05-Layer 2 - LAN Switching
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10005-Layer 2 - LAN Switching
09-HH3C-VLANGROUP-MIB
09-HH3C-VLANGROUP-MIB 35.64 KB
HH3C-VLANGROUP-MIB
About this MIB
Use this MIB to configure a VLAN group.
MIB file name
hh3c-vlangroup.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVlanGroup(178)
Tabular objects
hh3cVlanGroupTable
About this table
Use this table to describe a VLAN group.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cVlanGroupName.
Object (OID)
Access
Value range
Implementation
hh3cVlanGroupName
(1.3.6.1.4.1.25506.2.178.1.1.1)
read-only
OCTET STRING
OCTET STRING (1..31)
VLAN group name
As per the MIB.
