| 02-HH3C-COMMON-SYSTEM-MIB | 86.90 KB |
hh3cSystemWorkingModeDefault (not supported)
hh3cSystemWorkingModeCurrent (not supported)
hh3cSystemWorkingModeNext (not supported)
hh3cSystemDiagInfoTable (not supported)
hh3cSystemWorkingModeTable (not supported)
hh3cSysDyingGaspTrap (not supported)
About this MIB
Use this MIB to perform basic operations on the device. For example, access this MIB to reboot the device, obtain basic system information such as reboot mode and system operating mode, and send poweroff alarms. This MIB also contains notifications about device operation changes.
MIB file name
hh3c-common-system.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cSystem(6)
Scalar objects
hh3cReboot
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cReboot (1.3.6.1.4.1.25506.6.7) |
read-write |
INTEGER |
normal(0), reboot(1) |
Reboots the device. |
As per the MIB. |
hh3cSysBootType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysBootType (1.3.6.1.4.1.25506.6.10) |
read-only |
INTEGER |
coldStart(1), warmStart(2) |
Boot mode of the system. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeDefault (1.3.6.1.4.1.25506.6.14.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Default system operating mode. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeCurrent (1.3.6.1.4.1.25506.6.14.3) |
read-only |
Integer32 |
Current system operating mode. |
Not supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeNext (1.3.6.1.4.1.25506.6.14.4) |
read-write |
Integer32 |
The system operating mode for the next startup. |
Not supported. For the modified operating mode to take effect, reboot the device, The new operating mode will take effect on the entire device. |
hh3cSysStatisticPeriod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysStatisticPeriod (1.3.6.1.4.1.25506.6.11.1) |
read-write |
Integer |
Integer (0..900) |
Statistics interval. |
The default is 0, which indicates the statistics is disabled. |
hh3cSysSamplePeriod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysSamplePeriod (1.3.6.1.4.1.25506.6.11.2) |
read-write |
Integer |
Integer (0..300) |
Sampling interval. |
The default is 0, which indicates the sampling is disabled. |
hh3cSysTrapResendPeriod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysTrapResendPeriod (1.3.6.1.4.1.25506.6.11.3) |
read-write |
Integer |
Integer (0..3600) |
Trap resending interval, in seconds. |
The default is 0, which indicates trap resending is disabled. |
hh3cSysTrapCollectionPeriod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysTrapCollectionPeriod (1.3.6.1.4.1.25506.6.11.4) |
read-write |
Integer |
Integer (0..60) |
Trap saving interval, in seconds. |
The default is 0, which indicates trap saving is disabled. |
hh3cSysNetID (not supported)
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysNetID (1.3.6.1.4.1.25506.6.11.7) |
read-write |
OCTETSTRING |
OCTET STRING (0..127) |
System Net ID. |
As per the MIB. Supports only wireless products. |
hh3cSysTrapSendNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysTrapSendNum (1.3.6.1.4.1.25506.6.11.9) |
read-write |
Integer |
Integer (0..24) |
Maximum number of times for sending a trap. |
The default is 0, which indicates trap sending is disabled. |
hh3cSysFirstTrapTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysFirstTrapTime (1.3.6.1.4.1.25506.6.11.10) |
accessible-for-notify |
Timeticks |
Standard MIB values. |
Time when a trap is sent for the first time. |
Supports only some traps. |
hh3cSysBannerMOTD
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSysBannerMOTD (1.3.6.1.4.1.25506.6.11.11) |
read-write |
OCTETSTRING |
OCTET STRING (0..2000) |
Banner message. |
As per the MIB. |
Tabular objects
About this table
This table creates diagnosis files for the system.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cSystemDiagInfoIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemDiagInfoIndex (1.3.6.1.4.1.25506.6.13.1.1) |
not-accessible |
Integer32 |
Entry index. |
As per the MIB. |
hh3cSystemDiagInfoFilename (1.3.6.1.4.1.25506.6.13.1.2) |
read-create |
DisplayString |
OCTET STRING (0..255) |
Diagnosis file name. |
As per the MIB. The system uses the default file name if you do not specify a file name during row creation. |
hh3cSystemDiagInfoRowStatus (1.3.6.1.4.1.25506.6.13.1.3) |
read-create |
RowStatus |
active(1),notInService(2),notReady(3),createAndGo(4),createAndWait(5),destroy(6) |
Row status. |
As per the MIB. |
hh3cSystemDiagInfoOperEndTime(1.3.6.1.4.1.25506.6.13.1.4) |
read-only |
TimeStamp |
Time when the operation was completed. |
As per the MIB. |
hh3cSystemDiagInfoOperState (1.3.6.1.4.1.25506.6.13.1.5) |
read-only |
INTEGER |
opInProgress(1),opSuccess(2),opFailure(3) |
Operation status. |
As per the MIB. |
hh3cSystemDiagInfoOperFailReason (1.3.6.1.4.1.25506.6.13.1.6) |
read-only |
DisplayString |
Failure reason. |
As per the MIB. |
About this table
This table contains information about the system operating modes supported on the device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cSystemWorkingModeIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSystemWorkingModeIndex (1.3.6.1.4.1.25506.6.14.1.1.1) |
not-accessible |
Integer32 |
Index of a system operating mode. |
Not supported |
hh3cSystemWorkingModeName (1.3.6.1.4.1.25506.6.14.1.1.2) |
read-only |
DisplayString |
OCTET STRING (1..32) |
Name of the system operating mode. |
Not supported |
hh3cSystemWorkingModeDescr (1.3.6.1.4.1.25506.6.14.1.1.3) |
read-only |
DisplayString |
OCTET STRING (1..128) |
Description of the system operating mode. |
Not supported |
Notifications
The following information describes the notifications included in the HH3C-COMMON-SYSTEM-MIB module.
hh3cRebootSendTrap
Basic information
OID (object name) |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.6.8.3 |
The device is to reboot |
Informational |
N/A |
N/A |
ON |
This notification is generated two seconds before the reboot command is used to reboot the device.
Status control
This alarm cannot be cleared.
Objects
OID (object name) |
Index |
Type |
Value range |
N/A |
N/A |
N/A |
N/A |
N/A |
Recommended action
No action is required.
hh3cSysColdStartTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.4 |
A cold boot was performed |
Informational |
N/A |
N/A |
ON |
This notification is generated when a cold boot is performed on the device.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.6.11.10 (hh3cSysFirstTrapTime) |
Time when the alarm occurred. |
N/A |
TimeTicks |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
hh3cSysWarmStartTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.5 |
A warm boot was performed |
Informational |
N/A |
N/A |
ON |
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
N/A |
TimeTicks |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.6.8.7 |
Poweroff alarm |
Informational |
N/A |
N/A |
ON |
This alarm occurs when the device is powered off.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
N/A |
N/A |
N/A |
N/A |
N/A |
Recommended action
Verify that the power cord is connected correctly.
