01-Fundamentals
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10001-Fundamentals
05-RFC1213-MIB
05-RFC1213-MIB 68.80 KB
RFC1213-MIB
About this MIB
The protocol-related objects and tables defined in this MIB are redefined and replaced by protocol-specific MIBs as follows:
·     For information about interfaces, see the IF-MIB MIB document.
·     For information about IP and ICMP, see the IP-MIB MIB document.
·     For information about TCP, see the TCP-MIB MIB document.
·     For information about UDP, see the UDP-MIB MIB document.
·     For information about SNMP, see the SNMPv2-MIB MIB document.
MIB file name
rfc1213.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).system(1)
Scalar objects
sysDescr
Object (OID)
Access
Value range
Implementation
sysDescr (1.3.6.1.2.1.1.1)
read-only
DisplayString
OCTET STRING (0..255)
A textual description of the entity.
As per the MIB.
sysObjectID
Object (OID)
Access
Value range
Implementation
sysObjectID (1.3.6.1.2.1.1.2)
read-only
OBJECT IDENTIFIER
Standard MIB values.
The vendor's authoritative identification of the network management subsystem contained in the entity.
As per the MIB.
sysUpTime
Object (OID)
Access
Value range
Implementation
sysUpTime (1.3.6.1.2.1.1.3)
read-only
TimeTicks
The time (in hundredths of a second) since the network management portion of the system was last re-initialized.
As per the MIB.
sysContact
Object (OID)
Access
Value range
Implementation
sysContact (1.3.6.1.2.1.1.4)
read-write
DisplayString
The textual identification of the contact person for this managed node, together with information how to contact this person.
Restores the default value by setting a zero-length string.
sysName
Object (OID)
Access
Value range
Implementation
sysName (1.3.6.1.2.1.1.5)
read-write
DisplayString
An administratively-assigned name for this managed node.
A valid name is a string of  1 to 64 characters.
sysLocation
Object (OID)
Access
Value range
Implementation
sysLocation (1.3.6.1.2.1.1.6)
read-write
DisplayString
The physical location of this device.
sysServices
Object (OID)
Access
Value range
Implementation
sysServices (1.3.6.1.2.1.1.7)
read-only
Integer32
INTEGER (0..127)
A value which indicates the set of services that this entity primarily offers.
The value is calculated as follows:
78 (2^ (2-1) + 2^ (3-1) + 2^ (4-1) + 2^ (7-1))
Layer functionality:
·     2—Datalink/subnetwork (such as bridges)
·     3—Internet (such as IP gateways).
·     4—End-to-end (such as TCP).
·     7—Applications (such as SMTP).
Tabular objects
atTable
About this table
This table contains information about ARP entries.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are atIfIndex and atNetAddress.
Object (OID)
Access
Value range
Implementation
atIfIndex (1.3.6.1.2.1.3.1.1.1)
read-write
INTEGER
The interface on which this entry's equivalence is effective.
Supports only the read operation.
atPhysAddress (1.3.6.1.2.1.3.1.1.2)
read-write
PhysAddress
The media-dependent physical address.
atNetAddress (1.3.6.1.2.1.3.1.1.3)
read-write
NetworkAddress
The network address (for example, the IP address) corresponding to the media-dependent physical address.
ipRouteTable
About this table
This table contains information about IP routes.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is ipRouteDest.
Object (OID)
Access
Value range
Implementation
ipRouteDest(1.3.6.1.2.1.4.21.1.1)
read-write
IpAddress
OCTET STRING (4)
The destination IP address of this route.
ipRouteIfIndex(1.3.6.1.2.1.4.21.1.2)
read-write
INTEGER
The index value which uniquely identifies the local interface through which the next hop of this route should be reached.
ipRouteMetric1(1.3.6.1.2.1.4.21.1.3)
read-write
INTEGER
The primary routing metric for this route.
ipRouteMetric2(1.3.6.1.2.1.4.21.1.4)
read-write
INTEGER
An alternate routing metric for this route.
ipRouteMetric3(1.3.6.1.2.1.4.21.1.5)
read-write
INTEGER
ipRouteMetric4(1.3.6.1.2.1.4.21.1.6)
read-write
INTEGER
ipRouteNextHop(1.3.6.1.2.1.4.21.1.7)
read-write
IpAddress
OCTET STRING (4)
The IP address of the next hop of this route.
ipRouteType(1.3.6.1.2.1.4.21.1.8)
read-write
INTEGER
INTEGER {other(1), invalid(2), direct(3), indirect(4)}
The type of route.
ipRouteProto(1.3.6.1.2.1.4.21.1.9)
read-only
INTEGER
INTEGER {other(1), local(2), netmgmt(3), icmp(4), egp(5), ggp(6), hello(7), rip(8), is-is(9), es-is(10), ciscoIgrp(11), bbnSpfIgp(12), ospf(13), bgp(14)}
The routing mechanism via which this route was learned.
As per the MIB.
ipRouteAge(1.3.6.1.2.1.4.21.1.10)
read-write
INTEGER
The number of seconds since this route was last updated or otherwise determined to be correct.
ipRouteMask(1.3.6.1.2.1.4.21.1.11)
read-write
IpAddress
OCTET STRING (4)
Indicates the mask to be logical-ANDed with the destination address before being compared to the value for the ipRouteDest object.
ipRouteMetric5(1.3.6.1.2.1.4.21.1.12)
read-write
INTEGER
ipRouteInfo(1.3.6.1.2.1.4.21.1.13)
read-only
OBJECT IDENTIFIER
A reference to MIB definitions specific to the particular routing protocol which is responsible for this route, as determined by the value specified in the route's ipRouteProto value.
As per the MIB.
