information, neighboring LLDP information, and IEEE 802.1 extended configuration, DCBX extended configuration, IEEE 802.3 extended configuration. The CNP extended configuration is not supported in Comware V700R001.
MIB file name
lldp-ext-dot1-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962)
This MIB is the LLDP Management Information Base extension module for IEEE 802.1 organizationally defined discovery information.
Tabular objects
About this table
This table controls selection of LLDP port VLAN TLVs to be transmitted on individual ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.1.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigPortVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the port VLAN TLV transmission is enabled on a given LLDP transmission capable port.
The default is true for the following agents: Nearest bridge agents and nearest customer bridge agents on the Layer 2 Ethernet interfaces. Nearest customer bridge agents on Layer 2 aggregate interfaces.
About this table
This table controls selection of LLDP VLAN name TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.2.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigVlanNameTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the agents on the ports of the device can send VLAN name TLVs.
By default, the value is 0 and the status is FALSE. If this object is set to TRUE, the VLAN with the minimum VLAN ID is enabled. To delete an enabled VLAN, set the VLAN status to FALSE. Only one VLAN name TLV is supported in an LLDP packet.
As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to walk through all ports and VLANs.
About this table
This table controls selection of LLDP port and protocol VLAN ID TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocProtoVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.3.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigProtoVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the transmission of port and protocol VLAN ID TLVs is enabled on a given LLDP transmission capable port.
By default, the value is 0 and the status is FALSE. If this object is set to TRUE, the VLAN with the minimum VLAN ID is enabled. To delete an enabled VLAN, set the VLAN status to FALSE. Only one protocol VLAN TLV is supported in an LLDP packet.
As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to scan all ports and VLANs.
About this table
This table controls selection of LLDP protocol identity TLV instances to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocProtocolIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.4.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigProtocolTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.4.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the agents on the ports of the device can send protocol identity TLVs.
Not supported.
About this table
This table controls selection of LLDP VID usage digest TLVs to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is lldpV2LocPortIfIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.5.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigVidUsageDigestTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.5.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the agents on the ports of the device can send VID usage digest TLVs.
Not supported.
About this table
This table controls selection of management VID TLVs to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.6.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1ConfigManVidTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.6.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the management VID TLV transmission is enabled on a given LLDP transmission capable port.
As per the MIB.
lldpV2Xdot1LocTable
About this table
This table contains local VLAN ID information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.1.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.1.1.1)
read-only
Unsigned32
Unsigned32(0|1..4094)
Local VLAN ID.
As per the MIB.
About this table
This table contains information about local port and protocol VLANs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.2.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.1)
not-accessible
Unsigned32
Unsigned320|1..4094
Port and protocol VLAN ID.
As per the MIB.
lldpV2Xdot1LocProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given local port supports port and protocol VLANs.
As per the MIB.
lldpV2Xdot1LocProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether the port and protocol VLANs are enabled on the given local port.
As per the MIB.
About this table
This table contains information about VLAN names on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.3.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.1)
not-accessible
VlanId
Standard MIB values.
ID of the VLAN to which the port belongs.
As per the MIB.
lldpV2Xdot1LocVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.2)
read-only
SnmpAdminString
OCTET STRING (1..32)
VLAN name identified by the VLAN ID associated with the given local port.
As per the MIB.
About this table
This table contains protocol identity information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.4.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocProtocolIndex (1.3.111.2.802.1.1.13.1.5.32962.1.2.4.1.1)
not-accessible
Unsigned32
Unsigned32(1..2147483647)
Protocol index.
Not supported.
lldpV2Xdot1LocProtocolId (1.3.111.2.802.1.1.13.1.5.32962.1.2.4.1.2)
read-only
OCTET STRING
OCTET STRING (1..255)
IDs of the protocols associated with the given port.
Not supported.
About this table
This table contains management TLV information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.6.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocManVid (1.3.111.2.802.1.1.13.1.5.32962.1.2.6.1.1)
read-only
Unsigned32
Local management TLV information.
As per the MIB.
About this table
This table contains link aggregation information on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.7.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.1)
read-only
LldpV2LinkAggStatusMap
The link aggregation capabilities and the current aggregation status of the system.
As per the MIB.
lldpV2Xdot1LocLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.2)
read-only
Unsigned32
Unsigned32(0|1..2147483647)
Aggregate interface ID.
As per the MIB.
lldpV2Xdot1RemTable
About this table
This table contains information about physical network connections.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.1.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.1.1.1)
read-only
Unsigned32
PVID of the given port on a neighboring device.
As per the MIB.
About this table
This table contains port and protocol VLAN information about the neighboring devices, received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpV2Xdot1RemProtoVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.2.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.1)
not-accessible
Unsigned32
Port and protocol VLAN ID of a neighboring device.
As per the MIB.
lldpV2Xdot1RemProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates whether the given port of the neighboring device supports port and protocol VLANs.
As per the MIB.
lldpV2Xdot1RemProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates whether port and protocol VLANs are enabled on the given port of the neighboring device.
As per the MIB.
About this table
This table contains information about VLAN names on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex,a nd lldpV2Xdot1RemVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.3.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.1)
not-accessible
VlanId
ID of the VLAN to which a port on a neighboring device belongs.
As per the MIB.
lldpV2Xdot1RemVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.2)
read-only
SnmpAdminString
VLAN name identified by the VLAN ID associated with the neighboring device.
As per the MIB.
About this table
This table contains neighboring protocol information received on the given port.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddres, lldpV2RemIndex, and lldpV2Xdot1RemProtocolIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.4.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemProtocolIndex (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.1)
not-accessible
Unsigned32
Protocol index.
As per the MIB.
lldpV2Xdot1RemProtocolId (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.2)
read-only
OCTET STRING
IDs of the protocols associated with the ports of the neighboring devices.
As per the MIB.
About this table
This table contains VID usage information of the agents on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, and lldpV2RemLocalDestMACAddress.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.5.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemVidUsageDigest (1.3.111.2.802.1.1.13.1.5.32962.1.3.5.1.1)
read-only
Unsigned32
VID usage information on the given port of a neighboring device.
As per the MIB.
About this table
This table contains management VLAN information received from the neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.6.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemManVid (1.3.111.2.802.1.1.13.1.5.32962.1.3.6.1.1)
read-only
Unsigned32
Management VLAN information on the given port of a neighboring device.
As per the MIB.
About this table
This table contains port link aggregation information of the agents on the ports of the neighboring devices.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex. lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.7.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.1)
read-only
Link aggregation capabilities and current aggregation status of a neighboring device.
As per the MIB.
lldpV2Xdot1RemLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.2)
read-only
Unsigned32
As per the MIB.
About this table
The table controls selection of ETS configuration TLVs to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex .
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxConfigETSConfigurationTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the ETS Configuration TLV transmission is enabled on the agents of a given LLDP transmission capable port.
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSRecommendationTxEnable, lldpXdot1dcbxConfigPFCTxEnable, and lldpXdot1dcbxConfigApplicationPriorityTxEnable.
About this table
The table controls selection of ETS recommendation TLVs to be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxConfigETSRecommendationTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the ETS recommendation TLV transmission is enabled on the agents of a given LLDP transmission capable port.
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSConfigurationTxEnable, lldpXdot1dcbxConfigPFCTxEnable, and lldpXdot1dcbxConfigApplicationPriorityTxEnable.
About this table
The table controls selection of priority-based Flow Control TLVs o be transmitted on individual ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxConfigPFCTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.3.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the Flow Control TLV transmission is enabled on the agents of a given LLDP transmission capable port.
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSConfigurationTxEnable, lldpXdot1dcbxConfigETSRecommendationTxEnable, lldpXdot1dcbxConfigApplicationPriorityTxEnable, and
About this table
The table configures the transmission of the Application Priority TLV on a set of ports.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxConfigApplicationPriorityTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.4.1.1)
read-write
TruthValue
true(1),
false(2)
Indicates whether the Application Priority TLV transmission is enabled on the agents of a given LLDP transmission capable port.
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSConfigurationTxEnable, lldpXdot1dcbxConfigETSRecommendationTxEnable, and lldpXdot1dcbxConfigPFCTxEnable.
About this table
This table contains information about ETS configuration TLVs on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates if the credit-based shaper traffic selection algorithm is supported on the local system.
As per the MIB.
lldpXdot1dcbxLocETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.2)
read-only
LldpXdot1dcbxSupportedCapacity
Indicates the supported capacity of a given feature.
As per the MIB.
lldpXdot1dcbxLocETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates if the local system is willing to accept the ETS configuration recommended by a neighboring device.
As per the MIB.
About this table
This table contains one row per priority. The entry in each row indicates the traffic class to which the priority is assigned.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSConPriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.1.1)
not-accessible
IEEE8021PriorityValue
Indicates the priority that is assigned to a traffic class.
As per the MIB.
lldpXdot1dcbxLocETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.1.2)
read-only
LldpXdot1dcbxTrafficClassValue
Indicates the traffic class to which this priority is to be assigned.
As per the MIB.
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic class to which the bandwidth is assigned.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSConTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.1.1)
not-accessible
Indicates the traffic class to which this bandwidth applies.
As per the MIB.
lldpXdot1dcbxLocETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.1.2)
read-only
LldpXdot1dcbxTrafficClassBandwidthValue
Indicates the bandwidth assigned to this traffic class.
As per the MIB.
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic selction algorithm to be used by the traffic class.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSConTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxLocETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.1.2)
read-only
LldpXdot1dcbxTrafficSelectionAlgorithm
Indicates the traffic selection algorithm to which this traffic class is to be assigned.
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSRecoTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxLocETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.1.2)
read-only
As per the MIB.
About this table
This table contains one row per priority. The entry in each row indicates the traffic selction algorithm to be used by the traffic class.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSRecoTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxLocETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.1.2)
read-only
As per the MIB.
About this table
This table contains information about local PFC TLVs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index islldpV2LocPortIfIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates if the local system is willing to accept the PFC configuration of a neighboring device.
As per the MIB.
lldpXdot1dcbxLocPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates if the local system is capable of bypassing MACsec processing when MACsec is disabled.
As per the MIB.
lldpXdot1dcbxLocPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.3)
read-only
Indicates the number of traffic classes on the local device that might simultaneously have PFC enabled.
As per the MIB.
About this table
This table indicates if PFC is enabled on the corresponding priority on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocPFCEnablePriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.1.1)
not-accessible
Priority for which PFC is enabled or disabled.
As per the MIB.
lldpXdot1dcbxLocPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates if PFC is enabled on the corresponding priority.
As per the MIB.
About this table
This table contains entries that indicate the priority to be used for a given application.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex, lldpXdot1dcbxLocApplicationPriorityAESelector, and  lldpXdot1dcbxLocApplicationPriorityAEProtocol.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxLocApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.1)
not-accessible
LldpXdot1dcbxAppSelector
Protocol object index.
As per the MIB.
lldpXdot1dcbxLocApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.2)
not-accessible
LldpXdot1dcbxAppProtocol
Protocol ID index.
If the DCBX protocol version is the pre-standard version 1.0, the value of this object is fixed at 35078.
lldpXdot1dcbxLocApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.3)
read-only
The priority code point that should be used in frames transporting the specified protocol.
As per the MIB.
About this table
This table contains information about ETS configuration TLVs on the neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates if the credit-based shaper traffic selection algorithm is supported on a neighboring device.
As per the MIB.
lldpXdot1dcbxRemETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.2)
read-only
Indicates the number of traffic classes supported.
As per the MIB.
lldpXdot1dcbxRemETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.3)
read-only
TruthValue
true(1),
false(2)
Indicates if the remote system is willing to accept the ETS configuration recommended by the neighboring device.
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSConPriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxRemETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.1.2)
read-only
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSConTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxRemETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.1.2)
read-only
As per the MIB.
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic selection algorithm to be used by the traffic class.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress,  lldpV2RemIndex, and lldpXdot1dcbxRemETSConTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.1.1)
not-accessible
Indicates the traffic class that is assigned to a traffic selection algorithm.
As per the MIB.
lldpXdot1dcbxRemETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.1.2)
read-only
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSRecoTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxRemETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.1.2)
read-only
As per the MIB.
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic selction algorithm to be used by the priority.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSRecoTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxRemETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.1.2)
read-only
As per the MIB.
About this table
This table contains information about PFC TLVs on the neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, ldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates if a neighboring device is willing to accept the PFC configuration of the local system.
As per the MIB.
lldpXdot1dcbxRemPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
Indicates if a neighboring device is capable of bypassing MACsec processing when MACsec is disabled.
As per the MIB.
lldpXdot1dcbxRemPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.3)
read-only
Indicates the number of traffic classes on the neighboring device that might simultaneously have PFC enabled.
As per the MIB.
About this table
This table indicates if PFC is enabled on the corresponding priority on the neighbors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex. lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemPFCEnablePriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxRemPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.1.2)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex,  lldpXdot1dcbxRemApplicationPriorityAESelector, and lldpXdot1dcbxRemApplicationPriorityAEProtocol.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxRemApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxRemApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.2)
not-accessible
Protocol ID index.
As per the MIB.
lldpXdot1dcbxRemApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.3)
read-only
As per the MIB.
About this table
This table contains information about ETS configuration TLV configuration.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.1)
read-only
TruthValue
true(1),
false(2)
Indicates if the credit-based shaper traffic selection algorithm is supported.
As per the MIB.
lldpXdot1dcbxAdminETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.2)
read-only
As per the MIB.
lldpXdot1dcbxAdminETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.3)
read-write
TruthValue
true(1),
false(2)
Indicates if the local system is willing to accept the ETS configuration recommended by the remote system.
Supports only the read operation.
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSConPriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.1.2)
read-write
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSConTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.1.2)
read-write
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSConTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.1.2)
read-write
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSRecoTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.1.2)
read-write
About this table
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSRecoTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.1.2)
read-write
About this table
This table contains information about local PFC TLV configuration.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.1)
read-write
TruthValue
true(1),
false(2)
lldpXdot1dcbxAdminPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.2)
read-only
TruthValue
true(1),
false(2)
As per the MIB.
lldpXdot1dcbxAdminPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.3)
read-only
As per the MIB.
About this table
This table lists the configuration about whether PFC is enabled on the corresponding priority on the local system.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminPFCEnablePriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.1.2)
read-write
TruthValue
true(1),
false(2)
About this table
This table contains entries indicating the priority to be used for a given application.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are lldpV2LocPortIfIndex, lldpXdot1dcbxAdminApplicationPriorityAESelector, and lldpXdot1dcbxAdminApplicationPriorityAEProtocol.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.
Object (OID)
Access
Value range
Implementation
lldpXdot1dcbxAdminApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.1)
not-accessible
As per the MIB.
lldpXdot1dcbxAdminApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.2)
not-accessible
Protocol ID index.
As per the MIB.
lldpXdot1dcbxAdminApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.3)
read-create
