| 01-QoS commands | 131.44 KB |
Priority mapping commands
Priority map commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot11e-lp | dot1p-lp | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp ]
The device provides the following types of priority map.
Priority mapping |
dot11e-lp |
802.11e-local priority map. |
dot1p-lp |
802.1p-local priority map. |
dscp-lp |
DSCP-local priority map. |
lp-dot11e |
Local-802.11e priority map. |
lp-dot1p |
Local-802.1p priority map. |
lp-dscp |
Local-DSCP priority map. |
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
MAP-TABLE NAME |
Name of the priority map. |
TYPE |
Type of the priority map. |
IMPORT |
Input values of the priority map. |
EXPORT |
Output values of the priority map. |
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-local priority map to map 802.1p priority values 4 and 5 to local priority 1.
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot11e-lp | dot1p-lp | dscp-lp | lp-dot11e | lp-dot1p | lp-dscp }
For the description of other keywords, see Table 1.
# Enter 802.1p-local priority map view.
import
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of GigabitEthernet 1/0/1.
<Sysname> display qos trust interface gigabitethernet 1/0/1
Port priority information
Port priority: 0
Port dot1p priority: -
Port dscp priority: -
Port priority trust type: none
Interface type and interface number. |
Port priority |
Port priority set for the interface. |
Port dscp priority |
DSCP value rewritten for packets. If you have not rewritten the DSCP value of packets, this field displays a hyphen (-). |
Port priority trust type |
Priority trust mode on the interface: · dot1p—Uses the 802.1p priority of received packets for mapping. · dscp—Uses the DSCP precedence of received IP packets for mapping. · none—Trusts no packet priority. |
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp } [ override ]
undo qos trust
An interface does not trust any packet priority and trusts the port priority.
Interface view
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
override: Uses the priority derived through priority mapping to overwrite the original priority carried in the packet. This keyword is optional. By default, this feature is disabled.
# Set the priority trust mode to 802.1p priority on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
The port priority is 0.
Interface view
priority-value: Specifies the port priority value in the range of 0 to 7.
# Set the port priority of GigabitEthernet 1/0/1 to 2.
[Sysname-GigabitEthernet1/0/1] qos priority 2
Traffic policing commands
display qos car interface
Use display qos car interface to display the CAR configuration and statistics for interfaces.
display qos car interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the CAR configuration and statistics for all interfaces except VA interfaces. For information about VA interfaces, see PPP in Network Connectivity Configuration Guide.
If you specify a VT interface, this command displays the CAR configuration and statistics of each VA interface of the VT interface. It does not display QoS information about the VT interface.
# Display the CAR configuration and statistics for GigabitEthernet 1/0/1.
<Sysname> display qos car interface gigabitethernet 1/0/1
Direction: inbound
Rule: If-match any
CIR 128 (kbps), CBS 5120 (Bytes), PIR 128 (kbps), EBS 512 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Green packets : 0 (Packets), 0 (Bytes)
Yellow packets: 0 (Packets), 0 (Bytes)
Red packets : 0 (Packets), 0 (Bytes)
# Display the CAR information on GigabitEthernet 1/0/2.
<Sysname> display qos car interface gigabitethernet 1/0/2
Direction: inbound
Rule: If-match any
CIR 50 (%), CBS 600 (ms), EBS 0 (ms), PIR 50 (%)
Green action : pass
Interface name, including interface type and interface number. |
Direction |
Direction in which traffic policing is applied. |
Rule |
Match criteria. |
CIR |
CIR in kbps (if the CIR is specified in absolute value) or in percentage (if the CIR is specified in percentage). |
CBS |
CBS in bytes (if the CBS is specified in absolute value) or in ms (if the CBS is specified in milliseconds). When the CBS is specified in milliseconds, the actual CBS value is cbs-time × the actual CIR value. |
EBS |
EBS in bytes (if the EBS is specified in absolute value) or in ms (if the EBS is specified in milliseconds). When the EBS is specified in milliseconds, the actual EBS value is ebs-time × the actual CIR value. |
PIR |
PIR in kbps (if the PIR is specified in absolute value) or in percentage (if the PIR is specified in percentage). |
Green action |
Action to take on green packets. |
Yellow action |
Action to take on yellow packets. |
Red action |
Action to take on red packets. |
bandwidth (Interface Command Reference)
qos car (interface view)
qos carl
display qos carl
Use display qos carl to display CAR lists.
display qos carl [ carl-index ]
carl-index: Specifies a CAR list by its number in the range of 1 to 199. If you do not specify a CAR list, this command displays all CAR lists.
# Display all CAR lists.
<Sysname> display qos carl
List Rules
1 destination-ip-address range 1.1.1.1 to 1.1.1.2 per-address shared-bandwidth
2 destination-ip-address subnet 1.1.1.1 22 per-address shared-bandwidth
4 dscp 1 2 3 4 5 6 7 cs1
5 mac 0000-0000-0000
6 mpls-exp 0 1 2
9 precedence 0 1 2 3 4 5 6 7
10 source-ip-address range 1.1.1.1 to 1.1.1.2
11 source-ip-address subnet 1.1.1.1 31
Use qos car to configure a CAR policy on an interface.
Use undo qos car to delete a CAR policy from an interface.
Static CAR:
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index }
Dynamic CAR:
qos car { inbound | outbound } carl carl-index cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ max-cir max-committed-information-rate ] [ green action | red action | yellow action ] *
undo qos car { inbound | outbound } carl carl-index
No CAR policy is configured.
Interface view
inbound: Performs CAR for incoming packets on the interface.
outbound: Performs CAR for outgoing packets on the interface.
any: Performs CAR for all IP packets in the specified direction.
acl [ ipv6 ] acl-number: Performs CAR for packets matching an ACL specified by its number. The value range for the acl-number argument is 2000 to 2999 for basic ACLs and 3000 to 3999 for advanced ACLs. If you do not specify ipv6, this option specifies an IPv4 ACL. If you specify ipv6, this option specifies an IPv6 ACL.
carl carl-index: Performs CAR for packets matching a CAR list specified by its number in the range of 1 to 199.
cir committed-information-rate: Specifies the CIR in kbps. The value range for committed-information-rate is 8 to 10000000.
cbs committed-burst-size: Specifies the CBS in bytes, which is the size of bursty traffic when the actual average rate is not greater than the CIR. The value range for committed-burst-size is 1000 to 1000000000. The default CBS is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 1000000000. The default EBS is 0.
pir peak-information-rate: Specifies the PIR in kbps. The value range for peak-information-rate is 8 to 10000000.
green: Specifies the action to take on packets when the traffic rate conforms to the CIR. The default is pass.
red: Specifies the action to take on packets when the traffic rate conforms to neither CIR nor PIR. The default is discard.
yellow: Specifies the action to take on packets when the traffic rate exceeds the CIR but conforms to the PIR. The default is pass.
action: Specifies the action to take on packets:
· continue: Continues to process the packet by using the next CAR policy.
· discard: Drops the packet.
· pass: Permits the packet to pass through.
· remark-dot1p-continue new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and continues to process the packet by using the next CAR policy. The new-cos argument is in the range of 0 to 7.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-continue new-dscp: Remarks the packet with a new DSCP value and continues to process the packet by using the next CAR policy. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-mpls-exp-continue new-exp: Sets the EXP field value of the MPLS packet to new-exp and continues to process the packet by using the next CAR policy. The new-exp argument is in the range of 0 to 7.
· remark-mpls-exp-pass new-exp: Sets the EXP field value of the MPLS packet to new-exp and permits the packet to pass through. The new-exp argument is in the range of 0 to 7.
· remark-prec-continue new-precedence: Re-marks the packet with a new IP precedence and continues to process the packet by using the next CAR policy. The new-precedence argument is in the range of 0 to 7.
· remark-prec-pass new-precedence: Re-marks the packet with a new IP precedence and permits the packet to pass through. The new-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the qos car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the qos car command without the pir peak-information-rate option.
You can configure multiple qos car commands on an interface to define multiple CAR policies. These CAR policies are executed in their configuration order.
# Perform CAR for all packets in the outbound direction of GigabitEthernet 1/0/1. The CAR parameters are as follows:
· CIR is 200 kbps.
· CBS is 5120 bytes.
· EBS is 0.
· Conforming packets are transmitted.
· Excess packets are set with an IP precedence of 0 and transmitted.
[Sysname-GigabitEthernet1/0/1] qos car outbound any cir 200 cbs 5000 ebs 0 green pass red remark-prec-pass 0
qos carl
qos car (user profile view)
Use qos car any to configure a CAR policy for all packets of a user profile.
Use undo qos car to delete a CAR policy from a user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound } any
User profile view
inbound: Performs CAR for incoming traffic.
outbound: Performs CAR for outgoing traffic.
any: Performs CAR for all traffic.
cbs committed-burst-size: Specifies the committed burst size (CBS) in the range of 1000 to 1000000000 bytes. The default CBS is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in the range of 0 to 1000000000 bytes. The default EBS is 0.
The conforming traffic is permitted to pass through, and the excess traffic is dropped.
If you execute the qos car command multiple times for the same user profile or session group profile, the most recent configuration takes effect.
# Perform CAR for packets received by user profile user. The CAR parameters are as follows:
· The CIR is 200 kbps.
· The CBS is 51200 bytes.
[Sysname] user-profile user
[Sysname-user-profile-user] qos car outbound any cir 200 cbs 51200
qos car percent (interface view)
Use qos car percent to configure a CAR policy in percentage on an interface.
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } percent cir cir-percent [ cbs cbs-time [ ebs ebs-time ] ] [ green action | red action | yellow action ] *
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number | carl carl-index } percent cir cir-percent [ cbs cbs-time ] pir pir-percent [ ebs ebs-time ] [ green action | red action | yellow action ] *
No CAR policy is configured in percentage.
Interface view
any: Performs CAR for all IP data packets in the specified direction.
percent cir cir-percent: Specifies the CIR in percentage, in the range of 1 to 100. The actual CIR value is cir-percent × interface bandwidth.
cbs cbs-time: Specifies the CBS in milliseconds. The actual CBS value is cbs-time × the actual CIR value. The value range for the cbs-time argument is 50 to 2000. The default CBS is 500 bytes.
ebs ebs-time: Specifies the EBS in milliseconds. The actual EBS value is ebs-time × the actual CIR value. The value range for the ebs-time argument is 0 to 2000. The default EBS is 0.
pir pir-percent: Specifies the PIR in percentage, in the range of 1 to 100. The value for the pir-percent argument must be greater than or equal to the value for the cir-percent argument.
green: Specifies the action to take on packets when the traffic rate conforms to CIR. The default is pass.
yellow: Specifies the action to take on packets when the traffic rate exceeds CIR but conforms to PIR. The default is pass.
· remark-dot1p-continue new-cos: Sets the 802.1p priority value of the packet to new-cos and continues to process the packet by using the next CAR policy. The new-cos argument is in the range of 0 to 7.
· remark-dot1p-pass new-cos: Sets the 802.1p priority value of the packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
· remark-dscp-continue new-dscp: Sets the DSCP value of the packet and continues to process the packet by using the next CAR policy. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-dscp-pass new-dscp: Sets the DSCP value of the packet and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
· remark-prec-continue new-precedence: Sets the IP precedence of the packet and continues to process the packet by using the next CAR policy. The new-precedence argument is in the range of 0 to 7.
· remark-prec-pass new-precedence: Sets the IP precedence of the packet and permits the packet to pass through. The new-precedence argument is in the range of 0 to 7.
To use two rates for traffic policing, configure the qos car percent command with the pir pir-percent option. To use one rate for traffic policing, configure the qos car percent command without the pir pir-percent option.
You can configure multiple qos car percent commands on an interface to define multiple CAR policies. These CAR policies are executed in their configuration order.
# Perform CAR for all outgoing packets on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos car outbound any percent cir 50 cbs 1000
qos carl
Use qos carl to create or modify a CAR list.
Use undo qos carl to delete a CAR list.
qos carl carl-index { dscp dscp-list | mac mac-address | mpls-exp mpls-exp-value | precedence precedence-value | { destination-ip-address | source-ip-address } { range start-ip-address to end-ip-address | subnet ip-address mask-length } [ per-address [ shared-bandwidth ] ] }
undo qos carl carl-index
No CAR list is configured.
dscp dscp-list: Specifies a list of DSCP values. A DSCP value can be a number from 0 to 63 or any of the following keywords af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef. You can configure up to eight DSCP values in one command line. If the same DSCP value is specified multiple times, the system considers the values to be one value. If a packet matches one of the defined DSCP values, it matches the if-match clause.
mac mac-address: Specifies a MAC address in hexadecimal format.
mpls-exp mpls-exp-value: Specifies an MPLS EXP value in the range of 0 to 7. You can configure up to eight MPLS EXP values in one command line. If the same MPLS EXP value is specified multiple times, the system considers the values to be one value. If a packet matches one of the defined MPLS EXP values, it matches the if-match clause.
precedence precedence: Specifies a precedence value in the range of 0 to 7. You can configure up to eight IP precedence values in one command line. If the same IP precedence value is specified multiple times, the system considers the values to be one value. If a packet matches one of the defined IP precedence values, it matches the if-match clause.
destination-ip-address: Configures a destination IP address-based CAR list.
source-ip-address: Configures a source IP address-based CAR list.
range start-ip-address to end-ip-address: Specifies an IP address range by the start address and end address. The value for end-ip-address must be greater than the value for start-ip-address. The maximum number of IP addresses that an IP address range can accommodate is 1024.
subnet ip-address mask-length: Specifies a subnet by the IP subnet address and IP subnet address mask length. The value range for mask-length is 22 to 31.
per-address: Performs per-IP address rate limiting within the network segment. When this keyword is specified, the CIR is dedicated bandwidth for each IP address and is not shared by any other IP address. If you do not specify this keyword, the following events occur:
· Rate limiting is performed for the entire network segment.
· All of the CIR is allocated among all IP addresses in proportion to the traffic load of each IP address.
shared-bandwidth: Specifies that traffic of all IP addresses within the network segment shares the remaining bandwidth (the CIR). If you specify this keyword, all of the CIR is allocated evenly among all IP addresses with traffic load.
You can create a CAR list based on IP precedence, MAC address, MPLS EXP, DSCP, or IP network segment.
If you execute this command multiple times for the same CAR list, the most recent configuration takes effect. If you execute this command multiple times for different CAR lists, multiple CAR lists are created.
To perform rate limiting for a single IP address, use the qos car acl command in interface view.
# Apply CAR list 1 to the outbound direction of GigabitEthernet 1/0/1 to meet the following requirements:
· The rate of each host on the subnet 1.1.1.0/24 is limited to 512 kbps.
· Traffic of IP addresses in the subnet does not share the remaining bandwidth.
[Sysname] qos carl 1 source-ip-address subnet 1.1.1.0 24 per-address
[Sysname-GigabitEthernet1/0/1] qos car outbound carl 1 cir 512 cbs 5120 ebs 0 green pass red discard
# Apply CAR list 2 to the outbound direction of GigabitEthernet 1/0/1 to meet the following requirements:
· The rate of each host in the IP address range of 1.1.2.100 to 1.1.2.199 is limited to 5 Mbps.
· Traffic of IP addresses in the subnet shares the remaining bandwidth.
[Sysname] qos carl 2 source-ip-address range 1.1.2.100 to 1.1.2.199 per-address shared-bandwidth
[Sysname-GigabitEthernet1/0/1] qos car outbound carl 2 cir 5120 cbs 51200 ebs 51200 green pass red discard
display qos carl
qos car
Global CAR commands
display qos car name
Use display qos car name to display information about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command displays information about all global CAR actions.
# Display information about all global CAR actions.
<Sysname> display qos car name
Mode: aggregative
CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Green action : pass
Slot 0:
Table 5 Command output
Name |
Name of the global CAR action. |
Mode |
Type of the CAR action, which can only be aggregative. |
CIR CBS PIR EBS |
Parameters for the CAR action. |
Green action |
Action to take on green packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Yellow action |
Action to take on yellow packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Red action |
Action to take on red packets: · discard—Drops the packets. · pass—Permits the packets to pass through. |
Green packet |
Statistics about green packets. |
Yellow packet |
Statistics about yellow packets. |
Red packet |
Statistics about red packets. |
Use qos car to apply an aggregate CAR action to an interface.
Use undo qos car to remove an aggregate CAR action from an interface.
qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number } name car-name
undo qos car { inbound | outbound } { any | acl [ ipv6 ] acl-number }
No aggregate CAR action is applied to an interface.
Interface view
inbound: Performs aggregate CAR for incoming packets.
outbound: Performs aggregate CAR for outgoing packets.
any: Performs aggregate CAR for all IP packets.
acl acl-number: Performs aggregate CAR for packets matching an IPv4 ACL. The value range for acl-number is 2000 to 3999.
acl ipv6 acl-number: Performs aggregate CAR for packets matching an IPv6 ACL. The acl-number is in the range of 2000 to 3999.
name car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
You can apply multiple aggregate CAR actions to an interface. These aggregate CAR actions are executed in the order they are configured.
# Apply aggregate CAR action aggcar-1 to the inbound packets matching CAR list 1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos car inbound carl 1 name aggcar-1
qos car (system view)
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the global CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
aggregative: Specifies the global CAR action as an aggregate CAR action.
cir committed-information-rate: Specifies the CIR in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 10000000.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for committed-burst-size is 1000 to 1000000000. The default value for this argument is the product of 62.5 and the CIR.
ebs excess-burst-size: Specifies the EBS in bytes. The value range for excess-burst-size is 0 to 1000000000. If the PIR is configured, the default EBS is the product of 62.5 and the PIR.
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
· remark-dscp-pass new-dscp: Sets the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
To use two rates for aggregate CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for aggregate CAR, configure the qos car command without the pir peak-information-rate option.
An aggregate CAR action takes effect only after it is applied to an interface.
# Configure aggregate CAR action aggcar-1, where CIR is 25600, CBS is 512000, and red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name
Use reset qos car name to clear the statistics about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command clears statistics for all global CAR actions.
# Clear the statistics about global CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
