- 05-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LPBKDT-MIB
- 05-HH3C-LswMAM-MIB
- 06-HH3C-LswMSTP-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-PVST-MIB
- 09-HH3C-VLANGROUP-MIB
- 10-HH3C-VOICE-VLAN-MIB
- 11-HH3C-LswVLAN-MIB
- 12-IEEE8021-CFM-MIB
- 13-IEEE8021-CFM-V2-MIB
- 14-IEEE8023-LAG-MIB
- 15-LLDP-EXT-MED-MIB
- 16-LLDP-EXT-DOT3-V2-MIB
- 17-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 18-LLDP-EXT-DOT1-MIB
- 19-LLDP-EXT-DOT1-V2-MIB
- 20-LLDP-EXT-DOT3-MIB
- 21-LLDP-MIB
- 22-LLDP-V2-MIB
- 23-MAU-MIB
- 24-P-BRIDGE-MIB
- 25-Q-BRIDGE-MIB
- 26-RBRIDGE-MIB
| 08-HH3C-PVST-MIB | 41.34 KB |
HH3C-PVST-MIB
About this MIB
PVST allows every VLAN to have its own spanning tree, which increases usage of links and bandwidth. Because each VLAN runs RSTP independently, a spanning tree only serves its VLAN.
Use this MIB to configure PVST.
MIB file name
hh3c-pvst.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cPvst(131)
Tabular objects
hh3cPvstVlanConfigTable
About this table
Use this table to configure a PVST VLAN.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is hh3cPvstVlanID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPvstVlanID (1.3.6.1.4.1.25506.2.131.1.1.1.1) |
read-only |
Integer32 |
1..4094 |
VLAN index. |
Not supported |
hh3cPvstVlanPortConfigTable
About this table
Use this table to configure a VLAN on a PVST port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are hh3cPvstPortVlanID and hh3cPvstPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPvstPortVlanID (1.3.6.1.4.1.25506.2.131.1.2.1.1) |
read-only |
Integer32 |
1..4094 |
VLAN index. |
Not supported |
hh3cPvstPortIndex (1.3.6.1.4.1.25506.2.131.1.2.1.2) |
read-only |
Integer32 |
1..2147483647 |
Port index. |
Not supported |
